  4. Nach Update läuft nichts mehr!
    6.7k
iobroker updatenpmjs controller updatejsonhelp wanted
416 Beiträge 18 Kommentatoren 96.8k Aufrufe 9 Beobachtet
  • S SpeedyBlade
    aber du bist ja immer noch auf 18.17.1 => was ist daran falsch, hieß ja oben, dass v18 released ist
    pi@RaspberryPi4:~ $ iob status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module 'tar'
    Require stack:
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js
    - /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:121:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js:12:31)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/lib/setup/setupBackup.js',
        '/opt/iobroker/node_modules/@iobroker/js-controller-cli/build/index.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.17.1
    #364
    @speedyblade
    Das Skript zum Umstellen des nodesource-Repos kennst du ja schon.
    Versuch mal
    cd /opt/iobroker/node_modules/iobroker.js-controller
    sudo -H -u iobroker npm install tar
    • S SpeedyBlade
      pi@RaspberryPi4:~ $ node -v && nodejs -v && npm -v
      v18.18.0
      v18.18.0
      9.8.1
      ist up to date...ioBroker immer noch tot
      beim löschen von NodeJS bekomme ich immer folgende Meldung
      Entfernen von nodejs (18.17.1-deb-1nodesource1) ...
      dpkg: Warnung: Während Entfernens von nodejs ist Verzeichnis »/usr/lib/node_modules« nicht leer, wird daher nicht gelöscht
      Entfernen von perl-modules-5.28 (5.28.1-6+deb10u1) ...
      pi@RaspberryPi4:/lib $ cd /usr/lib/node_modules
      pi@RaspberryPi4:/usr/lib/node_modules $ dir
      corepack  n  npm
      bin mittlerweile sprachlos 🤕 :man-gesturing-ok:
      #365
      @speedyblade sagte in Nach Update läuft nichts mehr!:
      Warum????
      Lass die Finger davon, wenn die 18.18.0 (sauber!) drauf ist.
        @speedyblade
        Versuch mal
        SpeedyBlade
        #366
        pi@RaspberryPi4:/opt/iobroker/node_modules/iobroker.js-controller $ sudo -H -u iobroker npm install tar
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 295 packages, changed 1 package, and audited 305 packages in 2m
        13 packages are looking for funding
          run `npm fund` for details
        5 vulnerabilities (1 low, 3 moderate, 1 high)
        To address issues that do not require attention, run:
          npm audit fix
        Some issues need review, and may require choosing
        a different dependency.
        Run `npm audit` for details.
        npm notice
        npm notice New major version of npm available! 9.8.1 -> 10.1.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.1.0
        npm notice Run npm install -g npm@10.1.0 to update!
        npm notice
        • S SpeedyBlade
          v18.18.0
          v18.18.0
          9.8.1
          corepack  n  npm
          #367
          Und mit n sehe ich auch schon den Grund des Übels. Man installiert nodejs nicht per n sondern über den Paketmanager.
            Warum????
            SpeedyBlade
            #368
            @thomas-braun sagte in Nach Update läuft nichts mehr!:
            Warum????
            wie meinst du das mit "n"?
            • S SpeedyBlade
              Warum????
              #369
              @speedyblade
              n ist einer der nodejs-Versionsmanager. Neben nvm und ein paar anderen Programmen. Der pfuscht dir aber in die 'ordentliche Installation über den Paketmanager' rein. Wie man hier sieht.
                @speedyblade
                SpeedyBlade
                #370
                ok...ich wie bekommen wir das beseitigt?
                • S SpeedyBlade
                  #371
                  @speedyblade
                  Lass ihn stehen.
                  • S SpeedyBlade
                    v18.18.0
                    v18.18.0
                    9.8.1
                    corepack  n  npm
                    #372
                    corepack n npm
                      @speedyblade
                      Lass ihn stehen.
                      SpeedyBlade
                      #373
                      Lass ihn stehen.
                      verstehe nicht was du meinst, mit "stehen lassen"
                      • S SpeedyBlade
                        Lass ihn stehen.
                        #374
                        Einfach nichts tun.
                        Wenn es dich stört:
                        sudo rm /usr/lib/node_modules/n
                          Einfach nichts tun.
                          Wenn es dich stört:
                          SpeedyBlade
                          #375
                          pi@RaspberryPi4:/opt/iobroker/node_modules/iobroker.js-controller $ sudo rm /usr/lib/node_modules/n
                          rm: das Entfernen von '/usr/lib/node_modules/n' ist nicht möglich: Ist ein Verzeichnis
                          lässt sich eh nicht entfernen
                          • S SpeedyBlade
                            #376
                            @speedyblade
                            Ich konnte deinem Auszug von oben nicht entnehmen, dass es ein Verzeichnis ist.
                            sudo rm -rf /usr/lib/node_modules/n
                              @speedyblade
                              SpeedyBlade
                              #377
                              perfekt...läuft nun wieder sauber
                              ps.: gibt es ne Möglichkeit die lokale Backupdatei auf nen Windowsrechner zu kopiere (copy-paste)?
                              "Backup created: /opt/iobroker/backups/nodered.0_2023_09_29-13_38_48_backupiobroker.tar"
                              Thomas BraunT CodierknechtC HomoranH 3 Antworten Letzte Antwort
                              • S SpeedyBlade
                                #378
                                Keine Ahnung. Den Anwendungsfall hab ich hier nicht.
                                Mit scp oder dessen graphischem Pendant vielleicht.
                                • S SpeedyBlade
                                  CodierknechtC Offline
                                  Codierknecht
                                  #379
                                  Man sollte auf der Windows-Kiste eine Freigabe einrichten können, die man in Debian mountet.
                                  Dann kann man das im Backup-Adapter entsprechend einstellen.
                                  Oder man hat ein NAS wie z.B. Synology.
                                  Wenn dort NFS oder CIFS aktiviert ist, kann man auch dort sein Backup ablegen lassen.
                                  HmIP|ZigBee|Tasmota|Unifi
                                  Zabbix Certified Specialist
                                  • S SpeedyBlade
                                    #380
                                    mit winscp oder filezilla
                                    aber vorsicht mit den Rechten und Dateien nie mit üblichen WIN-Programmen bearbeiten
                                      SpeedyBlade
                                      #381
                                      danke...hab sie mir per FileZilla auf nen Windows Rechner kopiert, als Sicherung.
                                      kann es sein, dass Discovery nicht mehr funktioniert?
                                      • S SpeedyBlade
                                        #382
                                        @speedyblade
                                        Discovery braucht eh 'keiner' in einer etablierten Installation.
                                        Aber das Ding läuft nun wieder?
                                          @speedyblade
                                          SpeedyBlade
                                          #383
                                          ioBroker läuft nun wieder ja genau
                                          nur beim Discovery Adapter gibt es keine Einstellungen mehr :(
