  4. Problem nach Update, Node nicht vorhanden
    5.2k
22 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
  • F Flixer
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    aarch64
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    /usr/local/bin/npx
    /usr/local/bin/corepack
    v18.17.1
    -bash: /usr/local/bin/node: No such file or directory
    @flixer
    Dann hast du da mal irgendwann etwas falsch gemacht.
    Lies dich hier ein:
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    F 1 Antwort Letzte Antwort
      @flixer
      Lies dich hier ein:
      Flixer
      Ich habe jetzt versucht node wieder zu deinstallieren mit "sudo apt purge --autoremove nodejs* npm node-* libnode*" und bekomme nun diese Meldung:
        nodejs*
      0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
      After this operation, 177 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 55403 files and directories currently installed.)
      Removing nodejs (18.17.1-deb-1nodesource1) ...
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/yallist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/write-file-atomic' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wrappy' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wide-align' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wcwidth' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/walk-up-path' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-name' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-license' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/util-deprecate' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-slug' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-filename' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/treeverse' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tiny-relative-date' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/supports-color' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/strip-ansi' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string_decoder' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string-width' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ssri' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-expression-parse' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-correct' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/smart-buffer' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/signal-exit' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/set-blocking' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safer-buffer' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safe-buffer' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/readable-stream' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json-fast' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-cmd-shim' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/qrcode-terminal' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promzard' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-retry' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-inflight' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-call-limit' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-all-reject-late' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proc-log' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/path-is-absolute' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/parse-conflict-json' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/pacote/lib/util' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/p-map' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-registry-fetch' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-profile' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-pick-manifest' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-packlist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-package-arg' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-bundled' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-audit-report' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/normalize-package-data' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/.github' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/negotiator' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mute-stream' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ms' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minizlib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-sized' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-json-stream' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-flush' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-fetch' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-collect' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/make-fetch-happen' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmversion/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmteam' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmsearch' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpublish' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpack' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmorg' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmhook' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmfund' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmexec/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmdiff' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmaccess' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff-apply' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/jsonparse' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-stringify-nice' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-parse-even-better-errors' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/isexe' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-lambda' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-core-module' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-cidr' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ip' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ip-regex' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/infer-owner' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/indent-string' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ignore-walk' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/iconv-lite' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/humanize-ms' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/https-proxy-agent/dist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-proxy-agent/dist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-cache-semantics' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/hosted-git-info' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-unicode' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-flag' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/gauge/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/function-bind' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs.realpath' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs-minipass' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fastest-levenshtein' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/err-code' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/env-paths' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/encoding' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/emoji-regex' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/diff' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/depd/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/delegates' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/defaults' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/debug/node_modules/ms' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/console-control-strings' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/concat-map' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/common-ancestor-path' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-support' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-name' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-convert' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clone' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-table3' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-columns' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clean-stack' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cidr-regex' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chalk' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cacache/lib/util' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/builtins' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/brace-expansion' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/binary-extensions' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/bin-links' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/balanced-match' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/are-we-there-yet' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aproba' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ansi-styles' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ansi-regex' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aggregate-error' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agentkeepalive' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agent-base/dist/src' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@tootallnate/once/dist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/run-script' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/package-json' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/name-from-folder' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/move-file' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/metavuln-calculator' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/map-workspaces' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/installed-package-contents' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/git/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/common' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/disparity-colors' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/config/lib' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/string-locale-compare' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/config' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/commands' not empty so not removed
      dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/commands' not empty so not removed
      Processing triggers for man-db (2.9.4-2) ...
      • F Flixer
          nodejs*
        @flixer sagte in Problem nach Update, Node nicht vorhanden:
        Warum?
        Du musst die falschen Pfade löschen.
        Siehe Teil 2 vom bereits verlinkten HowTo.
        crunchipC F 2 Antworten Letzte Antwort
          Warum?
          crunchipC Offline
          crunchipC Offline
          @thomas-braun sagte in Problem nach Update, Node nicht vorhanden:
          Warum?
          weils vllt für den ein oder anderen nicht ganz ersichtlich und arbeitet Teil 1 ab
          eventuell in Teil 1 noch ne Anmerkung zwecks Pfade machen, bei
          @thomas-braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
          Alt-Installationen entfernen:
          Debian/RaspberryOS/Ubuntu und artverwandtes:
          Alt- und Vorinstallationen (z. B. die dfsg-Version von nodejs) entfernen.
            Warum?
            Flixer
            Ich habe
            sudo rm /usr/local/bin/node
            ausgeführt. Leider läßt sich das nicht löschen.
            pi@RasPi4ioBroker:~ $ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            aarch64
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/bin/npm
            /usr/bin/npx
            /usr/bin/corepack
            v18.17.1
            pi@RasPi4ioBroker:~ $ sudo rm /usr/local/bin/node
            rm: cannot remove '/usr/local/bin/node': No such file or directory
            es steht jetzt immernoch der "/usr/local/bin/node" drin.
              Warum?
              @crunchip
              Gibt doch sogar ein 'Inhaltsverzeichis':
              Teil 1: Installation und Update
              Teil 2: Installationen geradeziehen (siehe 2. Posting im Thread)
              • F Flixer
                Ich habe
                aarch64
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/bin/npm
                /usr/bin/npx
                /usr/bin/corepack
                v18.17.1
                Starte mal die Kiste ordentlich durch.
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  @thomas-braun schon, wer aber nicht auf die falschen Pfade achtet und meint, mit nodejs entfernen und neu installieren ist es getann, arbeitet Teil 1 der Reihe nach ab, wie hier im Beispiel zu sehen und kommt erst gar nicht auf die Idee Teil 2 zu lesen
                    @crunchip
                    Muss Windows-Denke sein... ;-)
                    Warum sollte eine Sache auf einmal funktionieren, wenn man sie einfach nur oft genug 'neu macht'?
                    Du musst sie nur anders (richtig) machen.
                      @crunchip
                      crunchipC Offline
                      crunchipC Offline
                      frag nicht mich😂
                      • F Offline
                        Flixer
                        UIUIUI!!!!!!
                        Nach dem 5ten Neustart bekomme ich die node wieder angezeigt. Ich musste die Ordner alle einzeln löschen, neustarten, löschen usw. Damit habe ich nicht gerechnet...
                        Der ioBroker ist auch gleich mit gestartet und läuft. Bei meinen beiden Smartmetern war irgendwie was falsch eingetragen und jetzt laufen die auch wieder SUPER, vielen Dank!
                        • F Flixer
                          UIUIUI!!!!!!
                          Ich auch nicht...
                          Ist auch nicht der Fall.
                          • F Flixer
                            UIUIUI!!!!!!
                            @flixer
                            Was sagt denn
                            iob diag
                            dazu?
                              @flixer
                              Was sagt denn
                              iob diag
                              dazu?
                              Flixer
                                                   v.2023-04-16
                              Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                              Kernel:                 6.1.21-v8+
                              Installation:           Native
                              User-ID:                1000
                              X-Server:               false
                              Pending OS-Updates:     0
                              Pending iob updates:    1
                              Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                      /usr/bin/node           v18.17.1
                                                      /usr/bin/npm            9.6.7
                                                      /usr/bin/npx            9.6.7
                              Recommended versions are nodejs 18.x.y and npm 9.x.y
                              MEMORY:
                              Mem:            3.8G        832M        2.5G        0.0K        491M        2.9G
                              Swap:            99M          0B         99M
                              Total:          3.9G        832M        2.6G
                              Active iob-Instances:   20
                              Active repo(s): stable
                              ioBroker Core:          js-controller           4.0.24
                                                      admin                   6.8.0
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : RasPi4ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.web.1                    : web                   : RasPi4ioBroker                           - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.2                    : web                   : RasPi4ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              Objects:                3063
                              States:                 2610
                              Size of iob-Database:
                              7.8M    /opt/iobroker/iobroker-data/objects.jsonl
                              3.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                              3.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/objects.json.broken
                              4.2M    /opt/iobroker/iobroker-data/states.jsonl
                              168K    /opt/iobroker/iobroker-data/states.json.migrated
                              168K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/states.json.broken
                              • F Flixer
                                                     v.2023-04-16
                                Kernel:                 6.1.21-v8+
                                User-ID:                1000
                                X-Server:               false
                                                        /usr/bin/npm            9.6.7
                                                        /usr/bin/npx            9.6.7
                                MEMORY:
                                Swap:            99M          0B         99M
                                                        admin                   6.8.0
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                3063
                                States:                 2610
                                @flixer
                                Passt. Hau das Update für den ioBroker noch rein.
                                  @flixer
                                  Flixer
                                  ich weiß leider nicht was ich noch aktualisieren soll. Folgende Befehle habe ich alle nochmal durchlaufen lassen.
                                  sudo iobroker stop
                                  sudo iobroker update
                                  sudo iobroker upgrade self
                                  sudo iobroker start
                                  Bis auf JavaScript (6.1.4 auf 7.0.3) ist alles aktuell. Ich muss erst noch nachsehen, ob meine Scripte von der Aktualisierung betroffen sind, daher noch kein Update.
                                  • F Flixer
                                    sudo iobroker stop
                                    sudo iobroker start
                                    DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    @flixer iobroker NIEMALS mit sudo anpacken !
                                    Lehrling seit 1975 !!!
