  4. Adapter lassen sich zum Teil nicht aktualisieren
    5.1k
33 Beiträge 6 Kommentatoren 4.4k Aufrufe 5 Beobachtet
  • C Cover1987
    Ist das die Langfassung? Oder das vor der Zusammenfassung
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 10 (buster)
    Kernel:                 5.10.103-v7l+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Cannot download repository hash file from "http://iobroker.live/repo/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://iobroker.live/repo/sources-dist.json": timeout of 10000ms exceeded
    Pending iob updates:    3
    Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                            /usr/bin/node           v16.20.2
                            /usr/bin/npm            8.19.4
                            /usr/bin/npx            8.19.4
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:           3.8G        1.2G        1.4G        9.0M        1.2G        2.8G
    Swap:           99M          0B         99M
    Total:         3.9G        1.2G        1.5G
    Active iob-Instances:   22
    Active repo(s): stable
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : raspberrypi-4-iobroker                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : raspberrypi-4-iobroker                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                13374
    States:                 10553
    Size of iob-Database:
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    9.2M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    4.0K    /opt/iobroker/iobroker-data/objects.json.old
    0       /opt/iobroker/iobroker-data/objects.json.broken
    7.2M    /opt/iobroker/iobroker-data/states.jsonl
    1.4M    /opt/iobroker/iobroker-data/states.json.migrated
    1.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.old
    0       /opt/iobroker/iobroker-data/states.json.broken
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
    Nein
    edit: und zieh vorher das Fenster der Konsole breiter
    Lehrling seit 1975 !!!
    C 1 Antwort Letzte Antwort
    • C Cover1987
                           v.2023-04-16
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.4
                              /usr/bin/npx            8.19.4
      MEMORY:
      Swap:           99M          0B         99M
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                13374
      States:                 10553
      nein, sondern
      ======== SUMMARY ==============
      aber auch hier sieht man schon
      dass du Netzwerkprobleme zu haben scheinst
      • DJMarc75D DJMarc75
        Nein
        Cover1987
        schrieb am zuletzt editiert von Cover1987
        @djmarc75
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Architecture    : armv7l
        Docker          : false
        Virtualization  : none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         15:50:12 up 1 day,  2:05,  1 user,  load average: 0.29, 0.40, 0.44
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        Other values than 0x0 hint to temperature/voltage problems
        temp=51.6'C
        volt=0.8375V
        *** Time and Time Zones ***
                       Local time: Tue 2023-08-22 15:50:12 CEST
                   Universal time: Tue 2023-08-22 13:50:12 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G        1.3G        1.4G        9.0M        1.2G        2.7G
        Swap:           99M          0B         99M
        Total:         3.9G        1.3G        1.5G
                 3837 M total memory
                 1255 M used memory
                  684 M active memory
                 1612 M inactive memory
                 1378 M free memory
                  233 M buffer memory
                  970 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /dev/root      ext4      110G  6.0G  100G   6% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Mon Aug 21 13:44:26 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:8D:C8:DD vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=8b0b0b13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Mon Aug 21 13:44:29 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Aug 21 13:44:29 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Aug 21 13:44:31 2023] EXT4-fs (sda2): re-mounted. Opts: (null)
        TARGET        SOURCE    FSTYPE OPTIONS
        /             /dev/sda2 ext4   rw,noatime
        |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        844M    /var/
        630M    /var/cache
        623M    /var/cache/apt
        564M    /var/cache/apt/archives
        102M    /var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        189M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.5G    /opt/iobroker/iobroker-data/
        1.2G    /opt/iobroker/iobroker-data/history
        158M    /opt/iobroker/iobroker-data/files
        128M    /opt/iobroker/iobroker-data/backup-objects
        52M     /opt/iobroker/iobroker-data/files/javascript.admin
        7.5M    /opt/iobroker/iobroker-data/states.jsonl
        6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
        *** NodeJS-Installation ***
        /usr/bin/npm            8.19.4
        /usr/bin/npx            8.19.4
        nodejs:
          Installed: 16.20.2-deb-1nodesource1
          Candidate: 16.20.2-deb-1nodesource1
          Version table:
         *** 16.20.2-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.5
        javascript:     7.0.3
        Adapters from github:   1
        Adapter State
        + system.adapter.backitup.0               : backitup              : raspberrypi-4-iobroker                   -  enabled
          system.adapter.binance.0                : binance               : raspberrypi-4-iobroker                   - disabled
          system.adapter.ble.0                    : ble                   : raspberrypi-4-iobroker                   - disabled
        + system.adapter.bluelink.0               : bluelink              : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.esphome.0                : esphome               : raspberrypi-4-iobroker                   -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.history.0                : history               : raspberrypi-4-iobroker                   -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypi-4-iobroker                   -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi-4-iobroker                   -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.info.0                   : info                  : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi-4-iobroker                   -  enabled
          system.adapter.luftdaten.0              : luftdaten             : raspberrypi-4-iobroker                   -  enabled
          system.adapter.mobile.0                 : mobile                : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : raspberrypi-4-iobroker                   -  enabled, port: 1884, bind: 192.168.178.27
          system.adapter.mqtt.1                   : mqtt                  : raspberrypi-4-iobroker                   - disabled, port: 1884, bind: 0.0.0.0
          system.adapter.odl.0                    : odl                   : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi-4-iobroker                   -  enabled
          system.adapter.pushbullet.0             : pushbullet            : raspberrypi-4-iobroker                   - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.simple-api.0             : simple-api            : raspberrypi-4-iobroker                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi-4-iobroker                   -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.trashschedule.1          : trashschedule         : raspberrypi-4-iobroker                   -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi-4-iobroker                   -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi-4-iobroker                   -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi-4-iobroker                   -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.wled.0                   : wled                  : raspberrypi-4-iobroker                   -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi-4-iobroker                   -  enabled, port: /dev/ttyUSB0
        + system.adapter.zwave2.0                 : zwave2                : raspberrypi-4-iobroker                   -  enabled
        + instance is alive
        ioBroker-Repositories
        stable        : http://iobroker.live/repo/sources-dist.json
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
        Adapter    "backitup"     : 2.6.23   , installed 2.6.23
        Adapter    "ble"          : 0.13.4   , installed 0.13.4
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "cloud"        : 4.4.1    , installed 4.4.1
        Adapter    "history"      : 2.2.4    , installed 2.2.4
        Adapter    "ical"         : 1.13.3   , installed 1.13.3
        Adapter    "javascript"   : 7.0.3    , installed 7.0.3
        Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
        Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
        Adapter    "odl"          : 2.0.5    , installed 2.0.5
        Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
        Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
        Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
        Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
        Adapter    "trashschedule": 2.2.0    , installed 2.2.0
        Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
        Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
        Objects and States
        Objects:        13374
        States:         10553
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17238      680/sshd
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1487186    18026/io.sonoff.0
        tcp        0      0 192.168.178.27:1884     0.0.0.0:*               LISTEN      1001       1486235    17899/io.mqtt.0
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          17356      688/smbd
        tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          17453      389/python
        tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       1490475    18888/python3.7
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1486873    17812/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1486866    17812/iobroker.js-c
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          17357      688/smbd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1484268    17830/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1488480    18586/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17240      680/sshd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1487435    18099/io.simple-api
        tcp6       0      0 :::445                  :::*                    LISTEN      0          17354      688/smbd
        tcp6       0      0 :::139                  :::*                    LISTEN      0          17355      688/smbd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17483      670/dhcpcd
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          17765      673/nmbd
        udp        0      0 192.168.178.27:137      0.0.0.0:*                           0          17764      673/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          17752      673/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          17767      673/nmbd
        udp        0      0 192.168.178.27:138      0.0.0.0:*                           0          17766      673/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          17753      673/nmbd
        udp        0      0 0.0.0.0:59059           0.0.0.0:*                           108        13268      410/avahi-daemon: r
        udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       1489474    18888/python3.7
        udp        0      0 192.168.178.27:5353     0.0.0.0:*                           1001       1489473    18888/python3.7
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1489468    18888/python3.7
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1492008    18757/io.esphome.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1490946    18646/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13266      410/avahi-daemon: r
        udp6       0      0 :::33721                :::*                                108        13269      410/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          1477194    670/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        13267      410/avahi-daemon: r
        2023-08-22 15:26:00.247  - error: esphome.0 (18757) Client 192.168.178.99 not reachable !
        2023-08-22 15:26:00.321  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
        2023-08-22 15:26:00.443  - info: cloud.0 (18046) Connection changed: connect
        2023-08-22 15:26:00.711  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.frontLeft" has to be type "number" but received type "boolean"
        2023-08-22 15:26:00.765  - info: bluelink.0 (18631) State value to set for "bluelink.0.***vehicleStatus.doorOpen.frontRight" has to be type "number" but received type "boolean"
        2023-08-22 15:26:00.776  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.backLeft" has to be type "number" but received type "boolean"
        2023-08-22 15:26:00.784  - info: bluelink.0 (18631) State value to set for "bluelink.0.***.vehicleStatus.doorOpen.backRight" has to be type "number" but received type "boolean"
        2023-08-22 15:26:00.846  - info: bluelink.0 (18631) Update for *** successfull
        2023-08-22 15:28:53.140  - info: zwave2.0 (18601) Node 10: ready to use
        2023-08-22 15:28:53.161  - info: zwave2.0 (18601) Node 10: has returned from the dead
        2023-08-22 15:30:00.062  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 19424
        2023-08-22 15:30:03.339  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-08-22 15:30:23.003  - info: zwave2.0 (18601) Node 14: ready to use
        2023-08-22 15:30:23.030  - info: zwave2.0 (18601) Node 14: has returned from the dead
        2023-08-22 15:40:00.103  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 21242
        2023-08-22 15:40:05.372  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        2023-08-22 15:42:35.456  - error: cloud.0 (18046) Ping timeout
        2023-08-22 15:43:35.468  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
        2023-08-22 15:43:45.465  - error: cloud.0 (18046) Error while connecting to cloud: timeout
        2023-08-22 15:44:35.480  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
        2023-08-22 15:44:45.468  - error: cloud.0 (18046) Error while connecting to cloud: timeout
        2023-08-22 15:45:35.476  - info: cloud.0 (18046) Trying to connect as system.user.admin to cloud
        2023-08-22 15:45:40.651  - info: cloud.0 (18046) Connection changed: connect
        2023-08-22 15:50:00.084  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 started with pid 23918
        2023-08-22 15:50:03.108  - info: host.raspberrypi-4-iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
        • C Cover1987
          @djmarc75
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        10
          Codename:       buster
          VERSION_ID="10"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          Raspberry only:
          throttled=0x0
          temp=51.6'C
          volt=0.8375V
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   3837 M total memory
                   1255 M used memory
                    684 M active memory
                   1378 M free memory
                    233 M buffer memory
                    970 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          844M    /var/
          630M    /var/cache
          623M    /var/cache/apt
          102M    /var/lib
          /usr/bin/npm            8.19.4
          /usr/bin/npx            8.19.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     7.0.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        13374
          States:         10553
          Pending Updates: 0
          GlasfaserG Offline
          GlasfaserG Offline
          @cover1987
          Erstmal dazu
          iob stop
          iob fix
          iob start
          dann versuche nochmal ein Update !
          • C Cover1987
            @djmarc75
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        10
            Codename:       buster
            VERSION_ID="10"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            temp=51.6'C
            volt=0.8375V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           99M          0B         99M
                     3837 M total memory
                     1255 M used memory
                      684 M active memory
                     1378 M free memory
                      233 M buffer memory
                      970 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            844M    /var/
            630M    /var/cache
            623M    /var/cache/apt
            102M    /var/lib
            /usr/bin/npm            8.19.4
            /usr/bin/npx            8.19.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        13374
            States:         10553
            Pending Updates: 0
            GlasfaserG Offline
            GlasfaserG Offline
            zu dem anderen in der Ausgabe !!
            Bullseye ist aktuell und auch dein
            /usr/bin/npm 8.19.4
            /usr/bin/npx 8.19.4
            ist nicht aktuell .
            • GlasfaserG Glasfaser
              /usr/bin/npm 8.19.4
              /usr/bin/npx 8.19.4
              ist nicht aktuell .
              Cover1987
              @glasfaser
              okay, dann update ich aml auf Bullseye und schau, wie ich den rest geupdated bekomme.
              Hoffentlich liegts dann auch daran 😄
              GlasfaserG HomoranH 2 Antworten Letzte Antwort
              • C Cover1987
                @glasfaser
                GlasfaserG Offline
                GlasfaserG Offline
                auf Bullseye
                habe ich nicht geschrieben , nur ein Hinweis !
                bitte erst die Befehle !
                • C Cover1987
                  @glasfaser
                  was?
                  die Meldung aus dem ersten Summary
                  weswegen das update des Repos nicht möglich war, ist in dem letzten full-diag icht mehr aufgetreten.
                  Wenn du da temporäre Netzwerkprobleme hast, wird ein upgrade des OS dafür nichts nutzen
                    @cover1987
                    Erstmal dazu
                    iob stop
                    iob fix
                    iob start
                    Cover1987
                    @glasfaser
                    Achso ganz vergessen, sorry!
                    Fix habe ich schon mehrfach gemacht, ohne Erfolg.
                    Update startet aber danach bleibt die alte Version stehen. Sowohl über die admin Oberfläche als auch über die Konsole
                    • C Cover1987
                      @glasfaser
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @cover1987
                      zeige die Ausgabe von :
                      iob upgrade admin --debug
                        @cover1987
                        GlasfaserG Offline
                        GlasfaserG Offline
                        vorher noch
                        iob update
                          vorher noch
                          iob update
                          Cover1987
                          @glasfaser
                          pi@raspberrypi-4-iobroker:~ $ iob update
                          und
                          pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                          Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                          Update admin from @6.3.5 to @6.8.0
                          host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                          NPM version: 8.19.4
                          Installing iobroker.admin@6.8.0... (System call)
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          npm WARN old lockfile Error: git dep preparation failed
                          npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
                          npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
                          npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
                          npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                          npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
                          npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
                          npm WARN old lockfile   cmd: '/usr/bin/node',
                          npm WARN old lockfile   args: [
                          npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
                          npm WARN old lockfile     'install',
                          npm WARN old lockfile     '--force',
                          npm WARN old lockfile     '--cache=/home/iobroker/.npm',
                          npm WARN old lockfile     '--prefer-offline=false',
                          npm WARN old lockfile     '--prefer-online=false',
                          npm WARN old lockfile     '--offline=false',
                          npm WARN old lockfile     '--no-progress',
                          npm WARN old lockfile     '--no-save',
                          npm WARN old lockfile     '--no-audit',
                          npm WARN old lockfile     '--include=dev',
                          npm WARN old lockfile     '--include=peer',
                          npm WARN old lockfile     '--include=optional',
                          npm WARN old lockfile     '--no-package-lock-only',
                          npm WARN old lockfile     '--no-dry-run'
                          npm WARN old lockfile   ],
                          npm WARN old lockfile   code: 1,
                          npm WARN old lockfile   signal: null,
                          npm WARN old lockfile   stdout: '\n' +
                          npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
                          npm WARN old lockfile     '> npip install\n' +
                          npm WARN old lockfile     '\n' +
                          npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
                          npm WARN old lockfile     'Successfully completed pip check.\n' +
                          npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
                          npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
                          npm WARN old lockfile     'Collecting tornado>=3.2\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
                          npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
                          npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
                          npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
                          npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
                          npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
                          npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
                          npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
                          npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
                          npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
                          npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
                          npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
                          npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
                          npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
                          npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
                          npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
                          npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
                          npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
                          npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
                          npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
                          npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
                          npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
                          npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
                          npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
                          npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
                          npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
                          npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
                          npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
                          npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
                          npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
                          npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
                          npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
                          npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
                          npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
                          npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
                          npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
                          npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
                          npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
                          npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
                          npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
                          npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
                          npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
                          npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
                          npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
                          npm WARN old lockfile     '  Installing build dependencies: started\n' +
                          npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
                          npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
                          npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
                          npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
                          npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
                          npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
                          npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
                          npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
                          npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
                          npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
                          npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                          npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
                          npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
                          npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
                          npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
                          npm WARN old lockfile     'Failed to build cryptography\n',
                          npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
                          npm WARN old lockfile     'npm WARN old lockfile \n' +
                          npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
                          npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
                          npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
                          npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
                          npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
                          npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
                          npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
                          npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
                          npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
                          npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
                          npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
                          npm WARN old lockfile     '  \n' +
                          npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
                          npm WARN old lockfile     '  │ exit code: 1\n' +
                          npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
                          npm WARN old lockfile     '      running bdist_wheel\n' +
                          npm WARN old lockfile     '      running build\n' +
                          npm WARN old lockfile     '      running build_py\n' +
                          npm WARN old lockfile     '      creating build\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                          npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
                          npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                          npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                          npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                          npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                          npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
                          npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
                          npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                          npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
                          npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
                          npm WARN old lockfile }
                          npm ERR! code 1
                          npm ERR! git dep preparation failed
                          npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                          npm ERR! > iobroker.esphome@0.2.4 install
                          npm ERR! > npip install
                          npm ERR!
                          npm ERR! No python_modules directory; installing pip locally if needed.
                          npm ERR! Successfully completed pip check.
                          npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                          npm ERR! Collecting esphome>=2021.8
                          npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                          npm ERR! Collecting tornado>=3.2
                          npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                          npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
                          npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
                          npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                          npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                          npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
                          npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
                          npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                          npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                          npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
                          npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
                          npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
                          npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                          npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                          npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
                          npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                          npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
                          npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                          npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
                          npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
                          npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
                          npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                          npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
                          npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
                          npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                          npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                          npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
                          npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                          npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
                          npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
                          npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
                          npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
                          npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
                          npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
                          npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                          npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
                          npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                          npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
                          npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
                          npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
                          npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                          npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
                          npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
                          npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                          npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
                          npm ERR!   Installing build dependencies: started
                          npm ERR!   Installing build dependencies: finished with status 'done'
                          npm ERR!   Getting requirements to build wheel: started
                          npm ERR!   Getting requirements to build wheel: finished with status 'done'
                          npm ERR!   Preparing metadata (pyproject.toml): started
                          npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                          npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
                          npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
                          npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
                          npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                          npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
                          npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                          npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                          npm ERR! Building wheels for collected packages: cryptography
                          npm ERR!   Building wheel for cryptography (pyproject.toml): started
                          npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                          npm ERR! Failed to build cryptography
                          npm ERR! npm WARN using --force Recommended protections disabled.
                          npm ERR! npm WARN old lockfile
                          npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
                          npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                          npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                          npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                          npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                          npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                          npm ERR! Cache entry deserialization failed, entry ignored
                          npm ERR!   error: subprocess-exited-with-error
                          npm ERR!
                          npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                          npm ERR!   │ exit code: 1
                          npm ERR!   ╰─> [172 lines of output]
                          npm ERR!       running bdist_wheel
                          npm ERR!       running build
                          npm ERR!       running build_py
                          npm ERR!       creating build
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                          npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                          npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                          npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                          npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                          npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                          npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                          npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                          npm ERR!       running egg_info
                          npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                          npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                          npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                          npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                          npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                          npm ERR!       reading manifest template 'MANIFEST.in'
                          npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                          npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
                          npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
                          npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
                          npm ERR!       no previously-included directories found matching 'docs/_build'
                          npm ERR!       warning: no previously-included files found matching 'vectors'
                          npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                          npm ERR!       warning: no previously-included files found matching 'src/rust/target'
                          npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
                          npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                          npm ERR!       warning: no previously-included files found matching 'release.py'
                          npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                          npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                          npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                          npm ERR!       adding license file 'LICENSE'
                          npm ERR!       adding license file 'LICENSE.APACHE'
                          npm ERR!       adding license file 'LICENSE.BSD'
                          npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                          npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                          npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                          npm ERR!       running build_ext
                          npm ERR!       running build_rust
                          npm ERR!
                          npm ERR!           =============================DEBUG ASSISTANCE=============================
                          npm ERR!           If you are seeing a compilation error please try the following steps to
                          npm ERR!           successfully install cryptography:
                          npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                          npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                          npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                          npm ERR!              instructions for your platform.
                          npm ERR!           3) Check our frequently asked questions for more information:
                          npm ERR!              https://cryptography.io/en/latest/faq/
                          npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                          npm ERR!              https://cryptography.io/en/latest/installation/#rust
                          npm ERR!
                          npm ERR!           Python: 3.7.3
                          npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
                          npm ERR!           pip: n/a
                          npm ERR!           setuptools: 68.0.0
                          npm ERR!           setuptools_rust: 1.6.0
                          npm ERR!           rustc: n/a
                          npm ERR!
                          npm ERR!       error: can't find Rust compiler
                          npm ERR!
                          npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                          npm ERR!
                          npm ERR!       To update pip, run:
                          npm ERR!
                          npm ERR!           pip install --upgrade pip
                          npm ERR!
                          npm ERR!       and then retry package installation.
                          npm ERR!
                          npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                          npm ERR!
                          npm ERR!       This package requires Rust >=1.56.0.
                          npm ERR!       [end of output]
                          npm ERR!
                          npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                          npm ERR!   ERROR: Failed building wheel for cryptography
                          npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                          npm ERR! npm ERR! code 1
                          npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
                          npm ERR! npm ERR! command failed
                          npm ERR! npm ERR! command sh -c -- npip install
                          npm ERR!
                          npm ERR! npm ERR! A complete log of this run can be found in:
                          npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
                          npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
                          upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                          upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                          upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                          upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                          upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                          upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                          upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                          upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                          upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                          upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                          upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                          upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                          upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                          upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                          upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                          host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
                          Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
                          • C Cover1987
                            @glasfaser
                            pi@raspberrypi-4-iobroker:~ $ iob update
                            Used repository: stable
                            Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                            Adapter    "ble"          : 0.13.4   , installed 0.13.4
                            Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Adapter    "ical"         : 1.13.3   , installed 1.13.3
                            Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                            Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
                            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                            Adapter    "odl"          : 2.0.5    , installed 2.0.5
                            Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                            Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                            Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                            Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
                            Adapter    "wled"         : 0.6.7    , installed 0.6.7
                            Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                            Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                            und
                            pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                            Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                            Update admin from @6.3.5 to @6.8.0
                            host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                            NPM version: 8.19.4
                            Installing iobroker.admin@6.8.0... (System call)
                            npm WARN old lockfile Error: git dep preparation failed
                            npm WARN old lockfile     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:        63:27)
                            npm WARN old lockfile     at ChildProcess.emit (node:events:513:28)
                            npm WARN old lockfile     at maybeClose (node:internal/child_process:1100:16)
                            npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
                            npm WARN old lockfile  Could not fetch metadata for iobroker.esphome@git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#7a3b        f744580e98afe4bba5ac90e80c73cd3117f2 Error: git dep preparation failed
                            npm WARN old lockfile     at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5) {
                            npm WARN old lockfile   cmd: '/usr/bin/node',
                            npm WARN old lockfile   args: [
                            npm WARN old lockfile     '/usr/lib/node_modules/npm/bin/npm-cli.js',
                            npm WARN old lockfile     'install',
                            npm WARN old lockfile     '--force',
                            npm WARN old lockfile     '--cache=/home/iobroker/.npm',
                            npm WARN old lockfile     '--prefer-offline=false',
                            npm WARN old lockfile     '--prefer-online=false',
                            npm WARN old lockfile     '--offline=false',
                            npm WARN old lockfile     '--no-progress',
                            npm WARN old lockfile     '--no-save',
                            npm WARN old lockfile     '--no-audit',
                            npm WARN old lockfile     '--include=dev',
                            npm WARN old lockfile     '--include=peer',
                            npm WARN old lockfile     '--include=optional',
                            npm WARN old lockfile     '--no-package-lock-only',
                            npm WARN old lockfile     '--no-dry-run'
                            npm WARN old lockfile   ],
                            npm WARN old lockfile   code: 1,
                            npm WARN old lockfile   signal: null,
                            npm WARN old lockfile   stdout: '\n' +
                            npm WARN old lockfile     '> iobroker.esphome@0.2.4 install\n' +
                            npm WARN old lockfile     '> npip install\n' +
                            npm WARN old lockfile     '\n' +
                            npm WARN old lockfile     'No python_modules directory; installing pip locally if needed.\n' +
                            npm WARN old lockfile     'Successfully completed pip check.\n' +
                            npm WARN old lockfile     'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple\n' +
                            npm WARN old lockfile     'Collecting esphome>=2021.8\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)\        n' +
                            npm WARN old lockfile     'Collecting tornado>=3.2\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)        \n' +
                            npm WARN old lockfile     'Collecting voluptuous==0.12.2 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)\n        ' +
                            npm WARN old lockfile     'Collecting PyYAML==6.0 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)\n        ' +
                            npm WARN old lockfile     'Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)\n' +
                            npm WARN old lockfile     'Collecting colorama==0.4.4 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)\n'        +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB        )\n' +
                            npm WARN old lockfile     'Collecting tzlocal==4.1 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)\n' +
                            npm WARN old lockfile     'Collecting tzdata>=2021.1 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)\n' +
                            npm WARN old lockfile     'Collecting pyserial==3.5 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)\n' +
                            npm WARN old lockfile     'Collecting platformio==5.2.5 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)\n        ' +
                            npm WARN old lockfile     'Collecting esptool==3.2 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)\n' +
                            npm WARN old lockfile     'Collecting click==8.0.3 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)\n' +
                            npm WARN old lockfile     'Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none        -any.whl (592 kB)\n' +
                            npm WARN old lockfile     'Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl        (49 kB)\n' +
                            npm WARN old lockfile     'Collecting zeroconf==0.38.3 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)\n' +
                            npm WARN old lockfile     'Collecting kconfiglib==13.7.1 (from esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145        kB)\n' +
                            npm WARN old lockfile     'Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)\        n' +
                            npm WARN old lockfile     'Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20        kB)\n' +
                            npm WARN old lockfile     'Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-an        y.whl (22 kB)\n' +
                            npm WARN old lockfile     'Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)\n' +
                            npm WARN old lockfile     'Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.        2->esphome>=2021.8) (2.6.1)\n' +
                            npm WARN old lockfile     'Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)\n' +
                            npm WARN old lockfile     'Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (81        9 kB)\n' +
                            npm WARN old lockfile     'Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)\n' +
                            npm WARN old lockfile     'Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)\n' +
                            npm WARN old lockfile     'Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)\n' +
                            npm WARN old lockfile     'Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)\n' +
                            npm WARN old lockfile     'Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB        )\n' +
                            npm WARN old lockfile     'Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5        ->esphome>=2021.8) (2.21.0)\n' +
                            npm WARN old lockfile     'Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-an        y.whl (19 kB)\n' +
                            npm WARN old lockfile     'Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)\n'        +
                            npm WARN old lockfile     'Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)\n' +
                            npm WARN old lockfile     'Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)\n' +
                            npm WARN old lockfile     'Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)\n' +
                            npm WARN old lockfile     'Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0        -py2.py3-none-any.whl (15 kB)\n' +
                            npm WARN old lockfile     'Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-        linux_armv7l.whl (76 kB)\n' +
                            npm WARN old lockfile     'Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)\n' +
                            npm WARN old lockfile     'Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)\n' +
                            npm WARN old lockfile     'Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.        whl (33 kB)\n' +
                            npm WARN old lockfile     'Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)\n' +
                            npm WARN old lockfile     'Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)\n' +
                            npm WARN old lockfile     'Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (15        3 kB)\n' +
                            npm WARN old lockfile     'Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->espto        ol==3.2->esphome>=2021.8) (1.12.0)\n' +
                            npm WARN old lockfile     'Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)\n' +
                            npm WARN old lockfile     'Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached cryptography-41.0.3.tar.gz (630 kB)\n' +
                            npm WARN old lockfile     '  Installing build dependencies: started\n' +
                            npm WARN old lockfile     "  Installing build dependencies: finished with status 'done'\n" +
                            npm WARN old lockfile     '  Getting requirements to build wheel: started\n' +
                            npm WARN old lockfile     "  Getting requirements to build wheel: finished with status 'done'\n" +
                            npm WARN old lockfile     '  Preparing metadata (pyproject.toml): started\n' +
                            npm WARN old lockfile     "  Preparing metadata (pyproject.toml): finished with status 'done'\n" +
                            npm WARN old lockfile     'Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)\n        ' +
                            npm WARN old lockfile     'Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)\n' +
                            npm WARN old lockfile     'Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\n'        +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)\n' +
                            npm WARN old lockfile     'Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)\        n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)\n' +
                            npm WARN old lockfile     'Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8        )\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (1        4 kB)\n' +
                            npm WARN old lockfile     'Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)\n' +
                            npm WARN old lockfile     '  Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)\        n' +
                            npm WARN old lockfile     'Building wheels for collected packages: cryptography\n' +
                            npm WARN old lockfile     '  Building wheel for cryptography (pyproject.toml): started\n' +
                            npm WARN old lockfile     "  Building wheel for cryptography (pyproject.toml): finished with status 'error'\n" +
                            npm WARN old lockfile     'Failed to build cryptography\n',
                            npm WARN old lockfile   stderr: 'npm WARN using --force Recommended protections disabled.\n' +
                            npm WARN old lockfile     'npm WARN old lockfile \n' +
                            npm WARN old lockfile     'npm WARN old lockfile The package-lock.json file was created with an old version of npm,\n' +
                            npm WARN old lockfile     'npm WARN old lockfile so supplemental metadata must be fetched from the registry.\n' +
                            npm WARN old lockfile     'npm WARN old lockfile This is a one-time fix-up, please be patient...\n' +
                            npm WARN old lockfile     'npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated\n' +
                            npm WARN old lockfile     'npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated\n' +
                            npm WARN old lockfile     'npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated\n' +
                            npm WARN old lockfile     'npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#depreca        ted\n' +
                            npm WARN old lockfile     'npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade t        o chokidar 3 with 15x fewer dependencies\n' +
                            npm WARN old lockfile     'Cache entry deserialization failed, entry ignored\n' +
                            npm WARN old lockfile     '  Cache entry deserialization failed, entry ignored\n' +
                            npm WARN old lockfile     '  error: subprocess-exited-with-error\n' +
                            npm WARN old lockfile     '  \n' +
                            npm WARN old lockfile     '  × Building wheel for cryptography (pyproject.toml) did not run successfully.\n' +
                            npm WARN old lockfile     '  │ exit code: 1\n' +
                            npm WARN old lockfile     '  ╰─> [172 lines of output]\n' +
                            npm WARN old lockfile     '      running bdist_wheel\n' +
                            npm WARN old lockfile     '      running build\n' +
                            npm WARN old lockfile     '      running build_py\n' +
                            npm WARN old lockfile     '      creating build\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/ha        zmat\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat        \n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                            npm WARN old lockfile     '      copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/        x509\n' +
                            npm WARN old lockfile     '      copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n' +
                            npm WARN old lockfile     '      copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                            npm WARN old lockfile     '      copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                            npm WARN old lockfile     '      copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509\n'        +
                            npm WARN old lockfile     '      copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x5        09\n' +
                            npm WARN old lockfile     '      copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/x509\n' +
                            npm WARN old lockfile     '      copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509        \n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/bindings\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/backends\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/crypto        graphy/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptogr        aphy/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/crypt        ography/hazmat/primitives\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/bindings/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/bindings/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/bindings/openssl\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/backends/openssl\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/c        ryptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cr        yptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryp        tography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cry        ptography/hazmat/primitives/kdf\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpyth        on-37/cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/        cryptography/hazmat/primitives/ciphers\n' +
                            npm WARN old lockfile     '      creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-        37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpytho        n-37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython        -37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37        /cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpyt        hon-37/cryptography/hazmat/primitives/asymmetric\n' +
                            npm WARN old lockfile     '      copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-3        7/cryptography/hazmat/primitives/as'... 8950 more characters
                            npm WARN old lockfile }
                            npm ERR! code 1
                            npm ERR! git dep preparation failed
                            npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                            npm ERR! > iobroker.esphome@0.2.4 install
                            npm ERR! > npip install
                            npm ERR!
                            npm ERR! No python_modules directory; installing pip locally if needed.
                            npm ERR! Successfully completed pip check.
                            npm ERR! Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                            npm ERR! Collecting esphome>=2021.8
                            npm ERR!   Using cached https://www.piwheels.org/simple/esphome/esphome-2022.2.6-py2.py3-none-any.whl (2.1 MB)
                            npm ERR! Collecting tornado>=3.2
                            npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.2-cp37-abi3-linux_armv7l.whl (422 kB)
                            npm ERR! Collecting voluptuous==0.12.2 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.12.2-py3-none-any.whl (35 kB)
                            npm ERR! Collecting PyYAML==6.0 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/pyyaml/PyYAML-6.0-cp37-cp37m-linux_armv7l.whl (45 kB)
                            npm ERR! Collecting paho-mqtt==1.6.1 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
                            npm ERR! Collecting colorama==0.4.4 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.4-py2.py3-none-any.whl (16 kB)
                            npm ERR!   Using cached https://www.piwheels.org/simple/tornado/tornado-6.1-cp37-cp37m-linux_armv7l.whl (428 kB)
                            npm ERR! Collecting tzlocal==4.1 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-4.1-py3-none-any.whl (19 kB)
                            npm ERR! Collecting tzdata>=2021.1 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/tzdata/tzdata-2023.3-py2.py3-none-any.whl (341 kB)
                            npm ERR! Collecting pyserial==3.5 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
                            npm ERR! Collecting platformio==5.2.5 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/platformio/platformio-5.2.5-py3-none-any.whl (343 kB)
                            npm ERR! Collecting esptool==3.2 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/esptool/esptool-3.2-py3-none-any.whl (326 kB)
                            npm ERR! Collecting click==8.0.3 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/click/click-8.0.3-py3-none-any.whl (97 kB)
                            npm ERR! Collecting esphome-dashboard==20220209.0 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20220209.0-py3-none-any.whl (592 kB)
                            npm ERR! Collecting aioesphomeapi==10.8.2 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/aioesphomeapi/aioesphomeapi-10.8.2-py2.py3-none-any.whl (49 kB)
                            npm ERR! Collecting zeroconf==0.38.3 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/zeroconf/zeroconf-0.38.3-py3-none-any.whl (97 kB)
                            npm ERR! Collecting kconfiglib==13.7.1 (from esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
                            npm ERR! Collecting protobuf<4.0,>=3.12.2 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/protobuf/protobuf-3.20.3-py2.py3-none-any.whl (162 kB)
                            npm ERR! Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==10.8.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
                            npm ERR! Collecting importlib-metadata (from click==8.0.3->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/importlib-metadata/importlib_metadata-6.7.0-py3-none-any.whl (22 kB)
                            npm ERR! Collecting bitstring>=3.1.6 (from esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/bitstring/bitstring-4.1.0-py3-none-any.whl (55 kB)
                            npm ERR! Requirement already satisfied: cryptography>=2.1.4 in /usr/lib/python3/dist-packages (from esptool==3.2->esphome>=2021.8) (2.6.1)
                            npm ERR! Collecting ecdsa>=0.16.0 (from esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/ecdsa/ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
                            npm ERR! Collecting reedsolo<=1.5.4,>=1.5.3 (from esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/reedsolo/reedsolo-1.5.4-cp37-cp37m-linux_armv7l.whl (819 kB)
                            npm ERR! Collecting aiofiles==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/aiofiles/aiofiles-0.8.0-py3-none-any.whl (13 kB)
                            npm ERR! Collecting ajsonrpc==1.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
                            npm ERR! Collecting bottle==0.12.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/bottle/bottle-0.12.25-py3-none-any.whl (90 kB)
                            npm ERR! Collecting marshmallow<4,>=2 (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached marshmallow-3.19.0-py3-none-any.whl (49 kB)
                            npm ERR! Collecting pyelftools<1,>=0.27 (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/pyelftools/pyelftools-0.29-py2.py3-none-any.whl (174 kB)
                            npm ERR! Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==5.2.5->esphome>=2021.8) (2.21.0)
                            npm ERR! Collecting semantic-version==2.9.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/semantic-version/semantic_version-2.9.0-py2.py3-none-any.whl (19 kB)
                            npm ERR! Collecting starlette==0.18.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/starlette/starlette-0.18.0-py3-none-any.whl (59 kB)
                            npm ERR! Collecting tabulate==0.8.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/tabulate/tabulate-0.8.10-py3-none-any.whl (37 kB)
                            npm ERR! Collecting uvicorn==0.16.0 (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/uvicorn/uvicorn-0.16.0-py3-none-any.whl (56 kB)
                            npm ERR! Collecting wsproto==1.0.* (from platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/wsproto/wsproto-1.0.0-py3-none-any.whl (24 kB)
                            npm ERR! Collecting pytz-deprecation-shim (from tzlocal==4.1->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/pytz-deprecation-shim/pytz_deprecation_shim-0.1.0.post0-py2.py3-none-any.whl (15 kB)
                            npm ERR! Collecting backports.zoneinfo (from tzlocal==4.1->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/backports-zoneinfo/backports.zoneinfo-0.2.1-cp37-cp37m-linux_armv7l.whl (76 kB)
                            npm ERR! Collecting ifaddr>=0.1.7 (from zeroconf==0.38.3->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
                            npm ERR! Collecting anyio<4,>=3.0.0 (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/anyio/anyio-3.7.1-py3-none-any.whl (80 kB)
                            npm ERR! Collecting typing-extensions (from starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.7.1-py3-none-any.whl (33 kB)
                            npm ERR! Collecting asgiref>=3.4.0 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/asgiref/asgiref-3.7.2-py3-none-any.whl (24 kB)
                            npm ERR! Collecting h11>=0.8 (from uvicorn==0.16.0->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
                            npm ERR! Collecting bitarray==2.8.0 (from bitstring>=3.1.6->esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/bitarray/bitarray-2.8.0-cp37-cp37m-linux_armv7l.whl (153 kB)
                            npm ERR! Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==3.2->esphome>=2021.8) (1.12.0)
                            npm ERR! Collecting packaging>=17.0 (from marshmallow<4,>=2->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/packaging/packaging-23.1-py3-none-any.whl (48 kB)
                            npm ERR! Collecting cryptography>=2.1.4 (from esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached cryptography-41.0.3.tar.gz (630 kB)
                            npm ERR!   Installing build dependencies: started
                            npm ERR!   Installing build dependencies: finished with status 'done'
                            npm ERR!   Getting requirements to build wheel: started
                            npm ERR!   Getting requirements to build wheel: finished with status 'done'
                            npm ERR!   Preparing metadata (pyproject.toml): started
                            npm ERR!   Preparing metadata (pyproject.toml): finished with status 'done'
                            npm ERR! Collecting cffi>=1.12 (from cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/cffi/cffi-1.15.1-cp37-cp37m-linux_armv7l.whl (219 kB)
                            npm ERR! Collecting zipp>=0.5 (from importlib-metadata->click==8.0.3->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/zipp/zipp-3.15.0-py3-none-any.whl (6.8 kB)
                            npm ERR! Collecting idna>=2.8 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/idna/idna-3.4-py3-none-any.whl (61 kB)
                            npm ERR! Collecting sniffio>=1.1 (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/sniffio/sniffio-1.3.0-py3-none-any.whl (10 kB)
                            npm ERR! Collecting exceptiongroup (from anyio<4,>=3.0.0->starlette==0.18.*->platformio==5.2.5->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.1.3-py3-none-any.whl (14 kB)
                            npm ERR! Collecting pycparser (from cffi>=1.12->cryptography>=2.1.4->esptool==3.2->esphome>=2021.8)
                            npm ERR!   Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.21-py2.py3-none-any.whl (119 kB)
                            npm ERR! Building wheels for collected packages: cryptography
                            npm ERR!   Building wheel for cryptography (pyproject.toml): started
                            npm ERR!   Building wheel for cryptography (pyproject.toml): finished with status 'error'
                            npm ERR! Failed to build cryptography
                            npm ERR! npm WARN using --force Recommended protections disabled.
                            npm ERR! npm WARN old lockfile
                            npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                            npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                            npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
                            npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
                            npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                            npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                            npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
                            npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
                            npm ERR! Cache entry deserialization failed, entry ignored
                            npm ERR!   error: subprocess-exited-with-error
                            npm ERR!
                            npm ERR!   × Building wheel for cryptography (pyproject.toml) did not run successfully.
                            npm ERR!   │ exit code: 1
                            npm ERR!   ╰─> [172 lines of output]
                            npm ERR!       running bdist_wheel
                            npm ERR!       running build_py
                            npm ERR!       copying src/cryptography/fernet.py -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       copying src/cryptography/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       copying src/cryptography/exceptions.py -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       copying src/cryptography/__about__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       copying src/cryptography/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       copying src/cryptography/hazmat/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                            npm ERR!       copying src/cryptography/hazmat/_oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/general_name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/oid.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/name.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/ocsp.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/extensions.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/x509/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/x509
                            npm ERR!       copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                            npm ERR!       copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends
                            npm ERR!       copying src/cryptography/hazmat/primitives/_asymmetric.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/_cipheralgorithm.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/_serialization.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/openssl
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/backends/openssl
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/kdf
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/ciphers
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/types.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/asymmetric
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                            npm ERR!       copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/twofactor
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs7.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/primitives/serialization
                            npm ERR!       running egg_info
                            npm ERR!       writing src/cryptography.egg-info/PKG-INFO
                            npm ERR!       writing dependency_links to src/cryptography.egg-info/dependency_links.txt
                            npm ERR!       writing requirements to src/cryptography.egg-info/requires.txt
                            npm ERR!       writing top-level names to src/cryptography.egg-info/top_level.txt
                            npm ERR!       reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
                            npm ERR!       reading manifest template 'MANIFEST.in'
                            npm ERR!       /tmp/pip-build-env-nz56ts3z/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                            npm ERR!         config = read_configuration(filepath, True, ignore_option_errors, dist)
                            npm ERR!       warning: no files found matching '*.c' under directory 'src/_cffi_src'
                            npm ERR!       warning: no files found matching '*.h' under directory 'src/_cffi_src'
                            npm ERR!       no previously-included directories found matching 'docs/_build'
                            npm ERR!       warning: no previously-included files found matching 'vectors'
                            npm ERR!       warning: no previously-included files matching '*' found under directory 'vectors'
                            npm ERR!       warning: no previously-included files found matching 'src/rust/target'
                            npm ERR!       warning: no previously-included files matching '*' found under directory 'src/rust/target'
                            npm ERR!       warning: no previously-included files matching '*' found under directory '.github'
                            npm ERR!       warning: no previously-included files found matching 'release.py'
                            npm ERR!       warning: no previously-included files found matching '.readthedocs.yml'
                            npm ERR!       warning: no previously-included files found matching 'ci-constraints-requirements.txt'
                            npm ERR!       warning: no previously-included files found matching 'mypy.ini'
                            npm ERR!       adding license file 'LICENSE'
                            npm ERR!       adding license file 'LICENSE.APACHE'
                            npm ERR!       adding license file 'LICENSE.BSD'
                            npm ERR!       writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
                            npm ERR!       copying src/cryptography/py.typed -> build/lib.linux-armv7l-cpython-37/cryptography
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/_openssl.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/asn1.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/exceptions.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/ocsp.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/pkcs7.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/x509.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust
                            npm ERR!       creating build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/__init__.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dh.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/dsa.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/ed448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hashes.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/hmac.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/kdf.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/poly1305.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x25519.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       copying src/cryptography/hazmat/bindings/_rust/openssl/x448.pyi -> build/lib.linux-armv7l-cpython-37/cryptography/hazmat/bindings/_rust/openssl
                            npm ERR!       running build_ext
                            npm ERR!       running build_rust
                            npm ERR!
                            npm ERR!           =============================DEBUG ASSISTANCE=============================
                            npm ERR!           If you are seeing a compilation error please try the following steps to
                            npm ERR!           successfully install cryptography:
                            npm ERR!           1) Upgrade to the latest pip and try again. This will fix errors for most
                            npm ERR!              users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
                            npm ERR!           2) Read https://cryptography.io/en/latest/installation/ for specific
                            npm ERR!              instructions for your platform.
                            npm ERR!           3) Check our frequently asked questions for more information:
                            npm ERR!              https://cryptography.io/en/latest/faq/
                            npm ERR!           4) Ensure you have a recent Rust toolchain installed:
                            npm ERR!              https://cryptography.io/en/latest/installation/#rust
                            npm ERR!
                            npm ERR!           Python: 3.7.3
                            npm ERR!           platform: Linux-5.10.103-v7l+-armv7l-with-debian-10.13
                            npm ERR!           pip: n/a
                            npm ERR!           setuptools: 68.0.0
                            npm ERR!           setuptools_rust: 1.6.0
                            npm ERR!           rustc: n/a
                            npm ERR!
                            npm ERR!       error: can't find Rust compiler
                            npm ERR!
                            npm ERR!       If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
                            npm ERR!
                            npm ERR!       To update pip, run:
                            npm ERR!
                            npm ERR!           pip install --upgrade pip
                            npm ERR!
                            npm ERR!       and then retry package installation.
                            npm ERR!
                            npm ERR!       If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
                            npm ERR!
                            npm ERR!       This package requires Rust >=1.56.0.
                            npm ERR!       [end of output]
                            npm ERR!
                            npm ERR!   note: This error originates from a subprocess, and is likely not a problem with pip.
                            npm ERR!   ERROR: Failed building wheel for cryptography
                            npm ERR! ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
                            npm ERR! npm ERR! code 1
                            npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonehqIr75
                            npm ERR! npm ERR! command failed
                            npm ERR! npm ERR! command sh -c -- npip install
                            npm ERR!
                            npm ERR! npm ERR! A complete log of this run can be found in:
                            npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_33_24_729Z-debug-0.log
                            npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_31_09_665Z-debug-0.log
                            upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                            upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                            upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                            upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                            upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                            upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                            upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                            upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                            upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                            upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                            upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                            upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                            upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                            upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                            host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is started
                            Wenn ich es richtig verstanden habe ist mein pip nicht aktuell und müsste updaten mit
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @cover1987
                            Nee .. keine Ahnung was du da mal quer installiert hast .
                            Wichtig .. ein Backup hast du !!!
                            mach mal :
                            iob stop
                            find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                            iob fix
                            iob start
                            C 1 Antwort Letzte Antwort
                            • GlasfaserG Glasfaser
                              @cover1987
                              mach mal :
                              iob stop
                              iob fix
                              iob start
                              Cover1987
                              @glasfaser
                              Ja Backup ist vorhanden
                              pi@raspberrypi-4-iobroker:~ $ iob stop
                              pi@raspberrypi-4-iobroker:~ $ find "/opt/iobroker/" -iname "*package-lock*" -exec rm "{}" \;
                              pi@raspberrypi-4-iobroker:~ $ iob fix
                              library: loaded
                              Library version=2022-12-09
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2023-04-02
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/5)
                              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                              Reading package lists... Done
                              Installed gcc-c++
                                  Checking ioBroker user and directory permissions (2/5)
                                  Check and cleanup npm temporary directories (3/5)
                              Done.
                                  Database maintenance (4/5)
                              Checking for uncompressed JSONL databases... This might take a while!
                              Compressing /opt/iobroker/iobroker-data/states.jsonl
                              Compressing /opt/iobroker/iobroker-data/objects.jsonl
                              Compressed 2 JSONL files. Done
                                  Checking autostart (5/5)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              pi@raspberrypi-4-iobroker:~ $ iob start
                              • C Cover1987
                                @glasfaser
                                library: loaded
                                Installed gcc-c++
                                Done.
                                Autostart enabled!
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @cover1987
                                jetzt nochmal
                                iob update
                                iob upgrade admin --debug
                                  @cover1987
                                  jetzt nochmal
                                  iob update
                                  Cover1987
                                  @glasfaser
                                  pi@raspberrypi-4-iobroker:~ $ iob update
                                  Used repository: stable
                                  Adapter    "admin"        : 6.8.0    , installed 6.3.5  [Updatable]
                                  Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                                  Adapter    "ble"          : 0.13.4   , installed 0.13.4
                                  Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                                  Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                                  Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                  Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                                  Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
                                  Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                  Adapter    "odl"          : 2.0.5    , installed 2.0.5
                                  Adapter    "ping"         : 1.6.2    , installed 1.5.3  [Updatable]
                                  Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                                  Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                  Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
                                  Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                                  Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
                                  Adapter    "wled"         : 0.6.7    , installed 0.6.7
                                  Adapter    "zigbee"       : 1.8.23   , installed 1.8.23
                                  Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                                  pi@raspberrypi-4-iobroker:~ $ iob upgrade admin --debug
                                  Would you like to upgrade admin from @6.3.5 to @6.8.0 now? [(y)es, (n)o]: y
                                  Update admin from @6.3.5 to @6.8.0
                                  host.raspberrypi-4-iobroker Adapter "system.adapter.admin.0" is stopped.
                                  NPM version: 8.19.4
                                  Installing iobroker.admin@6.8.0... (System call)
                                  npm ERR! code 1
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!       /tmp/pip-build-env-euzi8jyh/overlay/lib/python3.7/site-packages/setuptools/config/pyprojecttoml.py:66: _BetaConfiguration: Support for `[tool.setuptools]` in `pyproject.toml` is still *beta*.
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!           pip: n/a
                                  npm ERR!           rustc: n/a
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR!
                                  npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneqgjV2V
                                  npm ERR!
                                  npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_54_10_933Z-debug-0.log
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-08-22T15_53_58_978Z-debug-0.log
                                  • C Cover1987
                                    @glasfaser
                                    NPM version: 8.19.4
                                    npm ERR! code 1
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!           pip: n/a
                                    npm ERR!           rustc: n/a
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @cover1987 sagte in Adapter lassen sich zum Teil nicht aktualisieren:
                                    puhh da klemmt was ..
                                    sieht nach dem aus , bzw. mach das mal
                                    https://forum.iobroker.net/post/997137
                                      Cover1987
                                      @glasfaser
                                      pi@raspberrypi-4-iobroker:/lib/python3.7 $ python3 --version
                                      Python 3.7.3
                                      pi@raspberrypi-4-iobroker:/ $ sudo mv /lib/python3.7/EXTERNALLY-MANAGED ~
                                      mv: cannot stat '/lib/python3.7/EXTERNALLY-MANAGED': No such file or directory
                                      • C Cover1987
                                        @glasfaser
                                        Python 3.7.3
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        hast du weiter gelesen im Thread das war nur ein Namensvorschlag !
                                          Cover1987
                                          @glasfaser
                                          Ja, den Namen habe ich auf meine Python 3 Version (3.7.3, dementsprechend 3.7) angepasst. Im Verzeichnis habe ich manuell auch kein EXTERNALLY-MANAGED gefunden.
