  4. iob node fix - Skript
198 Beiträge 34 Kommentatoren 73.4k Aufrufe 37 Beobachtet
    Bei dem Slave komme ich von der nodejs@20 mit dem Skript nicht mehr weg.
    ioBroker nodejs fixer 2023-09-05
    Recommended nodejs-version is: No connection to databases possible ...
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v20.5.1
    /usr/bin/node           v20.5.1
    /usr/bin/npm            9.8.0
    /usr/bin/npx            9.8.0
    /usr/bin/corepack       0.19.0
    I found these versions available for installation:
    nodejs:
      Installed: 20.5.1-deb-1nodesource1
      Candidate: 20.5.1-deb-1nodesource1
      Version table:
     *** 20.5.1-deb-1nodesource1 100
         18.17.1-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
    Nothing to do, your installation is using the correct paths.
    !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
    You are running nodejs v20.5.1. Do you want to install recommended nodejs No connection to databases possible ...?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    yrm: cannot remove '': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists... Done
    ca-certificates is already the newest version (20210119).
    curl is already the newest version (7.74.0-1.3+deb11u7).
    gnupg is already the newest version (2.2.27-2+deb11u2).
    0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
    Creating new /etc/apt/sources.list.d/nodesource.list file with this content:
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
    Fetched 17.3 kB in 1s (17.6 kB/s)
    E: Version 'No connection to databases possible ...-1nodesource1' for 'nodejs' was not found
    Reinstallation of nodejs is not possible, it cannot be downloaded.
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    thomas@rpizigbee:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
    thomas@rpizigbee:~ $ nodejs -v
    v20.5.1
    @meister-mopper sagte in iob node fix - Skript:
    Versuch es jetzt nochmal.
      Meister MopperM Online
      Meister Mopper
      @thomas-braun sagte in iob node fix - Skript:
      thomas@rpizigbee:~ $ ./iob_node_update
      ioBroker node-update v2023-09-05 is starting. Please be patient!
      The state system.host.rpizigbee.versions.nodeNewestNext was not found!
      ./iob_node_update: Zeile 11: Syntaxfehler beim unerwarteten Symbol »;«
      ./iob_node_update: Zeile 11: `then;'
      Proxmox und HA ...
        @meister-mopper
        Un nu?
          @meister-mopper
          Hmmmm. Hat also nicht wie gedacht funktioniert. Dann muss ich da später mal genauer schauen. Die Syntax von 'find' ist auch in Skripten nicht die einfachste...
          F Online
          F Online
          fastfoot
          find / \( -path /proc -o -path /dev -o -path /sys -o -path /some_other_path \) -prune -o -name nodesource.[gk]* -print
            @meister-mopper
            Un nu?
            Meister Mopper
            Un nu?
            Nö!
            Could not detect recommended nodejs-version. Setting up the nodejs 18 tree now.
            /usr/bin/npm            9.8.0
            /usr/bin/npx            9.8.0
            nodejs:
              Version table:
            You are running nodejs v20.5.1. Do you want to install recommended nodejs ?
            Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Fetched 17.3 kB in 1s (22.6 kB/s)
            E: Version '-1nodesource1' for 'nodejs' was not found
            v20.5.1
            Proxmox und HA ...
            • F fastfoot
              @fastfoot sagte in iob node fix - Skript:
              find / ( -path /proc -o -path /dev -o -path /sys -o -path /some_other_path ) -prune -o -name nodesource.[gk]* -print
              Thx! Hab es jetzt drin.
                Meister Mopper
                Jetzt haben wir das
                /usr/bin/npm            9.8.0
                /usr/bin/npx            9.8.0
                nodejs:
                  Version table:
                ./iob_node_update: line 301: unexpected EOF while looking for matching `''
                ./iob_node_update: line 315: syntax error: unexpected end of file
                Proxmox und HA ...
                  Jetzt haben wir das
                  /usr/bin/npm            9.8.0
                  /usr/bin/npx            9.8.0
                  nodejs:
                    Version table:
                  @meister-mopper
                  Zieh nochmal rein. Aber ich glaube da ist noch ein Fehler drin...
                  Meister MopperM F 2 Antworten Letzte Antwort
                    @meister-mopper
                    Meister Mopper
                    schrieb am zuletzt editiert von Meister Mopper
                    Spaey
                    /usr/bin/npm            9.8.0
                    /usr/bin/npx            9.8.0
                    nodejs:
                      Version table:
                    ./iob_node_update: line 302: unexpected EOF while looking for matching `''
                    ./iob_node_update: line 316: syntax error: unexpected end of file
                    v20.5.1
                    Proxmox und HA ...
                      @meister-mopper
                      F Online
                      F Online
                      fastfoot
                      schrieb am zuletzt editiert von fastfoot
                      hinter dem -print) muss noch ein Anführungszeichen -print)";
                      und die vielen Semikolon kannste dir auch sparen :-)
                      • F fastfoot
                        ein Ausrufezeichen
                        • F fastfoot
                          Ich find die schön. Und meine IDE auch.
                            Spaey
                            /usr/bin/npm            9.8.0
                            /usr/bin/npx            9.8.0
                            nodejs:
                              Version table:
                            v20.5.1
                            @meister-mopper
                            Magst du noch mal schauen?
                              @meister-mopper
                              Meister Mopper
                              @meister-mopper
                              Sorry, musste in die Heia und heute war ich auf Dienstreise.
                              Es hat mit dem aktuellen Skript (wahrscheinlich) funktioniert.
                              ioBroker nodejs fixer 2023-09-06
                              No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                              /usr/bin/npm            9.8.0
                              /usr/bin/npx            9.8.0
                              I found these nodejs versions available for installation:
                              nodejs:
                                Version table:
                              You are running nodejs v20.5.1. Do you want to install recommended version ?
                              *** These repos are active on your system:
                              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                              *** Creating new /etc/apt/sources.list.d/nodesource.list
                              *** These repos are active after the adjustments:
                              Fetched 17.3 kB in 1s (16.9 kB/s)
                              Installing the recommended nodejs version now!
                              Exact recommended version unknown, installing a fallback!
                              The following packages will be DOWNGRADED:
                                nodejs
                              0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 2 not upgraded.
                              Need to get 26.7 MB of archives.
                              After this operation, 6614 kB disk space will be freed.
                              Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.0-1nodesource1 [26.7 MB]
                              Fetched 26.7 MB in 5s (5830 kB/s)
                              dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
                              (Reading database ... 123973 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.17.0-1nodesource1_armhf.deb ...
                              Detected old npm client, removing...
                              Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
                              Setting up nodejs (18.17.0-1nodesource1) ...
                              Processing triggers for man-db (2.9.4-2) ...
                              Updating fallback to latest nodejs v18 release
                              Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Calculating upgrade... Done
                              The following packages have been kept back:
                                libudev1 udev
                              The following packages will be upgraded:
                                nodejs
                              1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                              After this operation, 7168 B of additional disk space will be used.
                              Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.1-1nodesource1 [26.7 MB]
                              Fetched 26.7 MB in 3s (8606 kB/s)
                              apt-listchanges: Changelogs werden gelesen...
                              (Reading database ... 124040 files and directories currently installed.)
                              Preparing to unpack .../nodejs_18.17.1-1nodesource1_armhf.deb ...
                              Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
                              Setting up nodejs (18.17.1-1nodesource1) ...
                              We tried our best to fix your nodejs. Please run iob diag again to verify.
                              v18.17.1
                              Proxmox und HA ...
                                @meister-mopper
                                /usr/bin/npm            9.8.0
                                /usr/bin/npx            9.8.0
                                nodejs:
                                  Version table:
                                  nodejs
                                  libudev1 udev
                                  nodejs
                                v18.17.1
                                @meister-mopper
                                Prima! So soll es aussehen! Ich denke der Code ist dann soweit gediehen für ein Release.
                                Mag noch jemand mit einem LXC herumtesten?
                                  @meister-mopper
                                  MCU
                                  @thomas-braun LXC-Container
                                  Recommended nodejs-version is: 18.17.1
                                  /usr/bin/nodejs         v18.17.1
                                  /usr/bin/node           v18.17.1
                                  /usr/bin/npm            9.6.7
                                  /usr/bin/npx            9.6.7
                                  /usr/bin/corepack       0.18.0
                                  nodejs:
                                    Installed: 18.17.1-1nodesource1
                                    Candidate: 18.17.1-1nodesource1
                                    Version table:
                                   *** 18.17.1-1nodesource1 500
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                       18.13.0+dfsg1-1 500
                                          500 http://ftp.debian.org/debian bookworm/main amd64 Packages
                                  Nothing to do, your installed version is the recommended one.
                                  • M MCU
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
                                    nodejs:
                                      Version table:
                                         18.13.0+dfsg1-1 500
                                    @mcu sagte in iob node fix - Skript:
                                    Nothing to do
                                    Hm. Der Codepart war einfach... ;-) Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
                                    M M 2 Antworten Letzte Antwort
                                      Nothing to do
                                      M Online
                                      M Online
                                      mrjeschke
                                      nodejs 20 sieht bei mir im LXC-Container so aus.
                                      /usr/bin/npm            9.8.0
                                      /usr/bin/npx            9.8.0
                                      nodejs:
                                        Version table:
                                       *** 20.5.1-deb-1nodesource1 500
                                              500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                                           18.13.0+dfsg1-1 500
                                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                      You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
                                      find: '/lost+found': Permission denied
                                      lxc
                                      Hit:2 http://security.debian.org bookworm-security InRelease
                                      ca-certificates is already the newest version (20230311).
                                      curl is already the newest version (7.88.1-10+deb12u1).
                                      gnupg is already the newest version (2.2.40-1.1).
                                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      Hit:1 http://security.debian.org bookworm-security InRelease
                                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                                      Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
                                      Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
                                      Fetched 17.3 kB in 0s (38.4 kB/s)
                                      ./iob_node_update: line 275: [: : integer expression expected
                                        nodejs
                                      0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
                                      Need to get 29.4 MB of archives.
                                      After this operation, 5249 kB disk space will be freed.
                                      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
                                      Fetched 29.4 MB in 2s (13.2 MB/s)
                                      (Reading database ... 37746 files and directories currently installed.)
                                      Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
                                      Processing triggers for man-db (2.11.2-2) ...
                                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                        nodejs
                                      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
                                      Fetched 29.4 MB in 1s (43.5 MB/s)
                                      apt-listchanges: Reading changelogs...
                                      (Reading database ... 37813 files and directories currently installed.)
                                      Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
                                      ./iob_node_update: line 300: [: : integer expression expected
                                      *** You need to manually restart your container now! ***
                                      maik@iobtest:~$
                                        Nothing to do
                                        MCU
                                        @thomas-braun Frisch aufgesetzter LXC mit nodejs 16 ohne ioBroker.
                                        /usr/bin/nodejs         v16.20.2
                                        /usr/bin/node           v16.20.2
                                        /usr/bin/npm            8.19.4
                                        /usr/bin/npx            8.19.4
                                        /usr/bin/corepack       0.17.0
                                        nodejs:
                                          Installed: 16.20.2-deb-1nodesource1
                                          Candidate: 16.20.2-deb-1nodesource1
                                          Version table:
                                         *** 16.20.2-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                                500 http://security.debian.org bullseye-security/main amd64 Packages
                                             12.22.12~dfsg-1~deb11u3 500
                                                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                        You are running nodejs v16.20.2. Do you want to install recommended version ?
                                        [sudo] password for prox:
                                        lxc
                                        ./iob_node_update: line 248: iob: command not found
                                        Hit:1 http://ftp.debian.org/debian bullseye InRelease
                                        Hit:2 http://security.debian.org bullseye-security InRelease
                                        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                                        Hit:1 http://security.debian.org bullseye-security InRelease
                                        Hit:2 http://ftp.debian.org/debian bullseye InRelease
                                        Fetched 17.3 kB in 0s (57.5 kB/s)
                                          nodejs
                                        After this operation, 60.4 MB of additional disk space will be used.
                                        Fetched 29.4 MB in 1s (21.7 MB/s)
                                        (Reading database ... 22654 files and directories currently installed.)
                                        Unpacking nodejs (18.17.0-1nodesource1) over (16.20.2-deb-1nodesource1) ...
                                          nodejs
                                        Fetched 29.4 MB in 1s (41.9 MB/s)
                                        (Reading database ... 25141 files and directories currently installed.)
                                        nodejs is already the newest version (18.17.1-1nodesource1).
                                        • M MCU
                                          /usr/bin/npm            8.19.4
                                          /usr/bin/npx            8.19.4
                                          nodejs:
                                            Version table:
                                          lxc
                                            nodejs
                                            nodejs
                                          ohne ioBroker.
                                          dann kennt er natürlich (?) die empfohlene Version nicht
                                          @Thomas-Braun
                                          was tut er dann?
                                          M Thomas BraunT 2 Antworten Letzte Antwort
