  4. Virtual Devices
Virtual Devices
48 Beiträge 21 Kommentatoren 26.9k Aufrufe 11 Beobachtet
  • blauholstenB
    blauholstenB
    blauholsten
    @apollon77:
    So als Mini-Off-Topic-Tipp: Adater js2fs … der legt alle Skripte als Files auf dem Rechner ab wo der Adapter läuft und überwacht dann alle Änderungen und hält so alles in beide Richtungen immer aktuell. ich nehme inzwischen nur noch das um Skripte zu editieren.
    Damit ist ein "Global File Search&Replace" mega einfach :-)) `
    wollte ich gerade mal ausprobieren! Ging leider nicht,,,
    host.iobrokerDEV	2017-09-26 20:18:41.295	error	instance system.adapter.js2fs.0 terminated with code 0 (OK)
    Caught	2017-09-26 20:18:41.295	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:668:15
    Caught	2017-09-26 20:18:41.295	error	by controller[0]: at Files.readDir (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:462:48)
    Caught	2017-09-26 20:18:41.295	error	by controller[0]: at Array.forEach ()
    Caught	2017-09-26 20:18:41.295	error	by controller[0]: at forEach (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:466:29)
    Caught	2017-09-26 20:18:41.294	error	by controller[0]: at forEach (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:465:30)
    Caught	2017-09-26 20:18:41.294	error	by controller[0]: TypeError: stat.isDirectory is not a function
    js2fs.0	2017-09-26 20:18:41.281	error	at /opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:668:15
    js2fs.0	2017-09-26 20:18:41.281	error	at Files.readDir (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:462:48)
    js2fs.0	2017-09-26 20:18:41.281	error	at Array.forEach ()
    js2fs.0	2017-09-26 20:18:41.281	error	at forEach (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:466:29)
    js2fs.0	2017-09-26 20:18:41.281	error	at forEach (/opt/iobroker/node_modules/iobroker.js2fs/js2fs.js:465:30)
    js2fs.0	2017-09-26 20:18:41.281	error	TypeError: stat.isDirectory is not a function
    js2fs.0	2017-09-26 20:18:41.281	error	uncaught exception: stat.isDirectory is not a function
    js2fs.0	2017-09-26 20:18:41.208	info	starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.js2fs, node: v8.5.0
    - Alarm Adapter
    • P
      P
      Pman
      Ein weiteres Problem stellten für mich Datenpunkte dar, welche immer nur auf TRUE gesetzt werden, nie auf FALSE. Beispiel wäre hier der Homematic Klingelsensor. Sobald jemand klingelt, wird der Datenpunkt auf TRUE gesetzt und bleibt dann TRUE. Dass jemand klingelt erkennt man überhaupt nur daran, dass er erneut auf TRUE gesetzt wird.
      Mit diesem VirtualDevice setze ich den Wert 30 Sekunden später wieder auf False:
      TRUE/TRUE zu TRUE/FALSE:
      new VirtualDevice({
          namespace: 'Sensoren.Tueren',
          states: {
              'value': {
                  common: {type: 'boolean', def: false, read: true, write: false},
                  read: {
                      'hm-rpc.0.MEQ123456.1.PRESS_SHORT': {
                          before: function (device, value, callback) {
                              if (!device.init) { //do not set to true on init
                                  device.init = true;
                                  return;
                              callback();
                          after: function (device, value) {
                              if (value) {
                                  setStateDelayed(device.namespace + '.value', false, true, 30000, true);
              'reachable': {
                  read: {
                      'hm-rpc.0.MEQ123456.0.UNREACH': {
                          convert: function(val) {
                              return !val;
              'lowBat': {
                  read: {
                      'hm-rpc.0.MEQ123456.0.LOWBAT': {},
      • AlCalzoneA
        AlCalzoneA
        AlCalzone
        @Pman:
        Dass jemand klingelt erkennt man überhaupt nur daran, dass er erneut auf TRUE gesetzt wird. `
        state.lc (last change) wäre noch eine Möglichkeit es zu erkennen.
        • P
          P
          Pman
          @AlCalzone:
          @Pman:
          Dass jemand klingelt erkennt man überhaupt nur daran, dass er erneut auf TRUE gesetzt wird. state.lc (last change) wäre noch eine Möglichkeit es zu erkennen.
          Das stimmt, es gibt noch ein paar versteckte Möglichkeiten, allerdings finde ich es in VIS deutlich einfacher einen Wechsel von false auf true zu visualisieren. In FLOT ist es je nach Darstellung auch von Vorteil.
          • P
            P
            Pman
            Ich habe den Lampen-Zähler erweitert zu einem Lampen-Gruppierungs-Gerät. Man kann alle enthaltenen Lampen gleichzeitig ein- oder ausschalten sowie Dimmen. Der Dimmer ist dabei "smart", also dimmt nur alle bereits eingeschaltete Lampen und orientiert sich an der Lampe, mit dem höchsten level. Beispiel: Lampe 1: 20%, Lampe 2: 40% -> Gruppenlevel: 40%. Level wird auf 80% gestellt: Lampe1 -> 40%, Lampe2 -> 80%. Das Verhältnis der Helligkeiten bleibt also gegeben. So kann ich einen Raum mit mehreren Lampen insgesamt heller bekommen und dabei die eingestellten Lichtverhältnisse bewahren.
            * Level (0-100) and Switch (true/false) states supported
            * usage: new VirtualLampGroup('Name', ['LampId1.level','LampId2.level','LampId3.on'])
            function VirtualLampGroup(name, states) {
                "use strict";
                var config = {
                    namespace: 'Lamp.Group',
                    onCreate: function (device, callback) {
                        device.levels = {};
                        device.counter = {init: true};
                        callback();
                    states: {
                        'on': {
                            common: {type: 'number', min: 0, def: 0, read: true, write: false, unit: 'Lamps'},
                            read: {}
                        'off': {
                        'allOffSwitch': {
                            common: {type: 'boolean', def: false, read: true, write: true},
                            write: {}
                        'level': {
                            common: {type: 'number', def: 0, min: 0, max: 100, read: true, write: true, unit: '%'},
                            read: {},
                            write: {}
                for (var i = 0; i < states.length; i++) {
                    let state = states[i];
                    config.states.on.read[state] = {
                            if (value > 0 && !device.counter[state]) {
                                device.counter[state] = true;
                                setState(device.namespace + '.off', Object.keys(device.config.states.on.read).length - Object.keys(device.counter).length, true);
                                callback(Object.keys(device.counter).length);
                            } else if (value <= 0 && (device.counter[state] || device.counter.init)) {
                                delete device.counter[state];
                                delete device.counter.init;
                            if (value) {
                                setState(device.namespace + '.allOffSwitch', true, true);
                            else {
                                setState(device.namespace + '.allOffSwitch', false, true);
                    config.states.allOffSwitch.write[state] = {
                            if (typeof getState(state).val === 'number') {
                                value ? callback(100) : callback(0);
                                return;
                            callback(value);
                    config.states.level.read[state] = {
                            if (typeof getState(state).val !== 'number') {
                                return;
                            device.levels[state] = value;
                            var newLevel = Math.max.apply(null, Object.keys(device.levels).map(function (key) {
                                return device.levels[key];
                            if (!getState(device.namespace + '.level').ack || newLevel !== getState(device.namespace + '.level').val) {
                                callback(newLevel);
                    config.states.level.write[state] = {
                                return;
                            var newLevel;
                            if (Math.max.apply(null, Object.keys(device.levels).map(function (key) {
                                })) === 0) {
                                newLevel = value;
                            } else {
                                newLevel = Math.ceil(getState(state).val * value / Math.max.apply(null, Object.keys(device.levels).map(function (key) {
                            if (newLevel !== getState(state).val) {
                                callback(newLevel);
                return new VirtualDevice(config);
            }`[/i]
            • M
              M
              maniac
              Hi.
              Ich wollte das Script auf meine Bedürfnisse anpassen und habe dies so gemacht.
              new VirtualDevice({
                  namespace: 'Lampen',
                  name: 'Esszimmer', //das Gerät wird unter javascript.0.virtualDevice.Hue.Wohnzimmer erstellt
                  states: {
                      //welche States sollen erstellt werden?
                      'level': {
                          //State Konfiguration
                          read: {
                              //von welchen States sollen Werte eingelesen werden?
                              'tradfri.0.L-65539.lightbulb.brightness': {
                                  convert: function (val) { //wert soll konvertiert werden
                                      return Math.floor(val * 100 / 254);
                              'tradfri.0.L-65540.lightbulb.brightness': {
                          write: {
                              //in welche States sollen Werte geschrieben werden?
                                      return Math.ceil(val * 254 / 100);
                                  delay: 1500 // schreibe Werte erst nach 1,5 Sekunden in den Adapter (Puffer)
              Allerdings bekomme ich das Script nicht zum laufen, auch werden keine Datenpunkte angelegt.
              Auch wenn ich das Script von oben 1zu1 übernehme bekomme ich diesen Fehler.
              ! javascript.0 2017-10-22 10:08:05.628 error at ContextifyScript.Script.runInContext (vm.js:35:29)
              ! javascript.0 2017-10-22 10:08:05.627 error at script.js.Licht.Virtual.Esszimmer_Lampen:1:5
              ! javascript.0 2017-10-22 10:08:05.626 error ReferenceError: VirtualDevice is not defined
              ! javascript.0 2017-10-22 10:08:05.626 error ^
              ! javascript.0 2017-10-22 10:08:05.625 error new VirtualDevice({
              ! javascript.0 2017-10-22 10:08:05.624 error script.js.Licht.Virtual.Esszimmer_Lampen: script.js.Licht.Virtual.Esszimmer_Lampen:1
              ! javascript.0 2017-10-22 10:08:05.622 info Start javascript script.js.Licht.Virtual.Esszimmer_Lampen
              ! javascript.0 2017-10-22 10:08:03.850 info Stop script script.js.Licht.Virtual.Esszimmer_Lampen
              Gruß Frank…
              • M
                M
                maniac
                Habs gefunden. War wohl noch ein Windows Zeilenumbruch drin. ^ :evil:
                Es wird jetzt ein Gerät "Lampen" angelegt. Aber wie nutze ich das jetzt? Datenpunkte sind nicht vorhanden.
                Edit: Jetzt geht es doch wieder nicht, nachdem ich das Script nochmal gestartet habe. Und auch das Gerät Lampen ist wieder weg.
                Verstehe ich nicht.
                Gruß Frank…
                  Das Skript funktioniert sehr gut.
                  Ich nutze hauptsächlich zwave Devices von Fibaro.
                  Diese steuer ich nicht direkt, sondern habe alle wichtigen States als virtuelle States innerhalb javascript.0 angelegt und synchronisiere diese.
                  Insbesondere für History und Vis finde ich die virtuelle Eben sehr hilfreich.
                  Daraus nun noch virtuelle Devices zu machen ist eine sehr schöne Erweiterung ist schön übersichtlich.
                  Wie binde ich das Skript von @pman am besten ein?
                  Als globales Skript?
                  Wie strukturiert ihr eure Skripte um alle Devices sinnvoll zu verwalten im javascript?
                  Viele kleine Skripte z.B. je Raum, oder lieber alles in ein Skript?
                  • P
                    P
                    Pman
                    @maniac:
                    Auch wenn ich das Script von oben 1zu1 übernehme bekomme ich diesen Fehler. `
                    Ich habe dein Skript bei mir eingefügt und es funktioniert.
                    Du hast glaube ich das Hauptskript aus dem ersten Post (ganz unten) nicht geladen. Du müsstest das entweder noch vor dieses Skript kopieren oder unter "global" einfügen.
                    @nisio:
                    Viele kleine Skripte z.B. je Raum, oder lieber alles in ein Skript? `
                    Hallo, freut mich, dass du das Skript nützlich findest.
                    Ich habe das Skript selber in Global gepackt, was übrigens einfach bedeutet, dass es intern in jedes andere Skript eingefügt wird.
                    Dann habe ich bei den Skripten einen Ordner erstellt "VirtualDevices" und darin dann pro Gewerk ein Skript, also z. B. für Heizung, Lampen, Weiße Ware, usw. .
                    Wenn es sich lohnt habe ich noch eine kleine Hilfsfunktion gebaut, die aus wenigen Datenpunkten das ganze VirtualDevice erstellt. Das lohnt eigentlich immer, wenn man mehrere gleiche Geräte aus gleichen Datenpunkten erstellt. Bei Heizung ist das bei mir der Fall, da ich 7 Homematic Thermostate und Stellantriebe je gemeinsam in ein VirtualDevice gepackt habe. Das Heizungs-VirtualDevice macht übrigens das Modusumschalten bei Homematic Thermostaten sehr viel einfacher. So sieht dann bei mir das Skript Heizung aus:
                    function virtualHomematicThermostat(name, thermostatId, valveId) {
                        var config = {
                            namespace: 'Heizung',
                            states: {
                                'reachable': {
                                    read: {
                                        [thermostatId + '.0.UNREACH']: {
                                            convert: function(value) {
                                                return !value;
                                'reachableValve': {
                                    read: {
                                        [valveId + '.0.UNREACH']: {
                                                return !value;
                                'lowBat': {
                                    read: {
                                        [thermostatId + '.0.LOWBAT']: {},
                                'lowBatValve': {
                                    read: {
                                        [valveId + '.0.LOWBAT']: {},
                                'temperature': {
                                    common: {
                                        "type": "number",
                                        "unit": "°C",
                                        "def": 0,
                                        "min": -10,
                                        "max": 50,
                                        "read": true,
                                        "write": false
                                    read: {
                                        [thermostatId + '.1.TEMPERATURE']: {},
                                'humidity': {
                                    common: {
                                        "type": "number",
                                        "unit": "%",
                                        "def": 0,
                                        "min": 0,
                                        "max": 99,
                                        "read": true,
                                        "write": false
                                    read: {
                                        [thermostatId + '.1.HUMIDITY']: {},
                                'temperatureSet': {
                                    common: {
                                        "type": "number",
                                        "unit": "°C",
                                        "def": 20,
                                        "min": 4.5,
                                        "max": 30.5,
                                        "read": true,
                                        "write": true
                                    read: {
                                        [thermostatId + '.2.SET_TEMPERATURE']: {},
                                    write: {
                                            delay: 1500
                                'valve': {
                                    common: {
                                        "def": 0,
                                        "type": "number",
                                        "read": true,
                                        "write": false,
                                        "min": 0,
                                        "max": 99,
                                        "unit": "%",
                                    read: {
                                        [valveId + '.4.VALVE_STATE']: {},
                                'mode': {
                                    common: {
                                        "def": 0,
                                        "type": "number",
                                        "read": true,
                                        "write": true,
                                        "min": 0,
                                        "max": 1,
                                        "states": {
                                          "0": "AUTO-MODE",
                                          "1": "MANU-MODE",
                                    read: {
                                        [thermostatId + '.2.CONTROL_MODE']: {},
                                    write: {
                                        [thermostatId + '.2.AUTO_MODE']: {
                                            delay: 1500,
                                                if (value !== 0){
                                                    clearStateDelayed(thermostatId + '.2.AUTO_MODE');
                                                    return;
                                                callback(true);
                                        [thermostatId + '.2.MANU_MODE']: {
                                            delay: 1500,
                                                if (value !== 1){
                                                    clearStateDelayed(thermostatId + '.2.MANU_MODE');
                                                    return;
                                                callback(getState(thermostatId + '.2.SET_TEMPERATURE').val);
                        if (!valveId) {
                            delete config.states.lowBatValve;
                            delete config.states.reachableValve;
                            delete config.states.valve;
                    //Wohnzimmer
                    new virtualHomematicThermostat('Wohnzimmer', 'hm-rpc.0.LEQ1...', 'hm-rpc.0.LEQ2...');
                    //HWR
                    new virtualHomematicThermostat('HWR', 'hm-rpc.0.MEQ1...', '');
                    //Badezimmer
                    new virtualHomematicThermostat('Badezimmer', 'hm-rpc.0.LEQ3...', 'hm-rpc.0.LEQ4...');
                    //WC
                    new virtualHomematicThermostat('WC', 'hm-rpc.0.LEQ5...', 'hm-rpc.0.MEQ6...');
                    //Arbeitszimmer
                    new virtualHomematicThermostat('Arbeitszimmer', 'hm-rpc.0.LEQ7...', 'hm-rpc.0.MEQ8...');
                    //Gaestezimmer
                    new virtualHomematicThermostat('Gaestezimmer', 'hm-rpc.0.LEQ9...', 'hm-rpc.0.MEQ10...');
                    //Schlafzimmer
                    new virtualHomematicThermostat('Schlafzimmer', 'hm-rpc.0.LEQ11...', 'hm-rpc.0.ME12...');
                    • M
                      M
                      maniac
                      @Pman:
                      @maniac:
                      Du hast glaube ich das Hauptskript aus dem ersten Post (ganz unten) nicht geladen. Du müsstest das entweder noch vor dieses Skript kopieren oder unter "global" einfügen. `
                      Danke, das war es.
                      Gruß Frank…
                        Ich bekomme bei numerischen States immer eine Warning im Log: Wrong type of …: "string". Please fix, while deprecated and will not work in next versions.
                        Ich vermute es muss ein parseFloat() auf den ausgelesenen Value angewendet werden.
                        Wo baue ich das am besten ein in das Skript, damit es automatisch für States vom Type number angewendet wird?
                        • P
                          P
                          Pman
                          Also du möchtest einen numerischen State im VirtualDevice und hast als Eingang einen String? Oder genau umgekehrt?
                          Zur Konvertierung von Werten kann man optional eine Funktion bei jedem read- und write-State angeben. Ich habe im Beispiel beide Fälle abgedeckt.
                          Bei einer einfachen Typenkonvertierung muss es natürlich nicht bleiben, du kannst mit dem Eingangswert alles mögliche anstellen. Ich habe bei mir zum Beispiel Waschmaschine und andere Geräte an einem Strommessgerät und konvertiere Watt in den Zustand der Maschine (aus, standby, waschen, fertig). Es können auch noch zwei weitere Funktion before und after genutzt werden, um verschiedene Aktionen vor bzw. nach dem schreiben der virtuellen States durchzuführen. Bei der Waschmaschine schicke ich mir z. B. mit dem Pushbullet-Adapter eine Nachricht aufs Handy, wenn der Zustand fertig erreicht wird.
                          Beispiel Konvertierung
                          new VirtualDevice({
                              namespace: 'Beispiel',
                              states: {
                                  'string': {
                                      //dieser State ist vom Typ String
                                      common: {type: 'string', def: '', read: true, write: true},
                                      read: {
                                          //eingehende Werte werden zu String konvertiert
                                          'state.number': {
                                                  return val.toString();
                                      //ausgehende Werte werden zu Number konvertiert
                                      write: {
                                          'state.number': {
                                                  return parseFloat(val);
                                  'number': {
                                      //dieser State ist vom Typ Number
                                      common: {type: 'number', def: 0, read: true, write: true},
                                      read: {
                                          'state.string': {
                                              //eingehende Werte werden zu Number konvertiert
                                      write: {
                                          'state.string': {
                                              //ausgehende Werte werden zu String konvertiert
                            Ich habe einen numerischen Wert den ich auf einen virtuellen numerischen State schreibe.
                            Scheinbar liefert getState(…).val auch bei numerischen Werten einen string.
                            Die Lösung mit der convert Angabe läuft bei mir schon und funktioniert auch. Ich will das nur nicht bei allen devices einbauen. Daher suche ich eine zentrale Lösung.
                            Hier ist das Problem auch beschrieben: http://forum.iobroker.net/viewtopic.php?t=6819
                            • P
                              P
                              Pman
                              Dort ging es darum, dass bei Änderungen direkt über Admin der falsche Typ genutzt wurde, was aber auch mittlerweile gefixt sein sollte.
                              Ich kann das verhalten zumindest bei mir so nicht feststellen, vielleicht lohnt eine Suche nach dem Verursacher des falschen Datentyps? Oder du musst noch js-controller oder Admin updaten?
                              Dieser Codeschnipsel
                              log (typeof getState("hm-rpc.0.LEQ0535278.2.POWER").val)
                              liefert:
                              ` > 12:55:48.740 [info] javascript.1 Start javascript script.js.VirtualDevices.test
                              12:55:48.741 [info] javascript.1 script.js.VirtualDevices.test: number `
                              Also geht bei getState nicht der Typ number verloren.
                              Ich kann mir nur vorstellen, dass dein Eingangsstate entweder nicht vom Typ number ist (aber trotzdem eine Zahl, aber eben als String, enthält) oder irgendein Skript/Adapter in den korrekten number State trotzdem einen String schreibt.
                              Als temporären Fix könntest du das Skript so ändern, die mittlere Zeile ist neu, die anderen beiden findest du im Skript (ungetestet!):
                              if (newDelay !== undefined && newDelay !== null) writeObj.delay = newDelay;
                              if (this.config.states[state].common.type === 'number') newVal = parseFloat(newVal);
                              log(newVal + 'writing value ' + val + ' to ' + writeId + ' with delay ' + writeObj.delay, 'debug');
                              • AlCalzoneA
                                AlCalzoneA
                                AlCalzone
                                Der Fehler > Wrong type of …: "string". Please fix, while deprecated and will not work in next versions. tritt auf, wenn in einen State der nicht vom typ "string" ist, ein string geschrieben wird, woher auch immer. Analog für andere Datentypen (number => nicht-number, boolean => nicht-boolean, etc…).
                                Mit Lesen hat das wenn nur indirekt zu tun.
                                  Ich verwende zwave Sensoren.
                                  Das auslesen des Temperaturwertes ist angeblich ein string:
                                  log (typeof getState("zwave.0.NODE17.SENSOR_MULTILEVEL.Temperature_1").val);
                                  20:39:38.999	[info]	javascript.0 Start javascript script.js.test.dummy
                                  20:39:38.999	[info]	javascript.0 script.js.test.dummy: string
                                  Der Sensor ist ein "FIBARO System FGMS001-ZW5 Motion Sensor":
                                    "common": {
                                      "name": "Temperature",
                                      "type": "number",
                                      "role": "value.temperature",
                                      "read": true,
                                      "write": false
                                    "native": {
                                      "value_id": "17-49-1-1",
                                      "type": "decimal",
                                      "genre": "user",
                                      "label": "Temperature",
                                      "units": "C",
                                      "help": "",
                                      "node_id": 17,
                                      "class_id": 49,
                                      "instance": 1,
                                      "index": 1,
                                      "min": 0,
                                      "max": 0,
                                      "read_only": true,
                                      "write_only": false,
                                      "is_polled": false
                                    "acl": {
                                      "object": 1636,
                                      "owner": "system.user.admin",
                                      "state": 1636
                                    "_id": "zwave.0.NODE17.SENSOR_MULTILEVEL.Temperature_1",
                                    "type": "state"
                                  Alle Adapter sind aktuell:
                                  ioBroker.zwave: 0.8.0
                                  ioBroker.javascript; 3.4.0
                                  ioBroker.js-controller: 1.1.3
                                  • P
                                    P
                                    Pman
                                    Dann wird der Fehler im ZWave Adapter liegen, der Strings reinschreibt, statt Number.
                                      Denke auch an einen Bug im zwave Adapter.
                                      Hab mal ein Topic eröffnet dazu mit ein paar mehr Details:
                                      http://forum.iobroker.net/viewtopic.php?f=22&t=8718
                                      • modmaxM
                                        modmaxM
                                        modmax
                                        Da ich das gleiche Problem hatte (da mir gerade wieder ein Fensterkontakt gecrasht ist),
                                        hab ich nun die Sensoren und Schalter in virtuelle Devices verpackt.
                                        Jedoch hab ich das Skript "VirtualDevice" noch ergänzt, um ggfs. einen eigenes common/native-Gespann ins Device zu bringen.
                                        ! var obj; if (typeof this.config.copy == 'string') { obj = getObject(this.config.copy); } else if (typeof this.config.copy == 'object') { obj = this.config.copy; } else { obj = {common: {}, native: {}}; } !
                                        Für meine Homematic-Schalter nutze ich folgendes Skript:
                                        // virtuelle HM-Schalter
                                        new virtualHomematicSwitch('Wohnzimmer_Lampe', 'hm-rpc.0.ABC1234567');
                                        // virtuelle HM-IP-Schalter
                                        new virtualHomematicIpSwitch('Schlafzimmer_Lampe', 'hm-rpc.1.CBA7654321', 4);
                                        ! function virtualHomematicSwitch(name, deviceId) {
                                        var config = {
                                        namespace: 'Schalter',
                                        copy: {common: {"name":name,"role":"switch"}, native: {}},
                                        states: {
                                        'unreachable': {
                                        common: {type: 'boolean', def: false, read: true, write: false, name: name+'.unreachable', role: 'indicator.unreach'},
                                        read: {
                                        [deviceId + '.0.UNREACH']: {}
                                        'lowBat': {
                                        common: {type: 'boolean', def: false, read: true, write: false, name: name+'.lowBat', role: 'indicator.battery'},
                                        read: {
                                        [deviceId + '.0.LOWBAT']: {}
                                        'dutyCycle': {
                                        common: {type: 'boolean', def: false, read: true, write: false, name: name+'.dutyCycle', role: 'value'},
                                        read: {
                                        [deviceId + '.0.DUTYCYCLE']: {}
                                        'working': {
                                        common: {type: 'boolean', def: false, read: true, write: false, name: name+'.working', role: 'indicator.working'},
                                        read: {
                                        [deviceId + '.1.WORKING']: {}
                                        'state': {
                                        common: {type: 'boolean', def: false, read: true, write: true, name: name+'.state', role: 'state'},
                                        read: {
                                        [deviceId + '.1.STATE']: {}
                                        write: {
                                        ! function virtualHomematicIpSwitch(name, deviceId, switchState) {
                                        var config = {
                                        states: {
                                        'unreachable': {
                                        read: {
                                        'lowBat': {
                                        'dutyCycle': {
                                        read: {
                                        [deviceId + '.0.DUTY_CYCLE']: {}
                                        'working': {
                                        'state': {
                                        read: {
                                        [deviceId + '.' + switchState + '.STATE']: {}
                                        write: {
                                        Und für die Sensoren folgendes Skript:
                                        ! // Homematic Tür/Fenster Sensoren new virtualHomematicShutterContact('Wohnzimmer_Fenster', 'hm-rpc.0.ABC1234567'); // Homematic Drehgriffkontakte new virtualHomematicRotaryHandleSensor('Schlafzimmer_Fenster', 'hm-rpc.0.CBA7654321'); ! // ----------------- ! function virtualHomematicShutterContact(name, deviceId) { var config = { namespace: 'Sensor', name: name, copy: {common: {"name":name,"role":"sensor"}, native: {}}, states: { 'unreachable': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.unreachable', role: 'indicator.unreach'}, read: { [deviceId + '.0.UNREACH']: {} } }, 'lowBat': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.lowBat', role: 'indicator.battery'}, read: { [deviceId + '.0.LOWBAT']: {} } }, 'state': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.state', role: 'state'}, read: { [deviceId + '.1.STATE']: {} } } } } return new VirtualDevice(config); } ! function virtualHomematicRotaryHandleSensor(name, deviceId) { var config = { namespace: 'Sensor', name: name, copy: {common: {"name":name,"role":"sensor"}, native: {}}, states: { 'unreachable': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.unreachable', role: 'indicator.unreach'}, read: { [deviceId + '.0.UNREACH']: {} } }, 'lowBat': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.lowBat', role: 'indicator.battery'}, read: { [deviceId + '.0.LOWBAT']: {} } }, 'state': { common: {type: 'boolean', def: false, read: true, write: false, name: name+'.state', role: 'state'}, read: { [deviceId + '.1.STATE']: { convert: function(value) { return value !== 0; } } } ! }, 'handle': { common: {type: 'number', def: 0, read: true, write: false, states: {0: 'closed', 1: 'tilted', 2: 'open'}, name: name+'.handle', role: 'state'}, read: { [deviceId + '.1.STATE']: {} } } } } return new VirtualDevice(config); } !
                                        Für die HUE-Lampen habe ich das Skripot modifiziert, da ich zu jeder HUE-Lampe einen CUxD-Switch habe.
                                        Hier wolten ich sowohl über Alexa, als auch HueApp, als auch ioBroker, als auch CUxD-Schalter
                                        die komplette Synchronisation übernehmen; so daß alles per ioBroker synchronisiert wird.
                                        // Hue-Lampen verknüft mit CUxD-Schalter
                                        new virtualHueLamp("hue.0.hue_bridge.Stehlampe", "hm-rpc.2.CUX4001110.1.STATE");
                                        ! function virtualHueLamp(lampId, switchId) {
                                        var lampObj = getObject(lampId);
                                        var lampName = lampObj.common.name.split('.').splice(-1)[0];
                                        var config = {
                                            namespace: 'Hue',
                                            copy: {common: {"name":lampName,"role":lampObj.common.role}, native: {type: lampObj.native.type, model: lampObj.native.modelid}},
                                            states: {
                                                'unreachable': {
                                                    common: {type: 'boolean', def: false, read: true, write: false, name: lampName+'.unreachable', role: 'indicator.unreach'},
                                                    read: {
                                                        [lampId + '.reachable']: {
        return !value;
                                                'level': {
                                                    common: {type: 'number', def: 0, min: 0, max: 100, read: true, write: true, unit: '%', name: lampName+'.level', role: 'level.dimmer'},
                                                    read: {
                                                        [lampId + '.bri']: {
        return Math.floor(value*100/254);
        if (value > 0) {
        setState(device.namespace+'.lastLevel', value, true);
        callback();
                                                    write: {
        return Math.ceil(val*254/100);
                                                            delay: 800
                                                'lastLevel': {
                                                    common: {type: 'number', def: 100, min: 0, max: 100, read: true, write: false, unit: '%', name: lampName+'.lastLevel', role: 'value'},
                                                    read: {}
                                                'command': {
                                                    common: {type: 'string', def: '', read: true, write: true, name: lampName+'.command', role: 'command'},
                                                    write: {
                                                        [lampId + '.command']: {
                                                            delay: 800
                                        if (switchId) {
                                            config.states['switch'] = {
                                                common: {type: 'boolean', def: false, read: true, write: false, name: lampName+'.switch', role: 'state'},
                                                read: {
                                                    [switchId]: {
                                                            var level = getState(device.namespace + '.level').val;
                                                            if (value === false && level > 0) {
        setState(device.namespace + '.level', 0);
                                                            } else if (value === true && level <= 0) {
        var lastLevel = getState(device.namespace + '.lastLevel').val;
        setState(device.namespace + '.level', lastLevel);
                                        ! config.states.level.read[lampId + '.bri'].after = function (device, value) {
                                        if (value > 0 && getState(switchId).val === false) {
                                        setStateDelayed(switchId, true, 200);
                                        } else if (value <= 0) {
                                        setStateDelayed(switchId, false, 200);
                                        ! config.states.command.write[lampId + '.command'].before = function (device, value, callback) {
                                        var parsed;
                                        try{
                                        parsed = JSON.parse(value);
                                        } catch(e) {
                                        return;
                                        if (parsed.level > 0 && getState(switchId).val === false) {
                                        //if switch is off and level is greater 0 turn on switch
                                        setStateDelayed(switchId, true, false, 800, true, function(){
                                        callback(value, 3500);
                                        } else if (parsed.level <= 0){
                                        //if level is set to 0 turn off switch and set level 0
                                        setStateDelayed(switchId, false, false, 800, true, function(){
                                        callback(null, 0);
                                        } else {
                                        callback();
                                        if (lampObj.native && lampObj.native.type === 'Color temperature light' || lampObj.native.type === 'Extended color light') {
                                            config.states.ct = {
                                                common: {min: 2000, max: 6500, unit: 'K', step: 10, name: lampName+'.ct', role: 'level.color.temperature'},
                                                read: {
                                                    [lampId + '.ct']: {
                                                            return Math.max(2000, Math.min(6500, Math.round(Math.pow(10,6)/val)));
                                                write: {
                                                    [lampId + '.ct']: {
                                                            return Math.max(153, Math.min(500, Math.round(Math.pow(10,6)/val)));
                                                        delay: 1500
                                        if (lampObj.native && lampObj.native.type === 'Color light' || lampObj.native.type === 'Extended color light') {
                                            config.states.xy = {
                                                common: {read: true, write: true, type: "string", name: lampName+'.xy', role: 'level.color.xy'},
                                                read: {
                                                    [lampId + '.xy']: {}
                                                write: {
                                                    [lampId + '.xy']: {
                                                        delay: 800
                                        Vielleicht gibt es noch weitere Ideen.
                                          Ich habe das Skript jetzt seit einiger Zeit sehr erfolgreich im Einsatz.
                                          Wie geht es nun weiter?
                                          Plant jemand einen Adapter daraus zu erstellen?
                                          Oder den Adapter ioBroker.wrapper damit zu ergänzen?
                                          Oder gleich in ioBroker als zentrale Funktion aufnehmen?
                                          Ich habe bislang keine Erfahrung mit der Adapter Entwicklung, würde mich aber beteiligen.
                                          33.2k
                                          84.3k
