  4. iob node fix - Skript
    apollon77A
198 Beiträge 34 Kommentatoren 80.5k Aufrufe 37 Beobachtet
  • JoJo58J JoJo58
    @thomas-braun Das sieht schon besser aus. Wie soll ich weitermachen?
    ioBroker nodejs fixer 2023-10-07
    Recommended nodejs-version is: 18.18.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    /usr/bin/corepack       0.18.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v18.17.1. Do you want to install recommended version 18.18.0?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/run/user/1000/gvfs': Permission denied
    Virtualization: kvm
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Reading package lists... Done
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:6 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
    Fetched 17.4 kB in 0s (40.2 kB/s)
    Installing the recommended nodejs version now!
    Installing the recommended nodejs version!
    (Reading database ... 100420 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.18.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
    Setting up nodejs (18.18.0-1nodesource1) ...
    Processing triggers for man-db (2.11.2-2) ...
    *** You need to manually restart your container/virtual machine now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    smarthome@vm-iobroker:~$
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #188
    @jojo58 sagte in iob node fix - Skript:
    VM/Container neustarten. Und dann nochmal das Skript. Sollte dann mit doppeltem 'Nothing to do' verkünden, das alles i. O. ist.
    JoJo58J 1 Antwort Letzte Antwort
      JoJo58J
      JoJo58J
      JoJo58
      #189
      @thomas-braun Super, hat jetzt funktioniert. Danke dir. 👍
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      nodejs:
       Installed: 18.18.0-1nodesource1
       Candidate: 18.18.0-1nodesource1
       Version table:
      *** 18.18.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
          18.17.1-1nodesource1 1001
          18.17.0-1nodesource1 1001
          18.16.1-1nodesource1 1001
          18.16.0-1nodesource1 1001
          18.15.0-1nodesource1 1001
          18.14.2-1nodesource1 1001
          18.14.1-1nodesource1 1001
          18.14.0-1nodesource1 1001
          18.13.0+dfsg1-1 500
          18.13.0-1nodesource1 1001
          18.12.0-1nodesource1 1001
          18.11.0-1nodesource1 1001
          18.10.0-1nodesource1 1001
          18.9.1-1nodesource1 1001
          18.9.0-1nodesource1 1001
          18.8.0-1nodesource1 1001
          18.7.0-1nodesource1 1001
          18.6.0-1nodesource1 1001
          18.5.0-1nodesource1 1001
          18.4.0-1nodesource1 1001
          18.3.0-1nodesource1 1001
          18.2.0-1nodesource1 1001
          18.1.0-1nodesource1 1001
          18.0.0-1nodesource1 1001
      Nothing to do - Your version is the recommended one.
      You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
      Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
      Jetzt kann ich mich meinem JavaScript Adapter Problem zuwenden.
      Intel NUC i7 64GB 1TB SSD - Proxmox - Raspi 4 8GB 500 GB SSD - Raspi 4 4GB 500GB SSD - Qnap 16TB - CCU3 - Fritz 6591 Cable - Green Cell USV 1500VA
      Sonoff CC2652P - HUE Bridge - Broadlink RM4 pro u. RM3 mini - 5 x Echo - 1 x Samsung STab 8 - 54 x HM und HMIP - 32 x Zigbee - 2 x Shelly 3EM.
      Einfach ein tolles Hobby :-)
      • JoJo58J JoJo58
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
         Version table:
            18.13.0+dfsg1-1 500
        Thomas BraunT
        Thomas BraunT
        #190
        @jojo58
        Okay. Danke für die Hilfe beim Debuggen.
        Allerdings auch hier nochmal der Hinweise bzw. die dringende Empfehlung:
        Server NIE mit Desktop/graphischer Oberfläche betreiben!
        Da rumpelt nämlich ein gnome oder etwas davon abgeleitetes mit über dein System. Komplett unnötig. Und vermutlich mit der Auslöser für das Verhalten des Skripts.
          @jojo58
          JoJo58J
          JoJo58J
          JoJo58
          #191
          @thomas-braun Die grafische Oberfläche habe ich doch schon vor 4 Wochen runtergeschmissen? Wahrscheinlich hat das nicht sauber geklappt. Mist aber auch...
          • JoJo58J JoJo58
            Thomas BraunT
            Thomas BraunT
            #192
            runtergeschmissen?
            Komplett runtergeschmissen oder lediglich deaktiviert?
              runtergeschmissen?
              JoJo58J
              JoJo58J
              JoJo58
              #193
              @thomas-braun Komplett runtergeschmissen. Hoffe das war richtig so:
              sudo apt-get autoremove gdm3
              und
              sudo apt-get autoremove --purge gnome*
              • JoJo58J JoJo58
                und
                Thomas BraunT
                Thomas BraunT
                #194
                Das weiß ich nicht. Kenne dein System ja nicht.
                • U
                  U
                  UV-on-fire
                  #195
                  Ich habe am Sonntag mit dem Script auf V18.18.0 upgedatet. Hat auch alles geklappt. Allerdings besteht da ja das Problem das Backitup nicht sauber läuft.
                  Siehe Hier
                  Jetzt wollte ich eben auf 18.18.1 updaten aber das funktioniert nicht. Ausgabe des Skripts:
                   You are running nodejs v18.18.0. Do you want to install recommended version 18.18.1?
                  [sudo] password for uviob:
                  Sorry, try again.
                  Virtualization: lxc
                  Hit:1 http://security.debian.org bullseye-security InRelease
                  Hit:2 http://ftp.debian.org/debian bullseye InRelease
                  Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                  Package: nodejs
                  Pin-Priority: 1001
                  Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                  Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5540 B]
                  Err:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                    Hashes of expected file:
                     - Filesize:5540 [weak]
                     - SHA512:42fc03dd54ad0876c94818799e4c58fe6b1f55a39d99237e22eea4b127f782f1b893ed734c5d80c1c7fec87e88ece4373920aaa4792d1f25b28b398c093fd63c
                     - SHA256:38b78587e1a99e9c1b861ea8dd3a29e192dfae63e108aafd17b7f60bd6acd23f
                     - SHA1:d31595d3ddf7337cec92847e9ed8551f4addc693 [weak]
                     - MD5Sum:d69fd7a6e53a348af97ca66bf65317bf [weak]
                    Release file created at: Tue, 10 Oct 2023 17:30:21 +0000
                  Fetched 12.1 kB in 1s (22.5 kB/s)
                  E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:41a 443]
                  E: Some index files failed to download. They have been ignored, or old ones used instead.
                  Hier noch die Ausgabe von Diag
                  Lang:
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer-container
                             Chassis: container
                          Machine ID: c337b259b2a44b9da1e2356e14b395e6
                             Boot ID: 9fcb0b446bb94c388a463a906e17bdf2
                      Virtualization: lxc
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.2.16-14-pve
                        Architecture: x86-64
                  model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : amd64
                  Systemuptime and Load:
                   19:49:54 up 0 min,  1 user,  load average: 1.05, 0.62, 0.74
                  CPU threads: 1
                  *** Time and Time Zones ***
                                 Local time: Tue 2023-10-10 19:49:54 CEST
                             Universal time: Tue 2023-10-10 17:49:54 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** User and Groups ***
                  uviob
                  /home/uviob
                  uviob sudo iobroker
                  *** X-Server-Setup ***
                  X-Server:       false
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            4.1G        1.3G        2.6G        0.0K        222M        2.8G
                  Swap:           512M          0B        512M
                  Total:          4.6G        1.3G        3.1G
                           4096 M total memory
                           1288 M used memory
                             62 M active memory
                           1385 M inactive memory
                           2584 M free memory
                              0 M buffer memory
                            222 M swap cache
                            512 M total swap
                              0 M used swap
                            512 M free swap
                  *** FILESYSTEM ***
                  Filesystem                       Type   Size  Used Avail Use% Mounted on
                  /dev/mapper/pve-vm--210--disk--1 ext4   9.8G  7.1G  2.2G  77% /
                  none                             tmpfs  492K  4.0K  488K   1% /dev
                  tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                  tmpfs                            tmpfs  3.1G  104K  3.1G   1% /run
                  tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                  [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): mounted filesystem 1192067b-46b8-4ac5-a608-5f91cdfb985a with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:06:53 2023] EXT4-fs (dm-1): re-mounted 1192067b-46b8-4ac5-a608-5f91cdfb985a. Quota mode: none.
                  [Tue Oct  3 12:06:55 2023] EXT4-fs (sda): mounted filesystem 52b7d67a-b075-47cb-8f0d-78dafd5f3aa1 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:07:08 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:07:29 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                  [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:07:30 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                  [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                  [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 12:22:51 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                  [Tue Oct  3 13:23:08 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 13:23:21 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                  [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                  [Tue Oct  3 13:28:39 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                  [Tue Oct  3 13:32:47 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                  [Tue Oct  3 13:32:48 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                  [Tue Oct  3 13:33:04 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                  [Mon Oct  9 03:05:42 2023] EXT4-fs (dm-9): mounted filesystem 17044e68-e7a9-4220-9781-345fb7310a16 with ordered data mode. Quota mode: none.
                  [Mon Oct  9 03:05:55 2023] EXT4-fs (dm-9): unmounting filesystem 17044e68-e7a9-4220-9781-345fb7310a16.
                  [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
                  [Mon Oct  9 03:11:33 2023] EXT4-fs (dm-10): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 without journal. Quota mode: none.
                  [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-10): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                  [Mon Oct  9 03:15:42 2023] EXT4-fs (dm-7): mounted filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39 with ordered data mode. Quota mode: none.
                  [Mon Oct  9 03:15:59 2023] EXT4-fs (dm-7): unmounting filesystem 06481f10-cf2d-4303-b869-aafe07fe3d39.
                  [Tue Oct 10 19:31:24 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                  [Tue Oct 10 19:31:25 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                  [Tue Oct 10 19:38:50 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                  [Tue Oct 10 19:39:03 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                  [Tue Oct 10 19:48:54 2023] EXT4-fs (dm-8): unmounting filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0.
                  [Tue Oct 10 19:48:55 2023] EXT4-fs (dm-8): mounted filesystem 8c9be52e-5c56-4c56-9e37-b7adc973b1e0 with ordered data mode. Quota mode: none.
                  TARGET SOURCE                           FSTYPE OPTIONS
                  /      /dev/mapper/pve-vm--210--disk--1 ext4   rw,relatime,stripe=16
                  /var:
                  919M    /var/
                  402M    /var/log
                  401M    /var/log/journal/c337b259b2a44b9da1e2356e14b395e6
                  376M    /var/cache
                  Archived and active journals take up 96.0M in the file system.
                  /opt/iobroker/backups:
                  69M     /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  563M    /opt/iobroker/iobroker-data/
                  454M    /opt/iobroker/iobroker-data/files
                  80M     /opt/iobroker/iobroker-data/files/vis
                  80M     /opt/iobroker/iobroker-data/backup-objects
                  78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.eafddf6f.js.map
                  21M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.22196004.js.map
                  20M     /opt/iobroker/iobroker-data/objects.jsonl
                  18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                  11M     /opt/iobroker/iobroker-data/states.jsonl
                  *** NodeJS-Installation ***
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                          500 http://security.debian.org bullseye-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  No configuration change needed.
                  Multihost discovery server: disabled
                  Discovery authentication:   enabled
                  Persistent activation:      disabled
                  Objects:                    jsonl on 127.0.0.1
                  States:                     jsonl on 127.0.0.1
                  Core adapters versions
                  js-controller:  5.0.13
                  admin:          6.10.5
                  javascript:     7.1.5
                  Adapters from github:   0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.213, run as: admin
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                    system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
                    system.adapter.cameras.0                : cameras               : iobroker                                 - disabled, port: 8200, bind: 127.0.0.1
                    system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                    system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                    system.adapter.fitbit-fitness.0         : fitbit-fitness        : iobroker                                 -  enabled
                    system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                    system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                    system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hm-rpc.4                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                    system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                    system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.213
                    system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                  + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.sprinklecontrol.0        : sprinklecontrol       : iobroker                                 -  enabled
                    system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                    system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                    system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                    system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                    system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                    system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Stable (default): http://download.iobroker.net/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  Active repo(s): Beta (latest)
                  Installed ioBroker-Instances
                  Used repository: Beta (latest)
                  Adapter    "admin"        : 6.10.5   , installed 6.10.5
                  Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                  Adapter    "backitup"     : 2.8.3    , installed 2.8.3
                  Adapter    "bmw"          : 2.6.2    , installed 2.6.2
                  Adapter    "cameras"      : 1.3.0    , installed 1.3.0
                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                  Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                  Adapter    "discovery"    : 4.2.0    , installed 4.2.0
                  Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                  Adapter    "fitbit-fitness": 0.4.11  , installed 0.4.11
                  Adapter    "fritzdect"    : 2.4.1    , installed 2.4.1
                  Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                  Adapter    "history"      : 3.0.0    , installed 3.0.0
                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                  Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                  Adapter    "ical"         : 1.13.3   , installed 1.13.3
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "info"         : 2.0.0    , installed 2.0.0
                  Adapter    "javascript"   : 7.1.5    , installed 7.1.5
                  Controller "js-controller": 5.0.13   , installed 5.0.13
                  Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
                  Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                  Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                  Adapter    "openweathermap": 0.4.5   , installed 0.4.5
                  Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
                  Adapter    "proxmox"      : 2.1.0    , installed 2.1.0
                  Adapter    "socketio"     : 6.5.7    , installed 6.5.7
                  Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                  Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                  Adapter    "telegram"     : 2.0.0    , installed 2.0.0
                  Adapter    "text2command" : 3.0.2    , installed 3.0.2
                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                  Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
                  Adapter    "vis-2-widgets-energy": 0.3.8, installed 0.3.8
                  Adapter    "vis-2-widgets-gauges": 0.2.0, installed 0.2.0
                  Adapter    "vis-2-widgets-material": 1.2.1, installed 1.2.1
                  Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                  Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                  Adapter    "web"          : 6.1.4    , installed 6.1.4
                  Adapter    "wled"         : 0.7.1    , installed 0.7.1
                  Adapter    "ws"           : 2.5.7    , installed 2.5.7
                  Objects and States
                  Objects:        19069
                  States:         17076
                  E: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/main/binary-amd64/Packages.bz2  File has unexpected size (5247 != 5540). Mirror sync in progress? [IP: 2606:4700:10::6816:51a 443]
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        23619139   103/systemd-resolve
                  tcp        0      0 192.168.178.213:8701    0.0.0.0:*               LISTEN      1001       23620337   471/io.hm-rpc.4
                  tcp        0      0 192.168.178.213:9292    0.0.0.0:*               LISTEN      1001       23620124   434/io.hm-rpc.1
                  tcp        0      0 192.168.178.213:2010    0.0.0.0:*               LISTEN      1001       23620183   449/io.hm-rpc.2
                  tcp        0      0 192.168.178.213:2001    0.0.0.0:*               LISTEN      1001       23620043   409/io.hm-rpc.0
                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        23619146   103/systemd-resolve
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23618692   1/init
                  tcp        0      0 192.168.178.213:8081    0.0.0.0:*               LISTEN      1001       23619680   307/io.admin.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23619215   118/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23619280   118/iobroker.js-con
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          23619401   302/master
                  tcp6       0      0 :::5355                 :::*                    LISTEN      104        23619142   103/systemd-resolve
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          23619402   302/master
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          23618700   1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          23619008   1/init
                  udp        0      0 192.168.178.213:5353    0.0.0.0:*                           1001       23623327   937/io.tr-064.0
                  udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        23619138   103/systemd-resolve
                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        23619145   103/systemd-resolve
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23618695   1/init
                  udp6       0      0 :::5355                 :::*                                104        23619141   103/systemd-resolve
                  udp6       0      0 :::111                  :::*                                0          23618705   1/init
                  2023-10-10 19:50:10.452  - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                  2023-10-10 19:50:11.595  - info: netatmo.0 (772) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.netatmo, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:11.622  - info: netatmo.0 (772) Using stored tokens to initialize ... {"access_token":"5d0fe99722ab74000d32a982|ebceb12208f5b85bfcf8ae32b0258629","refresh_token":"5d0fe99722ab74000d32a982|46128978a77b62a4c13e6bf878f065da","scope":"read_station","client_id":"60156be20bbeae26d976880d"}
                  2023-10-10 19:50:11.623  - info: netatmo.0 (772) Authenticating with Netatmo using individual client-ID 60156be20bbeae26d976880d
                  2023-10-10 19:50:11.985  - info: netatmo.0 (772) Successfully authenticated with Netatmo with individual client-ID 60156be20bbeae26d976880d
                  2023-10-10 19:50:13.803  - info: host.iobroker instance system.adapter.ping.0 started with pid 833
                  2023-10-10 19:50:15.528  - info: ping.0 (833) starting. Version 1.6.2 in /opt/iobroker/node_modules/iobroker.ping, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:15.895  - info: ical.2 (728) Terminated (NO_ERROR): Without reason
                  2023-10-10 19:50:16.472  - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                  2023-10-10 19:50:17.806  - info: host.iobroker instance system.adapter.tahoma.0 started with pid 906
                  2023-10-10 19:50:19.137  - info: tahoma.0 (906) starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:19.152  - info: tahoma.0 (906) [START] Starting adapter tahoma v0.10.2.3
                  2023-10-10 19:50:19.152  - info: tahoma.0 (906) Configured polling interval: 20000
                  2023-10-10 19:50:21.298  - info: tahoma.0 (906) eventRegisterID = 1ab61062-0a19-0481-73a9-10cb0635bd01
                  2023-10-10 19:50:21.737  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 937
                  2023-10-10 19:50:23.041  - info: tr-064.0 (937) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:25.717  - info: host.iobroker instance scheduled system.adapter.openweathermap.0 37 * * * *
                  2023-10-10 19:50:25.739  - info: host.iobroker instance system.adapter.openweathermap.0 started with pid 972
                  2023-10-10 19:50:26.975  - info: openweathermap.0 (972) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:29.900  - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
                  2023-10-10 19:50:29.933  - info: host.iobroker instance system.adapter.tvspielfilm.0 started with pid 1016
                  2023-10-10 19:50:31.735  - info: tvspielfilm.0 (1016) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v18.18.0, js-controller: 5.0.13
                  2023-10-10 19:50:33.806  - info: host.iobroker instance system.adapter.mqtt.0 started with pid 1317
                  2023-10-10 19:50:33.810  - info: tvspielfilm.0 (1016) objects written
                  2023-10-10 19:50:35.323  - info: mqtt.0 (1317) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v18.18.0, js-controller: 5.0.13
                  Und kurz
                  Copy text starting here:
                                       v.2023-06-20
                             Chassis: container
                      Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               amd64
                  User-ID:                1000
                  X-Server:               false
                  Pending OS-Updates:     0
                  Pending iob updates:    0
                  Nodejs-Installation:    /usr/bin/nodejs         v18.18.0
                                          /usr/bin/npm            9.8.1
                                          /usr/bin/npx            9.8.1
                  Recommended versions are nodejs 18.x.y and npm 9.x.y
                  MEMORY:
                  Mem:            4.1G        2.1G        1.4G        0.0K        578M        1.9G
                  Swap:           512M          0B        512M
                  Total:          4.6G        2.1G        1.9G
                  Active iob-Instances:   31
                  ioBroker Core:          js-controller           5.0.13
                                          admin                   6.10.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                19069
                  States:                 17076
                  Size of iob-Database:
                  21M     /opt/iobroker/iobroker-data/objects.jsonl
                  13M     /opt/iobroker/iobroker-data/states.jsonl
                  === Mark text until here for copying ===
                  Jemand ne Idee worans harpert?
                  • U UV-on-fire
                    Siehe Hier
                    Sorry, try again.
                    Virtualization: lxc
                    Package: nodejs
                    Pin-Priority: 1001
                    Lang:
                    Skript v.2023-06-20
                    *** BASE SYSTEM ***
                               Chassis: container
                        Virtualization: lxc
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 1
                                     RTC time: n/a
                              RTC in local TZ: no
                    uviob
                    /home/uviob
                    uviob sudo iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           512M          0B        512M
                             4096 M total memory
                             1288 M used memory
                               62 M active memory
                             2584 M free memory
                                0 M buffer memory
                              222 M swap cache
                              512 M total swap
                                0 M used swap
                              512 M free swap
                    *** FILESYSTEM ***
                    /var:
                    919M    /var/
                    402M    /var/log
                    376M    /var/cache
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.10.5
                    javascript:     7.1.5
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        19069
                    States:         17076
                    Pending Updates: 0
                    Und kurz
                                         v.2023-06-20
                               Chassis: container
                        Virtualization: lxc
                    Installation:           lxc
                    Kernel:                 x86_64
                    Userland:               amd64
                    User-ID:                1000
                    X-Server:               false
                                            /usr/bin/npm            9.8.1
                                            /usr/bin/npx            9.8.1
                    MEMORY:
                    Swap:           512M          0B        512M
                                            admin                   6.10.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                19069
                    States:                 17076
                    Thomas BraunT
                    Thomas BraunT
                    #196
                    @uv-on-fire sagte in iob node fix - Skript:
                    Ja, der 'Mirror sync' läuft gerade.
                    Und noch so als Hinweis: Wenn die Quelle einmal richtig auf das richtige Repo inkl. nodejs@18 umgestellt wurde braucht man das Skript / den 'iob node-upgrade' nicht mehr, das läuft dann über das übliche
                    sudo apt update
                    ganz normal mit. Das Skript ist nur für die einmalige Umstellung gedacht, nicht für 0815-Updates.
                    U 1 Antwort Letzte Antwort
                      sudo apt update
                      U
                      U
                      UV-on-fire
                      #197
                      Super, danke.
                      Und danke für den Hinweis. 👍
                      • apollon77A
                        apollon77A
                        #198
                        Sooo... Danke für Alle die Hier unterstützt haben und mit getestet haben! Das Skript ist nun offizieller Bestandhteil vom iobroker CLI Kommando.
                        Daher ... weiter unter https://forum.iobroker.net/topic/69067/neuer-befehl-iob-nodejs-update
                        84.0k
