  4. inventwo Icon Set Adapter - updaten funktioniert nicht
    5.3k
61 Beiträge 4 Kommentatoren 7.7k Aufrufe 4 Beobachtet
    @rtwl sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
    Bin ich jetzt meine "Steinzeit" los?
    Moderne Neuzeit.
    Schau mal die 'Summary' von iob diag an. Da sollte es ja jetzt auch alles richtig sein.
    rtwlR Online
    rtwlR Online
    rtwl
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
    22:32:20 up  3:28,  1 user,  load average: 0.68, 1.83, 1.36
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=65.2'C
    volt=0.9060V
    *** Time and Time Zones ***
                  Local time: Sun 2023-08-13 22:32:20 CEST
              Universal time: Sun 2023-08-13 20:32:20 UTC
                    RTC time: n/a
                   Time zone: Europe/Vienna (CEST, +0200)
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    rtwl
    /home/rtwl
    rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        787M        2.1G        0.0K        952M        2.9G
    Swap:            99M          0B         99M
    Total:          3.9G        787M        2.2G
            3794 M total memory
             787 M used memory
             798 M active memory
             682 M inactive memory
            2054 M free memory
             137 M buffer memory
             814 M swap cache
              99 M total swap
               0 M used swap
              99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.9G  7.9G  43% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  800K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Aug 13 19:03:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=36a229aa-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Aug 13 19:03:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Aug 13 19:03:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Aug 13 19:03:50 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.2G    /var/
    795M    /var/log
    793M    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    144M    /var/cache
    Archived and active journals take up 792.1M in the file system.
    /opt/iobroker/backups:
    140M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    963M    /opt/iobroker/iobroker-data/
    485M    /opt/iobroker/iobroker-data/history
    297M    /opt/iobroker/iobroker-data/files
    139M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.1
    /usr/bin/node           v18.17.1
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
     Installed: 18.17.1-deb-1nodesource1
     Candidate: 18.17.1-deb-1nodesource1
     Version table:
    *** 18.17.1-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
        12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.4.1
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
     system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
     system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
     system.adapter.discovery.0              : discovery             : smarthome                                - disabled
    + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
     system.adapter.flot.0                   : flot                  : smarthome                                -  enabled
    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
     system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
     system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
     system.adapter.meteoalarm.0             : meteoalarm            : smarthome                                -  enabled
     system.adapter.meteoalarm.1             : meteoalarm            : smarthome                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
     system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
    + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
    + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
     system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
     system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.4.1
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
    Objects and States
    Objects:        9374
    States:         8189
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12596      531/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140851     10023/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       138998     9826/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       139891     9826/iobroker.js-co
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       141674     10152/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12598      531/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       140631     9848/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       140252     10071/io.web.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       139225     9961/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1892       667/dhcpcd
    udp        0      0 0.0.0.0:59618           0.0.0.0:*                           108        1769       392/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       141675     10152/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1767       392/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       140028     9919/io.shelly.0
    udp6       0      0 :::39631                :::*                                108        1770       392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1768       392/avahi-daemon: r
    2023-08-13 22:28:09.554  - info: mqtt.0 (10023) Starting MQTT authenticated server on 0.0.0.0:1883
    2023-08-13 22:28:10.520  - info: onkyo.0 (10016) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.onkyo, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:28:10.823  - info: onkyo.0 (10016) Starting AVR discovery
    2023-08-13 22:28:16.956  - info: web.0 (10071) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:28:17.528  - info: web.0 (10071) socket.io server listening on port 8082
    2023-08-13 22:28:17.538  - info: web.0 (10071) simpleAPI server listening on port 8082
    2023-08-13 22:28:17.542  - info: web.0 (10071) Allow states only when user is owner: false
    2023-08-13 22:28:17.563  - info: web.0 (10071) http server listening on port 8082
    2023-08-13 22:28:24.141  - info: bring.0 (10106) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:28:24.940  - info: bring.0 (10106) [LOGIN] Successfully logged in as Peter
    2023-08-13 22:28:31.689  - info: vis-inventwo.0 (10124) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:28:47.168  - info: shuttercontrol.0 (10216) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:29:05.768  - info: echarts.0 (10261) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.17.1, js-controller: 4.0.24
    2023-08-13 22:30:24.763  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz radar2.0 alive läuft wieder
    2023-08-13 22:30:38.971  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz mqtt.0 alive läuft wieder
    2023-08-13 22:30:40.700  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz onkyo.0 alive läuft wieder
    2023-08-13 22:30:42.738  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz backitup.0 alive läuft wieder
    2023-08-13 22:30:47.063  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz web.0 alive läuft wieder
    2023-08-13 22:30:54.240  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz bring.0 alive läuft wieder
    2023-08-13 22:31:01.869  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz vis-inventwo.0 alive läuft wieder
    2023-08-13 22:31:05.215  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz trashschedule.0 alive läuft wieder
    2023-08-13 22:31:05.576  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz harmony.0 alive läuft wieder
    2023-08-13 22:31:17.248  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz shuttercontrol.0 alive läuft wieder
    2023-08-13 22:31:32.122  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz sourceanalytix.0 alive läuft wieder
    2023-08-13 22:31:35.852  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz echarts.0 alive läuft wieder
                        v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                           /usr/bin/npm            9.6.7
                           /usr/bin/npx            9.6.7
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        825M        2.0G        0.0K        953M        2.9G
    Swap:            99M          0B         99M
    Total:          3.9G        825M        2.1G
    Active iob-Instances:   19
    ioBroker Core:          js-controller           4.0.24
                           admin                   6.4.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                9374
    States:                 8189
    Size of iob-Database:
    9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    5.6M    /opt/iobroker/iobroker-data/states.jsonl
    1.2M    /opt/iobroker/iobroker-data/states.json.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    -Peter
    • rtwlR rtwl
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=65.2'C
      volt=0.9060V
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      rtwl
      /home/rtwl
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
              3794 M total memory
               787 M used memory
               798 M active memory
              2054 M free memory
               137 M buffer memory
               814 M swap cache
                99 M total swap
                 0 M used swap
                99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.2G    /var/
      795M    /var/log
      144M    /var/cache
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.4.1
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9374
      States:         8189
      Pending Updates: 0
                          v.2023-04-16
      Kernel:                 6.1.21-v8+
      User-ID:                1000
      X-Server:               false
                             /usr/bin/npm            9.6.7
                             /usr/bin/npx            9.6.7
      MEMORY:
      Swap:            99M          0B         99M
                             admin                   6.4.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                9374
      States:                 8189
      @rtwl
      Ja, schaut sehr gut aus.
      Und Danke für's Beta-Testing des nodejs-Fixer-Codes. :-)
      • rtwlR Online
        rtwlR Online
        rtwl
        Ich hab nicht "beta-gestestet" ich hab nur copy&paste gemacht 😁
        mal schauen, ob sich jetzt der icontwo icon set Adapter updaten lässt - hängt jetzt schon 5 min in der Installation
        -Peter
        • rtwlR rtwl
          GlasfaserG Offline
          GlasfaserG Offline
          Sieht doch alles gut aus
          und Danke das du nicht quer im Hintergrund etwas selber gemacht hast ... LOB 👍
          rtwlR 1 Antwort Letzte Antwort
          • GlasfaserG Glasfaser
            rtwlR Online
            rtwlR Online
            rtwl
            @glasfaser @Thomas-Braun
            Ich muss euch beiden Danken! auch wenn ich seit beginn meines Threads immer wieder weg musste und keine Zeit hatte, habt ihr mir als ich dann wieder online war sofort wieder weiter geholfen.
            und das alles nur, weil ich mir ein paar neue Icons ansehen wollte (inventwo Icon Set Adapter).
            Dafür hab ich jetzt ein sauberes aktuelles System am laufen 👍
            DANKE
            -Peter
            • rtwlR rtwl
              DANKE
              GlasfaserG Offline
              GlasfaserG Offline
              DANKE
              Sehr gerne :)
              • rtwlR Online
                rtwlR Online
                rtwl
                eine abschließende Frage:
                damit ich in Zukunft nicht wieder in die Steinzeit zurück falle. Soll man diese 4 Schritte regelmäßig ausführen, um immer am aktuellen Stand zu bleiben? - wenn ja, wie oft ist "regelmäßig"?
                sudo apt update
                iob stop
                sudo apt full-upgrade
                sudo reboot
                -Peter
                • rtwlR rtwl
                  sudo apt update
                  iob stop
                  sudo reboot
                  Ja, natürlich. So oft wie möglich, aber alle paar Wochen spätestens.
                  Wobei hier 'nur' Updates innerhalb eines Releases (sei es des Betriebssystems oder von nodejs) vorgenommen werden. Sprünge auf das nächste Release muss man anders unternehmen.
                  Wobei der Stop des ioBrokers und ein reboot nicht immer zwingend ist, das war jetzt nur der Einfachheit halber drin. Meist kommt man auch mit
                  sudo apt update
                  hin.
                    sudo apt update
                    hin.
                    rtwlR Online
                    rtwlR Online
                    rtwl
                    @thomas-braun sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
                    Diese Sprünge werden dann aber sicher hier im Forum angekündigt und mit einer Anleitung zum Aktualisieren ergänzt. Nehme ich an?
                    alles klar, danke 👍
                    -Peter
                    • rtwlR rtwl
                      alles klar, danke 👍
                      Ja, und für beide Fälle gibt es bislang auch Anleitungen.
                      Bzw. für das Betriebsssystem-Update (Release Upgrade) gibt es natürlich hier im Forum nur indirekte Ankündigungen, das ist ja nicht Bestandteil des ioBrokers. Da muss man selber auch mal schauen, was sich da getan hat.
