  4. inventwo Icon Set Adapter - updaten funktioniert nicht
    5.3k
61 Beiträge 4 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • GlasfaserG Glasfaser
    @rtwl sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
    Dann kümmere ich mich darum, dass die Steinzeit verschwindet
    Eine Full Ausgabe von
    iob diag
    wäre schon vor deinem " kümmern " von Vorteil .!!!!
    rtwlR Online
    rtwlR Online
    rtwl
    @glasfaser sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
    iob diag
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : armv7l
    Docker          : false
    Virtualization  : none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     11:12:53 up 210 days, 18:35,  1 user,  load average: 1.34, 2.42, 1.42
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=64.2'C
    volt=0.9160V
    *** Time and Time Zones ***
                   Local time: Sun 2023-08-13 11:12:53 CEST
               Universal time: Sun 2023-08-13 09:12:53 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    rtwl
    /home/rtwl
    rtwl adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        924M        1.0G        0.0K        1.9G        3.0G
    Swap:            99M        1.0M         98M
    Total:          3.9G        925M        1.1G
             3838 M total memory
              924 M used memory
              698 M active memory
             1902 M inactive memory
             1044 M free memory
              140 M buffer memory
             1729 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.9G  7.9G  43% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     768M  812K  767M   1% /run
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Sat Jan 14 15:37:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=36a229aa-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Jan 14 15:37:18 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [Sat Jan 14 15:37:18 2023] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [Sat Jan 14 15:37:20 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sat Jan 14 15:37:20 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jan 14 15:37:20 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jan 14 15:37:23 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G    /var/
    786M    /var/log
    785M    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    144M    /var/cache
    Archived and active journals take up 784.1M in the file system.
    /opt/iobroker/backups:
    131M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    967M    /opt/iobroker/iobroker-data/
    484M    /opt/iobroker/iobroker-data/history
    297M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.eb0afecd.js.map
    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b04901d.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v14.19.0
    /usr/bin/node           v14.19.0
    /usr/bin/npm            6.14.16
    /usr/bin/npx            6.14.16
    nodejs:
      Installed: 14.19.0-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
         14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
     *** 14.19.0-deb-1nodesource1 100
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.4.1
    javascript:     7.0.3
    Adapters from github:   5
    Adapter State
    + system.adapter.admin.0                  : admin                 : smarthome                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : smarthome                                -  enabled
      system.adapter.alias-manager.0          : alias-manager         : smarthome                                -  enabled
    + system.adapter.backitup.0               : backitup              : smarthome                                -  enabled
    + system.adapter.bring.0                  : bring                 : smarthome                                -  enabled
      system.adapter.daswetter.0              : daswetter             : smarthome                                -  enabled
      system.adapter.discovery.0              : discovery             : smarthome                                - disabled
    + system.adapter.echarts.0                : echarts               : smarthome                                -  enabled
      system.adapter.flot.0                   : flot                  : smarthome                                -  enabled
    + system.adapter.harmony.0                : harmony               : smarthome                                -  enabled
    + system.adapter.history.0                : history               : smarthome                                -  enabled
      system.adapter.ical.0                   : ical                  : smarthome                                -  enabled
      system.adapter.ical.1                   : ical                  : smarthome                                -  enabled
    + system.adapter.javascript.0             : javascript            : smarthome                                -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : smarthome                                -  enabled
      system.adapter.meteoalarm.1             : meteoalarm            : smarthome                                -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : smarthome                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : smarthome                                -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : smarthome                                -  enabled
    + system.adapter.pushover.0               : pushover              : smarthome                                -  enabled
    + system.adapter.radar2.0                 : radar2                : smarthome                                -  enabled
    + system.adapter.shelly.0                 : shelly                : smarthome                                -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : smarthome                                -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : smarthome                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : smarthome                                -  enabled
      system.adapter.uv-protect.0             : uv-protect            : smarthome                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : smarthome                                -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : smarthome                                -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : smarthome                                -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : smarthome                                -  enabled
      system.adapter.vis.0                    : vis                   : smarthome                                -  enabled
    + system.adapter.web.0                    : web                   : smarthome                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.4.1
    Adapter    "alexa2"       : 3.24.1   , installed 3.24.1
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "javascript"   : 7.0.3    , installed 7.0.3
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "meteoalarm"   : 2.3.6    , installed 2.3.6
    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "radar2"       : 2.0.7    , installed 2.0.7
    Adapter    "shelly"       : 6.4.1    , installed 6.4.1
    Adapter    "shuttercontrol": 1.5.0   , installed 1.5.0
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "uv-protect"   : 0.4.0    , installed 0.4.0
    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.94.0 [Updatable]
    Objects and States
    Objects:        9374
    States:         8189
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 171
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       135573713  14664/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       135570114  14274/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       135570107  14274/iobroker.js-c
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14394      542/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       135574694  14804/io.harmony.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       135569310  14302/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       135572259  14699/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14396      542/sshd: /usr/sbin
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       135573576  14544/io.radar2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13576      646/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14341      397/avahi-daemon: r
    udp        0      0 0.0.0.0:40819           0.0.0.0:*                           108        14343      397/avahi-daemon: r
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       135574695  14804/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       135571949  14452/io.shelly.0
    udp6       0      0 :::5353                 :::*                                108        14342      397/avahi-daemon: r
    udp6       0      0 :::50211                :::*                                108        14344      397/avahi-daemon: r
    2023-08-13 11:10:34.562  - info: sourceanalytix.0 (15142) Found 3 SourceAnalytix enabled states
    2023-08-13 11:10:34.568  - info: sourceanalytix.0 (15142) Initialising (1 of 3) "shelly.0.SHPLG-S#9773DE#1.Relay0.Energy"
    2023-08-13 11:10:34.678  - info: echarts.0 (15184) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.19.0, js-controller: 4.0.23
    2023-08-13 11:10:38.035  - info: sourceanalytix.0 (15142) Initialization of shelly.0.SHPLG-S#9773DE#1.Relay0.Energy successfully
    2023-08-13 11:10:38.036  - info: sourceanalytix.0 (15142) Initialising (2 of 3) "shelly.0.SHPLG-S#8040D1#1.Relay0.Energy"
    2023-08-13 11:10:42.120  - info: sourceanalytix.0 (15142) Initialization of shelly.0.SHPLG-S#8040D1#1.Relay0.Energy successfully
    2023-08-13 11:10:42.121  - info: sourceanalytix.0 (15142) Initialising (3 of 3) "mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0"
    2023-08-13 11:10:44.175  - info: sourceanalytix.0 (15142) Initialization of mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0 successfully
    2023-08-13 11:10:44.200  - info: sourceanalytix.0 (15142) Successfully activated SourceAnalytix for 3 of 3 states, will do my Job until you stop me!
    2023-08-13 11:11:34.098  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz history.0 alive läuft wieder
    2023-08-13 11:11:36.252  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz pushover.0 alive läuft wieder
    2023-08-13 11:11:38.323  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz shelly.0 alive läuft wieder
    2023-08-13 11:11:44.249  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz radar2.0 alive läuft wieder
    2023-08-13 11:11:52.951  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz alexa2.0 alive läuft wieder
    2023-08-13 11:11:57.250  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz onkyo.0 alive läuft wieder
    2023-08-13 11:11:58.491  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz mqtt.0 alive läuft wieder
    2023-08-13 11:12:03.995  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz backitup.0 alive läuft wieder
    2023-08-13 11:12:08.418  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz web.0 alive läuft wieder
    2023-08-13 11:12:20.919  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz bring.0 alive läuft wieder
    2023-08-13 11:12:24.431  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz vis-inventwo.0 alive läuft wieder
    2023-08-13 11:12:25.641  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz harmony.0 alive läuft wieder
    2023-08-13 11:12:26.182  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz trashschedule.0 alive läuft wieder
    2023-08-13 11:12:37.922  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz shuttercontrol.0 alive läuft wieder
    2023-08-13 11:13:04.441  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz sourceanalytix.0 alive läuft wieder
    2023-08-13 11:13:04.785  - info: javascript.0 (14325) script.js.common.Adapter_check: Instanz echarts.0 alive läuft wieder
                        v.2023-04-16
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.92-v7l+
    Installation:           Native
    Timezone:               Europe/Vienna (CEST, +0200)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     171
    Pending iob updates:    2
    Nodejs-Installation:    /usr/bin/nodejs         v14.19.0
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            3.8G        978M        989M        0.0K        1.9G        2.9G
    Swap:            99M        1.0M         98M
    Total:          3.9G        979M        1.1G
    Active iob-Instances:   19
    ioBroker Core:          js-controller           4.0.23
                           admin                   6.4.1
    Objects type: jsonl
    States  type: jsonl
    Objects:                9374
    States:                 8189
    Size of iob-Database:
    9.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    9.6M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    3.9M    /opt/iobroker/iobroker-data/states.jsonl
    1.2M    /opt/iobroker/iobroker-data/states.json.migrated
    1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    0       /opt/iobroker/iobroker-data/states.json.broken
    ich würde mich sehr über Hilfe freuen!
    -Peter
    • rtwlR rtwl
      iob diag
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=64.2'C
      volt=0.9160V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      rtwl
      /home/rtwl
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M        1.0M         98M
               3838 M total memory
                924 M used memory
                698 M active memory
               1044 M free memory
                140 M buffer memory
               1729 M swap cache
                 99 M total swap
                  1 M used swap
                 98 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.1G    /var/
      786M    /var/log
      144M    /var/cache
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.4.1
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9374
      States:         8189
                          v.2023-04-16
      User-ID:                1000
      X-Server:               false
      MEMORY:
      Swap:            99M        1.0M         98M
                             admin                   6.4.1
      Objects type: jsonl
      States  type: jsonl
      Objects:                9374
      States:                 8189
      @rtwl
      System auf Stand bringen.
      171 Updates und nodejs auf die Empfehlung v18.
      rtwlR 1 Antwort Letzte Antwort
        @rtwl
        rtwlR Online
        rtwlR Online
        rtwl
        @thomas-braun sagte in inventwo Icon Set Adapter - updaten funktioniert nicht:
        Aufgrund der Anspielung auf meine "Steinzeit" wäre das auch mein Ziel.
        aber wie fange ich damit am besten an? - Ich hab noch keine Erfahrung damit. Copy&Paste war auch der Zugang bei mir beim Aufsetzen von ioBroker.
        -Peter
        • rtwlR rtwl
          @rtwl
          System mit
          sudo apt update
          iob stop
          sudo apt full-upgrade
          sudo reboot
          Wechsel auf nodejs18 nach meinem HowTo in meiner Signatur.
          Oder du kannst auch probieren mit der Bera-Version von iob diag auf node18 zu kommen.
          rtwlR 2 Antworten Letzte Antwort
            @rtwl
            System mit
            sudo apt update
            iob stop
            sudo reboot
            rtwlR Online
            rtwlR Online
            rtwl
            ich hab irgendwo mal die Empfehlung bekommen nichts mit sudo einzugeben - keine Ahnung warum genau.
            aber hier passt es wenn ich die 4 Schritte so mache? - ich will nur auf Nummer sicher gehen und bin dir sehr dankbar, dass du mir hilfst.
            -Peter
            • rtwlR rtwl
              @rtwl
              Das ist ja grundsätzlich richtig, sudo so selten wie möglich zu verwenden.
              Mittels sudo bekommt man Zugriff auf das Kernsystem, das ist aber bei Updates/Upgrades natürlich erforderlich.
                @rtwl
                rtwlR Online
                rtwlR Online
                rtwl
                alles klar, danke 👍
                Ich denke das wird einiges an Zeit in Anspruch nehmen (171 Updates...) daher gehts erst später weiter. Muss jetzt Essen fahren. 🙄
                -Peter
                  @rtwl
                  System mit
                  sudo apt update
                  iob stop
                  sudo reboot
                  rtwlR Online
                  rtwlR Online
                  rtwl
                  System mit
                  • sudo apt update
                  • iob stop
                  • sudo apt full-upgrade
                  • sudo reboot
                  soeben hab ich diese Schritte gemacht.
                  was wäre jetzt mein nächster Schritt?
                  js-controller updaten laut der offiziellen Anleitung?
                  oder muss ich da vorab nochmal was machen?
                  -Peter
                  • rtwlR rtwl
                    System mit
                    • sudo apt update
                    • iob stop
                    • sudo reboot
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Zeigen ...
                    Full-Ausgabe von
                    iob diag
                      Zeigen ...
                      Full-Ausgabe von
                      iob diag
                      rtwlR Online
                      rtwlR Online
                      rtwl
                      @glasfaser
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Architecture    : aarch64
                      Docker          : false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=raspbian
                      ID_LIKE=debian
                      19:19:40 up 15 min,  1 user,  load average: 0.31, 0.33, 0.35
                      CPU threads: 4
                      Raspberry only:
                      throttled=0x0
                      temp=62.3'C
                      volt=0.9060V
                                    Local time: Sun 2023-08-13 19:19:40 CEST
                                Universal time: Sun 2023-08-13 17:19:40 UTC
                                      RTC time: n/a
                                   NTP service: active
                               RTC in local TZ: no
                      rtwl
                      /home/rtwl
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            3.8G        1.0G        2.5G        0.0K        307M        3.0G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.0G        2.6G
                              3794 M total memory
                              1016 M used memory
                               756 M active memory
                               454 M inactive memory
                              2470 M free memory
                                43 M buffer memory
                               263 M swap cache
                                99 M total swap
                                 0 M used swap
                                99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       15G  5.8G  8.0G  42% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     759M  804K  759M   1% /run
                      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Sun Aug 13 19:03:46 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:75:F7:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=36a229aa-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Sun Aug 13 19:03:47 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sun Aug 13 19:03:47 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                      [Sun Aug 13 19:03:50 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      /var:
                      1.2G    /var/
                      794M    /var/log
                      793M    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
                      144M    /var/cache
                      Archived and active journals take up 792.1M in the file system.
                      978M    /opt/iobroker/iobroker-data/
                      485M    /opt/iobroker/iobroker-data/history
                      139M    /opt/iobroker/iobroker-data/backup-objects
                      36M     /opt/iobroker/iobroker-data/objects.jsonl
                      /usr/bin/nodejs         v14.21.3
                      /usr/bin/node           v14.21.3
                      /usr/bin/npm            6.14.18
                      /usr/bin/npx            6.14.18
                      nodejs:
                       Installed: 14.21.3-deb-1nodesource1
                       Version table:
                      *** 14.21.3-deb-1nodesource1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.4.1
                      javascript:     7.0.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        9374
                      States:         8189
                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12596      531/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       13074      871/io.mqtt.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15504      499/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15497      499/iobroker.js-con
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       13277      1000/io.harmony.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          12598      531/sshd: /usr/sbin
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15661      610/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13123      905/io.web.0
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       15839      793/io.radar2.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1892       667/dhcpcd
                      udp        0      0 0.0.0.0:59618           0.0.0.0:*                           108        1769       392/avahi-daemon: r
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13278      1000/io.harmony.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1767       392/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15105      761/io.shelly.0
                      udp6       0      0 :::39631                :::*                                108        1770       392/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        1768       392/avahi-daemon: r
                      2023-08-13 19:07:11.340  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz shelly.0 alive läuft wieder
                      2023-08-13 19:07:12.571  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz radar2.0 alive läuft wieder
                      2023-08-13 19:07:23.619  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz onkyo.0 alive läuft wieder
                      2023-08-13 19:07:24.578  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz mqtt.0 alive läuft wieder
                      2023-08-13 19:07:29.300  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz backitup.0 alive läuft wieder
                      2023-08-13 19:07:31.221  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz web.0 alive läuft wieder
                      2023-08-13 19:07:40.972  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz bring.0 alive läuft wieder
                      2023-08-13 19:07:41.818  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz vis-inventwo.0 alive läuft wieder
                      2023-08-13 19:07:45.832  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz trashschedule.0 alive läuft wieder
                      2023-08-13 19:07:52.116  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz harmony.0 alive läuft wieder
                      2023-08-13 19:08:02.115  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz shuttercontrol.0 alive läuft wieder
                      2023-08-13 19:08:17.218  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz sourceanalytix.0 alive läuft wieder
                      2023-08-13 19:08:21.352  - info: javascript.0 (686) script.js.common.Adapter_check: Instanz echarts.0 alive läuft wieder
                      2023-08-13 19:15:02.116  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Terrassen Fenster value: 100%
                      2023-08-13 19:15:07.196  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Küche value: 100%
                      2023-08-13 19:15:12.216  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Wäscheraum value: 100%
                      2023-08-13 19:15:12.231  - info: javascript.0 (686) script.js.Raffstores.Wäscheraum: geöffnet
                      2023-08-13 19:15:17.252  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Schrankraum value: 100%
                      2023-08-13 19:15:17.281  - info: javascript.0 (686) script.js.Raffstores.Schrankraum: geöffnet
                      2023-08-13 19:15:22.291  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: Kinderzimmer value: 100%
                      2023-08-13 19:15:22.305  - info: javascript.0 (686) script.js.Raffstores.LindaZimmer: geöffnet
                      2023-08-13 19:15:27.311  - info: shuttercontrol.0 (1048) Sunprotect #422 Set ID: IsabellZimmer value: 100%
                      2023-08-13 19:15:27.325  - info: javascript.0 (686) script.js.Raffstores.IsabellZimmer: geöffnet
                      2023-08-13 19:15:30.219  - info: javascript.0 (686) script.js.Raffstores.Küche: halb oben
                      2023-08-13 19:15:48.220  - info: javascript.0 (686) script.js.Raffstores.TerrassenFenster: halb geöffnet
                                          v.2023-04-16
                      Kernel:                 6.1.21-v8+
                      User-ID:                1000
                      X-Server:               false
                      Pending OS-Updates:     0
                      Nodejs-Installation:    /usr/bin/nodejs         v14.21.3
                      MEMORY:
                      Mem:            3.8G        1.0G        2.2G        0.0K        532M        3.0G
                      Swap:            99M          0B         99M
                      Total:          3.9G        1.0G        2.3G
                                             admin                   6.4.1
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                9374
                      States:                 8189
                      2.8M    /opt/iobroker/iobroker-data/states.jsonl
                      -Peter
                      • rtwlR rtwl
                        @glasfaser
                        Skript v.2023-04-16
                        *** BASE SYSTEM ***
                        Docker          : false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        Raspberry only:
                        throttled=0x0
                        temp=62.3'C
                        volt=0.9060V
                                        RTC time: n/a
                                     NTP service: active
                                 RTC in local TZ: no
                        rtwl
                        /home/rtwl
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M          0B         99M
                                3794 M total memory
                                1016 M used memory
                                 756 M active memory
                                2470 M free memory
                                  43 M buffer memory
                                 263 M swap cache
                                  99 M total swap
                                   0 M used swap
                                  99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.2G    /var/
                        794M    /var/log
                        144M    /var/cache
                        nodejs:
                         Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.4.1
                        javascript:     7.0.3
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        9374
                        States:         8189
                        Pending Updates: 0
                                            v.2023-04-16
                        Kernel:                 6.1.21-v8+
                        User-ID:                1000
                        X-Server:               false
                        MEMORY:
                        Swap:            99M          0B         99M
                                               admin                   6.4.1
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                9374
                        States:                 8189
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @rtwl
                        Überflogen ... sieht gut aus .
                        Würde jetzt das wichtigste machen , den js-controller updaten .
                        Zuvor aber ein BACKUP !!
                        • rtwlR rtwl
                          @glasfaser
                          Skript v.2023-04-16
                          *** BASE SYSTEM ***
                          Docker          : false
                          Release:        11
                          Codename:       bullseye
                          VERSION_ID="11"
                          ID=raspbian
                          ID_LIKE=debian
                          CPU threads: 4
                          Raspberry only:
                          throttled=0x0
                          temp=62.3'C
                          volt=0.9060V
                                          RTC time: n/a
                                       NTP service: active
                                   RTC in local TZ: no
                          rtwl
                          /home/rtwl
                          X-Server:       false
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Swap:            99M          0B         99M
                                  3794 M total memory
                                  1016 M used memory
                                   756 M active memory
                                  2470 M free memory
                                    43 M buffer memory
                                   263 M swap cache
                                    99 M total swap
                                     0 M used swap
                                    99 M free swap
                          Raspberry only:
                          oom events: 0
                          *** FILESYSTEM ***
                          /var:
                          1.2G    /var/
                          794M    /var/log
                          144M    /var/cache
                          nodejs:
                           Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin:          6.4.1
                          javascript:     7.0.3
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        9374
                          States:         8189
                          Pending Updates: 0
                                              v.2023-04-16
                          Kernel:                 6.1.21-v8+
                          User-ID:                1000
                          X-Server:               false
                          MEMORY:
                          Swap:            99M          0B         99M
                                                 admin                   6.4.1
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                9374
                          States:                 8189
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Was mich wundert ...
                          du bist in Stable und hast ein Uralte BETA Version vom Admin auf deinem System vorhanden !?
                            @rtwl
                            rtwlR Online
                            rtwlR Online
                            rtwl
                            Reicht das tägliche Backup vom backitup Adapter?
                            Keine Ahnung, ich glaube ich hab mal ein BETA Installiert. Soll ich da vorher was ändern, bevor ich den js-controller update?
                            -Peter
                            • rtwlR rtwl
                              GlasfaserG Offline
                              GlasfaserG Offline
                              NEIN ... immer vor einer Änderung / update / upgrade usw. erstellen !
                              • rtwlR Online
                                rtwlR Online
                                rtwl
                                okay, Backup soeben mit dem backitup Adapter gemacht - liegt auf google drive.
                                jetzt den js-controller? - sorry die blöden Fragen, aber ich will mir nichts zerstören.
                                -Peter
                                • rtwlR rtwl
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @rtwl
                                  Ja , jetzt den JS Controller
                                    @rtwl
                                    rtwlR Online
                                    rtwlR Online
                                    rtwl
                                    @glasfaser
                                    Skript v.2023-04-16
                                    *** BASE SYSTEM ***
                                    Docker          : false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    20:13:17 up  1:09,  1 user,  load average: 1.71, 1.78, 1.07
                                    CPU threads: 4
                                    Raspberry only:
                                    throttled=0x0
                                    temp=67.2'C
                                    volt=0.9060V
                                                  Local time: Sun 2023-08-13 20:13:17 CEST
                                              Universal time: Sun 2023-08-13 18:13:17 UTC
                                                    RTC time: n/a
                                                 NTP service: active
                                             RTC in local TZ: no
                                    rtwl
                                    /home/rtwl
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        646M        2.4G        0.0K        727M        3.1G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        646M        2.5G
                                            3794 M total memory
                                             646 M used memory
                                             665 M active memory
                                             484 M inactive memory
                                            2419 M free memory
                                             120 M buffer memory
                                             607 M swap cache
                                              99 M total swap
                                               0 M used swap
                                              99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    /var:
                                    1.2G    /var/
                                    794M    /var/log
                                    144M    /var/cache
                                    140M    /opt/iobroker/backups/
                                    956M    /opt/iobroker/iobroker-data/
                                    17M     /opt/iobroker/iobroker-data/files/echarts.admin/preview/static/js/main.1b04901d.js.map
                                    nodejs:
                                     Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    js-controller:  4.0.24
                                    admin:          6.4.1
                                    javascript:     7.0.3
                                    Adapter State
                                    No connection to databases possible ...
                                    Objects and States
                                    Objects:        9374
                                    States:         8192
                                    Hit:1 https://deb.nodesource.com/node_14.x bullseye InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       57685      3960/io.mqtt.0
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55023      3627/iobroker.js-co
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55016      3627/iobroker.js-co
                                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       58753      4150/io.harmony.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53785      3645/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57757      4033/io.web.0
                                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       59450      3782/io.radar2.0
                                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       58755      4150/io.harmony.0
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       57098      3728/io.shelly.0
                                    2023-08-13 20:14:21.939  - info: radar2.0 (3782) Adapter identified macs: (60:b7:6e:01:2e:68,84:2a:fd:25:2d:48,54:60:09:84:fd:d2,00:1e:c0:5d:9e:de,dc:0b:34:c9:1f:49,58:24:29:6b:45:17,00:04:20:fb:fa:12,5c:33:8e:9d:db:c6,b2:a7:b9:06:f9:22),
                                    ips: (192.168.0.8,192.168.0.29,192.168.0.12,192.168.0.23,192.168.0.9,192.168.0.7,192.168.0.6,192.168.0.19,192.168.0.100),
                                    bts LE: (),
                                    bts norm: ()
                                    2023-08-13 20:14:22.151  - info: radar2.0 (3782) will scan UWZ with code UWZAT00803 every 60 minutes
                                    2023-08-13 20:14:22.281  - info: radar2.0 (3782) UWZ found the following (changed) warnings: Unwetterwarnung der Stufe Rot vor starkem Gewitter, gültig von Sonntag, 13.08. 14:00 Uhr bis Dienstag, 15.08. 14:00 Uhr.: alert_forewarn_red
                                    Wetterhinweis wegen Hitze, gültig von Montag, 14.08. 14:00 Uhr bis Montag, 14.08. 17:00 Uhr.: notice_forewarn_orange
                                    2023-08-13 20:14:22.317  - info: radar2.0 (3782) radar2 found 9 devices in config (Papa,Drucker,Chromecast,LMAir,Tasker_Handy,Mama,HarmonyHub,Fernseher,Smartmeter) and 9 enabled.
                                    2023-08-13 20:14:22.318  - info: radar2.0 (3782) radar2 set use of noble(false), doArp(false), btid(-1) and doUwz(UWZAT00803,60,0,de,true).
                                    2023-08-13 20:14:22.912  - info: vis-inventwo.0 (4096) starting. Version 3.3.3 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v14.21.3, js-controller: 4.0.24
                                    2023-08-13 20:14:28.157  - info: shuttercontrol.0 (4151) starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v14.21.3, js-controller: 4.0.24
                                    2023-08-13 20:14:30.609  - info: sourceanalytix.0 (4200) starting. Version 0.4.14 in /opt/iobroker/node_modules/iobroker.sourceanalytix, node: v14.21.3, js-controller: 4.0.24
                                    2023-08-13 20:14:30.656  - info: sourceanalytix.0 (4200) Welcome to SourceAnalytix, making things ready ...
                                    2023-08-13 20:14:30.773  - info: sourceanalytix.0 (4200) Found 3 SourceAnalytix enabled states
                                    2023-08-13 20:14:30.774  - info: sourceanalytix.0 (4200) Initialising (1 of 3) "shelly.0.SHPLG-S#9773DE#1.Relay0.Energy"
                                    2023-08-13 20:14:32.305  - info: echarts.0 (4236) starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.echarts, node: v14.21.3, js-controller: 4.0.24
                                    2023-08-13 20:14:34.569  - info: sourceanalytix.0 (4200) Initialization of shelly.0.SHPLG-S#9773DE#1.Relay0.Energy successfully
                                    2023-08-13 20:14:34.570  - info: sourceanalytix.0 (4200) Initialising (2 of 3) "shelly.0.SHPLG-S#8040D1#1.Relay0.Energy"
                                    2023-08-13 20:14:38.809  - info: sourceanalytix.0 (4200) Initialization of shelly.0.SHPLG-S#8040D1#1.Relay0.Energy successfully
                                    2023-08-13 20:14:38.810  - info: sourceanalytix.0 (4200) Initialising (3 of 3) "mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0"
                                    2023-08-13 20:14:42.516  - info: sourceanalytix.0 (4200) Initialization of mqtt.0.SHRDZM.4C7525361F9E.4C7525361F9E.sensor.1.8.0 successfully
                                    2023-08-13 20:14:42.529  - info: sourceanalytix.0 (4200) Successfully activated SourceAnalytix for 3 of 3 states, will do my Job until you stop me!
                                    2023-08-13 20:14:48.938  - info: radar2.0 (3782) first scan took 26.618 seconds
                                    2023-08-13 20:14:48.939  - info: radar2.0 (3782) will scan external network every  60  minutes
                                    2023-08-13 20:14:49.496  - info: radar2.0 (3782) Adapter initialization finished!
                                    js-controller ist up to date.
                                    wie geht es weiter?
                                    -Peter
                                    • rtwlR rtwl
                                      @glasfaser
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=raspbian
                                      ID_LIKE=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=67.2'C
                                      volt=0.9060V
                                                      RTC time: n/a
                                                   NTP service: active
                                               RTC in local TZ: no
                                      rtwl
                                      /home/rtwl
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                              3794 M total memory
                                               646 M used memory
                                               665 M active memory
                                              2419 M free memory
                                               120 M buffer memory
                                               607 M swap cache
                                                99 M total swap
                                                 0 M used swap
                                                99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      1.2G    /var/
                                      794M    /var/log
                                      144M    /var/cache
                                      nodejs:
                                       Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.4.1
                                      javascript:     7.0.3
                                      Adapter State
                                      Objects and States
                                      Objects:        9374
                                      States:         8192
                                      Pending Updates: 0
                                      bts LE: (),
                                      bts norm: ()
                                      wie geht es weiter?
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      wie geht es weiter?
                                      HowTo in seiner Signatur zu 18
                                      https://forum.iobroker.net/post/1029006
                                        wie geht es weiter?
                                        rtwlR Online
                                        rtwlR Online
                                        rtwl
                                        @glasfaser
                                        ich habs befürchtet, dass das jetzt kommt...
                                        hab mir den Post 1 dort schon gelesen, aber bin mir nicht sicher ob ich das schaffe. Da muss man so viel selber kontrollieren und einschätzen ob korrekt bzw "kann man ignorieren" oder auch irgendwelche Verisonsnummern/Pfade rausfinden,... so dass ich mich da ehrlichgesagt nicht sicher fühle, das ganze durchzuspielen.
                                        -Peter
                                        • GlasfaserG Offline
                                          GlasfaserG Offline
                                          siehe hier den Hinweis !
                                          Oder du kannst auch probieren mit der Beta-Version von iob diag auf node18 zu kommen.
                                          per :
                                          curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_diag > iob_diag
                                          chmod 744 iob_diag
                                          ./iob_diag
