  4. Einrichten Modbus Adapter / Solar X3 Gen4
147 Beiträge 19 Kommentatoren 30.5k Aufrufe 18 Beobachtet
  • McWoolfM McWoolf
    @planb1
    Hi
    eigentlich mit dem ich dazwischen abgebrochen habe. Also den USR-TCP232-304, damit hat es dann geklappt.
    rettroo
    #125
    ich muss das hier nochmal aufgreifen. Ich habe eine ähnliche Konfiguration.
    Solax X3 + einem Waveshare Modbus->IP Konverter. Habe es bereits geschafft die Daten mit Loxone abzugreifen, würde die aber auch noch im iobroker benötigen. Kann ich eigentlich mit 2 Clients abfragen?
    Ich bekomme folgendes im Log:
    modbus.1
    2023-04-14 17:45:12.653	error	unknown function code: 0x26, 0x0
    modbus.1
    2023-04-14 17:45:12.639	error	unknown function code: 0x25, 0x0
    modbus.1
    2023-04-14 17:45:12.625	error	unknown function code: 0x24, 0x0
    modbus.1
    2023-04-14 17:45:12.611	error	unknown function code: 0x23, 0x0
    modbus.1
    2023-04-14 17:45:12.598	error	unknown function code: 0x22, 0x0
    modbus.1
    2023-04-14 17:45:12.486	error	unknown function code: 0x21, 0x0
    modbus.1
    2023-04-14 17:45:07.960	info	Connected to slave
    modbus.1
    2023-04-14 17:45:07.890	info	Can not execute task "add" for ID undefined: The id is empty! Please provide a valid id. ({"name":"add","obj":{"type":"state","common":{"name":"","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":-40000,"deviceId":1,"type":"string","len":"7","offset":0,"factor":1,"poll":true}}}
    modbus.1
    2023-04-14 17:45:07.839	error	Invalid object: {"type":"state","common":{"name":"","role":"value","type":"string","read":true,"write":true,"def":"","unit":""},"native":{"regType":"holdingRegs","address":-40000,"deviceId":1,"type":"string","len":"7","offset":0,"factor":1,"poll":true}}
    modbus.1
    2023-04-14 17:45:07.839	error	Invalid data holdingRegisters/0: {"_address":"1","name":"Serial","description":"","unit":"","type":"string","len":"7","factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":-40000,"deviceId":1,"fullId":"modbus.1.0"}
    modbus.1
    2023-04-14 17:45:07.838	error	Invalid holdingRegisters address: -40000
    • R rettroo
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      klassisch
      schrieb am zuletzt editiert von klassisch
      #126
      @rettroo sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
      Gute Frage. Der Waveshare ist ja ein Server und sollte das können. - also die Verbndung von Clients bis zum Waveshare. Mit den USRIOT habe ich das auch schon in einer anderen Konfiguration schon gemacht.
      Das scheint so weit auch in Deinem Fall zu funktionieren, da die Verbindung zum Waveshare nicht abzureißen scheint. Zumindest sehe ich keine entsprechende Fehlermeldung wie tiemout.
      Die Frage ist, wie sich der RS485 und das Modbus Protokoll sowie das Modbus Endgerät verhalten.
      • Läuft die Loxone Abfrage fehlerfrei weiter während man mit dem ioBroker parallel auf das Endgerät zugreifen will?
      • Was passiert wenn man die Loxone Abfrage pausiert und dann nur vom ioBroker aus zugreift?
      R 1 Antwort Letzte Antwort
      • K klassisch
        rettroo
        #127
        @klassisch
        ja Loxone läuft ganz normal weiter. Wenn ich Lox deaktiviere, bekomme ich den ersten Teil des Logs (Zeile 32 bis 19)
        wenn ich danach Lox wieder aktiviere bekomme ich für jeden von Lox abgefragten Wert " unknown function code: 0x22, 0x0" im iobroker Log.
        Nun habe ich von "RTU over TCP" auf "TCP" umgestellt mit folgenden Einstellungen. (ohne Aliase läuft Lox nicht mehr)
        Mit diesen Einstellungen habe ich zumindest mal die Seriennummer abfragen können im IOB und Lox läuft weiter!
        @McWoolf: Hast du schon die Register für die relevanten Werte eingepflegt? Könntest du diese vielleicht teilen?
        • R rettroo
          @klassisch
          klassisch
          #128
          @rettroo Ich würde mich erst mal so weit vorkämpfen, daß ich jeden Zweig einzeln lauffähig habe. Der Loxone Zweig läuft schon mal solo. Also nächster Schritt Loxone pausieren und ioBroker Modbus aufbauen. Schritt für Schritt, Datenpunkt für Datenpunkt. Weil Modbus sehr empfindlich ist aber keine hilfreiche Fehlermeldungen gibt.
          Wenn jeder Zweig solo funktioniert, dann kann man die Kombination testen. Fürchte aber, daß das in diesem Fall eher nicht funktionieren wird.
          40000er Adressen sind Alias Adressen, das sieht plausibel aus.
          Wenn der Parallelbetrieb nicht möglich ist, dann vielleicht eine ioBroker - Loxone Kopplung https://github.com/UncleSamSwiss/ioBroker.loxone ?
          • K klassisch
            rettroo
            #129
            @klassisch
            wie du vermutet hast läuft es nicht parallel... ich bekomme zwischenzeitlich Response Fehler in beiden Systemen.. Unabhängig funktioniert aber jedes System.. Schade, dann werde ich wohl die Daten mit dem Loxone Adapter wieder zurückholen wie du vorgeschlagen hast.
            • R rettroo
              @klassisch
              klassisch
              #130
              @rettroo Vielen Dank für die Info. Schade, daß das nicht geht. Über die Loxone - ioBroker Schnittstelle ist wahrscheinlich eh robuster und schnelller.
              • P planB1
                @mcwoolf Hallo, habe ebenfalls einen Solax X3 G4 15 D und möchte die Daten auch über Modbus auslesen (gibt ja keine andere Möglichkeit soweit ich sehe) - mit welchem Adapter hattest du schlussendlich Erfolg?
                solvo
                schrieb am zuletzt editiert von solvo
                #131
                Hi. Bin neu hier und, was Modbus angeht, blutiger Anfänger. @planb1 , du hst geschrieben, dass es mit dem USR-TCP232-304 geklappt hat. Daraufhin habe ich mir den bestellt.
                Mittlerweile kann ich mich auf einen Docker mit dem Teil verbinden. Er hängt am X3-Hybrid G4 und im LAN. Als Werte bekomme ich aber immer nur Nullen.
                Würdest du mir Screenshots der Settings machen? Gerne im sowohl im USR-TCP232-304 als auch im ioBroker ("Allgemein" und die verschiedenen Register).
                Da wär ich dir sehr dankbar!
                Hoppla... war @McWoolf !
                McWoolfM 1 Antwort Letzte Antwort
                • S solvo
                  McWoolfM Offline
                  McWoolfM Offline
                  McWoolf
                  #132
                  @solvo
                  Hier die beiden Dateien, die solltest du eigentlich im iobroker "modbus" importieren können.
                  Holding Register.txt
                  Eingangs Register.txt
                  Lieben Dank an die Helfer hier.
                  GLG Wolfi
                  Configuration:
                  Intel Nuc: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz (1 Socket)
                  RAM: 8 GB
                  JS-controler: 5.0.17
                  Node.js: 18.19.0
                  NPM: 10.2.3
                  S D P 4 Antworten Letzte Antwort
                  • McWoolfM McWoolf
                    @solvo
                    solvo
                    #133
                    @mcwoolf Tausend Dank für die Dateien! Ich hab sie reinkopiert und ioBroker hat auch nicht gemeckert. Läuft.
                    Leider sind immer noch die Werte bei allen Datenpunkten "0"
                    Kannst du mir noch für "Allgemein" mit der "Geräte ID" weiterhelfen (und sagen, wo die noch eingestellt sein soll)? Und mir im Konverter (USR) mit den richtigen Settings helfen? Oder was dir sonst noch so mit deiner nun reichhaltigen Erfahrung einfällt. :)
                    • McWoolfM McWoolf
                      @solvo
                      decnet
                      #134
                      @mcwoolf Wie kann ich die beiden Dateien importieren?
                      LG
                      Lutz
                      • D decnet
                        LG
                        Lutz
                        decnet
                        #135
                        @decnet Hat sich erledigt, habs gefunden - der Doppelpfeil war die Lösung
                        LG
                        Lutz
                        • D decnet
                          LG
                          Lutz
                          McWoolfM Offline
                          McWoolfM Offline
                          McWoolf
                          #136
                          Kurzes Update:
                          Meine Konfiguration läuft bis heute noch immer stabil, Werte werden immer ausgelesen, besser als mit der 5 min Abfrage von Solax selbst. Mittlerweile steuere ich alles mögliche mit den Daten, sowie meine Brauchwasserwärmepumpe, somit läuft die mit PV-Überschuss und nicht mehr in der Nacht. Mit solchen Steuerungen habe ich meinen Strombezug vom Netz deutlich reduziert. Also für mich hat sich der Ärger mit Modbus rentiert.
                          GLG Wolfi
                          Configuration:
                          RAM: 8 GB
                          Node.js: 18.19.0
                          NPM: 10.2.3
                          D Andre 6A 2 Antworten Letzte Antwort
                          • McWoolfM McWoolf
                            Kurzes Update:
                            docsnyder7
                            #137
                            @mcwoolf eine Frage hätte ich zu den Registern...ich versuche die Adresse "139" zu beschreiben, aber mit dem resultat , dass Modbus kurz aussteigt,.
                            Allerdings benutzt ich evcc als modbusproxy..
                            evt ne Idee
                            schönen Adventssonntag
                            • McWoolfM McWoolf
                              Kurzes Update:
                              Andre 6A Offline
                              Andre 6A Offline
                              Andre 6
                              #138
                              @mcwoolf Moin Wolfi, gibt es auch eine Möglichkeit auf den Solax Geräten über den WiFi Adapter Werte zu setzen?
                              MfG
                              André
                              It's not a bug it's a feature.
                              • McWoolfM McWoolf
                                @solvo
                                purligar
                                #139
                                @mcwoolf
                                Ich versuche einen X3-6-TD mittels RS485toUSB Adapter in iobroker (modbus.1) auszulesen, bisher aber ohne Erfolg. Da ich nur das LAN Dongle habe kann ich die iobroker.solax Instanz nur mit Cloud-API Abfrage benutzen, daher der Versuch Modbus auf PIN 4,5 des WR lokal für iobroker abzugreifen.
                                Funktionieren die beschriebenen Register auch im "SERIAL" Betrieb oder nur im Modbus over TCP ?
                                Oder stimmen meine Allgemein-Einstellungen nicht ?
                                Lese alleine die im HoldingRegister beschriebene Seriennummer aus.allgemein.png
                                11166	2024-03-23 11:59:01.831	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
                                • McWoolfM McWoolf
                                  @solvo
                                  solvo
                                  #140
                                  @mcwoolf
                                  Hallo McWoolf,
                                  nach einem knappen jahr geht es immer noch nicht. Würdest du mir bitte einen Screenshot deiner Einstellungen schicken? Die Register hat iobroker angenommen, mir fehlen die Settings im Konverter (USR TCP232-304) und in der iobroker-Modbus-Instanz. Ich wär die sehr, sehr dankbar.
                                  Solvo
                                  • K klassisch
                                    Habe mir mal die oben verlinkte Solax Registerliste angeschaut.
                                    Ich würde es mit Alias off bzw. nicht angehakt testen.
                                    In der Registerliste mit code 0x03 sind wohl die Input register und die 0x04 die holding register
                                    Wenn Alias aus ist, dann gibt man bei Adresse den Registerwert in Dezimal ein. Und ich hatte auch schon den Fall, wo man 1 dazuaddieren mußte.
                                    Devide ID ist die Modbus Geräteadresse des Wechselrichters. Die gibt man wahrscheinlich im Wechselrichter per Display und Tastatur ein
                                    solvo
                                    #141
                                    @klassisch
                                    dir und @McWoolf noch einmal ein Dankeschön für das Teilen der Infos. Heute habe ich wieder einen Abend am Laptop verbracht, nur um wieder frustriert aufzugeben. Könntest du oder jemand anderes mir helfen?
                                    Ich bin soweit, dass der USR, den auch @McWoolf benutzt, eine Verbindung mit meinem iobroker (auf 192.168.0.12) anzeigt. Auch die Modbus-Instanz schaltet auf "grün". Euer Verdienst! :)
                                    Die Hardware hinter der 192.168.0.12 ist eine Synology mit einem Docker, in dem der iobroker läuft. Ich habe für den Docker schon viele Portweiterleitungen eingerichtet, aber irgendwie bleiben die TX/RX-Werte im USR alle auf 0 und auch die Objekte im iobroker wechseln die Farbe und zeigen dann alle 0 an.
                                    Hier meine Einstellungen des USR
                                    Hier Modbus iob (Register wie von @McWoolf geschickt und Adresse auf "1", also so eingestellt, dass in den Objekten eine 0 statt keinem Wert angezeigt wird).
                                    Hier noch die Einstellungen im Wechselrichter:
                                    Über eure Hilfe würde ich mich sehr, sehr freuen!
                                    • ChrisNettC ChrisNett
                                      ich habe mir einen rs485 adapter besorgt und möchte damit den WR auslesen
                                      https://www.amazon.de/gp/product/B078X5H8H7/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
                                      den stick habe ich ans laufen bekommen ich scheitere aber gerade daran wie und wo ich die Register eintragen muss ich habe die adresse von solar bekommen.
                                      SolaxPower External Communication Protocol X1&X3 Hybrid -G4 ModbusRTU V3.14- public version.pdf
                                      aber wie bitte trage ich das richtig ein?
                                      hier noch ein Log des Adapters wenn benötigt.
                                      modbus.0
                                      2022-04-30 10:53:11.554	silly	States user redis pmessage modbus.0.*/modbus.0.info.connection:{"val":false,"ack":true,"ts":1651308791553,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1651308709938}
                                      modbus.0
                                      2022-04-30 10:53:11.552	silly	States user redis pmessage modbus.0.*/modbus.0.info.connection:{"val":true,"ack":true,"ts":1651308791551,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1651308791551}
                                      modbus.0
                                      2022-04-30 10:53:11.551	silly	States user redis pmessage modbus.0.*/modbus.0.info.connection:{"val":false,"ack":true,"ts":1651308791550,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1651308709938}
                                      modbus.0
                                      2022-04-30 10:53:11.549	debug	Cleaning up request fifo.
                                      modbus.0
                                      2022-04-30 10:53:11.548	info	Disconnected from slave
                                      modbus.0
                                      2022-04-30 10:53:11.547	info	Connected to slave
                                      modbus.0
                                      2022-04-30 10:53:11.544	debug	connect to serial /dev/ttyUSB1 with 19200
                                      modbus.0
                                      2022-04-30 10:53:11.412	silly	States system redis pmessage system.adapter.modbus.0.logLevel/system.adapter.modbus.0.logLevel:{"val":"silly","ack":true,"ts":1651308791408,"q":0,"from":"system.adapter.modbus.0","lc":1651306012066}
                                      modbus.0
                                      2022-04-30 10:53:11.374	info	starting. Version 4.0.4 in /opt/iobroker/node_modules/iobroker.modbus, node: v14.19.1, js-controller: 4.0.21
                                      modbus.0
                                      2022-04-30 10:53:11.248	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      danke Christian
                                      Ray 1
                                      #142
                                      @chrisnett
                                      Ich hole mir die Daten über den rs485 Modbus auch mit einem USB Adapter von meinem Growatt WR.
                                      Im ioBroker habe ich den Modbus Adapter installiert.
                                      In der Instanz habe ich wie auf dem Bild eingestellt:
                                      Und die 123 Eingangsregister genommen, da ich nur Daten lesen will.
                                        andiz_at
                                        #143
                                        @solvo hast du es zum laufen gebracht ? Habe mit den Waveshare und den USR besorgt und ich bekommen mit beiden keine Antwort von meinem Solax X3 G4. Das komische ist dass ich am Bus vom Smartmeter die Daten bekomme ( sehe ich beim Waveshare mit dem SSCOM debugger ) nur am COM Anschluss ist tote Hose. Mit dem Master Simulator hab ich auch noch keine Antworten bekommen. Dreh mich da nur mehr im Kreis gefühlt. Hab schon eher den Verdacht dass mein WR COM vielleicht tot ist. Hab auch das EVCC versucht aber das gibt immer nur einen timeout zurück.
                                        HomoranH S 2 Antworten Letzte Antwort
                                        • A andiz_at
                                          #144
                                          @andiz_at sagte in Einrichten Modbus Adapter / Solar X3 Gen4:
                                          mit einem rs485 to TCP Konverter hast du eine zusätzliche Konfigurationsebene in dem System!!
                                          auch das muss alles passen
