  4. Proxmox Container, Adapter grün, aber keine Datenpunkte
    3.2k
    3.1k
50 Beiträge 7 Kommentatoren 2.3k Aufrufe 6 Beobachtet
    @longbow sagte in Proxmox Container, Adapter grün, aber keine Datenpunkte:
    immer noch 4 anzeigt
    zeigen
    LongbowL Online
    LongbowL Online
    Longbow
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : lxc
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:46:58 up 36 min,  1 user,  load average: 4.08, 4.64, 4.98
    CPU threads: 4
    *** Time and Time Zones ***
                   Local time: Wed 2023-09-06 19:46:58 CEST
               Universal time: Wed 2023-09-06 17:46:58 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** User and Groups ***
    longbow
    /home/longbow
    longbow sudo iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             15G        4.9G         10G        0.0K        912M         11G
    Swap:           4.1G          0B        4.1G
    Total:           19G        4.9G         14G
            15894 M total memory
             4886 M used memory
              286 M active memory
             5278 M inactive memory
            10095 M free memory
                0 M buffer memory
              912 M swap cache
             4096 M total swap
                0 M used swap
             4096 M free swap
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--210--disk--0 ext4       49G  4.7G   42G  11% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
    tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs     3.2G  100K  3.2G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    dmesg: read kernel buffer failed: Operation not permitted
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
    /var:
    387M    /var/
    224M    /var/cache
    220M    /var/cache/apt
    153M    /var/cache/apt/archives
    136M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    158M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    818M    /opt/iobroker/iobroker-data/
    382M    /opt/iobroker/iobroker-data/files
    134M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    242M    /opt/iobroker/iobroker-data/states.jsonl
    60M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.67295ba8.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.8.0
    javascript:     7.0.3
    Adapters from github:   2
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
      system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
      system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
      system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
    + system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
    + system.adapter.eusec.0                  : eusec                 : iobroker-Final                           -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-Final                           -  enabled
      system.adapter.fb-checkpresence.1       : fb-checkpresence      : iobroker-Final                           - disabled
      system.adapter.feiertage.0              : feiertage             : iobroker-Final                           -  enabled
    + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
    + system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           -  enabled
    + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-Final                           -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           -  enabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
      system.adapter.klf200.0                 : klf200                : iobroker-Final                           -  enabled
      system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-Final                           -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : iobroker-Final                           - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
      system.adapter.net-tools.0              : net-tools             : iobroker-Final                           - disabled
    + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
    + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
    + system.adapter.nuki.0                   : nuki                  : iobroker-Final                           -  enabled
      system.adapter.onvif.0                  : onvif                 : iobroker-Final                           - disabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888,443,
      system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
      system.adapter.places.0                 : places                : iobroker-Final                           - disabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
      system.adapter.pushover.0               : pushover              : iobroker-Final                           - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker-Final                           -  enabled
    + system.adapter.robonect.0               : robonect              : iobroker-Final                           -  enabled
      system.adapter.samsung.0                : samsung               : iobroker-Final                           - disabled
      system.adapter.scenes.0                 : scenes                : iobroker-Final                           - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-Final                           - disabled
    + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
    + system.adapter.smartthings.0            : smartthings           : iobroker-Final                           -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker-Final                           -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
      system.adapter.statistics.0             : statistics            : iobroker-Final                           - disabled
    + system.adapter.synology.0               : synology              : iobroker-Final                           -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           -  enabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           -  enabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           -  enabled
      system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
      system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           - disabled
    + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
    + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 0.0.0.0
      system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.8.0    , installed 6.8.0
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "drag-indicator": 2.1.0   , installed 2.1.0
    Adapter    "eusec"        : 1.1.1    , installed 1.1.1
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "history"      : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hue"          : 3.9.5    , installed 3.9.5
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "klf200"       : 1.0.1    , installed 1.0.1
    Adapter    "lightcontrol" : 0.3.0    , installed 0.3.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.0.5    , installed 1.0.5
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "places"       : 1.1.2    , installed 1.1.2
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
    Adapter    "robonect"     : 0.1.4    , installed 0.1.0  [Updatable]
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
    Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
    Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
    Adapter    "socketio"     : 6.5.3    , installed 6.5.3
    Adapter    "sonos"        : 2.3.1    , installed 2.3.1
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "vw-connect"   : 0.0.67   , installed 0.1.2
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "web"          : 6.1.1    , installed 6.1.1
    Adapter    "wolf"         : 1.7.0    , installed 1.7.0
    Adapter    "wolf-smartset": 1.1.1    , installed 1.1.1
    Adapter    "ws"           : 2.5.4    , installed 2.5.4
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        56363
    States:         50962
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Get:4 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
    Fetched 4586 B in 1s (8272 B/s)
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       25541909   530/io.shelly.0
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1001       25547775   1639/go2rtc
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          25533864   1/init
    tcp        0      0 192.168.178.210:2001    0.0.0.0:*               LISTEN      1001       25543250   812/io.hm-rpc.1
    tcp        0      0 192.168.178.210:2010    0.0.0.0:*               LISTEN      1001       25537471   420/io.hm-rpc.0
    tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       25637858   2235/io.wolf.0
    tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        25534700   115/systemd-resolve
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        25534706   115/systemd-resolve
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          25533316   300/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25536514   127/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25533437   127/iobroker.js-con
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       25547768   1639/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       25547770   1639/go2rtc
    tcp6       0      0 :::22                   :::*                    LISTEN      0          25534604   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          25533866   1/init
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       25536116   379/io.sonos.0
    tcp6       0      0 :::5355                 :::*                    LISTEN      104        25534703   115/systemd-resolve
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25701505   2513/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       25536761   311/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          25533317   300/master
    udp        0      0 0.0.0.0:60484           0.0.0.0:*                           1001       25550593   1014/io.eusec.0
    udp        0      0 0.0.0.0:44999           0.0.0.0:*                           1001       25551210   1014/io.eusec.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       25541370   636/io.mihome-vacuu
    udp        0      0 192.168.178.210:5353    0.0.0.0:*                           1001       25541539   690/io.tr-064.0
    udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        25534699   115/systemd-resolve
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       25543701   715/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       25543702   715/io.tuya.0
    udp        0      0 0.0.0.0:56001           0.0.0.0:*                           1001       25551900   1014/io.eusec.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        25534705   115/systemd-resolve
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          25533865   1/init
    udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1001       25547771   1639/go2rtc
    udp6       0      0 :::5355                 :::*                                104        25534702   115/systemd-resolve
    udp6       0      0 :::111                  :::*                                0          25533867   1/init
    udp6       0      0 :::8443                 :::*                                1001       25547776   1639/go2rtc
    2023-09-06 19:47:25.893  - debug: wolf.0 (2235) Received Data from 192.168.178.24:55768: 0620f080001704000000f006009c0001009c0303132300
    2023-09-06 19:47:25.893  - debug: wolf.0 (2235) Acknowledge 0620f080001104000000f086009c000000
    2023-09-06 19:47:25.893  - debug: wolf.0 (2235) Data for cwl_t : 156
    2023-09-06 19:47:25.893  - debug: wolf.0 (2235) Set Value for cwl_t.156.Zeitweise Intensivlüftung Startzeit: Wed, 06 Sep 2023 17:35:00 GMT
    2023-09-06 19:47:26.052  - debug: wolf.0 (2235) Received Data from 192.168.178.24:55768: 0620f080001704000000f006009d0001009d0303162300
    2023-09-06 19:47:26.052  - debug: wolf.0 (2235) Acknowledge 0620f080001104000000f086009d000000
    2023-09-06 19:47:26.052  - debug: wolf.0 (2235) Data for cwl_t : 157
    2023-09-06 19:47:26.052  - debug: wolf.0 (2235) Set Value for cwl_t.157.Zeitweise Intensivlüftung Endzeit: Wed, 06 Sep 2023 20:35:00 GMT
    2023-09-06 19:47:27.182  - silly: wolf.0 (2235) States user redis pmessage wolf.0.*/wolf.0.cwl_t.156:{"val":"Wed, 06 Sep 2023 17:35:00 GMT","ack":true,"ts":1694022447145,"q":0,"from":"system.adapter.wolf.0","user":"system.user.admin","lc":1694022447145}
    2023-09-06 19:47:27.184  - silly: wolf.0 (2235) States user redis pmessage wolf.0.*/wolf.0.cwl_t.157:{"val":"Wed, 06 Sep 2023 20:35:00 GMT","ack":true,"ts":1694022447145,"q":0,"from":"system.adapter.wolf.0","user":"system.user.admin","lc":1694022447145}
    2023-09-06 19:47:29.680  - debug: wolf.0 (2235) Received Data from 192.168.178.24:55768: 0620f080001704000000f00600a1000100a10303132300
    2023-09-06 19:47:29.680  - debug: wolf.0 (2235) Acknowledge 0620f080001104000000f08600a1000000
    2023-09-06 19:47:29.680  - debug: wolf.0 (2235) Data for cwl_t : 161
    2023-09-06 19:47:29.680  - debug: wolf.0 (2235) Set Value for cwl_t.161.Zeitweiser Feuchteschutz Startzeit: Wed, 06 Sep 2023 17:35:00 GMT
    2023-09-06 19:47:29.684  - silly: wolf.0 (2235) States user redis pmessage wolf.0.*/wolf.0.cwl_t.161:{"val":"Wed, 06 Sep 2023 17:35:00 GMT","ack":true,"ts":1694022449683,"q":0,"from":"system.adapter.wolf.0","user":"system.user.admin","lc":1694022449683}
    2023-09-06 19:47:31.383  - debug: wolf.0 (2235) Received Data from 192.168.178.24:55768: 0620f080001704000000f00600a2000100a20303162300
    2023-09-06 19:47:31.383  - debug: wolf.0 (2235) Acknowledge 0620f080001104000000f08600a2000000
    2023-09-06 19:47:31.384  - debug: wolf.0 (2235) Data for cwl_t : 162
    2023-09-06 19:47:31.384  - debug: wolf.0 (2235) Set Value for cwl_t.162.Zeitweiser Feuchteschutz Endzeit: Wed, 06 Sep 2023 20:35:00 GMT
    2023-09-06 19:47:32.937  - silly: wolf.0 (2235) States user redis pmessage wolf.0.*/wolf.0.cwl_t.162:{"val":"Wed, 06 Sep 2023 20:35:00 GMT","ack":true,"ts":1694022452821,"q":0,"from":"system.adapter.wolf.0","user":"system.user.admin","lc":1694022452821}
    2023-09-06 19:47:34.985  - debug: wolf.0 (2235) Received Data from 192.168.178.24:55768: 0620f080001804000000f00600a6000100a603040011b340
    2023-09-06 19:47:34.986  - debug: wolf.0 (2235) Acknowledge 0620f080001104000000f08600a6000000
    2023-09-06 19:47:34.986  - debug: wolf.0 (2235) Data for cwl_t : 166
    2023-09-06 19:47:34.986  - debug: wolf.0 (2235) Set Value for cwl_t.166.Luftdurchsatz Zuluft: 116
    2023-09-06 19:47:34.988  - silly: wolf.0 (2235) States user redis pmessage wolf.0.*/wolf.0.cwl_t.166:{"val":116,"ack":true,"ts":1694022454987,"q":0,"from":"system.adapter.wolf.0","user":"system.user.admin","lc":1694022454987}
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.15.30-2-pve
    Installation:           lxc
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     4
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:             15G        4.9G         10G        0.0K        914M         10G
    Swap:           4.1G          0B        4.1G
    Total:           19G        4.9G         14G
    Active iob-Instances:   42
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.8.0
    Objects type: jsonl
    States  type: jsonl
    Objects:                56363
    States:                 50962
    Size of iob-Database:
    245M    /opt/iobroker/iobroker-data/states.jsonl
    • LongbowL Longbow
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      longbow
      /home/longbow
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           4.1G          0B        4.1G
      Total:           19G        4.9G         14G
               4886 M used memory
                286 M active memory
              10095 M free memory
                  0 M buffer memory
                912 M swap cache
               4096 M total swap
                  0 M used swap
               4096 M free swap
      *** FILESYSTEM ***
      /var:
      387M    /var/
      224M    /var/cache
      220M    /var/cache/apt
      136M    /var/lib
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.8.0
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        56363
      States:         50962
      Pending Updates: 4
                           v.2023-04-16
      Installation:           lxc
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
      Swap:           4.1G          0B        4.1G
      Total:           19G        4.9G         14G
                              admin                   6.8.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                56363
      States:                 50962
      HomoranH Offline
      HomoranH Offline
      Pending Updates: 4
      bezieht sich auf
      sudo apt update && sudo apt upgrade
      • LongbowL Longbow
        @homoran updates vom irobroker sind durch... Betriebssystem auch, aber es werden immer noch 4 anzeigt... komish..
        Kein Plan wie ich proxmox so update kann
        crunchipC Offline
        crunchipC Offline
        nicht proxmox, deinen LXC
        dein Proxmox-Host selbst, per Gui
        und das Loglevel vom wolf hast du immer noch nicht geändert
        LongbowL 1 Antwort Letzte Antwort
          LongbowL Online
          LongbowL Online
          Longbow
          @crunchip Danke, da hatte ich ein Denkfehler drin... aber der Adapter hatte ich auf diese Version, weil ich dachte mit einer ältern Version klappt das vielleicht, was aber auch nicht klappt
          • LongbowL Longbow
            LongbowL Online
            LongbowL Online
            Longbow
            schrieb am zuletzt editiert von Longbow
            @crunchip umgestellt von Wolf.
            Kann es an Ubuntu und Debian zusammenhängen?
            Denn der Adapter in einem anderen Iobroker LXC läuft ja, der einzige Unterschied das Image / Betriebsystem
            crunchipC LongbowL 2 Antworten Letzte Antwort
            • LongbowL Longbow
              crunchipC Offline
              crunchipC Offline
              der Adapter
              welcher Adapter?
              laut log seh ich nur
              info: tuya.0 (715) bf0113460f08310ff3gn19: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.133:6668
              • LongbowL Longbow
                LongbowL Online
                LongbowL Online
                Longbow
                @crunchip
                robonect.0
                6428 2023-09-06 20:17:48.197 error No connection to lawn mower. Check network connection.
                • crunchipC Offline
                  crunchipC Offline
                  @longbow ip Adresse passt?
                  Daten nochmal neu eingetragen und Instanz neu gestartet?
                    LongbowL Online
                    LongbowL Online
                    Longbow
                    @crunchip ja, mehrmals schon. Wenn ich den Button weiterleiten auf das Web-Interface klicke, komme ich genau dort hin, wo der Adapter die Daten abgreifen soll und muss.
                    • LongbowL Longbow
                      crunchipC Offline
                      crunchipC Offline
                      @longbow dann gibts vllt nur Probleme zur api/Server und ist temporär
                        LongbowL Online
                        LongbowL Online
                        Longbow
                        @crunchip Na in meinem alten iobroker auf dem gleichem System, nur in einem anderen LXC läuft der ohne Fehler. Muss nur einen neuen iobroker nehmen, aufbauen, der der alte ständig überlastet ist
                        • LongbowL Online
                          LongbowL Online
                          Longbow
                          Also Fehler bleibt weiterhin, also kein temporär Fehler.
                          Komisch, das der auf dem anderen LXC ohne Probleme läuft, aber auf dem neuen nicht.
                          Komme ja auch über den Weiterleiten Button auf das Interface, somit stimmen die Daten, die ich in den Adapter eingebe.
                          Wer kann mir helfen?
                          • LongbowL Longbow
                            Moin,
                            ich verstehe diesen Satz nicht, was bedeutet überlastet? Du kannst doch, so noch Ressourcen vorhanden, auf dem Proxmox Host, dem LXC Container mehr Ressourcen geben, sowohl CPU als auch Memory und Plattenplatz. Was glaubst Du, mit einem neuen LXC Container besser hinzukriegen?
                            Bernd
                              Moin,
                              Bernd
                              LongbowL Online
                              LongbowL Online
                              Longbow
                              @dp20eic einen frischen und sauberen LXC, da ich einige Fehler gemacht mit Installationen.
                              • LongbowL Longbow
                                Moin,
                                irgendwie sind die Informationen geheim, so kann man Dir nicht helfen, wenn man alles aus der Nase ziehen muss.
                                Schreib doch mal zusammen, was hast Du wie gemacht und das ganze dann auch mit Log Files oder Konfigurationsfiles belegen.
                                Welche angeblichen Fehler hast Du beim ersten LXC gemacht und was willst Du im neuen besser machen?
                                Aber am wichtigsten, wie sieht die Konfiguration vom alten aus und wie die vom neuen?
                                Bernd
                                  Moin,
                                  Bernd
                                  LongbowL Online
                                  LongbowL Online
                                  Longbow
                                  @dp20eic
                                  Du es ist nichts geheim, nur habe ich dort einiges Installiert und dann kam Fehler.
                                  Der LXC wurde immer langsamer, daher habe ich den Rat bekommen, das ich einen neuen machen soll und dann kein Backup einspielen soll. Das habe ich gemacht, es lauft auch alles super flüssig wie ich es kenne. Aber halt nur den Adapter.
                                  Wenn Du mir vielleicht noch sagt, was ich wie bereit stellen kann, mach ich es gern.
                                  Möchte das dies ja geht...
                                  HomoranH ? 2 Antworten Letzte Antwort
                                  • LongbowL Longbow
                                    @dp20eic
                                    HomoranH Offline
                                    HomoranH Offline
                                    heisst im klartext was genau?
                                    ist nichts geheim
                                    dann sag's doch
                                    • crunchipC Offline
                                      crunchipC Offline
                                      kein backup?
                                      wer oder woher kommen denn solche Ratschläge?
                                      alles was du gemacht hast, log Ausgaben, was nicht funktioniert, Daten Daten Daten
                                      • LongbowL Longbow
                                        hallo,
                                        es geht gerade nur noch um den Robonect Adapter.
                                        Die anderen gingen auf einmal, nachdem ich diese mehrmals gestartet habe.
                                        Hier aber mal die Daten:
                                        Ping Ok
                                        64 bytes from 192.168.178.8: icmp_seq=1 ttl=128 time=67.4 ms
                                        64 bytes from 192.168.178.8: icmp_seq=2 ttl=128 time=6.14 ms
                                        64 bytes from 192.168.178.8: icmp_seq=3 ttl=128 time=5.55 ms
                                        64 bytes from 192.168.178.8: icmp_seq=4 ttl=128 time=4.69 ms
                                        64 bytes from 192.168.178.8: icmp_seq=5 ttl=128 time=5.26 ms
                                        64 bytes from 192.168.178.8: icmp_seq=6 ttl=128 time=3.49 ms
                                        64 bytes from 192.168.178.8: icmp_seq=7 ttl=128 time=12.6 ms
                                        64 bytes from 192.168.178.8: icmp_seq=8 ttl=128 time=13.3 ms
                                        64 bytes from 192.168.178.8: icmp_seq=9 ttl=128 time=4.73 ms
                                        Protokoll ioborker
                                        robonect.0
                                        10051	2023-09-06 19:08:44.110	error	No connection to lawn mower. Check network connection.
                                        robonect.0
                                        10051	2023-09-06 19:07:44.106	error	No connection to lawn mower. Check network connection.
                                        robonect.0
                                        10051	2023-09-06 19:06:44.092	error	No connection to lawn mower. Check network connection.
                                        robonect.0
                                        10051	2023-09-06 19:05:44.088	error	No connection to lawn mower. Check network connection.
                                        robonect.0
                                        10051	2023-09-06 19:05:44.085	info	Done
                                        robonect.0
                                        10051	2023-09-06 19:05:41.996	info	Rest period 2 not configured. Period will be ignored.
                                        robonect.0
                                        10051	2023-09-06 19:05:41.996	info	Rest period 1 not configured. Period will be ignored.
                                        robonect.0
                                        10051	2023-09-06 19:05:41.968	info	starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.robonect, node: v18.17.1, js-controller: 4.0.24
                                        robonect.0
                                        10015	2023-09-06 19:05:37.033	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        robonect.0
                                        10015	2023-09-06 19:05:37.033	info	terminating
                                        robonect.0
                                        10015	2023-09-06 19:05:37.033	info	cleaned everything up...
                                        robonect.0
                                        10015	2023-09-06 19:05:37.032	info	Got terminate signal TERMINATE_YOURSELF
                                        iobroker iob diag
                                        Skript v.2023-04-16
                                        *** BASE SYSTEM ***
                                        Docker          : false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=debian
                                         19:11:37 up 1 min,  1 user,  load average: 5.90, 4.51, 3.98
                                        CPU threads: 4
                                                       Local time: Wed 2023-09-06 19:11:37 CEST
                                                   Universal time: Wed 2023-09-06 17:11:37 UTC
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        longbow
                                        /home/longbow
                                        X-Server:       false
                                        Desktop:
                                        Terminal:
                                        *** MEMORY ***
                                        Mem:             15G        2.2G         13G        0.0K        366M         13G
                                        Swap:           4.1G          0B        4.1G
                                        Total:           19G        2.2G         17G
                                                 2197 M used memory
                                                   58 M active memory
                                                 2424 M inactive memory
                                                13329 M free memory
                                                    0 M buffer memory
                                                  366 M swap cache
                                                 4096 M total swap
                                                    0 M used swap
                                                 4096 M free swap
                                        *** FILESYSTEM ***
                                        /dev/mapper/pve-vm--210--disk--0 ext4       49G  4.6G   42G  10% /
                                        /var:
                                        387M    /var/
                                        224M    /var/cache
                                        220M    /var/cache/apt
                                        136M    /var/lib
                                        699M    /opt/iobroker/iobroker-data/
                                        130M    /opt/iobroker/iobroker-data/states.jsonl
                                        53M     /opt/iobroker/iobroker-data/objects.jsonl
                                        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.e564fb87.js.map
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.8.0
                                        javascript:     7.0.3
                                        Adapter State
                                        + system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
                                        + system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
                                        + instance is alive
                                        Adapter    "robonect"     : 0.1.4    , installed 0.1.4
                                        Adapter    "socketio"     : 6.5.3    , installed 6.5.2  [Updatable]
                                        Adapter    "web"          : 6.1.1    , installed 6.1.0  [Updatable]
                                        Adapter    "ws"           : 2.5.4    , installed 2.5.3  [Updatable]
                                        Objects and States
                                        Objects:        56323
                                        States:         50923
                                        Fetched 4586 B in 1s (3182 B/s)
                                        Pending Updates: 4
                                        tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       25545059   827/io.wolf.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25545251   903/io.web.0
                                        udp        0    768 0.0.0.0:56001           0.0.0.0:*                           1001       25551900   1014/io.eusec.0
                                        2023-09-06 19:12:44.616  - debug: wolf.0 (827) Set Value for cwl_t.151.Zeitprogramm 2: Off
                                        2023-09-06 19:12:44.617  - debug: wolf.0 (827) Received Data from 192.168.178.24:65400: 0620f080001504000000f006009800010098030100
                                        2023-09-06 19:12:44.617  - debug: wolf.0 (827) Acknowledge 0620f080001104000000f0860098000000
                                        2023-09-06 19:12:44.617  - debug: wolf.0 (827) Data for cwl_t : 152
                                        2023-09-06 19:12:44.617  - debug: wolf.0 (827) Set Value for cwl_t.152.Zeitprogramm 3: Off
                                        2023-09-06 19:12:44.763  - debug: wolf.0 (827) Received Data from 192.168.178.24:65400: 0620f080001504000000f006009900010099030100
                                        2023-09-06 19:12:44.764  - debug: wolf.0 (827) Acknowledge 0620f080001104000000f0860099000000
                                        2023-09-06 19:12:44.764  - debug: wolf.0 (827) Data for cwl_t : 153
                                        2023-09-06 19:12:44.764  - debug: wolf.0 (827) Set Value for cwl_t.153.Zeitweise Intensivlüftung AN/AUS: Off
                                        2023-09-06 19:12:44.925  - debug: wolf.0 (827) Received Data from 192.168.178.24:65400: 0620f080001704000000f006009a0001009a0303060917
                                        2023-09-06 19:12:44.925  - debug: wolf.0 (827) Acknowledge 0620f080001104000000f086009a000000
                                        2023-09-06 19:12:44.925  - debug: wolf.0 (827) Data for cwl_t : 154
                                        2023-09-06 19:12:44.925  - debug: wolf.0 (827) Set Value for cwl_t.154.Zeitweise Intensivlüftung Startdatum: Tue, 05 Sep 2023 22:00:00 GMT
                                        2023-09-06 19:12:45.092  - info: tuya.0 (715) bf0113460f08310ff3gn19: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.133:6668
                                        2023-09-06 19:12:46.371  - debug: wolf.0 (827) Received Data from 192.168.178.24:65400: 0620f080001704000000f006009b0001009b0303060917
                                        2023-09-06 19:12:46.371  - debug: wolf.0 (827) Acknowledge 0620f080001104000000f086009b000000
                                        2023-09-06 19:12:46.372  - debug: wolf.0 (827) Data for cwl_t : 155
                                        2023-09-06 19:12:46.372  - debug: wolf.0 (827) Set Value for cwl_t.155.Zeitweise Intensivlüftung Enddatum: Tue, 05 Sep 2023 22:00:00 GMT
                                        2023-09-06 19:12:46.515  - debug: wolf.0 (827) Received Data from 192.168.178.24:65400: 0620f080001704000000f006009c0001009c0303130100
                                        2023-09-06 19:12:46.520  - debug: wolf.0 (827) Acknowledge 0620f080001104000000f086009c000000
                                        2023-09-06 19:12:46.521  - debug: wolf.0 (827) Data for cwl_t : 156
                                        2023-09-06 19:12:46.521  - debug: wolf.0 (827) Set Value for cwl_t.156.Zeitweise Intensivlüftung Startzeit: Wed, 06 Sep 2023 17:01:00 GMT
                                        2023-09-06 19:12:47.074  - info: iot.0 (1021) Connection changed: connect
                                        2023-09-06 19:12:47.171  - info: eusec.0 (1014) Connected to station T8030P2322400776 on host 91.19.174.90 and port 21028
                                        2023-09-06 19:12:47.216  - info: ical.0 (458) processing URL: wechdamit!
                                                             v.2023-04-16
                                        Installation:           lxc
                                        User-ID:                1000
                                        X-Server:               false
                                        Pending iob updates:    3
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
                                        MEMORY:
                                        Mem:             15G        5.4G        9.8G        0.0K        688M         10G
                                        Swap:           4.1G          0B        4.1G
                                        Total:           19G        5.4G         13G
                                        Active iob-Instances:   38
        admin                   6.8.0
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                56323
                                        States:                 50923
                                        56M     /opt/iobroker/iobroker-data/objects.jsonl
                                        165M    /opt/iobroker/iobroker-data/states.jsonl
                                        MOD-EDIT: persönliche Daten entfernt!
                                        crunchipC Offline
                                        crunchipC Offline
                                        Mem: 15G
                                        mal generelle Fragen
                                        • auf was für einen Rechner läuft denn da Proxmox?
                                        • wieviel Ram ist da verbaut?
                                        • wieviele VM und LXC laufen da gleichzeitig in Proxmox
                                        • LongbowL Longbow
                                          @dp20eic
                                          Moin,
                                          wer gibt denn so einen Rat, man schaut erst was ist aktuell im Argen, dann räumt man auf und erfreut sich an einem laufenden System, ist ja nicht wie bei KleinWeich wo man neu installiert nur, weil mal was nicht funktioniert.
                                          Nur mal so, ich habe seit gut 5 Jahren kein neues System aufgesetzt, ich bin nur durch Updates und Migration zu neuen Versionen gesprungen, wobei ich erwähnen muss, dass ich seit 5 Jahren eine Rolling Release Distribution Arch Linux einsetze.
                                          In Proxmox Host, gibt es ein Verzeichnis, in dem die Konfigurationen gespeichert werden, da kannst Du die beiden Container mal vergleichen, ob Du da schon Unterschiede eingebaut hast
                                          root@pve:~# ls -la /etc/pve/lxc/
                                          total 6
                                          drwxr-xr-x 2 root www-data    0 Sep 11  2020 .
                                          drwxr-xr-x 2 root www-data    0 Sep 11  2020 ..
                                          -rw-r----- 1 root www-data  701 Sep 12 22:10 100000.conf
                                          -rw-r----- 1 root www-data 1280 Sep 12 22:01 100.conf
                                          -rw-r----- 1 root www-data  635 Sep 12 22:02 101.conf
                                          -rw-r----- 1 root www-data  235 Sep 12 22:02 104.conf
                                          -rw-r----- 1 root www-data  708 Sep 12 22:03 200.conf
                                          -rw-r----- 1 root www-data  277 Sep 12 22:04 201.conf
                                          -rw-r----- 1 root www-data  295 Sep 12 22:05 202.conf
                                          -rw-r----- 1 root www-data  279 Sep 12 22:06 403.conf
                                          -rw-r----- 1 root www-data  666 Sep 12 22:06 404.conf
                                          -rw-r----- 1 root www-data  307 Sep 13 14:44 501.conf
                                          -rw-r----- 1 root www-data  676 Sep 12 22:10 604.conf
                                          Dann kann man mit vimdiff sich die Unterschiede anschauen.
                                          vimdiff /etc/pve/lxc/100.conf /etc/pve/lxc/101.conf
                                          Bernd
