  4. Plenticore Adapter startet nicht nach Aktualisierung
aktualisierungjs controller 5.0.12plenticore
27 Beiträge 5 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @hendrik
    Was ist denn das für ein merkwürdiges Log. Im Browser eine automatische Übersetzung aktiv?
    Hendrik
    2023-09-15 11:28:00.656 Error instance system.adapter.plenticore.0 was terminated with code 6 (UNCAUGHT_EXCEPTION)
    plenticore.0
    2023-09-15 11:28:00.032 warn Terminated (UNCAUGHT_EXCEPTION): without reason
    plenticore.0
    2023-09-15 11:27:59.037 Error Exception code: ERR_INVALID_ARG_TYPE: The "path" argument must be of type "string" or an instance of "buffer" or "URL". Received undefined
    plenticore.0
    2023-09-15 11:27:59.037 Error TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type "string" or an instance of "buffer" or "URL". Undefined received at Object.openSync (node:fs:595:10) at Object.writeFileSync (node:fs:2324:35) at Object.unload (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore. js: 773:5) at AdapterClass.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/main.js:40:14) at AdapterClass.emit (node:events:514:28) at AdapterClass. _stop (/opt /iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1369:26) at AdapterClass._ExceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build /lib/adapter/adapter.js:9113:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    plenticore.0
    09/15/2023 11:27:59.033 Error Unhandled promise rejection: the "path" argument must be of type "string" or an instance of "buffer" or "URL". Received undefined
    Translated with www.DeepL.com/Translator (free version)
      @hendrik sagte in Plenticore Adapter startet nicht nach Aktualisierung:
      IoBroker läuft auf einer Synology nas
      einfach so?
      • nativ?
      • Virtualization station?
      • Docker?
      Hendrik
      @homoran In einem Docker Plattform
      docker
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      2001 MHz
      Modell
      Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
      RAM
      9.58 GB
      System-Betriebszeit
      81 T. 08:40:32
      Node.js
      v18.17.1
      time
      1694770424015
      timeOffset
      -120
      NPM
      9.6.7
      Anzahl der Adapter
      496
      dockerInformation
      [object Object]
      Datenträgergröße
      3.49 TB
      freier Festplattenspeicher
      3.24 TB
      Aktive Instanzen
      27
      Weg
      /opt/iobroker/
      Betriebszeit
      00:27:00
      Hostname
      buanet-iobrokerv8latest
      MOD-EDIT:Code in code-tags gesetzt!
      • H Hendrik
        Nach der oben genannten Aktualisierung vom js Controller auf 5.0.12 startet der Adapter nicht mehr und gibt folgende Fehlermeldung=>
        Adapterwarnung
        Ausnahmecode:
        ENOENT: ENOENT: keine solche Datei oder kein solches Verzeichnis, mkdir '/opt/iobroker/node_modules/iobroker-data/plenticore.0'
        15.09.2023 10:09:27.442
        Ausnahmecode: ENOENT: ENOENT: keine solche Datei oder kein solches Verzeichnis, mkdir '/opt/iobroker/node_modules/iobroker-data/plenticore.0'
        15.09.2023
        Protokoll =>
        plenticore.0
        15.09.2023 10:41:13.226	warnen	Beendet (NO_ADAPTER_CONFIG_FOUND): Ohne Grund
        plenticore.0
        15.09.2023 10:41:13.155	Fehler	Adapter deaktiviert
        host.buanet-iobrokerv8latest
        15.09.2023 10:40:44.895	die Info	„system.adapter.plenticore.0“ deaktiviert
        15.09.2023 10:40:40.589	die Info	Starten Sie den Adapter system.adapter.plenticore.0 neu, da er aktiviert ist
        15.09.2023 10:40:40.588	Fehler	Instanz system.adapter.plenticore.0 wurde mit Code 6 (UNCAUGHT_EXCEPTION) beendet
        plenticore.0
        15.09.2023 10:40:39.963	warnen	Beendet (UNCAUGHT_EXCEPTION): Ohne Grund
        plenticore.0
        15.09.2023 10:40:38.968	Fehler	Ausnahmecode: ERR_INVALID_ARG_TYPE: Das Argument „Pfad“ muss vom Typ „String“ oder eine Instanz von „Puffer“ oder „URL“ sein. Unbestimmt empfangen
        plenticore.0
        15.09.2023 10:40:38.967	Fehler	TypeError [ERR_INVALID_ARG_TYPE]: Das Argument „Pfad“ muss vom Typ „String“ oder eine Instanz von „Puffer“ oder „URL“ sein. Undefiniert empfangen bei Object.openSync (node:fs:595:10) bei Object.writeFileSync (node:fs:2324:35) bei Object.unload (/opt/iobroker/node_modules/iobroker.plenticore/lib/plenticore.js: 773:5) bei AdapterClass.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/main.js:40:14) bei AdapterClass.emit (node:events:514:28) bei AdapterClass._stop (/opt /iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1369:26) unter AdapterClass._ExceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build /lib/adapter/adapter.js:9113:18) bei process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        plenticore.0
        15.09.2023 10:40:38.962	Fehler	Nicht behandelte Versprechensablehnung: Das Argument „Pfad“ muss vom Typ „String“ oder eine Instanz von „Puffer“ oder „URL“ sein. Unbestimmt empfangen
        plenticore.0
        15.09.2023 10:40:38.961	Fehler	Unbehandelte Versprechensablehnung. Dieser Fehler entstand entweder durch das Einwerfen einer asynchronen Funktion ohne Catch-Block oder durch die Ablehnung eines Versprechens, das nicht mit .catch() behandelt wurde.
        plenticore.0
        15.09.2023 10:40:38.952	Fehler	Ausnahmecode: ENOENT: ENOENT: keine solche Datei oder kein solches Verzeichnis, mkdir '/opt/iobroker/node_modules/iobroker-data/plenticore.0'
        plenticore.0
        15.09.2023 10:40:38.951	Fehler	Fehler: ENOENT: keine solche Datei oder kein solches Verzeichnis, mkdir '/opt/iobroker/node_modules/iobroker-data/plenticore.0' bei Object.mkdirSync (node:fs:1398:3) bei Object.setup (/opt/iobroker/ node_modules/iobroker.plenticore/lib/plenticore.js:695:6) bei Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore/main.js:189:17) bei process.processImmediate (node:internal /timers:478:21)
        plenticore.0
        15.09.2023 10:40:38.949	Fehler	Nicht erfasste Ausnahme: ENOENT: keine solche Datei oder kein solches Verzeichnis, mkdir '/opt/iobroker/node_modules/iobroker-data/plenticore.0'
        plenticore.0
        15.09.2023 10:40:38.945	die Info	[INFO] Konfiguriertes Abfrageintervall: 20000
        plenticore.0
        15.09.2023 10:40:38.943	die Info	Der konfigurierte Wp der Panel(s) ist 0
        plenticore.0
        15.09.2023 10:40:38.900	die Info	[START] Adapter Plenticore v2.2.0r237 wird gestartet
        plenticore.0
        15.09.2023 10:40:38.868	die Info	beginnend. Version 2.2.0 in /opt/iobroker/node_mo
        Danke im Voraus für die schnelle Unterstützung!
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @hendrik
        Welche Adapterversion verwendest du?
        Wenn ich es richtig lese 2.2.0. Aber bitte bei JEDEM Problem die Releases der beteiligten Adapter angeben. Verlängert die Lebensdauer unserer Glaskugeln :-)
        Das Problem sollte lt. Code Check spätestens ab 2.2.2 (aktuell im Latest ist 2.3.0) behoben sein.
        Leider hat der Dev bisher keinen Update des Adapters im stable repository angefordert. Es scheint heir ein Missverständnis gegeben zu haben.(https://github.com/pixcept/ioBroker.plenticore/issues/78).
        Ich versuche das zu klären.
        Zum Test kannst du die Version 2.3.0 von latest installieren. Aber wie immer LATEST = BETA = AT-OWN-RISK - also nur mit Backup
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        H 1 Antwort Letzte Antwort
          @thomas-braun Erstmal Danke für Deine schnelle Rückmeldung. Kannst Du mich bei diesem Problem unterstützen?
          beantworte doch erst einmal die Frage(n).
          im Moment weiss man zu wenig
          Hendrik
          @homoran Ich konnte das Problem erstmal lösen.in dem ich auf die alte Version zurückgegangen bin.
          Trotzdem stellt sich die Frage, warum es bei der neusten Version vom JS Controller nicht funktioniert beim Plenticore Adapter
          • H Hendrik
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @hendrik said in Plenticore Adapter startet nicht nach Aktualisierung:
            Ich vermute damit meinst du Rückstieg auf js-controller 4.x.x. Warum hast du nicht Plentiocor 2.3.0 getestet?
            Es funktioniert nicht weil der Plenticore Adapter in v2.2.0 eine nicht mehr unterstützte Methode zum Zugriff auf Daten verwendet. Dies wurde auch im Adapter schon gefixed. Mit Adapterversion 2.3.0 sollte es funktionieren.
            Sollte bei dir Plenticore 2.3.0 in Verbindung mit js-controlelr 5 nicht funktionieren, dann bitte
            -) ein Issue beim Aapter eröffen
            -) vollständigen log ahängen
            -) und gern hier verlinken
            mcm1957
            • mcm1957M mcm1957
              mcm1957
              Hendrik
              @mcm57 danke für den guten Hinweis ! mit der v2.3.0 hat es auch nicht funktioniert .
              • mcm1957M mcm1957
                @hendrik
                Hendrik
                @mcm57 Danke
                • H Hendrik
                  @mcm57 Danke
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @hendrik
                  Da eine Fehlerbehebung nur mit einem Issue zu erwarten ist, habe ich eines (für dich und andere User) geöffnet:
                  https://github.com/pixcept/ioBroker.plenticore/issues/84
                  Falls du logs der Probleme mit Version 2.3.0 beisteuern kannst, bitte häng sie an das Issue an.
                  H S 2 Antworten Letzte Antwort
                  • mcm1957M mcm1957
                    @hendrik
                    Hendrik
                    @mcm57 Danke im Voraus für Deine Unterstützung! Bezogen auf Deine Frage von Version 2.3.0, kann ich nur sagen, dass das gleiche Fehlerbild anstand d.h. der Adapter startet und bricht wieder ab.
                    • H Hendrik
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @hendrik
                      pixcept hat eine neue Version 2.3.1 erstellt. In den Releasenotes steht zwar nichts zu js-controlelr 5, aber bitte ev. doch testen. Und wenn es Probleme gibt im Adapter Repos isse erstellen oder aktualisieren.
                      DANKE
                      H 2 Antworten Letzte Antwort
                      • mcm1957M mcm1957
                        @hendrik
                        DANKE
                        Hendrik
                        @mcm57 erstmal danke für die Rückmeldung..! Kann mein System erst am Samstag aktualisieren.
                        • mcm1957M mcm1957
                          @hendrik
                          DANKE
                          Hendrik
                          @mcm57 Hallo mit der Version 2.3.1 sind die Probleme gleich geblieben.
                          Wie bereits von Dir geschrieben ist auch kein Hinweis im Änderungsprotokoll auf Version 5.
                          2.3.1
                          Weitere Option zur Steuerung des Batteriemanagements hinzugefügt [PastCoder]
                          • H Hendrik
                            2.3.1
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            @hendrik
                            Danke für Info
                            Und sorry f Probleme
                            • mcm1957M mcm1957
                              @hendrik
                              Danke für Info
                              Hendrik
                              @mcm57 Hallo, mein produktives System iob läuft auf einer Synology nas .
                              Ich habe jetzt den Adapter mit meinem Testsystem Proxmox getestet was auch mit der Version 2.2.2 mit js-controller 5 funktioniert hat.
                              Sollte ich es nochmal auf meiner Nas probieren ?
                              Danke im Voraus für die Rückmeldung !
                              • mcm1957M mcm1957
                                @hendrik
                                Spidermike
                                @mcm57
                                Möchte das Thema nochmal aufgreifen.
                                Habe auch den Plenticore Adapter auf 2.3.1
                                gibt es dafür eine Lösung?
                                • mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  @spidermike
                                  Da ich den Adapter nicht entwickelt habe oder warten kann muss ich dich mit der Frage an den Maintainer bzw ein issue im Repo verweisen:
                                  Ob pixcept hier im Forum mitliest / tätig ist weiß ich leider nicht.
                                  • mcm1957M mcm1957
                                    @spidermike
                                    Spidermike
                                    @mcm57
                                    ok danke, leider kenn ich mich mit Github nicht aus.
                                    Ich hoffe der Entwickler des Adapters schaut mal danach.
                                    • S Spidermike
                                      @mcm57
                                      @spidermike sagte in Plenticore Adapter startet nicht nach Aktualisierung:
                                      kann er nur, wenn du es ihm auf github mitteilst
                                        Spidermike
                                        ok habe mal eine Mitteilung hinterlassen,
                                        ich hoffe das passt so. 😕
                                        • S Spidermike
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          @spidermike
                                          Ich fühl mich zwar ein wenig als Briefträger möchte aber ggF hier Wartende nicht "verhungern" lassen:
                                          Der Dev hat hier
                                          https://github.com/pixcept/ioBroker.plenticore/issues/84#issuecomment-1793779149
                                          darum ersucht den Adapzter mit dem aktuellen Stand von Github zu testen.
                                          BITTE ggF dort ein Feedback / Nachfragen hinterlassen (und durchaus auch hier). Ich habe nicht die Zeit alle Meldungen hin und her zu kopieren.
