  4. Adapter lassen sich zum Teil nicht aktualisieren
    5.1k
33 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • C Cover1987
    @djmarc75
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     15:50:12 up 1 day,  2:05,  1 user,  load average: 0.29, 0.40, 0.44
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=51.6'C
    volt=0.8375V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-22 15:50:12 CEST
               Universal time: Tue 2023-08-22 13:50:12 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.3G        1.4G        9.0M        1.2G        2.7G
    Swap:           99M          0B         99M
    Total:         3.9G        1.3G        1.5G
             3837 M total memory
             1255 M used memory
              684 M active memory
             1612 M inactive memory
             1378 M free memory
              233 M buffer memory
              970 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4      110G  6.0G  100G   6% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Mon Aug 21 13:44:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:8D:C8:DD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=8b0b0b13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Aug 21 13:44:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mon Aug 21 13:44:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Aug 21 13:44:31 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    844M    /var/
    630M    /var/cache
    623M    /var/cache/apt
    564M    /var/cache/apt/archives
    102M    /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    189M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/history
    158M    /opt/iobroker/iobroker-data/files
    128M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    9.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    7.5M    /opt/iobroker/iobroker-data/states.jsonl
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.20.2
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi-4-iobroker                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi-4-iobroker                   -  enabled
      system.adapter.binance.0                : binance               : raspberrypi-4-iobroker                   - disabled
      system.adapter.ble.0                    : ble                   : raspberrypi-4-iobroker                   - disabled
    + system.adapter.bluelink.0               : bluelink              : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.esphome.0                : esphome               : raspberrypi-4-iobroker                   -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.history.0                : history               : raspberrypi-4-iobroker                   -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi-4-iobroker                   -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi-4-iobroker                   -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.info.0                   : info                  : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi-4-iobroker                   -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspberrypi-4-iobroker                   -  enabled
      system.adapter.mobile.0                 : mobile                : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-4-iobroker                   -  enabled, port: 1884, bind: 192.168.178.27
      system.adapter.mqtt.1                   : mqtt                  : raspberrypi-4-iobroker                   - disabled, port: 1884, bind: 0.0.0.0
      system.adapter.odl.0                    : odl                   : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi-4-iobroker                   -  enabled
      system.adapter.pushbullet.0             : pushbullet            : raspberrypi-4-iobroker                   - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi-4-iobroker                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi-4-iobroker                   -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.trashschedule.1          : trashschedule         : raspberrypi-4-iobroker                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-4-iobroker                   -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-4-iobroker                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi-4-iobroker                   -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi-4-iobroker                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspberrypi-4-iobroker                   -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi-4-iobroker                   -  enabled, port: /dev/ttyUSB0
    + system.adapter.zwave2.0                 : zwave2                : raspberrypi-4-iobroker                   -  enabled
    + instance is alive
    ioBroker-Repositories
    stable        : http://iobroker.live/repo/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "odl"          : 2.0.5    , installed 2.0.5
    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
    Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
    Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        13374
    States:         10553
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17238      680/sshd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1487186    18026/io.sonoff.0
    tcp        0      0 192.168.178.27:1884     0.0.0.0:*               LISTEN      1001       1486235    17899/io.mqtt.0
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          17356      688/smbd
    tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17453      389/python
    tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1490475    18888/python3.7
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1486873    17812/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1486866    17812/iobroker.js-c
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          17357      688/smbd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1484268    17830/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1488480    18586/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17240      680/sshd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1487435    18099/io.simple-api
    tcp6       0      0 :::445                  :::*                    LISTEN      0          17354      688/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          17355      688/smbd
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17483      670/dhcpcd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          17765      673/nmbd
    udp        0      0 192.168.178.27:137      0.0.0.0:*                           0          17764      673/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          17752      673/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          17767      673/nmbd
    udp        0      0 192.168.178.27:138      0.0.0.0:*                           0          17766      673/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          17753      673/nmbd
    udp        0      0 0.0.0.0:59059           0.0.0.0:*                           108        13268      410/avahi-daemon: r
    udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1489474    18888/python3.7
    udp        0      0 192.168.178.27:5353     0.0.0.0:*                           1001       1489473    18888/python3.7
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1489468    18888/python3.7
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1492008    18757/io.esphome.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1490946    18646/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13266      410/avahi-daemon: r
    udp6       0      0 :::33721                :::*                                108        13269      410/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          1477194    670/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        13267      410/avahi-daemon: r
    2023-08-22 15:26:00.247  - error: esphome.0 (18757) Client 192.168.178.99 not reachable !
    2023-08-22 15:26:00.321  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
    2023-08-22 15:26:00.443  - info: cloud.0 (18046) Connection changed: connect
    2023-08-22 15:26:00.711  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.frontLeft" has to be type "number" but received type "boolean"
    2023-08-22 15:26:00.765  - info: bluelink.0 (18631) State value to set for "bluelink.0.***vehicleStatus.doorOpen.frontRight" has to be type "number" but received type "boolean"
    2023-08-22 15:26:00.776  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.backLeft" has to be type "number" but received type "boolean"
    2023-08-22 15:26:00.784  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.backRight" has to be type "number" but received type "boolean"
    2023-08-22 15:26:00.846  - info: bluelink.0 (18631) Update for *** successfull
    2023-08-22 15:28:53.140  - info: zwave2.0 (18601) Node 10: ready to use
    2023-08-22 15:28:53.161  - info: zwave2.0 (18601) Node 10: has returned from the dead
    2023-08-22 15:30:00.062  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 19424
    2023-08-22 15:30:03.339  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-08-22 15:30:23.003  - info: zwave2.0 (18601) Node 14: ready to use
    2023-08-22 15:30:23.030  - info: zwave2.0 (18601) Node 14: has returned from the dead
    2023-08-22 15:40:00.103  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 21242
    2023-08-22 15:40:05.372  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    2023-08-22 15:42:35.456  - error: cloud.0 (18046) Ping timeout
    2023-08-22 15:43:35.468  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
    2023-08-22 15:43:45.465  - error: cloud.0 (18046) Error while connecting to cloud: timeout
    2023-08-22 15:44:35.480  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
    2023-08-22 15:44:45.468  - error: cloud.0 (18046) Error while connecting to cloud: timeout
    2023-08-22 15:45:35.476  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
    2023-08-22 15:45:40.651  - info: cloud.0 (18046) Connection changed: connect
    2023-08-22 15:50:00.084  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 23918
    2023-08-22 15:50:03.108  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
    GlasfaserG Offline
    GlasfaserG Offline
    @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
    zu dem anderen in der Ausgabe !!
    Bullseye ist aktuell und auch dein
    /usr/bin/npm 8.19.4
    /usr/bin/npx 8.19.4
    ist nicht aktuell .
    C 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      /usr/bin/npm 8.19.4
      /usr/bin/npx 8.19.4
      ist nicht aktuell .
      Cover1987
      @glasfaser
      okay, dann update ich aml auf Bullseye und schau, wie ich den rest geupdated bekomme.
      Hoffentlich liegts dann auch daran 😄
      GlasfaserG HomoranH 2 Antworten Letzte Antwort
      • C Cover1987
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        auf Bullseye
        habe ich nicht geschrieben , nur ein Hinweis !
        bitte erst die Befehle !
        • C Cover1987
          @glasfaser
          was?
          die Meldung aus dem ersten Summary
          Cannot download repository hash file from "http://iobroker.live/repo/sources-dist-hash.json": timeout of 10000ms exceeded
          weswegen das update des Repos nicht möglich war, ist in dem letzten full-diag icht mehr aufgetreten.
          Wenn du da temporäre Netzwerkprobleme hast, wird ein upgrade des OS dafür nichts nutzen
            @cover1987
            Erstmal dazu
            iob stop
            iob fix
            iob start
            dann versuche nochmal ein Update !
            Cover1987
            @glasfaser
            Achso ganz vergessen, sorry!
            Fix habe ich schon mehrfach gemacht, ohne Erfolg.
            Update startet aber danach bleibt die alte Version stehen. Sowohl über die admin Oberfläche als auch über die Konsole
            • C Cover1987
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @cover1987
              zeige die Ausgabe von :
              iob upgrade admin --debug
                @cover1987
                GlasfaserG Offline
                GlasfaserG Offline
                vorher noch
                iob update
                  vorher noch
                  iob update
                  Cover1987
                  schrieb am zuletzt editiert von Cover1987
                  @glasfaser
                  pi@raspberrypi-4-iobroker:~ $ iob update
                  und
                  pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                  Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                  Update admin from @6.3.5 to @6.8.0
                  host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                  NPM version: 8.19.4
                  Installing iobroker.admin@6.8.0... (System call)
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  npm WARN old lockfile Error: git dep preparation failed
                  npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
                  npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
                  npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
                  npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                  npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
                  npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
                  npm WARN old lockfile   cmd: '/usr/bin/node',
                  npm WARN old lockfile   args: [
                  npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
                  npm WARN old lockfile     'install',
                  npm WARN old lockfile     '--force',
                  npm WARN old lockfile     '--cache=/home/iobroker/.npm',
                  npm WARN old lockfile     '--prefer-offline=false',
                  npm WARN old lockfile     '--prefer-online=false',
                  npm WARN old lockfile     '--offline=false',
                  npm WARN old lockfile     '--no-progress',
                  npm WARN old lockfile     '--no-save',
                  npm WARN old lockfile     '--no-audit',
                  npm WARN old lockfile     '--include=dev',
                  npm WARN old lockfile     '--include=peer',
                  npm WARN old lockfile     '--include=optional',
                  npm WARN old lockfile     '--no-package-lock-only',
                  npm WARN old lockfile     '--no-dry-run'
                  npm WARN old lockfile   ],
                  npm WARN old lockfile   code: 1,
                  npm WARN old lockfile   signal: null,
                  npm WARN old lockfile   stdout: '\n' +
                  npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
                  npm WARN old lockfile     '> npip install\n' +
                  npm WARN old lockfile     '\n' +
                  npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
                  npm WARN old lockfile     'Successfully completed pip check.\n' +
                  npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
                  npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
                  npm WARN old lockfile     'Collecting tornado>=3.2\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
                  npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
                  npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
                  npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
                  npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
                  npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
                  npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
                  npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
                  npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
                  npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
                  npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
                  npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
                  npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
                  npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
                  npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
                  npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
                  npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
                  npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
                  npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
                  npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
                  npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
                  npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
                  npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
                  npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
                  npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
                  npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
                  npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
                  npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
                  npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
                  npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
                  npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
                  npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
                  npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
                  npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
                  npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
                  npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
                  npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
                  npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
                  npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
                  npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
                  npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
                  npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
                  npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
                  npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
                  npm WARN old lockfile     '  Installing build dependencies: started\n' +
                  npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
                  npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
                  npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
                  npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
                  npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
                  npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
                  npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
                  npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
                  npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
                  npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
                  npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                  npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
                  npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
                  npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
                  npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
                  npm WARN old lockfile     'Failed to build cryptography\n',
                  npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
                  npm WARN old lockfile     'npm WARN old lockfile \n' +
                  npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
                  npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
                  npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
                  npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
                  npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
                  npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
                  npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
                  npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
                  npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
                  npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
                  npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
                  npm WARN old lockfile     '  \n' +
                  npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
                  npm WARN old lockfile     '  │ exit code: 1\n' +
                  npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
                  npm WARN old lockfile     '      running bdist_wheel\n' +
                  npm WARN old lockfile     '      running build\n' +
                  npm WARN old lockfile     '      running build_py\n' +
                  npm WARN old lockfile     '      creating build\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                  npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
                  npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                  npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                  npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                  npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                  npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
                  npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
                  npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                  npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
                  npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
                  npm WARN old lockfile }
                  npm ERR! code 1
                  npm ERR! git dep preparation failed
                  npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                  npm ERR! > iobroker.esphome@0.2.4 install
                  npm ERR! > npip install
                  npm ERR!
                  npm ERR! No python_modules directory; installing pip locally if needed.
                  npm ERR! Successfully completed pip check.
                  npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                  npm ERR! Collecting esphome>=2021.8
                  npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                  npm ERR! Collecting tornado>=3.2
                  npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                  npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
                  npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
                  npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                  npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                  npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
                  npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
                  npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                  npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                  npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
                  npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
                  npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
                  npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                  npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                  npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
                  npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                  npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
                  npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                  npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
                  npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
                  npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
                  npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                  npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
                  npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
                  npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                  npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                  npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
                  npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                  npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
                  npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
                  npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
                  npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
                  npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
                  npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
                  npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                  npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
                  npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                  npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
                  npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
                  npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
                  npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                  npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
                  npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
                  npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                  npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
                  npm ERR!   Installing build dependencies: started
                  npm ERR!   Installing build dependencies: finished with status 'done'
                  npm ERR!   Getting requirements to build wheel: started
                  npm ERR!   Getting requirements to build wheel: finished with status 'done'
                  npm ERR!   Preparing metadata (pyproject.toml): started
                  npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                  npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
                  npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
                  npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
                  npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                  npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
                  npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                  npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                  npm ERR! Building wheels for collected packages: cryptography
                  npm ERR!   Building wheel for cryptography (pyproject.toml): started
                  npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                  npm ERR! Failed to build cryptography
                  npm ERR! npm WARN using --force Recommended protections disabled.
                  npm ERR! npm WARN old lockfile
                  npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
                  npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                  npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                  npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                  npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                  npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                  npm ERR! Cache entry deserialization failed, entry ignored
                  npm ERR!   error: subprocess-exited-with-error
                  npm ERR!
                  npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                  npm ERR!   │ exit code: 1
                  npm ERR!   ╰─> [172 lines of output]
                  npm ERR!       running bdist_wheel
                  npm ERR!       running build
                  npm ERR!       running build_py
                  npm ERR!       creating build
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                  npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                  npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                  npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                  npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                  npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                  npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                  npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                  npm ERR!       running egg_info
                  npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                  npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                  npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                  npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                  npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                  npm ERR!       reading manifest template 'MANIFEST.in'
                  npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                  npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
                  npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
                  npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
                  npm ERR!       no previously-included directories found matching 'docs/_build'
                  npm ERR!       warning: no previously-included files found matching 'vectors'
                  npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                  npm ERR!       warning: no previously-included files found matching 'src/rust/target'
                  npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
                  npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                  npm ERR!       warning: no previously-included files found matching 'release.py'
                  npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                  npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                  npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                  npm ERR!       adding license file 'LICENSE'
                  npm ERR!       adding license file 'LICENSE.APACHE'
                  npm ERR!       adding license file 'LICENSE.BSD'
                  npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                  npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                  npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                  npm ERR!       running build_ext
                  npm ERR!       running build_rust
                  npm ERR!
                  npm ERR!           =============================DEBUG ASSISTANCE=============================
                  npm ERR!           If you are seeing a compilation error please try the following steps to
                  npm ERR!           successfully install cryptography:
                  npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                  npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                  npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                  npm ERR!              instructions for your platform.
                  npm ERR!           3) Check our frequently asked questions for more information:
                  npm ERR!              https://cryptography.io/en/latest/faq/
                  npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                  npm ERR!              https://cryptography.io/en/latest/installation/#rust
                  npm ERR!
                  npm ERR!           Python: 3.7.3
                  npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
                  npm ERR!           pip: n/a
                  npm ERR!           setuptools: 68.0.0
                  npm ERR!           setuptools_rust: 1.6.0
                  npm ERR!           rustc: n/a
                  npm ERR!
                  npm ERR!       error: can't find Rust compiler
                  npm ERR!
                  npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                  npm ERR!
                  npm ERR!       To update pip, run:
                  npm ERR!
                  npm ERR!           pip install --upgrade pip
                  npm ERR!
                  npm ERR!       and then retry package installation.
                  npm ERR!
                  npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                  npm ERR!
                  npm ERR!       This package requires Rust >=1.56.0.
                  npm ERR!       [end of output]
                  npm ERR!
                  npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                  npm ERR!   ERROR: Failed building wheel for cryptography
                  npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                  npm ERR! npm ERR! code 1
                  npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
                  npm ERR! npm ERR! command failed
                  npm ERR! npm ERR! command sh -c -- npip install
                  npm ERR!
                  npm ERR! npm ERR! A complete log of this run can be found in:
                  npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
                  npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
                  upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                  upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                  upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                  upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                  upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                  upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                  upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                  upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                  upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                  upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                  upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                  upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                  upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                  upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                  host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
                  Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
                  • C Cover1987
                    @glasfaser
                    pi@raspberrypi-4-iobroker:~ $ iob update
                    Used repository: stable
                    Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                    Adapter    "ble"          : 0.13.4   , installed 0.13.4
                    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                    Adapter    "history"      : 2.2.4    , installed 2.2.4
                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                    Adapter    "odl"          : 2.0.5    , installed 2.0.5
                    Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                    Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                    Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
                    Adapter    "wled"         : 0.6.7    , installed 0.6.7
                    Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                    Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                    und
                    pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                    Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                    Update admin from @6.3.5 to @6.8.0
                    host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                    NPM version: 8.19.4
                    Installing iobroker.admin@6.8.0... (System call)
                    npm WARN old lockfile Error: git dep preparation failed
                    npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
                    npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
                    npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
                    npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                    npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
                    npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
                    npm WARN old lockfile   cmd: '/usr/bin/node',
                    npm WARN old lockfile   args: [
                    npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
                    npm WARN old lockfile     'install',
                    npm WARN old lockfile     '--force',
                    npm WARN old lockfile     '--cache=/home/iobroker/.npm',
                    npm WARN old lockfile     '--prefer-offline=false',
                    npm WARN old lockfile     '--prefer-online=false',
                    npm WARN old lockfile     '--offline=false',
                    npm WARN old lockfile     '--no-progress',
                    npm WARN old lockfile     '--no-save',
                    npm WARN old lockfile     '--no-audit',
                    npm WARN old lockfile     '--include=dev',
                    npm WARN old lockfile     '--include=peer',
                    npm WARN old lockfile     '--include=optional',
                    npm WARN old lockfile     '--no-package-lock-only',
                    npm WARN old lockfile     '--no-dry-run'
                    npm WARN old lockfile   ],
                    npm WARN old lockfile   code: 1,
                    npm WARN old lockfile   signal: null,
                    npm WARN old lockfile   stdout: '\n' +
                    npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
                    npm WARN old lockfile     '> npip install\n' +
                    npm WARN old lockfile     '\n' +
                    npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
                    npm WARN old lockfile     'Successfully completed pip check.\n' +
                    npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
                    npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
                    npm WARN old lockfile     'Collecting tornado>=3.2\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
                    npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
                    npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
                    npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
                    npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
                    npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
                    npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
                    npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
                    npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
                    npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
                    npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
                    npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
                    npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
                    npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
                    npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
                    npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
                    npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
                    npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
                    npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
                    npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
                    npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
                    npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
                    npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
                    npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
                    npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
                    npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
                    npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
                    npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
                    npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
                    npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
                    npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
                    npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
                    npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
                    npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
                    npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
                    npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
                    npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
                    npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
                    npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
                    npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
                    npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
                    npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
                    npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
                    npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
                    npm WARN old lockfile     '  Installing build dependencies: started\n' +
                    npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
                    npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
                    npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
                    npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
                    npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
                    npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
                    npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
                    npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
                    npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
                    npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
                    npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                    npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
                    npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
                    npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
                    npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
                    npm WARN old lockfile     'Failed to build cryptography\n',
                    npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
                    npm WARN old lockfile     'npm WARN old lockfile \n' +
                    npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
                    npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
                    npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
                    npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
                    npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
                    npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
                    npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
                    npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
                    npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
                    npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
                    npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
                    npm WARN old lockfile     '  \n' +
                    npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
                    npm WARN old lockfile     '  │ exit code: 1\n' +
                    npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
                    npm WARN old lockfile     '      running bdist_wheel\n' +
                    npm WARN old lockfile     '      running build\n' +
                    npm WARN old lockfile     '      running build_py\n' +
                    npm WARN old lockfile     '      creating build\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                    npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
                    npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                    npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                    npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                    npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                    npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
                    npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
                    npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                    npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
                    npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
                    npm WARN old lockfile }
                    npm ERR! code 1
                    npm ERR! git dep preparation failed
                    npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                    npm ERR! > iobroker.esphome@0.2.4 install
                    npm ERR! > npip install
                    npm ERR!
                    npm ERR! No python_modules directory; installing pip locally if needed.
                    npm ERR! Successfully completed pip check.
                    npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                    npm ERR! Collecting esphome>=2021.8
                    npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                    npm ERR! Collecting tornado>=3.2
                    npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                    npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
                    npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
                    npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                    npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                    npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
                    npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
                    npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                    npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                    npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
                    npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
                    npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
                    npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                    npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                    npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
                    npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                    npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
                    npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                    npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
                    npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
                    npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
                    npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                    npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
                    npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
                    npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                    npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                    npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
                    npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                    npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
                    npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
                    npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
                    npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
                    npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
                    npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
                    npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                    npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
                    npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                    npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
                    npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
                    npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
                    npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                    npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
                    npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
                    npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                    npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
                    npm ERR!   Installing build dependencies: started
                    npm ERR!   Installing build dependencies: finished with status 'done'
                    npm ERR!   Getting requirements to build wheel: started
                    npm ERR!   Getting requirements to build wheel: finished with status 'done'
                    npm ERR!   Preparing metadata (pyproject.toml): started
                    npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                    npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
                    npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
                    npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
                    npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                    npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
                    npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                    npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                    npm ERR! Building wheels for collected packages: cryptography
                    npm ERR!   Building wheel for cryptography (pyproject.toml): started
                    npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                    npm ERR! Failed to build cryptography
                    npm ERR! npm WARN using --force Recommended protections disabled.
                    npm ERR! npm WARN old lockfile
                    npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                    npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                    npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
                    npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                    npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                    npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                    npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                    npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                    npm ERR! Cache entry deserialization failed, entry ignored
                    npm ERR!   error: subprocess-exited-with-error
                    npm ERR!
                    npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                    npm ERR!   │ exit code: 1
                    npm ERR!   ╰─> [172 lines of output]
                    npm ERR!       running bdist_wheel
                    npm ERR!       running build_py
                    npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                    npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                    npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                    npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                    npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                    npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                    npm ERR!       running egg_info
                    npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                    npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                    npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                    npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                    npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                    npm ERR!       reading manifest template 'MANIFEST.in'
                    npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                    npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
                    npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
                    npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
                    npm ERR!       no previously-included directories found matching 'docs/_build'
                    npm ERR!       warning: no previously-included files found matching 'vectors'
                    npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                    npm ERR!       warning: no previously-included files found matching 'src/rust/target'
                    npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
                    npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                    npm ERR!       warning: no previously-included files found matching 'release.py'
                    npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                    npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                    npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                    npm ERR!       adding license file 'LICENSE'
                    npm ERR!       adding license file 'LICENSE.APACHE'
                    npm ERR!       adding license file 'LICENSE.BSD'
                    npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                    npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                    npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                    npm ERR!       running build_ext
                    npm ERR!       running build_rust
                    npm ERR!
                    npm ERR!           =============================DEBUG ASSISTANCE=============================
                    npm ERR!           If you are seeing a compilation error please try the following steps to
                    npm ERR!           successfully install cryptography:
                    npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                    npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                    npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                    npm ERR!              instructions for your platform.
                    npm ERR!           3) Check our frequently asked questions for more information:
                    npm ERR!              https://cryptography.io/en/latest/faq/
                    npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                    npm ERR!              https://cryptography.io/en/latest/installation/#rust
                    npm ERR!
                    npm ERR!           Python: 3.7.3
                    npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
                    npm ERR!           pip: n/a
                    npm ERR!           setuptools: 68.0.0
                    npm ERR!           setuptools_rust: 1.6.0
                    npm ERR!           rustc: n/a
                    npm ERR!
                    npm ERR!       error: can't find Rust compiler
                    npm ERR!
                    npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                    npm ERR!
                    npm ERR!       To update pip, run:
                    npm ERR!
                    npm ERR!           pip install --upgrade pip
                    npm ERR!
                    npm ERR!       and then retry package installation.
                    npm ERR!
                    npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                    npm ERR!
                    npm ERR!       This package requires Rust >=1.56.0.
                    npm ERR!       [end of output]
                    npm ERR!
                    npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                    npm ERR!   ERROR: Failed building wheel for cryptography
                    npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                    npm ERR! npm ERR! code 1
                    npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
                    npm ERR! npm ERR! command failed
                    npm ERR! npm ERR! command sh -c -- npip install
                    npm ERR!
                    npm ERR! npm ERR! A complete log of this run can be found in:
                    npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
                    npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
                    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                    host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
                    Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @cover1987
                    Nee .. keine Ahnung was du da mal quer installiert hast .
                    Wichtig .. ein Backup hast du !!!
                    mach mal :
                    iob stop
                    find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                    iob fix
                    iob start
                    C 1 Antwort Letzte Antwort
                    • GlasfaserG Glasfaser
                      @cover1987
                      mach mal :
                      iob stop
                      iob fix
                      iob start
                      Cover1987
                      @glasfaser
                      Ja Backup ist vorhanden
                      pi@raspberrypi-4-iobroker:~ $ iob stop
                      pi@raspberrypi-4-iobroker:~ $ find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                      pi@raspberrypi-4-iobroker:~ $ iob fix
                      library: loaded
                      Library version=2022-12-09
                          Welcome to the ioBroker installation fixer!
                          Script version: 2023-04-02
                          You might need to enter your password a couple of times.
                          Installing prerequisites (1/5)
                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                      Reading package lists... Done
                      Installed gcc-c++
                          Checking ioBroker user and directory permissions (2/5)
                          Check and cleanup npm temporary directories (3/5)
                      Done.
                          Database maintenance (4/5)
                      Checking for uncompressed JSONL databases... This might take a while!
                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                      Compressed 2 JSONL files. Done
                          Checking autostart (5/5)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      pi@raspberrypi-4-iobroker:~ $ iob start
                      • C Cover1987
                        @glasfaser
                        library: loaded
                        Installed gcc-c++
                        Done.
                        Autostart enabled!
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @cover1987
                        jetzt nochmal
                        iob update
                        iob upgrade admin --debug
                          @cover1987
                          jetzt nochmal
                          iob update
                          Cover1987
                          @glasfaser
                          pi@raspberrypi-4-iobroker:~ $ iob update
                          Used repository: stable
                          Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                          Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                          Adapter    "ble"          : 0.13.4   , installed 0.13.4
                          Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                          Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                          Adapter    "ical"         : 1.13.3   , installed 1.13.3
                          Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                          Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
                          Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                          Adapter    "odl"          : 2.0.5    , installed 2.0.5
                          Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                          Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                          Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                          Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                          Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                          pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                          Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                          Update admin from @6.3.5 to @6.8.0
                          host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 8.19.4
                          Installing iobroker.admin@6.8.0... (System call)
                          npm ERR! code 1
                          npm ERR!
                          npm ERR!
                          npm ERR!       /tmp/pip-build-env-euzi8jyh/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                          npm ERR!
                          npm ERR!
                          npm ERR!           pip: n/a
                          npm ERR!           rustc: n/a
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR!
                          npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneqgjV2V
                          npm ERR!
                          npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_54_10_933Z-debug-0.log
                          npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_53_58_978Z-debug-0.log
                          • C Cover1987
                            @glasfaser
                            NPM version: 8.19.4
                            npm ERR! code 1
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!           pip: n/a
                            npm ERR!           rustc: n/a
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            npm ERR!
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
                            puhh da klemmt was ..
                            sieht nach dem aus , bzw. mach das mal
                            https://forum.iobroker.net/post/997137
                              Cover1987
                              @glasfaser
                              pi@raspberrypi-4-iobroker:/lib/python3.7 $ python3 --version
                              Python 3.7.3
                              pi@raspberrypi-4-iobroker:/ $ sudo mv /lib/python3.7/EXTERNALLY-MANAGED ~
                              mv: cannot stat '/lib/python3.7/EXTERNALLY-MANAGED': No such file or directory
                              • C Cover1987
                                @glasfaser
                                Python 3.7.3
                                GlasfaserG Offline
                                GlasfaserG Offline
                                hast du weiter gelesen im Thread das war nur ein Namensvorschlag !
                                  Cover1987
                                  @glasfaser
                                  Ja, den Namen habe ich auf meine Python 3 Version (3.7.3, dementsprechend 3.7) angepasst. Im Verzeichnis habe ich manuell auch kein EXTERNALLY-MANAGED gefunden.
                                  • C Cover1987
                                    @glasfaser
                                    Python 3.7.3
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @cover1987
                                    ls -lAh /lib/python3.7*
                                    sagt
                                    • C Cover1987
                                      @glasfaser
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @cover1987
                                      mach mal das
                                      pip install --upgrade Rust
                                        @cover1987
                                        sagt
                                        Cover1987
                                        @glasfaser
                                        total 4.7M
                                        -rw-r--r-- 1 root root 5.5K Jun 29 20:03 abc.py
                                        -rw-r--r-- 1 root root  33K Jun 29 20:03 aifc.py
                                        -rw-r--r-- 1 root root  477 Jun 29 20:03 antigravity.py
                                        -rw-r--r-- 1 root root  94K Jun 29 20:03 argparse.py
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 ast.py
                                        -rw-r--r-- 1 root root  12K Jun 29 20:03 asynchat.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 asyncio
                                        -rw-r--r-- 1 root root  20K Jun 29 20:03 asyncore.py
                                        -rwxr-xr-x 1 root root  20K Jun 29 20:03 base64.py
                                        -rw-r--r-- 1 root root  31K Jun 29 20:03 bdb.py
                                        -rw-r--r-- 1 root root  14K Jun 29 20:03 binhex.py
                                        -rw-r--r-- 1 root root 2.5K Jun 29 20:03 bisect.py
                                        -rw-r--r-- 1 root root 1.8K Jun 29 20:03 _bootlocale.py
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 bz2.py
                                        -rw-r--r-- 1 root root  25K Jun 29 20:03 calendar.py
                                        -rwxr-xr-x 1 root root  34K Jun 29 20:03 cgi.py
                                        -rw-r--r-- 1 root root  12K Jun 29 20:03 cgitb.py
                                        -rw-r--r-- 1 root root 5.4K Jun 29 20:03 chunk.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 cmd.py
                                        -rw-r--r-- 1 root root  36K Jun 29 20:03 codecs.py
                                        -rw-r--r-- 1 root root 5.9K Jun 29 20:03 codeop.py
                                        -rw-r--r-- 1 root root  11K Jun 29 20:03 code.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:26 collections
                                        -rw-r--r-- 1 root root  26K Jun 29 20:03 _collections_abc.py
                                        -rw-r--r-- 1 root root 4.0K Jun 29 20:03 colorsys.py
                                        -rw-r--r-- 1 root root 8.6K Jun 29 20:03 _compat_pickle.py
                                        -rw-r--r-- 1 root root  14K Jun 29 20:03 compileall.py
                                        -rw-r--r-- 1 root root 5.3K Jun 29 20:03 _compression.py
                                        drwxr-xr-x 4 root root 4.0K Aug 21 13:27 concurrent
                                        drwxr-xr-x 2 root root 4.0K Aug 21 13:25 config-3.7m-arm-linux-gnueabihf
                                        -rw-r--r-- 1 root root  54K Jun 29 20:03 configparser.py
                                        -rw-r--r-- 1 root root  24K Jun 29 20:03 contextlib.py
                                        -rw-r--r-- 1 root root  129 Jun 29 20:03 contextvars.py
                                        -rw-r--r-- 1 root root 8.7K Jun 29 20:03 copy.py
                                        -rw-r--r-- 1 root root 6.9K Jun 29 20:03 copyreg.py
                                        -rwxr-xr-x 1 root root 5.7K Jun 29 20:03 cProfile.py
                                        -rw-r--r-- 1 root root 3.3K Jun 29 20:03 crypt.py
                                        -rw-r--r-- 1 root root  16K Jun 29 20:03 csv.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 ctypes
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 curses
                                        -rw-r--r-- 1 root root  48K Jun 29 20:03 dataclasses.py
                                        -rw-r--r-- 1 root root  85K Jun 29 20:03 datetime.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 dbm
                                        -rw-r--r-- 1 root root  320 Jun 29 20:03 decimal.py
                                        -rw-r--r-- 1 root root  83K Jun 29 20:03 difflib.py
                                        -rw-r--r-- 1 root root  20K Jun 29 20:03 dis.py
                                        drwxr-xr-x 4 root root 4.0K Aug 21 13:25 distutils
                                        -rw-r--r-- 1 root root 102K Jun 29 20:03 doctest.py
                                        -rw-r--r-- 1 root root 2.8K Jun 29 20:03 dummy_threading.py
                                        -rw-r--r-- 1 root root 5.0K Jun 29 20:03 _dummy_thread.py
                                        drwxr-xr-x 4 root root 4.0K Aug 21 13:27 email
                                        drwxr-xr-x 3 root root  20K Aug 21 13:26 encodings
                                        -rw-r--r-- 1 root root  34K Jun 29 20:03 enum.py
                                        -rw-r--r-- 1 root root 9.6K Jun 29 20:03 filecmp.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 fileinput.py
                                        -rw-r--r-- 1 root root 4.0K Jun 29 20:03 fnmatch.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 formatter.py
                                        -rw-r--r-- 1 root root  24K Jun 29 20:03 fractions.py
                                        -rw-r--r-- 1 root root  35K Jun 29 20:03 ftplib.py
                                        -rw-r--r-- 1 root root  32K Jun 29 20:03 functools.py
                                        -rw-r--r-- 1 root root 5.0K Jun 29 20:03 __future__.py
                                        -rw-r--r-- 1 root root 4.7K Jun 29 20:03 genericpath.py
                                        -rw-r--r-- 1 root root 7.4K Jun 29 20:03 getopt.py
                                        -rw-r--r-- 1 root root 5.9K Jun 29 20:03 getpass.py
                                        -rw-r--r-- 1 root root  22K Jun 29 20:03 gettext.py
                                        -rw-r--r-- 1 root root 5.6K Jun 29 20:03 glob.py
                                        -rw-r--r-- 1 root root  20K Jun 29 20:03 gzip.py
                                        -rw-r--r-- 1 root root 9.4K Jun 29 20:03 hashlib.py
                                        -rw-r--r-- 1 root root  23K Jun 29 20:03 heapq.py
                                        -rw-r--r-- 1 root root 6.4K Jun 29 20:03 hmac.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 html
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 http
                                        -rw-r--r-- 1 root root  53K Jun 29 20:03 imaplib.py
                                        -rw-r--r-- 1 root root 3.8K Jun 29 20:03 imghdr.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 importlib
                                        -rw-r--r-- 1 root root  11K Jun 29 20:03 imp.py
                                        -rw-r--r-- 1 root root 115K Jun 29 20:03 inspect.py
                                        -rw-r--r-- 1 root root 3.5K Jun 29 20:03 io.py
                                        -rw-r--r-- 1 root root  74K Jun 29 20:03 ipaddress.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 json
                                        -rwxr-xr-x 1 root root 2.2K Jun 29 20:03 keyword.py
                                        drwxr-xr-x 5 root root 4.0K Apr 11  2021 lib2to3
                                        drwxr-xr-x 2 root root  12K Aug 21 13:25 lib-dynload
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 LICENSE.txt
                                        -rw-r--r-- 1 root root 5.2K Jun 29 20:03 linecache.py
                                        -rw-r--r-- 1 root root  77K Jun 29 20:03 locale.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:26 logging
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 lzma.py
                                        -rw-r--r-- 1 root root 6.0K Jun 29 20:03 macpath.py
                                        -rw-r--r-- 1 root root  77K Jun 29 20:03 mailbox.py
                                        -rw-r--r-- 1 root root 8.9K Jun 29 20:03 mailcap.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 _markupbase.py
                                        -rw-r--r-- 1 root root  21K Jun 29 20:03 mimetypes.py
                                        -rw-r--r-- 1 root root  23K Jun 29 20:03 modulefinder.py
                                        drwxr-xr-x 4 root root 4.0K Aug 21 13:27 multiprocessing
                                        -rw-r--r-- 1 root root 5.5K Jun 29 20:03 netrc.py
                                        -rw-r--r-- 1 root root  43K Jun 29 20:03 nntplib.py
                                        -rw-r--r-- 1 root root  22K Jun 29 20:03 ntpath.py
                                        -rw-r--r-- 1 root root 2.6K Jun 29 20:03 nturl2path.py
                                        -rw-r--r-- 1 root root  11K Jun 29 20:03 numbers.py
                                        -rw-r--r-- 1 root root 5.7K Jun 29 20:03 opcode.py
                                        -rw-r--r-- 1 root root  11K Jun 29 20:03 operator.py
                                        -rw-r--r-- 1 root root  59K Jun 29 20:03 optparse.py
                                        -rw-r--r-- 1 root root  37K Jun 29 20:03 os.py
                                        -rw-r--r-- 1 root root  19K Jun 29 20:03 _osx_support.py
                                        -rw-r--r-- 1 root root  49K Jun 29 20:03 pathlib.py
                                        -rwxr-xr-x 1 root root  62K Jun 29 20:03 pdb.py
                                        -rw-r--r-- 1 root root   64 Jun 29 20:03 __phello__.foo.py
                                        -rw-r--r-- 1 root root  57K Jun 29 20:03 pickle.py
                                        -rw-r--r-- 1 root root  90K Jun 29 20:03 pickletools.py
                                        -rw-r--r-- 1 root root 8.8K Jun 29 20:03 pipes.py
                                        -rw-r--r-- 1 root root  21K Jun 29 20:03 pkgutil.py
                                        -rwxr-xr-x 1 root root  47K Jun 29 20:03 platform.py
                                        -rw-r--r-- 1 root root  30K Jun 29 20:03 plistlib.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 poplib.py
                                        -rw-r--r-- 1 root root  16K Jun 29 20:03 posixpath.py
                                        -rw-r--r-- 1 root root  21K Jun 29 20:03 pprint.py
                                        -rwxr-xr-x 1 root root  22K Jun 29 20:03 profile.py
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 pstats.py
                                        -rw-r--r-- 1 root root 4.7K Jun 29 20:03 pty.py
                                        -rw-r--r-- 1 root root 6.1K Jun 29 20:03 _py_abc.py
                                        drwxr-xr-x 2 root root  12K Aug 21 13:27 __pycache__
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 pyclbr.py
                                        -rw-r--r-- 1 root root 7.9K Jun 29 20:03 py_compile.py
                                        -rw-r--r-- 1 root root 224K Jun 29 20:03 _pydecimal.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 pydoc_data
                                        -rwxr-xr-x 1 root root 104K Jun 29 20:03 pydoc.py
                                        -rw-r--r-- 1 root root  90K Jun 29 20:03 _pyio.py
                                        -rw-r--r-- 1 root root  12K Jun 29 20:03 queue.py
                                        -rwxr-xr-x 1 root root 7.1K Jun 29 20:03 quopri.py
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 random.py
                                        -rw-r--r-- 1 root root 5.2K Jun 29 20:03 reprlib.py
                                        -rw-r--r-- 1 root root  15K Jun 29 20:03 re.py
                                        -rw-r--r-- 1 root root 7.0K Jun 29 20:03 rlcompleter.py
                                        -rw-r--r-- 1 root root  12K Jun 29 20:03 runpy.py
                                        -rw-r--r-- 1 root root 6.3K Jun 29 20:03 sched.py
                                        -rw-r--r-- 1 root root 2.0K Jun 29 20:03 secrets.py
                                        -rw-r--r-- 1 root root  19K Jun 29 20:03 selectors.py
                                        -rw-r--r-- 1 root root 8.4K Jun 29 20:03 shelve.py
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 shlex.py
                                        -rw-r--r-- 1 root root  41K Jun 29 20:03 shutil.py
                                        -rw-r--r-- 1 root root 2.1K Jun 29 20:03 signal.py
                                        -rw-r--r-- 1 root root 3.1K Jun 29 20:03 _sitebuiltins.py
                                        lrwxrwxrwx 1 root root   31 Jun 29 20:03 sitecustomize.py -> /etc/python3.7/sitecustomize.py
                                        -rw-r--r-- 1 root root  23K Jun 29 20:03 site.py
                                        -rwxr-xr-x 1 root root  34K Jun 29 20:03 smtpd.py
                                        -rwxr-xr-x 1 root root  44K Jun 29 20:03 smtplib.py
                                        -rw-r--r-- 1 root root 7.0K Jun 29 20:03 sndhdr.py
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 socket.py
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 socketserver.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 sqlite3
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 sre_compile.py
                                        -rw-r--r-- 1 root root 7.1K Jun 29 20:03 sre_constants.py
                                        -rw-r--r-- 1 root root  39K Jun 29 20:03 sre_parse.py
                                        -rw-r--r-- 1 root root  45K Jun 29 20:03 ssl.py
                                        -rw-r--r-- 1 root root  21K Jun 29 20:03 statistics.py
                                        -rw-r--r-- 1 root root 5.0K Jun 29 20:03 stat.py
                                        -rw-r--r-- 1 root root  13K Jun 29 20:03 stringprep.py
                                        -rw-r--r-- 1 root root  12K Jun 29 20:03 string.py
                                        -rw-r--r-- 1 root root  25K Jun 29 20:03 _strptime.py
                                        -rw-r--r-- 1 root root  257 Jun 29 20:03 struct.py
                                        -rw-r--r-- 1 root root  69K Jun 29 20:03 subprocess.py
                                        -rw-r--r-- 1 root root  18K Jun 29 20:03 sunau.py
                                        -rwxr-xr-x 1 root root 2.1K Jun 29 20:03 symbol.py
                                        -rw-r--r-- 1 root root 7.2K Jun 29 20:03 symtable.py
                                        -rw-r--r-- 1 root root  24K Jun 29 20:03 _sysconfigdata_m_linux_arm-linux-gnueabihf.py
                                        -rw-r--r-- 1 root root  24K Jun 29 20:03 sysconfig.py
                                        -rwxr-xr-x 1 root root  12K Jun 29 20:03 tabnanny.py
                                        -rwxr-xr-x 1 root root  91K Jun 29 20:03 tarfile.py
                                        -rw-r--r-- 1 root root  23K Jun 29 20:03 telnetlib.py
                                        -rw-r--r-- 1 root root  32K Jun 29 20:03 tempfile.py
                                        drwxr-xr-x 5 root root 4.0K Aug 21 13:27 test
                                        -rw-r--r-- 1 root root  20K Jun 29 20:03 textwrap.py
                                        -rw-r--r-- 1 root root 1003 Jun 29 20:03 this.py
                                        -rw-r--r-- 1 root root 7.1K Jun 29 20:03 _threading_local.py
                                        -rw-r--r-- 1 root root  47K Jun 29 20:03 threading.py
                                        -rwxr-xr-x 1 root root  14K Jun 29 20:03 timeit.py
                                        -rw-r--r-- 1 root root  27K Jun 29 20:03 tokenize.py
                                        -rw-r--r-- 1 root root 3.7K Jun 29 20:03 token.py
                                        -rw-r--r-- 1 root root  23K Jun 29 20:03 traceback.py
                                        -rw-r--r-- 1 root root  17K Jun 29 20:03 tracemalloc.py
                                        -rwxr-xr-x 1 root root  28K Jun 29 20:03 trace.py
                                        -rw-r--r-- 1 root root  879 Jun 29 20:03 tty.py
                                        -rw-r--r-- 1 root root 141K Jun 29 20:03 turtle.py
                                        -rw-r--r-- 1 root root 9.7K Jun 29 20:03 types.py
                                        -rw-r--r-- 1 root root  54K Jun 29 20:03 typing.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 unittest
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 urllib
                                        -rw-r--r-- 1 root root  29K Jun 29 20:03 uuid.py
                                        -rwxr-xr-x 1 root root 6.7K Jun 29 20:03 uu.py
                                        drwxr-xr-x 4 root root 4.0K Aug 21 13:27 venv
                                        -rw-r--r-- 1 root root  20K Jun 29 20:03 warnings.py
                                        -rw-r--r-- 1 root root  18K Jun 29 20:03 wave.py
                                        -rw-r--r-- 1 root root  21K Jun 29 20:03 weakref.py
                                        -rw-r--r-- 1 root root 5.6K Jun 29 20:03 _weakrefset.py
                                        -rwxr-xr-x 1 root root  23K Jun 29 20:03 webbrowser.py
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 wsgiref
                                        -rw-r--r-- 1 root root 5.8K Jun 29 20:03 xdrlib.py
                                        drwxr-xr-x 7 root root 4.0K Aug 21 13:27 xml
                                        drwxr-xr-x 3 root root 4.0K Aug 21 13:27 xmlrpc
                                        -rw-r--r-- 1 root root 7.4K Jun 29 20:03 zipapp.py
                                        -rw-r--r-- 1 root root  79K Jun 29 20:03 zipfile.py
                                          @cover1987
                                          mach mal das
                                          Cover1987
                                          @glasfaser
                                          pi@raspberrypi-4-iobroker:/ $ pip install --upgrade Rust
                                          Defaulting to user installation because normal site-packages is not writeable
                                          Collecting Rust
                                           Downloading https://www.piwheels.org/simple/rust/RUST-0.1.1-py3-none-any.whl (30 kB)
                                          Collecting biopython (from Rust)
                                           Downloading https://www.piwheels.org/simple/biopython/biopython-1.81-cp37-cp37m-linux_armv7l.whl (2.8 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.8/2.8 MB 3.1 MB/s eta 0:00:00
                                          Collecting matplotlib (from Rust)
                                           Downloading https://www.piwheels.org/simple/matplotlib/matplotlib-3.5.3-cp37-cp37m-linux_armv7l.whl (8.9 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 8.9/8.9 MB 5.3 MB/s eta 0:00:00
                                          Collecting mock<=1.0.1 (from Rust)
                                           Downloading https://www.piwheels.org/simple/mock/mock-1.0.1-py3-none-any.whl (26 kB)
                                          Collecting pysam (from Rust)
                                           Downloading https://www.piwheels.org/simple/pysam/pysam-0.21.0-cp37-cp37m-linux_armv7l.whl (9.0 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 9.0/9.0 MB 5.8 MB/s eta 0:00:00
                                          Collecting numpy (from biopython->Rust)
                                           Downloading numpy-1.21.6.zip (10.3 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 10.3/10.3 MB 5.4 MB/s eta 0:00:00
                                           Installing build dependencies ... done
                                           Getting requirements to build wheel ... done
                                           Preparing metadata (pyproject.toml) ... done
                                          Collecting cycler>=0.10 (from matplotlib->Rust)
                                           Downloading https://www.piwheels.org/simple/cycler/cycler-0.11.0-py3-none-any.whl (6.4 kB)
                                          Collecting fonttools>=4.22.0 (from matplotlib->Rust)
                                           Downloading https://www.piwheels.org/simple/fonttools/fonttools-4.38.0-cp37-cp37m-linux_armv7l.whl (1.7 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 2.4 MB/s eta 0:00:00
                                          Collecting kiwisolver>=1.0.1 (from matplotlib->Rust)
                                           Downloading https://www.piwheels.org/simple/kiwisolver/kiwisolver-1.4.4-cp37-cp37m-linux_armv7l.whl (530 kB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 530.4/530.4 kB 1.7 MB/s eta 0:00:00
                                          Requirement already satisfied: packaging>=20.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (23.1)
                                          Requirement already satisfied: pillow>=6.2.0 in /home/pi/.local/lib/python3.7/site-packages (from matplotlib->Rust) (9.5.0)
                                          Collecting pyparsing>=2.2.1 (from matplotlib->Rust)
                                           Downloading https://www.piwheels.org/simple/pyparsing/pyparsing-3.1.1-py3-none-any.whl (103 kB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 103.1/103.1 kB 2.4 MB/s eta 0:00:00
                                          Collecting python-dateutil>=2.7 (from matplotlib->Rust)
                                           Downloading https://www.piwheels.org/simple/python-dateutil/python_dateutil-2.8.2-py2.py3-none-any.whl (247 kB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 247.7/247.7 kB 3.9 MB/s eta 0:00:00
                                          Collecting cython (from pysam->Rust)
                                           Downloading https://www.piwheels.org/simple/cython/Cython-3.0.0-cp37-cp37m-linux_armv7l.whl (4.3 MB)
                                              ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 4.3/4.3 MB 4.4 MB/s eta 0:00:00
                                          Requirement already satisfied: typing-extensions in /home/pi/.local/lib/python3.7/site-packages (from kiwisolver>=1.0.1->matplotlib->Rust) (4.5.0)
                                          Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.7->matplotlib->Rust) (1.12.0)
                                          Building wheels for collected packages: numpy
                                           Building wheel for numpy (pyproject.toml) ... done
                                           Created wheel for numpy: filename=numpy-1.21.6-cp37-cp37m-linux_armv7l.whl size=15871852 sha256=941e9b10e4755023f4a6172659eb1adda2585823edcd71135728313ea39676f8
                                           Stored in directory: /home/pi/.cache/pip/wheels/4e/7e/9e/0fde042ccff2493994076dac9c3fbd78feb444c3bd94eb386a
                                          Successfully built numpy
                                          Installing collected packages: mock, python-dateutil, pyparsing, numpy, kiwisolver, fonttools, cython, cycler, pysam, matplotlib, biopython, Rust
                                          Successfully installed Rust-0.1.1 biopython-1.81 cycler-0.11.0 cython-3.0.0 fonttools-4.38.0 kiwisolver-1.4.4 matplotlib-3.5.3 mock-1.0.1 numpy-1.21.6 pyparsing-3.1.1 pysam-0.21.0 python-dateutil-2.8.2
                                          [notice] A new release of pip is available: 23.1 -> 23.2.1
                                          [notice] To update, run: python3 -m pip install --upgrade pip
                                          pip direkt updaten? Oder erstmal nochmal
                                          iob update
                                          probieren?
