  4. ioBroker extrem langsam
iobrokerlangsamkeine aktualisierung möglich
95 Beiträge 8 Kommentatoren 19.0k Aufrufe 6 Beobachtet
  • S Spidermike
    @homoran sagte in ioBroker extrem langsam:
    @spidermike sagte in ioBroker extrem langsam:
    kannst Du mir auch mal helfen ?
    und wie?
    Sorry war ich noch nicht so weit
    hoffe es ist besser so und du kannst damit was anfangen?
                            v.2023-10-10
       Static hostname: raspberrypi4-iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.61-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     150
    Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/build/lib/objects/objectsInRedisClient.js:493:23)
        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v20.7.0
                            /usr/bin/node           v20.7.0
                            /usr/bin/npm            10.1.0
                            /usr/bin/npx            10.1.0
                            /usr/bin/corepack       0.19.0
    Recommended versions are nodejs  Cannot determine Set feature status: Connection is closed.
     Connection is closed. and npm
    MEMORY:
    Mem:            7.9G        1.9G        4.6G        0.0K        1.4G        5.8G
    Swap:            99M          0B         99M
    Total:          8.0G        1.9G        4.7G
    Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/build/lib/states/statesInRedisClient.js:459:23)
    Active iob-Instances:   0
    No connection to databases possible ...
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.10.1
    ioBroker Status:         Cannot determine Set feature status: Connection is closed.
    Objects:                3
    States:                 1
    Size of iob-Database:
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.broken
    5.0M    /opt/iobroker/iobroker-data/objects.json.migrated
    5.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    33M     /opt/iobroker/iobroker-data/states.jsonl
    3.0M    /opt/iobroker/iobroker-data/states.json.migrated
    3.0M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    === Mark text until here for copying ===
    pi@raspberrypi4-iobroker:~ $ ======= Start marking the full check here =========
    -bash: =======: Kommando nicht gefunden.
    vpi@raspberrypi4-iobroker:~ $
    > Skript v.2023-10-10
    > *** BASE SYSTEM ***
    >          Icon name: computer
    >       Architecture: arm
    /> Model           : Raspberry Pi 4 Model B Rev 1.4
    > Docker          : false
    > Virtualization  : none
    > Kernel          : armv7l
    > Userland        : armhf
    j> Systemuptime and Load:
    >  14:57:05 up  3:21,  1 user,  load average: 3.31, 3.28, 3.17
    > CPU threads: 4
    l>
    e> *** RASPBERRY THROTTLING ***
    > Current issues:
    > No throttling issues detected.
    > Previously detected issues:
    s> *** Time and Time Zones ***
    >                Local time: Sun 2023-10-15 14:57:05 CEST
    >            Universal time: Sun 2023-10-15 12:57:05 UTC
    >                  RTC time: n/a
    >                 Time zone: Europe/Berlin (CEST, +0200)
    > System clock synchronized: yes
    >               NTP service: active
    >           RTC in local TZ: no
    > *** User and Groups ***
    > pi
    2> /home/pi
    > pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *> *** X-Server-Setup ***
    > X-Server:       false
    > Desktop:
    > Terminal:       tty
    > Boot Target:    graphical.target
     > *** MEMORY ***
    >                total        used        free      shared  buff/cache   available
    > Mem:            7.9G        1.8G        4.7G        0.0K        1.4G        5.9G
    > Swap:            99M          0B         99M
    > Total:          8.0G        1.8G        4.8G
    1>          7897 M total memory
    >          1848 M used memory
    >           360 M active memory
    >          2747 M inactive memory
    >          4650 M free memory
    >            96 M buffer memory
    >          1302 M swap cache
    >            99 M total swap
    >             0 M used swap
    >            99 M free swap
    > Raspberry only:
    > oom events: 0
    > lifetime oom required: 0 Mbytes
    > total time in oom handler: 0 ms
    > max time spent in oom handler: 0 ms
    > *** FAILED SERVICES ***
     >   UNIT LOAD ACTIVE SUB DESCRIPTION
    > 0 loaded units listed.
    m> *** FILESYSTEM ***
    > Filesystem     Type      Size  Used Avail Use% Mounted on
    > /dev/root      ext4      118G   23G   90G  21% /
    > devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    > tmpfs          tmpfs     3.9G   16K  3.9G   1% /dev/shm
    > tmpfs          tmpfs     1.6G  896K  1.6G   1% /run
    > tmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    > /dev/sdb1      exfat      29G  3.0G   26G  11% /mnt/usb0
    > /dev/sda1      vfat      253M   50M  203M  20% /boot
    > tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    > Messages concerning ext4 filesystem in dmesg:
    > [Sun Oct 15 11:35:23 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:FD:BB:CC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 console=ttyS0,115200 root=PARTUUID=1045efe5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    > [Sun Oct 15 11:35:26 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    > [Sun Oct 15 11:35:26 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    > [Sun Oct 15 11:35:30 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    > Show mounted filesystems \(real ones only\):
    > TARGET      SOURCE    FSTYPE OPTIONS
    > /           /dev/sda2 ext4   rw,noatime
    > |-/mnt/usb0 /dev/sdb1 exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dmask=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    > `-/boot     /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    -bash: Skript: Kommando nicht gefunden.
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    -bash: Static: Kommando nicht gefunden.
    -bash: Icon: Kommando nicht gefunden.
    -bash: command substitution: Zeile 7: Syntaxfehler beim unerwarteten Symbol »(«
    -bash: command substitution: Zeile 7: `  Operating System: Raspbian GNU/Linux 11 (bullseye)'
    -bash: -/boot: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi4-iobroker:~ $ Files in neuralgic directories:
    -bash: Files: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ /var:
    -bash: /var:: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi4-iobroker:~ $ 4.7G    /var/
    -bash: 4.7G: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 4.1G    /var/log
    -bash: 4.1G: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 3.9G    /var/log/journal/ceda8666c83a44189d7d8b22875c3095
    -bash: 3.9G: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 485M    /var/lib
    -bash: 485M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ Archived and active journals take up 3.8G in the file system.
    -bash: Archived: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ /opt/iobroker/backups:
    -bash: /opt/iobroker/backups:: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi4-iobroker:~ $ 6.2G    /opt/iobroker/backups/
    -bash: 6.2G: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ /opt/iobroker/iobroker-data:
    -bash: /opt/iobroker/iobroker-data:: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi4-iobroker:~ $ 881M    /opt/iobroker/iobroker-data/
    -bash: 881M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 404M    /opt/iobroker/iobroker-data/history
    -bash: 404M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 324M    /opt/iobroker/iobroker-data/files
    -bash: 324M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 84M     /opt/iobroker/iobroker-data/backup-objects
    -bash: 84M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 52M     /opt/iobroker/iobroker-data/files/javascript.admin
    -bash: 52M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ The five largest files in iobroker-data are:
    -bash: The: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    -bash: 35M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 25M     /opt/iobroker/iobroker-data/states.jsonl
    -bash: 25M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    -bash: 21M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    -bash: 19M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ 18M     /opt/iobroker/iobroker-data/objects.jsonl
    -bash: 18M: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ USB-Devices by-id:
    -bash: USB-Devices: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
    -bash: USB-Sticks: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ find: '/dev/serial/by-id/': No such file or directory
    -bash: find:: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ *** NodeJS-Installation ***
    iobroker [command]
    Commands:
    Options:
    pi@raspberrypi4-iobroker:~ $ /usr/bin/nodejs         v20.7.0
    node:internal/modules/cjs/loader:1051
      throw err;
    Error: Cannot find module '/home/pi/v20.7.0'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
        at Module._load (node:internal/modules/cjs/loader:901:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)
        at node:internal/main/run_main_module:23:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v20.7.0
    pi@raspberrypi4-iobroker:~ $ /usr/bin/node           v20.7.0
      throw err;
      requireStack: []
    Node.js v20.7.0
    pi@raspberrypi4-iobroker:~ $ /usr/bin/npm            10.1.0
    Unknown command: "10.1.0"
    To see a list of supported npm commands, run:
      npm help
    pi@raspberrypi4-iobroker:~ $ /usr/bin/npx            10.1.0
    npm notice
    npm notice New minor version of npm available! 10.1.0 -> 10.2.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.2.0
    npm notice Run npm install -g npm@10.2.0 to update!
    npm notice
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/10.1.0 - Not found
    npm ERR! 404
    npm ERR! 404  '10.1.0@*' is not in this registry.
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-15T13_03_33_846Z-debug-0.log
    pi@raspberrypi4-iobroker:~ $ /usr/bin/corepack       0.19.0
    Unknown Syntax Error: Command not found; did you mean one of:
      0. corepack -h
      1. corepack -v
      2. corepack enable [--install-directory #0] ...
      3. corepack disable [--install-directory #0] ...
      4. corepack hydrate [--activate] <fileName>
      5. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
    While running 0.19.0
    pi@raspberrypi4-iobroker:~ $ nodejs:
    -bash: nodejs:: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $   Installed: 20.7.0-1nodesource1
    -bash: Installed:: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $   Candidate: 20.8.1-1nodesource1
    -bash: Candidate:: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $   Version table:
    -bash: Version: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.8.1-1nodesource1 500
    -bash: 20.8.1-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $         500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
    -bash: 500: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.8.0-1nodesource1 500
    -bash: 20.8.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $  *** 20.7.0-1nodesource1 500
    iobroker [command]
    Commands:
    Options:
    pi@raspberrypi4-iobroker:~ $         100 /var/lib/dpkg/status
    -bash: 100: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.6.1-1nodesource1 500
    -bash: 20.6.1-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.6.0-1nodesource1 500
    -bash: 20.6.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.5.1-1nodesource1 500
    -bash: 20.5.1-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.5.0-1nodesource1 500
    -bash: 20.5.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.4.0-1nodesource1 500
    -bash: 20.4.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.3.1-1nodesource1 500
    -bash: 20.3.1-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.3.0-1nodesource1 500
    -bash: 20.3.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.2.0-1nodesource1 500
    -bash: 20.2.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.1.0-1nodesource1 500
    -bash: 20.1.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      20.0.0-1nodesource1 500
    -bash: 20.0.0-1nodesource1: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $      12.22.12~dfsg-1~deb11u4 500
    -bash: 12.22.12~dfsg-1~deb11u4: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $         500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    pi@raspberrypi4-iobroker:~ $ Temp directories causing npm8 problem: 0
    -bash: Temp: Kommando nicht gefunden.
    pi@raspberrypi4-iobroker:~ $ No problems detected
    -bash: No: Kommando nicht gefunden.
                            v.2023-10-10
             Icon name: computer
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    User-ID:                1000
    X-Server:               false
                            /usr/bin/npm            10.1.0
                            /usr/bin/npx            10.1.0
    MEMORY:
    Swap:            99M          0B         99M
    @spidermike wieso sind da so seltsam zeilen/zeichen mittendr7n?
      Spidermike
      keine ahnung hab es mit Putty laufen lassen und dann wollte ich es einfach nur kopieren und dann kam das raus ☹
      • S Spidermike
        haselchenH Offline
        haselchenH Offline
        haselchen
        @spidermike
        Vielleicht solltest Du auch mal die 150! Updates einspielen.....
        Thomas BraunT S 2 Antworten Letzte Antwort
        • haselchenH haselchen
          @spidermike
          @haselchen sagte in ioBroker extrem langsam:
          Das selbstverständlich auch.
            @spidermike
            Mach es nochmal.
            Und auf Basis von nodejs@18.
            Spidermike
            @thomas-braun sagte in ioBroker extrem langsam:
            @spidermike
            Mach es nochmal.
            wie komme ich jetzt wieder auf nodejs 18?
            ich hatte letzte Woche extreme Probleme und bin froh das es jetzt wieder halbwegs läuft.
            Dachte schon alles verloren zu haben und iobroker komplett neu machen zu müssen.
            noch nichtmal mein backup wurde mehr akzeptiert.
            Ich brauche mal jemanden der mir schreibt was hier falsch läuft und wie ich was richtig einstelle
              @spidermike
              Spidermike
              @spidermike
              150 Updates? Dashboard zeigt mit nichts mit Updates?
              ? HomoranH 2 Antworten Letzte Antwort
              • S Spidermike
                @spidermike
                Mach es nochmal.
                Damit:
                https://forum.iobroker.net/topic/69068/neuer-befehl-iob-nodejs-update
                • S Spidermike
                  @spidermike
                  Moin,
                  das sind Betriebssystem Updates, keine ioBroker Updates!
                  Bernd
                    Moin,
                    Bernd
                    Spidermike
                    Ich glaube ich bin ein bisschen überfordert.
                    Am besten ich speichere ich meine Blockly Scripts und mache alles platt uns setze es neu auf denn da sind bestimmt so viele Probleme und Baustellen.
                    Die Ladezeit beim start von iobroker komme ich mir vor ich bin in den 1990 mit einen 386er 😰
                    • S Spidermike
                      @spidermike
                      du hast zwar das neueste M$ Office, läufst aber noch auf WIN95
                        Damit:
                        Spidermike
                        schrieb am zuletzt editiert von Spidermike
                        könntest Du mir mal die genaue reihenfolge schreiben was ich bei Putty eingeben muss.
                        für euch ist das alles selbstverständlich aber für mich ist das alles latein rückwärts.
                        Ich versuche schon immer alles zu lesen aber wirklich kapieren tu ich es halt nicht.
                        Und wenn ich dann immer nur auf irgendwelche anderen Threads verwiesen werde dann lese ich wieder wie ein blöder und komme nicht weiter.
                        Sorry ich würde ja das gerne alles verstehen und mitreden können aber es klappt halt nicht mehr
                        • S Spidermike
                          iob node-update
                            iob node-update
                            Spidermike
                            iob node-update
                            login as: pi
                            pi@192.168.178.78's password:
                            Linux raspberrypi4-iobroker 5.15.61-v7l+ #1579 SMP Fri Aug 26 11:13:03 BST 2022        armv7l
                            permitted by applicable law.
                            Last login: Sun Oct 15 19:47:53 2023 from 192.168.178.20
                            pi@raspberrypi4-iobroker:~ $ iob node-update
                            iobroker [command]
                            Commands:
                            Options:
                            dann bekomme ich das als antwort
                            • S Spidermike
                              iob node-update
                              login as: pi
                              iobroker [command]
                              Commands:
                              Options:
                              dann
                              iob stop
                              iob fix
                              iob start
                              w a r t e n
                              iob node-update
                                dann
                                iob stop
                                iob fix
                                iob start
                                w a r t e n
                                iob node-update
                                Spidermike
                                iob start
                                Warum bekomme ich da eine Fehlermeldung
                                OK:1 http://phoscon.de/apt/deconz bullseye InRelease
                                OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                Holen:3 https://repos.influxdata.com/debian bullseye InRelease [7.040 B]
                                Holen:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15,0 kB]
                                OK:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Fehl:3 https://repos.influxdata.com/debian bullseye InRelease
                                  Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                Es wurden 22,0 kB in 2 s geholt (14,6 kB/s).
                                W: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. GPG-Fehler: https://repos.influxdata.com/debian bullseye InRelease: Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Fehlschlag beim Holen von https://repos.influxdata.com/debian/dists/bullseye/InRelease Die folgenden Signaturen konnten nicht überprüft werden, weil ihr öffentlicher Schlüssel nicht verfügbar ist: NO_PUBKEY D8FF8E1F7DF8B07E
                                W: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
                                • S Spidermike
                                  iob start
                                  @spidermike
                                  Weil du das influxdb-Repository nicht aktuell gehalten hast.
                                    dann
                                    iob stop
                                    iob fix
                                    iob start
                                    w a r t e n
                                    iob node-update
                                    Spidermike
                                    dann
                                    iob stop
                                    iob fix
                                    iob start
                                    w a r t e n
                                    iob node-update
                                    erledigt bekomme aber das gleiche wie ich schon gepostet hab
                                    iobroker [command]
                                    Commands:
                                    Options:
                                    • S Spidermike
                                      dann
                                      iob stop
                                      iob fix
                                      iob start
                                      w a r t e n
                                      iob node-update
                                      iobroker [command]
                                      Commands:
                                      Options:
                                      @spidermike
                                      iob nodejs-update
                                        @spidermike
                                        iob nodejs-update
                                        Spidermike
                                        iob nodejs-update
                                        es tut sich jetzt etwas 👍
                                        wie kann ich dann influxdb-Repository aktualisieren?
                                          @spidermike
                                          iob nodejs-update
                                          Spidermike
                                          @spidermike
                                          iob nodejs-update
                                          danke Dir bzw. ihr seid der Wahnsinn, es hat funktioniert.
                                          Der 1. Eindruck beim starten. "jetzt hab ich ein Ferrari"
                                          was muss ich jetzt machen das es auch so bleibt?
