  4. Adapter "smartmeter"
    6.7k
3.6k Beiträge 281 Kommentatoren 3.0m Aufrufe 162 Beobachtet
    @michihorn dann bitte ein debug-log vom Adapterstart und die Konfiguration
    M Online
    M Online
    michihorn
    schrieb am zuletzt editiert von michihorn
    #3451
    smartmeter.0
    2023-09-08 20:22:46.712	info	List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyUSB0","manufacturer":"FTDI","serialNumber":"D201033S","pnpId":"usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0","vendorId":"0403","productId":"6015"}]
    smartmeter.0
    2023-09-08 20:22:20.029	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:22:20.026	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:20:11.513	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:20:11.510	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:18:41.370	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:18:41.368	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:17:11.285	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:17:11.254	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:15:41.131	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:15:41.107	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:14:10.553	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:14:10.460	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:13:39.990	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
    smartmeter.0
    2023-09-08 20:12:43.158	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    smartmeter.0
    2023-09-08 20:12:43.146	error	smartmeter.0 already running
    smartmeter.0
    2023-09-08 20:11:13.717	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:11:13.296	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:09:42.368	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:09:42.342	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:08:12.042	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:08:12.019	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:06:41.896	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:06:41.890	info	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-09-08 20:06:11.738	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v18.17.1, js-controller: 4.0.24
    smartmeter.0
    2023-09-08 20:06:02.604	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    • M michihorn
      @thomas-braun Ich habe meine Hausaufgaben gemacht:
      cas@raspberrypi:~ $ find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
      ls -lAh /dev/serial/by-id
      apt policy udev
      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0
      insgesamt 0
      lrwxrwxrwx 1 root root 13  8. Sep 20:00 usb-FTDI_FT230X_Basic_UART_D201033S-if00-port0 -> ../../ttyUSB0
      udev:
        Installiert:           247.3-7+deb11u4
        Installationskandidat: 247.3-7+deb11u4
        Versionstabelle:
       *** 247.3-7+deb11u4 500
              500 http://deb.debian.org/debian bullseye-updates/main arm64 Packages
           247.3-7+deb11u2 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      cas@raspberrypi:~ $
      Leider verbindet sich der Adapter trotzdem nicht
      #3452
      @michihorn sagte in Adapter "smartmeter":
      Du hast gleich das Betriebssystem neuinstalliert?
      Ober warst du doch auf 32bit-armhf unterwegs und jetzt mit 64bit-arm64.
      Kommt da überhaupt ein Signal über die LED an?
      • M michihorn
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        smartmeter.0
        #3453
        @michihorn lass mal alle sonstigen Einstellungen auf default, insbes. keine signon message, das macht der Adapter schon selbst.
        sollte in etwa so aussehen
          M Online
          M Online
          michihorn
          #3454
          @thomas-braun ich hatte eh nur auf dieser installation den smartmeter-adapter und habe tatsächlich eine neue installation erstellt. Die LED am IR-Kopf blinkt unregelmäßig
            M Online
            M Online
            michihorn
            #3455
            @homoran Danke für den Screenshoot.
            Super Danke der Adapter liefert nun Daten, ich könnte Dich knutschen... Grins
            Kannst Du mir jetzt noch einen Screenshot der Objekte zeigen, damit ich sehe, was ankommen sollte ?
            • M michihorn
              #3456
              Das war nicht die dümmste Entscheidung.
              • M michihorn
                #3457
                jetzigen Konfiguration für die Nachwelt posten.
                was kommt denn bei dir?
                Dann kann man darauf aufbauen
                  M Online
                  M Online
                  michihorn
                  #3458
                  @thomas-braun die neue installation hat die selbe Hardware, damit auch die selbe IP. Leider mag Putty damit nicht umgehen
                  Haste nen Tip
                    M Online
                    M Online
                    michihorn
                    #3459
                    • M michihorn
                      Haste nen Tip
                      #3460
                      ssh freigeschaltet?
                      selber user?
                      selbes passwort? (default bei Installation geändert?)
                      • M michihorn
                        #3461
                        @michihorn dann hast du die PIN nicht drin und INF nicht auf ON
                        • M michihorn
                          Haste nen Tip
                          #3462
                          @michihorn
                          Ich mag mit puTTY auch nicht umgehen. ssh keys erneuert?
                            M Online
                            M Online
                            michihorn
                            #3463
                            @homoran sagte in Adapter "smartmeter":
                            PIN war definitiv drin und inf auf ON, kurze Zeit später war davon aber nichts mehr zu sehen
                              ssh freigeschaltet?
                              selber user?
                              M Online
                              M Online
                              michihorn
                              #3464
                              @homoran Ja SSH habe ich bewusst eingeschaltet
                              Habs gerade lösen können, ich habe per Konsole SSH aktiviert. Habe es nun per Externen Screen und UI-Desktop kontrolliert, da war SSH nicht aktiviert, aber jetzt geht auch Putty.
                              • M michihorn
                                #3465
                                dann hattest du es nicht bestätigt (langer Blink!)
                                und die anderen Parameter?
                                  M Online
                                  M Online
                                  michihorn
                                  #3466
                                  @homoran ich habe den PIN gerade nochmal eingegeben und nach fertigstellung lange geleuchtet, aktuell steht der Zähler auf On
                                  • M michihorn
                                    #3467
                                    und deine Objekte sehen jetzt wie aus?
                                      M Online
                                      M Online
                                      michihorn
                                      #3468
                                      Nur die Momentanlast ist nun neu...was sollte sonst noch zu sehen sein?
                                      • M michihorn
                                        #3469
                                        dass die anderen Werte jetzt Nachkommastellen haben!
                                        so muss es aussehen
                                          so muss es aussehen
                                          M Online
                                          M Online
                                          michihorn
                                          #3470
                                          so muss es aussehen
                                          hast du den anhang vergessen?
                                          HomoranH K 2 Antworten Letzte Antwort
