  4. Nach Update auf Admin 5.8 Startet Biobroker nicht mehr
    5.2k
120 Beiträge 7 Kommentatoren 13.3k Aufrufe 5 Beobachtet
    @michaelxhoffmann
    Wie / wo bist du denn da nun unterwegs?
    iob diag
    sagt? (Die Langfassung)
    michaelxhoffmann
    @thomas-braun Hallo,
    hier ist das Ergebnis von iob Diagnose:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     12:56:50 up  2:23,  1 user,  load average: 1.18, 0.86, 0.57
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=59.9'C
    volt=0.8625V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-29 12:56:50 CEST
               Universal time: Tue 2023-08-29 10:56:50 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            3.8G        106M        3.0G        1.0M        702M        3.6G
    Swap:            99M          0B         99M
    Total:          3.9G        106M        3.1G
             3794 M total memory
              106 M used memory
              187 M active memory
              492 M inactive memory
             2985 M free memory
              118 M buffer memory
              584 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.2G   21G  23% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Aug 29 10:32:53 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:5A:BB:67 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7332932-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Tue Aug 29 10:32:54 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Aug 29 10:32:54 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Tue Aug 29 10:32:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G	/var/
    868M	/var/log
    857M	/var/log/journal/d25d733f60db4f059662faf3a610222b
    178M	/var/cache
    Archived and active journals take up 856.2M in the file system.
    /opt/iobroker/backups:
    209M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    672M	/opt/iobroker/iobroker-data/
    495M	/opt/iobroker/iobroker-data/files
    100M	/opt/iobroker/iobroker-data/backup-objects
    88M	/opt/iobroker/iobroker-data/files/echarts.admin
    72M	/opt/iobroker/iobroker-data/files/telegram.admin
    68M	/opt/iobroker/iobroker-data/objects.jsonl
    41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v18.17.1
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		"admin" not found
    javascript: 	7.0.3
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
    npm ERR! extraneous: @iobroker/webserver@ /opt/iobroker/node_modules/@iobroker/webserver
    npm ERR! extraneous: @iobroker/ws-server@ /opt/iobroker/node_modules/@iobroker/ws-server
    npm ERR! extraneous: archiver-utils@ /opt/iobroker/node_modules/archiver-utils
    npm ERR! extraneous: archiver@ /opt/iobroker/node_modules/archiver
    npm ERR! extraneous: compress-commons@ /opt/iobroker/node_modules/compress-commons
    npm ERR! extraneous: crc-32@ /opt/iobroker/node_modules/crc-32
    npm ERR! extraneous: crc32-stream@ /opt/iobroker/node_modules/crc32-stream
    npm ERR! extraneous: express-fileupload@1.4.0 /opt/iobroker/node_modules/express-fileupload
    npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
    npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/lazystream
    npm ERR! extraneous: lodash.difference@ /opt/iobroker/node_modules/lodash.difference
    npm ERR! extraneous: lodash.union@ /opt/iobroker/node_modules/lodash.union
    npm ERR! extraneous: readdir-glob@ /opt/iobroker/node_modules/readdir-glob
    npm ERR! extraneous: zip-stream@ /opt/iobroker/node_modules/zip-stream
    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-08-29T10_57_36_039Z-debug-0.log
    Adapters from github: 	3
    Adapter State
      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
      system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
      system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      system.adapter.logparser.0              : logparser             : raspberrypi                              - disabled
      system.adapter.lovelace.0               : lovelace              : raspberrypi                              - disabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : raspberrypi                              - disabled
      system.adapter.milight-smart-light.0    : milight-smart-light   : raspberrypi                              -  enabled
      system.adapter.milight.0                : milight               : raspberrypi                              -  enabled, port: 5987
      system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
      system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.samsung.0                : samsung               : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3307
      system.adapter.sql.1                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
      system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
      system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    latest 1      : http://iobroker.live/repo/sources-dist-latest.json
    default 1     : http://iobroker.live/repo/sources-dist.json
    Installed ioBroker-Instances
    Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/../node_modules/iobroker.admin/io-package.json: /opt/iobroker/node_modules/iobroker.admin/package.json: Unexpected end of JSON input
    Cannot determine update info of "fritzbox": semver.gte is not a function
    Adapter    "alarm"        : 3.3.12   , installed 3.3.12
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "milight"      : 0.3.6    , installed 0.3.6
    Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
    Adapter    "musiccast"    : 1.1.0    , installed 1.1.0
    Adapter    "openweathermap": 0.3.9   , installed 0.3.9
    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "samsung"      : 0.5.11   , installed 0.5.11
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Objects and States
    Objects: 	12926
    States: 	10854
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12533      548/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12535      548/sshd: /usr/sbin
    udp        0      0 0.0.0.0:58307           0.0.0.0:*                           108        12507      399/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12505      399/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12556      734/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        12506      399/avahi-daemon: r
    udp6       0      0 :::53259                :::*                                108        12508      399/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12567      734/dhcpcd
    2023-08-29 10:03:42.849  - info: host.raspberrypi iobroker upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
    2023-08-29 10:03:42.916  - info: host.raspberrypi iobroker upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
    2023-08-29 10:03:42.974  - info: host.raspberrypi iobroker upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf font/ttf
    2023-08-29 10:03:43.039  - info: host.raspberrypi iobroker upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff font/woff
    2023-08-29 10:03:43.094  - info: host.raspberrypi iobroker upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
    2023-08-29 10:03:43.150  - info: host.raspberrypi iobroker upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
    2023-08-29 10:03:43.246  - info: host.raspberrypi iobroker upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
    2023-08-29 10:03:43.368  - info: host.raspberrypi iobroker upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
    2023-08-29 10:03:43.561  - info: host.raspberrypi iobroker upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
    2023-08-29 10:03:43.705  - info: host.raspberrypi iobroker upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
    2023-08-29 10:03:43.952  - info: host.raspberrypi iobroker upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
    2023-08-29 10:03:44.347  - info: host.raspberrypi instance system.adapter.yahka.0 started with pid 83210
    2023-08-29 10:03:44.653  - info: host.raspberrypi iobroker upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
    2023-08-29 10:03:45.673  - info: host.raspberrypi iobroker upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
    2023-08-29 10:03:47.105  - info: host.raspberrypi iobroker exit 0
    2023-08-29 10:04:04.956  - info: host.raspberrypi iobroker upgrade admin@6.8.0
    2023-08-29 10:04:08.094  - info: host.raspberrypi iobroker Update admin from @6.3.5 to @6.8.0
    2023-08-29 10:04:08.159  - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    2023-08-29 10:04:08.319  - info: host.raspberrypi "system.adapter.admin.0" disabled
    2023-08-29 10:04:08.321  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-08-29 10:04:08.392  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    2023-08-29 10:04:09.088  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2023-08-29 10:04:09.925  - info: host.raspberrypi iobroker NPM version: 9.5.1
    2023-08-29 10:04:09.942  - info: host.raspberrypi iobroker Installing iobroker.admin@6.8.0... (System call)
    iob diag has finished.
    Für mich sind das leider nur Böhmische Dörfer :(
    Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
    • M michaelxhoffmann
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:	11
      Codename:	bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=59.9'C
      volt=0.8625V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               3794 M total memory
                106 M used memory
                187 M active memory
               2985 M free memory
                118 M buffer memory
                584 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.3G	/var/
      868M	/var/log
      178M	/var/cache
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      javascript: 	7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	12926
      States: 	10854
      Pending Updates: 0
      @michaelxhoffmann sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
      Du hast aber doch auch npm 9.6.7 installiert? Wo kommt denn die 9.5.1 her?
      iob stop
      find "/opt/iobroker/" -iname "*package-lock*" -exec rm -rf "{}" \;
      find "/opt/iobroker/" -iname "*package.json*" -exec rm -rf "{}" \;
      iob start
        iob stop
        iob start
        michaelxhoffmann
        @thomas-braun Keine Ahnung ?
          michaelxhoffmann
          wenn ich im Terminal ein Restore aus dem Backup mache, wird dann auch der scheinbar fehlerhafte JS Controller und der Admin Adapter erneuert? Also macht es sinn das Restore durchzuführen?
            @michaelxhoffmann
            Du legst den iobroker ja neu 'leer' an. Der js-controller ist auch nicht Bestandteil des Backups, soweit ich weiß. Dürfte also funktionieren.
            Hast du die obigen Befehle ausgeführt? Resultat davon?
              @michaelxhoffmann
              michaelxhoffmann
              @thomas-braun ja. aber startet nicht
              pi@raspberrypi:~ $ iob status
              node:internal/modules/cjs/loader:1080
                throw err;
              Error: Cannot find module 'fs-extra'
              Require stack:
              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                  at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15)
                  at Module._load (node:internal/modules/cjs/loader:922:27)
                  at Module.require (node:internal/modules/cjs/loader:1143:19)
                  at require (node:internal/modules/cjs/helpers:121:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:16:12)
                  at Module._compile (node:internal/modules/cjs/loader:1256:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
                  at Module.load (node:internal/modules/cjs/loader:1119:32)
                  at Module._load (node:internal/modules/cjs/loader:960:12)
                  at Module.require (node:internal/modules/cjs/loader:1143:19) {
                code: 'MODULE_NOT_FOUND',
                requireStack: [
                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              Node.js v18.17.1
              M Thomas BraunT 2 Antworten Letzte Antwort
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                michaelxhoffmann
                IObroker Diagnose:
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:	11
                Codename:	bullseye
                VERSION_ID="11"
                ID=debian
                 19:16:54 up  8:44,  1 user,  load average: 0.51, 0.42, 0.36
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=57.4'C
                volt=0.8625V
                               Local time: Tue 2023-08-29 19:16:54 CEST
                           Universal time: Tue 2023-08-29 17:16:54 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server: 	false
                Desktop:
                Terminal: 	tty
                *** MEMORY ***
                Mem:            3.8G        103M        2.8G        1.0M        859M        3.6G
                Swap:            99M          0B         99M
                Total:          3.9G        103M        2.9G
                         3794 M total memory
                          103 M used memory
                          216 M active memory
                          483 M inactive memory
                         2832 M free memory
                          167 M buffer memory
                          691 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.4G	/var/
                925M	/var/log
                905M	/var/log/journal/d25d733f60db4f059662faf3a610222b
                178M	/var/cache
                Archived and active journals take up 904.2M in the file system.
                614M	/opt/iobroker/iobroker-data/
                19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                /usr/bin/npm 		9.6.7
                /usr/bin/npx 		9.6.7
                nodejs:
                  Version table:
                ioBroker Status
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                js-controller:
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                admin:
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                javascript:
                Adapters from github: 	4
                Adapter State
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                  throw err;
                Require stack:
                  requireStack: [
                Node.js v18.17.1
                Objects and States
                Objects: 	0
                States: 	0
                Pending Updates: 0
                    throw err;
                  Require stack:
                    requireStack: [
                  Node.js v18.17.1
                  @michaelxhoffmann
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.js-controller
                    IObroker Diagnose:
                    Skript v.2023-04-16
                    *** BASE SYSTEM ***
                    Docker          : false
                    Release:	11
                    Codename:	bullseye
                    VERSION_ID="11"
                    ID=debian
                    CPU threads: 4
                    Raspberry only:
                    throttled=0x0
                    temp=57.4'C
                    volt=0.8625V
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server: 	false
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Swap:            99M          0B         99M
                             3794 M total memory
                              103 M used memory
                              216 M active memory
                             2832 M free memory
                              167 M buffer memory
                              691 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.4G	/var/
                    925M	/var/log
                    178M	/var/cache
                    /usr/bin/npm 		9.6.7
                    /usr/bin/npx 		9.6.7
                    nodejs:
                      Version table:
                    ioBroker Status
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                    js-controller:
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                    admin:
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                    javascript:
                    Adapter State
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                      throw err;
                    Require stack:
                      requireStack: [
                    Node.js v18.17.1
                    Objects and States
                    Objects: 	0
                    States: 	0
                    Pending Updates: 0
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @michaelxhoffmann setz doch mal bitte die Texte in CODETAGS... kann doch nicht unbedingt so schwer sein ;)
                    Lehrling seit 1975 !!!
                    Thomas BraunT M 2 Antworten Letzte Antwort
                    • DJMarc75D DJMarc75
                      @djmarc75
                      Tut er ja. Ist nur beim c&p der Ausgabe vom iob diag nicht erforderlich. ;-)
                        @djmarc75
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @thomas-braun sagte in Nach Update auf Admin 5.8 Startet Biobroker nicht mehr:
                        doppelt gemoppelt quasi ... trotzdem sollten doch die User "sehen" dass diese langen Ausgaben prinzipiell - Kacke sind 👻 😁
                          michaelxhoffmann
                          @djmarc75 das habe ich getan, ich weiß auch nicht warum da nur einige Zeilen in der Codeformatierung sind. Tut mir leid :(
                            Wenn du die Ausgabe von iob diag wie vorgesehen inkl. der Steuerzeichen für die CodeTags kopierst brauchst du die nicht nochmal manuell im Forum zu setzen.
                              michaelxhoffmann
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:	11
                              Codename:	bullseye
                              VERSION_ID="11"
                              ID=debian
                               20:34:59 up 10:02,  1 user,  load average: 0.12, 0.07, 0.08
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=56.4'C
                              volt=0.8625V
                                             Local time: Tue 2023-08-29 20:34:59 CEST
                                         Universal time: Tue 2023-08-29 18:34:59 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              /home/pi
                              X-Server: 	false
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Mem:            3.8G        103M        2.8G        1.0M        902M        3.6G
                              Swap:            99M          0B         99M
                                       3794 M total memory
                                        103 M used memory
                                        248 M active memory
                                        493 M inactive memory
                                       2788 M free memory
                                        168 M buffer memory
                                        733 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              1.4G	/var/
                              966M	/var/log
                              937M	/var/log/journal/d25d733f60db4f059662faf3a610222b
                              178M	/var/cache
                              Archived and active journals take up 936.2M in the file system.
                              /usr/bin/npm 		9.6.7
                              /usr/bin/npx 		9.6.7
                              nodejs:
                                Version table:
                              ioBroker Status
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                              js-controller:
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                              admin:
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                              javascript:
                              Adapter State
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                                throw err;
                              Require stack:
                                requireStack: [
                              Node.js v18.17.1
                              Objects and States
                              Objects: 	0
                              States: 	0
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                              Pending Updates: 0
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:	11
                                Codename:	bullseye
                                VERSION_ID="11"
                                ID=debian
                                CPU threads: 4
                                Raspberry only:
                                throttled=0x0
                                temp=56.4'C
                                volt=0.8625V
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server: 	false
                                Desktop:
                                Terminal: 	tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                          103 M used memory
                                          248 M active memory
                                         2788 M free memory
                                          168 M buffer memory
                                          733 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /var:
                                1.4G	/var/
                                966M	/var/log
                                178M	/var/cache
                                /usr/bin/npm 		9.6.7
                                /usr/bin/npx 		9.6.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                js-controller:
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                admin:
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                javascript:
                                Adapter State
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                  throw err;
                                Require stack:
                                  requireStack: [
                                Node.js v18.17.1
                                Objects and States
                                Objects: 	0
                                States: 	0
                                Pending Updates: 0
                                @michaelxhoffmann
                                cd /opt/iobroker
                                  @michaelxhoffmann
                                  cd /opt/iobroker
                                  michaelxhoffmann
                                  Hat leider nicht funktioniert. :(
                                  npm ERR! code EINTEGRITY
                                  npm ERR! errno EINTEGRITY
                                  npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/axios: sha512-Yo0ZHtGUETLceWLfKlyrsjupDWUNYtNUAkblaOQBxzdQZTmcGTLdq9AmNS+nNIjXagoIZBFCa4vQc2oSL2Rh5g== integrity checksum failed when using sha512: wanted sha512-Yo0ZHtGUETLceWLfKlyrsjupDWUNYtNUAkblaOQBxzdQZTmcGTLdq9AmNS+nNIjXagoIZBFCa4vQc2oSL2Rh5g== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
                                  Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                    Keine Ahnung warum axios da mit anderer Prüfsumme aufwartet.
                                    • GlasfaserG Offline
                                      GlasfaserG Offline
                                      /usr/bin/npm 9.6.7
                                      /usr/bin/npx 9.6.7
                                      da passt was nicht .
                                      mache mal :
                                      sudo -H -u iobroker npm cache verify
                                      sudo -H -u iobroker npm cache clean --force
                                      sudo reboot
                                      dann
                                      cd /opt/iobroker
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @michaelxhoffmann
                                        könntest du bitte den Threadtitel anpassen auf 6.8.0
                                        ich dachte das wäre ein alter Thread ;)
                                        • GlasfaserG Glasfaser
                                          @michaelxhoffmann
                                          michaelxhoffmann
                                          @glasfaser :)) Wenn ich wüsste wie ich den Titel ändern kann würde ich's tun :))
