  4. iob backup bricht mit Fehler ab
    5.2k
24 Beiträge 6 Kommentatoren 1.4k Aufrufe 5 Beobachtet
    @klixy23
    Was kommt denn dabei heraus?
    klixy23
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     22:05:10 up 2 days,  4:27,  1 user,  load average: 0.33, 0.23, 0.17
    CPU threads: 4
    Raspberry only:
    throttled=0x20000
    Other values than 0x0 hint to temperature/voltage problems
    temp=55.8'C
    volt=1.2938V
    *** Time and Time Zones ***
                   Local time: Tue 2023-08-15 22:05:10 CEST
               Universal time: Tue 2023-08-15 20:05:10 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            971M        583M        195M        0.0K        193M        324M
    Swap:           511M        293M        218M
    Total:          1.5G        876M        413M
              971 M total memory
              583 M used memory
              394 M active memory
              279 M inactive memory
              195 M free memory
               18 M buffer memory
              174 M swap cache
              511 M total swap
              293 M used swap
              218 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  6.5G  7.0G  49% /
    devtmpfs       devtmpfs  358M     0  358M   0% /dev
    tmpfs          tmpfs     486M     0  486M   0% /dev/shm
    tmpfs          tmpfs     195M  640K  194M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
    [Sun Aug 13 17:37:22 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=501d671c-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Aug 13 17:37:25 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sun Aug 13 17:37:25 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sun Aug 13 17:37:25 2023] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sun Aug 13 17:37:26 2023] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
    [Sun Aug 13 17:37:26 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Aug 13 17:37:28 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Aug 13 17:37:28 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Aug 13 17:37:36 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.8G    /var/
    1.5G    /var/log
    1.4G    /var/log/journal/6ce9bd1f37ea42559463f35932da81c1
    809M    /var/cache
    Archived and active journals take up 1.3G in the file system.
    /opt/iobroker/backups:
    5.7M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    364M    /opt/iobroker/iobroker-data/
    191M    /opt/iobroker/iobroker-data/history.0
    116M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    36M     /opt/iobroker/iobroker-data/backup-objects
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.312d98a8.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.1-deb-1nodesource1
      Candidate: 18.17.1-deb-1nodesource1
      Version table:
     *** 18.17.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : RASPI3                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : RASPI3                                   -  enabled, port: 8090, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : RASPI3                                   -  enabled
      system.adapter.backitup.0               : backitup              : RASPI3                                   - disabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : RASPI3                                   -  enabled
    + system.adapter.discovery.0              : discovery             : RASPI3                                   -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : RASPI3                                   -  enabled
      system.adapter.flot.0                   : flot                  : RASPI3                                   -  enabled
    + system.adapter.history.0                : history               : RASPI3                                   -  enabled
      system.adapter.homeconnect.0            : homeconnect           : RASPI3                                   - disabled
    + system.adapter.info.0                   : info                  : RASPI3                                   -  enabled
    + system.adapter.iot.0                    : iot                   : RASPI3                                   -  enabled
    + system.adapter.javascript.0             : javascript            : RASPI3                                   -  enabled
    + system.adapter.panasonic-viera.0        : panasonic-viera       : RASPI3                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : RASPI3                                   -  enabled
    + system.adapter.shelly.0                 : shelly                : RASPI3                                   -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.signal-cmb.0             : signal-cmb            : RASPI3                                   -  enabled
    + system.adapter.simple-api.0             : simple-api            : RASPI3                                   -  enabled, port: 8087, bind: 192.168.94.120, run as: admin
    + system.adapter.snmp.0                   : snmp                  : RASPI3                                   -  enabled
    + system.adapter.socketio.0               : socketio              : RASPI3                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.statistics.0             : statistics            : RASPI3                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : RASPI3                                   -  enabled
    + system.adapter.tr-064.1                 : tr-064                : RASPI3                                   -  enabled
    + system.adapter.web.0                    : web                   : RASPI3                                   -  enabled, port: 8082, bind: 192.168.94.120, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
    Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "snmp"         : 2.4.11   , installed 2.4.11
    Adapter    "statistics"   : 2.3.0    , installed 2.3.0
    Objects and States
    Objects:        4084
    States:         3363
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 5
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14047      485/sshd: /usr/sbin
    tcp        0      0 192.168.94.120:8087     0.0.0.0:*               LISTEN      1001       1310455    12329/io.simple-api
    tcp        0      0 192.168.94.120:8082     0.0.0.0:*               LISTEN      1001       1306610    12197/io.web.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1308621    11924/iobroker.js-c
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1309815    11924/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14049      485/sshd: /usr/sbin
    tcp6       0      0 :::8090                 :::*                    LISTEN      1001       1306421    11956/io.admin.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1306405    11945/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1309411    12242/io.socketio.0
    udp        0      0 0.0.0.0:46092           0.0.0.0:*                           1001       1314814    13151/io.snmp.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1311052    12126/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10881      579/dhcpcd
    udp        0      0 0.0.0.0:49752           0.0.0.0:*                           108        10859      364/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10857      364/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12692      579/dhcpcd
    udp6       0      0 :::42159                :::*                                108        10860      364/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        10858      364/avahi-daemon: r
    2023-08-15 19:02:27.242  - info: socketio.0 (12242) <== Disconnect system.user.admin from ::ffff:192.168.94.147 flot
    2023-08-15 19:02:28.249  - info: socketio.0 (12242) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 19:07:26.234  - info: socketio.0 (12242) <== Disconnect system.user.admin from ::ffff:192.168.94.147 flot
    2023-08-15 19:07:28.248  - info: socketio.0 (12242) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 19:12:26.244  - info: socketio.0 (12242) <== Disconnect system.user.admin from ::ffff:192.168.94.147 flot
    2023-08-15 19:12:28.240  - info: socketio.0 (12242) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 19:14:28.731  - info: javascript.0 (12006) script.js.Fenster.DW2-Alarm2: true
    2023-08-15 19:14:28.733  - warn: javascript.0 (12006) script.js.Fenster.DW2-Alarm2: false
    2023-08-15 19:16:22.315  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    2023-08-15 19:17:26.243  - info: socketio.0 (12242) <== Disconnect system.user.admin from ::ffff:192.168.94.147 flot
    2023-08-15 19:17:28.252  - info: socketio.0 (12242) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 19:24:24.250  - info: socketio.0 (12242) <== Disconnect system.user.admin from ::ffff:192.168.94.147 flot
    2023-08-15 19:46:22.297  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    2023-08-15 20:16:22.296  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    2023-08-15 20:17:39.820  - info: admin.0 (11945) <== Disconnect system.user.admin from ::ffff:192.168.94.147
    2023-08-15 20:17:39.844  - info: admin.0 (11945) <== Disconnect system.user.admin from ::ffff:192.168.94.147 admin
    2023-08-15 20:17:40.392  - info: admin.0 (11945) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 20:17:44.430  - info: admin.0 (11945) ==> Connected system.user.admin from ::ffff:192.168.94.147
    2023-08-15 20:17:47.312  - info: host.RASPI3 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2023-08-15 20:18:24.595  - info: admin.0 (11945) <== Disconnect system.user.admin from ::ffff:192.168.94.147
    2023-08-15 20:21:09.256  - info: javascript.0 (12006) script.js.Fenster.DW2-Sensorwerte: 15.08.2023 20:21:09%0ATemparatur:25%0AHelligkeit:21%0AAuslöser:["sensor","temperature"]
    2023-08-15 20:46:22.305  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    2023-08-15 21:16:22.302  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    2023-08-15 21:44:16.341  - info: javascript.0 (12006) script.js.Fenster.DW2-Sensorwerte: 15.08.2023 21:44:16%0ATemparatur:24%0AHelligkeit:0%0AAuslöser:["sensor","temperature"]
    2023-08-15 21:46:22.297  - info: javascript.0 (12006) script.js.Drucker.Tonerlevel: Tonerlevel wurden aktualisiert.
    Und noch das Summary
                         v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v7+
    Installation:           Native
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     5
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                            /usr/bin/npm            9.6.7
                            /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            971M        556M         88M        0.0K        326M        351M
    Swap:           511M        316M        195M
    Total:          1.5G        872M        284M
    Active iob-Instances:   22
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                4084
    States:                 3363
    Size of iob-Database:
    4.5M    /opt/iobroker/iobroker-data/states.jsonl
    HomoranH Thomas BraunT crunchipC 3 Antworten Letzte Antwort
    • K klixy23
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x20000
      temp=55.8'C
      volt=1.2938V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
                971 M total memory
                583 M used memory
                394 M active memory
                195 M free memory
                 18 M buffer memory
                174 M swap cache
                511 M total swap
                293 M used swap
                218 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      2.8G    /var/
      1.5G    /var/log
      809M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        4084
      States:         3363
      Pending Updates: 5
                           v.2023-04-16
      Kernel:                 6.1.21-v7+
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.6.7
                              /usr/bin/npx            9.6.7
      MEMORY:
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                4084
      States:                 3363
      HomoranH Offline
      HomoranH Offline
      @klixy23 sagte in iob backup bricht mit Fehler ab:
      bei
      Mem: 971M
      ist doch nicht dein Ernst!?
      spendier dem System mindestens 4GB
        bei
        Mem: 971M
        @homoran sagte in iob backup bricht mit Fehler ab:
        RPi3 hat nur 1GB.
          RPi3 hat nur 1GB.
          HomoranH Offline
          HomoranH Offline
          @thomas-braun sagte in iob backup bricht mit Fehler ab:
          RPi3 hat nur 1GB.
          klar, aber für diese Anzahl Adapter braucht @klixy23 ein System mit mindestens 4GB RAM
          • K klixy23
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Docker          : false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            Raspberry only:
            throttled=0x20000
            temp=55.8'C
            volt=1.2938V
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                      971 M total memory
                      583 M used memory
                      394 M active memory
                      195 M free memory
                       18 M buffer memory
                      174 M swap cache
                      511 M total swap
                      293 M used swap
                      218 M free swap
            Raspberry only:
            oom events: 0
            *** FILESYSTEM ***
            /var:
            2.8G    /var/
            1.5G    /var/log
            809M    /var/cache
            /usr/bin/npm            9.6.7
            /usr/bin/npx            9.6.7
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     7.0.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        4084
            States:         3363
            Pending Updates: 5
                                 v.2023-04-16
            Kernel:                 6.1.21-v7+
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            9.6.7
                                    /usr/bin/npx            9.6.7
            MEMORY:
                                    admin                   6.3.5
            Objects type: jsonl
            States  type: jsonl
            Objects:                4084
            States:                 3363
            Updates einspielen und dann schau mal warum das iob-Repo nicht erreicht wird. Ggfls. auf den sog. live-Server gehen.
            • K klixy23
              Systemdata Bitte Ausfüllen
              Hardwaresystem: Pi3
              Arbeitsspeicher: 1GB
              Festplattenart: SD-Karte
              Betriebssystem: "Raspbian GNU/Linux 11 (bullseye)"
              Node-Version: v18.17.1
              Nodejs-Version: v18.17.1
              NPM-Version: 9.6.7
              Installationsart: Skript/Manuell
              Image genutzt: Nein
              Von einer ssh Konsole aus starte ich:
              iob backup
              und erhalte folgende Ausgabe:
              host.RASPI3 3363 states saved
              host.RASPI3 4088 objects saved
              host.RASPI3 Backup not created: Invalid or unexpected token
              Backup created: undefined
              Es wird kein Backup erstellt. Wodurch wird dieser Fehler verursacht und wie kann ich den beheben? Lässt sich das "token" wiederherstellen oder neu erstellen? Fehlt eine Systemkomponente oder ist defekt?
              Dadurch funktioniert auch der Backitup-Adapter nicht.
              Folgendes ist im Vorfeld passiert:
              • SD-Karte defekt
              • letztes OS dd-Image (vorher täglich erstellt und auf NAS kopiert) auf neue Karte übertragen
              • iob startete nicht mehr fehlerfrei
              • iob neu installiert
              • Adapter-Backups einzeln zurückgespielt
              • iob startet ohne erkennbare Fehler
              Für Unterstützung und Lösungsansätze vorab vielen Dank.
              VG Klixy
              Moin,
              wie Dir ja schon von @Homoran mitgeteilt wurde, ist 1 GB knapp bemessen, gerade dann, wenn Du Backups machen willst, da wird meist im Hauptspeicher versucht alles zu sammeln, was ins Backup hinein soll, um es dann zu komprimieren und auf Platte zu schreiben.
              Ein Versuch wäre es wert, einmal folgendes zu versuchen:
              iob stop
              iob backup
              iob start
              Und natürlich, die kleinen Probleme beheben, die Dir @Thomas-Braun mit auf den Weg gegeben hat.
              Bernd
                klixy23
                Updates hatte ich kurz vor dem Post eingespielt, über die Weboberfläche wird das Repo erreicht. Auch nodejs und npm habe ich aktualisiert. Das Repo wird nur von der Konsole aus nicht erreicht, über den Browser geht es:
                Warum das so ist, weiß ich nicht.
                VG Klixy
                • K klixy23
                  VG Klixy
                  @klixy23
                  Dann trag mal die 'live'-Server ein:
                  live-stable   : http://iobroker.live/repo/sources-dist.json
                  live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                    @klixy23
                    klixy23
                    OK. Die "Cannot download repository..." Einträge werden jetzt beim Diag nicht mehr angezeigt. Ich habe in der Fritzbox das Profil für den Raspi geändert, deshalb kam auch der Timeout.
                      Moin,
                      iob stop
                      iob backup
                      iob start
                      Bernd
                      klixy23
                      @dp20eic
                      Danke, aber das Ergebnis ist genauso.
                      VG Klixy
                      • K klixy23
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x20000
                        temp=55.8'C
                        volt=1.2938V
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                                  971 M total memory
                                  583 M used memory
                                  394 M active memory
                                  195 M free memory
                                   18 M buffer memory
                                  174 M swap cache
                                  511 M total swap
                                  293 M used swap
                                  218 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        2.8G    /var/
                        1.5G    /var/log
                        809M    /var/cache
                        /usr/bin/npm            9.6.7
                        /usr/bin/npx            9.6.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.3.5
                        javascript:     7.0.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        4084
                        States:         3363
                        Pending Updates: 5
                                             v.2023-04-16
                        Kernel:                 6.1.21-v7+
                        User-ID:                1000
                        X-Server:               false
                                                /usr/bin/npm            9.6.7
                                                /usr/bin/npx            9.6.7
                        MEMORY:
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                4084
                        States:                 3363
                        crunchipC Offline
                        crunchipC Offline
                        @klixy23 schmeiß die folgenden nicht benötigten(überflüssigen) Adapter raus
                        admin.1
                        discovery.0
                        info.0
                        wenn die folgenden generell nicht mehr genutzt werden, die auch noch löschen
                        flot.0
                        homeconnect.0
                        eventuell im web Adapter simple api nutzen und den externen noch entfernen
                          admin.1
                          discovery.0
                          info.0
                          flot.0
                          homeconnect.0
                          klixy23
                          @crunchip
                          Ja, aber das löst mein Problem auch nicht.
                          Kann man die Ausgabe erweitern, so dass man besser eingrenzen kann, wo das Problem liegt oder gibt es Logfiles die mehr Aufschluss geben?
                          VG Klixy
                          Thomas BraunT HomoranH crunchipC 3 Antworten Letzte Antwort
                          • K klixy23
                            @crunchip
                            VG Klixy
                            @klixy23
                            dmesg -wT
                            in einem Terminal anschauen, dann ein Backup machen. Ich habe die Vermutung dass da was auftauchen könnte.
                            • DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              So prinzipiell verstehe ich jetzt nicht warum man hier "rummacht" - auf einem RPI3 mit 1 GB Ram dem wohl definitiv der Speicher ausgeht sobald das Backup startet.
                              Lehrling seit 1975 !!!
                              • K klixy23
                                @crunchip
                                VG Klixy
                                HomoranH Offline
                                HomoranH Offline
                                besser als "RAM zu wenig"?
                                1GB RAM reicht für ca. 10 Instanzen, wenn nichts anderes als iob läuft.
                                sind damit definitiv viel zu viel.
                                dazu kommen noch die scheduled Instanzen, wie eben auch backitup.
                                Dieser benötigt richtig viel RAM für das Packen der Backupdaten.
                                Was willst du denn hören?
                                • K klixy23
                                  @crunchip
                                  VG Klixy
                                  crunchipC Offline
                                  crunchipC Offline
                                  @klixy23 war mehr oder wenig nur ein Vorschlag dein System "über Wasser" zu halten. Dazu kommt, Je weniger Instanzen desto weniger hat auch der Admin zu tun, ergo wird der Ram des admin auch kleiner.
                                  Den Backitup Adapter starte/stoppe ich z.b per script für den Zeitraum des backups, da dieser ebenfalls rund 100Mb in Anspruch nimmt.
                                  Mein admin allein benötigt z.b schon rund 230Mb.
                                  Hab allerdings auch 50 Instanzen laufen.
                                  Wie bereits erwähnt kommst du nicht drum herum, aufzurüsten, 4GB Ram sind mittlerweile üblich um iobroker vernünftig laufen zu lassen.
                                    @crunchip sagte in iob backup bricht mit Fehler ab:
                                    Moin,
                                    ein einem Post -> https://forum.iobroker.net/topic/67640/iob-backup-bricht-mit-fehler-ab/10?_=1692425433874, habe ich dem TE ja gesagt, dass er alles stoppen soll, vom TE -> https://forum.iobroker.net/topic/67640/iob-backup-bricht-mit-fehler-ab/15?_=1692425433874 kam, das es nicht geholfen hat.
                                    Ich verstehe das auch so, dass es nicht um den BackItUp Adapter geht, sondern um den Befehl, der mit Fehlern abbricht.
                                    iob backup
                                    Hoffe, dass ich nicht wieder etwas falsch verstanden habe.
                                    Bernd
                                    crunchipC K 2 Antworten Letzte Antwort
                                      Moin,
                                      iob backup
                                      Bernd
                                      crunchipC Offline
                                      crunchipC Offline
                                      @dp20eic sagte in iob backup bricht mit Fehler ab:
                                      Richtig...wegen dem token
                                      Allerdings kam ja als Nebenschauplatz zum Vorschein, das generell sein Ram nicht ausreicht um einen vernünftigen Betrieb des Systems zu gewährleisten
                                        Moin,
                                        iob backup
                                        Bernd
                                        klixy23
                                        @dp20eic
                                        Ja richtig, es geht um den Befehl auf der Kommandozeile. Und nur wenn das funktioniert, dann funktioniert auch Backitup.
                                        Und warum wird dann nicht als Fehler "Out of Memory" ausgegeben. In den Logs steht ja auch nix von wegen zu wenig Memory.
                                        Ich werde mal eine neue SD-Karte besorgen und ein iob-System von Grund auf neu installieren. Dann werde ich Backups machen und einen Adapter nach dem anderen installieren und sehen, ab wie vielen wieder dieser Tokenfehler auftritt. Ich bin gespannt auf das Ergebnis.
                                        VG Klixy
                                        • K klixy23
                                          @dp20eic
                                          VG Klixy
                                          crunchipC Offline
                                          crunchipC Offline
                                          Glaube nicht das der Tokenfehler abhängig der Adapteranzahl ist. Eher das aufgrund des Speichermangels es dir irgendwann etwas "zerschossen" hat.
                                          Weil er gar nicht soweit kommt, aufgrund des Tokenfehlers.
                                          Bei gestopptem iobroker gibt es ja auch keinen Speichermangel.
                                          Wenn du das eh vorhast, würde ich versuchen auf dem jetztigen System den js-controller mal neu zu installieren, oder auch ein iobroker setup first auszuführen.
                                          Anschliessend bei gestoppten iobroker nochmal das backup anzustoßen.
