  4. [gelöst] pivccu3 3.71.12 und nodejs 18.x
    5.1k
3.71.12nodejs 18pivccu3
148 Beiträge 7 Kommentatoren 30.3k Aufrufe 3 Beobachtet
  • M meicker
    marc@ioBroker:~$ dmesg
    [    0.000000] Booting Linux on physical CPU 0x500
    [    0.000000] Linux version 6.1.50-current-rockchip (armbian@next) (arm-linux-gnueabihf-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023
    [    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Rockchip RK3288 Asus Tinker Board S
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 16 MiB at 0x7f000000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
    [    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
    [    0.000000] percpu: Embedded 17 pages/cpu s40288 r8192 d21152 u69632
    [    0.000000] pcpu-alloc: s40288 r8192 d21152 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522560
    [    0.000000] Kernel command line: earlyprintk root=UUID=f9d46ad4-5004-44cd-9239-a862108641c5 rootwait rootfstype=ext4 console=ttyS2,115200n8 console=tty1 consoleblank=0 loglevel=1 ubootpart=ecdd8161-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    [    0.000000] The swapaccount= commandline option is deprecated. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
    [    0.000000] Unknown kernel command line parameters "earlyprintk ubootpart=ecdd8161-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] allocated 2097152 bytes of page_ext
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 2022472K/2097152K available (16384K kernel code, 2101K rwdata, 3572K rodata, 1024K init, 602K bss, 58296K reserved, 16384K cma-reserved, 1294336K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 48965 entries in 144 pages
    [    0.000000] ftrace: allocated 144 pages with 2 groups
    [    0.000000] trace event string verifier disabled
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] 	Rude variant of Tasks RCU enabled.
    [    0.000000] 	Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    [    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    [    0.000023] Switching to timer-based delay loop, resolution 41ns
    [    0.001892] Console: colour dummy device 80x30
    [    0.001963] printk: console [tty1] enabled
    [    0.002024] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    [    0.002050] CPU: Testing write buffer coherency: ok
    [    0.002109] CPU0: Spectre v2: using BPIALL workaround
    [    0.002123] pid_max: default: 32768 minimum: 301
    [    0.002269] LSM: Security Framework initializing
    [    0.002295] Yama: becoming mindful.
    [    0.002465] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.002493] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.004174] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
    [    0.006143] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.006159] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.006382] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.006395] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.006599] cblist_init_generic: Setting adjustable number of callback queues.
    [    0.006612] cblist_init_generic: Setting shift to 2 and lim to 1.
    [    0.006851] Setting up static identity map for 0x100000 - 0x100060
    [    0.007103] rcu: Hierarchical SRCU implementation.
    [    0.007115] rcu: 	Max phase no-delay instances is 1000.
    [    0.008408] smp: Bringing up secondary CPUs ...
    [    0.010763] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
    [    0.010787] CPU1: Spectre v2: using BPIALL workaround
    [    0.013383] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
    [    0.013406] CPU2: Spectre v2: using BPIALL workaround
    [    0.015918] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
    [    0.015941] CPU3: Spectre v2: using BPIALL workaround
    [    0.016162] smp: Brought up 1 node, 4 CPUs
    [    0.016184] SMP: Total of 4 processors activated (192.00 BogoMIPS).
    [    0.016199] CPU: All CPU(s) started in SVC mode.
    [    0.017281] devtmpfs: initialized
    [    0.037634] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
    [    0.038019] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.038056] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.039019] pinctrl core: initialized pinctrl subsystem
    [    0.041191] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.043840] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.044953] audit: initializing netlink subsys (disabled)
    [    0.045273] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
    [    0.046869] thermal_sys: Registered thermal governor 'step_wise'
    [    0.046975] cpuidle: using governor ladder
    [    0.047038] cpuidle: using governor menu
    [    0.048040] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.048061] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.056929] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio6@ff7d0000
    [    0.057030] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio7@ff7e0000
    [    0.079249] platform ff930000.vop: Fixed dependency cycle(s) with /hdmi@ff980000
    [    0.126610] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
    [    0.196977] raid6: neonx8   gen()   759 MB/s
    [    0.265217] raid6: neonx4   gen()  1221 MB/s
    [    0.333433] raid6: neonx2   gen()  1074 MB/s
    [    0.401672] raid6: neonx1   gen()   767 MB/s
    [    0.469884] raid6: int32x8  gen()   244 MB/s
    [    0.538146] raid6: int32x4  gen()   261 MB/s
    [    0.606360] raid6: int32x2  gen()   268 MB/s
    [    0.674548] raid6: int32x1  gen()   264 MB/s
    [    0.674561] raid6: using algorithm neonx4 gen() 1221 MB/s
    [    0.742715] raid6: .... xor() 807 MB/s, rmw enabled
    [    0.742729] raid6: using neon recovery algorithm
    [    0.744681] iommu: Default domain type: Translated
    [    0.744699] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.745548] SCSI subsystem initialized
    [    0.745940] usbcore: registered new interface driver usbfs
    [    0.746030] usbcore: registered new interface driver hub
    [    0.746107] usbcore: registered new device driver usb
    [    0.746328] mc: Linux media interface: v0.10
    [    0.746384] videodev: Linux video capture interface: v2.00
    [    0.746563] pps_core: LinuxPPS API ver. 1 registered
    [    0.746576] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.746608] PTP clock support registered
    [    0.748341] Bluetooth: Core ver 2.22
    [    0.748437] NET: Registered PF_BLUETOOTH protocol family
    [    0.748450] Bluetooth: HCI device and connection manager initialized
    [    0.748473] Bluetooth: HCI socket layer initialized
    [    0.748492] Bluetooth: L2CAP socket layer initialized
    [    0.748532] Bluetooth: SCO socket layer initialized
    [    0.748736] NetLabel: Initializing
    [    0.748745] NetLabel:  domain hash size = 128
    [    0.748755] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
    [    0.748862] NetLabel:  unlabeled traffic allowed by default
    [    0.749871] clocksource: Switched to clocksource arch_sys_counter
    [    0.899786] VFS: Disk quotas dquot_6.6.0
    [    0.899910] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.900170] FS-Cache: Loaded
    [    0.900542] CacheFiles: Loaded
    [    0.920845] NET: Registered PF_INET protocol family
    [    0.921199] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.924464] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 10240 bytes, linear)
    [    0.924519] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.924549] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.924722] TCP bind hash table entries: 8192 (order: 6, 327680 bytes, linear)
    [    0.925191] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.925345] UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
    [    0.925438] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
    [    0.925822] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.927554] Trying to unpack rootfs image as initramfs...
    [    0.928566] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
    [    0.931640] Initialise system trusted keyrings
    [    0.932047] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.944367] zbud: loaded
    [    0.947365] SGI XFS with ACLs, security attributes, realtime, scrub, quota, no debug enabled
    [    1.099002] xor: measuring software checksum speed
    [    1.109342]    arm4regs        :   957 MB/sec
    [    1.121219]    8regs           :   829 MB/sec
    [    1.133093]    32regs          :   829 MB/sec
    [    1.140190]    neon            :  1394 MB/sec
    [    1.140205] xor: using function: neon (1394 MB/sec)
    [    1.140228] Key type asymmetric registered
    [    1.140242] Asymmetric key parser 'x509' registered
    [    1.140570] bounce: pool size: 64 pages
    [    1.140802] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
    [    1.141176] io scheduler mq-deadline registered
    [    1.141195] io scheduler kyber registered
    [    1.155229] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
    [    1.155255] dma-pl330 ff250000.dma-controller: 	DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
    [    1.157099] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
    [    1.157123] dma-pl330 ffb20000.dma-controller: 	DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
    [    1.160108] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
    [    1.164735] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
    [    1.165074] serial serial0: tty port ttyS0 registered
    [    1.166933] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud = 1500000) is a 16550A
    [    1.167417] printk: console [ttyS2] enabled
    [    1.169224] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud = 1500000) is a 16550A
    [    1.171158] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 41, base_baud = 1500000) is a 16550A
    [    1.180918] rockchip-vop ff930000.vop: Adding to iommu group 1
    [    1.182234] rockchip-vop ff940000.vop: Adding to iommu group 2
    [    1.189256] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc1179314)
    [    1.189973] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc1179314)
    [    1.190105] dwhdmi-rockchip ff980000.hdmi: supply avdd-0v9 not found, using dummy regulator
    [    1.190396] dwhdmi-rockchip ff980000.hdmi: supply avdd-1v8 not found, using dummy regulator
    [    1.191898] usbcore: registered new interface driver udl
    [    1.200415] brd: module loaded
    [    1.214823] loop: module loaded
    [    1.217751] rockchip-spi ff130000.spi: cs1 >= max 1
    [    1.217778] spi_master spi2: spi_device register error /spi@ff130000/spidev@1
    [    1.217828] spi_master spi2: Failed to create SPI device for /spi@ff130000/spidev@1
    [    1.221512] tun: Universal TUN/TAP device driver, 1.6
    [    1.221933] CAN device driver interface
    [    1.224887] usbcore: registered new interface driver rt2500usb
    [    1.224979] usbcore: registered new interface driver rt73usb
    [    1.225064] usbcore: registered new interface driver rt2800usb
    [    1.225150] usbcore: registered new interface driver rtl8xxxu
    [    1.225251] usbcore: registered new interface driver rndis_wlan
    [    1.225335] usbcore: registered new interface driver cdc_ether
    [    1.225410] usbcore: registered new interface driver rndis_host
    [    1.226240] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
    [    1.226513] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
    [    1.286514] dwc2 ff540000.usb: DWC OTG Controller
    [    1.286567] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
    [    1.286642] dwc2 ff540000.usb: irq 48, io mem 0xff540000
    [    1.287008] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
    [    1.287036] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.287055] usb usb1: Product: DWC OTG Controller
    [    1.287070] usb usb1: Manufacturer: Linux 6.1.50-current-rockchip dwc2_hsotg
    [    1.287084] usb usb1: SerialNumber: ff540000.usb
    [    1.288217] hub 1-0:1.0: USB hub found
    [    1.288293] hub 1-0:1.0: 1 port detected
    [    1.289574] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
    [    1.289820] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
    [    1.418028] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
    [    1.419018] dwc2 ff580000.usb: DWC OTG Controller
    [    1.419068] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
    [    1.419124] dwc2 ff580000.usb: irq 49, io mem 0xff580000
    [    1.419435] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
    [    1.419461] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.419479] usb usb2: Product: DWC OTG Controller
    [    1.419494] usb usb2: Manufacturer: Linux 6.1.50-current-rockchip dwc2_hsotg
    [    1.419508] usb usb2: SerialNumber: ff580000.usb
    [    1.420534] hub 2-0:1.0: USB hub found
    [    1.420607] hub 2-0:1.0: 1 port detected
    [    1.424951] ehci-platform ff500000.usb: EHCI Host Controller
    [    1.425154] usbcore: registered new interface driver usb-storage
    [    1.425395] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
    [    1.426628] ehci-platform ff500000.usb: irq 50, io mem 0xff500000
    [    1.426763] usbcore: registered new interface driver iforce
    [    1.426877] usbcore: registered new interface driver xpad
    [    1.427054] usbcore: registered new interface driver usbtouchscreen
    [    1.427896] i2c_dev: i2c /dev entries driver
    [    1.439650] usbcore: registered new interface driver bfusb
    [    1.439767] usbcore: registered new interface driver btusb
    [    1.440646] sdhci: Secure Digital Host Controller Interface driver
    [    1.440660] sdhci: Copyright(c) Pierre Ossman
    [    1.440671] Synopsys Designware Multimedia Card Interface Driver
    [    1.441776] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.442659] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
    [    1.442678] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.442813] hid: raw HID events driver (C) Jiri Kosina
    [    1.443033] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
    [    1.443061] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
    [    1.443170] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 56,32 bit host data width,256 deep fifo
    [    1.443386] usbcore: registered new interface driver usbhid
    [    1.443404] usbhid: USB HID core driver
    [    1.443516] mmc_host mmc0: card is non-removable.
    [    1.447094] NET: Registered PF_INET6 protocol family
    [    1.449448] Segment Routing with IPv6
    [    1.449530] In-situ OAM (IOAM) with IPv6
    [    1.449676] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.451919] NET: Registered PF_PACKET protocol family
    [    1.452012] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.452030] can: controller area network core
    [    1.452128] NET: Registered PF_CAN protocol family
    [    1.452408] Bluetooth: RFCOMM TTY layer initialized
    [    1.452439] Bluetooth: RFCOMM socket layer initialized
    [    1.452482] Bluetooth: RFCOMM ver 1.11
    [    1.452517] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.452541] Bluetooth: HIDP socket layer initialized
    [    1.452819] 8021q: 802.1Q VLAN Support v1.8
    [    1.452874] lib80211: common routines for IEEE802.11 drivers
    [    1.452888] lib80211_crypt: registered algorithm 'NULL'
    [    1.452901] lib80211_crypt: registered algorithm 'WEP'
    [    1.452913] lib80211_crypt: registered algorithm 'CCMP'
    [    1.452925] lib80211_crypt: registered algorithm 'TKIP'
    [    1.452980] Key type dns_resolver registered
    [    1.453167] ThumbEE CPU extension supported.
    [    1.453192] Registering SWP/SWPB emulation handler
    [    1.454762] Loading compiled-in X.509 certificates
    [    1.456347] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    1.462973] zswap: loaded using pool zstd/z3fold
    [    1.463810] Key type .fscrypt registered
    [    1.463829] Key type fscrypt-provisioning registered
    [    1.466363] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
    [    1.536344] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc1179314)
    [    1.536963] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc1179314)
    [    1.537107] dwhdmi-rockchip ff980000.hdmi: supply avdd-0v9 not found, using dummy regulator
    [    1.537414] dwhdmi-rockchip ff980000.hdmi: supply avdd-1v8 not found, using dummy regulator
    [    1.537811] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
    [    1.539104] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc117cbe0)
    [    1.547050] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
    [    1.547144] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
    [    1.554627] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    1.593958] usb 1-1: new high-speed USB device number 2 using dwc2
    [    1.613906] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
    [    1.614352] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
    [    1.614380] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.614400] usb usb3: Product: EHCI Host Controller
    [    1.614414] usb usb3: Manufacturer: Linux 6.1.50-current-rockchip ehci_hcd
    [    1.614429] usb usb3: SerialNumber: ff500000.usb
    [    1.615493] hub 3-0:1.0: USB hub found
    [    1.615589] hub 3-0:1.0: 1 port detected
    [    1.823607] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
    [    1.823641] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    1.823660] usb 1-1: Product: USB2.0 Hub
    [    1.824860] hub 1-1:1.0: USB hub found
    [    1.825248] hub 1-1:1.0: 4 ports detected
    [    2.001915] dwmmc_rockchip ff0f0000.mmc: Busy; trying anyway
    [    2.044930] Freeing initrd memory: 12296K
    [    2.081817] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    2.095792] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    [    2.099878] Freeing unused kernel image (initmem) memory: 1024K
    [    2.126309] Run /init as init process
    [    2.126326]   with arguments:
    [    2.126335]     /init
    [    2.126345]     earlyprintk
    [    2.126354]   with environment:
    [    2.126361]     HOME=/
    [    2.126370]     TERM=linux
    [    2.126378]     ubootpart=ecdd8161-01
    [    2.126387]     cgroup_enable=memory
    [    2.126395]     cgroup_memory=1
    [    2.503472] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
    [    2.503861] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
    [    2.503914] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
    [    2.517428] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
    [    3.061947] dwmmc_rockchip ff0f0000.mmc: Busy; trying anyway
    [    3.140781] rockchip-gpio ff750000.gpio: probed /pinctrl/gpio@ff750000
    [    3.142409] rockchip-gpio ff780000.gpio: probed /pinctrl/gpio@ff780000
    [    3.142619] rk808 0-001b: chip id: 0x0
    [    3.144505] rockchip-gpio ff790000.gpio: probed /pinctrl/gpio@ff790000
    [    3.145627] rockchip-gpio ff7a0000.gpio: probed /pinctrl/gpio@ff7a0000
    [    3.146687] rockchip-gpio ff7b0000.gpio: probed /pinctrl/gpio@ff7b0000
    [    3.146745] dw-apb-uart ff180000.serial: Failed to create device link (0x180) with ff7b0000.gpio
    [    3.147787] rockchip-gpio ff7c0000.gpio: probed /pinctrl/gpio@ff7c0000
    [    3.187670] rockchip-gpio ff7d0000.gpio: probed /pinctrl/gpio@ff7d0000
    [    3.217828] rockchip-gpio ff7e0000.gpio: probed /pinctrl/gpio@ff7e0000
    [    3.218432] vdd10_lcd: Bringing 800000uV into 1000000-1000000uV
    [    3.219485] rockchip-gpio ff7f0000.gpio: probed /pinctrl/gpio@ff7f0000
    [    3.441373] rk808-rtc rk808-rtc: registered as rtc0
    [    3.447735] rk808-rtc rk808-rtc: setting system clock to 2013-01-18T08:50:24 UTC (1358499024)
    [    3.562924] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
    [    3.581113] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
    [    3.606306] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
    [    3.606559] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
    [    3.606977] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
    [    3.607004] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
    [    3.607023] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
    [    3.607051] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
    [    3.607150] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
    [    3.612186] rk_gmac-dwmac ff290000.ethernet: init for RGMII
    [    3.612553] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
    [    3.612584] rk_gmac-dwmac ff290000.ethernet: 	DWMAC1000
    [    3.612600] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
    [    3.612614] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
    [    3.612627] rk_gmac-dwmac ff290000.ethernet: COE Type 2
    [    3.612640] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
    [    3.612653] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
    [    3.612809] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
    [    3.612828] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
    [    3.612842] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
    [    3.701931] usb 3-1: new high-speed USB device number 2 using ehci-platform
    [    4.059596] usb 3-1: config 1 has an invalid interface number: 255 but max is 6
    [    4.059628] usb 3-1: config 1 has no interface number 6
    [    4.061080] usb 3-1: New USB device found, idVendor=0bda, idProduct=481a, bcdDevice= 0.00
    [    4.061106] usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
    [    4.061125] usb 3-1: Product: USB Audio
    [    4.061140] usb 3-1: Manufacturer: Generic
    [    4.061153] usb 3-1: SerialNumber: 201405280001
    [    4.129953] dwmmc_rockchip ff0f0000.mmc: Busy; trying anyway
    [    4.629983] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
    [    4.630917] input: Generic USB Audio Consumer Control as /devices/platform/ff500000.usb/usb3/3-1/3-1:1.255/0003:0BDA:481A.0001/input/input1
    [    4.643925] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 187500Hz, actual 187500HZ div = 0)
    [    4.693644] RTL8211E Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
    [    4.693677] RTL8211E Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
    [    4.694898] input: Generic USB Audio as /devices/platform/ff500000.usb/usb3/3-1/3-1:1.255/0003:0BDA:481A.0001/input/input2
    [    4.696096] hid-generic 0003:0BDA:481A.0001: input,hiddev96,hidraw0: USB HID v1.11 Device [Generic USB Audio] on usb-ff500000.usb-1/input255
    [    4.702556] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
    [    4.704438] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
    [    4.704483] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
    [    4.704592] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 80,32 bit host data width,256 deep fifo
    [    4.707402] mmc_host mmc1: card is polling.
    [    4.720642] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    4.723795] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
    [    4.728194] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
    [    4.728224] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
    [    4.728333] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 81,32 bit host data width,256 deep fifo
    [    4.730412] dwmmc_rockchip ff0d0000.mmc: allocated mmc-pwrseq
    [    4.730440] mmc_host mmc2: card is non-removable.
    [    4.742046] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
    [    4.772877] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
    [    4.774316] mmc2: new high speed SDIO card at address 0001
    [    4.774963] input: gpio-keys as /devices/platform/gpio-keys/input/input3
    [    4.811742] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
    [    5.205944] dwmmc_rockchip ff0f0000.mmc: Busy; trying anyway
    [    5.345197] dwmmc_rockchip ff0c0000.mmc: Successfully tuned phase to 199
    [    5.345243] mmc1: new ultra high speed SDR104 SDHC card at address e624
    [    5.349672] mmcblk1: mmc1:e624 SL16G 14.8 GiB
    [    5.357900]  mmcblk1: p1
    [    5.705975] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
    [    7.252534] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none.
    [    7.894341] systemd[1]: System time before build time, advancing clock.
    [    7.953303] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
    [    7.955497] systemd[1]: Detected architecture arm.
    [    7.967453] systemd[1]: Set hostname to <ioBroker>.
    [    8.205408] dw-apb-uart ff690000.serial: forbid DMA for kernel console
    [    9.295284] systemd[1]: Queued start job for default target Graphical Interface.
    [   11.349893] random: crng init done
    [   11.373293] systemd[1]: Created slice system-getty.slice.
    [   11.378217] systemd[1]: Created slice system-modprobe.slice.
    [   11.382566] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [   11.386626] systemd[1]: Created slice User and Session Slice.
    [   11.387245] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
    [   11.387947] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [   11.390445] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [   11.391265] systemd[1]: Reached target Local Encrypted Volumes.
    [   11.392355] systemd[1]: Reached target Paths.
    [   11.393089] systemd[1]: Reached target Slices.
    [   11.393755] systemd[1]: Reached target Swap.
    [   11.394471] systemd[1]: Reached target System Time Set.
    [   11.453522] systemd[1]: Listening on RPCbind Server Activation Socket.
    [   11.455329] systemd[1]: Listening on Syslog Socket.
    [   11.456953] systemd[1]: Listening on fsck to fsckd communication Socket.
    [   11.458108] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [   11.467054] systemd[1]: Listening on Journal Audit Socket.
    [   11.468707] systemd[1]: Listening on Journal Socket (/dev/log).
    [   11.470680] systemd[1]: Listening on Journal Socket.
    [   11.473379] systemd[1]: Listening on udev Control Socket.
    [   11.474963] systemd[1]: Listening on udev Kernel Socket.
    [   11.476615] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [   11.502623] systemd[1]: Mounting POSIX Message Queue File System...
    [   11.513064] systemd[1]: Mounting RPC Pipe File System...
    [   11.526249] systemd[1]: Mounting Kernel Debug File System...
    [   11.539275] systemd[1]: Mounting Kernel Trace File System...
    [   11.541832] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
    [   11.558380] systemd[1]: Starting Restore / save the current clock...
    [   11.570773] systemd[1]: Starting Set the console keyboard layout...
    [   11.583713] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [   11.598595] systemd[1]: Starting Load Kernel Module configfs...
    [   11.611400] systemd[1]: Starting Load Kernel Module drm...
    [   11.634582] systemd[1]: Starting Load Kernel Module fuse...
    [   11.651189] systemd[1]: Started Nameserver information manager.
    [   11.654210] systemd[1]: Reached target Network (Pre).
    [   11.659479] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [   11.659969] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [   11.675499] systemd[1]: Starting Load Kernel Modules...
    [   11.683268] RPC: Registered named UNIX socket transport module.
    [   11.683292] RPC: Registered udp transport module.
    [   11.683305] RPC: Registered tcp transport module.
    [   11.683315] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [   11.695101] systemd[1]: Starting Remount Root and Kernel File Systems...
    [   11.709579] systemd[1]: Starting Coldplug All udev Devices...
    [   11.716511] fuse: init (API version 7.37)
    [   11.736290] systemd[1]: Mounted POSIX Message Queue File System.
    [   11.738199] systemd[1]: Mounted RPC Pipe File System.
    [   11.739921] systemd[1]: Mounted Kernel Debug File System.
    [   11.741593] systemd[1]: Mounted Kernel Trace File System.
    [   11.747451] systemd[1]: Finished Restore / save the current clock.
    [   11.752898] systemd[1]: Finished Create list of static device nodes for the current kernel.
    [   11.756790] systemd[1]: modprobe@configfs.service: Succeeded.
    [   11.760546] systemd[1]: Finished Load Kernel Module configfs.
    [   11.764302] systemd[1]: modprobe@drm.service: Succeeded.
    [   11.768951] systemd[1]: Finished Load Kernel Module drm.
    [   11.773092] systemd[1]: modprobe@fuse.service: Succeeded.
    [   11.777178] systemd[1]: Finished Load Kernel Module fuse.
    [   11.793362] systemd[1]: Finished Load Kernel Modules.
    [   11.827513] systemd[1]: Mounting FUSE Control File System...
    [   11.844281] systemd[1]: Mounting Kernel Configuration File System...
    [   11.857119] systemd[1]: Starting Apply Kernel Variables...
    [   11.876552] systemd[1]: Mounted FUSE Control File System.
    [   11.878109] systemd[1]: Mounted Kernel Configuration File System.
    [   11.896459] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none.
    [   11.916453] systemd[1]: Finished Remount Root and Kernel File Systems.
    [   11.928293] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [   11.928811] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [   11.958289] systemd[1]: Starting Load/Save Random Seed...
    [   11.969155] systemd[1]: Starting Create System Users...
    [   11.983385] systemd[1]: Finished Apply Kernel Variables.
    [   12.144118] systemd[1]: Finished Load/Save Random Seed.
    [   12.145630] systemd[1]: Condition check resulted in First Boot Complete being skipped.
    [   12.157625] systemd[1]: Finished Create System Users.
    [   12.191918] systemd[1]: Starting Create Static Device Nodes in /dev...
    [   12.198257] systemd[1]: Finished Set the console keyboard layout.
    [   12.292080] systemd[1]: Finished Create Static Device Nodes in /dev.
    [   12.293344] systemd[1]: Reached target Local File Systems (Pre).
    [   12.327166] systemd[1]: Mounting /tmp...
    [   12.344120] systemd[1]: Starting Rule-based Manager for Device Events and Files...
    [   12.354875] systemd[1]: Mounted /tmp.
    [   12.356299] systemd[1]: Reached target Local File Systems.
    [   12.367614] systemd[1]: Starting Armbian leds state...
    [   12.380116] systemd[1]: Starting Armbian ZRAM config...
    [   12.397547] systemd[1]: Starting Set console font and keymap...
    [   12.410645] systemd[1]: Starting Preprocess NFS configuration...
    [   12.412348] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
    [   12.413067] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    [   12.461260] systemd[1]: nfs-config.service: Succeeded.
    [   12.465949] systemd[1]: Finished Preprocess NFS configuration.
    [   12.472752] systemd[1]: Finished Set console font and keymap.
    [   12.477439] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
    [   12.477573] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
    [   12.477714] systemd[1]: Reached target NFS client services.
    [   12.555274] systemd[1]: Finished Armbian leds state.
    [   12.584577] systemd[1]: Started Rule-based Manager for Device Events and Files.
    [   12.863765] systemd[1]: Finished Coldplug All udev Devices.
    [   12.927521] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
    [   12.970562] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
    [   12.999468] systemd[1]: Starting Raise network interfaces...
    [   13.086665] zram: Added device: zram0
    [   13.311438] zram: Added device: zram1
    [   13.539233] zram: Added device: zram2
    [   13.638525] generic_raw_uart: loading out-of-tree module taints kernel.
    [   13.641706] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
    [   13.641740] cpu cpu0: _opp_add: OPP not supported by regulators (2016000000)
    [   13.642264] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
    [   13.642293] cpu cpu0: _opp_add: OPP not supported by regulators (2040000000)
    [   13.646004] core: _opp_supported_by_regulators: OPP minuV: 1475000 maxuV: 1475000, not supported by regulator
    [   13.646038] cpu cpu0: _opp_add: OPP not supported by regulators (2064000000)
    [   13.646545] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.646570] cpu cpu0: _opp_add: OPP not supported by regulators (2088000000)
    [   13.647198] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.647225] cpu cpu0: _opp_add: OPP not supported by regulators (2112000000)
    [   13.647868] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.647894] cpu cpu0: _opp_add: OPP not supported by regulators (2136000000)
    [   13.648309] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.649425] cpu cpu0: _opp_add: OPP not supported by regulators (2160000000)
    [   13.650305] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.650333] cpu cpu0: _opp_add: OPP not supported by regulators (2184000000)
    [   13.650781] core: _opp_supported_by_regulators: OPP minuV: 1500000 maxuV: 1500000, not supported by regulator
    [   13.650807] cpu cpu0: _opp_add: OPP not supported by regulators (2208000000)
    [   13.650859] cpu cpu0: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 1704000000, volt: 1350000, enabled: 1. New: freq: 1704000000, volt: 1350000, enabled: 1
    [   13.650910] cpu cpu0: _opp_is_duplicate: duplicate OPPs detected. Existing: freq: 1800000000, volt: 1400000, enabled: 1. New: freq: 1800000000, volt: 1400000, enabled: 1
    [   13.651941] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 500000 KHz, changing to: 600000 KHz
    [   13.668538] systemd[1]: Finished Raise network interfaces.
    [   13.724055] rtc-rx8130 1-0032: Enabling charging of external capacitor
    [   13.724465] rtc-rx8130 1-0032: Update timer was detected
    [   13.726664] rtc-rx8130 1-0032: registered as rtc1
    [   13.733900] systemd[1]: Found device /dev/ttyS2.
    [   13.752900] Bluetooth: HCI UART driver ver 2.3
    [   13.752914] Bluetooth: HCI UART protocol H4 registered
    [   13.752918] Bluetooth: HCI UART protocol ATH3K registered
    [   13.752989] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   13.753132] Bluetooth: HCI UART protocol Broadcom registered
    [   13.753229] dw-apb-uart ff180000.serial: failed to request DMA
    [   13.764406] systemd[1]: Reached target Hardware activated USB gadget.
    [   13.775268] dw_wdt ff800000.watchdog: No valid TOPs array specified
    [   13.776424] gpiomem-rk3288 ff750000.rk3288-gpiomem: Initialised: Registers at 0xff750000
    [   13.782297] zram0: detected capacity change from 0 to 2052176
    [   13.820039] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
    [   13.828500] Adding 1026084k swap on /dev/zram0.  Priority:5 extents:1 across:1026084k SSFS
    [   13.832463] r8723bs: unknown parameter 'rtw_enusbss' ignored
    [   13.833037] pnetdev = 67370abf
    [   13.909883] dw_apb_raw_uart ff190000.serial: Initialized dw_apb device; mapbase=0xff190000; irq=83; sclk rate=1843200; pclk rate=74250000
    [   13.909922] dw_apb_raw_uart ff190000.serial: Detected RPI-RF-MOD, using alternative reset pin
    [   13.910109] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio6@ff7d0000
    [   13.910131] dw_apb_raw_uart ff190000.serial: No valid reset pin configured
    [   13.910149] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio7@ff7e0000
    [   13.910167] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio7@ff7e0000
    [   13.910184] OF: /serial@ff190000: could not get #gpio-cells for /pinctrl/gpio7@ff7e0000
    [   13.910220] raw-uart raw-uart: Reset radio module
    [   13.910226] raw-uart raw-uart: Registered new raw-uart device using underlying device GPIO@ff190000.serial.
    [   14.389171] rk3288-crypto ff8a0000.crypto: will run requests pump with realtime priority
    [   14.393953] rk3288-crypto ff8a0000.crypto: Crypto Accelerator successfully registered
    [   14.403896] rockchip-iep ff900000.iep: Adding to iommu group 0
    [   14.404894] rockchip-rga ff920000.rga: HW Version: 0x00.00
    [   14.404896] rockchip-iep ff900000.iep: Device rockchip-iep registered as /dev/video0
    [   14.405472] rockchip-rga ff920000.rga: Registered rockchip-rga as /dev/video1
    [   14.417012] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
    [   14.441978] hantro-vpu ff9a0000.video-codec: Adding to iommu group 3
    [   14.442690] hantro-vpu ff9a0000.video-codec: registered rockchip,rk3288-vpu-enc as /dev/video2
    [   14.443342] rkvdec ff9c0000.hevc: Adding to iommu group 4
    [   14.443498] hantro-vpu ff9a0000.video-codec: registered rockchip,rk3288-vpu-dec as /dev/video3
    [   14.444084] panfrost ffa30000.gpu: clock rate = 400000000
    [   14.473393] zram1: detected capacity change from 0 to 102400
    [   14.481835] panfrost ffa30000.gpu: [drm:panfrost_devfreq_init [panfrost]] Failed to register cooling device
    [   14.481978] panfrost ffa30000.gpu: mali-t760 id 0x750 major 0x0 minor 0x0 status 0x1
    [   14.481988] panfrost ffa30000.gpu: features: 00000000,00000407, issues: 00000000,24040400
    [   14.481997] panfrost ffa30000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
    [   14.482007] panfrost ffa30000.gpu: shader_present=0xf l2_present=0x1
    [   14.483635] [drm] Initialized panfrost 1.2.0 20180908 for ffa30000.gpu on minor 1
    [   14.488982] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
    [   14.493198] Bluetooth: hci0: RTL: rom_version status=0 version=1
    [   14.493219] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723bs_fw.bin
    [   14.510610] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723bs_config.bin
    [   14.518537] systemd[1]: Finished Armbian ZRAM config.
    [   14.534487] Bluetooth: hci0: RTL: cfg_sz 68, total sz 24088
    [   14.538745] systemd[1]: Starting Armbian memory supported logging...
    [   14.561156] usb 3-1: 4:11: invalid format type 0x2001 is detected, processed as PCM
    [   14.620443] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
    [   14.620474] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
    [   14.717424] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [   14.738541] systemd[1]: Starting Load/Save RF Kill Switch Status...
    [   14.901020] systemd[1]: Reached target Bluetooth.
    [   14.909094] systemd[1]: Started Load/Save RF Kill Switch Status.
    [   15.181353] Bluetooth: hci0: RTL: fw version 0x1e4cc3ff
    [   16.624217] usbcore: registered new interface driver snd-usb-audio
    [   16.683026] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
    [   16.683389] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [   16.683679] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
    [   16.683768] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
    [   16.683949] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [   16.684062] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
    [   16.684127] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
    [   18.760838] systemd[1]: Finished Armbian memory supported logging.
    [   18.782015] systemd[1]: Starting Journal Service...
    [   18.943181] systemd[1]: Started Journal Service.
    [   18.996986] systemd-journald[666]: Received client request to flush runtime journal.
    [   22.185320] systemd-journald[666]: Received client request to relinquish /var/log/journal/078479a1b0a4459f80590dd571c3d6de access.
    [   22.795028] raw-uart raw-uart: Reset radio module
    [   23.918807] rk_gmac-dwmac ff290000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
    [   23.922639] rk_gmac-dwmac ff290000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
    [   23.922669] rk_gmac-dwmac ff290000.ethernet eth0: No Safety Features support found
    [   23.922681] rk_gmac-dwmac ff290000.ethernet eth0: PTP not supported by HW
    [   23.932420] rk_gmac-dwmac ff290000.ethernet eth0: configuring for phy/rgmii link mode
    [   23.992407] rtl8723bs: acquire FW from file:rtlwifi/rtl8723bs_nic.bin
    [   25.116401] raw-uart raw-uart: Reset radio module
    [   26.850366] platform sound: deferred probe pending
    [   27.010698] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   27.010814] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [   27.036870] br0: port 1(eth0) entered blocking state
    [   27.036903] br0: port 1(eth0) entered disabled state
    [   27.037080] device eth0 entered promiscuous mode
    [   27.037195] br0: port 1(eth0) entered blocking state
    [   27.037204] br0: port 1(eth0) entered listening state
    [   27.072917] eth0: renamed from vethFWT4Hb
    [   42.209688] br0: port 1(eth0) entered learning state
    [   57.313561] br0: port 1(eth0) entered forwarding state
    [   57.313589] br0: topology change detected, propagating
    [   57.313687] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
    [   68.910512] eq3loop: created slave mmd_hmip
    [   68.912558] eq3loop: created slave mmd_bidcos
    [   71.041605] eq3loop: eq3loop_open_slave() mmd_bidcos
    [   88.427092] eq3loop: eq3loop_open_slave() mmd_hmip
    [   88.427254] eq3loop: eq3loop_close_slave() mmd_hmip
    [   88.433391] eq3loop: eq3loop_open_slave() mmd_hmip
    [   88.433539] eq3loop: eq3loop_close_slave() mmd_hmip
    [   88.434407] eq3loop: eq3loop_open_slave() mmd_hmip
    [   88.434589] eq3loop: eq3loop_close_slave() mmd_hmip
    [   88.442111] eq3loop: eq3loop_open_slave() mmd_hmip
    @meicker sagte in pivccu3 3.71.12 und nodejs 18.x:
    da scheint es loszugehen
    ob die open/close so sein dürfen weiss ich nicht
      @wildbill sagte in pivccu3 3.71.12 und nodejs 18.x:
      PiVCCU erstellt einen eigenen Container in dem dann die CCU läuft.
      Und baut network bridges. Das weiß ich auch noch.
      W Online
      W Online
      Wildbill
      @thomas-braun Wenn man PiVCCU und NodeJS googled kommen auch nur ein paar Threads im iobroker-Forum und einmal was in Vebindung mit Homebridge. Also sollte es PiVCCU meiner Meinung nach nicht jucken, ob da NodeJS parallel läuft und in welcher Version. Aber wer weiss schon...
      Gruss, Jürgen
      • W Wildbill
        Gruss, Jürgen
        Gruss, Jürgen
        tut es nicht! zumindest bisher
        ich weiß nich wieviele All in one Images ich damals gebaut habe und auch selber genutzt habe.
          meicker
          ich leider auch nicht .... Daher vielleicht wieder auf 16 zurück und testen:
          @Thomas-Braun
          wie komme ich sauber auf 16 zurück ? Hast Du da eine schöne Anleitung ? :-) Das was ich im Forum gefunden hatte war ja scheinbar veraltet ...
          • M meicker
            Hi Thomas,
            läuft wohl doch nicht zu 100% - Gestern war alles OK. Eben war das Board scheinbar am abschmieren und ist dann letztlich abgeschmiert. Das passiert zwischendurch und ich weiß bis heute nicht warum, Hab damals schon alles komplett neu gemacht und dennoch hängt sich das Board alle paar Tage mal auf ...
            Aber jetzt ist alles wieder so wie es war als es nicht lief. Homematic ist nicht erreichbar auf 192.168.1.30 - Funk scheint aber noch anzukommen, Homematic Fensterkontakte z.B signalisieren mit Grün aber die beiden hm-rega und rpc starten nicht mehr.
            Hier mal die komplette diagnose:
            Skript v.2023-06-20
            *** BASE SYSTEM ***
               Static hostname: ioBroker
                     Icon name: computer
                    Machine ID: 078479a1b0a4459f80590dd571c3d6de
                       Boot ID: 8f20e4fc59964966a9ffbb09a7990217
              Operating System: Armbian 23.8.1 bullseye
                        Kernel: Linux 6.1.50-current-rockchip
                  Architecture: arm
            model name	: ARMv7 Processor rev 1 (v7l)
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : armhf
            Systemuptime and Load:
             19:32:15 up 13 min,  1 user,  load average: 1.41, 6.61, 6.58
            CPU threads: 4
            *** Time and Time Zones ***
                           Local time: Fri 2023-09-29 19:32:15 CEST
                       Universal time: Fri 2023-09-29 17:32:15 UTC
                             RTC time: Tue 1973-08-14 17:06:08
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            marc
            /home/marc
            marc tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh bluetooth iobroker
            *** X-Server-Setup ***
            X-Server: 	false
            Desktop:
            Terminal: 	tty
            Boot Target: 	graphical.target
            *** MEMORY ***
            Mem:            2.0G        1.6G        212M        0.0K        231M        373M
            Swap:           1.0G        245M        756M
            Total:          3.0G        1.8G        969M
                     2004 M total memory
                     1560 M used memory
                      800 M active memory
                      722 M inactive memory
                      212 M free memory
                       14 M buffer memory
                      216 M swap cache
                     1002 M total swap
                      245 M used swap
                      756 M free swap
            *** FILESYSTEM ***
            udev           devtmpfs  988M     0  988M   0% /dev
            tmpfs          tmpfs     201M  3.5M  197M   2% /run
            /dev/mmcblk1p1 ext4       15G  9.9G  4.4G  70% /
            tmpfs          tmpfs    1003M     0 1003M   0% /dev/shm
            tmpfs          tmpfs    1003M  288K 1002M   1% /tmp
            /dev/zram1     ext4       49M   31M   15M  69% /var/log
            tmpfs          tmpfs     201M     0  201M   0% /run/user/1000
            [Fri Sep 29 19:19:14 2023] Kernel command line: earlyprintk root=UUID=f9d46ad4-5004-44cd-9239-a862108641c5 rootwait rootfstype=ext4 console=ttyS2,115200n8 console=tty1 consoleblank=0 loglevel=1 ubootpart=ecdd8161-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
            [Fri Sep 29 19:19:21 2023] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Quota mode: none.
            [Fri Sep 29 19:19:25 2023] EXT4-fs (mmcblk1p1): re-mounted. Quota mode: none.
            [Fri Sep 29 19:19:28 2023] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
            [Fri Sep 29 19:19:28 2023] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
            TARGET         SOURCE                   FSTYPE OPTIONS
            /              /dev/mmcblk1p1           ext4   rw,noatime,errors=remount-ro,commit=600
            |-/var/log.hdd /dev/mmcblk1p1[/var/log] ext4   rw,noatime,errors=remount-ro,commit=600
            `-/var/log     /dev/zram1               ext4   rw,relatime,discard
            /var:
            1.7G	/var/
            885M	/var/cache
            880M	/var/cache/apt
            815M	/var/cache/apt/archives
            678M	/var/lib
            Archived and active journals take up 7.5M in the file system.
            /opt/iobroker/backups:
            913M	/opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            684M	/opt/iobroker/iobroker-data/
            401M	/opt/iobroker/iobroker-data/files
            167M	/opt/iobroker/iobroker-data/backup-objects
            72M	/opt/iobroker/iobroker-data/files/telegram.admin
            55M	/opt/iobroker/iobroker-data/files/material
            41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            37M	/opt/iobroker/iobroker-data/objects.jsonl
            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.a3f9f634.js.map
            25M	/opt/iobroker/iobroker-data/objects.json.broken
            *** NodeJS-Installation ***
            /usr/bin/nodejs 	v18.18.0
            /usr/bin/node 		v18.18.0
            /usr/bin/npm 		9.8.1
            /usr/bin/npx 		9.8.1
            nodejs:
              Installed: 18.18.0-1nodesource1
              Candidate: 18.18.0-1nodesource1
              Version table:
             *** 18.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
                 12.22.12~dfsg-1~deb11u3 500
                    500 http://deb.debian.org/debian bullseye/main armhf Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            No configuration change needed.
            Multihost discovery server: disabled
            Discovery authentication:   enabled
            Persistent activation:      disabled
            Objects:                    jsonl on 127.0.0.1
            States:                     jsonl on 127.0.0.1
            Core adapters versions
            js-controller: 	5.0.12
            admin: 		6.10.1
            javascript: 	7.1.4
            Adapters from github: 	2
            Adapter State
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
            + system.adapter.controme.0               : controme              : ioBroker                                 -  enabled
              system.adapter.devices.0                : devices               : ioBroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
            + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
            + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            + system.adapter.homepilot20.0            : homepilot20           : ioBroker                                 -  enabled
            + system.adapter.hue-extended.0           : hue-extended          : ioBroker                                 -  enabled
            + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
            + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
              system.adapter.klf200.0                 : klf200                : ioBroker                                 - disabled
              system.adapter.material.0               : material              : ioBroker                                 - disabled
            + system.adapter.melcloud.0               : melcloud              : ioBroker                                 -  enabled
            + system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 -  enabled
              system.adapter.mobile.0                 : mobile                : ioBroker                                 - disabled
            + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
              system.adapter.simple-api.0             : simple-api            : ioBroker                                 - disabled, port: 8087, bind: 192.168.1.31, run as: admin
              system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
            + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
              system.adapter.synology.0               : synology              : ioBroker                                 - disabled, port: 5001
              system.adapter.systeminfo.0             : systeminfo            : ioBroker                                 - disabled
            + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : ioBroker                                 -  enabled, port: 8088, bind: 192.168.1.31, run as: admin
            + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
            + system.adapter.tinker.0                 : tinker                : ioBroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
            + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
              system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.31, run as: admin
            + system.adapter.withings.0               : withings              : ioBroker                                 -  enabled
            + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 6.10.1   , installed 6.10.1
            Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
            Adapter    "backitup"     : 2.8.1    , installed 2.8.1
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "discovery"    : 3.1.0    , installed 3.2.0
            Adapter    "geofency"     : 1.2.4    , installed 1.2.4
            Adapter    "history"      : 2.2.6    , installed 2.2.6
            Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
            Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "iot"          : 1.14.5   , installed 2.0.10
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.8
            Adapter    "javascript"   : 7.1.4    , installed 7.1.4
            Controller "js-controller": 5.0.12   , installed 5.0.12
            Adapter    "klf200"       : 1.0.1    , installed 1.0.1
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "melcloud"     : 1.3.5    , installed 1.3.5
            Adapter    "mercedesme"   : 0.1.1    , installed 0.1.1
            Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
            Adapter    "nuki-extended": 2.6.5    , installed 2.6.5
            Adapter    "plex"         : 1.0.5    , installed 1.0.5
            Adapter    "socketio"     : 6.5.5    , installed 6.5.5
            Adapter    "statistics"   : 2.3.0    , installed 2.3.0
            Adapter    "synology"     : 3.0.0    , installed 3.0.0
            Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
            Adapter    "telegram"     : 1.16.0   , installed 1.16.0
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "text2command" : 3.0.2    , installed 3.0.2
            Adapter    "tinker"       : 1.2.0    , installed 1.2.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "web"          : 6.1.2    , installed 6.1.2
            Adapter    "withings"     : 0.0.13   , installed 0.0.13
            Adapter    "ws"           : 2.5.5    , installed 2.5.5
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Objects and States
            Objects: 	33801
            States: 	22753
            Hit:1 http://deb.debian.org/debian bullseye InRelease
            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
            Hit:3 http://deb.debian.org/debian bullseye-backports InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
            Get:6 http://imola.armbian.com/apt bullseye InRelease [53.3 kB]
            Fetched 53.3 kB in 3s (18.6 kB/s)
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      112        20015      1143/redis-server 1
            tcp        0      0 127.0.0.1:36499         0.0.0.0:*               LISTEN      1001       27500      3805/io.yahka.0
            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       33006      3848/io.jarvis.0
            tcp        0      0 192.168.1.31:8082       0.0.0.0:*               LISTEN      1001       27561      3935/io.web.0
            tcp        0      0 192.168.1.31:2010       0.0.0.0:*               LISTEN      1001       42737      8290/io.hm-rpc.0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17638      1/init
            tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          21064      1260/dnsmasq
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21019      1206/sshd: /usr/sbi
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20254      1235/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20249      1235/iobroker.js-co
            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       32226      3892/io.terminal.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30764      3006/io.admin.0
            tcp6       0      0 :::40709                :::*                    LISTEN      1001       32094      3805/io.yahka.0
            tcp6       0      0 :::51989                :::*                    LISTEN      1001       32167      3748/io.nuki-extend
            tcp6       0      0 :::7999                 :::*                    LISTEN      1001       31096      3629/io.geofency.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          17641      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          21030      1206/sshd: /usr/sbi
            udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          21063      1260/dnsmasq
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          21060      1260/dnsmasq
            udp        0      0 0.0.0.0:48725           0.0.0.0:*                           1001       32170      3902/io.upnp.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13149      1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       32095      3805/io.yahka.0
            udp        0      0 192.168.1.31:5353       0.0.0.0:*                           1001       31160      3731/io.tr-064.0
            udp        0      0 127.0.0.1:323           0.0.0.0:*                           0          21696      1157/chronyd
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       33035      3902/io.upnp.0
            udp6       0      0 :::111                  :::*                                0          13152      1/init
            udp6       0      0 ::1:323                 :::*                                0          21697      1157/chronyd
            udp6       0      0 fe80::74ec:e37a:b8b:546 :::*                                0          23679      727/NetworkManager
            2023-09-29 19:30:22.692  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:30:32.108  - error: hm-rpc.0 (6019) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:30:55.780  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:31:02.086  - error: hm-rpc.0 (6019) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:31:04.021  - info: host.ioBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2023-09-29 19:31:04.022  - info: host.ioBroker Restart adapter system.adapter.hm-rpc.0 because enabled
            2023-09-29 19:31:28.836  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:31:34.858  - info: host.ioBroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
            2023-09-29 19:31:35.595  - info: host.ioBroker instance system.adapter.hm-rpc.0 started with pid 6615
            2023-09-29 19:31:46.063  - error: hm-rpc.0 (6615) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:32:01.924  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:32:16.074  - error: hm-rpc.0 (6615) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:32:18.072  - info: host.ioBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2023-09-29 19:32:18.074  - info: host.ioBroker Restart adapter system.adapter.hm-rpc.0 because enabled
            2023-09-29 19:32:35.012  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:32:49.987  - info: host.ioBroker instance system.adapter.hm-rpc.0 started with pid 7584
            2023-09-29 19:33:00.717  - error: hm-rpc.0 (7584) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:33:08.068  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:33:30.693  - error: hm-rpc.0 (7584) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            2023-09-29 19:33:34.244  - info: host.ioBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2023-09-29 19:33:34.246  - info: host.ioBroker Restart adapter system.adapter.hm-rpc.0 because enabled
            2023-09-29 19:33:41.123  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:34:06.440  - info: host.ioBroker instance system.adapter.hm-rpc.0 started with pid 8290
            2023-09-29 19:34:14.180  - error: hm-rega.0 (3643) CCU 192.168.1.30 unreachable
            2023-09-29 19:34:17.258  - error: hm-rpc.0 (8290) Init not possible, going to stop: connect EHOSTUNREACH 192.168.1.30:2010
            GlasfaserG Offline
            GlasfaserG Offline
            @meicker
            Eine Frage ,
            da es ja zwei Container sind , wie lange hast du gewartet bis alles gestartet ist .
            Eventuell ist der CCU Container noch nicht vollständig geladen und du schaust im Log vom ioBroker und siehst dann keine Verbindung !?
            Wäre jetzt noch die Frage , wie kann man herrausfinden ob überhaupt der CCU Container läuft , kenne mich leider mit pivccu3 nicht aus .
            HomoranH W M 3 Antworten Letzte Antwort
            • GlasfaserG Glasfaser
              @meicker
              Eine Frage ,
              @glasfaser sagte in pivccu3 3.71.12 und nodejs 18.x:
              sudo pivccu-info
              aber ich check es nochmal
              EDIT
              _____ _       _               ____                      _
              |_   _(_)_ __ | | _____ _ __  | __ )  ___   __ _ _ __ __| |
                | | | | '_ \| |/ / _ \ '__| |  _ \ / _ \ / _` | '__/ _` |
                | | | | | | |   <  __/ |    | |_) | (_) | (_| | | | (_| |
                |_| |_|_| |_|_|\_\___|_|    |____/ \___/ \__,_|_|  \__,_|
              Welcome to Armbian 22.11.1 Buster with Linux 5.15.80-rockchip
              No end-user support: unsupported (buster) userspace!
              System load:   2%               Up time:       38 days 11:41
              Memory usage:  13% of 1.96G     IP:            192.168.138.66
              CPU temp:      60°C             Usage of /:    6% of 28G
              RX today:      147.2 MiB
              Tip of the day: Submit your desktop wallpaper creation! https://forum.armbian.com/topic/29433-armbian-desktop-wallpaper-contest/
              [ General system configuration (beta): armbian-config ]
              Last login: Fri Feb  3 11:13:04 2023 from 192.168.138.145
              pi@tinkerboard:~$ sudo pivccu-info
              [sudo] password for pi:
              piVCCU version: 3.65.8-74
              Kernel modules: Available
              Raw UART dev:   Available
              HMRF Hardware:  RPI-RF-MOD
               Connected via: GPIO@ff190000.serial (/dev/raw-uart)
               Board serial:  58A992F452
               Radio MAC:     0xFFF452
              HMIP Hardware:  RPI-RF-MOD
               SGTIN:         3014F711A0001F58A992F452
               Radio MAC:     0xB3424E
              State:          RUNNING
              PID:            25935
              IP:             192.168.138.92
              CPU use:        133343.53 seconds
              BlkIO use:      8.89 MiB
              Memory use:     199.88 MiB
              KMem use:       4.24 MiB
              Link:           vethpivccu
               TX bytes:      8.87 GiB
               RX bytes:      4.17 GiB
               Total bytes:   13.05 GiB
              pi@tinkerboard:~$
                @meicker
                Eine Frage ,
                W Online
                W Online
                Wildbill
                schrieb am zuletzt editiert von Wildbill
                @glasfaser Mittels
                sudo systemctl status pivccu3
                sieht man zumindest mal, ob der zugehörige serivce, der dann den Container startet irgendwelche fehler geworfen hat oder sauber gestartet ist.
                PiVCCU gibt es wohl noch einige Befehle direkt, müsste ich aber auch mal googlen.
                Gruss, Jürgen
                EDIT: Genau, @Homoran hat den befehl für PiVCCU parat. Also schauen, was der service macht und dann mit pivccu-info direkt in den Container horchen, was da los ist
                HomoranH M 2 Antworten Letzte Antwort
                • M meicker
                  @Thomas-Braun
                  Ja, mein vollumfängliches 'Node-HowTo'.
                  https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                    Siehe edit
                    🤔 könnt ich auch mal neu aufsetzen 🤔
                    • W Wildbill
                      @glasfaser Mittels
                      Gruss, Jürgen
                      aber nicht im Container ausführen, das wsr bei lxccu
                      W 1 Antwort Letzte Antwort
                        W Online
                        W Online
                        Wildbill
                        @homoran Nee, ich meine schon vom Host aus. In den PiVCCU-Container kommt man glaub eh nicht so einfach rein. Zumindest SSH ist da glaub standardmäßig deaktivert?!
                          @meicker
                          Eine Frage ,
                          meicker
                          @glasfaser
                          hat immer alles funktioniert bis update auf 18 .... Es scheint ja auch das pivccu läuft und auch das hm Modul Funk empfängt. Fensterkontakte quittieren grün. Die Adapter gehen nicht mehr an. Normalerweise ist nach 2-3 Minuten alles hochgelaufen und funktioniert ...
                          • M meicker
                            @glasfaser
                            W Online
                            W Online
                            Wildbill
                            @meicker Hast Du die beiden Befehle mal ausgeführt und geschaut, was dabei rum kommt?
                            sudo pivccu-info
                            Gruss, Jürgen
                              sudo pivccu-info
                              EDIT
                              _____ _       _               ____                      _
                              RX today:      147.2 MiB
                               Radio MAC:     0xFFF452
                               Radio MAC:     0xB3424E
                              State:          RUNNING
                              PID:            25935
                              IP:             192.168.138.92
                              BlkIO use:      8.89 MiB
                              KMem use:       4.24 MiB
                              Link:           vethpivccu
                               TX bytes:      8.87 GiB
                               RX bytes:      4.17 GiB
                              pi@tinkerboard:~$
                              meicker
                              @homoran sagte in pivccu3 3.71.12 und nodejs 18.x:
                              sudo pivccu-info
                              piVCCU version: 3.71.12-85
                              OS:             Armbian 23.8.1 bullseye
                              Kernel:         6.1.50-current-rockchip armv7l
                               Board serial:  58A992FB3B
                               Radio MAC:     0xFFFB3B
                               SGTIN:         3014F711A0001F58A992FB3B
                               Radio MAC:     0xB3D162
                              State:          RUNNING
                              PID:            1701
                              IP:             192.168.1.30
                              Link:           vethpivccu
                               TX bytes:      56.93 KiB
                               RX bytes:      0 bytes
                               Total bytes:   56.93 KiB
                              die IP stimmt - ist aber nicht erreichbar. Vielleicht doch das Board ... ? Ich kann die 192.168.1.30 nicht erreichen:
                              marc@ioBroker:~$ ping 192.168.1.30
                              PING 192.168.1.30 (192.168.1.30) 56(84) bytes of data.
                              From 192.168.1.31 icmp_seq=1 Destination Host Unreachable
                              ^C
                              --- 192.168.1.30 ping statistics ---
                              4 packets transmitted, 0 received, +1 errors, 100% packet loss, time 3034ms
                              • W Wildbill
                                @glasfaser Mittels
                                Gruss, Jürgen
                                meicker
                                marc@ioBroker:~$ sudo systemctl status pivccu3
                                Unit pivccu3.service could not be found.
                                • W Wildbill
                                  sudo pivccu-info
                                  Gruss, Jürgen
                                  meicker
                                  sudo pivccu-info
                                  war unter gegangen - hatte ich aber gemacht:
                                  marc@ioBroker:~$ sudo pivccu-info
                                   Radio MAC:     0xFFFB3B
                                   Radio MAC:     0xB3D162
                                  State:          RUNNING
                                  PID:            1701
                                  IP:             192.168.1.30
                                  Link:           vethpivccu
                                   TX bytes:      60.97 KiB
                                   RX bytes:      0 bytes
                                   Total bytes:   60.97 KiB
                                  marc@ioBroker:~$
                                  • M meicker
                                    W Online
                                    W Online
                                    Wildbill
                                    Sorry, der Befehl heisst
                                    ohne 3 hinten. Das wurde wohl mal geändert. Früher gabe es Unterschiede zwischen „alter“ CCU per PiVCCU und neuer CCU3 per PiVCCU3.
                                    Aber da Du Infos mit pivccu-info bekommst scheint es zu laufen. Dann weiss ich grad auch nicht so wirklich weiter.
                                    Welche IP hat denn der Host, also der Rechner auf dem PiVCCU installiert ist. Und welche IP hat Dein Rechner, auf dem Du per Browser zugreifen willst?
                                    Gruss, Jürgen
                                      meicker
                                      Ich habe mein Tinker *kein S' wieder ausgegraben.
                                      Gleich tausche ich die SD, das Homematic Board um auf das alte Tinker und starte die Kiste mal. Bin gespannt ob es dann läuft. Wenn nicht liegt es nicht am Board.
                                      Ich hoffe nur das der Wechsel zwischen den beiden Tinker mit dem laufenden Betriebssystem kein Problem ist ...
                                      • W Wildbill
                                        Gruss, Jürgen
                                        meicker
                                        @wildbill
                                        ● pivccu.service - piVCCU
                                             Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; vendor preset: enabled)
                                             Active: active (running) since Fri 2023-09-29 18:17:16 CEST; 2h 33min ago
                                            Process: 1141 ExecStart=/var/lib/piVCCU3/start_container.sh (code=exited, status=0/SUCCESS)
                                           Main PID: 1700 (lxc-start)
                                              Tasks: 0 (limit: 4740)
                                             Memory: 312.0K
                                                CPU: 1.180s
                                             CGroup: /system.slice/pivccu.service
                                                     ‣ 1700 /usr/bin/lxc-start --lxcpath /var/lib/piVCCU3 --name lxc --pidfile /var/run/pivccu3.pid --daemon
                                        Sep 29 18:17:11 ioBroker systemd[1]: Starting piVCCU...
                                        Sep 29 18:17:14 ioBroker start_container.sh[1334]: cat: /sys/class/net//address: No such file or directory
                                        Sep 29 18:17:16 ioBroker start_container.sh[1697]: kernel.sched_rt_runtime_us = -1
                                        Sep 29 18:17:16 ioBroker systemd[1]: Started piVCCU.
                                        • M meicker
                                          @wildbill
                                               Memory: 312.0K
                                                  CPU: 1.180s
                                          W Online
                                          W Online
                                          Wildbill
                                          @meicker Bei mir sieht es so aus:
                                               Loaded: loaded (/lib/systemd/system/pivccu.service; enabled; preset: enabled)
                                               Active: active (running) since Sat 2023-09-02 10:51:00 CEST; 3 weeks 6 days ago
                                              Process: 757 ExecStart=/var/lib/piVCCU3/start_container.sh (code=exited, status=0/SUCCESS)
                                             Main PID: 1420 (lxc-start)
                                                Tasks: 0 (limit: 2057)
                                                  CPU: 3.179s
                                                       ‣ 1420 /usr/bin/lxc-start --lxcpath /var/lib/piVCCU3 --name lxc --pidfile /var/run/pivccu3.pid -->
                                          Sep 02 10:50:46 raspberrypi systemd[1]: Starting pivccu.service - piVCCU...
                                          Sep 02 10:50:57 raspberrypi start_container.sh[1417]: kernel.sched_rt_runtime_us = -1
                                          Sep 02 10:51:00 raspberrypi systemd[1]: Started pivccu.service - piVCCU.
                                          Bei Dir scheint der Container keine Adresse nach außen zu bekommen. Warum, habe ich keine Ahnung. Habe den Thread aber jetzt nicht ganz im Kopf. Ist der Host jetzt das Gerät, auf dem PiVCCU immer schon lief und wo Du nur auf NodeJS 18 gegangen bist und schon lief es nicht mehr? Oder ist das jetzt andere Hardware? Ich meine, die Network-Bridge, die PiVCCU aufbaut ist irgendwie an die MAC-Adresse der realen Netzwerkkarte gekoppelt, aber da bin ich dann auch raus. Das wäre dann eher etwas für das Homematic-Forum, wenn Du PiVCCU direkt so umziehen wolltest. Das geht im Normalfall nur per Backup, neu installieren auf der neuen Hardware und dann wieder ein restore.
                                          Gruss, Jürgen
