  4. Adapter auf dem Slave werden nicht gestartet
20 Beiträge 2 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • S splatterjoe
    Hier die Diagnose-Daten.
    MASTER HOST: "iobroker"
    Skript v.2023-06-20
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm
          Machine ID: ebdd90e2768c433a95f6c3984d8ebc8c
             Boot ID: e0821ce7b3a1424eb9471933c32e9d9d
      Virtualization: kvm
    Operating System: Ubuntu 22.04.3 LTS
              Kernel: Linux 6.2.0-33-generic
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     22:40:25 up 8 min,  5 users,  load average: 0.28, 0.42, 0.26
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Fri 2023-09-29 22:40:25 CEST
               Universal time: Fri 2023-09-29 20:40:25 UTC
                     RTC time: Fri 2023-09-29 20:40:25
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    aike
    /home/aike
    aike adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        3.9G        2.2G         63M        1.9G        3.7G
    Swap:           2.0G          0B        2.0G
    Total:            9G        3.9G        4.2G
             7933 M total memory
             3903 M used memory
              841 M active memory
             4428 M inactive memory
             2162 M free memory
              160 M buffer memory
             1707 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    tmpfs          tmpfs  794M  1.7M  792M   1% /run
    /dev/sda5      ext4    49G   20G   27G  42% /
    tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat   511M  4.0K  511M   1% /boot/efi
    tmpfs          tmpfs  794M  108K  794M   1% /run/user/1000
    [Fri Sep 29 22:32:24 2023] EXT4-fs (sda5): mounted filesystem 3a1a2d5e-01d6-4c4f-9bd3-2cde3ef77127 with ordered data mode. Quota mode: none.
    [Fri Sep 29 22:32:26 2023] EXT4-fs (sda5): re-mounted 3a1a2d5e-01d6-4c4f-9bd3-2cde3ef77127. Quota mode: none.
    TARGET                                   SOURCE                         FSTYPE      OPTIONS
    /                                        /dev/sda5                      ext4        rw,relatime,errors=remount-ro
    |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/snap/bare/5                           /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2785                      /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core18/2790                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/1974                      /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core20/2015                      /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core22/858                       /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/core22/864                       /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/firefox/3166                     /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/firefox/3206                     /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-3-38-2004/140              /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-3-38-2004/143              /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-42-2204/126                /dev/loop11                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gnome-42-2204/132                /dev/loop12                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gtk-common-themes/1534           /dev/loop13                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/gtk-common-themes/1535           /dev/loop14                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/node/7707                        /dev/loop15                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snap-store/638                   /dev/loop17                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/node/7823                        /dev/loop16                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/19993                      /dev/loop18                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd-desktop-integration/57     /dev/loop20                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snap-store/959                   /dev/loop19                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/var/snap/firefox/common/host-hunspell /dev/sda5[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
    |-/snap/snapd-desktop-integration/83     /dev/loop22                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    |-/snap/snapd/20092                      /dev/loop21                    squashfs    ro,nodev,relatime,errors=continue,threads=single
    `-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
    /var:
    7.6G    /var/
    4.5G    /var/lib
    4.1G    /var/lib/snapd
    3.0G    /var/log/journal/ebdd90e2768c433a95f6c3984d8ebc8c
    Archived and active journals take up 2.9G in the file system.
    /opt/iobroker/backups:
    172M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    706M    /opt/iobroker/iobroker-data/
    377M    /opt/iobroker/iobroker-data/files
    247M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    No configuration change needed.
    Multihost discovery server: disabled
    Discovery authentication:   enabled
    Persistent activation:      disabled
    Objects:                    jsonl on 0.0.0.0
    States:                     jsonl on 0.0.0.0
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.10.1
    javascript:     7.1.4
    Adapters from github:   9
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.2               : backitup              : iobroker                                 -  enabled
    + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
      system.adapter.canbus.0                 : canbus                : iobrokerSlave                            - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.ecb1.0                   : ecb1                  : iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
    + system.adapter.enocean.0                : enocean               : iobroker                                 -  enabled
    + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : iobroker                                 -  enabled
    + system.adapter.hydrawise.0              : hydrawise             : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : iobrokerSlave                            - disabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.100.3
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.paw.0                    : paw                   : iobroker                                 -  enabled, port: 8898
    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartmeter.0             : smartmeter            : iobrokerSlave                            -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tahoma.0                 : tahoma                : iobroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tibberconnect.0          : tibberconnect         : iobroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
      system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_56ef6b11b293eb11953d1b4f3d98b6d1-if00-port0
    + instance is alive
    ioBroker-Repositories
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    live-stable   : http://iobroker.live/repo/sources-dist.json
    default       : http://download.iobroker.net/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.10.1   , installed 6.10.1
    Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
    Adapter    "backitup"     : 2.8.1    , installed 2.8.1
    Adapter    "bydhvs"       : 1.4.0    , installed 1.4.0
    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "fronius"      : 1.1.3    , installed 1.1.6
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.12   , installed 5.0.12
    Adapter    "meteoalarm"   : 2.3.7    , installed 2.3.7
    Adapter    "mihome-vacuum": 4.0.0    , installed 4.0.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "synology"     : 3.0.0    , installed 3.0.0
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "tapo"         : 0.0.8    , installed 0.0.8
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vw-connect"   : 0.0.67   , installed 0.0.72
    Adapter    "web"          : 6.1.2    , installed 6.1.2
    Adapter    "ws"           : 2.5.5    , installed 2.5.5
    Adapter    "yeelight-2"   : 1.2.1    , installed 1.2.1
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects:        14570
    States:         15978
    Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          21967      596/cupsd
    tcp        0      0 192.168.100.3:1883      0.0.0.0:*               LISTEN      1001       29374      2489/io.mqtt.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       24680      597/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       21430      597/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20854      634/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17731      1/init
    tcp        0      0 0.0.0.0:41303           0.0.0.0:*               LISTEN      1001       29927      2459/io.alexa2.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       27504      2362/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       29968      2519/io.shelly.0
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22604      398/systemd-resolve
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          21966      596/cupsd
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       31666      3530/io.socketio.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24187      1455/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34849      3560/io.web.0
    tcp6       0      0 :::8898                 :::*                    LISTEN      1001       34476      3854/io.paw.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       31229      2808/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20865      634/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1749       1/init
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22603      398/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17732      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       27631      2474/io.mihome-vacu
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       31230      2808/io.harmony.0
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          20942      677/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        21862      519/avahi-daemon: r
    udp        0      0 0.0.0.0:54510           0.0.0.0:*                           115        21864      519/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          18495      1/init
    udp6       0      0 :::5353                 :::*                                115        21863      519/avahi-daemon: r
    udp6       0      0 :::56149                :::*                                115        21865      519/avahi-daemon: r
    2023-09-29 22:39:13.985  - info: mihome-vacuum.0 (2474) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2023-09-29 22:39:25.130  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 0(Aike Huawei/88:10:8F:30:99:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:39:25.232  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 1(Netti OnePlus3/C0:EE:FB:D5:64:90) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:39:32.789  - warn: paw.0 (3854) Update app on device: KFTRPWI
    2023-09-29 22:39:35.143  - info: mihome-vacuum.0 (2474) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2023-09-29 22:39:45.717  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 0(Aike Huawei/88:10:8F:30:99:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:39:45.825  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 1(Netti OnePlus3/C0:EE:FB:D5:64:90) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:39:56.284  - info: mihome-vacuum.0 (2474) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2023-09-29 22:40:00.026  - info: host.iobroker instance system.adapter.netatmo-crawler.0 started with pid 5568
    2023-09-29 22:40:01.219  - info: netatmo-crawler.0 (5568) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 5.0.12
    2023-09-29 22:40:01.249  - info: netatmo-crawler.0 (5568) Getting data for stationid:70:ee:50:3f:70:e8
    2023-09-29 22:40:06.294  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 0(Aike Huawei/88:10:8F:30:99:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:40:06.395  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 1(Netti OnePlus3/C0:EE:FB:D5:64:90) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:40:06.456  - info: netatmo-crawler.0 (5568) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2023-09-29 22:40:06.969  - info: host.iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-09-29 22:40:17.448  - info: mihome-vacuum.0 (2474) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2023-09-29 22:40:26.837  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 0(Aike Huawei/88:10:8F:30:99:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:40:26.938  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 1(Netti OnePlus3/C0:EE:FB:D5:64:90) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:40:32.788  - warn: paw.0 (3854) Update app on device: KFTRPWI
    2023-09-29 22:40:34.420  - debug: tibberconnect.0 (3980) Get current price from tibber api: {"total":0.3439,"energy":0.1066,"tax":0.2373,"startsAt":"2023-09-29T22:00:00.000+02:00","currency":"EUR","level":"NORMAL"}
    2023-09-29 22:40:34.422  - debug: tibberconnect.0 (3980) Get prices today from tibber api: [{"total":0.3461,"energy":0.1085,"tax":0.2376,"startsAt":"2023-09-29T00:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3336,"energy":0.0979,"tax":0.2357,"startsAt":"2023-09-29T01:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3307,"energy":0.0956,"tax":0.2351,"startsAt":"2023-09-29T02:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3265,"energy":0.092,"tax":0.2345,"startsAt":"2023-09-29T03:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3289,"energy":0.094,"tax":0.2349,"startsAt":"2023-09-29T04:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3368,"energy":0.1007,"tax":0.2361,"startsAt":"2023-09-29T05:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3699,"energy":0.1284,"tax":0.2415,"startsAt":"2023-09-29T06:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3812,"energy":0.1379,"tax":0.2433,"startsAt":"2023-09-29T07:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3718,"energy":0.13,"tax":0.2418,"startsAt":"2023-09-29T08:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3441,"energy":0.1068,"tax":0.2373,"startsAt":"2023-09-29T09:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3266,"energy":0.0921,"tax":0.2345,"startsAt":"2023-09-29T10:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.321,"energy":0.0874,"tax":0.2336,"startsAt":"2023-09-29T11:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.3147,"energy":0.082,"tax":0.2327,"startsAt":"2023-09-29T12:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.3032,"energy":0.0724,"tax":0.2308,"startsAt":"2023-09-29T13:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.3087,"energy":0.077,"tax":0.2317,"startsAt":"2023-09-29T14:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.325,"energy":0.0907,"tax":0.2343,"startsAt":"2023-09-29T15:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3318,"energy":0.0965,"tax":0.2353,"startsAt":"2023-09-29T16:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3503,"energy":0.112,"tax":0.2383,"startsAt":"2023-09-29T17:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3718,"energy":0.13,"tax":0.2418,"startsAt":"2023-09-29T18:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3842,"energy":0.1405,"tax":0.2437,"startsAt":"2023-09-29T19:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3752,"energy":0.1329,"tax":0.2423,"startsAt":"2023-09-29T20:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.352,"energy":0.1134,"tax":0.2386,"startsAt":"2023-09-29T21:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3439,"energy":0.1066,"tax":0.2373,"startsAt":"2023-09-29T22:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3373,"energy":0.1011,"tax":0.2362,"startsAt":"2023-09-29T23:00:00.000+02:00","currency":"EUR","level":"NORMAL"}]
    2023-09-29 22:40:34.487  - debug: tibberconnect.0 (3980) Get prices tomorrow from tibber api: [{"total":0.3253,"energy":0.091,"tax":0.2343,"startsAt":"2023-09-30T00:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3228,"energy":0.0889,"tax":0.2339,"startsAt":"2023-09-30T01:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3227,"energy":0.0888,"tax":0.2339,"startsAt":"2023-09-30T02:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3226,"energy":0.0887,"tax":0.2339,"startsAt":"2023-09-30T03:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3221,"energy":0.0883,"tax":0.2338,"startsAt":"2023-09-30T04:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3266,"energy":0.0921,"tax":0.2345,"startsAt":"2023-09-30T05:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3423,"energy":0.1053,"tax":0.237,"startsAt":"2023-09-30T06:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3473,"energy":0.1095,"tax":0.2378,"startsAt":"2023-09-30T07:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.348,"energy":0.11,"tax":0.238,"startsAt":"2023-09-30T08:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3419,"energy":0.105,"tax":0.2369,"startsAt":"2023-09-30T09:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3212,"energy":0.0875,"tax":0.2337,"startsAt":"2023-09-30T10:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.301,"energy":0.0705,"tax":0.2305,"startsAt":"2023-09-30T11:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.2679,"energy":0.0428,"tax":0.2251,"startsAt":"2023-09-30T12:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.2275,"energy":0.0088,"tax":0.2187,"startsAt":"2023-09-30T13:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.2349,"energy":0.015,"tax":0.2199,"startsAt":"2023-09-30T14:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.2837,"energy":0.056,"tax":0.2277,"startsAt":"2023-09-30T15:00:00.000+02:00","currency":"EUR","level":"CHEAP"},{"total":0.3182,"energy":0.085,"tax":0.2332,"startsAt":"2023-09-30T16:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3452,"energy":0.1077,"tax":0.2375,"startsAt":"2023-09-30T17:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3794,"energy":0.1364,"tax":0.243,"startsAt":"2023-09-30T18:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.4121,"energy":0.1639,"tax":0.2482,"startsAt":"2023-09-30T19:00:00.000+02:00","currency":"EUR","level":"EXPENSIVE"},{"total":0.3766,"energy":0.1341,"tax":0.2425,"startsAt":"2023-09-30T20:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3508,"energy":0.1124,"tax":0.2384,"startsAt":"2023-09-30T21:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3448,"energy":0.1074,"tax":0.2374,"startsAt":"2023-09-30T22:00:00.000+02:00","currency":"EUR","level":"NORMAL"},{"total":0.3373,"energy":0.101,"tax":0.2363,"startsAt":"2023-09-30T23:00:00.000+02:00","currency":"EUR","level":"NORMAL"}]
    2023-09-29 22:40:38.596  - info: mihome-vacuum.0 (2474) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2023-09-29 22:40:47.394  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 0(Aike Huawei/88:10:8F:30:99:24) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2023-09-29 22:40:47.502  - info: tr-064.0 (2534) forEachConfiguredDevice: in GetSpecificHostEntry 1(Netti OnePlus3/C0:EE:FB:D5:64:90) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    SLAVE HOST: "iobrokerSlave"
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: iobrokerSlave
             Icon name: computer
            Machine ID: bd37f8ac5bea4b2384407892c7e9ce43
               Boot ID: eae03fc004114abfb9a77d60b8a9fb43
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
     22:31:48 up 3 days, 18 min,  1 user,  load average: 2.67, 2.41, 1.50
    CPU threads: 4
    Raspberry only:
    throttled=0x50005
    Other values than 0x0 hint to temperature/voltage problems
    temp=58.0'C
    volt=1.2000V
                   Local time: Fri 2023-09-29 22:31:49 CEST
               Universal time: Fri 2023-09-29 20:31:49 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    aike
    /home/aike
    aike adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            909M        175M        221M        1.0M        512M        669M
    Swap:            99M          0B         99M
    Total:          1.0G        175M        321M
              909 M total memory
              176 M used memory
              285 M active memory
              304 M inactive memory
              220 M free memory
               56 M buffer memory
              456 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  5.7G   22G  22% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  1.1M  181M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.9G    /var/
    3.1G    /var/log
    2.9G    /var/log/journal/bd37f8ac5bea4b2384407892c7e9ce43
    515M    /var/cache
    Archived and active journals take up 2.8G in the file system.
    4.0K    /opt/iobroker/backups/
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    384K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    ioBroker Status
    No connection to databases possible ...
    Objects:                    jsonl on 192.168.100.3
    States:                     jsonl on 192.168.100.3
    admin:          "admin" not found
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
    + instance is alive
    Adapter    "canbus"       : 1.3.1    , installed 1.3.1
    Objects and States
    Objects:        14570
    States:         15978
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://packages.azlux.fr/debian buster InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
    Pending Updates: 0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3438       662/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3440       662/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14950      874/dhcpcd
    udp        0      0 0.0.0.0:57953           0.0.0.0:*                           108        3396       533/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3394       533/avahi-daemon: r
    udp6       0      0 :::37399                :::*                                108        3397       533/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          13689      874/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        3395       533/avahi-daemon: r
    2023-09-29 22:35:19.129  - error: host.iobrokerSlave Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-29 22:35:19.130  - error: host.iobrokerSlave Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
    2023-09-29 22:35:19.131  - error: host.iobrokerSlave Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js:15:15)
    2023-09-29 22:35:19.132  - error: host.iobrokerSlave Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-29 22:35:19.132  - error: host.iobrokerSlave Caught by controller[0]: Node.js v18.18.0
    2023-09-29 22:35:19.133  - error: host.iobrokerSlave instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-29 22:35:19.134  - info: host.iobrokerSlave Restart adapter system.adapter.smartmeter.0 because enabled
    2023-09-29 22:35:50.109  - info: host.iobrokerSlave instance system.adapter.smartmeter.0 started with pid 79303
    2023-09-29 22:35:51.351  - error: host.iobrokerSlave Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js:1
    2023-09-29 22:35:51.352  - error: host.iobrokerSlave Caught by controller[0]: �D�l@��$
    2023-09-29 22:35:51.353  - error: host.iobrokerSlave Caught by controller[0]: ^
    2023-09-29 22:35:51.354  - error: host.iobrokerSlave Caught by controller[0]: SyntaxError: Invalid or unexpected token
    2023-09-29 22:35:51.354  - error: host.iobrokerSlave Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
    2023-09-29 22:35:51.356  - error: host.iobrokerSlave Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1178:20)
    2023-09-29 22:35:51.356  - error: host.iobrokerSlave Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1220:27)
    2023-09-29 22:35:51.357  - error: host.iobrokerSlave Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
    2023-09-29 22:35:51.358  - error: host.iobrokerSlave Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
    2023-09-29 22:35:51.358  - error: host.iobrokerSlave Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
    2023-09-29 22:35:51.359  - error: host.iobrokerSlave Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
    2023-09-29 22:35:51.360  - error: host.iobrokerSlave Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
    2023-09-29 22:35:51.361  - error: host.iobrokerSlave Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js:15:15)
    2023-09-29 22:35:51.361  - error: host.iobrokerSlave Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
    2023-09-29 22:35:51.362  - error: host.iobrokerSlave Caught by controller[0]: Node.js v18.18.0
    2023-09-29 22:35:51.363  - error: host.iobrokerSlave instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-09-29 22:35:51.364  - info: host.iobrokerSlave Restart adapter system.adapter.smartmeter.0 because enabled
    splatterjoe
    @splatterjoe sagte in Adapter auf dem Slave werden nicht gestartet:
    Raspberry only:
    throttled=0x50005
    temp=58.0'C
    volt=1.2000V
    Der Raspberry fühlt sich nicht wohl. Ich vermute da Trouble mit der Spannung.
    Lösch das Repo.
    Und für den Master legst du auch das neue nodesource-Repo an, wie es auf dem Raspberry schon der Fall ist.
    Die /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
    scheint aber defekt zu sein.
    Wie schaut die aus?
    cat /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
      Raspberry only:
      throttled=0x50005
      temp=58.0'C
      volt=1.2000V
      Lösch das Repo.
      Wie schaut die aus?
      splatterjoe
      schrieb am zuletzt editiert von splatterjoe
      Das mit der Spannung wäre auf jeden Fall ein guter Grund, warum die Adapter nicht funktionieren, da es sich um zusätzliche Hardware handelt. Vermutlich ist das USB-Kabel zu stark in Mitleidenschaft gezogen worden, wenn ich mir das so anschaue... Da es leider sehr eng in dem Verteilerkasten ist, werde ich wohl einen Sicherungsautomaten umbauen müssen. Das mache ich dann eher morgen ;)
      Welches Repo meinst du genau und wie soll ich das löschen? Wie kann man das nodesource-Repo auf dem Master anlegen? Geschieht dies nicht über das Update von nodejs/npm (iobroker update && iobroker upgrade self)?
      Die /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js scheint tatsächlich defekt zu sein. Wie kann man die wieder reparieren?
      • S splatterjoe
        @splatterjoe
        0x50005 means you are currently under-voltage and throttled.
        Da klemmt es also in der Tat bei der Stromversorgung.
        ls -lAh /etc/apt/sources.list.d/
        sagt? Da müsste es eine Datei azlinux.list oder so ähnlich geben. Die löschen.
        Wie hast du es denn auf dem Raspberry gemacht?
        In meiner Signatur findest du aber einen Link zum 'node-fixer-Skript', das legt dir auch alles passend an.
        • S splatterjoe
          Ich weiß nicht wo die herkommt. Ich vermute die kommt beim js-controller mit. Installier den nochmal.
            splatterjoe
            Guten Morgen :)
            ls -lAh /etc/apt/sources.list.d/ ergibt:
            insgesamt 12K
            -rw-r--r-- 1 root root  49 26. Sep 21:02 azlux.list
            -rw-r--r-- 1 root root 100 20. Sep 21:45 nodesource.list
            -rw-r--r-- 1 root root 191 22. Sep 2022  raspi.list
            Ich habe nun azlux.list gelöscht. Ein wenig spät, aber was genau ist/macht diese Liste?
            Das Update für nodeJS habe ich mit Hilfe dieser Anleitung durchgeführt und js-controller über die Anleitung, die einem im Admin-Webinterface angeboten wird mit iob fix vor und nach dem Upgrade.
            Ich tausche nun mal das Kabel für die Spannungsversorgung aus...
            • S splatterjoe
              Guten Morgen :)
              insgesamt 12K
              Die war doch auf deinem System. Musst du angelegt haben und daher wissen warum.
              Die Anleitung zum nodejs-Update ist nicht mehr aktuell. Mittlerweile ist das ein anderes Repository.
                splatterjoe
                Das Netzteil habe ich nun mal ausgetauscht und die Core-Spannung des Pis sieht wieder normal aus. Danke für den Hinweis erst einmal.
                An die azlux.list kann ich mich nicht erinnern. Wer weiß woher die kommt. 😁
                Ich hatte bei der Installation von nodejs ein paar Probleme gehabt und konnte diese durch mehrmaliges löschen und erneutes installieren von nodejs korrigieren. Eine Neuinstallation vom js-controller hat eben leider auch nicht geholfen den Fehler aus meinem ersten Post zu beseitigen.
                Folgendermaßen habe ich ihn neu installiert.
                iob stop
                npm uninstall iobroker.js-controller
                npm install iobroker.js-controller
                iob start
                • S splatterjoe
                  iob stop
                  iob start
                  Welcher Art?
                  • S splatterjoe
                    iob stop
                    iob start
                    Immer vollständige Ein- und Ausgaben, inkl. des LoginPrompts. So kann ich nicht sehen in welchem Verzeichnis du gestanden hast. Davon abgesehen wird die Installation mit dem User 'iobroker' durchgeführt.
                    S 2 Antworten Letzte Antwort
                      splatterjoe
                      @thomas-braun sagte in Adapter auf dem Slave werden nicht gestartet:
                      aike@iobrokerSlave:~ $ vcgencmd measure_volts core
                      volt=1.3375V
                      aike@iobrokerSlave:~ $ cd /opt/iobroker/
                      aike@iobrokerSlave:/opt/iobroker $ iob status
                      iobroker is not running on this host.
                      At least one iobroker host is running.
                      Objects type: jsonl
                      States  type: jsonl
                      aike@iobrokerSlave:/opt/iobroker $ npm install iobroker.js-controller
                      up to date in 9s
                      28 packages are looking for funding
                        run `npm fund` for details
                      aike@iobrokerSlave:/opt/iobroker $ npm uninstall iobroker.js-controller
                      removed 248 packages in 7s
                      16 packages are looking for funding
                      added 247 packages in 6m
                      aike@iobrokerSlave:/opt/iobroker $ iob start
                      aike@iobrokerSlave:/opt/iobroker $ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v18.18.0
                      v18.18.0
                      9.8.1
                      9.8.1
                        splatterjoe
                        Ich hatte Probleme mit npm, da dies nicht korrekt geupdated wurde. Das bliebt auf der alten Version hängen.
                        • S splatterjoe
                          Dann war das nicht ordentlich über den Paketmanager installiert sondern wild daneben geworfen.
                            splatterjoe
                            @thomas-braun Das kann durch meine Reparaturversuche gut möglich sein. Jetzt sind die Versionen auf jeden fall auf dem Maser und Slave aktuell und in Ordnung :) Lediglich der js-controller zickt noch etwas herum.
                            • S splatterjoe
                              volt=1.3375V
                              Objects type: jsonl
                              States  type: jsonl
                              up to date in 9s
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              v18.18.0
                              v18.18.0
                              9.8.1
                              9.8.1
                              @splatterjoe
                              iob stop
                              iob fix
                              ion start
                              Und gib nochmal die
                              iob diag
                              her.
                                @splatterjoe
                                iob stop
                                iob fix
                                ion start
                                Und gib nochmal die
                                iob diag
                                her.
                                splatterjoe
                                Diagnose-Daten SLAVE:
                                Skript v.2023-06-20
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                           Boot ID: 66b67d3b884940cfb2ac71c64708e2f2
                                      Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 12:37:01 up  1:23,  1 user,  load average: 0.09, 0.17, 0.40
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=56.4'C
                                volt=1.3375V
                                               Local time: Sat 2023-09-30 12:37:01 CEST
                                           Universal time: Sat 2023-09-30 10:37:01 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                aike
                                /home/aike
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            909M         87M        334M        0.0K        488M        750M
                                Swap:            99M        1.0M         98M
                                Total:          1.0G         88M        432M
                                          909 M total memory
                                           87 M used memory
                                          124 M active memory
                                          341 M inactive memory
                                          334 M free memory
                                           32 M buffer memory
                                          456 M swap cache
                                           99 M total swap
                                            1 M used swap
                                           98 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/root      ext4       29G  5.8G   22G  22% /
                                [Sat Sep 30 11:13:20 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=36b9d505-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Sat Sep 30 11:13:23 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sat Sep 30 11:13:23 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Sat Sep 30 11:13:27 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                3.9G    /var/
                                3.1G    /var/log
                                515M    /var/cache
                                /usr/bin/npm            9.8.1
                                /usr/bin/npx            9.8.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Adapter State
                                  system.adapter.canbus.0                 : canbus                : iobrokerSlave                            -  enabled
                                  system.adapter.modbus.0                 : modbus                : iobrokerSlave                            -  enabled
                                + instance is alive
                                Objects and States
                                Objects:        14570
                                States:         15923
                                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13131      660/sshd: /usr/sbin
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          13133      660/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:52280           0.0.0.0:*                           108        13059      533/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11798      899/dhcpcd
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13057      533/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          11816      899/dhcpcd
                                udp6       0      0 :::32893                :::*                                108        13060      533/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                108        13058      533/avahi-daemon: r
                                2023-09-30 12:21:34.573  - error: host.iobrokerSlave instance system.adapter.smartmeter.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2023-09-30 12:21:34.573  - info: host.iobrokerSlave Restart adapter system.adapter.smartmeter.0 because enabled
                                2023-09-30 12:21:40.381  - info: host.iobrokerSlave instance system.adapter.modbus.0 started with pid 3802
                                2023-09-30 12:21:41.182  - error: host.iobrokerSlave Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js:1
                                2023-09-30 12:21:41.183  - error: host.iobrokerSlave Caught by controller[0]: �D�l@��$
                                2023-09-30 12:21:41.184  - error: host.iobrokerSlave Caught by controller[0]: ^
                                2023-09-30 12:21:41.184  - error: host.iobrokerSlave Caught by controller[0]: SyntaxError: Invalid or unexpected token
                                2023-09-30 12:21:41.184  - error: host.iobrokerSlave Caught by controller[0]:     at internalCompileFunction (node:internal/vm:73:18)
                                2023-09-30 12:21:41.185  - error: host.iobrokerSlave Caught by controller[0]:     at wrapSafe (node:internal/modules/cjs/loader:1178:20)
                                2023-09-30 12:21:41.185  - error: host.iobrokerSlave Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1220:27)
                                2023-09-30 12:21:41.185  - error: host.iobrokerSlave Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                                2023-09-30 12:21:41.186  - error: host.iobrokerSlave Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1119:32)
                                2023-09-30 12:21:41.186  - error: host.iobrokerSlave Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:960:12)
                                2023-09-30 12:21:41.186  - error: host.iobrokerSlave Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1143:19)
                                2023-09-30 12:21:41.187  - error: host.iobrokerSlave Caught by controller[0]:     at require (node:internal/modules/cjs/helpers:119:18)
                                2023-09-30 12:21:41.187  - error: host.iobrokerSlave Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.modbus/main.js:6:21)
                                2023-09-30 12:21:41.187  - error: host.iobrokerSlave Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1256:14)
                                2023-09-30 12:21:41.187  - error: host.iobrokerSlave Caught by controller[0]: Node.js v18.18.0
                                2023-09-30 12:21:41.188  - error: host.iobrokerSlave instance system.adapter.modbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2023-09-30 12:21:41.188  - info: host.iobrokerSlave Restart adapter system.adapter.modbus.0 because enabled
                                2023-09-30 12:21:43.119  - info: host.iobrokerSlave received SIGTERM
                                2023-09-30 12:21:43.127  - info: host.iobrokerSlave stopInstance system.adapter.modbus.0 (force=false, process=false)
                                2023-09-30 12:21:43.128  - info: host.iobrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=false)
                                2023-09-30 12:21:43.128  - info: host.iobrokerSlave stopInstance system.adapter.canbus.0 (force=false, process=false)
                                2023-09-30 12:21:58.169  - info: host.iobrokerSlave force terminating
                                Die cat /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js ist leider immer noch defekt. Könntest du mir noch eben verraten wie ich das anstellen soll?
                                • S splatterjoe
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=56.4'C
                                  volt=1.3375V
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  aike
                                  /home/aike
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M        1.0M         98M
                                            909 M total memory
                                             87 M used memory
                                            124 M active memory
                                            334 M free memory
                                             32 M buffer memory
                                            456 M swap cache
                                             99 M total swap
                                              1 M used swap
                                             98 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  3.9G    /var/
                                  3.1G    /var/log
                                  515M    /var/cache
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        14570
                                  States:         15923
                                  Pending Updates: 0
                                  @splatterjoe
                                  Für die nodesource.list findest du ein Skript in meiner Signatur.
                                    splatterjoe
                                    Ich habe mich durchgerungen und den Slave mal wieder neu installiert und danach wollte ich die drei Adapter (can, smartmeter, modbus) nach dem Aufsetzen des Multihost-Systems wieder auf den Slave verschieben (über Master-Webinterface). Leider bekomme ich das Multihost-System nicht korrekt zum laufen und musste zwischendurch sogar meinen Master nochmal reanimieren. Nun läuft immerhin der Master wieder :)
                                    Über ein einfaches iobroker multihost enable auf dem Master und dann ein iobroker multihost connect auf dem Slave hat es leider nicht funktioniert. Danach habe ich per iobroker setup custom beide Systeme überprüft.
                                    Master:
                                    Current configuration:
                                    - Objects database:
                                      - Type: jsonl
                                      - Host/Unix Socket: 0.0.0.0
                                      - Port: 9001
                                    - States database:
                                      - Type: jsonl
                                      - Port: 9000
                                    - Data Directory: ../../iobroker-data/
                                    - Host name: iobroker
                                    Slave:
                                    - Objects database:
                                      - Type: jsonl
                                      - Host/Unix Socket: 192.168.100.3
                                      - Port: 9001
                                    - States database:
                                      - Type: jsonl
                                      - Port: 9000
                                    Was mir jetzt auffällt ist, dass der Hostname beim Slave fehlt. Ist das so richtig? Schließlich wird dieser ja auch abgefragt.
                                    Starte ich nun auf dem Master iobroker multihost enable bleibt dieser stehen, obwohl in allen Anleitungen/Tutorials er in dann im normalen Prompt wieder landen sollte, wie es nach jedem Befehl eigentlich auch üblich ist. Beim Slave ist das genauso nachdem ich iobroker multihost connect eingebe. Im Hintergrund passiert auf jeden Fall etwas, da der Slave komischerweise dann im Master auftaucht, obwohl ich noch nicht einmal ein Passwort eingegeben habe.
                                    Master:
                                    aike@iobroker:~$ iobroker multihost enable
                                    Multihost discovery server activated on this host. If iobroker is currently not running please start befeore trying to discover this host.
                                    Important: Multihost discovery works with UDP packets. Make sure they are routed correctly in your network. If you use Docker you also need to configure this correctly.
                                    Multihost discovery will be automatically deactivated after 15 minutes. If you want to activate it permanently use the --persist flag
                                    Discovery authentication activated.
                                    Enter secret phrase for connection:
                                    Repeat secret phrase for connection:
                                    Please check the binding of the configured jsonl server to allow remote connections.
                                    Please restart ioBroker for the changes to take effect: "iobroker restart"
                                    Multihost discovery server: enabled
                                    Slave:
                                    aike@iobrokerSlave:~ $ iobroker multihost connect
                                    Beim Schreiben dieses Posts fiel mir ein, dass ich das Log des Slaves einmal auf "Alles" stellen könnte und dort sind mir folgende Logs aufgefallen. Das sieht mir so aus, als wären hier ein paar Reste vom Versuch per redis die Multihost-Konfiguration (Anleitung) zu nutzen.
                                    host.iobrokerSlave
                                    2023-10-02 21:40:21.165	silly	States system redis pmessage system.adapter.*.alive/system.adapter.socketio.0.alive:{"val":true,"ack":true,"ts":1696275621164,"q":0,"from":"system.adapter.socketio.0","lc":1696272246053,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:21.115	silly	States system redis pmessage system.adapter.*.alive/system.adapter.modbus.1.alive:{"val":true,"ack":true,"ts":1696275621114,"q":0,"from":"system.adapter.modbus.1","lc":1696272186030,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:21.108	silly	States system redis pmessage system.adapter.*.alive/system.adapter.evcc.0.alive:{"val":true,"ack":true,"ts":1696275621107,"q":0,"from":"system.adapter.evcc.0","lc":1696272306040,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:20.497	silly	States system redis pmessage system.adapter.*.alive/system.adapter.vw-connect.0.alive:{"val":true,"ack":true,"ts":1696275620496,"q":0,"from":"system.adapter.vw-connect.0","lc":1696272290414,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:20.486	silly	States system redis pmessage system.adapter.*.alive/system.adapter.iot.0.alive:{"val":true,"ack":true,"ts":1696275620485,"q":0,"from":"system.adapter.iot.0","lc":1696272230391,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:20.195	silly	States system redis pmessage system.adapter.*.alive/system.adapter.shelly.0.alive:{"val":true,"ack":true,"ts":1696275620194,"q":0,"from":"system.adapter.shelly.0","lc":1696272170120,"expire":true}
                                    host.iobrokerSlave
                                    2023-10-02 21:40:19.162	silly
                                    Vielleicht kann mir jemand helfen die etwas verkorkste Multihost-Installation wieder zum Laufen zu bringen.
                                    -> Weiter hier Multihost-Konfiguration nicht wiederherstellbar
