  4. [Adapter] cloudfreie Auslesung von Deye-Invertern
1.2k Beiträge 114 Kommentatoren 515.8k Aufrufe 93 Beobachtet
  • ralleR ralle
    @rene55 said in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
    @ralle Wenn das nicht hilft: Konfiguration sichern, komplett löschen, neu installieren, Instanz erstellen und konfiguration wieder einspielen.
    Hallo nochmal,
    1. wie kann ich die Konfig sichern?
    2. anbei das Installierungslog:
    $ iobroker url https://github.com/raschy/ioBroker.deyeidc --host raspberrypi --debug
    install raschy/ioBroker.deyeidc#13f435f5039df499207f02165ffe3f221eab215c
    NPM version: 8.19.4
    Installing raschy/ioBroker.deyeidc#13f435f5039df499207f02165ffe3f221eab215c... (System call)
    up to date in 12s132 packages are looking for funding run `npm fund` for details
    upload [12] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/deyeidc.png deyeidc.png image/png
    upload [11] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [1] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] deyeidc.admin /opt/iobroker/node_modules/iobroker.deyeidc/admin/jsonConfig.json jsonConfig.json application/json
    Process exited with code 0
    Rene55R Offline
    Rene55R Offline
    Rene55
    #504
    @ralle So wie ich das sehe, ist das die richtige Version.
    Die Konfiguration kann/muss - solange der Adapter noch nicht gelöscht ist - in 'Instanzen' über den rechten Pfeil exportiert werden.Konfiguration_exportieren.png
    ralleR 1 Antwort Letzte Antwort
    • Rene55R Rene55
      ralleR Offline
      ralleR Offline
      ralle
      #505
      Hi, ein nochmaliges überschreiben brachte nichts, gerade den Adapter gelöscht neu installiert.
      LEIDER OHNE ERFOLG !!
      • ralleR ralle
        Rene55R Offline
        Rene55R Offline
        Rene55
        #506
        @ralle Hast du den Fehler jetzt in beiden Instanzen?
        • Rene55R Rene55
          ralleR Offline
          ralleR Offline
          ralle
          #507
          @rene55 nein, nur in der mit dem Relais!
          • ralleR ralle
            Rene55R Offline
            Rene55R Offline
            Rene55
            #508
            @ralle Dann vermute ich nur noch, dass die beiden Firmwaren (ohne und mit Relais) etwas unterschiedlich sind. Sonst ist dieser Effekt nicht zu erklären. Ich vermute mal, mein Relais kommt in 40 - 45 Tagen. Dann kann ich mich um eine wirkliche Fehlersuche bemühen. Sorry bis dahin.
            • Rene55R Rene55
              ralleR Offline
              ralleR Offline
              ralle
              #509
              Ok ich warte, Danke. Übrigens hab ich ein zweites Relais bestellt in München beim Versender , das hat 1 Woche gedauert !
              • ralleR ralle
                Rene55R Offline
                Rene55R Offline
                Rene55
                #510
                @ralle Oh, das geht auch? Ich hatte nur das Kontaktformular von Deye über meinen Fachhändler bekommen.
                • Rene55R Rene55
                  ralleR Offline
                  ralleR Offline
                  ralle
                  #511
                  info@safetytaxfree.com , Mail und im Anhang die Rechnung des BKW und die Anzahl am Relai, mit der Bitte um Versendung.....
                  • Rene55R Offline
                    Rene55R Offline
                    Rene55
                    #512
                    @ralle Danke für die Info. Versuch ich morgen auch, vielleicht gehts dann schneller. (Man bekommt ja eh keine Nachricht, ob da schon was unterwegs ist)
                    • Rene55R Rene55
                      MPF
                      #513
                      @rene55 ich habe 2 Relais hier liegen, verzichte aber vorerst auf einen Einbau. Es gibt Probleme beim Verbinden mit dem WR und wieder zusätzlichen Stromverbrauch.
                      • M MPF
                        Rene55R Offline
                        Rene55R Offline
                        Rene55
                        #514
                        @mpf Danke für die Warnung, nutzt mir aber nix. Wenn ich den Fehler fixen will, brauche ich Relais und aktuelle Firmware. Mein Risiko - aber vielleicht wird es ja gar nicht sooooo schlimm.
                          skybundi
                          #515
                          Hallo
                          Ich bekomme seit geraumer Zeit regelmäßig die Fehlermeldung "ControlCode faulty!: Data may be corrupt, therefore discarded". Wie bekomme ich das weg?
                          Gruß Skybundi
                          • S skybundi
                            Hallo
                            Gruß Skybundi
                            Rene55R Offline
                            Rene55R Offline
                            Rene55
                            #516
                            @skybundi Hast du auch die neue Firmware drauf? Eine Möglichkeit - die nicht bei allen funktioniert hat - einfach nochmal direkt von Github drüberinstallieren.
                            • Rene55R Rene55
                              skybundi
                              schrieb am zuletzt editiert von skybundi
                              #517
                              @rene55 ich habe die v0.0.11 drauf. Ich hatte den Adapter auch schon neu installiert.
                              • S skybundi
                                Rene55R Offline
                                Rene55R Offline
                                Rene55
                                #518
                                @skybundi Das mag ja richtig sein. Es gibt ja auch noch keine neuere Version. Nur bei einer neuen Installation direkt von Github wird dieser Fehler nicht mehr angezeigt. Es bleibt bei der 0.0.11!
                                • Rene55R Rene55
                                  MPF
                                  schrieb am zuletzt editiert von MPF
                                  #519
                                  @rene55 sagte in [neuer Adapter] cloudfreie Auslesung von Deye-Invertern:
                                  Das stimmt, dafür benötigst Du natürlich die neue FW im WR.
                                  Nur noch mal der Vollständigkeit halber, den Fehler "ControlCode faulty!: Data may be corrupt, therefore discarded" habe ich aber auch mit der FW 1.57 im WR hin und wieder.
                                  Es soll wohl inzwischen eine FW-Version, glaube 2.36D geben, die auch wieder ohne Relais den WR einspeisen lässt.
                                  • M MPF
                                    Rene55R Offline
                                    Rene55R Offline
                                    Rene55
                                    #520
                                    @mpf Das mit dem sporadischen 'ControlCode'-Fehler ist ja auch schon öfters angesprochen worden. Es handelt sich hier um eine Information, die im inneren des WR produziert wird. Wann dies ausgelöst wird ist mir immer noch nicht bekannt. Es ist nach meiner Auffassung nur fatal, wenn der WR so eine Meldung ausgibt, die Daten einfach so zu übernehmen. Ich hab diesen Effekt auch zwischen 2 und 5 mal am Tag.
                                    Ich bin mal gespannt, ob ich die neue Firmware überhaupt sinnvoll handeln kann egal ob 2.32 oder 2.36.
                                    • Rene55R Rene55
                                      skybundi
                                      #521
                                      Hat funktionierte, danke für die Hilfe.
                                      • Rene55R Rene55
                                        MPF
                                        #522
                                        @rene55 ich habe den Adapter vorgestern auch noch mal komplett neu von Github installiert. Seit dem bisher kein ControlCode-Fehler mit der 1.57Firmware.
                                        • ralleR ralle
                                          Rene55R Offline
                                          Rene55R Offline
                                          Rene55
                                          #523
                                          @ralle Das hat schon mal nicht geklappt. Kommunikation mit safetytaxfree funktioniert gut nur: Leider können wir Ihnen kein Relais zuschicken, da Ihr Wechselrichter von dem Hersteller Bosswerke ist. Dann heißt es weiter warten.
                                          G 1 Antwort Letzte Antwort
