  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
  • M michaelxhoffmann
    @thomas-braun ja. aber startet nicht
    pi@raspberrypi:~ $ iob status
    node:internal/modules/cjs/loader:1080
      throw err;
    Error: Cannot find module 'fs-extra'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
        at Module._load (node:internal/modules/cjs/loader:922:27)
        at Module.require (node:internal/modules/cjs/loader:1143:19)
        at require (node:internal/modules/cjs/helpers:121:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:16:12)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
        at Module.load (node:internal/modules/cjs/loader:1119:32)
        at Module._load (node:internal/modules/cjs/loader:960:12)
        at Module.require (node:internal/modules/cjs/loader:1143:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    Node.js v18.17.1
    @michaelxhoffmann
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
      IObroker Diagnose:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.2
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       19:16:54 up  8:44,  1 user,  load average: 0.51, 0.42, 0.36
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=57.4'C
      volt=0.8625V
      *** Time and Time Zones ***
                     Local time: Tue 2023-08-29 19:16:54 CEST
                 Universal time: Tue 2023-08-29 17:16:54 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            3.8G        103M        2.8G        1.0M        859M        3.6G
      Swap:            99M          0B         99M
      Total:          3.9G        103M        2.9G
               3794 M total memory
                103 M used memory
                216 M active memory
                483 M inactive memory
               2832 M free memory
                167 M buffer memory
                691 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.2G   21G  23% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.1M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Tue Aug 29 10:32:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:BB:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7332932-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Tue Aug 29 10:32:54 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Tue Aug 29 10:32:54 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Tue Aug 29 10:32:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G	/var/
      925M	/var/log
      905M	/var/log/journal/d25d733f60db4f059662faf3a610222b
      178M	/var/cache
      Archived and active journals take up 904.2M in the file system.
      /opt/iobroker/backups:
      209M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      614M	/opt/iobroker/iobroker-data/
      495M	/opt/iobroker/iobroker-data/files
      100M	/opt/iobroker/iobroker-data/backup-objects
      88M	/opt/iobroker/iobroker-data/files/echarts.admin
      72M	/opt/iobroker/iobroker-data/files/telegram.admin
      41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.17.1
      /usr/bin/node 		v18.17.1
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Installed: 18.17.1-deb-1nodesource1
        Candidate: 18.17.1-deb-1nodesource1
        Version table:
       *** 18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      Core adapters versions
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      js-controller:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      admin:
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      javascript:
      Adapters from github: 	4
      Adapter State
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      ioBroker-Repositories
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      Installed ioBroker-Instances
        throw err;
      Require stack:
        requireStack: [
      Node.js v18.17.1
      Objects and States
      Objects: 	0
      States: 	0
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12533      548/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12535      548/sshd: /usr/sbin
      udp        0      0 0.0.0.0:58307           0.0.0.0:*                           108        12507      399/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12505      399/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12556      734/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12506      399/avahi-daemon: r
      udp6       0      0 :::53259                :::*                                108        12508      399/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12567      734/dhcpcd
      2023-08-29 10:03:42.849  - info: host.raspberrypi iobroker upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
      2023-08-29 10:03:42.916  - info: host.raspberrypi iobroker upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
      2023-08-29 10:03:42.974  - info: host.raspberrypi iobroker upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
      2023-08-29 10:03:43.039  - info: host.raspberrypi iobroker upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
      2023-08-29 10:03:43.094  - info: host.raspberrypi iobroker upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
      2023-08-29 10:03:43.150  - info: host.raspberrypi iobroker upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
      2023-08-29 10:03:43.246  - info: host.raspberrypi iobroker upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
      2023-08-29 10:03:43.368  - info: host.raspberrypi iobroker upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
      2023-08-29 10:03:43.561  - info: host.raspberrypi iobroker upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
      2023-08-29 10:03:43.705  - info: host.raspberrypi iobroker upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
      2023-08-29 10:03:43.952  - info: host.raspberrypi iobroker upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
      2023-08-29 10:03:44.347  - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 83210
      2023-08-29 10:03:44.653  - info: host.raspberrypi iobroker upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
      2023-08-29 10:03:45.673  - info: host.raspberrypi iobroker upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
      2023-08-29 10:03:47.105  - info: host.raspberrypi iobroker exit 0
      2023-08-29 10:04:04.956  - info: host.raspberrypi iobroker upgrade admin@6.8.0
      2023-08-29 10:04:08.094  - info: host.raspberrypi iobroker Update admin from @6.3.5 to @6.8.0
      2023-08-29 10:04:08.159  - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      2023-08-29 10:04:08.319  - info: host.raspberrypi "system.adapter.admin.0" disabled
      2023-08-29 10:04:08.321  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
      2023-08-29 10:04:08.392  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
      2023-08-29 10:04:09.088  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2023-08-29 10:04:09.925  - info: host.raspberrypi iobroker NPM version: 9.5.1
      2023-08-29 10:04:09.942  - info: host.raspberrypi iobroker Installing iobroker.admin@6.8.0... (System call)
      iob diag has finished.
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @michaelxhoffmann setz doch mal bitte die Texte in CODETAGS... kann doch nicht unbedingt so schwer sein ;)
      Lehrling seit 1975 !!!
      Thomas BraunT M 2 Antworten Letzte Antwort
      • DJMarc75D DJMarc75
        @djmarc75
        Tut er ja. Ist nur beim c&p der Ausgabe vom iob diag nicht erforderlich. ;-)
          @djmarc75
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @thomas-braun sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
          doppelt gemoppelt quasi ... trotzdem sollten doch die User "sehen" dass diese langen Ausgaben prinzipiell - Kacke sind 👻 😁
            michaelxhoffmann
            @djmarc75 das habe ich getan, ich weiß auch nicht warum da nur einige Zeilen in der Codeformatierung sind. Tut mir leid :(
            Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
              @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
              Wenn du die Ausgabe von iob diag wie vorgesehen inkl. der Steuerzeichen für die CodeTags kopierst brauchst du die nicht nochmal manuell im Forum zu setzen.
                michaelxhoffmann
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:	11
                Codename:	bullseye
                VERSION_ID="11"
                ID=debian
                 20:34:59 up 10:02,  1 user,  load average: 0.12, 0.07, 0.08
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=56.4'C
                volt=0.8625V
                               Local time: Tue 2023-08-29 20:34:59 CEST
                           Universal time: Tue 2023-08-29 18:34:59 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:            3.8G        103M        2.8G        1.0M        902M        3.6G
                Swap:            99M          0B         99M
                         3794 M total memory
                          103 M used memory
                          248 M active memory
                          493 M inactive memory
                         2788 M free memory
                          168 M buffer memory
                          733 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.4G	/var/
                966M	/var/log
                937M	/var/log/journal/d25d733f60db4f059662faf3a610222b
                178M	/var/cache
                Archived and active journals take up 936.2M in the file system.
                /usr/bin/npm 		9.6.7
                /usr/bin/npx 		9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                js-controller:
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                admin:
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                javascript:
                Adapter State
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                Objects and States
                Objects: 	0
                States: 	0
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Pending Updates: 0
                  Skript v.2023-04-16
                  *** BASE SYSTEM ***
                  Docker          : false
                  Release:	11
                  Codename:	bullseye
                  VERSION_ID="11"
                  ID=debian
                  CPU threads: 4
                  Raspberry only:
                  throttled=0x0
                  temp=56.4'C
                  volt=0.8625V
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  /home/pi
                  X-Server: 	false
                  Desktop:
                  Terminal: 	tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           3794 M total memory
                            103 M used memory
                            248 M active memory
                           2788 M free memory
                            168 M buffer memory
                            733 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /var:
                  1.4G	/var/
                  966M	/var/log
                  178M	/var/cache
                  /usr/bin/npm 		9.6.7
                  /usr/bin/npx 		9.6.7
                  nodejs:
                    Version table:
                  ioBroker Status
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                  js-controller:
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                  admin:
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                  javascript:
                  Adapter State
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                  Objects and States
                  Objects: 	0
                  States: 	0
                  Pending Updates: 0
                  @michaelxhoffmann
                  cd /opt/iobroker
                    @michaelxhoffmann
                    cd /opt/iobroker
                    michaelxhoffmann
                    Hat leider nicht funktioniert. :(
                    npm ERR! code EINTEGRITY
                    npm ERR! errno EINTEGRITY
                    npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/axios: sha512-Yo0ZHtGUETLceWLfKlyrsjupDWUNYtNUAkblaOQBxzdQZTmcGTLdq9AmNS+nNIjXagoIZBFCa4vQc2oSL2Rh5g== integrity checksum failed when using sha512: wanted sha512-Yo0ZHtGUETLceWLfKlyrsjupDWUNYtNUAkblaOQBxzdQZTmcGTLdq9AmNS+nNIjXagoIZBFCa4vQc2oSL2Rh5g== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      Keine Ahnung warum axios da mit anderer Prüfsumme aufwartet.
                      • GlasfaserG Offline
                        GlasfaserG Offline
                        /usr/bin/npm 9.6.7
                        /usr/bin/npx 9.6.7
                        da passt was nicht .
                        mache mal :
                        sudo -H -u iobroker npm cache verify
                        sudo -H -u iobroker npm cache clean --force
                        sudo reboot
                        dann
                        cd /opt/iobroker
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @michaelxhoffmann
                          könntest du bitte den Threadtitel anpassen auf 6.8.0
                          ich dachte das wäre ein alter Thread ;)
                          • GlasfaserG Glasfaser
                            @michaelxhoffmann
                            michaelxhoffmann
                            @glasfaser :)) Wenn ich wüsste wie ich den Titel ändern kann würde ich's tun :))
                              /usr/bin/npm 9.6.7
                              /usr/bin/npx 9.6.7
                              mache mal :
                              sudo reboot
                              dann
                              cd /opt/iobroker
                              michaelxhoffmann
                              @glasfaser sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                              Super Biobroker läuft wieder! Jetzt fehlt mir lediglich noch der Webadapter bzw. die Adminoberfläche. Die bekomme ich nämlich nicht angezeigt im Browser :(
                              Thomas BraunT ? 2 Antworten Letzte Antwort
                                @michaelxhoffmann
                                Laufen die Adaper?
                                Zeig mal
                                iob diag
                                in der Langfassung.
                                  @michaelxhoffmann
                                  Laufen die Adaper?
                                  Zeig mal
                                  iob diag
                                  in der Langfassung.
                                  michaelxhoffmann
                                  @thomas-braun ======== Start marking the full check here =========
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:	11
                                  Codename:	bullseye
                                  VERSION_ID="11"
                                  ID=debian
                                   22:38:25 up 14 min,  1 user,  load average: 1.72, 1.76, 1.22
                                  CPU threads: 4
                                  Raspberry only:
                                  throttled=0x0
                                  temp=65.7'C
                                  volt=0.8625V
                                                 Local time: Tue 2023-08-29 22:38:25 CEST
                                             Universal time: Tue 2023-08-29 20:38:25 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server: 	false
                                  Desktop:
                                  Terminal: 	tty
                                  *** MEMORY ***
                                  Mem:            3.8G        446M        2.1G        1.0M        1.2G        3.3G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        446M        2.2G
                                           3794 M total memory
                                            446 M used memory
                                            545 M active memory
                                            923 M inactive memory
                                           2126 M free memory
                                            124 M buffer memory
                                           1096 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       29G  4.6G   23G  17% /
                                  [Tue Aug 29 22:24:15 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:BB:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7332932-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Tue Aug 29 22:24:16 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Tue Aug 29 22:24:16 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Tue Aug 29 22:24:18 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  /var:
                                  1.5G	/var/
                                  1.1G	/var/log
                                  993M	/var/log/journal/d25d733f60db4f059662faf3a610222b
                                  178M	/var/cache
                                  Archived and active journals take up 992.2M in the file system.
                                  494M	/opt/iobroker/iobroker-data/files
                                  /usr/bin/npm 		9.6.7
                                  /usr/bin/npx 		9.6.7
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  js-controller: 	5.0.12
                                  admin: 		"admin" not found
                                  javascript: 	"javascript" not found
                                  Adapters from github: 	1
                                  Adapter State
                                    system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
                                    system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                    system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                    system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                    system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
                                    system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
                                    system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
                                    system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                    system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                                    system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                                    system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
                                    system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                    system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                                    system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                    system.adapter.logparser.0              : logparser             : raspberrypi                              - disabled
                                    system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                                    system.adapter.material.0               : material              : raspberrypi                              - disabled
                                    system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
                                    system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 5987
                                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
                                    system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
                                    system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
                                    system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                                    system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                    system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
                                    system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                                    system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
                                    system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
                                    system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                    system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                    system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                                    system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                    system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                                    system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
                                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                                    system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                    system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                    system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
                                  + instance is alive
                                  Stable (default): http://download.iobroker.net/sources-dist.json
                                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                  latest 1      : http://iobroker.live/repo/sources-dist-latest.json
                                  default 1     : http://iobroker.live/repo/sources-dist.json
                                  Adapter    "alarm"        : 3.3.12   , installed 3.3.12
                                  Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
                                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                                  Controller "js-controller": 4.0.24   , installed 5.0.12
                                  Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                  Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                                  Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                  Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Objects and States
                                  Objects: 	12920
                                  States: 	10849
                                  Get:5 https://deb.nodesource.com/node_18.x bullseye InRelease [4586 B]
                                  Fetched 4586 B in 2s (2521 B/s)
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14906      1125/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16537      1125/iobroker.js-co
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1545       550/sshd: /usr/sbin
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1547       550/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:43918           0.0.0.0:*                           108        1471       398/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1469       398/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14583      736/dhcpcd
                                  udp6       0      0 :::37280                :::*                                108        1472       398/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          1572       736/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        1470       398/avahi-daemon: r
                                  2023-08-29 22:39:35.403  - info: host.raspberrypi "system.adapter.vis.0" enabled
                                  2023-08-29 22:39:35.407  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                                  2023-08-29 22:39:35.636  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.vis-metro created/updated
                                  2023-08-29 22:39:36.765  - info: host.raspberrypi iobroker npm-install: exit 0
                                  2023-08-29 22:39:37.766  - warn: host.raspberrypi startInstance cannot find adapter "vis-weather@2.5.6". Try to install it... 1 attempt
                                  2023-08-29 22:39:37.767  - info: host.raspberrypi iobroker install vis-weather@2.5.6 using installedFrom
                                  2023-08-29 22:39:42.728  - info: host.raspberrypi iobroker npm-install: NPM version: 9.6.7
                                  2023-08-29 22:39:42.731  - info: host.raspberrypi iobroker npm-install: Installing iobroker.vis-weather@2.5.6... (System call)
                                  2023-08-29 22:39:53.079  - info: host.raspberrypi iobroker npm-install:
                                  2023-08-29 22:39:53.081  - info: host.raspberrypi iobroker npm-install: added 1 package in 10s
                                  2023-08-29 22:39:53.083  - info: host.raspberrypi iobroker npm-install: 163 packages are looking for funding
                                  2023-08-29 22:39:53.085  - info: host.raspberrypi iobroker npm-install:   run `npm fund` for details
                                  2023-08-29 22:39:53.137  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter vis-weather@2.5.6
                                  2023-08-29 22:39:53.461  - info: host.raspberrypi iobroker npm-install: upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
                                  2023-08-29 22:39:53.485  - info: host.raspberrypi iobroker npm-install: upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
                                  2023-08-29 22:39:53.512  - info: host.raspberrypi iobroker npm-install: upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
                                  2023-08-29 22:39:53.539  - info: host.raspberrypi iobroker npm-install: upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
                                  2023-08-29 22:39:53.569  - info: host.raspberrypi iobroker npm-install: INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
                                  2023-08-29 22:39:53.657  - info: host.raspberrypi "system.adapter.vis.0" disabled
                                  2023-08-29 22:39:53.674  - info: host.raspberrypi "system.adapter.vis.0" enabled
                                  2023-08-29 22:39:53.677  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                                  2023-08-29 22:39:54.003  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.vis-weather created/updated
                                  2023-08-29 22:39:55.125  - info: host.raspberrypi iobroker npm-install: exit 0
                                  2023-08-29 22:39:56.125  - warn: host.raspberrypi startInstance cannot find adapter "admin@6.3.5". Try to install it... 1 attempt
                                  2023-08-29 22:39:56.126  - info: host.raspberrypi iobroker install admin@6.3.5 using installedFrom
                                  verstehe ich das richtig dass die erforderlichen Instanzen web und Admin nicht gestartet wurden?
                                  M Thomas BraunT 2 Antworten Letzte Antwort
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:	11
                                    Codename:	bullseye
                                    VERSION_ID="11"
                                    ID=debian
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=65.7'C
                                    volt=0.8625V
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    /home/pi
                                    X-Server: 	false
                                    Desktop:
                                    Terminal: 	tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             3794 M total memory
                                              446 M used memory
                                              545 M active memory
                                             2126 M free memory
                                              124 M buffer memory
                                             1096 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.5G	/var/
                                    1.1G	/var/log
                                    178M	/var/cache
                                    /usr/bin/npm 		9.6.7
                                    /usr/bin/npx 		9.6.7
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects: 	12920
                                    States: 	10849
                                    Pending Updates: 0
                                    michaelxhoffmann
                                    @michaelxhoffmann mittlerweile läuft die Vorschaltete des Brokers. Auf die Adminseite komme ich allerdings noch immer nicht :( Ich warte mal ab bis morgen früh, vielleicht braucht der Kollege einfach mehr Zeit :))
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:	11
                                      Codename:	bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=65.7'C
                                      volt=0.8625V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      /home/pi
                                      X-Server: 	false
                                      Desktop:
                                      Terminal: 	tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                               3794 M total memory
                                                446 M used memory
                                                545 M active memory
                                               2126 M free memory
                                                124 M buffer memory
                                               1096 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.5G	/var/
                                      1.1G	/var/log
                                      178M	/var/cache
                                      /usr/bin/npm 		9.6.7
                                      /usr/bin/npx 		9.6.7
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects: 	12920
                                      States: 	10849
                                      Pending Updates: 0
                                      Richtig.
                                      iob start admin
                                      iob start web
                                        Super Biobroker
                                        Moin,
                                        ist mir schon von Anfang an aufgefallen, ioBroker ist biologisch wertvoll und heißt ab jetzt Biobroker.
                                        Sorry konnte nicht anders :)
                                        Bernd
                                        P.S.: @michaelxhoffmann den Titel, kannst Du anpassen, indem Du im ersten Post, einfach auf den Titel klickst und änderst.
                                          Super Biobroker
                                          Moin,
                                          Bernd
                                          michaelxhoffmann
                                          @dp20 Na klar alles Biologisch :) Aber ich komme an den Startartikel gar nicht mehr ran. Ich komme nicht auf die erste threadseite :) um den Titel zu ändern.
