  4. Adapter lassen sich zum Teil nicht aktualisieren
    5.1k
33 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @cover1987
    zeige die Ausgabe von :
    iob upgrade admin --debug
    GlasfaserG Offline
    GlasfaserG Offline
    vorher noch
    iob update
    C 1 Antwort Letzte Antwort
      vorher noch
      iob update
      Cover1987
      schrieb am zuletzt editiert von Cover1987
      @glasfaser
      pi@raspberrypi-4-iobroker:~ $ iob update
      Used repository: stable
      Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "ble"          : 0.13.4   , installed 0.13.4
      Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "odl"          : 2.0.5    , installed 2.0.5
      Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
      Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
      Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
      Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
      und
      pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
      Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
      Update admin from @6.3.5 to @6.8.0
      host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
      NPM version: 8.19.4
      Installing iobroker.admin@6.8.0... (System call)
      npm WARN old lockfile
      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm WARN old lockfile Error: git dep preparation failed
      npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
      npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
      npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
      npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
      npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
      npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
      npm WARN old lockfile   cmd: '/usr/bin/node',
      npm WARN old lockfile   args: [
      npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
      npm WARN old lockfile     'install',
      npm WARN old lockfile     '--force',
      npm WARN old lockfile     '--cache=/home/iobroker/.npm',
      npm WARN old lockfile     '--prefer-offline=false',
      npm WARN old lockfile     '--prefer-online=false',
      npm WARN old lockfile     '--offline=false',
      npm WARN old lockfile     '--no-progress',
      npm WARN old lockfile     '--no-save',
      npm WARN old lockfile     '--no-audit',
      npm WARN old lockfile     '--include=dev',
      npm WARN old lockfile     '--include=peer',
      npm WARN old lockfile     '--include=optional',
      npm WARN old lockfile     '--no-package-lock-only',
      npm WARN old lockfile     '--no-dry-run'
      npm WARN old lockfile   ],
      npm WARN old lockfile   code: 1,
      npm WARN old lockfile   signal: null,
      npm WARN old lockfile   stdout: '\n' +
      npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
      npm WARN old lockfile     '> npip install\n' +
      npm WARN old lockfile     '\n' +
      npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
      npm WARN old lockfile     'Successfully completed pip check.\n' +
      npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
      npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
      npm WARN old lockfile     'Collecting tornado>=3.2\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
      npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
      npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
      npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
      npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
      npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
      npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
      npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
      npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
      npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
      npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
      npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
      npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
      npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
      npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
      npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
      npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
      npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
      npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
      npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
      npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
      npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
      npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
      npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
      npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
      npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
      npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
      npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
      npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
      npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
      npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
      npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
      npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
      npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
      npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
      npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
      npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
      npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
      npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
      npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
      npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
      npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
      npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
      npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
      npm WARN old lockfile     '  Installing build dependencies: started\n' +
      npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
      npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
      npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
      npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
      npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
      npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
      npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
      npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
      npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
      npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
      npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
      npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
      npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
      npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
      npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
      npm WARN old lockfile     'Failed to build cryptography\n',
      npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
      npm WARN old lockfile     'npm WARN old lockfile \n' +
      npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
      npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
      npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
      npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
      npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
      npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
      npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
      npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
      npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
      npm WARN old lockfile     '  \n' +
      npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
      npm WARN old lockfile     '  │ exit code: 1\n' +
      npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
      npm WARN old lockfile     '      running bdist_wheel\n' +
      npm WARN old lockfile     '      running build\n' +
      npm WARN old lockfile     '      running build_py\n' +
      npm WARN old lockfile     '      creating build\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
      npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
      npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
      npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
      npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
      npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
      npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
      npm WARN old lockfile }
      npm ERR! code 1
      npm ERR! git dep preparation failed
      npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      npm ERR! > iobroker.esphome@0.2.4 install
      npm ERR! > npip install
      npm ERR!
      npm ERR! No python_modules directory; installing pip locally if needed.
      npm ERR! Successfully completed pip check.
      npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      npm ERR! Collecting esphome>=2021.8
      npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
      npm ERR! Collecting tornado>=3.2
      npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
      npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
      npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
      npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
      npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
      npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
      npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
      npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
      npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
      npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
      npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
      npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
      npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
      npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
      npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
      npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
      npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
      npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
      npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
      npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
      npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
      npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
      npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
      npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
      npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
      npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
      npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
      npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
      npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
      npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
      npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
      npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
      npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
      npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
      npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
      npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
      npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
      npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
      npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
      npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
      npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
      npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
      npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
      npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
      npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
      npm ERR!   Installing build dependencies: started
      npm ERR!   Installing build dependencies: finished with status 'done'
      npm ERR!   Getting requirements to build wheel: started
      npm ERR!   Getting requirements to build wheel: finished with status 'done'
      npm ERR!   Preparing metadata (pyproject.toml): started
      npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
      npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
      npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
      npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
      npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
      npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
      npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
      npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
      npm ERR! Building wheels for collected packages: cryptography
      npm ERR!   Building wheel for cryptography (pyproject.toml): started
      npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
      npm ERR! Failed to build cryptography
      npm ERR! npm WARN using --force Recommended protections disabled.
      npm ERR! npm WARN old lockfile
      npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
      npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
      npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
      npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
      npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
      npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
      npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
      npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
      npm ERR! Cache entry deserialization failed, entry ignored
      npm ERR!   error: subprocess-exited-with-error
      npm ERR!
      npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
      npm ERR!   │ exit code: 1
      npm ERR!   ╰─> [172 lines of output]
      npm ERR!       running bdist_wheel
      npm ERR!       running build
      npm ERR!       running build_py
      npm ERR!       creating build
      npm ERR!       creating build/lib.linux-armv7l-cpython-37
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
      npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
      npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
      npm ERR!       running egg_info
      npm ERR!       writing src/cryptography.egg-info/PKG-INFO
      npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
      npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
      npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
      npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
      npm ERR!       reading manifest template 'MANIFEST.in'
      npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
      npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
      npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
      npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
      npm ERR!       no previously-included directories found matching 'docs/_build'
      npm ERR!       warning: no previously-included files found matching 'vectors'
      npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
      npm ERR!       warning: no previously-included files found matching 'src/rust/target'
      npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
      npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
      npm ERR!       warning: no previously-included files found matching 'release.py'
      npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
      npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
      npm ERR!       warning: no previously-included files found matching 'mypy.ini'
      npm ERR!       adding license file 'LICENSE'
      npm ERR!       adding license file 'LICENSE.APACHE'
      npm ERR!       adding license file 'LICENSE.BSD'
      npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
      npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
      npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
      npm ERR!       running build_ext
      npm ERR!       running build_rust
      npm ERR!
      npm ERR!           =============================DEBUG ASSISTANCE=============================
      npm ERR!           If you are seeing a compilation error please try the following steps to
      npm ERR!           successfully install cryptography:
      npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
      npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
      npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
      npm ERR!              instructions for your platform.
      npm ERR!           3) Check our frequently asked questions for more information:
      npm ERR!              https://cryptography.io/en/latest/faq/
      npm ERR!           4) Ensure you have a recent Rust toolchain installed:
      npm ERR!              https://cryptography.io/en/latest/installation/#rust
      npm ERR!
      npm ERR!           Python: 3.7.3
      npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
      npm ERR!           pip: n/a
      npm ERR!           setuptools: 68.0.0
      npm ERR!           setuptools_rust: 1.6.0
      npm ERR!           rustc: n/a
      npm ERR!
      npm ERR!       error: can't find Rust compiler
      npm ERR!
      npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
      npm ERR!
      npm ERR!       To update pip, run:
      npm ERR!
      npm ERR!           pip install --upgrade pip
      npm ERR!
      npm ERR!       and then retry package installation.
      npm ERR!
      npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
      npm ERR!
      npm ERR!       This package requires Rust >=1.56.0.
      npm ERR!       [end of output]
      npm ERR!
      npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
      npm ERR!   ERROR: Failed building wheel for cryptography
      npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
      npm ERR! npm ERR! code 1
      npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
      npm ERR! npm ERR! command failed
      npm ERR! npm ERR! command sh -c -- npip install
      npm ERR!
      npm ERR! npm ERR! A complete log of this run can be found in:
      npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
      npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
      upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
      upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
      upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
      upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
      upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
      upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
      upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
      upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
      upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
      upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
      upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
      upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
      upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
      host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
      Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
      • C Cover1987
        @glasfaser
        pi@raspberrypi-4-iobroker:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "odl"          : 2.0.5    , installed 2.0.5
        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
        Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
        und
        pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
        Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
        Update admin from @6.3.5 to @6.8.0
        host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
        NPM version: 8.19.4
        Installing iobroker.admin@6.8.0... (System call)
        npm WARN old lockfile Error: git dep preparation failed
        npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
        npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
        npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
        npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
        npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
        npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
        npm WARN old lockfile   cmd: '/usr/bin/node',
        npm WARN old lockfile   args: [
        npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
        npm WARN old lockfile     'install',
        npm WARN old lockfile     '--force',
        npm WARN old lockfile     '--cache=/home/iobroker/.npm',
        npm WARN old lockfile     '--prefer-offline=false',
        npm WARN old lockfile     '--prefer-online=false',
        npm WARN old lockfile     '--offline=false',
        npm WARN old lockfile     '--no-progress',
        npm WARN old lockfile     '--no-save',
        npm WARN old lockfile     '--no-audit',
        npm WARN old lockfile     '--include=dev',
        npm WARN old lockfile     '--include=peer',
        npm WARN old lockfile     '--include=optional',
        npm WARN old lockfile     '--no-package-lock-only',
        npm WARN old lockfile     '--no-dry-run'
        npm WARN old lockfile   ],
        npm WARN old lockfile   code: 1,
        npm WARN old lockfile   signal: null,
        npm WARN old lockfile   stdout: '\n' +
        npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
        npm WARN old lockfile     '> npip install\n' +
        npm WARN old lockfile     '\n' +
        npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
        npm WARN old lockfile     'Successfully completed pip check.\n' +
        npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
        npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
        npm WARN old lockfile     'Collecting tornado>=3.2\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
        npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
        npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
        npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
        npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
        npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
        npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
        npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
        npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
        npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
        npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
        npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
        npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
        npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
        npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
        npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
        npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
        npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
        npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
        npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
        npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
        npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
        npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
        npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
        npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
        npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
        npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
        npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
        npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
        npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
        npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
        npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
        npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
        npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
        npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
        npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
        npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
        npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
        npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
        npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
        npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
        npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
        npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
        npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
        npm WARN old lockfile     '  Installing build dependencies: started\n' +
        npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
        npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
        npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
        npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
        npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
        npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
        npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
        npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
        npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
        npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
        npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
        npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
        npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
        npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
        npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
        npm WARN old lockfile     'Failed to build cryptography\n',
        npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
        npm WARN old lockfile     'npm WARN old lockfile \n' +
        npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
        npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
        npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
        npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
        npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
        npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
        npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
        npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
        npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
        npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
        npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
        npm WARN old lockfile     '  \n' +
        npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
        npm WARN old lockfile     '  │ exit code: 1\n' +
        npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
        npm WARN old lockfile     '      running bdist_wheel\n' +
        npm WARN old lockfile     '      running build\n' +
        npm WARN old lockfile     '      running build_py\n' +
        npm WARN old lockfile     '      creating build\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
        npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
        npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
        npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
        npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
        npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
        npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
        npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
        npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
        npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
        npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
        npm WARN old lockfile }
        npm ERR! code 1
        npm ERR! git dep preparation failed
        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
        npm ERR! > iobroker.esphome@0.2.4 install
        npm ERR! > npip install
        npm ERR!
        npm ERR! No python_modules directory; installing pip locally if needed.
        npm ERR! Successfully completed pip check.
        npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
        npm ERR! Collecting esphome>=2021.8
        npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
        npm ERR! Collecting tornado>=3.2
        npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
        npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
        npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
        npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
        npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
        npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
        npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
        npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
        npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
        npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
        npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
        npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
        npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
        npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
        npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
        npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
        npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
        npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
        npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
        npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
        npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
        npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
        npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
        npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
        npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
        npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
        npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
        npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
        npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
        npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
        npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
        npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
        npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
        npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
        npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
        npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
        npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
        npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
        npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
        npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
        npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
        npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
        npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
        npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
        npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
        npm ERR!   Installing build dependencies: started
        npm ERR!   Installing build dependencies: finished with status 'done'
        npm ERR!   Getting requirements to build wheel: started
        npm ERR!   Getting requirements to build wheel: finished with status 'done'
        npm ERR!   Preparing metadata (pyproject.toml): started
        npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
        npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
        npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
        npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
        npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
        npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
        npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
        npm ERR! Building wheels for collected packages: cryptography
        npm ERR!   Building wheel for cryptography (pyproject.toml): started
        npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
        npm ERR! Failed to build cryptography
        npm ERR! npm WARN using --force Recommended protections disabled.
        npm ERR! npm WARN old lockfile
        npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
        npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
        npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
        npm ERR! Cache entry deserialization failed, entry ignored
        npm ERR!   error: subprocess-exited-with-error
        npm ERR!
        npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
        npm ERR!   │ exit code: 1
        npm ERR!   ╰─> [172 lines of output]
        npm ERR!       running bdist_wheel
        npm ERR!       running build_py
        npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
        npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
        npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
        npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       running egg_info
        npm ERR!       writing src/cryptography.egg-info/PKG-INFO
        npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
        npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
        npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
        npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
        npm ERR!       reading manifest template 'MANIFEST.in'
        npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
        npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
        npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
        npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
        npm ERR!       no previously-included directories found matching 'docs/_build'
        npm ERR!       warning: no previously-included files found matching 'vectors'
        npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
        npm ERR!       warning: no previously-included files found matching 'src/rust/target'
        npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
        npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
        npm ERR!       warning: no previously-included files found matching 'release.py'
        npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
        npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
        npm ERR!       warning: no previously-included files found matching 'mypy.ini'
        npm ERR!       adding license file 'LICENSE'
        npm ERR!       adding license file 'LICENSE.APACHE'
        npm ERR!       adding license file 'LICENSE.BSD'
        npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
        npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       running build_ext
        npm ERR!       running build_rust
        npm ERR!
        npm ERR!           =============================DEBUG ASSISTANCE=============================
        npm ERR!           If you are seeing a compilation error please try the following steps to
        npm ERR!           successfully install cryptography:
        npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
        npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
        npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
        npm ERR!              instructions for your platform.
        npm ERR!           3) Check our frequently asked questions for more information:
        npm ERR!              https://cryptography.io/en/latest/faq/
        npm ERR!           4) Ensure you have a recent Rust toolchain installed:
        npm ERR!              https://cryptography.io/en/latest/installation/#rust
        npm ERR!
        npm ERR!           Python: 3.7.3
        npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
        npm ERR!           pip: n/a
        npm ERR!           setuptools: 68.0.0
        npm ERR!           setuptools_rust: 1.6.0
        npm ERR!           rustc: n/a
        npm ERR!
        npm ERR!       error: can't find Rust compiler
        npm ERR!
        npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
        npm ERR!
        npm ERR!       To update pip, run:
        npm ERR!
        npm ERR!           pip install --upgrade pip
        npm ERR!
        npm ERR!       and then retry package installation.
        npm ERR!
        npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
        npm ERR!
        npm ERR!       This package requires Rust >=1.56.0.
        npm ERR!       [end of output]
        npm ERR!
        npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
        npm ERR!   ERROR: Failed building wheel for cryptography
        npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
        npm ERR! npm ERR! code 1
        npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
        npm ERR! npm ERR! command failed
        npm ERR! npm ERR! command sh -c -- npip install
        npm ERR!
        npm ERR! npm ERR! A complete log of this run can be found in:
        npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
        npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
        upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
        Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
        GlasfaserG Offline
        GlasfaserG Offline
        @cover1987
        Nee .. keine Ahnung was du da mal quer installiert hast .
        Wichtig .. ein Backup hast du !!!
        mach mal :
        iob stop
        find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
        iob fix
        iob start
        C 1 Antwort Letzte Antwort
        • GlasfaserG Glasfaser
          @cover1987
          mach mal :
          iob stop
          iob fix
          iob start
          Cover1987
          @glasfaser
          Ja Backup ist vorhanden
          pi@raspberrypi-4-iobroker:~ $ iob stop
          pi@raspberrypi-4-iobroker:~ $ find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
          pi@raspberrypi-4-iobroker:~ $ iob fix
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2023-04-02
              You might need to enter your password a couple of times.
              Installing prerequisites (1/5)
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/5)
              Check and cleanup npm temporary directories (3/5)
          Done.
              Database maintenance (4/5)
          Checking for uncompressed JSONL databases... This might take a while!
          Compressing /opt/iobroker/iobroker-data/states.jsonl
          Compressing /opt/iobroker/iobroker-data/objects.jsonl
          Compressed 2 JSONL files. Done
              Checking autostart (5/5)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi-4-iobroker:~ $ iob start
          • C Cover1987
            @glasfaser
            library: loaded
            Installed gcc-c++
            Done.
            Autostart enabled!
            GlasfaserG Offline
            GlasfaserG Offline
            @cover1987
            jetzt nochmal
            iob update
            iob upgrade admin --debug
              @cover1987
              jetzt nochmal
              iob update
              Cover1987
              @glasfaser
              pi@raspberrypi-4-iobroker:~ $ iob update
              Used repository: stable
              Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
              Adapter    "ble"          : 0.13.4   , installed 0.13.4
              Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "ical"         : 1.13.3   , installed 1.13.3
              Adapter    "javascript"   : 7.0.3    , installed 7.0.3
              Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
              Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
              Adapter    "odl"          : 2.0.5    , installed 2.0.5
              Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
              Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
              Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
              Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
              Adapter    "wled"         : 0.6.7    , installed 0.6.7
              Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
              Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
              pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
              Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
              Update admin from @6.3.5 to @6.8.0
              host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
              NPM version: 8.19.4
              Installing iobroker.admin@6.8.0... (System call)
              npm ERR! code 1
              npm ERR!
              npm ERR!
              npm ERR!       /tmp/pip-build-env-euzi8jyh/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
              npm ERR!
              npm ERR!
              npm ERR!           pip: n/a
              npm ERR!           rustc: n/a
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR!
              npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneqgjV2V
              npm ERR!
              npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_54_10_933Z-debug-0.log
              npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_53_58_978Z-debug-0.log
              • C Cover1987
                @glasfaser
                NPM version: 8.19.4
                npm ERR! code 1
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!           pip: n/a
                npm ERR!           rustc: n/a
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                npm ERR!
                GlasfaserG Offline
                GlasfaserG Offline
                @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
                puhh da klemmt was ..
                sieht nach dem aus , bzw. mach das mal
                https://forum.iobroker.net/post/997137
                  Cover1987
                  @glasfaser
                  pi@raspberrypi-4-iobroker:/lib/python3.7 $ python3 --version
                  Python 3.7.3
                  pi@raspberrypi-4-iobroker:/ $ sudo mv /lib/python3.7/EXTERNALLY-MANAGED ~
                  mv: cannot stat '/lib/python3.7/EXTERNALLY-MANAGED': No such file or directory
                  • C Cover1987
                    @glasfaser
                    Python 3.7.3
                    GlasfaserG Offline
                    GlasfaserG Offline
                    hast du weiter gelesen im Thread das war nur ein Namensvorschlag !
                      Cover1987
                      @glasfaser
                      Ja, den Namen habe ich auf meine Python 3 Version (3.7.3, dementsprechend 3.7) angepasst. Im Verzeichnis habe ich manuell auch kein EXTERNALLY-MANAGED gefunden.
                      • C Cover1987
                        @glasfaser
                        Python 3.7.3
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @cover1987
                        ls -lAh /lib/python3.7*
                        sagt
                        • C Cover1987
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @cover1987
                          mach mal das
                          pip install --upgrade Rust
                            @cover1987
                            sagt
                            Cover1987
                            @glasfaser
                            total 4.7M
                            -rw-r--r-- 1 root root 5.5K Jun 29 20:03 abc.py
                            -rw-r--r-- 1 root root  33K Jun 29 20:03 aifc.py
                            -rw-r--r-- 1 root root  477 Jun 29 20:03 antigravity.py
                            -rw-r--r-- 1 root root  94K Jun 29 20:03 argparse.py
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 ast.py
                            -rw-r--r-- 1 root root  12K Jun 29 20:03 asynchat.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 asyncio
                            -rw-r--r-- 1 root root  20K Jun 29 20:03 asyncore.py
                            -rwxr-xr-x 1 root root  20K Jun 29 20:03 base64.py
                            -rw-r--r-- 1 root root  31K Jun 29 20:03 bdb.py
                            -rw-r--r-- 1 root root  14K Jun 29 20:03 binhex.py
                            -rw-r--r-- 1 root root 2.5K Jun 29 20:03 bisect.py
                            -rw-r--r-- 1 root root 1.8K Jun 29 20:03 _bootlocale.py
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 bz2.py
                            -rw-r--r-- 1 root root  25K Jun 29 20:03 calendar.py
                            -rwxr-xr-x 1 root root  34K Jun 29 20:03 cgi.py
                            -rw-r--r-- 1 root root  12K Jun 29 20:03 cgitb.py
                            -rw-r--r-- 1 root root 5.4K Jun 29 20:03 chunk.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 cmd.py
                            -rw-r--r-- 1 root root  36K Jun 29 20:03 codecs.py
                            -rw-r--r-- 1 root root 5.9K Jun 29 20:03 codeop.py
                            -rw-r--r-- 1 root root  11K Jun 29 20:03 code.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:26 collections
                            -rw-r--r-- 1 root root  26K Jun 29 20:03 _collections_abc.py
                            -rw-r--r-- 1 root root 4.0K Jun 29 20:03 colorsys.py
                            -rw-r--r-- 1 root root 8.6K Jun 29 20:03 _compat_pickle.py
                            -rw-r--r-- 1 root root  14K Jun 29 20:03 compileall.py
                            -rw-r--r-- 1 root root 5.3K Jun 29 20:03 _compression.py
                            drwxr-xr-x 4 root root 4.0K Aug 21 13:27 concurrent
                            drwxr-xr-x 2 root root 4.0K Aug 21 13:25 config-3.7m-arm-linux-gnueabihf
                            -rw-r--r-- 1 root root  54K Jun 29 20:03 configparser.py
                            -rw-r--r-- 1 root root  24K Jun 29 20:03 contextlib.py
                            -rw-r--r-- 1 root root  129 Jun 29 20:03 contextvars.py
                            -rw-r--r-- 1 root root 8.7K Jun 29 20:03 copy.py
                            -rw-r--r-- 1 root root 6.9K Jun 29 20:03 copyreg.py
                            -rwxr-xr-x 1 root root 5.7K Jun 29 20:03 cProfile.py
                            -rw-r--r-- 1 root root 3.3K Jun 29 20:03 crypt.py
                            -rw-r--r-- 1 root root  16K Jun 29 20:03 csv.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 ctypes
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 curses
                            -rw-r--r-- 1 root root  48K Jun 29 20:03 dataclasses.py
                            -rw-r--r-- 1 root root  85K Jun 29 20:03 datetime.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 dbm
                            -rw-r--r-- 1 root root  320 Jun 29 20:03 decimal.py
                            -rw-r--r-- 1 root root  83K Jun 29 20:03 difflib.py
                            -rw-r--r-- 1 root root  20K Jun 29 20:03 dis.py
                            drwxr-xr-x 4 root root 4.0K Aug 21 13:25 distutils
                            -rw-r--r-- 1 root root 102K Jun 29 20:03 doctest.py
                            -rw-r--r-- 1 root root 2.8K Jun 29 20:03 dummy_threading.py
                            -rw-r--r-- 1 root root 5.0K Jun 29 20:03 _dummy_thread.py
                            drwxr-xr-x 4 root root 4.0K Aug 21 13:27 email
                            drwxr-xr-x 3 root root  20K Aug 21 13:26 encodings
                            -rw-r--r-- 1 root root  34K Jun 29 20:03 enum.py
                            -rw-r--r-- 1 root root 9.6K Jun 29 20:03 filecmp.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 fileinput.py
                            -rw-r--r-- 1 root root 4.0K Jun 29 20:03 fnmatch.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 formatter.py
                            -rw-r--r-- 1 root root  24K Jun 29 20:03 fractions.py
                            -rw-r--r-- 1 root root  35K Jun 29 20:03 ftplib.py
                            -rw-r--r-- 1 root root  32K Jun 29 20:03 functools.py
                            -rw-r--r-- 1 root root 5.0K Jun 29 20:03 __future__.py
                            -rw-r--r-- 1 root root 4.7K Jun 29 20:03 genericpath.py
                            -rw-r--r-- 1 root root 7.4K Jun 29 20:03 getopt.py
                            -rw-r--r-- 1 root root 5.9K Jun 29 20:03 getpass.py
                            -rw-r--r-- 1 root root  22K Jun 29 20:03 gettext.py
                            -rw-r--r-- 1 root root 5.6K Jun 29 20:03 glob.py
                            -rw-r--r-- 1 root root  20K Jun 29 20:03 gzip.py
                            -rw-r--r-- 1 root root 9.4K Jun 29 20:03 hashlib.py
                            -rw-r--r-- 1 root root  23K Jun 29 20:03 heapq.py
                            -rw-r--r-- 1 root root 6.4K Jun 29 20:03 hmac.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 html
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 http
                            -rw-r--r-- 1 root root  53K Jun 29 20:03 imaplib.py
                            -rw-r--r-- 1 root root 3.8K Jun 29 20:03 imghdr.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 importlib
                            -rw-r--r-- 1 root root  11K Jun 29 20:03 imp.py
                            -rw-r--r-- 1 root root 115K Jun 29 20:03 inspect.py
                            -rw-r--r-- 1 root root 3.5K Jun 29 20:03 io.py
                            -rw-r--r-- 1 root root  74K Jun 29 20:03 ipaddress.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 json
                            -rwxr-xr-x 1 root root 2.2K Jun 29 20:03 keyword.py
                            drwxr-xr-x 5 root root 4.0K Apr 11  2021 lib2to3
                            drwxr-xr-x 2 root root  12K Aug 21 13:25 lib-dynload
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 LICENSE.txt
                            -rw-r--r-- 1 root root 5.2K Jun 29 20:03 linecache.py
                            -rw-r--r-- 1 root root  77K Jun 29 20:03 locale.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:26 logging
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 lzma.py
                            -rw-r--r-- 1 root root 6.0K Jun 29 20:03 macpath.py
                            -rw-r--r-- 1 root root  77K Jun 29 20:03 mailbox.py
                            -rw-r--r-- 1 root root 8.9K Jun 29 20:03 mailcap.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 _markupbase.py
                            -rw-r--r-- 1 root root  21K Jun 29 20:03 mimetypes.py
                            -rw-r--r-- 1 root root  23K Jun 29 20:03 modulefinder.py
                            drwxr-xr-x 4 root root 4.0K Aug 21 13:27 multiprocessing
                            -rw-r--r-- 1 root root 5.5K Jun 29 20:03 netrc.py
                            -rw-r--r-- 1 root root  43K Jun 29 20:03 nntplib.py
                            -rw-r--r-- 1 root root  22K Jun 29 20:03 ntpath.py
                            -rw-r--r-- 1 root root 2.6K Jun 29 20:03 nturl2path.py
                            -rw-r--r-- 1 root root  11K Jun 29 20:03 numbers.py
                            -rw-r--r-- 1 root root 5.7K Jun 29 20:03 opcode.py
                            -rw-r--r-- 1 root root  11K Jun 29 20:03 operator.py
                            -rw-r--r-- 1 root root  59K Jun 29 20:03 optparse.py
                            -rw-r--r-- 1 root root  37K Jun 29 20:03 os.py
                            -rw-r--r-- 1 root root  19K Jun 29 20:03 _osx_support.py
                            -rw-r--r-- 1 root root  49K Jun 29 20:03 pathlib.py
                            -rwxr-xr-x 1 root root  62K Jun 29 20:03 pdb.py
                            -rw-r--r-- 1 root root   64 Jun 29 20:03 __phello__.foo.py
                            -rw-r--r-- 1 root root  57K Jun 29 20:03 pickle.py
                            -rw-r--r-- 1 root root  90K Jun 29 20:03 pickletools.py
                            -rw-r--r-- 1 root root 8.8K Jun 29 20:03 pipes.py
                            -rw-r--r-- 1 root root  21K Jun 29 20:03 pkgutil.py
                            -rwxr-xr-x 1 root root  47K Jun 29 20:03 platform.py
                            -rw-r--r-- 1 root root  30K Jun 29 20:03 plistlib.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 poplib.py
                            -rw-r--r-- 1 root root  16K Jun 29 20:03 posixpath.py
                            -rw-r--r-- 1 root root  21K Jun 29 20:03 pprint.py
                            -rwxr-xr-x 1 root root  22K Jun 29 20:03 profile.py
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 pstats.py
                            -rw-r--r-- 1 root root 4.7K Jun 29 20:03 pty.py
                            -rw-r--r-- 1 root root 6.1K Jun 29 20:03 _py_abc.py
                            drwxr-xr-x 2 root root  12K Aug 21 13:27 __pycache__
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 pyclbr.py
                            -rw-r--r-- 1 root root 7.9K Jun 29 20:03 py_compile.py
                            -rw-r--r-- 1 root root 224K Jun 29 20:03 _pydecimal.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 pydoc_data
                            -rwxr-xr-x 1 root root 104K Jun 29 20:03 pydoc.py
                            -rw-r--r-- 1 root root  90K Jun 29 20:03 _pyio.py
                            -rw-r--r-- 1 root root  12K Jun 29 20:03 queue.py
                            -rwxr-xr-x 1 root root 7.1K Jun 29 20:03 quopri.py
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 random.py
                            -rw-r--r-- 1 root root 5.2K Jun 29 20:03 reprlib.py
                            -rw-r--r-- 1 root root  15K Jun 29 20:03 re.py
                            -rw-r--r-- 1 root root 7.0K Jun 29 20:03 rlcompleter.py
                            -rw-r--r-- 1 root root  12K Jun 29 20:03 runpy.py
                            -rw-r--r-- 1 root root 6.3K Jun 29 20:03 sched.py
                            -rw-r--r-- 1 root root 2.0K Jun 29 20:03 secrets.py
                            -rw-r--r-- 1 root root  19K Jun 29 20:03 selectors.py
                            -rw-r--r-- 1 root root 8.4K Jun 29 20:03 shelve.py
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 shlex.py
                            -rw-r--r-- 1 root root  41K Jun 29 20:03 shutil.py
                            -rw-r--r-- 1 root root 2.1K Jun 29 20:03 signal.py
                            -rw-r--r-- 1 root root 3.1K Jun 29 20:03 _sitebuiltins.py
                            lrwxrwxrwx 1 root root   31 Jun 29 20:03 sitecustomize.py -> /etc/python3.7/sitecustomize.py
                            -rw-r--r-- 1 root root  23K Jun 29 20:03 site.py
                            -rwxr-xr-x 1 root root  34K Jun 29 20:03 smtpd.py
                            -rwxr-xr-x 1 root root  44K Jun 29 20:03 smtplib.py
                            -rw-r--r-- 1 root root 7.0K Jun 29 20:03 sndhdr.py
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 socket.py
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 socketserver.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 sqlite3
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 sre_compile.py
                            -rw-r--r-- 1 root root 7.1K Jun 29 20:03 sre_constants.py
                            -rw-r--r-- 1 root root  39K Jun 29 20:03 sre_parse.py
                            -rw-r--r-- 1 root root  45K Jun 29 20:03 ssl.py
                            -rw-r--r-- 1 root root  21K Jun 29 20:03 statistics.py
                            -rw-r--r-- 1 root root 5.0K Jun 29 20:03 stat.py
                            -rw-r--r-- 1 root root  13K Jun 29 20:03 stringprep.py
                            -rw-r--r-- 1 root root  12K Jun 29 20:03 string.py
                            -rw-r--r-- 1 root root  25K Jun 29 20:03 _strptime.py
                            -rw-r--r-- 1 root root  257 Jun 29 20:03 struct.py
                            -rw-r--r-- 1 root root  69K Jun 29 20:03 subprocess.py
                            -rw-r--r-- 1 root root  18K Jun 29 20:03 sunau.py
                            -rwxr-xr-x 1 root root 2.1K Jun 29 20:03 symbol.py
                            -rw-r--r-- 1 root root 7.2K Jun 29 20:03 symtable.py
                            -rw-r--r-- 1 root root  24K Jun 29 20:03 _sysconfigdata_m_linux_arm-linux-gnueabihf.py
                            -rw-r--r-- 1 root root  24K Jun 29 20:03 sysconfig.py
                            -rwxr-xr-x 1 root root  12K Jun 29 20:03 tabnanny.py
                            -rwxr-xr-x 1 root root  91K Jun 29 20:03 tarfile.py
                            -rw-r--r-- 1 root root  23K Jun 29 20:03 telnetlib.py
                            -rw-r--r-- 1 root root  32K Jun 29 20:03 tempfile.py
                            drwxr-xr-x 5 root root 4.0K Aug 21 13:27 test
                            -rw-r--r-- 1 root root  20K Jun 29 20:03 textwrap.py
                            -rw-r--r-- 1 root root 1003 Jun 29 20:03 this.py
                            -rw-r--r-- 1 root root 7.1K Jun 29 20:03 _threading_local.py
                            -rw-r--r-- 1 root root  47K Jun 29 20:03 threading.py
                            -rwxr-xr-x 1 root root  14K Jun 29 20:03 timeit.py
                            -rw-r--r-- 1 root root  27K Jun 29 20:03 tokenize.py
                            -rw-r--r-- 1 root root 3.7K Jun 29 20:03 token.py
                            -rw-r--r-- 1 root root  23K Jun 29 20:03 traceback.py
                            -rw-r--r-- 1 root root  17K Jun 29 20:03 tracemalloc.py
                            -rwxr-xr-x 1 root root  28K Jun 29 20:03 trace.py
                            -rw-r--r-- 1 root root  879 Jun 29 20:03 tty.py
                            -rw-r--r-- 1 root root 141K Jun 29 20:03 turtle.py
                            -rw-r--r-- 1 root root 9.7K Jun 29 20:03 types.py
                            -rw-r--r-- 1 root root  54K Jun 29 20:03 typing.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 unittest
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 urllib
                            -rw-r--r-- 1 root root  29K Jun 29 20:03 uuid.py
                            -rwxr-xr-x 1 root root 6.7K Jun 29 20:03 uu.py
                            drwxr-xr-x 4 root root 4.0K Aug 21 13:27 venv
                            -rw-r--r-- 1 root root  20K Jun 29 20:03 warnings.py
                            -rw-r--r-- 1 root root  18K Jun 29 20:03 wave.py
                            -rw-r--r-- 1 root root  21K Jun 29 20:03 weakref.py
                            -rw-r--r-- 1 root root 5.6K Jun 29 20:03 _weakrefset.py
                            -rwxr-xr-x 1 root root  23K Jun 29 20:03 webbrowser.py
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 wsgiref
                            -rw-r--r-- 1 root root 5.8K Jun 29 20:03 xdrlib.py
                            drwxr-xr-x 7 root root 4.0K Aug 21 13:27 xml
                            drwxr-xr-x 3 root root 4.0K Aug 21 13:27 xmlrpc
                            -rw-r--r-- 1 root root 7.4K Jun 29 20:03 zipapp.py
                            -rw-r--r-- 1 root root  79K Jun 29 20:03 zipfile.py
                              @cover1987
                              mach mal das
                              Cover1987
                              @glasfaser
                              pi@raspberrypi-4-iobroker:/ $ pip install --upgrade Rust
                              Defaulting to user installation because normal site-packages is not writeable
                              Collecting Rust
                               Downloading https://www.piwheels.org/simple/rust/RUST-0.1.1-py3-none-any.whl (30 kB)
                              Collecting biopython (from Rust)
                               Downloading https://www.piwheels.org/simple/biopython/biopython-1.81-cp37-cp37m-linux_armv7l.whl (2.8 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.8/2.8 MB 3.1 MB/s eta 0:00:00
                              Collecting matplotlib (from Rust)
                               Downloading https://www.piwheels.org/simple/matplotlib/matplotlib-3.5.3-cp37-cp37m-linux_armv7l.whl (8.9 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 8.9/8.9 MB 5.3 MB/s eta 0:00:00
                              Collecting mock<=1.0.1 (from Rust)
                               Downloading https://www.piwheels.org/simple/mock/mock-1.0.1-py3-none-any.whl (26 kB)
                              Collecting pysam (from Rust)
                               Downloading https://www.piwheels.org/simple/pysam/pysam-0.21.0-cp37-cp37m-linux_armv7l.whl (9.0 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.0/9.0 MB 5.8 MB/s eta 0:00:00
                              Collecting numpy (from biopython->Rust)
                               Downloading numpy-1.21.6.zip (10.3 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 10.3/10.3 MB 5.4 MB/s eta 0:00:00
                               Installing build dependencies ... done
                               Getting requirements to build wheel ... done
                               Preparing metadata (pyproject.toml) ... done
                              Collecting cycler>=0.10 (from matplotlib->Rust)
                               Downloading https://www.piwheels.org/simple/cycler/cycler-0.11.0-py3-none-any.whl (6.4 kB)
                              Collecting fonttools>=4.22.0 (from matplotlib->Rust)
                               Downloading https://www.piwheels.org/simple/fonttools/fonttools-4.38.0-cp37-cp37m-linux_armv7l.whl (1.7 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 2.4 MB/s eta 0:00:00
                              Collecting kiwisolver>=1.0.1 (from matplotlib->Rust)
                               Downloading https://www.piwheels.org/simple/kiwisolver/kiwisolver-1.4.4-cp37-cp37m-linux_armv7l.whl (530 kB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 530.4/530.4 kB 1.7 MB/s eta 0:00:00
                              Requirement already satisfied: packaging>=20.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (23.1)
                              Requirement already satisfied: pillow>=6.2.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (9.5.0)
                              Collecting pyparsing>=2.2.1 (from matplotlib->Rust)
                               Downloading https://www.piwheels.org/simple/pyparsing/pyparsing-3.1.1-py3-none-any.whl (103 kB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 103.1/103.1 kB 2.4 MB/s eta 0:00:00
                              Collecting python-dateutil>=2.7 (from matplotlib->Rust)
                               Downloading https://www.piwheels.org/simple/python-dateutil/python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 247.7/247.7 kB 3.9 MB/s eta 0:00:00
                              Collecting cython (from pysam->Rust)
                               Downloading https://www.piwheels.org/simple/cython/Cython-3.0.0-cp37-cp37m-linux_armv7l.whl (4.3 MB)
                                  ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.3/4.3 MB 4.4 MB/s eta 0:00:00
                              Requirement already satisfied: typing-extensions in /home/pi/.local/lib/python3.7/site-packages (from kiwisolver>=1.0.1->matplotlib->Rust) (4.5.0)
                              Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.7->matplotlib->Rust) (1.12.0)
                              Building wheels for collected packages: numpy
                               Building wheel for numpy (pyproject.toml) ... done
                               Created wheel for numpy: filename=numpy-1.21.6-cp37-cp37m-linux_armv7l.whl size=15871852 sha256=941e9b10e4755023f4a6172659eb1adda2585823edcd71135728313ea39676f8
                               Stored in directory: /home/pi/.cache/pip/wheels/4e/7e/9e/0fde042ccff2493994076dac9c3fbd78feb444c3bd94eb386a
                              Successfully built numpy
                              Installing collected packages: mock, python-dateutil, pyparsing, numpy, kiwisolver, fonttools, cython, cycler, pysam, matplotlib, biopython, Rust
                              Successfully installed Rust-0.1.1 biopython-1.81 cycler-0.11.0 cython-3.0.0 fonttools-4.38.0 kiwisolver-1.4.4 matplotlib-3.5.3 mock-1.0.1 numpy-1.21.6 pyparsing-3.1.1 pysam-0.21.0 python-dateutil-2.8.2
                              [notice] A new release of pip is available: 23.1 -> 23.2.1
                              [notice] To update, run: python3 -m pip install --upgrade pip
                              pip direkt updaten? Oder erstmal nochmal
                              iob update
                              probieren?
                              • C Cover1987
                                @glasfaser
                                Collecting Rust
                                iob update
                                probieren?
                                Cover1987
                                Hat keiner mehr einen Tip?
                                gibt immer noch das gleiche zurück
                                DJMarc75D crunchipC 2 Antworten Letzte Antwort
                                • C Cover1987
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  jo, mach neu und spiel Dein Backup zurück.
                                  Lehrling seit 1975 !!!
                                  • C Cover1987
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @cover1987 ist da jetzt immer noch buster drauf?
                                    hast du mal den esp-home gelöscht und neu installiert?
                                      Cover1987
                                      @crunchip
                                      ESPHome habe ich deinstalliert, Backup erstellt, bullseye drauf gemacht (komplett neu aufgesetzt), iobroker neu installiert, vis installiert, Backup wieder hergestellt. Alles bis auf ESPHome geht wieder. Weiß nicht ob ich ESPHome wieder installieren sollte, ohne dabei was kaputt zu machen.
                                      • C Cover1987
                                        @crunchip
                                        Kann man natürlich machen. Hinweise, was es da ggf. zu beachten gibt stehen ja hier bestimmt im Thread drin.
                                        So aus der Erinnerung:
                                        Sperrdatei 'EXTERNALLY_MANAGED' aus dem python-Pfad (zumindest temporär) rauswerfe, 'nopy' und das Drumherum auf die richtigen Rechte setzen.
                                          Cover1987
                                          Hat soweit funktioniert! Danke.
                                          Probleme sind soweit dann alle behoben.
                                          Danke an alle, die mir geholfen haben!
