  4. Test Adapter ds18b20 v2.0.x
    6.6k
adapterds18b20test
27 Beiträge 5 Kommentatoren 4.6k Aufrufe 4 Beobachtet
  • FredFF FredF
    @crycode sagte in Test Adapter ds18b20 v2.0.x:
    Hast du noch das gesamte Log vom Update und der Migration?
    Dazu evtl. auch einen Export deiner alten Adapterconfig vor dem Update?
    So bitte schön:
    2023-07-19 18:08:29.215  - info: host.iobrokerpi iobroker upgrade ds18b20@2.0.1
    2023-07-19 18:08:35.482  - info: host.iobrokerpi iobroker Update ds18b20 from @1.6.1 to @2.0.1
    2023-07-19 18:08:38.530  - info: host.iobrokerpi iobroker NPM version: 9.5.1
    2023-07-19 18:08:38.533  - info: host.iobrokerpi iobroker Installing iobroker.ds18b20@2.0.1... (System call)
    2023-07-19 18:09:00.985  - info: host.iobrokerpi iobroker
    2023-07-19 18:09:00.989  - info: host.iobrokerpi iobroker added 1 package, removed 82 packages, and changed 2 packages in 19s21 packages are looking for funding  run `npm fund` for details
    2023-07-19 18:09:01.166  - info: host.iobrokerpi iobroker Update "system.adapter.ds18b20.0"
    2023-07-19 18:09:01.212  - info: host.iobrokerpi stopInstance system.adapter.ds18b20.0 (force=false, process=true)
    2023-07-19 18:09:01.222  - info: host.iobrokerpi stopInstance system.adapter.ds18b20.0 send kill signal
    2023-07-19 18:09:01.219  - info: ds18b20.0 (6050) Got terminate signal TERMINATE_YOURSELF
    2023-07-19 18:09:01.256  - info: ds18b20.0 (6050) terminating
    2023-07-19 18:09:01.259  - info: ds18b20.0 (6050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-19 18:09:01.306  - info: host.iobrokerpi iobroker upload [16] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/ds18b20.png ds18b20.png image/png
    2023-07-19 18:09:01.423  - info: host.iobrokerpi iobroker upload [15] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/de.json i18n/de.json application/json
    2023-07-19 18:09:01.440  - info: host.iobrokerpi iobroker upload [14] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/en.json i18n/en.json application/json
    2023-07-19 18:09:01.457  - info: host.iobrokerpi iobroker upload [13] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/es.json i18n/es.json application/json
    2023-07-19 18:09:01.471  - info: host.iobrokerpi iobroker upload [12] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/fr.json i18n/fr.json application/json
    2023-07-19 18:09:01.490  - info: host.iobrokerpi iobroker upload [11] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/it.json i18n/it.json application/json
    2023-07-19 18:09:01.506  - info: host.iobrokerpi iobroker upload [10] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/nl.json i18n/nl.json application/json
    2023-07-19 18:09:01.521  - info: host.iobrokerpi iobroker upload [9] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/pl.json i18n/pl.json application/json
    2023-07-19 18:09:01.535  - info: host.iobrokerpi iobroker upload [8] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/pt.json i18n/pt.json application/json
    2023-07-19 18:09:01.549  - info: host.iobrokerpi iobroker upload [7] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/ru.json i18n/ru.json application/json
    2023-07-19 18:09:01.561  - info: host.iobrokerpi iobroker upload [6] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/uk.json i18n/uk.json application/json
    2023-07-19 18:09:01.580  - info: host.iobrokerpi iobroker upload [5] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
    2023-07-19 18:09:01.594  - info: host.iobrokerpi iobroker upload [4] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/index_m.html index_m.html text/html
    2023-07-19 18:09:01.614  - info: host.iobrokerpi iobroker upload [3] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/jsonConfig.json jsonConfig.json application/json
    2023-07-19 18:09:01.636  - info: host.iobrokerpi iobroker upload [2] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/sensor_disabled.png sensor_disabled.png image/png
    2023-07-19 18:09:01.664  - info: host.iobrokerpi iobroker upload [1] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/sensor_error.png sensor_error.png image/png
    2023-07-19 18:09:01.691  - info: host.iobrokerpi iobroker upload [0] ds18b20.admin /opt/iobroker/node_modules/iobroker.ds18b20/admin/sensor_ok.png sensor_ok.png image/png
    2023-07-19 18:09:02.418  - info: host.iobrokerpi instance system.adapter.ds18b20.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-19 18:09:02.828  - info: host.iobrokerpi iobroker exit 0
    2023-07-19 18:09:04.740  - info: host.iobrokerpi instance system.adapter.ds18b20.0 started with pid 6639
    2023-07-19 18:09:08.836  - info: ds18b20.0 (6639) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v18.16.1, js-controller: 4.0.24
    2023-07-19 18:09:08.922  - info: ds18b20.0 (6639) Migrate config from old version ...
    2023-07-19 18:09:09.181  - info: ds18b20.0 (6639) Rewriting adapter config
    2023-07-19 18:09:09.185  - info: ds18b20.0 (6639) Terminated (START_IMMEDIATELY_AFTER_STOP): Restart adapter to apply config changes
    2023-07-19 18:09:09.231  - info: host.iobrokerpi stopInstance system.adapter.ds18b20.0 (force=false, process=true)
    2023-07-19 18:09:09.253  - info: ds18b20.0 (6639) Got terminate signal TERMINATE_YOURSELF
    2023-07-19 18:09:09.292  - info: host.iobrokerpi stopInstance system.adapter.ds18b20.0 send kill signal
    2023-07-19 18:09:10.228  - info: host.iobrokerpi instance system.adapter.ds18b20.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-07-19 18:09:12.825  - info: host.iobrokerpi instance system.adapter.ds18b20.0 started with pid 6655
    2023-07-19 18:09:16.947  - info: ds18b20.0 (6655) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v18.16.1, js-controller: 4.0.24
    2023-07-19 18:09:17.145  - warn: ds18b20.0 (6655) No sensors configured or enabled!
     "_id": "system.adapter.ds18b20.0",
     "common": {
       "name": "ds18b20",
       "version": "1.6.1",
       "title": "DS18B20",
       "docs": {
         "en": "docs/en/ds18b20.md",
         "de": "docs/de/ds18b20.md"
       "authors": [
         "Peter Müller <peter@crycode.de>"
       "keywords": [
         "ds18b20",
         "ds1820",
         "1wire"
       "license": "MIT",
       "platform": "Javascript/Node.js",
       "main": "build/main.js",
       "icon": "ds18b20.png",
       "enabled": true,
       "extIcon": "https://raw.githubusercontent.com/crycode-de/ioBroker.ds18b20/master/admin/ds18b20.png",
       "readme": "https://github.com/crycode-de/ioBroker.ds18b20/blob/master/README.md",
       "loglevel": "info",
       "mode": "daemon",
       "type": "hardware",
       "connectionType": "local",
       "dataSource": "poll",
       "compact": true,
       "materialize": true,
       "messagebox": true,
       "dependencies": [
           "js-controller": ">=2.0.0"
       "plugins": {
         "sentry": {
           "dsn": "https://4e2fc6b87e4a4016874cb8d91f5cbd97@sentry.cryhost.de/5"
       "installedFrom": "iobroker.ds18b20@1.6.1",
       "installedVersion": "1.6.1",
       "host": "iobrokerpi",
       "adminUI": {
         "config": "materialize"
     "native": {
       "defaultInterval": 60000,
       "w1DevicesPath": "/sys/bus/w1/devices",
       "remoteEnabled": false,
       "remotePort": 1820,
       "remoteKey": "01e717633cdd52406a2356d4eaa181670e595eaabf2d5a25edc78d5547ba98bf",
       "_values": [
           "address": "28-011927e15c58",
           "remoteSystemId": "",
           "name": "Vorlauf Poolheizung",
           "interval": null,
           "unit": "°C",
           "factor": 1,
           "offset": 0,
           "decimals": 2,
           "nullOnError": true,
           "enabled": true,
           "sortOrder": 1,
           "obj": {
             "_id": "ds18b20.0.sensors.28-011927e15c58",
             "common": {
               "write": false,
               "read": true,
               "unit": "°C",
               "type": "number",
               "role": "value.temperature",
               "custom": {
                 "influxdb.0": {
                   "enabled": true,
                   "storageType": "",
                   "aliasId": "Vorlauftemperatur Poolheizung",
                   "debounceTime": 0,
                   "blockTime": 0,
                   "changesOnly": true,
                   "changesRelogInterval": 0,
                   "changesMinDelta": 0,
                   "ignoreBelowNumber": "",
                   "disableSkippedValueLogging": false,
                   "enableDebugLogs": false,
                   "debounce": 1000
             "native": {
               "interval": null,
               "factor": 1,
               "offset": 0,
               "decimals": 2,
               "enabled": true,
               "sortOrder": 1
             "type": "state",
             "acl": {
               "object": 1636,
               "state": 1636,
               "owner": "system.user.admin",
             "user": "system.user.admin",
             "ts": 1658651002793
           "address": "28-011927f4963c",
           "name": "Vorlauf Heizkörper",
           "interval": null,
           "unit": "°C",
           "factor": 1,
           "offset": 0,
           "decimals": 2,
           "enabled": true,
           "sortOrder": 2,
           "obj": {
             "_id": "ds18b20.0.sensors.28-011927f4963c",
             "common": {
               "write": false,
               "read": true,
               "unit": "°C",
               "type": "number",
               "custom": {
                 "influxdb.0": {
                   "enabled": true,
                   "storageType": "",
                   "aliasId": "Vorlauftemperatur Heizkörper",
                   "debounceTime": 0,
                   "blockTime": 0,
                   "debounce": 1000
             "native": {
               "interval": null,
               "factor": 1,
               "offset": 0,
               "decimals": 2,
               "enabled": true,
               "sortOrder": 2
             "type": "state",
             "acl": {
               "object": 1636,
               "state": 1636,
             "ts": 1658651049812
           "address": "28-011927fcac4b",
           "name": "Vorlauf Fussbodenheizung",
           "interval": null,
           "unit": "°C",
           "factor": 1,
           "offset": 0,
           "decimals": 2,
           "enabled": true,
           "sortOrder": 3,
           "obj": {
             "_id": "ds18b20.0.sensors.28-011927fcac4b",
             "common": {
               "write": false,
               "read": true,
               "unit": "°C",
               "type": "number",
               "custom": {
                 "influxdb.0": {
                   "enabled": true,
                   "storageType": "",
                   "aliasId": "Vorlauftemperatur Fussbodenheizung",
                   "debounceTime": 0,
                   "blockTime": 0,
                   "debounce": 1000
             "native": {
               "interval": null,
               "factor": 1,
               "offset": 0,
               "decimals": 2,
               "enabled": true,
               "sortOrder": 3
             "type": "state",
             "acl": {
               "object": 1636,
               "state": 1636,
             "ts": 1658651074668
    crycodeC Offline
    crycodeC Offline
    crycode
    @fredf Denke ich habe den Fehler gefunden und das sollte mit v2.0.2 (ab sofort auf NPM) behoben sein.
    Zudem habe ich einen weiteren Bug gefunden und behoben.
    Wenn Remote-Sensoren verwendet werden, muss nun im Admin einmalig nach der Migration ein neuer Schlüssel dafür festgelegt werden.
    Meine Adapter: discord | canbus | ds18b20 | odl | radiohead
    • crycodeC crycode
      Josh
      Läuft der Adapter eigentlich auf dem neuen js-controller 5?
      Habe gerade mal ein Update auf V5 gefahren und der DS18B20-Adapter wirft Fehler und bleibt rot.
      host.ioBroker-Slave-KG
      	2023-08-13 20:20:17.686	warn	instance system.adapter.ds18b20.0 terminated due to SIGTERM
      	2023-08-13 20:19:43.702	error	instance system.adapter.ds18b20.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      	2023-08-13 20:19:43.700	error	Caught by controller[1]: at Ds18b20Adapter.onReady (/opt/iobroker/node_modules/iobroker.ds18b20/src/main.ts:269:41)
      	2023-08-13 20:19:43.698	error	Caught by controller[1]: at new Sensor (/opt/iobroker/node_modules/iobroker.ds18b20/src/sensor.ts:122:33)
      	2023-08-13 20:19:43.697	error	Caught by controller[1]: at Ds18b20Adapter.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2603:19)
      	2023-08-13 20:19:43.695	error	Caught by controller[1]: at Function.assertNumber (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:288:19)
      	2023-08-13 20:19:43.694	error	Caught by controller[1]: Error: Parameter "timeout" needs to be of type "number" but type "string" has been passed
      	2023-08-13 20:19:43.682	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      ds18b20.0
      	2023-08-13 20:19:42.572	info	terminating
      ds18b20.0
      	2023-08-13 20:19:42.542	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      ds18b20.0
      	2023-08-13 20:19:42.536	info	terminating
      ds18b20.0
      	2023-08-13 20:19:41.406	error	Parameter "timeout" needs to be of type "number" but type "string" has been passed
      ds18b20.0
      	2023-08-13 20:19:41.402	error	Error: Parameter "timeout" needs to be of type "number" but type "string" has been passed at Function.assertNumber (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:288:19) at Ds18b20Adapter.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2603:19) at new Sensor (/opt/iobroker/node_modules/iobroker.ds18b20/src/sensor.ts:122:33) at Ds18b20Adapter.onReady (/opt/iobroker/node_modules/iobroker.ds18b20/src/main.ts:269:41)
      ds18b20.0
      	2023-08-13 20:19:40.003	error	unhandled promise rejection: Parameter "timeout" needs to be of type "number" but type "string" has been passed
      ds18b20.0
      	2023-08-13 20:19:39.984	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ds18b20.0
      	2023-08-13 20:19:39.764	info	starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v18.17.1, js-controller: 5.0.11
      Intel NUC10i5-32GB-1TB_SSD - Proxmox 9.2 - LXC Debian 13
      RPi3B - ZigBee2MQTT - CC2652P
      RPi3B - ZigBee2MQTT - CC2538+CC2592
      node.js 22.22.3 / NPM 10.9.8
      crycodeC 2 Antworten Letzte Antwort
      • J Josh
        ds18b20.0
        ds18b20.0
        ds18b20.0
        ds18b20.0
        ds18b20.0
        ds18b20.0
        ds18b20.0
        ds18b20.0
        crycodeC Offline
        crycodeC Offline
        crycode
        @josh Sollte eigentlich laufen, aber schau ich mir noch mal genau an.
        Wird aber erst nächste Woche, da ich aktuell im Urlaub bin.
        • J Josh
          ds18b20.0
          ds18b20.0
          ds18b20.0
          ds18b20.0
          ds18b20.0
          ds18b20.0
          ds18b20.0
          ds18b20.0
          crycodeC Offline
          crycodeC Offline
          crycode
          @josh Ich habe soeben die v2.0.3 auf NPM veröffentlicht. Ab morgen sollte die Version dann auch im im latest-Repo sein.
          Kannst du die bitte mal zusammen mit dem aktueller js-controller 5.0.12 testen? Da sollte das dann laufen. :)
          • crycodeC crycode
            Josh
            schrieb am zuletzt editiert von Josh
            @crycode Habe den Adapter auf dem neusten js-controller getestet. Bleibt leider noch immer rot. Hier der Log mit Warnstufe Debug.
            2023-08-20 18:05:40.563 - debug: ds18b20.0 (19143) Redis Objects: Use Redis connection: 192.168.178.194:9001
            2023-08-20 18:05:40.686 - debug: ds18b20.0 (19143) Objects client ready ... initialize now
            2023-08-20 18:05:40.693 - debug: ds18b20.0 (19143) Objects create System PubSub Client
            2023-08-20 18:05:40.699 - debug: ds18b20.0 (19143) Objects create User PubSub Client
            2023-08-20 18:05:40.800 - debug: ds18b20.0 (19143) Objects client initialize lua scripts
            2023-08-20 18:05:40.829 - debug: ds18b20.0 (19143) Objects connected to redis: 192.168.178.194:9001
            2023-08-20 18:05:40.922 - debug: ds18b20.0 (19143) Redis States: Use Redis connection: 192.168.178.194:6379
            2023-08-20 18:05:40.949 - debug: ds18b20.0 (19143) States create System PubSub Client
            2023-08-20 18:05:40.955 - debug: ds18b20.0 (19143) States create User PubSub Client
            2023-08-20 18:05:40.995 - debug: ds18b20.0 (19143) States connected to redis: 192.168.178.194:6379
            2023-08-20 18:05:41.168 - debug: ds18b20.0 (19143) Plugin sentry Initialize Plugin (enabled=true)
            2023-08-20 18:05:42.545 - info: ds18b20.0 (19143) starting. Version 2.0.3 in /opt/iobroker/node_modules/iobroker.ds18b20, node: v18.17.1, js-controller: 5.0.12
            2023-08-20 18:05:42.758 - error: ds18b20.0 (19143) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            2023-08-20 18:05:42.776 - error: ds18b20.0 (19143) unhandled promise rejection: Parameter "timeout" needs to be of type "number" but type "string" has been passed
            2023-08-20 18:05:44.453 - error: ds18b20.0 (19143) Error: Parameter "timeout" needs to be of type "number" but type "string" has been passed
            at Ds18b20Adapter.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2655:19)
            at Ds18b20Adapter.onReady (/opt/iobroker/node_modules/iobroker.ds18b20/src/main.ts:268:41)
            2023-08-20 18:05:44.456 - error: ds18b20.0 (19143) Parameter "timeout" needs to be of type "number" but type "string" has been passed
            2023-08-20 18:05:45.493 - info: ds18b20.0 (19143) terminating
            2023-08-20 18:05:45.497 - debug: ds18b20.0 (19143) Plugin sentry destroyed
            2023-08-20 18:05:45.500 - warn: ds18b20.0 (19143) Terminated (UNCAUGHT_EXCEPTION): Without reason
            2023-08-20 18:05:45.523 - info: ds18b20.0 (19143) terminating
            2023-08-20 18:05:46.614 - error: host.ioBroker-Slave-KG Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2023-08-20 18:05:46.626 - error: host.ioBroker-Slave-KG Caught by controller[1]: Error: Parameter "timeout" needs to be of type "number" but type "string" has been passed
            2023-08-20 18:05:46.628 - error: host.ioBroker-Slave-KG Caught by controller[1]: at Function.assertNumber (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/validator.ts:288:19)
            2023-08-20 18:05:46.629 - error: host.ioBroker-Slave-KG Caught by controller[1]: at Ds18b20Adapter.setInterval (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2655:19)
            2023-08-20 18:05:46.630 - error: host.ioBroker-Slave-KG Caught by controller[1]: at new Sensor (/opt/iobroker/node_modules/iobroker.ds18b20/src/sensor.ts:122:33)
            2023-08-20 18:05:46.632 - error: host.ioBroker-Slave-KG Caught by controller[1]: at Ds18b20Adapter.onReady (/opt/iobroker/node_modules/iobroker.ds18b20/src/main.ts:268:41)
            2023-08-20 18:05:46.634 - error: host.ioBroker-Slave-KG instance system.adapter.ds18b20.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
            2023-08-20 18:06:22.995 - debug: ds18b20.0 (19206) Redis Objects: Use Redis connection: 192.168.178.194:9001
            2023-08-20 18:06:23.118 - debug: ds18b20.0 (19206) Objects client ready ... initialize now
            2023-08-20 18:06:23.125 - debug: ds18b20.0 (19206) Objects create System PubSub Client
            2023-08-20 18:06:23.131 - debug: ds18b20.0 (19206) Objects create User PubSub Client
            2023-08-20 18:06:23.237 - debug: ds18b20.0 (19206) Objects client initialize lua scripts
            2023-08-20 18:06:23.271 - debug: ds18b20.0 (19206) Objects connected to redis: 192.168.178.194:9001
            2023-08-20 18:06:23.364 - debug: ds18b20.0 (19206) Redis States: Use Redis connection: 192.168.178.194:6379
            2023-08-20 18:06:23.397 - debug: ds18b20.0 (19206) States create System PubSub Client
            2023-08-20 18:06:23.402 - debug: ds18b20.0 (19206) States create User PubSub Client
            2023-08-20 18:06:23.472 - debug: ds18b20.0 (19206) States connected to redis: 192.168.178.194:6379
            2023-08-20 18:06:23.587 - debug: ds18b20.0 (19206) Plugin sentry Initialize Plugin (enabled=true)
            2023-08-20 18:06:24.608 - error: ds18b20.0 (19206) adapter disabled
            2023-08-20 18:06:24.655 - debug: ds18b20.0 (19206) Plugin sentry destroyed
            2023-08-20 18:06:24.659 - warn: ds18b20.0 (19206) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            2023-08-20 18:06:25.884 - error: host.ioBroker-Slave-KG instance system.adapter.ds18b20.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
            EDIT: neuen Log mit veränderter Warnstufe eingestellt.
            crycodeC 1 Antwort Letzte Antwort
            • J Josh
              crycodeC Offline
              crycodeC Offline
              crycode
              @josh Danke dir.
              Kannst du mal deine Adapter-Config exportieren und posten bitte? Ich hab da eine Vermutung...
              • crycodeC crycode
                @josh Danke dir.
                Josh
                @crycode Gerne. Hier bitte:
                • J Josh
                  crycodeC Offline
                  crycodeC Offline
                  crycode
                  @josh Nicht als Bild, sondern als json-Datei über den Export-Button oben rechts. ;)
                  • crycodeC crycode
                    Josh
                    @crycode Hups... kannte ich noch nicht. Aber hier bitte schön. IDs habe ich aus 'Datenschutzgründen' verändert.
                    ds18b20.0.json
                    • J Josh
                      ds18b20.0.json
                      crycodeC Offline
                      crycodeC Offline
                      crycode
                      @josh Danke dir! Das bestätigt meine Vermutung. Der defaultInterval wird als String und nicht als Zahl gespeichert.
                      Dem js-controller 4 war das wohl egal (Node.js macht in solchen Fällen automatisch eine Konvertierung der Datentypen), wobei der js-controller 5 da extra prüft.
                      Ich werde versuchen zeitnah einen Fix dafür mit einer neuen Version zu veröffentlichen.
                      Danke fürs Finden und Melden des Fehlers! 👍
                      • crycodeC crycode
                        crycodeC Offline
                        crycodeC Offline
                        crycode
                        @Josh Version 2.0.4 ist ab sofort über NPM und ab morgen dann im latest-Repo verfügbar. Damit sollte das Problem behoben sein. :)
                        • crycodeC crycode
                          Josh
                          @crycode Adapter wird und bleibt grün. Werte werden ausgelesen. Funktioniert also wieder.
                          Vielen Dank!
                          • C Offline
                            chinaboy
                            Hardwaresystem: Pi3
                            Arbeitsspeicher: 1GB
                            Festplattenart: SD-Karte
                            Betriebssystem: Linux
                            Node-Version: 18.18.0
                            Nodejs-Version: 18.18.0
                            NPM-Version: 9.8.1
                            Servus,
                            Nach Update auf JS 5.0.12 läuft meine DS18B20 V2.0.4 Instanz nicht mehr richtig.
                            Der Adapter wechselt immer wieder mal zwischen grün und gelb.
                            Ich habe drei Sensoren am laufen, vor dem Update liefen sie ohne Probleme
                            Jetzt fällt immer wieder mal einer oder mehrere mit folgendem Fehlermeldung aus:
                            ds18b20.0
                            2023-10-27 10:37:41.029	warn	Error reading sensor 10-00080289****: Error: Read error
                            Es ist nicht immer der selbe Sensor.
                            Hab dann mal alles neu installiert, hat aber nichts gebracht
                            Direkt nach der erfolgreichen Installation bekam ich aber folgende Adapter Warnung vom der Instanz admin.0
                            2023-10-27 08:09:46.811 - warn: admin.0 (3322310) ds18b20 has an invalid jsonConfig: [{"instancePath":"/items/sensorsTab/items/sensors/items/1","schemaPath":"#/patternProperties/%5E.%2B/allOf/22/then/properties/items/items/allOf/20/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"hide"},"message":"must NOT have additional properties"},{"instancePath":"/items/sensorsTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                            Wer kann mir helfen.
                            crycodeC mcm1957M 2 Antworten Letzte Antwort
                            • C chinaboy
                              Hardwaresystem: Pi3
                              NPM-Version: 9.8.1
                              Servus,
                              ds18b20.0
                              crycodeC Offline
                              crycodeC Offline
                              crycode
                              @chinaboy sagte in Test Adapter ds18b20 v2.0.x:
                              Das deutet eher auf ein Hardwareproblem hin und heißt eigentlich, dass der Sensor keine brauchbaren Daten geliefert hat bzw. vom System gar nicht erkannt wurde.
                              Werden vom System unter /sys/bus/w1/devices/ alle Sensoren richtig aufgelistet?
                              Demnach hast du wohl die latest-Version vom Admin-Adapter installiert. Die Warnung ist aber falsch und kann einfach ignoriert werden.
                              • crycodeC crycode
                                chinaboy
                                @crycode said in Test Adapter ds18b20 v2.0.x:
                                Ja da passt alles:
                                pi@IOBMaster:/sys/bus/w1/devices $ ls
                                10-000802897a**  10-0008028993**  10-00080289a9**  w1_bus_master1
                                Ich hab auch an der HW nix geändert aber der Fehler kommt seit dem Update
                                • C chinaboy
                                  Ja da passt alles:
                                  crycodeC Offline
                                  crycodeC Offline
                                  crycode
                                  @chinaboy Erscheinen sonst irgendwelche Fehler oder Warnungen im Log zu den Zeitpunkten, wo das passiert?
                                  Kannst du mal, möglich genau zu dem Zeitpunkt, wo der "Read error" geloggt wird, im Terminal ein cat auf den Sensor im System machen und davon die Ausgabe posten?
                                  Beispiel:
                                  cat /sys/bus/w1/devices/28-0000077b9fea/w1_slave
                                  31 01 4b 46 7f ff 0f 10 1f : crc=1f YES
                                  31 01 4b 46 7f ff 0f 10 1f t=19062
                                  Zudem wäre die Ausgabe von dmesg -T | grep w1 interessant, um zu sehen, ob der Kernel dort irgendwas loggt.
                                  • C chinaboy
                                    Hardwaresystem: Pi3
                                    NPM-Version: 9.8.1
                                    Servus,
                                    ds18b20.0
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @crycode
                                    Hast du ein Issue bei https://github.com/ioBroker/adapter-react-v5/issues?q=is%3Aopen+is%3Aissue erstellt?
                                    Ansonsten wird den potenziellen Fehler foxriver76 wohl nicht mitbekommen.
                                    ABER - wenn ich es richtig sehe verwendest du ein Attribute 'hide'. Das gibt es lt. SCHEMA.md nicht. Das Attribute heißt 'hidden'. Könnte also sehr wohl ein Fehler im Adapter sein.
                                    Bitte prüfen.
                                    DANKE
                                    P.S: Have issue https://github.com/crycode-de/ioBroker.ds18b20/issues/112 zur weiteren Nachverfolgung erstellt.
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    • mcm1957M mcm1957
                                      @crycode
                                      Bitte prüfen.
                                      DANKE
                                      crycodeC Offline
                                      crycodeC Offline
                                      crycode
                                      @mcm57 Huch... danke dir!
                                      Mit war so, als hätte ich das (da es im Zusammenhang mit der Tabelle steht) bei den bereits gemeldeten Problemen gesehen gehabt. Dann ist es wohl doch mein Fehler. Schau ich mir auf jeden Fall noch mal an.
                                      Mit dem beschrieben Problem beim Lesen der Sensoren hat es trotzdem nichts zu tun. 😉
                                      • crycodeC crycode
                                        mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        @crycode
                                        No mit den sensoren hat sicher nichts zu tun.
                                        Und ja 90% der json warnings sind falsevpositives. Aber ich hab schon 3 od 4 echte Fehler mitbekommen. Daher scgau ich mittlerweile genauer.
                                        Aber keinen Stress. Funktion des Adapters ist ja ok
                                        • mcm1957M mcm1957
                                          @crycode
                                          crycodeC Offline
                                          crycodeC Offline
                                          crycode
                                          @mcm57 Die jsonConfig ist in 2.0.5 jetzt gefixed. :)
