  4. inventwo Icon Set Adapter - updaten funktioniert nicht
    5.2k
61 Beiträge 4 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • rtwlR rtwl
    @glasfaser
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
    19:19:40 up 15 min,  1 user,  load average: 0.31, 0.33, 0.35
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=62.3'C
    volt=0.9060V
    *** Time and Time Zones ***
                  Local time: Sun 2023-08-13 19:19:40 CEST
              Universal time: Sun 2023-08-13 17:19:40 UTC
                    RTC time: n/a
                   Time zone: Europe/Vienna (CEST, +0200)
                 NTP service: active
             RTC in local TZ: no
    *** User and Groups ***
    rtwl
    /home/rtwl
    rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        1.0G        2.5G        0.0K        307M        3.0G
    Swap:            99M          0B         99M
    Total:          3.9G        1.0G        2.6G
            3794 M total memory
            1016 M used memory
             756 M active memory
             454 M inactive memory
            2470 M free memory
              43 M buffer memory
             263 M swap cache
              99 M total swap
               0 M used swap
              99 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.8G  8.0G  42% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  804K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sun Aug 13 19:03:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=36a229aa-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Aug 13 19:03:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Aug 13 19:03:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Aug 13 19:03:50 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.2G    /var/
    794M    /var/log
    793M    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    144M    /var/cache
    Archived and active journals take up 792.1M in the file system.
    /opt/iobroker/backups:
    131M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    978M    /opt/iobroker/iobroker-data/
    485M    /opt/iobroker/iobroker-data/history
    297M    /opt/iobroker/iobroker-data/files
    139M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    36M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v14.21.3
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    nodejs:
     Installed: 14.21.3-deb-1nodesource1
     Candidate: 14.21.3-deb-1nodesource1
     Version table:
    *** 14.21.3-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
        12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.4.1
    javascript:     7.0.3
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
     system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
     system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
     system.adapter.discovery.0              : discovery             : smarthome                                - disabled
    + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
     system.adapter.flot.0                   : flot                  : smarthome                                -  enabled
    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
     system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
     system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
     system.adapter.meteoalarm.0             : meteoalarm            : smarthome                                -  enabled
     system.adapter.meteoalarm.1             : meteoalarm            : smarthome                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
     system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
    + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
    + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
     system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
     system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.4.1
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
    Objects and States
    Objects:        9374
    States:         8189
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12596      531/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13074      871/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15504      499/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15497      499/iobroker.js-con
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       13277      1000/io.harmony.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12598      531/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15661      610/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13123      905/io.web.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       15839      793/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1892       667/dhcpcd
    udp        0      0 0.0.0.0:59618           0.0.0.0:*                           108        1769       392/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13278      1000/io.harmony.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1767       392/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15105      761/io.shelly.0
    udp6       0      0 :::39631                :::*                                108        1770       392/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        1768       392/avahi-daemon: r
    2023-08-13 19:07:11.340  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz shelly.0 alive läuft wieder
    2023-08-13 19:07:12.571  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz radar2.0 alive läuft wieder
    2023-08-13 19:07:23.619  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz onkyo.0 alive läuft wieder
    2023-08-13 19:07:24.578  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz mqtt.0 alive läuft wieder
    2023-08-13 19:07:29.300  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz backitup.0 alive läuft wieder
    2023-08-13 19:07:31.221  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz web.0 alive läuft wieder
    2023-08-13 19:07:40.972  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz bring.0 alive läuft wieder
    2023-08-13 19:07:41.818  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz vis-inventwo.0 alive läuft wieder
    2023-08-13 19:07:45.832  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz trashschedule.0 alive läuft wieder
    2023-08-13 19:07:52.116  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz harmony.0 alive läuft wieder
    2023-08-13 19:08:02.115  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz shuttercontrol.0 alive läuft wieder
    2023-08-13 19:08:17.218  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz sourceanalytix.0 alive läuft wieder
    2023-08-13 19:08:21.352  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz echarts.0 alive läuft wieder
    2023-08-13 19:15:02.116  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Terrassen Fenster value: 100%
    2023-08-13 19:15:07.196  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Küche value: 100%
    2023-08-13 19:15:12.216  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Wäscheraum value: 100%
    2023-08-13 19:15:12.231  - info: javascript.0 (686) script.js.Raffstores.Wäscheraum: geöffnet
    2023-08-13 19:15:17.252  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Schrankraum value: 100%
    2023-08-13 19:15:17.281  - info: javascript.0 (686) script.js.Raffstores.Schrankraum: geöffnet
    2023-08-13 19:15:22.291  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Kinderzimmer value: 100%
    2023-08-13 19:15:22.305  - info: javascript.0 (686) script.js.Raffstores.LindaZimmer: geöffnet
    2023-08-13 19:15:27.311  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: IsabellZimmer value: 100%
    2023-08-13 19:15:27.325  - info: javascript.0 (686) script.js.Raffstores.IsabellZimmer: geöffnet
    2023-08-13 19:15:30.219  - info: javascript.0 (686) script.js.Raffstores.Küche: halb oben
    2023-08-13 19:15:48.220  - info: javascript.0 (686) script.js.Raffstores.TerrassenFenster: halb geöffnet
                        v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 6.1.21-v8+
    Installation:           Native
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v14.21.3
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        1.0G        2.2G        0.0K        532M        3.0G
    Swap:            99M          0B         99M
    Total:          3.9G        1.0G        2.3G
    Active iob-Instances:   19
    ioBroker Core:          js-controller           4.0.23
                           admin                   6.4.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                9374
    States:                 8189
    Size of iob-Database:
    9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.8M    /opt/iobroker/iobroker-data/states.jsonl
    1.2M    /opt/iobroker/iobroker-data/states.json.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    GlasfaserG Offline
    GlasfaserG Offline
    @rtwl sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
    Was mich wundert ...
    du bist in Stable und hast ein Uralte BETA Version vom Admin auf deinem System vorhanden !?
    • GlasfaserG Glasfaser
      @rtwl
      Überflogen ... sieht gut aus .
      Würde jetzt das wichtigste machen , den js-controller updaten .
      Zuvor aber ein BACKUP !!
      rtwlR Online
      rtwlR Online
      rtwl
      @glasfaser sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
      Reicht das tägliche Backup vom backitup Adapter?
      Keine Ahnung, ich glaube ich hab mal ein BETA Installiert. Soll ich da vorher was ändern, bevor ich den js-controller update?
      -Peter
      • rtwlR rtwl
        GlasfaserG Offline
        GlasfaserG Offline
        NEIN ... immer vor einer Änderung / update / upgrade usw. erstellen !
        • rtwlR Online
          rtwlR Online
          rtwl
          okay, Backup soeben mit dem backitup Adapter gemacht - liegt auf google drive.
          jetzt den js-controller? - sorry die blöden Fragen, aber ich will mir nichts zerstören.
          -Peter
          • rtwlR rtwl
            GlasfaserG Offline
            GlasfaserG Offline
            @rtwl
            Ja , jetzt den JS Controller
            rtwlR 1 Antwort Letzte Antwort
              @rtwl
              rtwlR Online
              rtwlR Online
              rtwl
              @glasfaser
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              20:13:17 up  1:09,  1 user,  load average: 1.71, 1.78, 1.07
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=67.2'C
              volt=0.9060V
                            Local time: Sun 2023-08-13 20:13:17 CEST
                        Universal time: Sun 2023-08-13 18:13:17 UTC
                              RTC time: n/a
                           NTP service: active
                       RTC in local TZ: no
              rtwl
              /home/rtwl
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            3.8G        646M        2.4G        0.0K        727M        3.1G
              Swap:            99M          0B         99M
              Total:          3.9G        646M        2.5G
                      3794 M total memory
                       646 M used memory
                       665 M active memory
                       484 M inactive memory
                      2419 M free memory
                       120 M buffer memory
                       607 M swap cache
                        99 M total swap
                         0 M used swap
                        99 M free swap
              Raspberry only:
              oom events: 0
              *** FILESYSTEM ***
              /var:
              1.2G    /var/
              794M    /var/log
              144M    /var/cache
              140M    /opt/iobroker/backups/
              956M    /opt/iobroker/iobroker-data/
              17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
              nodejs:
               Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              js-controller:  4.0.24
              admin:          6.4.1
              javascript:     7.0.3
              Adapter State
              No connection to databases possible ...
              Objects and States
              Objects:        9374
              States:         8192
              Hit:1 https://deb.nodesource.com/node_14.x bullseye InRelease
              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
              Pending Updates: 0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       57685      3960/io.mqtt.0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55023      3627/iobroker.js-co
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55016      3627/iobroker.js-co
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       58753      4150/io.harmony.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53785      3645/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57757      4033/io.web.0
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       59450      3782/io.radar2.0
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       58755      4150/io.harmony.0
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       57098      3728/io.shelly.0
              2023-08-13 20:14:21.939  - info: radar2.0 (3782) Adapter identified macs: (60:b7:6e:01:2e:68,84:2a:fd:25:2d:48,54:60:09:84:fd:d2,00:1e:c0:5d:9e:de,dc:0b:34:c9:1f:49,58:24:29:6b:45:17,00:04:20:fb:fa:12,5c:33:8e:9d:db:c6,b2:a7:b9:06:f9:22),
              ips: (192.168.0.8,192.168.0.29,192.168.0.12,192.168.0.23,192.168.0.9,192.168.0.7,192.168.0.6,192.168.0.19,192.168.0.100),
              bts LE: (),
              bts norm: ()
              2023-08-13 20:14:22.151  - info: radar2.0 (3782) will scan UWZ with code UWZAT00803 every 60 minutes
              2023-08-13 20:14:22.281  - info: radar2.0 (3782) UWZ found the following (changed) warnings: Unwetterwarnung der Stufe Rot vor starkem Gewitter, gültig von Sonntag, 13.08. 14:00 Uhr bis Dienstag, 15.08. 14:00 Uhr.: alert_forewarn_red
              Wetterhinweis wegen Hitze, gültig von Montag, 14.08. 14:00 Uhr bis Montag, 14.08. 17:00 Uhr.: notice_forewarn_orange
              2023-08-13 20:14:22.317  - info: radar2.0 (3782) radar2 found 9 devices in config (Papa,Drucker,Chromecast,LMAir,Tasker_Handy,Mama,HarmonyHub,Fernseher,Smartmeter) and 9 enabled.
              2023-08-13 20:14:22.318  - info: radar2.0 (3782) radar2 set use of noble(false), doArp(false), btid(-1) and doUwz(UWZAT00803,60,0,de,true).
              2023-08-13 20:14:22.912  - info: vis-inventwo.0 (4096) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v14.21.3, js-controller: 4.0.24
              2023-08-13 20:14:28.157  - info: shuttercontrol.0 (4151) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.21.3, js-controller: 4.0.24
              2023-08-13 20:14:30.609  - info: sourceanalytix.0 (4200) starting. Version 0.4.14 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v14.21.3, js-controller: 4.0.24
              2023-08-13 20:14:30.656  - info: sourceanalytix.0 (4200) Welcome to SourceAnalytix, making things ready ...
              2023-08-13 20:14:30.773  - info: sourceanalytix.0 (4200) Found 3 SourceAnalytix enabled states
              2023-08-13 20:14:30.774  - info: sourceanalytix.0 (4200) Initialising (1 of 3) "shelly.0.SHPLG-S#9773DE#1.Relay0.Energy"
              2023-08-13 20:14:32.305  - info: echarts.0 (4236) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.21.3, js-controller: 4.0.24
              2023-08-13 20:14:34.569  - info: sourceanalytix.0 (4200) Initialization of shelly.0.SHPLG-S#9773DE#1.Relay0.Energy successfully
              2023-08-13 20:14:34.570  - info: sourceanalytix.0 (4200) Initialising (2 of 3) "shelly.0.SHPLG-S#8040D1#1.Relay0.Energy"
              2023-08-13 20:14:38.809  - info: sourceanalytix.0 (4200) Initialization of shelly.0.SHPLG-S#8040D1#1.Relay0.Energy successfully
              2023-08-13 20:14:38.810  - info: sourceanalytix.0 (4200) Initialising (3 of 3) "mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0"
              2023-08-13 20:14:42.516  - info: sourceanalytix.0 (4200) Initialization of mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0 successfully
              2023-08-13 20:14:42.529  - info: sourceanalytix.0 (4200) Successfully activated SourceAnalytix for 3 of 3 states, will do my Job until you stop me!
              2023-08-13 20:14:48.938  - info: radar2.0 (3782) first scan took 26.618 seconds
              2023-08-13 20:14:48.939  - info: radar2.0 (3782) will scan external network every  60  minutes
              2023-08-13 20:14:49.496  - info: radar2.0 (3782) Adapter initialization finished!
              js-controller ist up to date.
              wie geht es weiter?
              -Peter
              • rtwlR rtwl
                @glasfaser
                Skript v.2023-04-16
                *** BASE SYSTEM ***
                Docker          : false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                CPU threads: 4
                Raspberry only:
                throttled=0x0
                temp=67.2'C
                volt=0.9060V
                                RTC time: n/a
                             NTP service: active
                         RTC in local TZ: no
                rtwl
                /home/rtwl
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M          0B         99M
                        3794 M total memory
                         646 M used memory
                         665 M active memory
                        2419 M free memory
                         120 M buffer memory
                         607 M swap cache
                          99 M total swap
                           0 M used swap
                          99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.2G    /var/
                794M    /var/log
                144M    /var/cache
                nodejs:
                 Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.4.1
                javascript:     7.0.3
                Adapter State
                Objects and States
                Objects:        9374
                States:         8192
                Pending Updates: 0
                bts LE: (),
                bts norm: ()
                wie geht es weiter?
                GlasfaserG Offline
                GlasfaserG Offline
                wie geht es weiter?
                HowTo in seiner Signatur zu 18
                https://forum.iobroker.net/post/1029006
                  wie geht es weiter?
                  rtwlR Online
                  rtwlR Online
                  rtwl
                  @glasfaser
                  ich habs befürchtet, dass das jetzt kommt...
                  hab mir den Post 1 dort schon gelesen, aber bin mir nicht sicher ob ich das schaffe. Da muss man so viel selber kontrollieren und einschätzen ob korrekt bzw "kann man ignorieren" oder auch irgendwelche Verisonsnummern/Pfade rausfinden,... so dass ich mich da ehrlichgesagt nicht sicher fühle, das ganze durchzuspielen.
                  -Peter
                  • GlasfaserG Offline
                    GlasfaserG Offline
                    siehe hier den Hinweis !
                    @thomas-braun sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
                    Oder du kannst auch probieren mit der Beta-Version von iob diag auf node18 zu kommen.
                    per :
                    curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                    chmod 744 iob_diag
                    ./iob_diag
                      per :
                      chmod 744 iob_diag
                      ./iob_diag
                      rtwlR Online
                      rtwlR Online
                      rtwl
                      @glasfaser
                      kann ich gerne "probieren". Was aber passiert da im schlimmsten Fall? Kann ich damit mein System lahm legen?
                      muss ich diese 3 Zeilen hintereinander einfügen mit jeweils [ENTER], oder ist es nur eine Zeile und beim Einfügen hier etwas schief gegangen?
                      -Peter
                      • rtwlR rtwl
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        in der ersten Zeile wird von Github das Script auf dein System geladen
                        in der zweiten Zeile die Rechte dafür vergeben
                        die dritte Zeile startet das Script .
                        Also alles einzeln eingeben !
                          rtwlR Online
                          rtwlR Online
                          rtwl
                          @glasfaser
                          Erledigt.
                          Skript v.2023-08-13
                          *** BASE SYSTEM ***
                             Static hostname: smarthome
                                   Icon name: computer
                                  Machine ID: ce513f1a44ff4c9dbd382eb66e08c51e
                                     Boot ID: 6acd61a272a4420690e212e4f6f77ae7
                            Operating System: Raspbian GNU/Linux 11 (bullseye)
                                      Kernel: Linux 6.1.21-v8+
                                Architecture: arm64
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : armhf
                           21:02:55 up  1:59,  1 user,  load average: 0.41, 0.67, 1.06
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=63.3'C
                          volt=0.9060V
                                         Local time: Sun 2023-08-13 21:02:55 CEST
                                     Universal time: Sun 2023-08-13 19:02:55 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          rtwl
                          /home/rtwl
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            3.8G        1.1G        2.0G        0.0K        768M        2.9G
                          Swap:            99M          0B         99M
                          Total:          3.9G        1.1G        2.1G
                                   3794 M total memory
                                   1059 M used memory
                                    840 M active memory
                                    751 M inactive memory
                                   1966 M free memory
                                    123 M buffer memory
                                    645 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** FILESYSTEM ***
                          /dev/root      ext4       15G  5.8G  8.0G  43% /
                          tmpfs          tmpfs     759M  808K  759M   1% /run
                          /var:
                          1.2G    /var/
                          794M    /var/log
                          144M    /var/cache
                          962M    /opt/iobroker/iobroker-data/
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          /usr/bin/corepack       0.15.1
                          nodejs:
                            Version table:
                          Errors in npm tree:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.4.1
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        9374
                          States:         8137
                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                          Reading package lists... Done
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       65910      4948/io.mqtt.0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65035      4683/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65028      4683/iobroker.js-co
                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       64370      5142/io.harmony.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62901      4702/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       66017      5011/io.web.0
                          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       86007      6067/io.radar2.0
                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       64371      5142/io.harmony.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       63006      4793/io.shelly.0
                          2023-08-13 20:42:00.180  - info: javascript.0 (4725) script.js.VIS.Anzahl_Lampen: 1
                          2023-08-13 20:51:20.212  - info: web.0 (5011) ==> Connected system.user.admin from ::ffff:192.168.0.5
                          2023-08-13 20:52:00.073  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Terrassen Fenster value: 0%
                          2023-08-13 20:52:00.096  - info: javascript.0 (4725) script.js.Raffstores.TerrassenFenster: geschlossen
                          2023-08-13 20:52:03.102  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Küche value: 0%
                          2023-08-13 20:52:03.117  - info: javascript.0 (4725) script.js.Raffstores.Küche: geschlossen
                          2023-08-13 20:52:06.132  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Wäscheraum value: 0%
                          2023-08-13 20:52:06.169  - info: javascript.0 (4725) script.js.Raffstores.Wäscheraum: geschlossen
                          2023-08-13 20:52:09.179  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Wohnzimmer value: 0%
                          2023-08-13 20:52:11.202  - info: javascript.0 (4725) script.js.Raffstores.Wohnzimmer: geschlossen / Lamellen offen
                          2023-08-13 20:52:12.219  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Vorzimmer value: 0%
                          2023-08-13 20:52:15.289  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Bad value: 0%
                          2023-08-13 20:52:18.309  - info: shuttercontrol.0 (5194) Living down #18 Set ID: Schrankraum value: 0%
                          2023-08-13 20:52:47.299  - info: javascript.0 (4725) script.js.Raffstores.Vorzimmer: geschlossen / Lamellen offen
                          2023-08-13 20:52:49.313  - info: javascript.0 (4725) script.js.Raffstores.Bad: geschlossen / Lamellen offen
                          2023-08-13 20:52:52.345  - info: javascript.0 (4725) script.js.Raffstores.Schrankraum: geschlossen / Lamellen offen
                          2023-08-13 21:00:21.982  - info: sourceanalytix.0 (5227) Got terminate signal TERMINATE_YOURSELF
                          2023-08-13 21:00:21.985  - info: sourceanalytix.0 (5227) SourceAnalytix stopped, now you have to calculate by yourself :'( ...
                          2023-08-13 21:00:21.986  - info: sourceanalytix.0 (5227) terminating
                          2023-08-13 21:00:21.988  - info: sourceanalytix.0 (5227) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2023-08-13 21:01:04.205  - info: radar2.0 (4852) Got terminate signal TERMINATE_YOURSELF
                          2023-08-13 21:01:04.213  - info: radar2.0 (4852) Unload adapter now with null
                          2023-08-13 21:01:04.215  - info: radar2.0 (4852) Adapter disconnected and stopped with dostop(null) and callback(true)
                          2023-08-13 21:01:04.216  - info: radar2.0 (4852) terminating
                          2023-08-13 21:01:04.218  - info: radar2.0 (4852) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          Vielen Dank zwischendurch mal für deine Hilfe!
                          -Peter
                          • rtwlR rtwl
                            @glasfaser
                            Erledigt.
                            Skript v.2023-08-13
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : armhf
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            temp=63.3'C
                            volt=0.9060V
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            rtwl
                            /home/rtwl
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:            99M          0B         99M
                                     3794 M total memory
                                     1059 M used memory
                                      840 M active memory
                                     1966 M free memory
                                      123 M buffer memory
                                      645 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.2G    /var/
                            794M    /var/log
                            144M    /var/cache
                            nodejs:
                              Version table:
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.4.1
                            javascript:     7.0.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        9374
                            States:         8137
                            Pending Updates: 0
                            rtwlR Online
                            rtwlR Online
                            rtwl
                            ah doch nicht - wird erst jetzt installiert
                            -Peter
                              GlasfaserG Offline
                              jipp
                                jipp
                                rtwlR Online
                                rtwlR Online
                                rtwl
                                @glasfaser
                                sieht schlecht aus...
                                You are running nodejs v.14.21.3. Do you want to install recommended nodejs v.18.17.1?
                                *** DO NOT TRY THIS FIX ON NON-LINUX-SYSTEMS! ***
                                Press <y> to continue or any other key to quit
                                Waiting for ioBroker to shut down - Give me a minute...
                                ############################################################sudo: /home/iobroker/nodesetup: command not found
                                E: Version '18.17.1-deb-1nodesource1' for 'nodejs' was not found
                                -Peter
                                • rtwlR rtwl
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @Thomas-Braun
                                  kannst du mal in dein Script schauen !!!
                                  • rtwlR rtwl
                                    @glasfaser
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @rtwl
                                    Kein Panik , warte bitte auf @Thomas-Braun
                                      @rtwl
                                      rtwlR Online
                                      rtwlR Online
                                      rtwl
                                      @glasfaser
                                      alles klar - Danke für deine/eure Hilfe!
                                      -Peter
                                      • rtwlR rtwl
                                        @glasfaser
                                        @rtwl
                                        Schau mal bitte was denn gefunden wird.
                                        apt policy nodejs
                                        bitte.
                                          @rtwl
                                          apt policy nodejs
                                          bitte.
                                          rtwlR Online
                                          rtwlR Online
                                          rtwl
                                          das hier wird angezeigt:
                                          nodejs:
                                            Version table:
                                           *** 14.21.3-deb-1nodesource1 100
                                          -Peter
