  4. iobroker geht nicht nach stromausfall
    1.0k
154 Beiträge 7 Kommentatoren 17.8k Aufrufe 5 Beobachtet
    @esmax666 sagte in iobroker geht nicht nach stromausfall:
    kann mir jemand klären was ich genau mache sollte?
    Zu nächst (mal wieder...) NIE NIE NIE sudo vor iobroker setzen. Nie!
    Und dann bitte keine schiefen Bilder von deinem Monitor. So hübsch ist der nicht.
    Per SSH aufschalten und dann den Text in CodeTags eingebettet hier rein.
    iob diag
    sagt?
    Esmax666
    Das:
    ubuntu@ubuntu:~$ iob diag
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-con        troller
      iobroker stop                                                stops the js-cont        roller
      iobroker restart                                             Restarts js-contr        oller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
      iobroker info                                                Shows the host in        fo
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter
      iobroker install <adapter>                                   Installs a specif        ied adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specif        ied adapter
      iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter fr        om system
      iobroker del <adapter>.<instance>                            Remove adapter in        stance
      iobroker update [<repositoryUrl>]                            Update repository        and list adapters
      iobroker upgrade                                             Upgrade managemen        t
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
      iobroker list <type> [<filter>]                              List all entries,        like objects
      iobroker chmod <mode> <file>                                 Change file right        s
      iobroker chown <user> <group> <file>                         Change file owner        ship
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given        hostname
      iobroker set <adapter>.<instance>                            Change settings o        f adapter config
      iobroker license <license.file or license.text>              Update license by        given file
      iobroker cert                                                Certificate manag        ement
      iobroker clean <yes>                                         Clears all object        s and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specifi        ed backup
      iobroker validate <backup name or path>                      Validate a specif        ied backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance
      iobroker repo [<name>]                                       Show repo informa        tion
      iobroker uuid                                                Show uuid of the        installation
      iobroker unsetup                                             Reset license, in        stallation secret and language
      iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost managem        ent
      iobroker compact                                             compact group man        agement
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    • E Esmax666
      Das:
      iobroker [command]
      Commands:
      Options:
      @esmax666
      Dann
      iob stop
      iob fix
      iob start
      ...ABWARTEN...
      iob diag
      E 1 Antwort Letzte Antwort
        @esmax666
        Dann
        iob stop
        iob fix
        iob start
        ...ABWARTEN...
        iob diag
        Esmax666
        @thomas-braun said in iobroker geht nicht nach stromausfall:
        iob diag
        Skript v.2023-06-20
        *** BASE SYSTEM ***
           Static hostname: ubuntu
                 Icon name: computer
                Machine ID: 551875df55414c0f832b43a896fe8ce5
                   Boot ID: a58fe4cd23274d7e86463c9c059dca8f
          Operating System: Ubuntu 21.04
                    Kernel: Linux 5.11.0-1027-raspi
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         12:19:36 up 28 min,  1 user,  load average: 1.46, 1.33, 1.15
        CPU threads: 4
        *** Time and Time Zones ***
                       Local time: Tue 2023-09-19 12:19:36 CEST
                   Universal time: Tue 2023-09-19 10:19:36 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ubuntu
        /home/ubuntu
        ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        175M        7.1G        3.0M        625M        7.6G
        Swap:            0B          0B          0B
        Total:         7.9G        175M        7.1G
                 7886 M total memory
                  176 M used memory
                  252 M active memory
                  327 M inactive memory
                 7084 M free memory
                  102 M buffer memory
                  522 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Filesystem     Type   Size  Used Avail Use% Mounted on
        tmpfs          tmpfs  789M  4.0M  785M   1% /run
        /dev/sda2      ext4    57G  6.9G   48G  13% /
        tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
        /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
        tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
        [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
        [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
        TARGET              SOURCE     FSTYPE   OPTIONS
        /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
        |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
        |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
        |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
        |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
        |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
        |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
        |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
        |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
        |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
        |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
        `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.2G    /var/
        1.9G    /var/log
        1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
        1.2G    /var/lib
        Archived and active journals take up 1.6G in the file system.
        /opt/iobroker/backups:
        54M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        148M    /opt/iobroker/iobroker-data/
        129M    /opt/iobroker/iobroker-data/files
        59M     /opt/iobroker/iobroker-data/files/javascript.admin
        44M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
        9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
        4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v12.22.7
        /usr/bin/node           v12.22.7
        /usr/bin/npm            6.14.15
        /usr/bin/npx            6.14.15
        nodejs:
          Installed: 12.22.7-deb-1nodesource1
          Candidate: 12.22.12-deb-1nodesource1
          Version table:
             12.22.12-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x hirsute/main armhf Packages
         *** 12.22.7-deb-1nodesource1 100
             12.21.0~dfsg-3ubuntu1 500
                500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
        No problems detected
        • E Esmax666
          iob diag
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          ubuntu
          /home/ubuntu
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            0B          0B          0B
                   7886 M total memory
                    176 M used memory
                    252 M active memory
                   7084 M free memory
                    102 M buffer memory
                    522 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          3.2G    /var/
          1.9G    /var/log
          1.2G    /var/lib
          nodejs:
            Version table:
          Ubuntu 21.04
          Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version 'Lite' empfehlen.
          VIEL zu alt. Bring das auf nodejs@18. Evtl. mit diesem Skript:
          Und die Ausgabe von iob diag ist nicht vollständig.
          Mach es nochmal, nachdem die nodejs-Version auf Stand ist.
            Ubuntu 21.04
            Esmax666
            Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version empfehlen.
            ja aber aber ist doch nicht das Problem oder ? also früher hat das funjtionniert vor "stromausfall"
            Siehe code + Diag nochmal
            ioBroker nodejs fixer 2023-09-15
            Recommended nodejs-version is:  Cannot read system.config: null (OK when migrating or restoring)
            Checking your installation now. Please be patient!
            Your current setup is:
            We found these nodejs versions available for installation:
            nodejs:
              Version table:
            Nothing to do, your installation is using the correct paths.
            You are running nodejs v12.22.7. Do you want to install recommended version  Cannot read system.config: null (OK when migrating or restoring)?
            Press <y> to continue or any other key to quit
            Trying to fix your installation now. Please be patient.
            Waiting for ioBroker to shut down - Give me a minute...
            *** These repos are active on your system:
            Ign:1 http://ports.ubuntu.com/ubuntu-ports hirsute InRelease
            Ign:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease
            Ign:3 http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease
            Ign:4 http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease
            Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute Release
              404  Not Found [IP: 2620:2d:4000:1::19 80]
            Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
            Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
            Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
            Reading package lists... Done
            E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute Release' no longer has a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release' no longer has a Release file.
            E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release' no longer has a Release file.
            E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security Release' no longer has a Release file.
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
              404  Not Found [IP: 2620:2d:4000:1::16 80]
            Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
            Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
            Get:10 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
            Installing the recommended nodejs version now!
            E: Version ' Cannot read system.config: null (OK when migrating or restoring)-1nodesource1' for 'nodejs' was not found
            Calculating upgrade... Done
            The following packages will be upgraded:
              alsa-ucm-conf cloud-init command-not-found libasound2 libasound2-data libnetplan0 libssl1.1 linux-base linux-firmware netplan.io nodejs openssh-client openssh-server openssh-sftp-server openssl
              python3-commandnotfound python3-software-properties software-properties-common sosreport ubuntu-advantage-tools ufw update-notifier-common usrmerge
            23 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 190 MB of archives.
            After this operation, 93.2 MB of additional disk space will be used.
            Do you want to continue? [Y/n] Y
            Err:1 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf update-notifier-common all 3.192.40.4
            Err:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libssl1.1 armhf 1.1.1j-1ubuntu3.6
            Err:3 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf usrmerge all 24ubuntu3.1
            Err:4 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libnetplan0 armhf 0.103-0ubuntu5~21.04.4
            Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf netplan.io armhf 0.103-0ubuntu5~21.04.4
            Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssl armhf 1.1.1j-1ubuntu3.6
            Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ubuntu-advantage-tools armhf 27.5~21.04.1
            Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf command-not-found all 20.10.2
            Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-commandnotfound all 20.10.2
            Err:10 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-sftp-server armhf 1:8.4p1-5ubuntu1.2
            Err:11 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-server armhf 1:8.4p1-5ubuntu1.2
            Err:12 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-client armhf 1:8.4p1-5ubuntu1.2
            Err:13 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ufw all 0.36-7.1ubuntu1
            Err:14 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2 armhf 1.2.4-1.1ubuntu2.1
            Err:15 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2-data all 1.2.4-1.1ubuntu2.1
            Err:16 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf alsa-ucm-conf all 1.2.4-2ubuntu1.4
            Err:17 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-base all 4.5ubuntu5.4
            Err:18 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-firmware all 1.197.5
            Err:19 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf software-properties-common all 0.99.10.2
            Err:20 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-software-properties all 0.99.10.2
            Err:21 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf sosreport armhf 4.2-1ubuntu0.21.04.1
            Err:22 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf cloud-init all 21.4-0ubuntu1~21.04.1
            Get:23 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.18.0-1nodesource1 [26.8 MB]
            Fetched 26.8 MB in 3s (7858 kB/s)
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/update-notifier/update-notifier-common_3.192.40.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/libssl1.1_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/usrmerge/usrmerge_24ubuntu3.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/libnetplan0_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/netplan.io_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/openssl_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.5%7e21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/command-not-found_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/python3-commandnotfound_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-sftp-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-client_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ufw/ufw_0.36-7.1ubuntu1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2_1.2.4-1.1ubuntu2.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2-data_1.2.4-1.1ubuntu2.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-ucm-conf/alsa-ucm-conf_1.2.4-2ubuntu1.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-base/linux-base_4.5ubuntu5.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-firmware/linux-firmware_1.197.5_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/software-properties-common_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/python3-software-properties_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/sosreport/sosreport_4.2-1ubuntu0.21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/cloud-init/cloud-init_21.4-0ubuntu1%7e21.04.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
            E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
             Please refresh or restart your browser in a few moments.
            Diag: ( am ende war das blokiert mit " Cannot read system.config: null (OK when migrating or restoring)" )
            Skript v.2023-06-20
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : armhf
             12:43:23 up 52 min,  1 user,  load average: 1.20, 1.21, 1.24
            CPU threads: 4
                           Local time: Tue 2023-09-19 12:43:24 CEST
                       Universal time: Tue 2023-09-19 10:43:24 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            ubuntu
            /home/ubuntu
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           7.9G        188M        6.9G        3.0M        832M        7.6G
            Swap:            0B          0B          0B
            Total:         7.9G        188M        6.9G
                     7886 M total memory
                      188 M used memory
                      484 M active memory
                      274 M inactive memory
                     6865 M free memory
                      226 M buffer memory
                      606 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            3.2G    /var/
            1.9G    /var/log
            1.2G    /var/lib
            149M    /opt/iobroker/iobroker-data/
            nodejs:
              Candidate: 18.18.0-1nodesource1
              Version table:
                 18.18.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: file
            States  type: file
            No configuration change needed.
            Multihost discovery server: disabled
            Discovery authentication:   enabled
            Persistent activation:      disabled
            Objects:                    file on 127.0.0.1
            States:                     file on 127.0.0.1
            Core adapters versions
            js-controller:  3.3.18
            admin:          5.2.1
            javascript:     5.2.13
            Adapters from github:   2
            Adapter State
            + instance is alive
            ioBroker-Repositories
            Cannot get list: undefined
            Installed ioBroker-Instances
            Error: Object "system.config" not found
            E Thomas BraunT 2 Antworten Letzte Antwort
            • E Esmax666
              nodejs:
                Version table:
              Package: nodejs
              Pin-Priority: 1001
              Skript v.2023-06-20
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : armhf
              CPU threads: 4
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              ubuntu
              /home/ubuntu
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            0B          0B          0B
                       7886 M total memory
                        188 M used memory
                        484 M active memory
                       6865 M free memory
                        226 M buffer memory
                        606 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              3.2G    /var/
              1.9G    /var/log
              1.2G    /var/lib
              nodejs:
                Version table:
              ioBroker Status
              Objects type: file
              States  type: file
              admin:          5.2.1
              javascript:     5.2.13
              Adapter State
              + instance is alive
              Esmax666
              und das war für FIX:
              ubuntu@ubuntu:~$ iob fix
              library: loaded
              Library version=2022-12-09
                  Welcome to the ioBroker installation fixer!
                  Script version: 2023-04-02
                  You might need to enter your password a couple of times.
                  Installing prerequisites (1/5)
              Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
              Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
              Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
              Installed gcc-c++
              Installed cmake
                  Checking ioBroker user and directory permissions (2/5)
                  Check and cleanup npm temporary directories (3/5)
              Done.
                  Database maintenance (4/5)
              Checking for uncompressed JSONL databases... This might take a while!
              npx: installed 12 in 6.831s
              No path given, using /opt/iobroker/iobroker-data
              No relevant JSONL files found to compress, skip
                  Checking autostart (5/5)
              Enabling autostart...
              Autostart enabled!
                  Your installation was fixed successfully
                  Run iobroker start to start ioBroker again!
              ubuntu@ubuntu:~$
              • E Esmax666
                nodejs:
                  Version table:
                Package: nodejs
                Pin-Priority: 1001
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                CPU threads: 4
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                ubuntu
                /home/ubuntu
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            0B          0B          0B
                         7886 M total memory
                          188 M used memory
                          484 M active memory
                         6865 M free memory
                          226 M buffer memory
                          606 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                3.2G    /var/
                1.9G    /var/log
                1.2G    /var/lib
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: file
                States  type: file
                admin:          5.2.1
                javascript:     5.2.13
                Adapter State
                + instance is alive
                Nein, aber abgekündigte, nicht mehr gewartete Versionen sind immer ein Problem. Ja länger die Leiche da rumgammelt, umso schwieriger wird der Umgang mit dem Kadaver. Weg damit.
                Das sind nämlich die Folgen daraus:
                Und deswegen funktioniert da auch nix mehr, was Software-Installationen angeht. Ist halt tot...
                sudo apt install nodejs=18.18.0-1nodesource1
                liefert?
                  liefert?
                  Esmax666
                  ubuntu@ubuntu:~$ sudo apt install nodejs=18.18.0-1nodesource1
                    nodejs
                  1 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
                  Need to get 0 B/26.8 MB of archives.
                  After this operation, 91.4 MB of additional disk space will be used.
                  (Reading database ... 116546 files and directories currently installed.)
                  Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
                  Detected old npm client, removing...
                  Unpacking nodejs (18.18.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
                  Setting up nodejs (18.18.0-1nodesource1) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Scanning processes...
                  Scanning processor microcode...
                  Scanning linux images...
                  Running kernel seems to be up-to-date.
                  Failed to check for processor microcode upgrades.
                  No services need to be restarted.
                  No containers need to be restarted.
                  No user sessions are running outdated binaries.
                  ubuntu@ubuntu:~$
                  • E Esmax666
                      nodejs
                    ubuntu@ubuntu:~$
                    @esmax666
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iob restart
                      @esmax666
                      cd /opt/iobroker
                      iob restart
                      Esmax666
                        nodejs
                      ubuntu@ubuntu:~$ ^C
                      ubuntu@ubuntu:~$ cd /opt/iobroker
                      ubuntu@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                      npm WARN old lockfile
                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                      changed 1 package in 9m
                      85 packages are looking for funding
                        run `npm fund` for details
                      ubuntu@ubuntu:/opt/iobroker$ iob restart
                      und nochmal diag
                      Skript v.2023-06-20
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : armhf
                       13:34:12 up  1:43,  1 user,  load average: 0.99, 0.93, 1.00
                      CPU threads: 4
                                     Local time: Tue 2023-09-19 13:34:12 CEST
                                 Universal time: Tue 2023-09-19 11:34:12 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      ubuntu
                      /home/ubuntu
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:           7.9G        184M        6.6G        3.0M        1.1G        7.6G
                      Swap:            0B          0B          0B
                      Total:         7.9G        184M        6.6G
                               7886 M total memory
                                184 M used memory
                                544 M active memory
                                464 M inactive memory
                               6595 M free memory
                                236 M buffer memory
                                870 M swap cache
                                  0 M total swap
                                  0 M used swap
                                  0 M free swap
                      *** FILESYSTEM ***
                      /dev/sda2      ext4    57G  7.0G   48G  13% /
                      /var:
                      3.2G    /var/
                      1.9G    /var/log
                      1.2G    /var/lib
                      /usr/bin/nodejs         v18.18.0
                      /usr/bin/node           v18.18.0
                      /usr/bin/npm            9.8.1
                      /usr/bin/npx            9.8.1
                      nodejs:
                        Installed: 18.18.0-1nodesource1
                        Version table:
                       *** 18.18.0-1nodesource1 1001
                      ioBroker Status
                       Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                      No connection to databases possible ...
                      js-controller:  3.3.22
                      admin:          5.2.1
                      javascript:     5.2.13
                      Adapters from github:   0
                      Adapter State
                      + instance is alive
                      latest      : http://download.iobroker.net/sources-dist-latest.json
                      stable      : http://download.iobroker.net/sources-dist.json
                      Active repo: stable
                      Used repository: stable
                      hash changed or no sources cached => force download of new sources
                      Cannot get any information of "_repoInfo". Ignored.
                      update done
                       Cannot find view "system" for search "instance"
                      Error: Cannot find view "system"
                          at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
                      Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
                      Adapter    "backitup"      : 2.6.23   , installed 2.2.2 [Updateable]
                      Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                      Adapter    "discovery"     : 3.1.0    , installed 2.7.0 [Updateable]
                      Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                      Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
                      Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
                      Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
                      Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
                      Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
                      Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
                      Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
                      Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
                      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                      Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
                      Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
                      Adapter    "shuttercontrol": 1.6.1    , installed 1.2.1 [Updateable]
                      Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
                      Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
                      Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
                      Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
                      Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
                      Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
                      Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
                      Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
                      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                      Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                      Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                      Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
                      Adapter    "zwave2"        : 3.0.5    , installed 2.4.1 [Updateable]
                      Objects and States
                      Objects:        11
                      States:         21
                      Pending Updates: 22
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287610     4905/iobroker.js-co
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        39620      1926/systemd-resolv
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38625      2046/sshd: /usr/sbi
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          38627      2046/sshd: /usr/sbi
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        39619      1926/systemd-resolv
                      udp        0      0 192.168.178.51:68       0.0.0.0:*                           100        41269      1924/systemd-networ
                      udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                100        40545      1924/systemd-networ
                      2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "state"
                      2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "instance"
                      2023-09-19 13:35:02.368  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Error: Cannot find view "system"
                      2023-09-19 13:35:02.369  - error: host.ubuntu _design/system missing - call node iobroker.js setup
                      2023-09-19 13:35:02.369  - info: host.ubuntu no instances found
                      2023-09-19 13:35:02.384  - error: host.ubuntu uncaught exception: doc.rows is not iterable
                      2023-09-19 13:35:02.385  - error: host.ubuntu TypeError: doc.rows is not iterable
                          at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
                          at getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
                      2023-09-19 13:35:02.395  - info: host.ubuntu iobroker _restart
                      2023-09-19 13:35:02.443  - error: host.ubuntu Cannot write host object:Error: DB closed
                      2023-09-19 13:35:02.705  - info: host.ubuntu terminated
                      2023-09-19 13:35:03.353  - info: host.ubuntu iobroker Starting node restart.js
                      2023-09-19 13:35:05.193  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                      2023-09-19 13:35:05.199  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                      2023-09-19 13:35:05.200  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                      2023-09-19 13:35:05.201  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                      2023-09-19 13:35:05.343  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                      2023-09-19 13:35:35.225  - error: host.ubuntu No connection to databases possible, restart
                      2023-09-19 13:35:35.235  - info: host.ubuntu iobroker _restart
                      2023-09-19 13:35:40.760  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                      2023-09-19 13:35:40.765  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                      2023-09-19 13:35:40.767  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                      2023-09-19 13:35:40.768  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                      2023-09-19 13:35:41.092  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                      iob diag has finished.
                      Press any key for a summary
                      • E Esmax666
                          nodejs
                        ubuntu@ubuntu:~$ ^C
                        und nochmal diag
                        Skript v.2023-06-20
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm
                        Docker          : false
                        Kernel          : armv7l
                        Userland        : armhf
                        CPU threads: 4
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        ubuntu
                        /home/ubuntu
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            0B          0B          0B
                                 7886 M total memory
                                  184 M used memory
                                  544 M active memory
                                 6595 M free memory
                                  236 M buffer memory
                                  870 M swap cache
                                    0 M total swap
                                    0 M used swap
                                    0 M free swap
                        *** FILESYSTEM ***
                        /var:
                        3.2G    /var/
                        1.9G    /var/log
                        1.2G    /var/lib
                        /usr/bin/npm            9.8.1
                        /usr/bin/npx            9.8.1
                        nodejs:
                          Version table:
                        ioBroker Status
                        admin:          5.2.1
                        javascript:     5.2.13
                        Adapter State
                        + instance is alive
                        Active repo: stable
                        update done
                        Objects and States
                        Objects:        11
                        States:         21
                        Pending Updates: 22
                        Steinalt. Wie der Rest von der Kiste halt auch...
                        Versuch es damit
                        iob update
                        iob upgrade all -y
                        iob stop
                        iob fix
                        iob upgrade self
                        iob restart
                        E OliverIOO 2 Antworten Letzte Antwort
                          Versuch es damit
                          iob update
                          iob upgrade all -y
                          iob stop
                          iob fix
                          iob upgrade self
                          iob restart
                          Esmax666
                          iob stop
                          ich bekomme schonn hier fehler
                          ubuntu@ubuntu:/opt/iobroker$ iob update
                          hash unchanged, use cached sources
                          update done
                              at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                          ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
                            Versuch es damit
                            iob update
                            iob upgrade all -y
                            iob stop
                            iob fix
                            iob upgrade self
                            iob restart
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                            ich glaube mich dunkel daran zu erinnern, das man von so alten installationen nicht in einem rutsch auf aktuell aktualisieren kann.
                            ich musste damals erst auf die letzte 3er version mit npm install den js-controller aktualisieren und dann ging es wieder mit iob upgrade weiter.
                            das ist aber nicht sicher, wie gesagt kann mich nur dunkel daran erinnern.
                            auch das einspielen eines backups könnte von so alten versionen problematisch sein. aber da müssen sich hier noch andere dazu äußern
                            Meine Adapter und Widgets
                            Links im Profil
                            Thomas BraunT E 2 Antworten Letzte Antwort
                            • OliverIOO OliverIO
                              @oliverio
                              Ich hatte mich jetzt hieran orientiert:
                              Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt.
                              Eine zwingende Installation von Vorversionen lese ich da nicht heraus.
                                @oliverio
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                wenn es klappt, dann gut
                                ist gesichert, das sein Datenspeicher noch gut ist?
                                Nach Stromausfall zicken manchmal die SD-Cards rum
                                Links im Profil
                                  @oliverio sagte in iobroker geht nicht nach stromausfall:
                                  Offenbar klappt es nicht.
                                  Da gab es aber auch schon mal was gegen. Ich hab nur gerade kein Heilmittel parat.
                                    Ja, die fressen dann offene files...
                                    Ist hier ja auch offenbar passiert.
                                    • OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                                      evtl ist die redis db kaputt
                                      Links im Profil
                                        @oliverio
                                        Da hab ich überhaupt keine Aktien drin.
                                        Damals war glaube ich File/File der Standard?
                                          Esmax666
                                          @oliverio was soll dann genau machen ?
                                          82.9k
