  4. js-controller 5.0.x jetzt für alle User im STABLE!
js-controllerstableupgrade
509 Beiträge 82 Kommentatoren 178.3k Aufrufe 65 Beobachtet
  • K Karacho
    habe das Problem, dass ich seit update auf JS-Controler 5.x nicht mehr auf
    • VIS Runtime (endlosSchleifen von 10 runterzählend)
    • Visualisierung (no connection)
    • Flot (no connection to server)
    --> WebSrerver neu isntalliert, aber
    Aktuelles Fehlerprotokoll
    web.0
    2023-09-18 16:08:10.435	error	Error: Cannot find module './controllerTools'Require stack:- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/index.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommon.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketAdmin.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/index.js- /opt/iobroker/node_modules/iobroker.socketio/lib/socketIO.js- /opt/iobroker/node_modules/iobroker.socketio/lib/socket.js- /opt/iobroker/node_modules/iobroker.web/main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) at Function.Module._load (node:internal/modules/cjs/loader:922:27) at Module.require (node:internal/modules/cjs/loader:1143:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/index.js:19:27) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Function.Module._load (node:internal/modules/cjs/loader:960:12) at Module.require (node:internal/modules/cjs/loader:1143:19)
    web.0
    2023-09-18 16:08:10.428	error	ERROR: Cannot find module './controllerTools'Require stack:- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/adapter-core/build/index.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommands.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketCommon.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/lib/socketAdmin.js- /opt/iobroker/node_modules/iobroker.socketio/node_modules/@iobroker/socket-classes/index.js- /opt/iobroker/node_modules/iobroker.socketio/lib/socketIO.js- /opt/iobroker/node_modules/iobroker.socketio/lib/socket.js- /opt/iobroker/node_modules/iobroker.web/main.js
    web.0
    2023-09-18 16:08:10.427	error	Initialization of integrated socket.io failed. Please reinstall the web adapter.
    iob diag summary
                         v.2023-06-20
       Static hostname: raspberrypi4-iob
             Icon name: computer
            Machine ID: 7520f6fd74454b99bf8a0c3666ca6ae6
               Boot ID: 17ed88c2e25541859b6bb26e1bc933f3
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    Kernel:                 armv7l
    Userland:               armhf
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/node           v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        1.4G        1.8G        8.0M        633M        2.3G
    Swap:           99M          0B         99M
    Total:         3.9G        1.4G        1.9G
    Active iob-Instances:   31
    ioBroker Core:          js-controller           5.0.12
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                15062
    States:                 13143
    Size of iob-Database:
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.migrated
    11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    12M     /opt/iobroker/iobroker-data/states.jsonl
    2.5M    /opt/iobroker/iobroker-data/states.json.migrated
    2.5M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #152
    @karacho warum jetzt hier weiter und nicht in Deinem eigenen Beitrag ? 🙄
    Lehrling seit 1975 !!!
    • G Offline
      garbleflux
      #153
      Seit dem Upgrade auf js 5.0.x funktioniert bei mir der Fritzbox-Adapter nicht mehr, bleibt beharrlich auf "rot", das heißt, es gibt keine Verbindung mit dem Host und kein Lebenszeichen. Adapter wurde gelöscht und neu installiert, keine Änderung. Die Fehlermöglichkeit für falsche Settings sind bei diesem Adapter ja ausschließlich auf die IP-Adresse der Fritzbox beschränkt. Einstellungen der FB (7490) mehrfach kontrolliert, auch hier neueste Version der FRITZ!OS 7.57 vom 08.09.23. Alle Adapter im System auf dem neuesten Stand, IOB ebenso aktuell. Hat jemand eine Idee zur Problemlösung?
      Darüber hinaus habe ich das Empfinden, dass das System (Intel NUC) jetzt mit einer CPU-Last von durchschnittlich 60 Prozent deutlich höher ausgelastet ist als vorher.
                           v.2023-06-20
       Static hostname: me-nuc
             Icon name: computer-desktop
               Chassis: desktop
            Machine ID: b9adafe7623d4472b96adc8d03b11f08
               Boot ID: 89d1e20e22294a089055806c3f94db54
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 6.2.0-32-generic
          Architecture: x86-64
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               true
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Mem:            7.7G        3.4G        1.1G         19M        3.2G        4.0G
      Swap:           2.0G        1.0M        2.0G
      Total:          9.8G        3.4G        3.2G
      Active repo(s): stable
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : me-nuc                                   -  enabled, compact disabled, port: 8081, bind: 192.168.160.121, run as: admin
      + system.adapter.web.0                    : web                   : me-nuc                                   -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                18076
      States:                 15181
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      6.3M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.3M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      6.3M    /opt/iobroker/iobroker-data/states.jsonl
      1.7M    /opt/iobroker/iobroker-data/states.json.migrated
      1.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      Danke vorab von
      Michael
      • G garbleflux
                             v.2023-06-20
                 Chassis: desktop
        Kernel:                 x86_64
        Userland:               amd64
        User-ID:                1000
        X-Server:               true
                                /usr/bin/npm            9.6.7
                                /usr/bin/npx            9.6.7
        MEMORY:
                                admin                   6.8.0
        Objects type: jsonl
        States  type: jsonl
        Objects:                18076
        States:                 15181
        Danke vorab von
        Michael
        #154
        @garbleflux sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
        Dann schmeiß den laufenden Desktop schon mal raus.
        Und was steht im LogFile zu dem Adapter? Bei einem kompletten Neustart des Adapters?
        G 1 Antwort Letzte Antwort
        • DJMarc75D DJMarc75
          Karacho
          #155
          @djmarc75
          • Die hier von mir beschriebenen Probleme bestehen seit update auf JS-controller 5.0
          • Die im anderen Thread behandelten Themen (u.a. Aktualität System) haben nix mit update js-controler zu tun, da aktuelles - Problem 100% identisch wie vor den Systemaktualisierungen im anderen Thread...
            garbleflux
            #156
            Verehrter Herr Braun! Hier das LogFile zum Adapter:
            host.me-nuc
            	2023-09-18 17:07:26.866	error	instance system.adapter.fritzbox.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: Node.js v18.17.1
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: }
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: ]
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.fritzbox/main.js'
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.fritzbox/lib/utils.js',
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: requireStack: [
            host.me-nuc
            	2023-09-18 17:07:26.865	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1143:19) {
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:960:12)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1119:32)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1256:14)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/lib/utils.js:46:25)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:121:18)
            host.me-nuc
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:922:27)
            host.me-nuc
            	2023-09-18 17:07:26.864	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.fritzbox/main.js
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.fritzbox/lib/utils.js
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: Require stack:
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: ^
            host.me-nuc
            	2023-09-18 17:07:26.863	error	Caught by controller[0]: throw err;
            host.me-nuc
            	2023-09-18 17:07:26.862	error	Caught by controller[0]: node:internal/modules/cjs/loader:1080
            host.me-nuc
            	2023-09-18 17:07:26.660	info	instance system.adapter.fritzbox.0 started with pid 45918
            Vorab danke für die Hilfestellung.
            VG Michael
            • K Karacho
              @djmarc75
              Karacho
              #157
              Problem bzgl Web-Server gelöst.... kann es aber nicht nachvollziehen warum es jetzt funktioniert...
              Web-Server neu installiert - gleiches Fehlerbild auch nach reboot... no connection etc.
              Dann den Port von 8082 auf einfach mal 8081 geändert. WebServer verliert Verbindung und keine Connection
              Wieder zurück auf 8082 und funktioniert alles...
              • G garbleflux
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                VG Michael
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #158
                @garbleflux said in js-controller 5.0.x jetzt für alle User im STABLE!:
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                host.me-nuc
                VG Michael
                Welche Version des Adapters (fritzbox) ist installiert?
                Bitte bei ALLEN Problmen IMMER die Versionen der beteiligten Adapter angeben...
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                • mcm1957M mcm1957
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  host.me-nuc
                  VG Michael
                  garbleflux
                  #159
                  @mcm57 Beim Adapter für die Fritzbox handelt es sich um die aktuell zur Verfügung stehende Version 0.2.1 - diese wurde auch regulär - also nicht über Github o.ä. - installiert.
                  VG Michael
                  • G garbleflux
                    VG Michael
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #160
                    VG Michael
                    Sorry, da haben wir im Repo was übersehen. Die AKTUELLE Version ist 0.5.0. Diese ist aber nur um LATEST / BETA Repository verfügbar.
                    Bitte installier die 0.5.0 vom beta / latest repository - wenn du dir das zutraust. Aber nicht vergessen nachher wieder auf stabel zurüpck zu schalten.
                    Alternativ warte bis morgen, ich veranlasse einen Update des stable Repositories.
                    • mcm1957M mcm1957
                      VG Michael
                      garbleflux
                      #161
                      @mcm57 sagte in js-controller 5.0.x jetzt für alle User im STABLE!:
                      Nach den zurückliegenden Frust-Tagen zur Fehlersuche und dessen Behebung kann ich jetzt auch noch die Füße still halten und warten, bis das Update zeitnah offiziell vorliegt.
                      Schon jetzt herzlichen Dank für die Bemühungen.
                      VG Michael
                      • G garbleflux
                        VG Michael
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        #162
                        @garbleflux
                        Sorry für Frust. Können wir sonst noch wo zur Fehlerbehebung beitragen?
                        Ansonsten gib bitte nur kurz Bescheid ob 0.5.0 tut was erwartet wird oder nicht.
                        • W Wildbill
                          Ich habe jetzt mal den Sonos-Adapter angehalten, die gesamten Datenpunkte gelöscht und dann manuell ein Backup mit Backitup gestartet. Das lief durch. Allerdings gab es auch wieder Hieroglyphen im Output, diesmal vom Sayit-Adapter und dessen mp3-Datenpunkt. Aber der zugewiesene Arbeitsspeicher hat wohl für das backup gereicht, es wurde eines erfolgreich erstellt.
                          Anscheinend besteht das Problem mit allen Datenpunkten, die in der Objektliste mit "type": "file" angelegt sind und bei denen sich dann beim Draufklicken eben ein Bild (cover_png bei Sonos) oder Soundfile (mp3 bei Sayit) direkt öffnen lassen.
                          Bei der vorherigen stable-Version vom js-controller bin ich ziemlich sicher, dass die Datenpunke da noch nicht so waren, dass sie sich beim Draufklicken öffnen ließen, oder?
                          Gruss, Jürgen
                          EDIT: @Duffy Hattest Du auch bei einem Deiner Lautsprecher mal was abgespielt, so dass der Datenpunkt cover_png auch etwas enthielt und nicht nur leer war?
                          DuffyD Online
                          DuffyD Online
                          Duffy
                          #163
                          @wildbill
                          Ich verwende gar kein Sonos ich habe es nur einmal installiert um zu schauen ob das Backup funktioniert wenn ich schon so einen Scheiß gebaut habe mit dem sonos und sonoff verwechseln.
                          Hatte gehofft es könne euch vielleicht weiter helfen.
                          LG Duffy
                          Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                          Node.js: v22.23.2
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
                          W 1 Antwort Letzte Antwort
                          • DuffyD Duffy
                            @wildbill
                            LG Duffy
                            W Online
                            W Online
                            Wildbill
                            schrieb am zuletzt editiert von Wildbill
                            #164
                            @duffy Dann liegt es daran, dass bei Dir eben kein Albumbild im Datenpunkt cover_png liegt, sondern der einfach leer ist. Sobald Du, wenn Du ein Sonos-Gerät hättest, was abspielst, landet dort das Albumcover. Von der Objektliste aus lässt es sich direkt durch Klicken auf [file] öffnen (öffnet sich dann im Browser). Und der Backitup-Adapter macht daraus eben 100e oder 1000e Zeilen mit Hieroglyphen, weshalb er wohl mit Speichermangel aussteigt.
                            Gruss, Jürgen
                            EDIT: Da es sowohl bei den besagten Datenpunkten beim Sayit (mp3 und ogg), als auch beim Sonos mit dem cover_png auftritt, überlege ich gerade, ob das dann nicht eher als issue beim Backitup-Adapter landen sollte? Die Funktionalität der beiden Adapter ist ja gegeben, die machen was sie sollen. Nur in Verbindung mit dem neuen js-controller gibt es nun ein Problem, aber anscheinend ja nur in Verbindung mit dem Backitup-Adapter. Oder übersehe ich da was?
                            • W Wildbill
                              Gruss, Jürgen
                              #165
                              @wildbill
                              Der Backitup Adapter benutzt die eingebaute backup Funktion von iobroker, also das gehört schon hierher.. denn diese ist im js-Controller
                              • mcm1957M mcm1957
                                @garbleflux
                                garbleflux
                                schrieb am zuletzt editiert von garbleflux
                                #166
                                @mcm57 Das mit dem Frust soll aber bitte kein Vorwurf an die Entwickler sein - IOB ist ja nicht lebensnotwendig. Doch wenn man das schon über Jahre nutzt, gibt's schon psychische und physische Abhängigkeiten. Da über den Fritzbox-Adapter bei mir u.a. eine Matrix-Laufschrift über den letzten Anruf gesteuert wird, steht mittlerweile auch meine Regierung wohlwollend den Aktivitäten des IOB-infizierten Mannes gegenüber. Somit dient das Ganze auch speziell dem WAF (Woman Akzeptanz Faktor) - deshalb wäre es fatal, bei der Chefin in Ungnade zu fallen. 😧
                                Spaß beiseite - sobald ich mit dem Adapter Neuigkeiten habe, melde ich mich. Und danke für die Aufmerksamkeit und Bemühungen, damit alles wieder wie gewohnt läuft.
                                VG Michael
                                • G garbleflux
                                  VG Michael
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #167
                                  @garbleflux
                                  Ich hab deine Meldung keineswegs als Kritik gesehen. Es ist nur meine (und wahrscheinlich die Einstellung von 99,9% aller Entwickler hier) möglichst wenig Äger / Enttäuschung / Frust bei Anwendern zu erzeugen. Ziel ist jedenfalls das ioBroker einfach läuft. Leider geht sich das mit den vrofügbaren Resourcen nicht immer aus.
                                  Daher auch an der Stelle: Wenn wer mitarbeiten will -er/sie ist sehr gern gesehen.
                                  • mcm1957M mcm1957
                                    @garbleflux
                                    garbleflux
                                    #168
                                    @garbleflux
                                    Nach dem Update auf Fritzbox 0.5.0 ist wieder alles im grünen Bereich - soweit ich das jetzt absehen kann funktioniert der Adapter ohne Fehlermeldung. Danke für die zeitnahe Lösung!!!
                                    Und mitarbeiten würde ich schon gerne, doch dafür fehlt mir schlichtweg das Wissen respektive das Können. Ich bin schon froh, dass ich die Komplexität des ioBrokers für meine Bedürfnisse einigermaßen hinbekomme.
                                    VG Michael
                                    • Siggi0904S Offline
                                      Siggi0904S Offline
                                      Siggi0904
                                      #169
                                      Habt ihr eigentlich bemerkt, oder ist es bekannt, dass alle Scripte gespeichert werden sollen,
                                      wenn man nur in das Fenster mit dem Blockly klickt?
                                      Scheinbar kommt das Thema vom js-Controller Update.
                                      Kann man das für alle Scripte automatisieren?
                                      Danke im Voraus.
                                      • ? Offline
                                        #170
                                        @siggi0904
                                        Nee, das kam mit nem JavaScript Update 7.x mal dazu…
                                        W Siggi0904S 2 Antworten Letzte Antwort
                                        • Siggi0904S Siggi0904
                                          Danke im Voraus.
                                          W Online
                                          W Online
                                          Wildbill
                                          #171
                                          @siggi0904 Ist mir auch schon aufgefallen. Einmal neu gespeichert passiert das aber bei dem jeweiligen Script dann nicht mehr.
                                          Naja, ich glaube nicht, dass ch mich jetzt durch alle Scripts klicke und einmal speichere…
                                          Sie funktionieren ja nach wie vor.
                                          Gruss, Jürgen
