  4. Adapter lassen sich zum Teil nicht aktualisieren
    5.1k
33 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @cover1987
    Nee .. keine Ahnung was du da mal quer installiert hast .
    Wichtig .. ein Backup hast du !!!
    mach mal :
    iob stop
    find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
    iob fix
    iob start
    Cover1987
    @glasfaser
    Ja Backup ist vorhanden
    pi@raspberrypi-4-iobroker:~ $ iob stop
    pi@raspberrypi-4-iobroker:~ $ find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
    pi@raspberrypi-4-iobroker:~ $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi-4-iobroker:~ $ iob start
    • C Cover1987
      @glasfaser
      library: loaded
      Installed gcc-c++
      Done.
      Autostart enabled!
      GlasfaserG Offline
      GlasfaserG Offline
      @cover1987
      jetzt nochmal
      iob update
      iob upgrade admin --debug
      C 1 Antwort Letzte Antwort
        @cover1987
        jetzt nochmal
        iob update
        Cover1987
        @glasfaser
        pi@raspberrypi-4-iobroker:~ $ iob update
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "odl"          : 2.0.5    , installed 2.0.5
        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
        Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
        pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
        Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
        Update admin from @6.3.5 to @6.8.0
        host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
        NPM version: 8.19.4
        Installing iobroker.admin@6.8.0... (System call)
        npm ERR! code 1
        npm ERR! git dep preparation failed
        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
        npm ERR! > iobroker.esphome@0.2.4 install
        npm ERR! > npip install
        npm ERR!
        npm ERR! No python_modules directory; installing pip locally if needed.
        npm ERR! Successfully completed pip check.
        npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
        npm ERR! Collecting esphome>=2021.8
        npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
        npm ERR! Collecting tornado>=3.2
        npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
        npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
        npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
        npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
        npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
        npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
        npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
        npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
        npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
        npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
        npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
        npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
        npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
        npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
        npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
        npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
        npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
        npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
        npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
        npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
        npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
        npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
        npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
        npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
        npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
        npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
        npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
        npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
        npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
        npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
        npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
        npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
        npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
        npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
        npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
        npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
        npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
        npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
        npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
        npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
        npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
        npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
        npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
        npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
        npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
        npm ERR!   Installing build dependencies: started
        npm ERR!   Installing build dependencies: finished with status 'done'
        npm ERR!   Getting requirements to build wheel: started
        npm ERR!   Getting requirements to build wheel: finished with status 'done'
        npm ERR!   Preparing metadata (pyproject.toml): started
        npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
        npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
        npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
        npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
        npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
        npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
        npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
        npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
        npm ERR! Building wheels for collected packages: cryptography
        npm ERR!   Building wheel for cryptography (pyproject.toml): started
        npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
        npm ERR! Failed to build cryptography
        npm ERR! npm WARN using --force Recommended protections disabled.
        npm ERR! npm WARN old lockfile
        npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
        npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
        npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
        npm ERR! Cache entry deserialization failed, entry ignored
        npm ERR!   error: subprocess-exited-with-error
        npm ERR!
        npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
        npm ERR!   │ exit code: 1
        npm ERR!   ╰─> [172 lines of output]
        npm ERR!       running bdist_wheel
        npm ERR!       running build
        npm ERR!       running build_py
        npm ERR!       creating build
        npm ERR!       creating build/lib.linux-armv7l-cpython-37
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
        npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
        npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
        npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
        npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
        npm ERR!       running egg_info
        npm ERR!       writing src/cryptography.egg-info/PKG-INFO
        npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
        npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
        npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
        npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
        npm ERR!       reading manifest template 'MANIFEST.in'
        npm ERR!       /tmp/pip-build-env-euzi8jyh/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
        npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
        npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
        npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
        npm ERR!       no previously-included directories found matching 'docs/_build'
        npm ERR!       warning: no previously-included files found matching 'vectors'
        npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
        npm ERR!       warning: no previously-included files found matching 'src/rust/target'
        npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
        npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
        npm ERR!       warning: no previously-included files found matching 'release.py'
        npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
        npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
        npm ERR!       warning: no previously-included files found matching 'mypy.ini'
        npm ERR!       adding license file 'LICENSE'
        npm ERR!       adding license file 'LICENSE.APACHE'
        npm ERR!       adding license file 'LICENSE.BSD'
        npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
        npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
        npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
        npm ERR!       running build_ext
        npm ERR!       running build_rust
        npm ERR!
        npm ERR!           =============================DEBUG ASSISTANCE=============================
        npm ERR!           If you are seeing a compilation error please try the following steps to
        npm ERR!           successfully install cryptography:
        npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
        npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
        npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
        npm ERR!              instructions for your platform.
        npm ERR!           3) Check our frequently asked questions for more information:
        npm ERR!              https://cryptography.io/en/latest/faq/
        npm ERR!           4) Ensure you have a recent Rust toolchain installed:
        npm ERR!              https://cryptography.io/en/latest/installation/#rust
        npm ERR!
        npm ERR!           Python: 3.7.3
        npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
        npm ERR!           pip: n/a
        npm ERR!           setuptools: 68.0.0
        npm ERR!           setuptools_rust: 1.6.0
        npm ERR!           rustc: n/a
        npm ERR!
        npm ERR!       error: can't find Rust compiler
        npm ERR!
        npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
        npm ERR!
        npm ERR!       To update pip, run:
        npm ERR!
        npm ERR!           pip install --upgrade pip
        npm ERR!
        npm ERR!       and then retry package installation.
        npm ERR!
        npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
        npm ERR!
        npm ERR!       This package requires Rust >=1.56.0.
        npm ERR!       [end of output]
        npm ERR!
        npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
        npm ERR!   ERROR: Failed building wheel for cryptography
        npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
        npm ERR! npm ERR! code 1
        npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneqgjV2V
        npm ERR! npm ERR! command failed
        npm ERR! npm ERR! command sh -c -- npip install
        npm ERR!
        npm ERR! npm ERR! A complete log of this run can be found in:
        npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_54_10_933Z-debug-0.log
        npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_53_58_978Z-debug-0.log
        upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
        upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
        upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
        upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
        upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
        upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
        upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
        upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
        upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
        • C Cover1987
          @glasfaser
          NPM version: 8.19.4
          npm ERR! code 1
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!           pip: n/a
          npm ERR!           rustc: n/a
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          npm ERR!
          GlasfaserG Offline
          GlasfaserG Offline
          @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
          puhh da klemmt was ..
          sieht nach dem aus , bzw. mach das mal
          https://forum.iobroker.net/post/997137
            Cover1987
            @glasfaser
            pi@raspberrypi-4-iobroker:/lib/python3.7 $ python3 --version
            Python 3.7.3
            pi@raspberrypi-4-iobroker:/ $ sudo mv /lib/python3.7/EXTERNALLY-MANAGED ~
            mv: cannot stat '/lib/python3.7/EXTERNALLY-MANAGED': No such file or directory
            • C Cover1987
              @glasfaser
              Python 3.7.3
              GlasfaserG Offline
              GlasfaserG Offline
              hast du weiter gelesen im Thread das war nur ein Namensvorschlag !
                Cover1987
                @glasfaser
                Ja, den Namen habe ich auf meine Python 3 Version (3.7.3, dementsprechend 3.7) angepasst. Im Verzeichnis habe ich manuell auch kein EXTERNALLY-MANAGED gefunden.
                • C Cover1987
                  @glasfaser
                  Python 3.7.3
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @cover1987
                  ls -lAh /lib/python3.7*
                  sagt
                  • C Cover1987
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @cover1987
                    mach mal das
                    pip install --upgrade Rust
                      @cover1987
                      sagt
                      Cover1987
                      @glasfaser
                      total 4.7M
                      -rw-r--r-- 1 root root 5.5K Jun 29 20:03 abc.py
                      -rw-r--r-- 1 root root  33K Jun 29 20:03 aifc.py
                      -rw-r--r-- 1 root root  477 Jun 29 20:03 antigravity.py
                      -rw-r--r-- 1 root root  94K Jun 29 20:03 argparse.py
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 ast.py
                      -rw-r--r-- 1 root root  12K Jun 29 20:03 asynchat.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 asyncio
                      -rw-r--r-- 1 root root  20K Jun 29 20:03 asyncore.py
                      -rwxr-xr-x 1 root root  20K Jun 29 20:03 base64.py
                      -rw-r--r-- 1 root root  31K Jun 29 20:03 bdb.py
                      -rw-r--r-- 1 root root  14K Jun 29 20:03 binhex.py
                      -rw-r--r-- 1 root root 2.5K Jun 29 20:03 bisect.py
                      -rw-r--r-- 1 root root 1.8K Jun 29 20:03 _bootlocale.py
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 bz2.py
                      -rw-r--r-- 1 root root  25K Jun 29 20:03 calendar.py
                      -rwxr-xr-x 1 root root  34K Jun 29 20:03 cgi.py
                      -rw-r--r-- 1 root root  12K Jun 29 20:03 cgitb.py
                      -rw-r--r-- 1 root root 5.4K Jun 29 20:03 chunk.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 cmd.py
                      -rw-r--r-- 1 root root  36K Jun 29 20:03 codecs.py
                      -rw-r--r-- 1 root root 5.9K Jun 29 20:03 codeop.py
                      -rw-r--r-- 1 root root  11K Jun 29 20:03 code.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:26 collections
                      -rw-r--r-- 1 root root  26K Jun 29 20:03 _collections_abc.py
                      -rw-r--r-- 1 root root 4.0K Jun 29 20:03 colorsys.py
                      -rw-r--r-- 1 root root 8.6K Jun 29 20:03 _compat_pickle.py
                      -rw-r--r-- 1 root root  14K Jun 29 20:03 compileall.py
                      -rw-r--r-- 1 root root 5.3K Jun 29 20:03 _compression.py
                      drwxr-xr-x 4 root root 4.0K Aug 21 13:27 concurrent
                      drwxr-xr-x 2 root root 4.0K Aug 21 13:25 config-3.7m-arm-linux-gnueabihf
                      -rw-r--r-- 1 root root  54K Jun 29 20:03 configparser.py
                      -rw-r--r-- 1 root root  24K Jun 29 20:03 contextlib.py
                      -rw-r--r-- 1 root root  129 Jun 29 20:03 contextvars.py
                      -rw-r--r-- 1 root root 8.7K Jun 29 20:03 copy.py
                      -rw-r--r-- 1 root root 6.9K Jun 29 20:03 copyreg.py
                      -rwxr-xr-x 1 root root 5.7K Jun 29 20:03 cProfile.py
                      -rw-r--r-- 1 root root 3.3K Jun 29 20:03 crypt.py
                      -rw-r--r-- 1 root root  16K Jun 29 20:03 csv.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 ctypes
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 curses
                      -rw-r--r-- 1 root root  48K Jun 29 20:03 dataclasses.py
                      -rw-r--r-- 1 root root  85K Jun 29 20:03 datetime.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 dbm
                      -rw-r--r-- 1 root root  320 Jun 29 20:03 decimal.py
                      -rw-r--r-- 1 root root  83K Jun 29 20:03 difflib.py
                      -rw-r--r-- 1 root root  20K Jun 29 20:03 dis.py
                      drwxr-xr-x 4 root root 4.0K Aug 21 13:25 distutils
                      -rw-r--r-- 1 root root 102K Jun 29 20:03 doctest.py
                      -rw-r--r-- 1 root root 2.8K Jun 29 20:03 dummy_threading.py
                      -rw-r--r-- 1 root root 5.0K Jun 29 20:03 _dummy_thread.py
                      drwxr-xr-x 4 root root 4.0K Aug 21 13:27 email
                      drwxr-xr-x 3 root root  20K Aug 21 13:26 encodings
                      -rw-r--r-- 1 root root  34K Jun 29 20:03 enum.py
                      -rw-r--r-- 1 root root 9.6K Jun 29 20:03 filecmp.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 fileinput.py
                      -rw-r--r-- 1 root root 4.0K Jun 29 20:03 fnmatch.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 formatter.py
                      -rw-r--r-- 1 root root  24K Jun 29 20:03 fractions.py
                      -rw-r--r-- 1 root root  35K Jun 29 20:03 ftplib.py
                      -rw-r--r-- 1 root root  32K Jun 29 20:03 functools.py
                      -rw-r--r-- 1 root root 5.0K Jun 29 20:03 __future__.py
                      -rw-r--r-- 1 root root 4.7K Jun 29 20:03 genericpath.py
                      -rw-r--r-- 1 root root 7.4K Jun 29 20:03 getopt.py
                      -rw-r--r-- 1 root root 5.9K Jun 29 20:03 getpass.py
                      -rw-r--r-- 1 root root  22K Jun 29 20:03 gettext.py
                      -rw-r--r-- 1 root root 5.6K Jun 29 20:03 glob.py
                      -rw-r--r-- 1 root root  20K Jun 29 20:03 gzip.py
                      -rw-r--r-- 1 root root 9.4K Jun 29 20:03 hashlib.py
                      -rw-r--r-- 1 root root  23K Jun 29 20:03 heapq.py
                      -rw-r--r-- 1 root root 6.4K Jun 29 20:03 hmac.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 html
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 http
                      -rw-r--r-- 1 root root  53K Jun 29 20:03 imaplib.py
                      -rw-r--r-- 1 root root 3.8K Jun 29 20:03 imghdr.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 importlib
                      -rw-r--r-- 1 root root  11K Jun 29 20:03 imp.py
                      -rw-r--r-- 1 root root 115K Jun 29 20:03 inspect.py
                      -rw-r--r-- 1 root root 3.5K Jun 29 20:03 io.py
                      -rw-r--r-- 1 root root  74K Jun 29 20:03 ipaddress.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 json
                      -rwxr-xr-x 1 root root 2.2K Jun 29 20:03 keyword.py
                      drwxr-xr-x 5 root root 4.0K Apr 11  2021 lib2to3
                      drwxr-xr-x 2 root root  12K Aug 21 13:25 lib-dynload
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 LICENSE.txt
                      -rw-r--r-- 1 root root 5.2K Jun 29 20:03 linecache.py
                      -rw-r--r-- 1 root root  77K Jun 29 20:03 locale.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:26 logging
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 lzma.py
                      -rw-r--r-- 1 root root 6.0K Jun 29 20:03 macpath.py
                      -rw-r--r-- 1 root root  77K Jun 29 20:03 mailbox.py
                      -rw-r--r-- 1 root root 8.9K Jun 29 20:03 mailcap.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 _markupbase.py
                      -rw-r--r-- 1 root root  21K Jun 29 20:03 mimetypes.py
                      -rw-r--r-- 1 root root  23K Jun 29 20:03 modulefinder.py
                      drwxr-xr-x 4 root root 4.0K Aug 21 13:27 multiprocessing
                      -rw-r--r-- 1 root root 5.5K Jun 29 20:03 netrc.py
                      -rw-r--r-- 1 root root  43K Jun 29 20:03 nntplib.py
                      -rw-r--r-- 1 root root  22K Jun 29 20:03 ntpath.py
                      -rw-r--r-- 1 root root 2.6K Jun 29 20:03 nturl2path.py
                      -rw-r--r-- 1 root root  11K Jun 29 20:03 numbers.py
                      -rw-r--r-- 1 root root 5.7K Jun 29 20:03 opcode.py
                      -rw-r--r-- 1 root root  11K Jun 29 20:03 operator.py
                      -rw-r--r-- 1 root root  59K Jun 29 20:03 optparse.py
                      -rw-r--r-- 1 root root  37K Jun 29 20:03 os.py
                      -rw-r--r-- 1 root root  19K Jun 29 20:03 _osx_support.py
                      -rw-r--r-- 1 root root  49K Jun 29 20:03 pathlib.py
                      -rwxr-xr-x 1 root root  62K Jun 29 20:03 pdb.py
                      -rw-r--r-- 1 root root   64 Jun 29 20:03 __phello__.foo.py
                      -rw-r--r-- 1 root root  57K Jun 29 20:03 pickle.py
                      -rw-r--r-- 1 root root  90K Jun 29 20:03 pickletools.py
                      -rw-r--r-- 1 root root 8.8K Jun 29 20:03 pipes.py
                      -rw-r--r-- 1 root root  21K Jun 29 20:03 pkgutil.py
                      -rwxr-xr-x 1 root root  47K Jun 29 20:03 platform.py
                      -rw-r--r-- 1 root root  30K Jun 29 20:03 plistlib.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 poplib.py
                      -rw-r--r-- 1 root root  16K Jun 29 20:03 posixpath.py
                      -rw-r--r-- 1 root root  21K Jun 29 20:03 pprint.py
                      -rwxr-xr-x 1 root root  22K Jun 29 20:03 profile.py
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 pstats.py
                      -rw-r--r-- 1 root root 4.7K Jun 29 20:03 pty.py
                      -rw-r--r-- 1 root root 6.1K Jun 29 20:03 _py_abc.py
                      drwxr-xr-x 2 root root  12K Aug 21 13:27 __pycache__
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 pyclbr.py
                      -rw-r--r-- 1 root root 7.9K Jun 29 20:03 py_compile.py
                      -rw-r--r-- 1 root root 224K Jun 29 20:03 _pydecimal.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 pydoc_data
                      -rwxr-xr-x 1 root root 104K Jun 29 20:03 pydoc.py
                      -rw-r--r-- 1 root root  90K Jun 29 20:03 _pyio.py
                      -rw-r--r-- 1 root root  12K Jun 29 20:03 queue.py
                      -rwxr-xr-x 1 root root 7.1K Jun 29 20:03 quopri.py
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 random.py
                      -rw-r--r-- 1 root root 5.2K Jun 29 20:03 reprlib.py
                      -rw-r--r-- 1 root root  15K Jun 29 20:03 re.py
                      -rw-r--r-- 1 root root 7.0K Jun 29 20:03 rlcompleter.py
                      -rw-r--r-- 1 root root  12K Jun 29 20:03 runpy.py
                      -rw-r--r-- 1 root root 6.3K Jun 29 20:03 sched.py
                      -rw-r--r-- 1 root root 2.0K Jun 29 20:03 secrets.py
                      -rw-r--r-- 1 root root  19K Jun 29 20:03 selectors.py
                      -rw-r--r-- 1 root root 8.4K Jun 29 20:03 shelve.py
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 shlex.py
                      -rw-r--r-- 1 root root  41K Jun 29 20:03 shutil.py
                      -rw-r--r-- 1 root root 2.1K Jun 29 20:03 signal.py
                      -rw-r--r-- 1 root root 3.1K Jun 29 20:03 _sitebuiltins.py
                      lrwxrwxrwx 1 root root   31 Jun 29 20:03 sitecustomize.py -> /etc/python3.7/sitecustomize.py
                      -rw-r--r-- 1 root root  23K Jun 29 20:03 site.py
                      -rwxr-xr-x 1 root root  34K Jun 29 20:03 smtpd.py
                      -rwxr-xr-x 1 root root  44K Jun 29 20:03 smtplib.py
                      -rw-r--r-- 1 root root 7.0K Jun 29 20:03 sndhdr.py
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 socket.py
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 socketserver.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 sqlite3
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 sre_compile.py
                      -rw-r--r-- 1 root root 7.1K Jun 29 20:03 sre_constants.py
                      -rw-r--r-- 1 root root  39K Jun 29 20:03 sre_parse.py
                      -rw-r--r-- 1 root root  45K Jun 29 20:03 ssl.py
                      -rw-r--r-- 1 root root  21K Jun 29 20:03 statistics.py
                      -rw-r--r-- 1 root root 5.0K Jun 29 20:03 stat.py
                      -rw-r--r-- 1 root root  13K Jun 29 20:03 stringprep.py
                      -rw-r--r-- 1 root root  12K Jun 29 20:03 string.py
                      -rw-r--r-- 1 root root  25K Jun 29 20:03 _strptime.py
                      -rw-r--r-- 1 root root  257 Jun 29 20:03 struct.py
                      -rw-r--r-- 1 root root  69K Jun 29 20:03 subprocess.py
                      -rw-r--r-- 1 root root  18K Jun 29 20:03 sunau.py
                      -rwxr-xr-x 1 root root 2.1K Jun 29 20:03 symbol.py
                      -rw-r--r-- 1 root root 7.2K Jun 29 20:03 symtable.py
                      -rw-r--r-- 1 root root  24K Jun 29 20:03 _sysconfigdata_m_linux_arm-linux-gnueabihf.py
                      -rw-r--r-- 1 root root  24K Jun 29 20:03 sysconfig.py
                      -rwxr-xr-x 1 root root  12K Jun 29 20:03 tabnanny.py
                      -rwxr-xr-x 1 root root  91K Jun 29 20:03 tarfile.py
                      -rw-r--r-- 1 root root  23K Jun 29 20:03 telnetlib.py
                      -rw-r--r-- 1 root root  32K Jun 29 20:03 tempfile.py
                      drwxr-xr-x 5 root root 4.0K Aug 21 13:27 test
                      -rw-r--r-- 1 root root  20K Jun 29 20:03 textwrap.py
                      -rw-r--r-- 1 root root 1003 Jun 29 20:03 this.py
                      -rw-r--r-- 1 root root 7.1K Jun 29 20:03 _threading_local.py
                      -rw-r--r-- 1 root root  47K Jun 29 20:03 threading.py
                      -rwxr-xr-x 1 root root  14K Jun 29 20:03 timeit.py
                      -rw-r--r-- 1 root root  27K Jun 29 20:03 tokenize.py
                      -rw-r--r-- 1 root root 3.7K Jun 29 20:03 token.py
                      -rw-r--r-- 1 root root  23K Jun 29 20:03 traceback.py
                      -rw-r--r-- 1 root root  17K Jun 29 20:03 tracemalloc.py
                      -rwxr-xr-x 1 root root  28K Jun 29 20:03 trace.py
                      -rw-r--r-- 1 root root  879 Jun 29 20:03 tty.py
                      -rw-r--r-- 1 root root 141K Jun 29 20:03 turtle.py
                      -rw-r--r-- 1 root root 9.7K Jun 29 20:03 types.py
                      -rw-r--r-- 1 root root  54K Jun 29 20:03 typing.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 unittest
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 urllib
                      -rw-r--r-- 1 root root  29K Jun 29 20:03 uuid.py
                      -rwxr-xr-x 1 root root 6.7K Jun 29 20:03 uu.py
                      drwxr-xr-x 4 root root 4.0K Aug 21 13:27 venv
                      -rw-r--r-- 1 root root  20K Jun 29 20:03 warnings.py
                      -rw-r--r-- 1 root root  18K Jun 29 20:03 wave.py
                      -rw-r--r-- 1 root root  21K Jun 29 20:03 weakref.py
                      -rw-r--r-- 1 root root 5.6K Jun 29 20:03 _weakrefset.py
                      -rwxr-xr-x 1 root root  23K Jun 29 20:03 webbrowser.py
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 wsgiref
                      -rw-r--r-- 1 root root 5.8K Jun 29 20:03 xdrlib.py
                      drwxr-xr-x 7 root root 4.0K Aug 21 13:27 xml
                      drwxr-xr-x 3 root root 4.0K Aug 21 13:27 xmlrpc
                      -rw-r--r-- 1 root root 7.4K Jun 29 20:03 zipapp.py
                      -rw-r--r-- 1 root root  79K Jun 29 20:03 zipfile.py
                        @cover1987
                        mach mal das
                        Cover1987
                        @glasfaser
                        pi@raspberrypi-4-iobroker:/ $ pip install --upgrade Rust
                        Defaulting to user installation because normal site-packages is not writeable
                        Collecting Rust
                         Downloading https://www.piwheels.org/simple/rust/RUST-0.1.1-py3-none-any.whl (30 kB)
                        Collecting biopython (from Rust)
                         Downloading https://www.piwheels.org/simple/biopython/biopython-1.81-cp37-cp37m-linux_armv7l.whl (2.8 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.8/2.8 MB 3.1 MB/s eta 0:00:00
                        Collecting matplotlib (from Rust)
                         Downloading https://www.piwheels.org/simple/matplotlib/matplotlib-3.5.3-cp37-cp37m-linux_armv7l.whl (8.9 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 8.9/8.9 MB 5.3 MB/s eta 0:00:00
                        Collecting mock<=1.0.1 (from Rust)
                         Downloading https://www.piwheels.org/simple/mock/mock-1.0.1-py3-none-any.whl (26 kB)
                        Collecting pysam (from Rust)
                         Downloading https://www.piwheels.org/simple/pysam/pysam-0.21.0-cp37-cp37m-linux_armv7l.whl (9.0 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.0/9.0 MB 5.8 MB/s eta 0:00:00
                        Collecting numpy (from biopython->Rust)
                         Downloading numpy-1.21.6.zip (10.3 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 10.3/10.3 MB 5.4 MB/s eta 0:00:00
                         Installing build dependencies ... done
                         Getting requirements to build wheel ... done
                         Preparing metadata (pyproject.toml) ... done
                        Collecting cycler>=0.10 (from matplotlib->Rust)
                         Downloading https://www.piwheels.org/simple/cycler/cycler-0.11.0-py3-none-any.whl (6.4 kB)
                        Collecting fonttools>=4.22.0 (from matplotlib->Rust)
                         Downloading https://www.piwheels.org/simple/fonttools/fonttools-4.38.0-cp37-cp37m-linux_armv7l.whl (1.7 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 2.4 MB/s eta 0:00:00
                        Collecting kiwisolver>=1.0.1 (from matplotlib->Rust)
                         Downloading https://www.piwheels.org/simple/kiwisolver/kiwisolver-1.4.4-cp37-cp37m-linux_armv7l.whl (530 kB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 530.4/530.4 kB 1.7 MB/s eta 0:00:00
                        Requirement already satisfied: packaging>=20.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (23.1)
                        Requirement already satisfied: pillow>=6.2.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (9.5.0)
                        Collecting pyparsing>=2.2.1 (from matplotlib->Rust)
                         Downloading https://www.piwheels.org/simple/pyparsing/pyparsing-3.1.1-py3-none-any.whl (103 kB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 103.1/103.1 kB 2.4 MB/s eta 0:00:00
                        Collecting python-dateutil>=2.7 (from matplotlib->Rust)
                         Downloading https://www.piwheels.org/simple/python-dateutil/python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 247.7/247.7 kB 3.9 MB/s eta 0:00:00
                        Collecting cython (from pysam->Rust)
                         Downloading https://www.piwheels.org/simple/cython/Cython-3.0.0-cp37-cp37m-linux_armv7l.whl (4.3 MB)
                            ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.3/4.3 MB 4.4 MB/s eta 0:00:00
                        Requirement already satisfied: typing-extensions in /home/pi/.local/lib/python3.7/site-packages (from kiwisolver>=1.0.1->matplotlib->Rust) (4.5.0)
                        Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.7->matplotlib->Rust) (1.12.0)
                        Building wheels for collected packages: numpy
                         Building wheel for numpy (pyproject.toml) ... done
                         Created wheel for numpy: filename=numpy-1.21.6-cp37-cp37m-linux_armv7l.whl size=15871852 sha256=941e9b10e4755023f4a6172659eb1adda2585823edcd71135728313ea39676f8
                         Stored in directory: /home/pi/.cache/pip/wheels/4e/7e/9e/0fde042ccff2493994076dac9c3fbd78feb444c3bd94eb386a
                        Successfully built numpy
                        Installing collected packages: mock, python-dateutil, pyparsing, numpy, kiwisolver, fonttools, cython, cycler, pysam, matplotlib, biopython, Rust
                        Successfully installed Rust-0.1.1 biopython-1.81 cycler-0.11.0 cython-3.0.0 fonttools-4.38.0 kiwisolver-1.4.4 matplotlib-3.5.3 mock-1.0.1 numpy-1.21.6 pyparsing-3.1.1 pysam-0.21.0 python-dateutil-2.8.2
                        [notice] A new release of pip is available: 23.1 -> 23.2.1
                        [notice] To update, run: python3 -m pip install --upgrade pip
                        pip direkt updaten? Oder erstmal nochmal
                        iob update
                        probieren?
                        • C Cover1987
                          @glasfaser
                          Collecting Rust
                          iob update
                          probieren?
                          Cover1987
                          Hat keiner mehr einen Tip?
                          gibt immer noch das gleiche zurück
                          DJMarc75D crunchipC 2 Antworten Letzte Antwort
                          • C Cover1987
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            jo, mach neu und spiel Dein Backup zurück.
                            Lehrling seit 1975 !!!
                            • C Cover1987
                              crunchipC Abwesend
                              crunchipC Abwesend
                              @cover1987 ist da jetzt immer noch buster drauf?
                              hast du mal den esp-home gelöscht und neu installiert?
                                Cover1987
                                @crunchip
                                ESPHome habe ich deinstalliert, Backup erstellt, bullseye drauf gemacht (komplett neu aufgesetzt), iobroker neu installiert, vis installiert, Backup wieder hergestellt. Alles bis auf ESPHome geht wieder. Weiß nicht ob ich ESPHome wieder installieren sollte, ohne dabei was kaputt zu machen.
                                • C Cover1987
                                  @crunchip
                                  Kann man natürlich machen. Hinweise, was es da ggf. zu beachten gibt stehen ja hier bestimmt im Thread drin.
                                  So aus der Erinnerung:
                                  Sperrdatei 'EXTERNALLY_MANAGED' aus dem python-Pfad (zumindest temporär) rauswerfe, 'nopy' und das Drumherum auf die richtigen Rechte setzen.
                                    Cover1987
                                    Hat soweit funktioniert! Danke.
                                    Probleme sind soweit dann alle behoben.
                                    Danke an alle, die mir geholfen haben!
