  4. iobroker geht nicht nach stromausfall
    5.1k
154 Beiträge 7 Kommentatoren 21.6k Aufrufe 5 Beobachtet
  • E Esmax666
    ubuntu@ubuntu:~$ sudo apt install nodejs=18.18.0-1nodesource1
    Reading package lists... Done
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 22 not upgraded.
    Need to get 0 B/26.8 MB of archives.
    After this operation, 91.4 MB of additional disk space will be used.
    (Reading database ... 116546 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_armhf.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.18.0-1nodesource1) over (12.22.7-deb-1nodesource1) ...
    Setting up nodejs (18.18.0-1nodesource1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Scanning processes...
    Scanning processor microcode...
    Scanning linux images...
    Running kernel seems to be up-to-date.
    Failed to check for processor microcode upgrades.
    No services need to be restarted.
    No containers need to be restarted.
    No user sessions are running outdated binaries.
    ubuntu@ubuntu:~$
    @esmax666
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    iob restart
    E 1 Antwort Letzte Antwort
      @esmax666
      cd /opt/iobroker
      iob restart
      Esmax666
        nodejs
      ubuntu@ubuntu:~$ ^C
      ubuntu@ubuntu:~$ cd /opt/iobroker
      ubuntu@ubuntu:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      changed 1 package in 9m
      85 packages are looking for funding
        run `npm fund` for details
      ubuntu@ubuntu:/opt/iobroker$ iob restart
      und nochmal diag
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: ubuntu
               Icon name: computer
              Machine ID: 551875df55414c0f832b43a896fe8ce5
                 Boot ID: a58fe4cd23274d7e86463c9c059dca8f
        Operating System: Ubuntu 21.04
                  Kernel: Linux 5.11.0-1027-raspi
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       13:34:12 up  1:43,  1 user,  load average: 0.99, 0.93, 1.00
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Tue 2023-09-19 13:34:12 CEST
                 Universal time: Tue 2023-09-19 11:34:12 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ubuntu
      /home/ubuntu
      ubuntu adm dialout cdrom floppy sudo audio dip video plugdev netdev lxd iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        184M        6.6G        3.0M        1.1G        7.6G
      Swap:            0B          0B          0B
      Total:         7.9G        184M        6.6G
               7886 M total memory
                184 M used memory
                544 M active memory
                464 M inactive memory
               6595 M free memory
                236 M buffer memory
                870 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      tmpfs          tmpfs  789M  4.0M  785M   1% /run
      /dev/sda2      ext4    57G  7.0G   48G  13% /
      tmpfs          tmpfs  3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs  4.0M     0  4.0M   0% /sys/fs/cgroup
      /dev/sda1      vfat   253M  120M  133M  48% /boot/firmware
      tmpfs          tmpfs  789M  4.0K  789M   1% /run/user/1000
      [Tue Sep 19 11:50:44 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm2708_fb.fbheight=0 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:1B:22:9D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash
      [Tue Sep 19 11:50:54 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Tue Sep 19 11:50:57 2023] EXT4-fs (sda2): re-mounted. Opts: discard,errors=remount-ro. Quota mode: none.
      TARGET              SOURCE     FSTYPE   OPTIONS
      /                   /dev/sda2  ext4     rw,relatime,discard,errors=remount-ro
      |-/snap/core18/2789 /dev/loop0 squashfs ro,nodev,relatime
      |-/snap/core20/1894 /dev/loop2 squashfs ro,nodev,relatime
      |-/snap/core18/2795 /dev/loop1 squashfs ro,nodev,relatime
      |-/snap/lxd/24921   /dev/loop3 squashfs ro,nodev,relatime
      |-/snap/snapd/19366 /dev/loop4 squashfs ro,nodev,relatime
      |-/snap/snapd/20101 /dev/loop7 squashfs ro,nodev,relatime
      |-/snap/core22/754  /dev/loop8 squashfs ro,nodev,relatime
      |-/snap/core22/868  /dev/loop5 squashfs ro,nodev,relatime
      |-/snap/lxd/25507   /dev/loop9 squashfs ro,nodev,relatime
      |-/snap/core20/2018 /dev/loop6 squashfs ro,nodev,relatime
      `-/boot/firmware    /dev/sda1  vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.2G    /var/
      1.9G    /var/log
      1.7G    /var/log/journal/551875df55414c0f832b43a896fe8ce5
      1.2G    /var/lib
      Archived and active journals take up 1.6G in the file system.
      /opt/iobroker/backups:
      54M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      149M    /opt/iobroker/iobroker-data/
      129M    /opt/iobroker/iobroker-data/files
      59M     /opt/iobroker/iobroker-data/files/javascript.admin
      44M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
      9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
      9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
      4.4M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
      4.4M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/2.934fa7ad.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.21.0~dfsg-3ubuntu1 500
              500 http://ports.ubuntu.com/ubuntu-ports hirsute/universe armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
       Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      No connection to databases possible ...
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    file on 127.0.0.1
      States:                     file on 127.0.0.1
      Core adapters versions
      js-controller:  3.3.22
      admin:          5.2.1
      javascript:     5.2.13
      Adapters from github:   0
      Adapter State
      + instance is alive
      ioBroker-Repositories
      latest      : http://download.iobroker.net/sources-dist-latest.json
      stable      : http://download.iobroker.net/sources-dist.json
      Active repo: stable
      Installed ioBroker-Instances
      Used repository: stable
      hash changed or no sources cached => force download of new sources
      Cannot get any information of "_repoInfo". Ignored.
      update done
       Cannot find view "system" for search "instance"
      Error: Cannot find view "system"
          at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Adapter    "admin"         : 6.10.1   , installed 5.2.1 [Updateable]
      Adapter    "alexa2"        : 3.25.2   , installed 3.9.3 [Updateable]
      Adapter    "backitup"      : 2.6.23   , installed 2.2.2 [Updateable]
      Adapter    "cloud"         : 4.4.1    , installed 4.1.0 [Updateable]
      Adapter    "discovery"     : 3.1.0    , installed 2.7.0 [Updateable]
      Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
      Adapter    "heatingcontrol": 2.11.1   , installed 2.7.2 [Updateable]
      Adapter    "history"       : 2.2.6    , installed 1.9.14 [Updateable]
      Adapter    "ical"          : 1.13.3   , installed 1.11.4 [Updateable]
      Adapter    "info"          : 1.9.26   , installed 1.9.8 [Updateable]
      Adapter    "iot"           : 1.14.5   , installed 1.8.22 [Updateable]
      Adapter    "javascript"    : 7.1.4    , installed 5.2.13 [Updateable]
      Controller "js-controller" : 5.0.12   , installed 3.3.22 [Updateable]
      Adapter    "linkeddevices" : 1.5.5    , installed 1.4.3 [Updateable]
      Adapter    "mobile"        : 1.0.1    , installed 1.0.1
      Adapter    "radar2"        : 2.0.7    , installed 2.0.3 [Updateable]
      Adapter    "rpi2"          : 1.3.2    , installed 1.3.1 [Updateable]
      Adapter    "shuttercontrol": 1.6.1    , installed 1.2.1 [Updateable]
      Adapter    "simple-api"    : 2.7.2    , installed 2.6.2 [Updateable]
      Adapter    "socketio"      : 6.5.5    , installed 3.1.4 [Updateable]
      Adapter    "telegram"      : 1.16.0   , installed 1.10.0 [Updateable]
      Adapter    "text2command"  : 3.0.2    , installed 2.1.1 [Updateable]
      Adapter    "tr-064"        : 4.2.18   , installed 4.2.14 [Updateable]
      Adapter    "vis"           : 1.4.16   , installed 1.4.5 [Updateable]
      Adapter    "vis-colorpicker": 2.0.3   , installed 1.2.0 [Updateable]
      Adapter    "vis-hqwidgets" : 1.4.0    , installed 1.1.7 [Updateable]
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-metro"     : 1.2.0    , installed 1.1.2 [Updateable]
      Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
      Adapter    "web"           : 6.1.2    , installed 3.4.9 [Updateable]
      Adapter    "zwave2"        : 3.0.5    , installed 2.4.1 [Updateable]
      Objects and States
      Objects:        11
      States:         21
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-updates Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-backports Release' no longer has a Release file.
      E: The repository 'http://ports.ubuntu.com/ubuntu-ports hirsute-security Release' no longer has a Release file.
      Pending Updates: 22
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287610     4905/iobroker.js-co
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        39620      1926/systemd-resolv
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38625      2046/sshd: /usr/sbi
      tcp6       0      0 :::22                   :::*                    LISTEN      0          38627      2046/sshd: /usr/sbi
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        39619      1926/systemd-resolv
      udp        0      0 192.168.178.51:68       0.0.0.0:*                           100        41269      1924/systemd-networ
      udp6       0      0 fe80::e65f:1ff:fe1b:546 :::*                                100        40545      1924/systemd-networ
      2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "state"
      2023-09-19 13:35:02.363  - error: host.ubuntu Cannot find view "system" for search "instance"
      2023-09-19 13:35:02.368  - error: host.ubuntu Could not collect system.host.ubuntu states to check for obsolete states: Error: Cannot find view "system"
      2023-09-19 13:35:02.369  - error: host.ubuntu _design/system missing - call node iobroker.js setup
      2023-09-19 13:35:02.369  - info: host.ubuntu no instances found
      2023-09-19 13:35:02.384  - error: host.ubuntu uncaught exception: doc.rows is not iterable
      2023-09-19 13:35:02.385  - error: host.ubuntu TypeError: doc.rows is not iterable
          at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
          at getInstances (/opt/iobroker/node_modules/iobroker.js-controller/main.js:2707:23)
      2023-09-19 13:35:02.395  - info: host.ubuntu iobroker _restart
      2023-09-19 13:35:02.443  - error: host.ubuntu Cannot write host object:Error: DB closed
      2023-09-19 13:35:02.705  - info: host.ubuntu terminated
      2023-09-19 13:35:03.353  - info: host.ubuntu iobroker Starting node restart.js
      2023-09-19 13:35:05.193  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
      2023-09-19 13:35:05.199  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2023-09-19 13:35:05.200  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
      2023-09-19 13:35:05.201  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
      2023-09-19 13:35:05.343  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
      2023-09-19 13:35:35.225  - error: host.ubuntu No connection to databases possible, restart
      2023-09-19 13:35:35.235  - info: host.ubuntu iobroker _restart
      2023-09-19 13:35:40.760  - info: host.ubuntu iobroker.js-controller version 3.3.22 js-controller starting
      2023-09-19 13:35:40.765  - info: host.ubuntu Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
      2023-09-19 13:35:40.767  - info: host.ubuntu hostname: ubuntu, node: v18.18.0
      2023-09-19 13:35:40.768  - info: host.ubuntu ip addresses: 192.168.178.51 2003:fa:736:b00:e65f:1ff:fe1b:229d fe80::e65f:1ff:fe1b:229d
      2023-09-19 13:35:41.092  - info: host.ubuntu-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
      iob diag has finished.
      Press any key for a summary
      • E Esmax666
          nodejs
        ubuntu@ubuntu:~$ ^C
        und nochmal diag
        Skript v.2023-06-20
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : armhf
        CPU threads: 4
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        ubuntu
        /home/ubuntu
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            0B          0B          0B
                 7886 M total memory
                  184 M used memory
                  544 M active memory
                 6595 M free memory
                  236 M buffer memory
                  870 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        3.2G    /var/
        1.9G    /var/log
        1.2G    /var/lib
        /usr/bin/npm            9.8.1
        /usr/bin/npx            9.8.1
        nodejs:
          Version table:
        ioBroker Status
        admin:          5.2.1
        javascript:     5.2.13
        Adapter State
        + instance is alive
        Active repo: stable
        update done
        Objects and States
        Objects:        11
        States:         21
        Pending Updates: 22
        @esmax666 sagte in iobroker geht nicht nach stromausfall:
        Steinalt. Wie der Rest von der Kiste halt auch...
        Versuch es damit
        iob update
        iob upgrade all -y
        iob stop
        iob fix
        iob upgrade self
        iob restart
        E OliverIOO 2 Antworten Letzte Antwort
          Versuch es damit
          iob update
          iob upgrade all -y
          iob stop
          iob fix
          iob upgrade self
          iob restart
          Esmax666
          @thomas-braun said in iobroker geht nicht nach stromausfall:
          iob stop
          ich bekomme schonn hier fehler
          ubuntu@ubuntu:/opt/iobroker$ iob update
          hash unchanged, use cached sources
          update done
              at ObjectsInMemoryServerClass._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:3313:59)
          ubuntu@ubuntu:/opt/iobroker$ iob upgrade all -y
            Versuch es damit
            iob update
            iob upgrade all -y
            iob stop
            iob fix
            iob upgrade self
            iob restart
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @thomas-braun sagte in iobroker geht nicht nach stromausfall:
            ich glaube mich dunkel daran zu erinnern, das man von so alten installationen nicht in einem rutsch auf aktuell aktualisieren kann.
            ich musste damals erst auf die letzte 3er version mit npm install den js-controller aktualisieren und dann ging es wieder mit iob upgrade weiter.
            das ist aber nicht sicher, wie gesagt kann mich nur dunkel daran erinnern.
            auch das einspielen eines backups könnte von so alten versionen problematisch sein. aber da müssen sich hier noch andere dazu äußern
            Meine Adapter und Widgets
            Links im Profil
            Thomas BraunT E 2 Antworten Letzte Antwort
            • OliverIOO OliverIO
              @oliverio
              Ich hatte mich jetzt hieran orientiert:
              Darüber hinaus ist der js-controller 5.0 generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1/2.2/3.x ist problemlos möglich. Wir empfehlen allerings vor dem Update auf die 5.0 idealerweise ein Update auf die 4.0 und vorher auf 3.3.x durchzuführen, da ein Downgrade nach einem erfolgten Update nur auf eine 3.3.x möglich ist (siehe FAQ)! Nur die Node.js Version muss weiterhin mindestens 16.x sein, wie oben bereits ausgeführt.
              Eine zwingende Installation von Vorversionen lese ich da nicht heraus.
                @oliverio
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                wenn es klappt, dann gut
                ist gesichert, das sein Datenspeicher noch gut ist?
                Nach Stromausfall zicken manchmal die SD-Cards rum
                Links im Profil
                  @oliverio sagte in iobroker geht nicht nach stromausfall:
                  Offenbar klappt es nicht.
                  Da gab es aber auch schon mal was gegen. Ich hab nur gerade kein Heilmittel parat.
                    Ja, die fressen dann offene files...
                    Ist hier ja auch offenbar passiert.
                    • OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      Die Fehlermeldung scheint auf redis hinzuweisen, das er da die system.* datenpunkte nicht findet.
                      evtl ist die redis db kaputt
                      Links im Profil
                        @oliverio
                        Da hab ich überhaupt keine Aktien drin.
                        Damals war glaube ich File/File der Standard?
                          Esmax666
                          @oliverio was soll dann genau machen ?
                          • E Esmax666
                            @esmax666
                            Hast du redis verwendet?
                            apt policy redis*
                            sagt?
                              @esmax666
                              apt policy redis*
                              sagt?
                              Esmax666
                              apt policy redis*
                              ubuntu@ubuntu:/opt/iobroker$ apt policy redis*
                              redis-server:
                                Installed: (none)
                                Candidate: 5:6.0.11-1
                                Version table:
                                   5:6.0.11-1 500
                              redis-redisearch-doc:
                                Installed: (none)
                                Candidate: 1:1.2.2-3
                                Version table:
                                   1:1.2.2-3 500
                              redis-sentinel:
                                Installed: (none)
                                Version table:
                                   5:6.0.11-1 500
                              redis-tools:
                                Installed: (none)
                                Version table:
                                   5:6.0.11-1 500
                              redis-redisearch:
                                Installed: (none)
                                Version table:
                                   1:1.2.2-3 500
                              redis:
                                Installed: (none)
                                Version table:
                                   5:6.0.11-1 500
                              redis:
                                Installed: (none)
                                Version table:
                                   5:6.0.11-1 500
                              • E Esmax666
                                apt policy redis*
                                redis-server:
                                  Installed: (none)
                                  Version table:
                                     5:6.0.11-1 500
                                  Installed: (none)
                                  Version table:
                                     1:1.2.2-3 500
                                redis-sentinel:
                                  Installed: (none)
                                  Version table:
                                     5:6.0.11-1 500
                                redis-tools:
                                  Installed: (none)
                                  Version table:
                                     5:6.0.11-1 500
                                redis-redisearch:
                                  Installed: (none)
                                  Version table:
                                     1:1.2.2-3 500
                                redis:
                                  Installed: (none)
                                  Version table:
                                     5:6.0.11-1 500
                                redis:
                                  Installed: (none)
                                  Version table:
                                     5:6.0.11-1 500
                                Demnach kann das nicht direkt über redis gelaufen sein. Sonst müsste da irgendwas aus der Ecke installiert sein.
                                cd /opt/iobroker
                                npm install iobroker.js-controller@4.0.24
                                liefert?
                                  cd /opt/iobroker
                                  liefert?
                                  Esmax666
                                  ubuntu@ubuntu:/opt/iobroker$ cd /opt/iobroker
                                  ubuntu@ubuntu:/opt/iobroker$ npm install iobroker.js-controller@4.0.24
                                  added 48 packages, removed 33 packages, and changed 52 packages in 1m
                                  86 packages are looking for funding
                                  ubuntu@ubuntu:/opt/iobroker$ ~^C
                                  redis-server:
                                    Installed: (none)
                                    Version table:
                                       5:6.0.11-1 500
                                    Installed: (none)
                                    Version table:
                                       1:1.2.2-3 500
                                  redis-sentinel:
                                    Installed: (none)
                                    Version table:
                                       5:6.0.11-1 500
                                  redis-tools:
                                    Installed: (none)
                                    Version table:
                                       5:6.0.11-1 500
                                  redis-redisearch:
                                    Installed: (none)
                                    Version table:
                                       1:1.2.2-3 500
                                  redis:
                                    Installed: (none)
                                    Version table:
                                       5:6.0.11-1 500
                                  • E Esmax666
                                    redis-server:
                                      Installed: (none)
                                      Version table:
                                         5:6.0.11-1 500
                                      Installed: (none)
                                      Version table:
                                         1:1.2.2-3 500
                                    redis-sentinel:
                                      Installed: (none)
                                      Version table:
                                         5:6.0.11-1 500
                                    redis-tools:
                                      Installed: (none)
                                      Version table:
                                         5:6.0.11-1 500
                                    redis-redisearch:
                                      Installed: (none)
                                      Version table:
                                         1:1.2.2-3 500
                                    redis:
                                      Installed: (none)
                                      Version table:
                                         5:6.0.11-1 500
                                    @esmax666
                                    iob restart
                                    ...etwas abwarten...
                                    iob status
                                      @esmax666
                                      iob restart
                                      iob status
                                      Esmax666
                                      iob status
                                      ubuntu@ubuntu:/opt/iobroker$ iob status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      • E Esmax666
                                        iob status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        @esmax666
                                        Okay, schaut schon besser aus.
                                        iob update
                                        iob upgrade all -y
                                          @esmax666
                                          iob update
                                          iob upgrade all -y
                                          Esmax666
                                          iob upgrade all -y
                                          ok läuft er braucht noch ein bisschen zeit 😧
