  4. iobroker geht nicht nach stromausfall
    5.2k
154 Beiträge 7 Kommentatoren 21.6k Aufrufe 5 Beobachtet
  • E Esmax666
    @thomas-braun said in iobroker geht nicht nach stromausfall:
    iob diag
    Skript v.2023-06-20
    *** BASE SYSTEM ***
       Static hostname: ubuntu
             Icon name: computer
            Machine ID: 551875df55414c0f832b43a896fe8ce5
               Boot ID: a58fe4cd23274d7e86463c9c059dca8f
      Operating System: Ubuntu 21.04
                Kernel: Linux 5.11.0-1027-raspi
          Architecture: arm
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : armhf
    Systemuptime and Load:
     12:19:36 up 28 min,  1 user,  load average: 1.46, 1.33, 1.15
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Tue 2023-09-19 12:19:36 CEST
               Universal time: Tue 2023-09-19 10:19:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    ubuntu
    /home/ubuntu
    ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        175M        7.1G        3.0M        625M        7.6G
    Swap:            0B          0B          0B
    Total:         7.9G        175M        7.1G
             7886 M total memory
              176 M used memory
              252 M active memory
              327 M inactive memory
             7084 M free memory
              102 M buffer memory
              522 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem     Type   Size  Used Avail Use% Mounted on
    tmpfs          tmpfs  789M  4.0M  785M   1% /run
    /dev/sda2      ext4    57G  6.9G   48G  13% /
    tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
    /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
    tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
    [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
    [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
    TARGET              SOURCE     FSTYPE   OPTIONS
    /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
    |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
    |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
    |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
    |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
    |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
    |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
    |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
    |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
    |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
    |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
    `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.2G    /var/
    1.9G    /var/log
    1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
    1.2G    /var/lib
    Archived and active journals take up 1.6G in the file system.
    /opt/iobroker/backups:
    54M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    148M    /opt/iobroker/iobroker-data/
    129M    /opt/iobroker/iobroker-data/files
    59M     /opt/iobroker/iobroker-data/files/javascript.admin
    44M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
    4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v12.22.7
    /usr/bin/node           v12.22.7
    /usr/bin/npm            6.14.15
    /usr/bin/npx            6.14.15
    nodejs:
      Installed: 12.22.7-deb-1nodesource1
      Candidate: 12.22.12-deb-1nodesource1
      Version table:
         12.22.12-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x hirsute/main armhf Packages
     *** 12.22.7-deb-1nodesource1 100
         12.21.0~dfsg-3ubuntu1 500
            500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
    No problems detected
    @esmax666 sagte in iobroker geht nicht nach stromausfall:
    Ubuntu 21.04
    Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version 'Lite' empfehlen.
    VIEL zu alt. Bring das auf nodejs@18. Evtl. mit diesem Skript:
    Und die Ausgabe von iob diag ist nicht vollständig.
    Mach es nochmal, nachdem die nodejs-Version auf Stand ist.
    E 1 Antwort Letzte Antwort
      Ubuntu 21.04
      Esmax666
      Zu alt, abgekündigt. Installier da was lebendiges, für einen Raspberry würde ich aber Raspberry OS in der 64Bit-Version empfehlen.
      ja aber aber ist doch nicht das Problem oder ? also früher hat das funjtionniert vor "stromausfall"
      Siehe code + Diag nochmal
      ioBroker nodejs fixer 2023-09-15
      Recommended nodejs-version is:  Cannot read system.config: null (OK when migrating or restoring)
      Checking your installation now. Please be patient!
      Your current setup is:
      We found these nodejs versions available for installation:
      nodejs:
        Version table:
      Nothing to do, your installation is using the correct paths.
      You are running nodejs v12.22.7. Do you want to install recommended version  Cannot read system.config: null (OK when migrating or restoring)?
      Press <y> to continue or any other key to quit
      Trying to fix your installation now. Please be patient.
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Ign:1 http://ports.ubuntu.com/ubuntu-ports hirsute InRelease
      Ign:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates InRelease
      Ign:3 http://ports.ubuntu.com/ubuntu-ports hirsute-backports InRelease
      Ign:4 http://ports.ubuntu.com/ubuntu-ports hirsute-security InRelease
      Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute Release
        404  Not Found [IP: 2620:2d:4000:1::19 80]
      Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
      Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
      Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
      Reading package lists... Done
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute Release' no longer has a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security Release' no longer has a Release file.
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
        404  Not Found [IP: 2620:2d:4000:1::16 80]
      Get:8 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-security Release
      Get:10 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5267 B]
      Installing the recommended nodejs version now!
      E: Version ' Cannot read system.config: null (OK when migrating or restoring)-1nodesource1' for 'nodejs' was not found
      Calculating upgrade... Done
      The following packages will be upgraded:
        alsa-ucm-conf cloud-init command-not-found libasound2 libasound2-data libnetplan0 libssl1.1 linux-base linux-firmware netplan.io nodejs openssh-client openssh-server openssh-sftp-server openssl
        python3-commandnotfound python3-software-properties software-properties-common sosreport ubuntu-advantage-tools ufw update-notifier-common usrmerge
      23 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 190 MB of archives.
      After this operation, 93.2 MB of additional disk space will be used.
      Do you want to continue? [Y/n] Y
      Err:1 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf update-notifier-common all 3.192.40.4
      Err:2 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libssl1.1 armhf 1.1.1j-1ubuntu3.6
      Err:3 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf usrmerge all 24ubuntu3.1
      Err:4 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libnetplan0 armhf 0.103-0ubuntu5~21.04.4
      Err:5 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf netplan.io armhf 0.103-0ubuntu5~21.04.4
      Err:6 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssl armhf 1.1.1j-1ubuntu3.6
      Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ubuntu-advantage-tools armhf 27.5~21.04.1
      Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf command-not-found all 20.10.2
      Err:9 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-commandnotfound all 20.10.2
      Err:10 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-sftp-server armhf 1:8.4p1-5ubuntu1.2
      Err:11 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-server armhf 1:8.4p1-5ubuntu1.2
      Err:12 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf openssh-client armhf 1:8.4p1-5ubuntu1.2
      Err:13 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf ufw all 0.36-7.1ubuntu1
      Err:14 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2 armhf 1.2.4-1.1ubuntu2.1
      Err:15 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf libasound2-data all 1.2.4-1.1ubuntu2.1
      Err:16 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf alsa-ucm-conf all 1.2.4-2ubuntu1.4
      Err:17 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-base all 4.5ubuntu5.4
      Err:18 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf linux-firmware all 1.197.5
      Err:19 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf software-properties-common all 0.99.10.2
      Err:20 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf python3-software-properties all 0.99.10.2
      Err:21 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf sosreport armhf 4.2-1ubuntu0.21.04.1
      Err:22 http://ports.ubuntu.com/ubuntu-ports hirsute-updates/main armhf cloud-init all 21.4-0ubuntu1~21.04.1
      Get:23 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.18.0-1nodesource1 [26.8 MB]
      Fetched 26.8 MB in 3s (7858 kB/s)
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/update-notifier/update-notifier-common_3.192.40.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/libssl1.1_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/usrmerge/usrmerge_24ubuntu3.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/libnetplan0_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/n/netplan.io/netplan.io_0.103-0ubuntu5%7e21.04.4_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssl/openssl_1.1.1j-1ubuntu3.6_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ubuntu-advantage-tools/ubuntu-advantage-tools_27.5%7e21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/command-not-found_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/command-not-found/python3-commandnotfound_20.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-sftp-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-server_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/o/openssh/openssh-client_8.4p1-5ubuntu1.2_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/u/ufw/ufw_0.36-7.1ubuntu1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2_1.2.4-1.1ubuntu2.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-lib/libasound2-data_1.2.4-1.1ubuntu2.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/a/alsa-ucm-conf/alsa-ucm-conf_1.2.4-2ubuntu1.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-base/linux-base_4.5ubuntu5.4_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/l/linux-firmware/linux-firmware_1.197.5_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/software-properties-common_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/software-properties/python3-software-properties_0.99.10.2_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/s/sosreport/sosreport_4.2-1ubuntu0.21.04.1_armhf.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/pool/main/c/cloud-init/cloud-init_21.4-0ubuntu1%7e21.04.1_all.deb  404  Not Found [IP: 2620:2d:4000:1::16 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      Diag: ( am ende war das blokiert mit " Cannot read system.config: null (OK when migrating or restoring)" )
      Skript v.2023-06-20
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : armhf
       12:43:23 up 52 min,  1 user,  load average: 1.20, 1.21, 1.24
      CPU threads: 4
                     Local time: Tue 2023-09-19 12:43:24 CEST
                 Universal time: Tue 2023-09-19 10:43:24 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      ubuntu
      /home/ubuntu
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        188M        6.9G        3.0M        832M        7.6G
      Swap:            0B          0B          0B
      Total:         7.9G        188M        6.9G
               7886 M total memory
                188 M used memory
                484 M active memory
                274 M inactive memory
               6865 M free memory
                226 M buffer memory
                606 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      3.2G    /var/
      1.9G    /var/log
      1.2G    /var/lib
      149M    /opt/iobroker/iobroker-data/
      nodejs:
        Candidate: 18.18.0-1nodesource1
        Version table:
           18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: file
      States  type: file
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    file on 127.0.0.1
      States:                     file on 127.0.0.1
      Core adapters versions
      js-controller:  3.3.18
      admin:          5.2.1
      javascript:     5.2.13
      Adapters from github:   2
      Adapter State
      + instance is alive
      ioBroker-Repositories
      Cannot get list: undefined
      Installed ioBroker-Instances
      Error: Object "system.config" not found
      E Thomas BraunT 2 Antworten Letzte Antwort
      • E Esmax666
        nodejs:
          Version table:
        Package: nodejs
        Pin-Priority: 1001
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        ubuntu
        /home/ubuntu
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            0B          0B          0B
                 7886 M total memory
                  188 M used memory
                  484 M active memory
                 6865 M free memory
                  226 M buffer memory
                  606 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        3.2G    /var/
        1.9G    /var/log
        1.2G    /var/lib
        nodejs:
          Version table:
        ioBroker Status
        Objects type: file
        States  type: file
        admin:          5.2.1
        javascript:     5.2.13
        Adapter State
        + instance is alive
        Esmax666
        und das war für FIX:
        ubuntu@ubuntu:~$ iob fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2023-04-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
        Err:7 http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release
        Err:8 http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release
        Installed gcc-c++
        Installed cmake
            Checking ioBroker user and directory permissions (2/5)
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        npx: installed 12 in 6.831s
        No path given, using /opt/iobroker/iobroker-data
        No relevant JSONL files found to compress, skip
            Checking autostart (5/5)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        ubuntu@ubuntu:~$
        • E Esmax666
          nodejs:
            Version table:
          Package: nodejs
          Pin-Priority: 1001
          Skript v.2023-06-20
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : armhf
          CPU threads: 4
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          ubuntu
          /home/ubuntu
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            0B          0B          0B
                   7886 M total memory
                    188 M used memory
                    484 M active memory
                   6865 M free memory
                    226 M buffer memory
                    606 M swap cache
                      0 M total swap
                      0 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          /var:
          3.2G    /var/
          1.9G    /var/log
          1.2G    /var/lib
          nodejs:
            Version table:
          ioBroker Status
          Objects type: file
          States  type: file
          admin:          5.2.1
          javascript:     5.2.13
          Adapter State
          + instance is alive
          Nein, aber abgekündigte, nicht mehr gewartete Versionen sind immer ein Problem. Ja länger die Leiche da rumgammelt, umso schwieriger wird der Umgang mit dem Kadaver. Weg damit.
          Das sind nämlich die Folgen daraus:
          Und deswegen funktioniert da auch nix mehr, was Software-Installationen angeht. Ist halt tot...
          sudo apt install nodejs=18.18.0-1nodesource1
          liefert?
            liefert?
            Esmax666
            ubuntu@ubuntu:~$ sudo apt install nodejs=18.18.0-1nodesource1
              nodejs
            1 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
            Need to get 0 B/26.8 MB of archives.
            After this operation, 91.4 MB of additional disk space will be used.
            (Reading database ... 116546 files and directories currently installed.)
            Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
            Detected old npm client, removing...
            Unpacking nodejs (18.18.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
            Setting up nodejs (18.18.0-1nodesource1) ...
            Processing triggers for man-db (2.9.4-2) ...
            Scanning processes...
            Scanning processor microcode...
            Scanning linux images...
            Running kernel seems to be up-to-date.
            Failed to check for processor microcode upgrades.
            No services need to be restarted.
            No containers need to be restarted.
            No user sessions are running outdated binaries.
            ubuntu@ubuntu:~$
            • E Esmax666
                nodejs
              ubuntu@ubuntu:~$
              @esmax666
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iob restart
                @esmax666
                cd /opt/iobroker
                iob restart
                Esmax666
                  nodejs
                ubuntu@ubuntu:~$ ^C
                ubuntu@ubuntu:~$ cd /opt/iobroker
                ubuntu@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                npm WARN old lockfile
                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                npm WARN old lockfile This is a one-time fix-up, please be patient...
                changed 1 package in 9m
                85 packages are looking for funding
                  run `npm fund` for details
                ubuntu@ubuntu:/opt/iobroker$ iob restart
                und nochmal diag
                Skript v.2023-06-20
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : armhf
                 13:34:12 up  1:43,  1 user,  load average: 0.99, 0.93, 1.00
                CPU threads: 4
                               Local time: Tue 2023-09-19 13:34:12 CEST
                           Universal time: Tue 2023-09-19 11:34:12 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                ubuntu
                /home/ubuntu
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.9G        184M        6.6G        3.0M        1.1G        7.6G
                Swap:            0B          0B          0B
                Total:         7.9G        184M        6.6G
                         7886 M total memory
                          184 M used memory
                          544 M active memory
                          464 M inactive memory
                         6595 M free memory
                          236 M buffer memory
                          870 M swap cache
                            0 M total swap
                            0 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /dev/sda2      ext4    57G  7.0G   48G  13% /
                /var:
                3.2G    /var/
                1.9G    /var/log
                1.2G    /var/lib
                /usr/bin/nodejs         v18.18.0
                /usr/bin/node           v18.18.0
                /usr/bin/npm            9.8.1
                /usr/bin/npx            9.8.1
                nodejs:
                  Installed: 18.18.0-1nodesource1
                  Version table:
                 *** 18.18.0-1nodesource1 1001
                ioBroker Status
                 Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                No connection to databases possible ...
                js-controller:  3.3.22
                admin:          5.2.1
                javascript:     5.2.13
                Adapters from github:   0
                Adapter State
                + instance is alive
                latest      : http://download.iobroker.net/sources-dist-latest.json
                stable      : http://download.iobroker.net/sources-dist.json
                Active repo: stable
                Used repository: stable
                hash changed or no sources cached => force download of new sources
                Cannot get any information of "_repoInfo". Ignored.
                update done
                 Cannot find view "system" for search "instance"
                Error: Cannot find view "system"
                    at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
                Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
                Adapter    "backitup"      : 2.6.23   , installed 2.2.2 [Updateable]
                Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
                Adapter    "discovery"     : 3.1.0    , installed 2.7.0 [Updateable]
                Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
                Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
                Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
                Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
                Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
                Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
                Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
                Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
                Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
                Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
                Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
                Adapter    "shuttercontrol": 1.6.1    , installed 1.2.1 [Updateable]
                Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
                Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
                Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
                Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
                Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
                Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
                Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
                Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
                Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
                Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
                Adapter    "zwave2"        : 3.0.5    , installed 2.4.1 [Updateable]
                Objects and States
                Objects:        11
                States:         21
                Pending Updates: 22
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287610     4905/iobroker.js-co
                tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        39620      1926/systemd-resolv
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38625      2046/sshd: /usr/sbi
                tcp6       0      0 :::22                   :::*                    LISTEN      0          38627      2046/sshd: /usr/sbi
                udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        39619      1926/systemd-resolv
                udp        0      0 192.168.178.51:68       0.0.0.0:*                           100        41269      1924/systemd-networ
                udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                100        40545      1924/systemd-networ
                2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "state"
                2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "instance"
                2023-09-19 13:35:02.368  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Error: Cannot find view "system"
                2023-09-19 13:35:02.369  - error: host.ubuntu _design/system missing - call node iobroker.js setup
                2023-09-19 13:35:02.369  - info: host.ubuntu no instances found
                2023-09-19 13:35:02.384  - error: host.ubuntu uncaught exception: doc.rows is not iterable
                2023-09-19 13:35:02.385  - error: host.ubuntu TypeError: doc.rows is not iterable
                    at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
                    at getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
                2023-09-19 13:35:02.395  - info: host.ubuntu iobroker _restart
                2023-09-19 13:35:02.443  - error: host.ubuntu Cannot write host object:Error: DB closed
                2023-09-19 13:35:02.705  - info: host.ubuntu terminated
                2023-09-19 13:35:03.353  - info: host.ubuntu iobroker Starting node restart.js
                2023-09-19 13:35:05.193  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                2023-09-19 13:35:05.199  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2023-09-19 13:35:05.200  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                2023-09-19 13:35:05.201  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                2023-09-19 13:35:05.343  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                2023-09-19 13:35:35.225  - error: host.ubuntu No connection to databases possible, restart
                2023-09-19 13:35:35.235  - info: host.ubuntu iobroker _restart
                2023-09-19 13:35:40.760  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
                2023-09-19 13:35:40.765  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2023-09-19 13:35:40.767  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
                2023-09-19 13:35:40.768  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
                2023-09-19 13:35:41.092  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
                iob diag has finished.
                Press any key for a summary
                • E Esmax666
                    nodejs
                  ubuntu@ubuntu:~$ ^C
                  und nochmal diag
                  Skript v.2023-06-20
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : armhf
                  CPU threads: 4
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  ubuntu
                  /home/ubuntu
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            0B          0B          0B
                           7886 M total memory
                            184 M used memory
                            544 M active memory
                           6595 M free memory
                            236 M buffer memory
                            870 M swap cache
                              0 M total swap
                              0 M used swap
                              0 M free swap
                  *** FILESYSTEM ***
                  /var:
                  3.2G    /var/
                  1.9G    /var/log
                  1.2G    /var/lib
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  ioBroker Status
                  admin:          5.2.1
                  javascript:     5.2.13
                  Adapter State
                  + instance is alive
                  Active repo: stable
                  update done
                  Objects and States
                  Objects:        11
                  States:         21
                  Pending Updates: 22
                  Steinalt. Wie der Rest von der Kiste halt auch...
                  Versuch es damit
                  iob update
                  iob upgrade all -y
                  iob stop
                  iob fix
                  iob upgrade self
                  iob restart
                  E OliverIOO 2 Antworten Letzte Antwort
                    Versuch es damit
                    iob update
                    iob upgrade all -y
                    iob stop
                    iob fix
                    iob upgrade self
                    iob restart
                    Esmax666
                    iob stop
                    ich bekomme schonn hier fehler
                    ubuntu@ubuntu:/opt/iobroker$ iob update
                    hash unchanged, use cached sources
                    update done
                        at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
                    ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
                      Versuch es damit
                      iob update
                      iob upgrade all -y
                      iob stop
                      iob fix
                      iob upgrade self
                      iob restart
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                      ich glaube mich dunkel daran zu erinnern, das man von so alten installationen nicht in einem rutsch auf aktuell aktualisieren kann.
                      ich musste damals erst auf die letzte 3er version mit npm install den js-controller aktualisieren und dann ging es wieder mit iob upgrade weiter.
                      das ist aber nicht sicher, wie gesagt kann mich nur dunkel daran erinnern.
                      auch das einspielen eines backups könnte von so alten versionen problematisch sein. aber da müssen sich hier noch andere dazu äußern
                      Meine Adapter und Widgets
                      Links im Profil
                      Thomas BraunT E 2 Antworten Letzte Antwort
                      • OliverIOO OliverIO
                        @oliverio
                        Ich hatte mich jetzt hieran orientiert:
                        Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt.
                        Eine zwingende Installation von Vorversionen lese ich da nicht heraus.
                          @oliverio
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          wenn es klappt, dann gut
                          ist gesichert, das sein Datenspeicher noch gut ist?
                          Nach Stromausfall zicken manchmal die SD-Cards rum
                          Links im Profil
                            @oliverio sagte in iobroker geht nicht nach stromausfall:
                            Offenbar klappt es nicht.
                            Da gab es aber auch schon mal was gegen. Ich hab nur gerade kein Heilmittel parat.
                              Ja, die fressen dann offene files...
                              Ist hier ja auch offenbar passiert.
                              • OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                                evtl ist die redis db kaputt
                                Links im Profil
                                  @oliverio
                                  Da hab ich überhaupt keine Aktien drin.
                                  Damals war glaube ich File/File der Standard?
                                    Esmax666
                                    @oliverio was soll dann genau machen ?
                                    • E Esmax666
                                      @esmax666
                                      Hast du redis verwendet?
                                      apt policy redis*
                                      sagt?
                                        @esmax666
                                        apt policy redis*
                                        sagt?
                                        Esmax666
                                        apt policy redis*
                                        ubuntu@ubuntu:/opt/iobroker$ apt policy redis*
                                        redis-server:
                                          Installed: (none)
                                          Candidate: 5:6.0.11-1
                                          Version table:
                                             5:6.0.11-1 500
                                        redis-redisearch-doc:
                                          Installed: (none)
                                          Candidate: 1:1.2.2-3
                                          Version table:
                                             1:1.2.2-3 500
                                        redis-sentinel:
                                          Installed: (none)
                                          Version table:
                                             5:6.0.11-1 500
                                        redis-tools:
                                          Installed: (none)
                                          Version table:
                                             5:6.0.11-1 500
                                        redis-redisearch:
                                          Installed: (none)
                                          Version table:
                                             1:1.2.2-3 500
                                        redis:
                                          Installed: (none)
                                          Version table:
                                             5:6.0.11-1 500
                                        redis:
                                          Installed: (none)
                                          Version table:
                                             5:6.0.11-1 500
                                        • E Esmax666
                                          apt policy redis*
                                          redis-server:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                            Installed: (none)
                                            Version table:
                                               1:1.2.2-3 500
                                          redis-sentinel:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          redis-tools:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          redis-redisearch:
                                            Installed: (none)
                                            Version table:
                                               1:1.2.2-3 500
                                          redis:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          redis:
                                            Installed: (none)
                                            Version table:
                                               5:6.0.11-1 500
                                          Demnach kann das nicht direkt über redis gelaufen sein. Sonst müsste da irgendwas aus der Ecke installiert sein.
                                          cd /opt/iobroker
                                          npm install iobroker.js-controller@4.0.24
                                          liefert?
