  4. Problem nach Update, Node nicht vorhanden
    5.3k
22 Beiträge 4 Kommentatoren 2.5k Aufrufe 4 Beobachtet
    @flixer
    Alles gut.
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    sagt?
    Flixer
    aarch64
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    /usr/local/bin/npx
    /usr/local/bin/corepack
    v18.17.1
    -bash: /usr/local/bin/node: No such file or directory
    • F Flixer
      aarch64
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      /usr/local/bin/npx
      v18.17.1
      @flixer
      Dann hast du da mal irgendwann etwas falsch gemacht.
      Lies dich hier ein:
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      F 1 Antwort Letzte Antwort
        @flixer
        Lies dich hier ein:
        Flixer
        Ich habe jetzt versucht node wieder zu deinstallieren mit "sudo apt purge --autoremove nodejs* npm node-* libnode*" und bekomme nun diese Meldung:
          nodejs*
        0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
        After this operation, 177 MB disk space will be freed.
        Do you want to continue? [Y/n] y
        (Reading database ... 55403 files and directories currently installed.)
        Removing nodejs (18.17.1-deb-1nodesource1) ...
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/yallist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/write-file-atomic' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wrappy' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wide-align' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wcwidth' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/walk-up-path' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-name' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-license' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/util-deprecate' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-slug' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-filename' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/treeverse' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tiny-relative-date' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/supports-color' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/strip-ansi' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string_decoder' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string-width' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ssri' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-expression-parse' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-correct' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/smart-buffer' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/signal-exit' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/set-blocking' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safer-buffer' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safe-buffer' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/readable-stream' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json-fast' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-cmd-shim' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/qrcode-terminal' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promzard' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-retry' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-inflight' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-call-limit' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-all-reject-late' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proc-log' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/path-is-absolute' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/parse-conflict-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/pacote/lib/util' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/p-map' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-registry-fetch' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-profile' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-pick-manifest' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-packlist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-package-arg' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-bundled' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-audit-report' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/normalize-package-data' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/.github' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/negotiator' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mute-stream' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ms' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minizlib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-sized' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-json-stream' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-flush' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-fetch' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-collect' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/make-fetch-happen' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmversion/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmteam' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmsearch' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpublish' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpack' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmorg' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmhook' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmfund' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmexec/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmdiff' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmaccess' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff-apply' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/jsonparse' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-stringify-nice' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-parse-even-better-errors' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/isexe' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-lambda' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-fullwidth-code-point' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-core-module' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-cidr' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ip' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ip-regex' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/infer-owner' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/indent-string' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ignore-walk' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/iconv-lite' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/humanize-ms' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/https-proxy-agent/dist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-proxy-agent/dist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-cache-semantics' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/hosted-git-info' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-unicode' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-flag' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/gauge/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/function-bind' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs.realpath' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs-minipass' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fastest-levenshtein' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/err-code' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/env-paths' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/encoding' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/emoji-regex' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/diff' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/depd/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/delegates' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/defaults' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/debug/node_modules/ms' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/console-control-strings' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/concat-map' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/common-ancestor-path' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-support' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-name' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-convert' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clone' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-table3' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-columns' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clean-stack' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cidr-regex' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chalk' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cacache/lib/util' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/builtins' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/brace-expansion' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/binary-extensions' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/bin-links' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/balanced-match' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/are-we-there-yet' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aproba' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ansi-styles' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ansi-regex' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aggregate-error' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agentkeepalive' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agent-base/dist/src' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@tootallnate/once/dist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/run-script' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/package-json' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/name-from-folder' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/move-file' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/metavuln-calculator' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/map-workspaces' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/installed-package-contents' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/git/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/common' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/disparity-colors' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/config/lib' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/string-locale-compare' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils/config' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/commands' not empty so not removed
        dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/commands' not empty so not removed
        Processing triggers for man-db (2.9.4-2) ...
        • F Flixer
            nodejs*
          @flixer sagte in Problem nach Update, Node nicht vorhanden:
          Warum?
          Du musst die falschen Pfade löschen.
          Siehe Teil 2 vom bereits verlinkten HowTo.
          crunchipC F 2 Antworten Letzte Antwort
            Warum?
            crunchipC Offline
            crunchipC Offline
            @thomas-braun sagte in Problem nach Update, Node nicht vorhanden:
            Warum?
            weils vllt für den ein oder anderen nicht ganz ersichtlich und arbeitet Teil 1 ab
            eventuell in Teil 1 noch ne Anmerkung zwecks Pfade machen, bei
            @thomas-braun sagte in [HowTo] Nodejs-Installation und Upgrades unter Debian:
            Alt-Installationen entfernen:
            Debian/RaspberryOS/Ubuntu und artverwandtes:
            Alt- und Vorinstallationen (z. B. die dfsg-Version von nodejs) entfernen.
              Warum?
              Flixer
              Ich habe
              sudo rm /usr/local/bin/node
              ausgeführt. Leider läßt sich das nicht löschen.
              pi@RasPi4ioBroker:~ $ uname -m && type -P nodejs node npm npx corepack && nodejs -v && node -v && npm -v && npx -v && corepack -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
              aarch64
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/bin/npm
              /usr/bin/npx
              /usr/bin/corepack
              v18.17.1
              pi@RasPi4ioBroker:~ $ sudo rm /usr/local/bin/node
              rm: cannot remove '/usr/local/bin/node': No such file or directory
              es steht jetzt immernoch der "/usr/local/bin/node" drin.
                Warum?
                @crunchip
                Gibt doch sogar ein 'Inhaltsverzeichis':
                Teil 1: Installation und Update
                Teil 2: Installationen geradeziehen (siehe 2. Posting im Thread)
                • F Flixer
                  Ich habe
                  aarch64
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  /usr/bin/corepack
                  v18.17.1
                  Starte mal die Kiste ordentlich durch.
                    @crunchip
                    crunchipC Offline
                    crunchipC Offline
                    @thomas-braun schon, wer aber nicht auf die falschen Pfade achtet und meint, mit nodejs entfernen und neu installieren ist es getann, arbeitet Teil 1 der Reihe nach ab, wie hier im Beispiel zu sehen und kommt erst gar nicht auf die Idee Teil 2 zu lesen
                      @crunchip
                      Muss Windows-Denke sein... ;-)
                      Warum sollte eine Sache auf einmal funktionieren, wenn man sie einfach nur oft genug 'neu macht'?
                      Du musst sie nur anders (richtig) machen.
                        @crunchip
                        crunchipC Offline
                        crunchipC Offline
                        frag nicht mich😂
                        • F Offline
                          Flixer
                          UIUIUI!!!!!!
                          Nach dem 5ten Neustart bekomme ich die node wieder angezeigt. Ich musste die Ordner alle einzeln löschen, neustarten, löschen usw. Damit habe ich nicht gerechnet...
                          Der ioBroker ist auch gleich mit gestartet und läuft. Bei meinen beiden Smartmetern war irgendwie was falsch eingetragen und jetzt laufen die auch wieder SUPER, vielen Dank!
                          • F Flixer
                            UIUIUI!!!!!!
                            Ich auch nicht...
                            Ist auch nicht der Fall.
                            • F Flixer
                              UIUIUI!!!!!!
                              @flixer
                              Was sagt denn
                              iob diag
                              dazu?
                                @flixer
                                Was sagt denn
                                iob diag
                                dazu?
                                Flixer
                                                     v.2023-04-16
                                Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
                                Kernel:                 6.1.21-v8+
                                Installation:           Native
                                User-ID:                1000
                                X-Server:               false
                                Pending OS-Updates:     0
                                Pending iob updates:    1
                                Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                                                        /usr/bin/node           v18.17.1
                                                        /usr/bin/npm            9.6.7
                                                        /usr/bin/npx            9.6.7
                                Recommended versions are nodejs 18.x.y and npm 9.x.y
                                MEMORY:
                                Mem:            3.8G        832M        2.5G        0.0K        491M        2.9G
                                Swap:            99M          0B         99M
                                Total:          3.9G        832M        2.6G
                                Active iob-Instances:   20
                                Active repo(s): stable
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.8.0
                                Objects type: jsonl
                                States  type: jsonl
                                + system.adapter.admin.0                  : admin                 : RasPi4ioBroker                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  system.adapter.web.1                    : web                   : RasPi4ioBroker                           - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.web.2                    : web                   : RasPi4ioBroker                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                Objects:                3063
                                States:                 2610
                                Size of iob-Database:
                                7.8M    /opt/iobroker/iobroker-data/objects.jsonl
                                3.7M    /opt/iobroker/iobroker-data/objects.json.migrated
                                3.7M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                0       /opt/iobroker/iobroker-data/objects.json.broken
                                4.2M    /opt/iobroker/iobroker-data/states.jsonl
                                168K    /opt/iobroker/iobroker-data/states.json.migrated
                                168K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                0       /opt/iobroker/iobroker-data/states.json.broken
                                • F Flixer
                                                       v.2023-04-16
                                  Kernel:                 6.1.21-v8+
                                  User-ID:                1000
                                  X-Server:               false
                                                          /usr/bin/npm            9.6.7
                                                          /usr/bin/npx            9.6.7
                                  MEMORY:
                                  Swap:            99M          0B         99M
                                                          admin                   6.8.0
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Objects:                3063
                                  States:                 2610
                                  @flixer
                                  Passt. Hau das Update für den ioBroker noch rein.
                                    @flixer
                                    Flixer
                                    ich weiß leider nicht was ich noch aktualisieren soll. Folgende Befehle habe ich alle nochmal durchlaufen lassen.
                                    sudo iobroker stop
                                    sudo iobroker update
                                    sudo iobroker upgrade self
                                    sudo iobroker start
                                    Bis auf JavaScript (6.1.4 auf 7.0.3) ist alles aktuell. Ich muss erst noch nachsehen, ob meine Scripte von der Aktualisierung betroffen sind, daher noch kein Update.
                                    • F Flixer
                                      sudo iobroker stop
                                      sudo iobroker start
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @flixer iobroker NIEMALS mit sudo anpacken !
                                      Lehrling seit 1975 !!!
