  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • O oFbEQnpoLKKl6mbY5e13
    @foxriver76 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
    2023-09-26 08:46:11.322  - info: javascript.0 (16432) Start javascript script.js.common._Tests.Test_6
    2023-09-26 08:46:12.429  - info: javascript.0 (16432) script.js.common._Tests.Test_6: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    2023-09-26 08:46:16.104  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "alexa2.0" can't be copied: {}
    2023-09-26 08:46:17.665  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "hue-sync-box.0" can't be copied: {}
    2023-09-26 08:46:18.086  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nanoleaf-lightpanels.0" can't be copied: {}
    2023-09-26 08:46:18.088  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nanoleaf-lightpanels.1" can't be copied: {}
    2023-09-26 08:46:18.102  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "nuki-extended.0" can't be copied: {}
    2023-09-26 08:46:18.215  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.deyeidc.upload" can't be copied: {}
    2023-09-26 08:46:18.243  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.alive" can't be copied: {}
    2023-09-26 08:46:18.243  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.compactMode" can't be copied: {}
    2023-09-26 08:46:18.244  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.connected" can't be copied: {}
    2023-09-26 08:46:18.244  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.cpu" can't be copied: {}
    2023-09-26 08:46:18.245  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.cputime" can't be copied: {}
    2023-09-26 08:46:18.245  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.inputCount" can't be copied: {}
    2023-09-26 08:46:18.246  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.logLevel" can't be copied: {}
    2023-09-26 08:46:18.247  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memHeapTotal" can't be copied: {}
    2023-09-26 08:46:18.247  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memHeapUsed" can't be copied: {}
    2023-09-26 08:46:18.248  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.memRss" can't be copied: {}
    2023-09-26 08:46:18.248  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.outputCount" can't be copied: {}
    2023-09-26 08:46:18.249  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.sigKill" can't be copied: {}
    2023-09-26 08:46:18.249  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "system.adapter.vis.0.uptime" can't be copied: {}
    2023-09-26 08:46:18.271  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "tuya.0" can't be copied: {}
    2023-09-26 08:46:18.276  - error: javascript.0 (16432) script.js.common._Tests.Test_6: Object "unifi.0" can't be copied: {}
    foxriver76F Offline
    foxriver76F Offline
    foxriver76
    #287
    @ofbeqnpolkkl6mby5e13
    (async () => {
        $('*').each(async id => {
            try {
                const state = await getBinaryStateAsync(id)
                try {
                if (state) {
                    JSON.parse(state.toString())
                } catch (e) {
                    log('Binary state found: ' + id, 'error')
            } catch {
                // ignore
    Macht er das oder meckert er da auch?
    Videotutorials & mehr
    O 1 Antwort Letzte Antwort
    • foxriver76F foxriver76
      (async () => {
              try {
                  try {
                  if (state) {
                  } catch (e) {
              } catch {
                  // ignore
      O Abwesend
      O Abwesend
      #288
      (async () => {
      Kein Fehler, aber jetzt ist das Log 12MB groß (kein Vorwurf!), weil er jeden State als Binary erkennt.
        (async () => {
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        schrieb am zuletzt editiert von foxriver76
        #289
        @ofbeqnpolkkl6mby5e13 Kannst du mir das Log bereitstellen?
          O Abwesend
          O Abwesend
          #290
          @foxriver76
          Selbstverständlich. Wie?
            @foxriver76
            foxriver76F Offline
            foxriver76F Offline
            foxriver76
            #291
            @ofbeqnpolkkl6mby5e13 12 MB könnten evtl noch per Mail gehen: moritz.heusinger@gmail.com
            Ansonsten villt eifnach ein File Upload (https://easyupload.io/) und mir den Link schicken falls du keine Bedenken hast
              O Abwesend
              O Abwesend
              #292
              @foxriver76
              Ist ja nur Text. Gepackt keine 300kb groß.
                @foxriver76
                foxriver76F Offline
                foxriver76F Offline
                foxriver76
                #293
                @ofbeqnpolkkl6mby5e13 Ok, passt ne keine Binary States würde ich sagen. Das Log für jeden State kommt vom controller bei jedem Aufruf von binary Methoden. Und die Node Version bei dir war welche?
                  O Abwesend
                  O Abwesend
                  #294
                  @foxriver76
                  18.16.0
                    @foxriver76
                    18.16.0
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    #295
                    @ofbeqnpolkkl6mby5e13 hm magst du mal innerhalb der 18er Range upgraden um auszuschließen dass es daran liegt - ich vermute wenn nach Vorgaben installiert sollte ein sudo apt update && sudo apt upgrade zur Aktualisierung ausrecihen. Ansonsten bliebe noch das ich probiere es mit deinem Backup nachzustellen, aber aktuell fehlt mir leider jeder Anhaltspunkt.
                      O Abwesend
                      O Abwesend
                      #296
                      @foxriver76
                      Selber Fehler bei @ilovegym mit 18.17.1 und @FredF mit 18.17.0. Und @Wildbill
                      Siehe:
                      https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/107?_=1695806792051
                      https://forum.iobroker.net/topic/68290/js-controller-5-0-x-jetzt-für-alle-user-im-stable/128?_=1695806792051
                        @foxriver76
                        Siehe:
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        #297
                        @ofbeqnpolkkl6mby5e13 aktuelle LTS wäre 18.18.0
                        ansonsten wie gesagt, ich kann probieren es mit deinem System nachzustellen, wenn du mir ein Backup zukommen lässt und rein debuggen. Ansonsten keine Idee und wie gesagt eher selten und bei anderen lag es meist an den übergebliebenen Binary States.
                          O Abwesend
                          O Abwesend
                          #298
                          @foxriver76
                          Ich bringe mein System erst mal auf Stand.
                          Bin jetzt auf:
                          Node.js: v18.17.1
                          NPM: 9.6.7
                          und beobachte.
                            @foxriver76
                            Scheint im MQTT-Adapter selbst auch nicht komplett abgefangen zu werden:
                            2023-09-15 00:37:44.321  - error: mqtt.0 (456) Client [DVES_990210] Cannot parse "stat/tasmota_990210/STATUS11": {"StatusSTS":{"Time":"2023-09-14T23:37:34","Uptime":"100T16:49:22","UptimeSec":8700562,"Heap":19,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":24,"POWER":"OFF","Wifi":{"AP":1,"SSId":"***","BSSId":"***","Channel":1,"Mode":"11n","RSSI":62,"Signal":-69,"LinkCount":8,"Downtime":"0T00� stat/t
                            O Abwesend
                            O Abwesend
                            #299
                            @ofbeqnpolkkl6mby5e13 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                            @foxriver76
                            @foxriver76
                            Um auch noch mal auf dieses Thema zurückzukommen. Ich erhalte für nahezu jedes Tasmota-Gerät eine solche Meldung beim Subscribe.
                              @foxriver76
                              @foxriver76
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #300
                              @ofbeqnpolkkl6mby5e13 Hm was hat das mit Controller zu tun? Er möchte die Message als JSON parsen, aber es scheint kein vollständiges JSON zu sein. Da hat Controller nix mit zu tun
                              https://github.com/ioBroker/ioBroker.mqtt/blob/4491114d4819ce65d2baf68f063d3eb169390d0d/lib/common.js#L179
                                O Abwesend
                                O Abwesend
                                #301
                                @foxriver76
                                Tritt erst seit JS-Controller 5 auf. So wie auch der Fehler mit dem MQTT-Client.
                                  @foxriver76
                                  foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  #302
                                  @ofbeqnpolkkl6mby5e13 was ist der Fehler mit dem MQTT client?
                                    O Abwesend
                                    O Abwesend
                                    #303
                                    @foxriver76
                                    https://github.com/iobroker-community-adapters/ioBroker.mqtt-client/issues/233
                                      @foxriver76
                                      foxriver76F Offline
                                      foxriver76F Offline
                                      foxriver76
                                      #304
                                      @ofbeqnpolkkl6mby5e13 das kommt durch Controller v5 - ja.
                                      Aber bei der JSON parse Geschichte sollte das absolut keinen Einfluss haben.
                                        O Abwesend
                                        O Abwesend
                                        #305
                                        @foxriver76
                                        Okay.
                                        • L Offline
                                          laola
                                          #306
                                          also - bei mir lief die Installation nach obiger Anleitung völlig fehlerfrei durch. Es funktioniert im Prinzip auch alles wie vorher - nur kann ich Adapter nicht updaten/instllieren, die den js-controller 5.x voraussetzen - es wird seitens ioBroker gemeckert, dass noch die Version 4.0.24 installiert sei ??
                                          Wenn ich mir die Ausgabe von iob diag ansehe, dann sieht (für mich) auch alles fehlerfrei aus und dort wird auch die js-controller version 5.0.12 reportet. ?? RPi4 wurde bereits mehrfach neu gebootet.
                                          Skript v.2023-06-20
                                          *** BASE SYSTEM ***
                                             Static hostname: ioBroker-Pi4
                                                   Icon name: computer
                                                  Machine ID: db4e6210948f4c2fbbfcc8b99fdb2210
                                                     Boot ID: a3037da1fe234331bbb0cb1822274c48
                                            Operating System: Raspbian GNU/Linux 10 (buster)
                                                      Kernel: Linux 6.1.10-v7l+
                                                Architecture: arm
                                          Model           : Raspberry Pi 4 Model B Rev 1.4
                                          Docker          : false
                                          Virtualization  : none
                                          Kernel          : armv7l
                                          Userland        : armhf
                                          Systemuptime and Load:
                                           12:16:17 up 16 min,  2 users,  load average: 3.80, 2.03, 1.43
                                          CPU threads: 4
                                          Raspberry only:
                                          throttled=0x0
                                          Other values than 0x0 hint to temperature/voltage problems
                                          temp=51.6'C
                                          volt=0.8500V
                                          *** Time and Time Zones ***
                                                         Local time: Thu 2023-09-28 12:16:17 CEST
                                                     Universal time: Thu 2023-09-28 10:16:17 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          Boot Target:    multi-user.target
                                          *** MEMORY ***
                                          Mem:           7.9G        1.4G        5.9G        9.0M        550M        6.2G
                                          Swap:           99M          0B         99M
                                          Total:         8.0G        1.4G        6.0G
                                                   7897 M total memory
                                                   1449 M used memory
                                                   1576 M active memory
                                                    180 M inactive memory
                                                   5897 M free memory
                                                     86 M buffer memory
                                                    464 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          Raspberry only:
                                          oom events: 0
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      110G   28G   79G  26% /
                                          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                                          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                          tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
                                          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                                          /dev/sda1      vfat      253M   51M  202M  20% /boot
                                          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                                          [Thu Sep 28 11:59:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:EE:B3:A8 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=ffb03b60-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Thu Sep 28 11:59:24 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                          [Thu Sep 28 11:59:24 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                          [Thu Sep 28 11:59:27 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                          TARGET        SOURCE    FSTYPE OPTIONS
                                          /             /dev/sda2 ext4   rw,noatime
                                          |-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                          `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          329M    /var/
                                          128M    /var/lib
                                          93M     /var/cache
                                          78M     /var/cache/apt
                                          69M     /var/lib/apt/lists
                                          Archived and active journals take up 8.0M in the file system.
                                          /opt/iobroker/backups:
                                          4.1G    /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          16G     /opt/iobroker/iobroker-data/history
                                          389M    /opt/iobroker/iobroker-data/files
                                          234M    /opt/iobroker/iobroker-data/backup-objects
                                          52M     /opt/iobroker/iobroker-data/files/javascript.admin
                                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                          27M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/objects.json.migrated
                                          24M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.edf7552a.js.map
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v18.17.1
                                          /usr/bin/node           v18.17.1
                                          /usr/bin/npm            9.6.7
                                          /usr/bin/npx            9.6.7
                                          nodejs:
                                            Installed: 18.17.1-deb-1nodesource1
                                            Candidate: 18.17.1-deb-1nodesource1
                                            Version table:
                                           *** 18.17.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_18.x buster/main armhf Packages
                                               10.24.0~dfsg-1~deb10u3 500
                                          No problems detected
                                          Errors in npm tree: 0
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                           Cannot load "custom": Connection is closed.
                                           Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
                                          Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                          No configuration change needed.
                                          Multihost discovery server: disabled
                                          Discovery authentication:   enabled
                                          Persistent activation:      disabled
                                          Objects:                    jsonl on 0.0.0.0
                                          States:                     jsonl on 0.0.0.0
                                          Core adapters versions
                                          js-controller:  5.0.12
                                          admin:          6.10.4
                                          javascript:     7.1.4
                                          Adapters from github:   1
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : ioBroker-Pi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.alexa2.0                 : alexa2                : ioBroker-Pi4                             -  enabled
                                          + system.adapter.backitup.0               : backitup              : ioBroker-Pi4                             -  enabled
                                            system.adapter.bring.0                  : bring                 : ioBroker-Pi4                             - disabled
                                            system.adapter.chromecast.0             : chromecast            : ioBroker-Pi4                             - disabled
                                            system.adapter.daswetter.0              : daswetter             : ioBroker-Pi4                             -  enabled
                                            system.adapter.denon.0                  : denon                 : ioBroker-Pi4                             - disabled
                                          + system.adapter.device-reminder.0        : device-reminder       : ioBroker-Pi4                             -  enabled
                                            system.adapter.devices.0                : devices               : ioBroker-Pi4                             - disabled
                                          + system.adapter.discovery.0              : discovery             : ioBroker-Pi4                             -  enabled
                                            system.adapter.emby.0                   : emby                  : ioBroker-Pi4                             - disabled
                                            system.adapter.ems-esp.0                : ems-esp               : ioBroker-Pi4                             - disabled
                                            system.adapter.feiertage.0              : feiertage             : ioBroker-Pi4                             - disabled
                                            system.adapter.flot.0                   : flot                  : ioBroker-Pi4                             - disabled
                                            system.adapter.fritzdect.0              : fritzdect             : ioBroker-Pi4                             - disabled
                                            system.adapter.go-e.0                   : go-e                  : ioBroker-Pi4                             - disabled
                                            system.adapter.harmony.0                : harmony               : ioBroker-Pi4                             - disabled
                                          + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker-Pi4                             -  enabled
                                          + system.adapter.history.0                : history               : ioBroker-Pi4                             -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : ioBroker-Pi4                             -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-Pi4                             -  enabled, port: 0
                                          + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-Pi4                             -  enabled, port: 0
                                            system.adapter.hs100.0                  : hs100                 : ioBroker-Pi4                             - disabled
                                            system.adapter.ical.0                   : ical                  : ioBroker-Pi4                             -  enabled
                                            system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-Pi4                             - disabled
                                            system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-Pi4                             - disabled
                                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-Pi4                             - disabled
                                            system.adapter.info.0                   : info                  : ioBroker-Pi4                             -  enabled
                                          + system.adapter.iot.0                    : iot                   : ioBroker-Pi4                             -  enabled
                                            system.adapter.iqontrol.0               : iqontrol              : ioBroker-Pi4                             - disabled
                                          + system.adapter.javascript.0             : javascript            : ioBroker-Pi4                             -  enabled
                                            system.adapter.kodi.0                   : kodi                  : ioBroker-Pi4                             - disabled, port: 9090
                                          + system.adapter.lgtv.0                   : lgtv                  : ioBroker-Pi4                             -  enabled
                                            system.adapter.lgtv.1                   : lgtv                  : ioBroker-Pi4                             -  enabled
                                            system.adapter.mercedesme.0             : mercedesme            : ioBroker-Pi4                             - disabled
                                            system.adapter.meross.0                 : meross                : ioBroker-Pi4                             - disabled
                                          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker-Pi4                             -  enabled, port: 54321
                                            system.adapter.mobile.0                 : mobile                : ioBroker-Pi4                             - disabled
                                            system.adapter.net-tools.0              : net-tools             : ioBroker-Pi4                             - disabled
                                          + system.adapter.onkyo.0                  : onkyo                 : ioBroker-Pi4                             -  enabled
                                            system.adapter.onvif.0                  : onvif                 : ioBroker-Pi4                             - disabled
                                          + system.adapter.openweathermap.0         : openweathermap        : ioBroker-Pi4                             -  enabled
                                            system.adapter.ping.0                   : ping                  : ioBroker-Pi4                             - disabled
                                          + system.adapter.pushover.0               : pushover              : ioBroker-Pi4                             -  enabled
                                            system.adapter.radar2.0                 : radar2                : ioBroker-Pi4                             - disabled
                                            system.adapter.robonect.0               : robonect              : ioBroker-Pi4                             - disabled
                                          + system.adapter.scenes.0                 : scenes                : ioBroker-Pi4                             -  enabled
                                          + system.adapter.shelly.0                 : shelly                : ioBroker-Pi4                             -  enabled, port: 1899, bind: 0.0.0.0
                                          + system.adapter.shelly.1                 : shelly                : ioBroker-Pi4                             -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.smartgarden.0            : smartgarden           : ioBroker-Pi4                             -  enabled
                                          + system.adapter.solax.0                  : solax                 : ioBroker-Pi4                             -  enabled
                                          + system.adapter.sonoff.0                 : sonoff                : ioBroker-Pi4                             -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-Pi4                             -  enabled
                                          + system.adapter.sourceanalytix.1         : sourceanalytix        : ioBroker-Pi4                             -  enabled
                                            system.adapter.telegram.0               : telegram              : ioBroker-Pi4                             - disabled, port: 8443, bind: 0.0.0.0
                                          + system.adapter.text2command.0           : text2command          : ioBroker-Pi4                             -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : ioBroker-Pi4                             -  enabled
                                            system.adapter.tr-064.1                 : tr-064                : ioBroker-Pi4                             - disabled
                                            system.adapter.tr-064.2                 : tr-064                : ioBroker-Pi4                             - disabled
                                            system.adapter.tuya.0                   : tuya                  : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-history.0            : vis-history           : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-lcars.0              : vis-lcars             : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-map.0                : vis-map               : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-Pi4                             - disabled
                                            system.adapter.vis-weather.0            : vis-weather           : ioBroker-Pi4                             - disabled
                                            system.adapter.vis.0                    : vis                   : ioBroker-Pi4                             -  enabled
                                          + system.adapter.vw-connect.0             : vw-connect            : ioBroker-Pi4                             -  enabled
                                          + system.adapter.web.0                    : web                   : ioBroker-Pi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker-Pi4                             - disabled
                                            system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : ioBroker-Pi4                             - disabled
                                          + system.adapter.wled.0                   : wled                  : ioBroker-Pi4                             -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : ioBroker-Pi4                             -  enabled, port: /dev/ttyUSB0
                                          + instance is alive
                                          ioBroker-Repositories
                                          Stable (default): http://download.iobroker.net/sources-dist.json
                                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                          Active repo(s): Beta (latest)
                                          Installed ioBroker-Instances
                                          Used repository: Beta (latest)
                                          Adapter    "admin"        : 6.10.4   , installed 6.10.4
                                          Adapter    "alexa2"       : 3.25.2   , installed 3.24.1 [Updatable]
                                          Adapter    "backitup"     : 2.8.1    , installed 2.6.23 [Updatable]
                                          Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
                                          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                                          Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
                                          Adapter    "denon"        : 1.15.4   , installed 1.15.4
                                          Adapter    "device-reminder": 2.0.1  , installed 1.2.9  [Updatable]
                                          Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                          Adapter    "discovery"    : 4.1.0    , installed 3.1.0  [Updatable]
                                          Adapter    "emby"         : 1.0.2    , installed 1.0.2
                                          Adapter    "ems-esp"      : 2.4.1    , installed 2.2.0  [Updatable]
                                          Adapter    "feiertage"    : 1.1.4    , installed 1.1.0  [Updatable]
                                          Adapter    "fritzdect"    : 2.4.1    , installed 2.3.1  [Updatable]
                                          Adapter    "go-e"         : 1.0.27   , installed 1.0.27
                                          Adapter    "harmony"      : 1.2.2    , installed 1.2.2
                                          Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
                                          Adapter    "history"      : 3.0.0    , installed 2.2.6  [Updatable]
                                          Adapter    "hm-rega"      : 4.0.0    , installed 3.0.47 [Updatable]
                                          Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                          Adapter    "hs100"        : 2.1.2    , installed 2.1.2
                                          Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                          Adapter    "info"         : 2.0.0    , installed 1.9.26 [Updatable]
                                          Adapter    "iot"          : 2.0.11   , installed 1.14.5 [Updatable]
                                          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
                                          Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                          Controller "js-controller": 5.0.12   , installed 5.0.12
                                          Adapter    "kodi"         : 3.0.0    , installed 2.0.9  [Updatable]
                                          Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
                                          Adapter    "mercedesme"   : 0.1.3    , installed 0.1.3
                                          Adapter    "meross"       : 1.15.1   , installed 1.15.1
                                          Adapter    "mihome-vacuum": 4.0.0    , installed 3.11.0 [Updatable]
                                          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                          Adapter    "onvif"        : 1.0.5    , installed 1.0.5
                                          Adapter    "openweathermap": 0.4.3   , installed 0.3.9  [Updatable]
                                          Adapter    "pushover"     : 3.0.4    , installed 3.0.3  [Updatable]
                                          Adapter    "radar2"       : 2.0.7    , installed 2.0.7
                                          Adapter    "robonect"     : 1.2.0    , installed 0.1.4  [Updatable]
                                          Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
                                          Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
                                          Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                          Adapter    "solax"        : 0.7.7    , installed 0.4.3  [Updatable]
                                          Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
                                          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                          Adapter    "telegram"     : 1.16.0   , installed 1.16.0
                                          Adapter    "text2command" : 3.0.2    , installed 3.0.2
                                          Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                                          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                          Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                          Adapter    "vw-connect"   : 0.1.3    , installed 0.1.3
                                          Adapter    "web"          : 6.1.2    , installed 6.1.2
                                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                          Adapter    "wled"         : 0.7.0    , installed 0.6.7  [Updatable]
                                          Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                          Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
                                          Objects and States
                                          Objects:        30015
                                          States:         21061
                                          Hit:1 http://phoscon.de/apt/deconz buster InRelease
                                          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:4 https://deb.nodesource.com/node_18.x buster InRelease
                                          Reading package lists...
                                          Pending Updates: 90
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16955      542/cupsd
                                          tcp        0      0 192.168.1.4:2010        0.0.0.0:*               LISTEN      1001       83598      17507/io.hm-rpc.1
                                          tcp        0      0 192.168.1.4:2001        0.0.0.0:*               LISTEN      1001       85041      17496/io.hm-rpc.0
                                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          18433      639/smbd
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18294      634/sshd
                                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16384      639/smbd
                                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       82646      17367/iobroker.js-c
                                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       83400      17367/iobroker.js-c
                                          tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      1001       83707      17617/io.shelly.0
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       83624      17549/io.sonoff.0
                                          tcp6       0      0 :::139                  :::*                    LISTEN      0          16383      639/smbd
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          18296      634/sshd
                                          tcp6       0      0 :::445                  :::*                    LISTEN      0          16382      639/smbd
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       82724      17386/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       86674      18074/io.web.0
                                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16954      542/cupsd
                                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16254      624/cups-browsed
                                          udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          14171      622/nmbd
                                          udp        0      0 192.168.1.4:137         0.0.0.0:*                           0          14170      622/nmbd
                                          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          14160      622/nmbd
                                          udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          14173      622/nmbd
                                          udp        0      0 192.168.1.4:138         0.0.0.0:*                           0          14172      622/nmbd
                                          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          14161      622/nmbd
                                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       86045      17583/io.mihome-vac
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       84635      18095/io.wled.0
                                          udp        0      0 192.168.1.4:5353        0.0.0.0:*                           1001       85137      17564/io.tr-064.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16186      538/avahi-daemon: r
                                          udp        0      0 0.0.0.0:52157           0.0.0.0:*                           108        16188      538/avahi-daemon: r
                                          udp        0      0 0.0.0.0:42012           0.0.0.0:*                           1001       95341      17639/io.shelly.1
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       86355      17639/io.shelly.1
                                          udp6       0      0 :::5353                 :::*                                108        16187      538/avahi-daemon: r
                                          udp6       0      0 :::56338                :::*                                108        16189      538/avahi-daemon: r
                                          2023-09-28 12:18:50.877  - warn: wled.0 (18095) State attribute definition missing for : m12 with value : 0
                                          2023-09-28 12:18:51.005  - info: wled.0 (18095) Bonjour service started, new  devices  will  be detected automatically
                                          2023-09-28 12:18:51.117  - info: wled.0 (18095) WLED connected
                                          2023-09-28 12:18:51.481  - warn: wled.0 (18095) State attribute definition missing for : liveseg with value : -1
                                          2023-09-28 12:18:51.689  - warn: wled.0 (18095) State attribute definition missing for : cpalcount with value : 0
                                          2023-09-28 12:18:51.746  - warn: wled.0 (18095) State attribute definition missing for : 0 with value : 0
                                          2023-09-28 12:18:52.473  - info: info.0 (17779) Reading process data every 8 seconds.
                                          2023-09-28 12:18:52.704  - warn: wled.0 (18095) State attribute definition missing for : c1 with value : 128
                                          2023-09-28 12:18:52.712  - warn: wled.0 (18095) State attribute definition missing for : c2 with value : 128
                                          2023-09-28 12:18:52.722  - warn: wled.0 (18095) State attribute definition missing for : c3 with value : 16
                                          2023-09-28 12:18:52.754  - warn: wled.0 (18095) State attribute definition missing for : o1 with value : false
                                          2023-09-28 12:18:52.765  - warn: wled.0 (18095) State attribute definition missing for : o2 with value : false
                                          2023-09-28 12:18:52.787  - warn: wled.0 (18095) State attribute definition missing for : o3 with value : false
                                          2023-09-28 12:18:52.801  - warn: wled.0 (18095) State attribute definition missing for : si with value : 0
                                          2023-09-28 12:18:52.813  - warn: wled.0 (18095) State attribute definition missing for : m12 with value : 0
                                          2023-09-28 12:18:53.931  - info: mihome-vacuum.0 (17583) State value to set for "mihome-vacuum.0.info.water_box" has to be type "string" but received type "boolean"
                                          2023-09-28 12:18:55.143  - info: info.0 (17779) State value to set for "info.0.sysinfo.disks.blockDevices.dev1.size" has to be type "string" but received type "number"
                                          2023-09-28 12:18:55.424  - info: info.0 (17779) State value to set for "info.0.sysinfo.disks.blockDevices.dev2.size" has to be type "string" but received type "number"
                                          2023-09-28 12:18:56.149  - info: info.0 (17779) State value to set for "info.0.sysinfo.disks.fsSize.fs0.type" has to be type "undefined" but received type "string"
                                          2023-09-28 12:18:57.015  - info: info.0 (17779) Reading disk data every 8 seconds.
                                          2023-09-28 12:18:57.464  - info: openweathermap.0 (17538) Terminated (NO_ERROR): Without reason
                                          2023-09-28 12:18:58.302  - info: host.ioBroker-Pi4 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
                                          2023-09-28 12:19:00.424  - info: info.0 (17779) State value to set for "info.0.sysinfo.network.interfaces.iface0.dhcp" has to be type "string" but received type "boolean"
                                          2023-09-28 12:19:01.031  - info: wled.0 (18095) WLED initialisation finalized, ready to do my job have fun !
                                          2023-09-28 12:19:01.939  - info: info.0 (17779) Reading network data every 3 seconds.
                                          Was mir so als Besonderheit bei mir einfällt - ich hatte mal den RPi4 als Master/Slave zu laufen - aber ich habe schon vor längerer Zeit den Slave von System deinstalliert (aber vielleicht nicht richtig ?). Ob das was mit dem Problem zu tun hat, kann ich aber nicht sagen :-(
                                          Was muss ich tun ?
                                          DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
