  4. Mit conbee2 von deconz zu zigbee Adapter wechseln
    5.2k
118 Beiträge 8 Kommentatoren 12.4k Aufrufe 7 Beobachtet
  • D docsnyder7
    @marc-berg
    Zigbee2MQTT:info  2023-09-22 08:43:52: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2023-09-22.08-43-52' filename: log.txt
    Zigbee2MQTT:info  2023-09-22 08:43:52: Starting Zigbee2MQTT version 1.33.0 (commit #f224ef7)
    Zigbee2MQTT:info  2023-09-22 08:43:52: Starting zigbee-herdsman (0.18.5)
    Zigbee2MQTT:info  2023-09-22 08:43:53: zigbee-herdsman started (resumed)
    Zigbee2MQTT:info  2023-09-22 08:43:53: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
    Zigbee2MQTT:info  2023-09-22 08:44:02: Currently 0 devices are joined:
    Zigbee2MQTT:info  2023-09-22 08:44:02: Zigbee: disabling joining new devices.
    Zigbee2MQTT:info  2023-09-22 08:44:03: Connecting to MQTT server at mqtt://192.168.178.57:1883
    Zigbee2MQTT:info  2023-09-22 08:44:03: Connected to MQTT server
    Zigbee2MQTT:info  2023-09-22 08:44:03: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
    Zigbee2MQTT:info  2023-09-22 08:44:04: Started frontend on port 0.0.0.0:8080
    Zigbee2MQTT:info  2023-09-22 08:44:04: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"f224ef7","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x412b1dae7bdd8bf3","panID":31839},"permit_join":false,"version":"1.33.0"}'
    Zigbee2MQTT:info  2023-09-22 08:44:04: Zigbee2MQTT started!
    das schaut gut aus... in dem zustand geht auch die 8080
    jetzt STRG C, dann den Service wieder enable
    dann start zigbee2mqtt.... korrekt
    Marc BergM Offline
    Marc BergM Offline
    Marc Berg
    @docsnyder7 sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
    Wenn der Service gestartet ist, kannst du auch unter
    die logs sehen, falls noch was klemmt. Nach jedem Start wird eine neue Datei angelegt.
    • Marc BergM Marc Berg
      docsnyder7
      @marc-berg
      [Unit]
      Description=zigbee2mqtt
      After=network.target
      [Service]
      Environment=NODE_ENV=production
      ExecStart=/usr/bin/npm start
      WorkingDirectory=/opt/zigbee2mqtt
      StandardOutput=inherit
      # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
      StandardError=inherit
      Restart=always
      RestartSec=10s
      User=pi
      [Install]
      WantedBy=multi-user.target
      in die service kommt ja obiger Inhalt rein... ich habe aber keinen user=pi... muss hier mein user rein mit dem ich mich am Pi anmelde?
      • D docsnyder7
        @marc-berg
        [Unit]
        [Service]
        Restart=always
        RestartSec=10s
        User=pi
        [Install]
        Marc BergM Offline
        Marc BergM Offline
        Marc Berg
        #66
        Da kann ich nicht helfen.
          docsnyder7
          #67
          @marc-berg
          so läuft...
          hab den user an meinen angepasst...
          muss ich jetzt zwigend den Adapter im iobroker installieren, wenn ich Datenpunkte für Blockly und vis benötige ?
          Riesiges DANKSCHÖN erstmal bis hierhin...😊
          • D docsnyder7
            @marc-berg
            so läuft...
            Marc BergM Offline
            Marc BergM Offline
            Marc Berg
            #68
            Das ist 'ne Glaubensfrage. Z2M liefert die Daten der Sensoren als einzelne Attribute aus, wenn du das so konfigurierst. Wenn du allerdings Geräte wie Plugs hast, dann musst du, um die steuern zu können, den /set-Pfad als MQTT Topic einmalig pro Gerät anlegen. Das macht wohl der Adapter für dich.
            Für mich habe ich entschieden, dass ich lieber einmalig die Hand anlege, als ständig einen zusätzlichen Adapter laufen zu lassen. Probier's einfach aus.
            @marc-berg sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
            Bei Z2M kann man mittlerweile einstellen, ob man die Werte als JSON, aufgedröselt oder beides haben möchte:
            Somit benötigt man den Adapter nicht zwingend. Das einzige, was man noch manuell erstellen muss, sind die "set" Zweige, um die Geräte zu steuern.
              docsnyder7
              schrieb am zuletzt editiert von docsnyder7
              #69
              @marc-berg
              ist das ein screen aus der Z2M Oberfläche?
              das ist alles noch ziemliches Neuland für mich...
              • Marc BergM Offline
                Marc BergM Offline
                Marc Berg
                #70
                ja, unter Einstellungen --> Erweitert
                  docsnyder7
                  #71
                  @marc-berg
                  ok das hab ich gefunden..
                  und jetzt muss ich mir noch eine separaten DP anlegen? oder den bestehenden in mqtt ändern
                    Marc BergM Offline
                    Marc Berg
                    #72
                    Jetzt pairst du einfach neue Zigbee-Geräte und freust dich, dass neue Datenpunkte unter MQTT.0 automatisch erzeugt werden.
                    Wenn du Geräte in Z2M umbenennst, werden übrigens auch die DP geändert. Wenn du das also vorhast, dann am besten gleich machen.
                    Ist aber alles sehr gut dokumentiert. https://www.zigbee2mqtt.io/guide/usage/pairing_devices.html
                      docsnyder7
                      #73
                      @marc-berg
                      das pairing hab ich hinbekommen... ich versuche jetzt die DP zu verstehen, die da entstehen und wie ich die in meine Blockly und vis einbaue
                      • D docsnyder7
                        @marc-berg
                        docsnyder7
                        #74
                        @docsnyder7
                        den DP state... kann ich manuell am Plug schalten... das ändert dann auch den Wert
                        über einen button im vis ändert sich zwar auch der Wert, aber der Plug schaltet nicht... muss hier der DP noch geändert werden oder muss ich zusätzlich einen 2. DP anlegen, der den state korrekt ausgibt?
                        • D docsnyder7
                          @docsnyder7
                          Marc BergM Offline
                          Marc BergM Offline
                          Marc Berg
                          #75
                          Wie ich oben geschrieben hatte, du musst noch einen DP zum Schalten setzen. Zu jedem gepairten Gerät ist ein Link auf der Oberfläche, dann kommst du zu so einer Seite (Beispiel Nous A1Z):
                          https://www.zigbee2mqtt.io/devices/A1Z.html
                          Hier ist beschrieben, wie jedes Gerät zu schalten ist:
                          In diesem Beispiel musst du also unter "Steckdose_Johanna" einen DP anlegen. Z.B. über Expertenmodus, neuen State "set.state" anlegen. Dann kannst du in "state", entweder "ON", "OFF" oder "TOGGLE" schreiben.
                            docsnyder7
                            #76
                            @marc-berg
                            sorry.. aber das geht nicht, kann nur eine Struktur darüber einen DP anlegen.. im Ordner Steckdose Johanna nicht
                            • D docsnyder7
                              @marc-berg
                              Marc BergM Offline
                              Marc BergM Offline
                              Marc Berg
                              #77
                              das geht nicht,
                              "geht nicht" ... Kannst du bitte etwas präziser werden in deinen Aussagen? Was passiert, wenn du den DP anlegen willst? Screenshot zeigen!
                                das geht nicht,
                                docsnyder7
                                #78
                                @marc-berg
                                es ist nicht möglich das PLUS zu betätigen, erst eine Struktur weiter oben geht das, aber dann bin ich nicht mehr im Ordner "Steckdose_Johanna"
                                Marc BergM mickymM 2 Antworten Letzte Antwort
                                • D docsnyder7
                                  @marc-berg
                                  Marc BergM Offline
                                  Marc BergM Offline
                                  Marc Berg
                                  #79
                                  das hier auf "attribute " stellen:
                                  , den DP "Steckdose_Johanna" löschen und Z2M neu starten.
                                  • D docsnyder7
                                    @marc-berg
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #80
                                    @marc-berg
                                    Dann gibst Du als Datenpunktname einfach Steckdose_Johanna.set auf der Ebene darüber an.
                                    • mickymM mickym
                                      @marc-berg
                                      Marc BergM Offline
                                      Marc BergM Offline
                                      Marc Berg
                                      #81
                                      @mickym sagte in Mit conbee2 von deconz zu zigbee Adapter wechseln:
                                      Kann man das auch gleich über zwei Ebenen machen, also "Steckdose_Johanna.set.state"?
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #82
                                        @marc-berg Was soll denn das bringen.
                                        Entweder man verwendet den zigbee2mqtt Adapter der alles in einzelne Datenpunkte aufdröselt oder man nimmt normales MQTT.
                                        state braucht man keinen Datenpunkt:
                                        Über den Set Datenpunkt schaltet man in dem man den State als JSON übergibt - wenn man das alles nicht will, dann muss man den Adapter verwenden.
                                        Also kein Datenpunkt unter set - der bringt NICHTs.
                                        Den Status ermittelt man aus dem JSON des Gerätes. Mit set schalte ich. Mit get kann ich erneut den Status darüber anfordern. Wenn man aus dem JSON schalten und einzeln herausbekommen möchte und MWTT verwenden will dann schaltet man das mit Blockly über einen Alias.
                                        D Marc BergM 2 Antworten Letzte Antwort
                                        • mickymM mickym
                                          docsnyder7
                                          #83
                                          @mickym
                                          könntest du mal bitte den Inhalt des get und set DP zeigen?
