  4. Backitupadapter
    5.2k
Backitupadapter
57 Beiträge 5 Kommentatoren 6.7k Aufrufe 4 Beobachtet
  • M michaelxhoffmann
    @thomas-braun auf iob fix reagiert das Ding nicht
    pi@raspi:~ $ iob fix
    pi@raspi:~ $
    @michaelxhoffmann
    Hm. Klar...
    Zeih es aus dem Netz:
    curl -fsL https://iobroker.net/fix.sh | bash -
      @michaelxhoffmann
      Hm. Klar...
      michaelxhoffmann
      schrieb am zuletzt editiert von michaelxhoffmann
      @thomas-braun sagte in Backitupadapter:
      pi@raspi:/ $ curl -fsL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Get:6 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [314 kB]
      Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [308 kB]
      Fetched 689 kB in 2s (339 kB/s)
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspi:/ $ iobroker start
      pi@raspi:/ $
      Ich werde wirklich bald bekloppt jetzt läuft das Ding...Und alle Adapter grün
      Bin jetzt gespannt was passiert wenn ich die Visu aufrufen will... Damit fing der ganze spass ja an ...
      Visu läuft auch ....FETTES DANKE ...
      Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
        library: loaded
        Installed gcc-c++
        Done.
        Autostart enabled!
        pi@raspi:/ $
        @michaelxhoffmann
        Lesson learned? Nie als root herumhampeln und nie Kommandos ohne Notwendigkeit per sudo einleiten.
          @michaelxhoffmann
          michaelxhoffmann
          Jo die Lektion habe ich gelernt ... ABER der Fehler ist wieder da... IOB abgeschmiert alle Adapter starten schon wieder neu. ...
          Ich mache eine neue installation :(
          Das kann ich ja mittlerweile
            @michaelxhoffmann
            Keine Ahnung was du da treibst...
            Bist du sicher, dass die Hardware gesund ist?
              @michaelxhoffmann
              michaelxhoffmann
              @thomas-braun Tja wie sicher kann man da sein .... Ich habe einen Raspberry 4 mit 4 GB und einem 5V 3 A Netzteil, angeschlossen ist das Teil über LAN ...Es war eine nieselnagelneue SD Card mit dem aktuellsten 64Bit OS
                @michaelxhoffmann sagte in Backitupadapter:
                In den einschlägigen Logs as ight man sowas auch oft.
                dmesg
                oder
                journalctl
                können da Hinweise geben.
                  dmesg
                  oder
                  journalctl
                  michaelxhoffmann
                  @thomas-braun Also ich habe jetzt mal das Netzteil ausgetauscht. Ist jetzt ein 12Watt Adapter 5,2 Volt ... sollte es tatsächlich am Netzteil gelegen haben ....
                    der pi4 kommt mit
                    möglicherweise ins Schleudern. 5.1V sollten es schon sein
                      der pi4 kommt mit
                      michaelxhoffmann
                      @homoran jo jetzt habe ich ihm ein 5,2 volt Apple Netzteil spendiert ...
                        @michaelxhoffmann
                        Richtiges Netzteil oder Ladegerät?
                        Ich habe hier die originalen Pi-Netzteile laufen. Nie Probleme gehabt.
                        M 2 Antworten Letzte Antwort
                          @michaelxhoffmann
                          michaelxhoffmann
                          @thomas-braun Ihm wo ist der Unterschied? Also das 12 Watt Netzteil / Ladegerät das früher bei den iPads beilag
                            @michaelxhoffmann
                            Ein Ladegerät ist i.d.R. nicht stabilisiert.
                              @michaelxhoffmann
                              michaelxhoffmann
                              @thomas-braun Das, welches beilag ist ein Hama 5V 3A ... Das war im Paket dabei. Und es lief ja auch alles 1,5 Jahre einwandfrei :)
                                @michaelxhoffmann
                                michaelxhoffmann
                                @thomas-braun So der Broker läuft bisher ohne Probleme durch. Nun da ich weiß dass ich nichts mit sudo machen soll und ein stärkeres Ladegerät / Netzteil spendiert habe, hoffe ich doch dass ich jetzt Ruhe haben werde ;) Aber wieder ein Dankeschön an dieser Stelle.
                                  Moin,
                                  so hat das niemand gesagt, Du sollst natürlich sudo nutzen, nur halt nicht, wenn es um die ioBroker Dinge geht, also alles was mit iob oder iobroker anfängt.
                                  Ansonsten ist sudo immer richtig.
                                  Bernd
                                    Moin,
                                    Bernd
                                    @dp20eic sagte in Backitupadapter:
                                    @michaelxhoffmann
                                    und auch nicht bei npm-Befehlen. Die sind sowieso nicht erste Wahl. Da gibt es noch mehr zu beachten.
                                    ? M 2 Antworten Letzte Antwort
                                      @michaelxhoffmann
                                      @homoran sagte in Backitupadapter:
                                      Moin,
                                      ok, dann sollten wir mal eine List machen, guter Befehl und böser Befehle :)
                                      Nein Scherz beiseite, etwas selbst mitdenken wäre schon ganz nett.
                                      Gerade wenn ich nicht weiß, was ein Befehl macht, nutze ich ihn nicht automatisch, nur weil das in einem Forum oder Post gesagt wurde, ich schaue mir immer erst an, was ein Befehl macht und wieso er gerade in diesem Fall eingesetzt wurde, erst wenn ich das verstanden habe, mache ich dann weiter oder ich frage vorher nochmal, ob es so korrekt ist.
                                      Ist aber off topic und ich bin da vielleicht auch etwas speziell :)
                                      Bernd
                                        @michaelxhoffmann
                                        michaelxhoffmann
                                        @homoran ist notiert ;)
