  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Iob neu auf Synology VM - Datenpunkte leer
    5.1k
57 Beiträge 6 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • N Njdfg
    Hier sind mehrere Fehlermeldungen im Syslog, hat das damit evtl. zu tun?
    2023-07-24 17:52:23,817 io.vertx.core.impl.ContextImpl ERROR [vert.x-worker-thread-6] Unhandled exception
    de.eq3.cbcs.legacy.communication.rpc.RpcIOException: java.net.ConnectException: Connection refused (Connection refused)
    	at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:110) ~[HMIPServer.jar:?]
    	at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.sendRequest(RpcClient.java:94) ~[HMIPServer.jar:?]
    	at de.eq3.cbcs.legacy.communication.rpc.internal.rpc.RpcClient.invoke(RpcClient.java:82) ~[HMIPServer.jar:?]
    	at com.sun.proxy.$Proxy40.event(Unknown Source) ~[?:?]
    	at de.eq3.ccu.virtualdevice.service.internal.rega.vertx.RegaClientWorker.handleEvent(RegaClientWorker.java:73) ~[HMIPServer.jar:?]
    	at de.eq3.ccu.virtualdevice.service.internal.rega.vertx.RegaClientWorker.access$000(RegaClientWorker.java:13) ~[HMIPServer.jar:?]
    	at de.eq3.ccu.virtualdevice.service.internal.rega.vertx.RegaClientWorker$1.handle(RegaClientWorker.java:35) ~[HMIPServer.jar:?]
    	at de.eq3.ccu.virtualdevice.service.internal.rega.vertx.RegaClientWorker$1.handle(RegaClientWorker.java:26) ~[HMIPServer.jar:?]
    	at io.vertx.core.impl.AbstractContext.dispatch(AbstractContext.java:100) ~[HMIPServer.jar:?]
    	at io.vertx.core.impl.WorkerContext.lambda$emit$0(WorkerContext.java:59) ~[HMIPServer.jar:?]
    	at io.vertx.core.impl.WorkerContext.lambda$execute$2(WorkerContext.java:104) ~[HMIPServer.jar:?]
    	at io.vertx.core.impl.TaskQueue.run(TaskQueue.java:76) ~[HMIPServer.jar:?]
    	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_372]
    	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_372]
    	at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) ~[HMIPServer.jar:?]
    	at java.lang.Thread.run(Thread.java:750) ~[?:1.8.0_372]
    Caused by: java.net.ConnectException: Connection refused (Connection refused)
    	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_372]
    	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_372]
    	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_372]
    	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_372]
    	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_372]
    	at java.net.Socket.connect(Socket.java:613) ~[?:1.8.0_372]
    	at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:120) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:179) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:144) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:134) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:612) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:447) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:884) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:107) ~[HMIPServer.jar:?]
    	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:55) ~[HMIPServer.jar:?]
    	at de.eq3.cbcs.legacy.communication.rpc.internal.transport.http.HttpTransport.sendRequest(HttpTransport.java:106) ~[HMIPServer.jar:?]
    	... 15 more
    F Online
    F Online
    fastfoot
    schrieb am zuletzt editiert von fastfoot
    @njdfg es gibt da gerade ein issue mit hm-rpc, mW aber mit Node20. Dennoch könntest du mal probieren Sentry in der GUI abzuschalten, in den Instanzen beim Adapter das grüne Dreieck klicken, wird dann grau und der Adapter startet neu. Ist ja nur ein Klick und einen Versuch wert
    Edit: dazu muss in den Expertenmodus gewechselt werden, sonst sieht man das Dreieck gar nicht
    N 1 Antwort Letzte Antwort
      @njdfg hab da keine Ahnung von.
      hab zwar so etwas inder Art erwartet
      @njdfg sagte in Iob neu auf Synology VM - Datenpunkte leer:
      aber nicht als error aus den Tiefen von Java, sondern mehr in Klartext mit IP und Hostnamen
      N Offline
      N Offline
      Njdfg
      Hier das iob diag Ergebnis:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : microsoft
      Distributor ID: Ubuntu
      Description:    Ubuntu 22.04.2 LTS
      Release:        22.04
      Codename:       jammy
      PRETTY_NAME="Ubuntu 22.04.2 LTS"
      NAME="Ubuntu"
      VERSION_ID="22.04"
      VERSION="22.04.2 LTS (Jammy Jellyfish)"
      VERSION_CODENAME=jammy
      ID=ubuntu
      ID_LIKE=debian
      HOME_URL="https://www.ubuntu.com/"
      SUPPORT_URL="https://help.ubuntu.com/"
      BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
      PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
      UBUNTU_CODENAME=jammy
      Systemuptime and Load:
       18:11:52 up  3:57,  2 users,  load average: 0.02, 0.12, 0.17
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Mon 2023-07-24 18:11:52 CEST
                 Universal time: Mon 2023-07-24 16:11:52 UTC
                       RTC time: Mon 2023-07-24 16:11:52
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            5.9G        2.3G        3.1G        1.0M        540M        3.4G
      Swap:           2.0G          0B        2.0G
      Total:          8.0G        2.3G        5.2G
               5921 M total memory
               2264 M used memory
                197 M active memory
               2315 M inactive memory
               3116 M free memory
                 58 M buffer memory
                481 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      Filesystem                        Type   Size  Used Avail Use% Mounted on
      tmpfs                             tmpfs  593M  1.1M  592M   1% /run
      /dev/mapper/ubuntu--vg-ubuntu--lv ext4    12G  7.2G  3.5G  68% /
      tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
      tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
      /dev/sda2                         ext4   2.0G  130M  1.7G   8% /boot
      tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/0
      [Mon Jul 24 14:14:37 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Mon Jul 24 14:14:38 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
      [Mon Jul 24 14:14:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      TARGET              SOURCE                            FSTYPE   OPTIONS
      /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
      |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/1822 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/lxd/24322   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/18357 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
      |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
      `-/boot             /dev/sda2                         ext4     rw,relatime
      /var:
      889M    /var/
      539M    /var/lib
      343M    /var/lib/snapd
      342M    /var/lib/snapd/snaps
      249M    /var/cache
      Archived and active journals take up 88.0M in the file system.
      /opt/iobroker/backups:
      48M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      325M    /opt/iobroker/iobroker-data/
      221M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/backup-objects
      51M     /opt/iobroker/iobroker-data/files/javascript.admin
      43M     /opt/iobroker/iobroker-data/files/iot.admin
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/states.jsonl
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.17.0
      /usr/bin/node           v18.17.0
      /usr/bin/npm            9.6.7
      /usr/bin/npx            9.6.7
      nodejs:
        Installed: 18.17.0-deb-1nodesource1
        Candidate: 18.17.0-deb-1nodesource1
        Version table:
       *** 18.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.8
      admin:          6.6.1
      javascript:     7.1.1
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : ubunto-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ubunto-iobroker                          -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : ubunto-iobroker                          -  enabled
      + system.adapter.backitup.0               : backitup              : ubunto-iobroker                          -  enabled
      + system.adapter.bring.0                  : bring                 : ubunto-iobroker                          -  enabled
      + system.adapter.cloud.0                  : cloud                 : ubunto-iobroker                          -  enabled
      + system.adapter.discovery.0              : discovery             : ubunto-iobroker                          -  enabled
        system.adapter.dwd.0                    : dwd                   : ubunto-iobroker                          -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : ubunto-iobroker                          -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : ubunto-iobroker                          -  enabled
      + system.adapter.harmony.0                : harmony               : ubunto-iobroker                          -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ubunto-iobroker                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ubunto-iobroker                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ubunto-iobroker                          -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : ubunto-iobroker                          -  enabled
      + system.adapter.hyperion_ng.0            : hyperion_ng           : ubunto-iobroker                          -  enabled
        system.adapter.ical.0                   : ical                  : ubunto-iobroker                          -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : ubunto-iobroker                          -  enabled
      + system.adapter.info.0                   : info                  : ubunto-iobroker                          -  enabled
      + system.adapter.iot.0                    : iot                   : ubunto-iobroker                          -  enabled
      + system.adapter.javascript.0             : javascript            : ubunto-iobroker                          -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : ubunto-iobroker                          -  enabled
        system.adapter.luftdaten.0              : luftdaten             : ubunto-iobroker                          -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ubunto-iobroker                          -  enabled, port: 54321
      + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ubunto-iobroker                          -  enabled, port: 16021
      + system.adapter.pollenflug.0             : pollenflug            : ubunto-iobroker                          -  enabled
      + system.adapter.sonoff.0                 : sonoff                : ubunto-iobroker                          -  enabled, port: 1883, bind: 192.168.123.95
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ubunto-iobroker                          -  enabled
      + system.adapter.telegram.0               : telegram              : ubunto-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : ubunto-iobroker                          -  enabled
      + system.adapter.tr-064.0                 : tr-064                : ubunto-iobroker                          -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ubunto-iobroker                          -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ubunto-iobroker                          -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubunto-iobroker                          -  enabled
        system.adapter.vis-metro.0              : vis-metro             : ubunto-iobroker                          -  enabled
        system.adapter.vis.0                    : vis                   : ubunto-iobroker                          - disabled
      + system.adapter.web.0                    : web                   : ubunto-iobroker                          -  enabled, port: 8082, bind: 192.168.123.95, run as: admin
      + system.adapter.worx.0                   : worx                  : ubunto-iobroker                          -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.6.1    , installed 6.6.1
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "awtrix-light" : 0.5.1    , installed 0.5.1
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "bring"        : 1.8.1    , installed 1.8.1
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "discovery"    : 3.2.0    , installed 3.2.0
      Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "harmony"      : 1.2.2    , installed 1.2.2
      Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
      Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "hyperion_ng"  : 0.1.23   , installed 0.1.23
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.1    , installed 7.1.1
      Controller "js-controller": 5.0.8    , installed 5.0.8
      Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
      Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
      Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
      Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "socketio"     : 6.4.0    , installed 6.4.0
      Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "web"          : 5.5.3    , installed 5.5.3
      Adapter    "worx"         : 2.3.2    , installed 2.3.2
      Adapter    "ws"           : 2.4.0    , installed 2.4.0
      Objects and States
      Objects:        13450
      States:         10882
      Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
      Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18881      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20227      742/sshd: /usr/sbin
      tcp        0      0 192.168.123.95:8082     0.0.0.0:*               LISTEN      1001       24742      1337/io.web.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20365      691/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22003      691/iobroker.js-con
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        19941      672/systemd-resolve
      tcp        0      0 192.168.123.95:2010     0.0.0.0:*               LISTEN      1001       63257      3242/io.hm-rpc.1
      tcp        0      0 192.168.123.95:2001     0.0.0.0:*               LISTEN      1001       66456      3374/io.hm-rpc.0
      tcp        0      0 192.168.123.95:1883     0.0.0.0:*               LISTEN      1001       22975      1063/io.sonoff.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       24041      1185/io.harmony.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          18883      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20247      742/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22663      921/io.admin.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        19940      672/systemd-resolve
      udp        0      0 192.168.123.95:68       0.0.0.0:*                           101        19921      670/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18882      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       23676      1046/io.mihome-vacu
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       24042      1185/io.harmony.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       26482      1951/io.nanoleaf-li
      udp6       0      0 :::111                  :::*                                0          18884      1/init
      udp6       0      0 fe80::11:32ff:fe2f::546 :::*                                101        19976      670/systemd-network
      2023-07-24 18:00:34.089  - info: hm-rega.0 (1108) renamed hm-rpc.0.BidCoS-RF.50.PRESS_SHORT to "BidCoS-RF:50.PRESS_SHORT"
      2023-07-24 18:00:36.121  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:01:36.945  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:02:37.770  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:02:50.611  - info: worx.0 (1200) Refresh token for MQTT-Connection
      2023-07-24 18:02:50.612  - info: worx.0 (1200) Disconnected
      2023-07-24 18:02:51.013  - info: worx.0 (1200) MQTT connected to: iot.eu-west-1.worxlandroid.com
      2023-07-24 18:03:38.598  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:04:39.424  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:05:00.034  - info: host.ubunto-iobroker instance system.adapter.dwd.0 started with pid 3392
      2023-07-24 18:05:01.878  - info: dwd.0 (3392) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.8
      2023-07-24 18:05:04.397  - info: dwd.0 (3392) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-24 18:05:04.929  - info: host.ubunto-iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-24 18:05:40.050  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:06:40.464  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:07:40.775  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:08:41.603  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:09:42.428  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:10:00.036  - info: host.ubunto-iobroker instance system.adapter.dwd.0 started with pid 3410
      2023-07-24 18:10:01.850  - info: dwd.0 (3410) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.8
      2023-07-24 18:10:06.336  - info: dwd.0 (3410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-07-24 18:10:06.869  - info: host.ubunto-iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-07-24 18:10:43.257  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:11:44.095  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      2023-07-24 18:12:44.908  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
      ~~~~strikethrough text~~~~
      iob diag has finished.
      Press any key for a summary
      bahnuhrB HomoranH 2 Antworten Letzte Antwort
      • N Njdfg
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        22.04
        Codename:       jammy
        NAME="Ubuntu"
        VERSION_ID="22.04"
        ID=ubuntu
        ID_LIKE=debian
        CPU threads: 2
                      NTP service: active
                  RTC in local TZ: no
        root
        /root
        root
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
                 5921 M total memory
                 2264 M used memory
                  197 M active memory
                 3116 M free memory
                   58 M buffer memory
                  481 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        /var:
        889M    /var/
        539M    /var/lib
        343M    /var/lib/snapd
        249M    /var/cache
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.6.1
        javascript:     7.1.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        13450
        States:         10882
        Pending Updates: 0
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @njdfg
        Warum bist du als beta unterwegs ?
        Und dann wundert man sich wenn irgendwas nicht klappt.
        Danke.
        • N Njdfg
          Skript v.2023-04-16
          *** BASE SYSTEM ***
          Docker          : false
          Release:        22.04
          Codename:       jammy
          NAME="Ubuntu"
          VERSION_ID="22.04"
          ID=ubuntu
          ID_LIKE=debian
          CPU threads: 2
                        NTP service: active
                    RTC in local TZ: no
          root
          /root
          root
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           2.0G          0B        2.0G
                   5921 M total memory
                   2264 M used memory
                    197 M active memory
                   3116 M free memory
                     58 M buffer memory
                    481 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          889M    /var/
          539M    /var/lib
          343M    /var/lib/snapd
          249M    /var/cache
          /usr/bin/npm            9.6.7
          /usr/bin/npx            9.6.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.6.1
          javascript:     7.1.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        13450
          States:         10882
          Pending Updates: 0
          root
          muss das sein?
          das ist eine Betaversion.
          sogar alles!
          warum?
          • F fastfoot
            N Offline
            N Offline
            Njdfg
            @fastfoot
            COOL, das war es .... :-) 👏
            Habe in beiden Instanzen Sentry abgeschaltet und nun sind alle Datenpunkte da.
            DANKE.
            F 1 Antwort Letzte Antwort
            • bahnuhrB bahnuhr
              @njdfg
              N Offline
              N Offline
              Njdfg
              @bahnuhr
              Hinterher ist man immer schlauer.....
                root
                muss das sein?
                sogar alles!
                warum?
                N Offline
                N Offline
                Njdfg
                Kann ich wieder auf Stable wechseln - oder bringt das jetzt nicht?
                • N Njdfg
                  @bahnuhr
                  @bahnuhr
                  was meinst du damit?
                  Beta ist immer riskant
                  So eine Info muss es zu Beginn geben.
                  • N Njdfg
                    erstens ja!
                    du müsstest ja alles downgraden
                    zweitens ja!
                    Möglicherweise bleibt dieses Issue sogar nach einem downgrade.
                    • N Njdfg
                      @fastfoot
                      DANKE.
                      F Online
                      F Online
                      fastfoot
                      @njdfg Das gefällt mir jetzt so gar nicht, auch wenn ich mich natürlich freue dass Dir das geholfen hat. Ich versuche gerade diesen Fehler zu finden den es auch in anderen Adaptern gibt und die Annahme war bisher dass das nur mit Node20 auftritt, du hast ja aber die 18. Wobei beim hm-rpc auch der Controller 5.0.8 genannt wurde.
                      N HomoranH 2 Antworten Letzte Antwort
                        @bahnuhr
                        N Offline
                        N Offline
                        Njdfg
                        Ja, habe ich jetzt auch gelernt, hatte vorher noch nie Probleme, ich denke ich habe das "damals" aktiviert als es die Alexa - Probleme gab und wollt durch die Beta wieder ein laufendes System haben.
                        Werde nun auf Stable - Version umschalten.
                        • F fastfoot
                          N Offline
                          N Offline
                          Njdfg
                          @fastfoot
                          Ich habe das System ja vor 2 Tagen erst neu aufgesetzt und alles (beta) aus der iob - Oberfläche installiert.
                          • F fastfoot
                            @fastfoot sagte in Iob neu auf Synology VM - Datenpunkte leer:
                            leider nein.
                            zumindest das was im rpc Problemthread steht.
                            keine Daten war höchstens zwischen den Zeilen dabei.
                            den Thread kennst du?
                            sonst such ich ihn dir
                            edit: https://forum.iobroker.net/post/1017380
                            • N Njdfg
                              @fastfoot
                              dann ist aber stable aktiv.
                                N Offline
                                N Offline
                                Njdfg
                                ja, aber da ich gute Erfahrung mit den Beta Dateien hatte und die ja meisten schon neues implementiert haben habe ich umgestellt - was vielleicht nun im Nachgang ein Fehler war.
                                Aber läuft das denn mit Sentry in der Stable - Version? Also hätte ich den Fehler dann nicht bekommen?
                                HomoranH F 2 Antworten Letzte Antwort
                                • N Njdfg
                                  das werden wir jetzt nie erfahren.
                                    leider nein.
                                    F Online
                                    F Online
                                    fastfoot
                                    @homoran doch den habe ich gestern gelesen, aber bei allen anderen Adaptern (influx, nuki-extended, tr-064, netatmo)tritt es scheinbar nur mit Node20 auf, der hm-rpc scheint da eine Ausnahme zu sein. Macht die Fehlersuche nicht einfacher(oder vlt. doch, mal sehen)
                                    • F fastfoot
                                      leider.
                                      hatte es nur nebenbei mit zigbee mitbekommen
                                        N Offline
                                        N Offline
                                        Njdfg
                                        @homoran 🤔
                                        • N Njdfg
                                          @homoran 🤔
                                          @homoran 🤔
                                          Siehe Diskussion/posts von @fastfoot
