  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • foxriver76F foxriver76
    @ofbeqnpolkkl6mby5e13 Führe mal bitte das Skript aus und schau welche IDs geloggt werden.
        $('*').each(async id => {
            try {
                const obj = await getObjectAsync(id);
                if (obj.binary) {
                    log(id, 'warn');
            } catch {
                // ignore
    O Abwesend
    O Abwesend
    oFbEQnpoLKKl6mbY5e13
    #283
    @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
    2023-09-26 08:46:11.322  - info: javascript.0 (16432) Start javascript script.js.common._Tests.Test_6
    2023-09-26 08:46:12.429  - info: javascript.0 (16432) script.js.common._Tests.Test_6: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-09-26 08:46:16.104  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "alexa2.0" can't be copied: {}
    2023-09-26 08:46:17.665  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "hue-sync-box.0" can't be copied: {}
    2023-09-26 08:46:18.086  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nanoleaf-lightpanels.0" can't be copied: {}
    2023-09-26 08:46:18.088  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nanoleaf-lightpanels.1" can't be copied: {}
    2023-09-26 08:46:18.102  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nuki-extended.0" can't be copied: {}
    2023-09-26 08:46:18.215  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.deyeidc.upload" can't be copied: {}
    2023-09-26 08:46:18.243  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.alive" can't be copied: {}
    2023-09-26 08:46:18.243  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.compactMode" can't be copied: {}
    2023-09-26 08:46:18.244  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.connected" can't be copied: {}
    2023-09-26 08:46:18.244  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.cpu" can't be copied: {}
    2023-09-26 08:46:18.245  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.cputime" can't be copied: {}
    2023-09-26 08:46:18.245  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.inputCount" can't be copied: {}
    2023-09-26 08:46:18.246  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.logLevel" can't be copied: {}
    2023-09-26 08:46:18.247  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memHeapTotal" can't be copied: {}
    2023-09-26 08:46:18.247  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memHeapUsed" can't be copied: {}
    2023-09-26 08:46:18.248  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memRss" can't be copied: {}
    2023-09-26 08:46:18.248  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.outputCount" can't be copied: {}
    2023-09-26 08:46:18.249  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.sigKill" can't be copied: {}
    2023-09-26 08:46:18.249  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.uptime" can't be copied: {}
    2023-09-26 08:46:18.271  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "tuya.0" can't be copied: {}
    2023-09-26 08:46:18.276  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "unifi.0" can't be copied: {}
    foxriver76F 2 Antworten Letzte Antwort
    • O oFbEQnpoLKKl6mbY5e13
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #284
      @ofbeqnpolkkl6mby5e13 Hm okay, kp was javascript da intern treibt. Ich schaue nochmal obs ne andere Variante gibt die binary states zu finden. Dachte eigentlich Admin könnte filtern - leider nicht.
      Videotutorials & mehr
        @peoples du kannst ja mal nur die Adapter upgraden (web, ws, socket) ich vermute dein PRoblem wird auch ohne den neuen Controller auftreten, bzw, kannst du es villt auf einen der Adapter begrenzen und ein Issue erstellen.
        PeoplesP Offline
        PeoplesP Offline
        Peoples
        #285
        @foxriver76
        Ich habe mir gestern jetzt mal die Mühe gemacht, alle möglichen Varianten (Adapterversionen / Js-Controler auf 4 und 5) durch zu spielen mit folgenden Erkenntinissen:
        • Socket / Web / Ws Adapter aktuell, Controller auf V4... (im Webadapter auf intern gestellt und Websockets angehackt)
          Probleme in Vis treten erst nach einiger Zeit auf, betrifft hauptsächlich CSS - Eigentschaften und Bindings
          Beispielsweise habe ich auf meinem "Homescreen" ein graues Kästchen welches ich bei eine Systemmeldung über CSS
          als Overlay über den ganzen Bildschirm strecke. Dies funktioniert Anfangs und nach einer gewissen Zeit wird nur noch der
          Text oben Links wo im Editor das Kästchen mit deaktivierten Css-Eigenschaften liegt angezeigt.
        • Socket / Web / Ws Adapter aktuell ebenso der Controller auf V5 (im Webadapter auf ws gestellt da es sonst nicht geht)
          Das oben beschriebene Problem tritt nach ca. 5 Minuten kontinuierlich auf. Reload des Projekts behebt das Problem für
          wieder ca. 5 Minuten.
        • Socket / Web /Ws Adapter auf den Vorversionen und Controller auf V4
          keine Probleme vorhanden.
        Da mir das Zusammenspiel der einzelnen Adapter nicht klar ist und ich auch nicht sagen kann welchen Einfluss der Js-Controller auf das Thema hat, wüsste ich auch garnicht bei welchem Adapter ich hier ein Issue eröffnen sollte.
        Wenn es mir jedoch jemand erklärt mache ich das natürlich sehr gerne.
        • PeoplesP Peoples
          @foxriver76
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          schrieb am zuletzt editiert von foxriver76
          #286
          @peoples und ob die webinstanz ws oder socketio nutzt macht kein Unterschied im Verhalten? Und irgendwie https im Spiel? ICh kann es nicht nachstellen und es ist nicht trivial herauszufinden woran es liegen könnte, daher möglichst viele Infos bitte. Controller würde ich eher ausschließen, da wie du sagst auch ohne neuen Controller passiert (auch wenn es laut deinen Tests häufiger auftritt).
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            #287
            (async () => {
                    try {
                        const state = await getBinaryStateAsync(id)
                        try {
                        if (state) {
                            JSON.parse(state.toString())
                        } catch (e) {
                            log('Binary state found: ' + id, 'error')
                    } catch {
                        // ignore
            Macht er das oder meckert er da auch?
            O 1 Antwort Letzte Antwort
              (async () => {
                      try {
                          try {
                          if (state) {
                          } catch (e) {
                      } catch {
                          // ignore
              O Abwesend
              O Abwesend
              #288
              (async () => {
              Kein Fehler, aber jetzt ist das Log 12MB groß (kein Vorwurf!), weil er jeden State als Binary erkennt.
                (async () => {
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #289
                @ofbeqnpolkkl6mby5e13 Kannst du mir das Log bereitstellen?
                  O Abwesend
                  O Abwesend
                  #290
                  @foxriver76
                  Selbstverständlich. Wie?
                    @foxriver76
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #291
                    @ofbeqnpolkkl6mby5e13 12 MB könnten evtl noch per Mail gehen: moritz.heusinger@gmail.com
                    Ansonsten villt eifnach ein File Upload (https://easyupload.io/) und mir den Link schicken falls du keine Bedenken hast
                      O Abwesend
                      O Abwesend
                      #292
                      @foxriver76
                      Ist ja nur Text. Gepackt keine 300kb groß.
                        @foxriver76
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        #293
                        @ofbeqnpolkkl6mby5e13 Ok, passt ne keine Binary States würde ich sagen. Das Log für jeden State kommt vom controller bei jedem Aufruf von binary Methoden. Und die Node Version bei dir war welche?
                          O Abwesend
                          O Abwesend
                          #294
                          @foxriver76
                          18.16.0
                            @foxriver76
                            18.16.0
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            #295
                            @ofbeqnpolkkl6mby5e13 hm magst du mal innerhalb der 18er Range upgraden um auszuschließen dass es daran liegt - ich vermute wenn nach Vorgaben installiert sollte ein sudo apt update && sudo apt upgrade zur Aktualisierung ausrecihen. Ansonsten bliebe noch das ich probiere es mit deinem Backup nachzustellen, aber aktuell fehlt mir leider jeder Anhaltspunkt.
                              O Abwesend
                              O Abwesend
                              #296
                              @foxriver76
                              Selber Fehler bei @ilovegym mit 18.17.1 und @FredF mit 18.17.0. Und @Wildbill
                              Siehe:
                              https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/107?_=1695806792051
                              https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/128?_=1695806792051
                                @foxriver76
                                Siehe:
                                foxriver76F Offline
                                foxriver76F Offline
                                foxriver76
                                #297
                                @ofbeqnpolkkl6mby5e13 aktuelle LTS wäre 18.18.0
                                ansonsten wie gesagt, ich kann probieren es mit deinem System nachzustellen, wenn du mir ein Backup zukommen lässt und rein debuggen. Ansonsten keine Idee und wie gesagt eher selten und bei anderen lag es meist an den übergebliebenen Binary States.
                                  O Abwesend
                                  O Abwesend
                                  #298
                                  @foxriver76
                                  Ich bringe mein System erst mal auf Stand.
                                  Bin jetzt auf:
                                  Node.js: v18.17.1
                                  NPM: 9.6.7
                                  und beobachte.
                                    @foxriver76
                                    Scheint im MQTT-Adapter selbst auch nicht komplett abgefangen zu werden:
                                    2023-09-15 00:37:44.321  - error: mqtt.0 (456) Client [DVES_990210] Cannot parse "stat/tasmota_990210/STATUS11": {"StatusSTS":{"Time":"2023-09-14T23:37:34","Uptime":"100T16:49:22","UptimeSec":8700562,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":24,"POWER":"OFF","Wifi":{"AP":1,"SSId":"***","BSSId":"***","Channel":1,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":8,"Downtime":"0T00� stat/t
                                    O Abwesend
                                    O Abwesend
                                    #299
                                    @ofbeqnpolkkl6mby5e13 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                                    @foxriver76
                                    @foxriver76
                                    Um auch noch mal auf dieses Thema zurückzukommen. Ich erhalte für nahezu jedes Tasmota-Gerät eine solche Meldung beim Subscribe.
                                      @foxriver76
                                      @foxriver76
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      #300
                                      @ofbeqnpolkkl6mby5e13 Hm was hat das mit Controller zu tun? Er möchte die Message als JSON parsen, aber es scheint kein vollständiges JSON zu sein. Da hat Controller nix mit zu tun
                                      https://github.com/ioBroker/ioBroker.mqtt/blob/4491114d4819ce65d2baf68f063d3eb169390d0d/lib/common.js#L179
                                        O Abwesend
                                        O Abwesend
                                        #301
                                        @foxriver76
                                        Tritt erst seit JS-Controller 5 auf. So wie auch der Fehler mit dem MQTT-Client.
                                          @foxriver76
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          #302
                                          @ofbeqnpolkkl6mby5e13 was ist der Fehler mit dem MQTT client?
