  4. Test Adapter telegram-menu v.1.6.x
    1.0k
1.9k Beiträge 65 Kommentatoren 1.0m Aufrufe 63 Beobachtet
  • Michael RolingM Michael Roling
    @negalein Mmmh das ist komisch, ich habe das Problem nicht, ich bastel gerade selbst an meinem Menu und bei mir taucht das Problem nicht auf
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #146
    @michael-roling sagte in Test Adapter telegram-menu v.0.3.x:
    ich hab hier mal das Log vom Start.
    Eventuell siehst du was.
    2023-07-31 10:18:50.581  - info: host.ioBroker instance system.adapter.telegram-menu.0 started with pid 394412
    2023-07-31 10:18:51.002  - debug: telegram-menu.0 (394412) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-07-31 10:18:51.101  - debug: telegram-menu.0 (394412) Objects client ready ... initialize now
    2023-07-31 10:18:51.102  - debug: telegram-menu.0 (394412) Objects create System PubSub Client
    2023-07-31 10:18:51.102  - debug: telegram-menu.0 (394412) Objects create User PubSub Client
    2023-07-31 10:18:51.252  - debug: telegram-menu.0 (394412) Objects client initialize lua scripts
    2023-07-31 10:18:51.265  - debug: telegram-menu.0 (394412) Objects connected to redis: 0.0.0.0:9001
    2023-07-31 10:18:51.325  - debug: telegram-menu.0 (394412) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-07-31 10:18:51.373  - debug: telegram-menu.0 (394412) States create System PubSub Client
    2023-07-31 10:18:51.373  - debug: telegram-menu.0 (394412) States create User PubSub Client
    2023-07-31 10:18:51.467  - debug: telegram-menu.0 (394412) States connected to redis: 0.0.0.0:9000
    2023-07-31 10:18:51.934  - info: telegram-menu.0 (394412) starting. Version 0.4.2 in /opt/iobroker/node_modules/iobroker.telegram-menu, node: v16.20.1, js-controller: 4.0.24
    2023-07-31 10:18:51.972  - debug: telegram-menu.0 (394412) Instance "telegram.0"
    2023-07-31 10:18:51.972  - debug: telegram-menu.0 (394412) Datapoint "telegram.0.info.connection"
    2023-07-31 10:18:52.517  - info: telegram-menu.0 (394412) Telegram was found
    2023-07-31 10:18:52.519  - debug: telegram-menu.0 (394412) Navigation {"Global":[{"call":"Home","value":"Licht && Strom && Wetter","text":"Wählen Sie eine Aktion"},{"call":"Licht","value":"Home && Wohnzimmer Licht, Wintergarten Licht, Wintergarten Strip","text":"Wähle eine Aktion"},{"call":"Strom","value":"Home && Pelletsofen, 3D Drucker","text":"Wähle eine Aktion"},{"call":"Wetter","value":"Home && Aussentemperatur, Windstärke, Regen","text":"Wähle eine Aktion"}],"Christian":[{"call":"Startseite","value":"Licht, Steckdose && Iobroker, Heizung","text":"Wähle eine Aktion"}]}
    2023-07-31 10:18:52.519  - debug: telegram-menu.0 (394412) Action {"Global":{"get":[{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}],"set":[{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}],"pic":[]},"Christian":{"get":[],"set":[],"pic":[]}}
    2023-07-31 10:18:52.520  - debug: telegram-menu.0 (394412) Array [["Licht "],[" Strom "],[" Wetter"]]
    2023-07-31 10:18:52.520  - debug: telegram-menu.0 (394412) Array [["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]]
    2023-07-31 10:18:52.521  - debug: telegram-menu.0 (394412) Array [["Home "],[" Pelletsofen"," 3D Drucker"]]
    2023-07-31 10:18:52.521  - debug: telegram-menu.0 (394412) Array [["Home "],[" Aussentemperatur"," Windstärke"," Regen"]]
    2023-07-31 10:18:52.522  - debug: telegram-menu.0 (394412) elementVal [["Licht "],[" Strom "],[" Wetter"]]
    2023-07-31 10:18:52.522  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]]
    2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Pelletsofen"," 3D Drucker"]]
    2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) elementVal [["Home "],[" Aussentemperatur"," Windstärke"," Regen"]]
    2023-07-31 10:18:52.523  - debug: telegram-menu.0 (394412) New Structure: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"}}
    2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action set: [{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}]
    2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action get: [{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}]
    2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action pic: []
    2023-07-31 10:18:52.524  - debug: telegram-menu.0 (394412) action : {"get":[{"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]},{"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]},{"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}],"set":[{"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]},{"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}],"pic":[]}
    2023-07-31 10:18:52.525  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wintergarten Strip"],"IDs":["hue.0.Wintergarten_Strip.on"],"values":["-"],"returnText":["Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Wintergarten Strip"]
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Pelletsofen"],"IDs":["hs100.0.10_0_1_76.state"],"values":["-"],"returnText":["Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Pelletsofen"]
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wohnzimmer Licht"],"IDs":["hue.0.Wohnzimmer.on"],"values":["-"],"returnText":["Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Trigger: ["Wohnzimmer Licht"]
    2023-07-31 10:18:52.526  - debug: telegram-menu.0 (394412) Element set: {"trigger":["Wintergarten Licht"],"IDs":["hue.0.Wintergarten.on"],"values":["-"],"returnText":["Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["Wintergarten Licht"]
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element set: {"trigger":["3D Drucker"],"IDs":["alias.0.EG.Strom.3D-Drucker"],"values":["-"],"returnText":["3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"],"confirm":["true"],"switch_checkbox":["true"]}
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["3D Drucker"]
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Obj set: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"true","returnText":"Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"true","returnText":"Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"true","returnText":"3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]}}
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Aussentemperatur"],"IDs":["0_userdata.0.Wetterstation.Aussentemperatur"],"text":["Aussentemperatur && °C"],"newline_checkbox":["true"]}
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Trigger: ["Aussentemperatur"]
    2023-07-31 10:18:52.527  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Windstärke"],"IDs":["0_userdata.0.Wetterstation.Wind"],"text":["Windstärke && km/h"],"newline_checkbox":["true"]}
    2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Trigger: ["Windstärke"]
    2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Element get: {"trigger":["Regen"],"IDs":["0_userdata.0.Wetterstation.Regen_Tag"],"text":["Regen heute && mm"],"newline_checkbox":["true"]}
    2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Trigger: ["Regen"]
    2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wintergarten_Strip.on"
    2023-07-31 10:18:52.528  - debug: telegram-menu.0 (394412) Subscribe "hs100.0.10_0_1_76.state"
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wohnzimmer.on"
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "hue.0.Wintergarten.on"
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Subscribe "alias.0.EG.Strom.3D-Drucker"
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) SetForeignStates: ["hue.0.Wintergarten_Strip.on","hs100.0.10_0_1_76.state","hue.0.Wohnzimmer.on","hue.0.Wintergarten.on","alias.0.EG.Strom.3D-Drucker"]
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Name "Global"
    2023-07-31 10:18:52.529  - debug: telegram-menu.0 (394412) Array Buttons: [{"call":"Home","value":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},{"call":"Licht","value":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},{"call":"Strom","value":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},{"call":"Wetter","value":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"}]
    2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) Gen. Actions: {"Home":{"nav":[["Licht "],[" Strom "],[" Wetter"]],"text":"Wählen Sie eine Aktion"},"Licht":{"nav":[["Home "],[" Wohnzimmer Licht"," Wintergarten Licht"," Wintergarten Strip"]],"text":"Wähle eine Aktion"},"Strom":{"nav":[["Home "],[" Pelletsofen"," 3D Drucker"]],"text":"Wähle eine Aktion"},"Wetter":{"nav":[["Home "],[" Aussentemperatur"," Windstärke"," Regen"]],"text":"Wähle eine Aktion"},"Wintergarten Strip":{"switch":[{"id":"hue.0.Wintergarten_Strip.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Light Strip ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Pelletsofen":{"switch":[{"id":"hs100.0.10_0_1_76.state","value":"-","toggle":true,"confirm":"true","returnText":"Pelletsofen ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wohnzimmer Licht":{"switch":[{"id":"hue.0.Wohnzimmer.on","value":"-","toggle":true,"confirm":"true","returnText":"Wohnzimmer Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Wintergarten Licht":{"switch":[{"id":"hue.0.Wintergarten.on","value":"-","toggle":true,"confirm":"true","returnText":"Wintergarten Licht ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"3D Drucker":{"switch":[{"id":"alias.0.EG.Strom.3D-Drucker","value":"-","toggle":true,"confirm":"true","returnText":"3D-Drucker ist && change{\"true\":\"ein\", \"false\":\"aus\"}"}]},"Aussentemperatur":{"getData":[{"id":"0_userdata.0.Wetterstation.Aussentemperatur","text":"Aussentemperatur && °C","newline":"true"}]},"Windstärke":{"getData":[{"id":"0_userdata.0.Wetterstation.Wind","text":"Windstärke && km/h","newline":"true"}]},"Regen":{"getData":[{"id":"0_userdata.0.Wetterstation.Regen_Tag","text":"Regen heute && mm","newline":"true"}]}}
    2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) Array [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
    2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) elementVal [["Licht"," Steckdose "],[" Iobroker"," Heizung"]]
    2023-07-31 10:18:52.535  - debug: telegram-menu.0 (394412) New Structure: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action set: []
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action get: []
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action pic: []
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) action : {"get":[],"set":[],"pic":[]}
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Obj set: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) SetForeignStates: []
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Name "Christian"
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Array Buttons: [{"call":"Startseite","value":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}]
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Gen. Actions: {"Startseite":{"nav":[["Licht"," Steckdose "],[" Iobroker"," Heizung"]],"text":"Wähle eine Aktion"}}
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) Checkbox {"checkboxNoValueFound":true,"resKey":true,"oneTiKey":false}
    2023-07-31 10:18:52.536  - debug: telegram-menu.0 (394412) GroupList ["Global","Christian"]
    2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Group "Global"
    2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Send this Value : "Wählen Sie eine Aktion"
    2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Send this to : "Christian"
    2023-07-31 10:18:52.537  - debug: telegram-menu.0 (394412) Group "Christian"
    2023-07-31 10:18:52.538  - debug: telegram-menu.0 (394412) Send this Value : "Wähle eine Aktion"
    2023-07-31 10:18:52.538  - debug: telegram-menu.0 (394412) Send this to : ""
    2023-07-31 10:19:02.772  - debug: telegram-menu.0 (394412) else "hs100.0.10_0_1_76.state"
    2023-07-31 10:19:02.772  - debug: telegram-menu.0 (394412) else undefined
    2023-07-31 10:19:03.056  - debug: telegram-menu.0 (394412) else "alias.0.EG.Strom.3D-Drucker"
    2023-07-31 10:19:03.057  - debug: telegram-menu.0 (394412) else undefined
    ° Fixer ---> iob fix
    Michael RolingM 1 Antwort Letzte Antwort
    • NegaleinN Negalein
      Michael RolingM Offline
      Michael Roling
      #147
      @negalein Leider kann ich so nichts finden! Da scheint auch einiges noch zu fehlen
        @fritzke316 jetzt geht es, musste direkt von github laden
        F Online
        F Online
        fritzke316
        schrieb am zuletzt editiert von fritzke316
        #148
        @michael-roling
        habe nochmal die neueste Version von github geladen, jetzt werden mir die Werte von den Submenus nicht mehr gesetzt und im Log bekomme ich Fehlermeldungen dieser Art beim Betätigen der Navi Buttons:
        backMenu{"Friedrich":{"list":["Startseite","Heizung","Startseite"],"last":"Licht"}}
        backMenu{"Friedrich":{"list":[],"last":"Startseite"}}
        backMenu{"Friedrich":{"list":["Startseite"],"last":"Heizung"}}
        Michael RolingM 2 Antworten Letzte Antwort
        • F fritzke316
          @michael-roling
          Michael Roling
          #149
          @fritzke316 installiere dann die latest 0.4.2 direkt im iobroker.
          F 1 Antwort Letzte Antwort
            F Online
            F Online
            fritzke316
            #150
            @michael-roling
            Wie muss ich da vorgehen? Den Adapter löschen und nochmal installieren?
              Aktuelle Test Version 1.6.x
              Veröffentlichungsdatum 29.05.2023
              Github Link https://github.com/MiRo1310/ioBroker.telegram-menu
              Adapter um ein Telegram Menu zu erstellen.
              Es können verschiedene Benutzer erstellt werden, mit jeweils einem eigenen Menu, oder man erstellt einen Globalen User, bei dem man Benutzern das gleiche Menu geben kann.
              Viel Spaß beim Testen
              flkontaktF Online
              flkontaktF Online
              flkontakt
              #151
              @michael-roling Hallo, auch auf die Gefahr hin, dass ich mich blamiere:
              Bisher habe ich per Script und Telegram gesteuert, möchte gerne deinen Adapter testen. Siehe Bilder, meine ersten Einstellungen. Ich scheitere aber schon am Navigationsmenu, ich kann dies im Adapter anpassen, beim betätigen der Button erfolgt aber keine weitere Navigation.
              Was mache ich hier falsch?
              • flkontaktF flkontakt
                F Online
                F Online
                fritzke316
                #152
                @flkontakt
                ich denke du musst noch ganz oben einen Benutzer für die Gruppe eintragen!
                Ansonsten sieht es doch gut aus :)
                flkontaktF 1 Antwort Letzte Antwort
                • F fritzke316
                  @flkontakt
                  flkontaktF Online
                  flkontaktF Online
                  flkontakt
                  #153
                  @fritzke316 das also zum Thema blamieren............. Das war es natürlich, hätte man drauf kommen können ;-)
                  Jetzt kann ich testen, werde hier sicherlich nochmal mit Fragen aufschlagen.
                  Vielen Dank für die Unterstützung!!!
                    Michael Roling
                    #154
                    @flkontakt Perfekt! Oben der Button ist nur die Gruppe, unten muss der Name rein, wie schon geschehen. Du kannst den Button auch zum Beispiel Gruppe 1 nennen.
                    • F fritzke316
                      @michael-roling
                      Michael Roling
                      #155
                      @fritzke316
                      Du stellst erstmal auf latest repo um und dann kannst du unter adapter au dem rechten plus kästchen die version auswählen. evtl. muss du erst eine version zurück gehen und dann wieder auf die 0.4.2!
                      • F fritzke316
                        @michael-roling
                        Michael Roling
                        #156
                        @fritzke316 die beiden errors sind garkeine errors, ich hatte die vergessen aus dem code zu nehmen🙈🙈🙈
                          @fritzke316
                          F Online
                          F Online
                          fritzke316
                          #157
                          @michael-roling
                          Wenn ich auf das plus Kästchen drücke kommt bei mir keine Versionsauswahl, nur das:
                          • F fritzke316
                            @michael-roling
                            Michael Roling
                            #158
                            @fritzke316 du hast aber umgestellt auf latest?
                              F Online
                              F Online
                              fritzke316
                              #159
                              @michael-roling
                              ja den Hacken bei latest Repository habe ich gesetzt.
                              Habe dann nochmal den Pfeil für "Adapter auf Updates überprüfen" angecklickt, dann hats geklappt.
                              Auch die Werte aus den Submeüs werden jetzt gesetz.
                              Danke für die Hilfe!!
                              • F fritzke316
                                @michael-roling
                                Michael Roling
                                #160
                                @fritzke316 ok. Das liegt dann aber an deinem System. Das kann ich nicht beeinflussen.
                                Welches Menu lässt sich denn nicht mehr anzeigen?
                                  F Online
                                  F Online
                                  fritzke316
                                  #161
                                  @michael-roling
                                  Sorry habe meinen post von vorher nochmal editiert, da ich die Lösung gefunden habe, war nur etwas zu langsam :))
                                  • F fritzke316
                                    @michael-roling
                                    Michael Roling
                                    #162
                                    @fritzke316 also geht wieder alles?
                                      F Online
                                      F Online
                                      fritzke316
                                      #163
                                      @michael-roling
                                      Ja soweit alles Super 👍
                                      Danke nochmal für die Hilfe
                                      • F fritzke316
                                        @michael-roling
                                        Michael Roling
                                        #164
                                        @fritzke316 Nutz du denn noch das menu:back?
                                          F Online
                                          F Online
                                          fritzke316
                                          #165
                                          @michael-roling
                                          Nein habe ich noch nicht in Verwendung wollte ich aber noch testen
