  4. inventwo Icon Set Adapter - updaten funktioniert nicht
    5.3k
61 Beiträge 4 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • rtwlR rtwl
    müsste passen, oder?
    rtwl@smarthome:~ $ node -v
    v18.17.1
    Bin ich jetzt meine "Steinzeit" los? 🙂
    @rtwl sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
    Moderne Neuzeit.
    Schau mal die 'Summary' von iob diag an. Da sollte es ja jetzt auch alles richtig sein.
    rtwlR 1 Antwort Letzte Antwort
      Moderne Neuzeit.
      rtwlR Online
      rtwlR Online
      rtwl
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture    : aarch64
      Docker          : false
      Virtualization  : none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
      22:32:20 up  3:28,  1 user,  load average: 0.68, 1.83, 1.36
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=65.2'C
      volt=0.9060V
      *** Time and Time Zones ***
                    Local time: Sun 2023-08-13 22:32:20 CEST
                Universal time: Sun 2023-08-13 20:32:20 UTC
                      RTC time: n/a
                     Time zone: Europe/Vienna (CEST, +0200)
                   NTP service: active
               RTC in local TZ: no
      *** User and Groups ***
      rtwl
      /home/rtwl
      rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        787M        2.1G        0.0K        952M        2.9G
      Swap:            99M          0B         99M
      Total:          3.9G        787M        2.2G
              3794 M total memory
               787 M used memory
               798 M active memory
               682 M inactive memory
              2054 M free memory
               137 M buffer memory
               814 M swap cache
                99 M total swap
                 0 M used swap
                99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       15G  5.9G  7.9G  43% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  800K  759M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sun Aug 13 19:03:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=36a229aa-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Aug 13 19:03:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Aug 13 19:03:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Aug 13 19:03:50 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.2G    /var/
      795M    /var/log
      793M    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
      144M    /var/cache
      Archived and active journals take up 792.1M in the file system.
      /opt/iobroker/backups:
      140M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      963M    /opt/iobroker/iobroker-data/
      485M    /opt/iobroker/iobroker-data/history
      297M    /opt/iobroker/iobroker-data/files
      139M    /opt/iobroker/iobroker-data/backup-objects
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
      17M     /opt/iobroker/iobroker-data/objects.jsonl
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.1
      /usr/bin/node           v18.17.1
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
       Installed: 18.17.1-deb-1nodesource1
       Candidate: 18.17.1-deb-1nodesource1
       Version table:
      *** 18.17.1-deb-1nodesource1 500
             500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
          12.22.12~dfsg-1~deb11u4 500
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.4.1
      javascript:     7.0.3
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
       system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
      + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
      + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
       system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
       system.adapter.discovery.0              : discovery             : smarthome                                - disabled
      + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
       system.adapter.flot.0                   : flot                  : smarthome                                -  enabled
      + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
      + system.adapter.history.0                : history               : smarthome                                -  enabled
       system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
       system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
      + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
       system.adapter.meteoalarm.0             : meteoalarm            : smarthome                                -  enabled
       system.adapter.meteoalarm.1             : meteoalarm            : smarthome                                -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
       system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
      + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
      + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
      + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
      + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
       system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
       system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
       system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
       system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
      + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.4.1
      Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
      Adapter    "alias-manager": 1.2.4    , installed 1.2.4
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "javascript"   : 7.0.3    , installed 7.0.3
      Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "shelly"       : 6.4.1    , installed 6.4.1
      Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
      Objects and States
      Objects:        9374
      States:         8189
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12596      531/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140851     10023/io.mqtt.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       138998     9826/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       139891     9826/iobroker.js-co
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       141674     10152/io.harmony.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12598      531/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       140631     9848/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       140252     10071/io.web.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       139225     9961/io.radar2.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1892       667/dhcpcd
      udp        0      0 0.0.0.0:59618           0.0.0.0:*                           108        1769       392/avahi-daemon: r
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       141675     10152/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1767       392/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       140028     9919/io.shelly.0
      udp6       0      0 :::39631                :::*                                108        1770       392/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        1768       392/avahi-daemon: r
      2023-08-13 22:28:09.554  - info: mqtt.0 (10023) Starting MQTT authenticated server on 0.0.0.0:1883
      2023-08-13 22:28:10.520  - info: onkyo.0 (10016) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.onkyo, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:28:10.823  - info: onkyo.0 (10016) Starting AVR discovery
      2023-08-13 22:28:16.956  - info: web.0 (10071) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:28:17.528  - info: web.0 (10071) socket.io server listening on port 8082
      2023-08-13 22:28:17.538  - info: web.0 (10071) simpleAPI server listening on port 8082
      2023-08-13 22:28:17.542  - info: web.0 (10071) Allow states only when user is owner: false
      2023-08-13 22:28:17.563  - info: web.0 (10071) http server listening on port 8082
      2023-08-13 22:28:24.141  - info: bring.0 (10106) starting. Version 1.8.1 in /opt/iobroker/node_modules/iobroker.bring, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:28:24.940  - info: bring.0 (10106) [LOGIN] Successfully logged in as Peter
      2023-08-13 22:28:31.689  - info: vis-inventwo.0 (10124) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:28:47.168  - info: shuttercontrol.0 (10216) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:29:05.768  - info: echarts.0 (10261) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v18.17.1, js-controller: 4.0.24
      2023-08-13 22:30:24.763  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz radar2.0 alive läuft wieder
      2023-08-13 22:30:38.971  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz mqtt.0 alive läuft wieder
      2023-08-13 22:30:40.700  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz onkyo.0 alive läuft wieder
      2023-08-13 22:30:42.738  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz backitup.0 alive läuft wieder
      2023-08-13 22:30:47.063  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz web.0 alive läuft wieder
      2023-08-13 22:30:54.240  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz bring.0 alive läuft wieder
      2023-08-13 22:31:01.869  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz vis-inventwo.0 alive läuft wieder
      2023-08-13 22:31:05.215  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz trashschedule.0 alive läuft wieder
      2023-08-13 22:31:05.576  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz harmony.0 alive läuft wieder
      2023-08-13 22:31:17.248  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz shuttercontrol.0 alive läuft wieder
      2023-08-13 22:31:32.122  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz sourceanalytix.0 alive läuft wieder
      2023-08-13 22:31:35.852  - info: javascript.0 (9871) script.js.common.Adapter_check: Instanz echarts.0 alive läuft wieder
                          v.2023-04-16
      Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
      Kernel:                 6.1.21-v8+
      Installation:           Native
      Timezone:               Europe/Vienna (CEST, +0200)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.17.1
                             /usr/bin/npm            9.6.7
                             /usr/bin/npx            9.6.7
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            3.8G        825M        2.0G        0.0K        953M        2.9G
      Swap:            99M          0B         99M
      Total:          3.9G        825M        2.1G
      Active iob-Instances:   19
      ioBroker Core:          js-controller           4.0.24
                             admin                   6.4.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                9374
      States:                 8189
      Size of iob-Database:
      9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      9.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      5.6M    /opt/iobroker/iobroker-data/states.jsonl
      1.2M    /opt/iobroker/iobroker-data/states.json.migrated
      1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      -Peter
      • rtwlR rtwl
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=65.2'C
        volt=0.9060V
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        rtwl
        /home/rtwl
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                3794 M total memory
                 787 M used memory
                 798 M active memory
                2054 M free memory
                 137 M buffer memory
                 814 M swap cache
                  99 M total swap
                   0 M used swap
                  99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.2G    /var/
        795M    /var/log
        144M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
         Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.4.1
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        9374
        States:         8189
        Pending Updates: 0
                            v.2023-04-16
        Kernel:                 6.1.21-v8+
        User-ID:                1000
        X-Server:               false
                               /usr/bin/npm            9.6.7
                               /usr/bin/npx            9.6.7
        MEMORY:
        Swap:            99M          0B         99M
                               admin                   6.4.1
        Objects type: jsonl
        States  type: jsonl
        Objects:                9374
        States:                 8189
        @rtwl
        Ja, schaut sehr gut aus.
        Und Danke für's Beta-Testing des nodejs-Fixer-Codes. :-)
        • rtwlR Online
          rtwlR Online
          rtwl
          Ich hab nicht "beta-gestestet" ich hab nur copy&paste gemacht 😁
          mal schauen, ob sich jetzt der icontwo icon set Adapter updaten lässt - hängt jetzt schon 5 min in der Installation
          -Peter
          • rtwlR rtwl
            GlasfaserG Offline
            GlasfaserG Offline
            Sieht doch alles gut aus
            und Danke das du nicht quer im Hintergrund etwas selber gemacht hast ... LOB 👍
            • GlasfaserG Glasfaser
              rtwlR Online
              rtwlR Online
              rtwl
              @glasfaser @Thomas-Braun
              Ich muss euch beiden Danken! auch wenn ich seit beginn meines Threads immer wieder weg musste und keine Zeit hatte, habt ihr mir als ich dann wieder online war sofort wieder weiter geholfen.
              und das alles nur, weil ich mir ein paar neue Icons ansehen wollte (inventwo Icon Set Adapter).
              Dafür hab ich jetzt ein sauberes aktuelles System am laufen 👍
              DANKE
              -Peter
              • rtwlR rtwl
                DANKE
                GlasfaserG Offline
                GlasfaserG Offline
                DANKE
                Sehr gerne :)
                • rtwlR Online
                  rtwlR Online
                  rtwl
                  eine abschließende Frage:
                  damit ich in Zukunft nicht wieder in die Steinzeit zurück falle. Soll man diese 4 Schritte regelmäßig ausführen, um immer am aktuellen Stand zu bleiben? - wenn ja, wie oft ist "regelmäßig"?
                  sudo apt update
                  iob stop
                  sudo apt full-upgrade
                  sudo reboot
                  -Peter
                  • rtwlR rtwl
                    sudo apt update
                    iob stop
                    sudo reboot
                    Ja, natürlich. So oft wie möglich, aber alle paar Wochen spätestens.
                    Wobei hier 'nur' Updates innerhalb eines Releases (sei es des Betriebssystems oder von nodejs) vorgenommen werden. Sprünge auf das nächste Release muss man anders unternehmen.
                    Wobei der Stop des ioBrokers und ein reboot nicht immer zwingend ist, das war jetzt nur der Einfachheit halber drin. Meist kommt man auch mit
                    sudo apt update
                    hin.
                      sudo apt update
                      hin.
                      rtwlR Online
                      rtwlR Online
                      rtwl
                      @thomas-braun sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
                      Diese Sprünge werden dann aber sicher hier im Forum angekündigt und mit einer Anleitung zum Aktualisieren ergänzt. Nehme ich an?
                      alles klar, danke 👍
                      -Peter
                      • rtwlR rtwl
                        alles klar, danke 👍
                        Ja, und für beide Fälle gibt es bislang auch Anleitungen.
                        Bzw. für das Betriebsssystem-Update (Release Upgrade) gibt es natürlich hier im Forum nur indirekte Ankündigungen, das ist ja nicht Bestandteil des ioBrokers. Da muss man selber auch mal schauen, was sich da getan hat.
