  4. iob node fix - Skript
    apollon77A
198 Beiträge 34 Kommentatoren 80.9k Aufrufe 37 Beobachtet
    @thomas-braun sagte in iob node fix - Skript:
    Kannst du das jetzt nochmal nachstellen?
    Neues Skript heruntergeladen - kein reboot nach Installation auf nodejs@20:
    ioBroker nodejs fixer 2023-09-05
    Recommended nodejs-version is: 18.17.1
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v20.6.0
    /usr/bin/node           v20.6.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    I found these versions available for installation:
    nodejs:
      Installed: 20.6.0-1nodesource1
      Candidate: 20.6.0-1nodesource1
      Version table:
     *** 20.6.0-1nodesource1 500
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.5.1-1nodesource1 500
         20.5.0-1nodesource1 500
         20.4.0-1nodesource1 500
         20.3.1-1nodesource1 500
         20.3.0-1nodesource1 500
         20.2.0-1nodesource1 500
         20.1.0-1nodesource1 500
         20.0.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
    Nothing to do, your installation is using the correct paths.
    !!! THIS CODE IS IN BETA STAGE. TRY IT AT YOUR OWN RISK !!!
    You are running nodejs v20.6.0. Do you want to install recommended nodejs 18.17.1?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/sys/kernel/debug': Permission denied
    find: '/sys/fs/fuse/connections/60': Permission denied
    find: '/sys/fs/fuse/connections/55': Permission denied
    find: '/dev/.lxc/sys/kernel': Permission denied
    find: '/dev/.lxc/sys/power': Permission denied
    find: '/dev/.lxc/sys/class': Permission denied
    find: '/dev/.lxc/sys/devices': Permission denied
    find: '/dev/.lxc/sys/dev': Permission denied
    find: '/dev/.lxc/sys/hypervisor': Permission denied
    find: '/dev/.lxc/sys/fs': Permission denied
    find: '/dev/.lxc/sys/bus': Permission denied
    find: '/dev/.lxc/sys/firmware': Permission denied
    find: '/dev/.lxc/sys/block': Permission denied
    find: '/dev/.lxc/sys/module': Permission denied
    find: '/dev/.lxc/proc/fs': Permission denied
    find: '/dev/.lxc/proc/bus': Permission denied
    find: '/dev/.lxc/proc/irq': Permission denied
    find: '/dev/.lxc/proc/spl': Permission denied
    find: '/dev/.lxc/proc/sys': Permission denied
    find: '/dev/.lxc/proc/tty': Permission denied
    find: '/dev/.lxc/proc/acpi': Permission denied
    find: '/dev/.lxc/proc/scsi': Permission denied
    find: '/dev/.lxc/proc/driver': Permission denied
    find: '/dev/.lxc/proc/sysvipc': Permission denied
    find: '/dev/.lxc/proc/pressure': Permission denied
    find: '/dev/.lxc/proc/dynamic_debug': Permission denied
    find: '/dev/.lxc/proc/1': Permission denied
    find: '/dev/.lxc/proc/45': Permission denied
    find: '/dev/.lxc/proc/76': Permission denied
    find: '/dev/.lxc/proc/92': Permission denied
    find: '/dev/.lxc/proc/93': Permission denied
    find: '/dev/.lxc/proc/95': Permission denied
    find: '/dev/.lxc/proc/96': Permission denied
    find: '/dev/.lxc/proc/123': Permission denied
    find: '/dev/.lxc/proc/127': Permission denied
    find: '/dev/.lxc/proc/128': Permission denied
    find: '/dev/.lxc/proc/129': Permission denied
    find: '/dev/.lxc/proc/130': Permission denied
    find: '/dev/.lxc/proc/19126': Permission denied
    find: '/dev/.lxc/proc/19129': Permission denied
    find: '/dev/.lxc/proc/19130': Permission denied
    find: '/dev/.lxc/proc/19149': Permission denied
    find: '/dev/.lxc/proc/19150': Permission denied
    find: '/dev/.lxc/proc/20024': Permission denied
    find: '/dev/.lxc/proc/20125': Permission denied
    find: '/dev/.lxc/proc/20126': Permission denied
    find: '/dev/.lxc/proc/20129': Permission denied
    find: '/dev/.lxc/proc/20130': Permission denied
    rm: cannot remove '': No such file or directory
    lxc
    Waiting for ioBroker to shut down - Give me a minute...
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Reading package lists... Done
    ca-certificates is already the newest version (20230311).
    curl is already the newest version (7.88.1-10+deb12u1).
    gnupg is already the newest version (2.2.40-1.1).
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Creating new /etc/apt/sources.list.d/nodesource.list file with this content:
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
    Get:4 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Get:5 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5181 B]
    Fetched 17.3 kB in 1s (20.9 kB/s)
    The following packages will be DOWNGRADED:
      nodejs
    0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
    Need to get 0 B/29.4 MB of archives.
    After this operation, 5746 kB disk space will be freed.
    dpkg: warning: downgrading nodejs from 20.6.0-1nodesource1 to 18.17.1-1nodesource1
    (Reading database ... 46293 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.1-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.17.1-1nodesource1) over (20.6.0-1nodesource1) ...
    Setting up nodejs (18.17.1-1nodesource1) ...
    Processing triggers for man-db (2.11.2-2) ...
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    After this operation, 0 B of additional disk space will be used.
    (Reading database ... 46317 files and directories currently installed.)
    Unpacking nodejs (18.17.1-1nodesource1) over (18.17.1-1nodesource1) ...
    *** You need to manually restart your container now! ***
    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @meister-mopper
    Hmmmm. Hat also nicht wie gedacht funktioniert. Dann muss ich da später mal genauer schauen. Die Syntax von 'find' ist auch in Skripten nicht die einfachste...
    Meister MopperM F 2 Antworten Letzte Antwort
      @meister-mopper
      Meister MopperM
      Meister MopperM
      Meister Mopper
      Bei dem Slave komme ich von der nodejs@20 mit dem Skript nicht mehr weg.
      Recommended nodejs-version is: No connection to databases possible ...
      /usr/bin/nodejs         v20.5.1
      /usr/bin/node           v20.5.1
      /usr/bin/npm            9.8.0
      /usr/bin/npx            9.8.0
      nodejs:
        Installed: 20.5.1-deb-1nodesource1
        Candidate: 20.5.1-deb-1nodesource1
        Version table:
       *** 20.5.1-deb-1nodesource1 100
           18.17.1-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
      You are running nodejs v20.5.1. Do you want to install recommended nodejs No connection to databases possible ...?
      yrm: cannot remove '': No such file or directory
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      ca-certificates is already the newest version (20210119).
      curl is already the newest version (7.74.0-1.3+deb11u7).
      gnupg is already the newest version (2.2.27-2+deb11u2).
      0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
      Get:3 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
      Get:4 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages [5161 B]
      Fetched 17.3 kB in 1s (17.6 kB/s)
      E: Version 'No connection to databases possible ...-1nodesource1' for 'nodejs' was not found
      Reinstallation of nodejs is not possible, it cannot be downloaded.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      thomas@rpizigbee:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
      thomas@rpizigbee:~ $ nodejs -v
      v20.5.1
      Proxmox und HA ...
        /usr/bin/npm            9.8.0
        /usr/bin/npx            9.8.0
        nodejs:
          Version table:
        v20.5.1
        Thomas BraunT
        Thomas BraunT
        @meister-mopper sagte in iob node fix - Skript:
        Versuch es jetzt nochmal.
          Meister MopperM
          Meister MopperM
          Meister Mopper
          thomas@rpizigbee:~ $ ./iob_node_update
          ioBroker node-update v2023-09-05 is starting. Please be patient!
          The state system.host.rpizigbee.versions.nodeNewestNext was not found!
          ./iob_node_update: Zeile 11: Syntaxfehler beim unerwarteten Symbol »;«
          ./iob_node_update: Zeile 11: `then;'
          Proxmox und HA ...
            Thomas BraunT
            Thomas BraunT
            @meister-mopper
            Un nu?
              @meister-mopper
              F
              F
              fastfoot
              find / \( -path /proc -o -path /dev -o -path /sys -o -path /some_other_path \) -prune -o -name nodesource.[gk]* -print
                @meister-mopper
                Un nu?
                Meister MopperM
                Meister MopperM
                Meister Mopper
                Un nu?
                Nö!
                Could not detect recommended nodejs-version. Setting up the nodejs 18 tree now.
                /usr/bin/npm            9.8.0
                /usr/bin/npx            9.8.0
                nodejs:
                  Version table:
                You are running nodejs v20.5.1. Do you want to install recommended nodejs ?
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Fetched 17.3 kB in 1s (22.6 kB/s)
                E: Version '-1nodesource1' for 'nodejs' was not found
                v20.5.1
                Proxmox und HA ...
                • F fastfoot
                  Thomas BraunT
                  Thomas BraunT
                  @fastfoot sagte in iob node fix - Skript:
                  find / ( -path /proc -o -path /dev -o -path /sys -o -path /some_other_path ) -prune -o -name nodesource.[gk]* -print
                  Thx! Hab es jetzt drin.
                    Meister MopperM
                    Meister MopperM
                    Meister Mopper
                    Jetzt haben wir das
                    /usr/bin/npm            9.8.0
                    /usr/bin/npx            9.8.0
                    nodejs:
                      Version table:
                    ./iob_node_update: line 301: unexpected EOF while looking for matching `''
                    ./iob_node_update: line 315: syntax error: unexpected end of file
                    Proxmox und HA ...
                      Jetzt haben wir das
                      /usr/bin/npm            9.8.0
                      /usr/bin/npx            9.8.0
                      nodejs:
                        Version table:
                      Thomas BraunT
                      Thomas BraunT
                      @meister-mopper
                      Zieh nochmal rein. Aber ich glaube da ist noch ein Fehler drin...
                        @meister-mopper
                        Meister MopperM
                        Meister MopperM
                        Meister Mopper
                        schrieb am zuletzt editiert von Meister Mopper
                        Spaey
                        /usr/bin/npm            9.8.0
                        /usr/bin/npx            9.8.0
                        nodejs:
                          Version table:
                        ./iob_node_update: line 302: unexpected EOF while looking for matching `''
                        ./iob_node_update: line 316: syntax error: unexpected end of file
                        v20.5.1
                        Proxmox und HA ...
                          @meister-mopper
                          F
                          F
                          fastfoot
                          schrieb am zuletzt editiert von fastfoot
                          hinter dem -print) muss noch ein Anführungszeichen -print)";
                          und die vielen Semikolon kannste dir auch sparen :-)
                          • F fastfoot
                            ein Ausrufezeichen
                            • F fastfoot
                              Thomas BraunT
                              Thomas BraunT
                              Ich find die schön. Und meine IDE auch.
                                Spaey
                                /usr/bin/npm            9.8.0
                                /usr/bin/npx            9.8.0
                                nodejs:
                                  Version table:
                                v20.5.1
                                Thomas BraunT
                                Thomas BraunT
                                @meister-mopper
                                Magst du noch mal schauen?
                                  @meister-mopper
                                  Meister MopperM
                                  Meister MopperM
                                  Meister Mopper
                                  @meister-mopper
                                  Sorry, musste in die Heia und heute war ich auf Dienstreise.
                                  Es hat mit dem aktuellen Skript (wahrscheinlich) funktioniert.
                                  ioBroker nodejs fixer 2023-09-06
                                  No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
                                  /usr/bin/npm            9.8.0
                                  /usr/bin/npx            9.8.0
                                  I found these nodejs versions available for installation:
                                  nodejs:
                                    Version table:
                                  You are running nodejs v20.5.1. Do you want to install recommended version ?
                                  *** These repos are active on your system:
                                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                  *** Creating new /etc/apt/sources.list.d/nodesource.list
                                  *** These repos are active after the adjustments:
                                  Fetched 17.3 kB in 1s (16.9 kB/s)
                                  Installing the recommended nodejs version now!
                                  Exact recommended version unknown, installing a fallback!
                                    nodejs
                                  0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 2 not upgraded.
                                  Need to get 26.7 MB of archives.
                                  After this operation, 6614 kB disk space will be freed.
                                  Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.0-1nodesource1 [26.7 MB]
                                  Fetched 26.7 MB in 5s (5830 kB/s)
                                  dpkg: warning: downgrading nodejs from 20.5.1-deb-1nodesource1 to 18.17.0-1nodesource1
                                  (Reading database ... 123973 files and directories currently installed.)
                                  Preparing to unpack .../nodejs_18.17.0-1nodesource1_armhf.deb ...
                                  Unpacking nodejs (18.17.0-1nodesource1) over (20.5.1-deb-1nodesource1) ...
                                  Setting up nodejs (18.17.0-1nodesource1) ...
                                  Processing triggers for man-db (2.9.4-2) ...
                                  Updating fallback to latest nodejs v18 release
                                  Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Calculating upgrade... Done
                                  The following packages have been kept back:
                                    libudev1 udev
                                  The following packages will be upgraded:
                                    nodejs
                                  1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                                  After this operation, 7168 B of additional disk space will be used.
                                  Get:1 https://deb.nodesource.com/node_18.x nodistro/main armhf nodejs armhf 18.17.1-1nodesource1 [26.7 MB]
                                  Fetched 26.7 MB in 3s (8606 kB/s)
                                  apt-listchanges: Changelogs werden gelesen...
                                  (Reading database ... 124040 files and directories currently installed.)
                                  Preparing to unpack .../nodejs_18.17.1-1nodesource1_armhf.deb ...
                                  Unpacking nodejs (18.17.1-1nodesource1) over (18.17.0-1nodesource1) ...
                                  We tried our best to fix your nodejs. Please run iob diag again to verify.
                                  v18.17.1
                                  Proxmox und HA ...
                                    @meister-mopper
                                    /usr/bin/npm            9.8.0
                                    /usr/bin/npx            9.8.0
                                    nodejs:
                                      Version table:
                                      nodejs
                                      libudev1 udev
                                      nodejs
                                    v18.17.1
                                    Thomas BraunT
                                    Thomas BraunT
                                    @meister-mopper
                                    Prima! So soll es aussehen! Ich denke der Code ist dann soweit gediehen für ein Release.
                                    Mag noch jemand mit einem LXC herumtesten?
                                      @meister-mopper
                                      M
                                      M
                                      MCU
                                      @thomas-braun LXC-Container
                                      /usr/bin/nodejs         v18.17.1
                                      /usr/bin/node           v18.17.1
                                      /usr/bin/npm            9.6.7
                                      /usr/bin/npx            9.6.7
                                      /usr/bin/corepack       0.18.0
                                      nodejs:
                                        Installed: 18.17.1-1nodesource1
                                        Candidate: 18.17.1-1nodesource1
                                        Version table:
                                       *** 18.17.1-1nodesource1 500
                                              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                           18.13.0+dfsg1-1 500
                                              500 http://ftp.debian.org/debian bookworm/main amd64 Packages
                                      Nothing to do, your installed version is the recommended one.
                                      • M MCU
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        nodejs:
                                          Version table:
                                             18.13.0+dfsg1-1 500
                                        Thomas BraunT
                                        Thomas BraunT
                                        @mcu sagte in iob node fix - Skript:
                                        Nothing to do
                                        Hm. Der Codepart war einfach... ;-) Kannst du mal von einer Version <> 18 kommend das Skript laufen lassen?
                                        M M 2 Antworten Letzte Antwort
                                          Nothing to do
                                          M
                                          M
                                          mrjeschke
                                          nodejs 20 sieht bei mir im LXC-Container so aus.
                                          /usr/bin/npm            9.8.0
                                          /usr/bin/npx            9.8.0
                                          nodejs:
                                            Version table:
                                           *** 20.5.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_20.x bookworm/main amd64 Packages
                                               18.13.0+dfsg1-1 500
                                          You are running nodejs v20.5.1. Do you want to install recommended version 18.17.1?
                                          find: '/lost+found': Permission denied
                                          lxc
                                          Hit:2 http://security.debian.org bookworm-security InRelease
                                          Hit:1 http://security.debian.org bookworm-security InRelease
                                          Fetched 17.3 kB in 0s (38.4 kB/s)
                                          ./iob_node_update: line 275: [: : integer expression expected
                                            nodejs
                                          Need to get 29.4 MB of archives.
                                          After this operation, 5249 kB disk space will be freed.
                                          Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
                                          Fetched 29.4 MB in 2s (13.2 MB/s)
                                          (Reading database ... 37746 files and directories currently installed.)
                                          Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
                                          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                            nodejs
                                          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                          Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.1-1nodesource1 [29.4 MB]
                                          Fetched 29.4 MB in 1s (43.5 MB/s)
                                          apt-listchanges: Reading changelogs...
                                          (Reading database ... 37813 files and directories currently installed.)
                                          ./iob_node_update: line 300: [: : integer expression expected
                                          maik@iobtest:~$
                                          84.0k
