  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Iob neu auf Synology VM - Datenpunkte leer
    5.1k
57 Beiträge 6 Kommentatoren 6.6k Aufrufe 4 Beobachtet
  • N Njdfg
    Hier das iob diag Ergebnis:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : microsoft
    Distributor ID: Ubuntu
    Description:    Ubuntu 22.04.2 LTS
    Release:        22.04
    Codename:       jammy
    PRETTY_NAME="Ubuntu 22.04.2 LTS"
    NAME="Ubuntu"
    VERSION_ID="22.04"
    VERSION="22.04.2 LTS (Jammy Jellyfish)"
    VERSION_CODENAME=jammy
    ID=ubuntu
    ID_LIKE=debian
    HOME_URL="https://www.ubuntu.com/"
    SUPPORT_URL="https://help.ubuntu.com/"
    BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
    PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
    UBUNTU_CODENAME=jammy
    Systemuptime and Load:
     18:11:52 up  3:57,  2 users,  load average: 0.02, 0.12, 0.17
    CPU threads: 2
    *** Time and Time Zones ***
                   Local time: Mon 2023-07-24 18:11:52 CEST
               Universal time: Mon 2023-07-24 16:11:52 UTC
                     RTC time: Mon 2023-07-24 16:11:52
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    root
    /root
    root
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        2.3G        3.1G        1.0M        540M        3.4G
    Swap:           2.0G          0B        2.0G
    Total:          8.0G        2.3G        5.2G
             5921 M total memory
             2264 M used memory
              197 M active memory
             2315 M inactive memory
             3116 M free memory
               58 M buffer memory
              481 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    *** FILESYSTEM ***
    Filesystem                        Type   Size  Used Avail Use% Mounted on
    tmpfs                             tmpfs  593M  1.1M  592M   1% /run
    /dev/mapper/ubuntu--vg-ubuntu--lv ext4    12G  7.2G  3.5G  68% /
    tmpfs                             tmpfs  2.9G     0  2.9G   0% /dev/shm
    tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
    /dev/sda2                         ext4   2.0G  130M  1.7G   8% /boot
    tmpfs                             tmpfs  593M  4.0K  593M   1% /run/user/0
    [Mon Jul 24 14:14:37 2023] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Mon Jul 24 14:14:38 2023] EXT4-fs (dm-0): re-mounted. Opts: (null). Quota mode: none.
    [Mon Jul 24 14:14:40 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    TARGET              SOURCE                            FSTYPE   OPTIONS
    /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
    |-/snap/core20/1974 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/core20/1822 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/lxd/24322   /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/18357 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
    |-/snap/snapd/19457 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
    `-/boot             /dev/sda2                         ext4     rw,relatime
    /var:
    889M    /var/
    539M    /var/lib
    343M    /var/lib/snapd
    342M    /var/lib/snapd/snaps
    249M    /var/cache
    Archived and active journals take up 88.0M in the file system.
    /opt/iobroker/backups:
    48M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    325M    /opt/iobroker/iobroker-data/
    221M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    43M     /opt/iobroker/iobroker-data/files/iot.admin
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.17.0
    /usr/bin/node           v18.17.0
    /usr/bin/npm            9.6.7
    /usr/bin/npx            9.6.7
    nodejs:
      Installed: 18.17.0-deb-1nodesource1
      Candidate: 18.17.0-deb-1nodesource1
      Version table:
     *** 18.17.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x jammy/main amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.8
    admin:          6.6.1
    javascript:     7.1.1
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ubunto-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ubunto-iobroker                          -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : ubunto-iobroker                          -  enabled
    + system.adapter.backitup.0               : backitup              : ubunto-iobroker                          -  enabled
    + system.adapter.bring.0                  : bring                 : ubunto-iobroker                          -  enabled
    + system.adapter.cloud.0                  : cloud                 : ubunto-iobroker                          -  enabled
    + system.adapter.discovery.0              : discovery             : ubunto-iobroker                          -  enabled
      system.adapter.dwd.0                    : dwd                   : ubunto-iobroker                          -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : ubunto-iobroker                          -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ubunto-iobroker                          -  enabled
    + system.adapter.harmony.0                : harmony               : ubunto-iobroker                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : ubunto-iobroker                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ubunto-iobroker                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : ubunto-iobroker                          -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : ubunto-iobroker                          -  enabled
    + system.adapter.hyperion_ng.0            : hyperion_ng           : ubunto-iobroker                          -  enabled
      system.adapter.ical.0                   : ical                  : ubunto-iobroker                          -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ubunto-iobroker                          -  enabled
    + system.adapter.info.0                   : info                  : ubunto-iobroker                          -  enabled
    + system.adapter.iot.0                    : iot                   : ubunto-iobroker                          -  enabled
    + system.adapter.javascript.0             : javascript            : ubunto-iobroker                          -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ubunto-iobroker                          -  enabled
      system.adapter.luftdaten.0              : luftdaten             : ubunto-iobroker                          -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ubunto-iobroker                          -  enabled, port: 54321
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : ubunto-iobroker                          -  enabled, port: 16021
    + system.adapter.pollenflug.0             : pollenflug            : ubunto-iobroker                          -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ubunto-iobroker                          -  enabled, port: 1883, bind: 192.168.123.95
    + system.adapter.tankerkoenig.0           : tankerkoenig          : ubunto-iobroker                          -  enabled
    + system.adapter.telegram.0               : telegram              : ubunto-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ubunto-iobroker                          -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ubunto-iobroker                          -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ubunto-iobroker                          -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ubunto-iobroker                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubunto-iobroker                          -  enabled
      system.adapter.vis-metro.0              : vis-metro             : ubunto-iobroker                          -  enabled
      system.adapter.vis.0                    : vis                   : ubunto-iobroker                          - disabled
    + system.adapter.web.0                    : web                   : ubunto-iobroker                          -  enabled, port: 8082, bind: 192.168.123.95, run as: admin
    + system.adapter.worx.0                   : worx                  : ubunto-iobroker                          -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 6.6.1    , installed 6.6.1
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "awtrix-light" : 0.5.1    , installed 0.5.1
    Adapter    "backitup"     : 2.6.23   , installed 2.6.23
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "cloud"        : 4.4.1    , installed 4.4.1
    Adapter    "discovery"    : 3.2.0    , installed 3.2.0
    Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.18  , installed 1.15.18
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "hyperion_ng"  : 0.1.23   , installed 0.1.23
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.1    , installed 7.1.1
    Controller "js-controller": 5.0.8    , installed 5.0.8
    Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
    Adapter    "luftdaten"    : 3.0.0    , installed 3.0.0
    Adapter    "mihome-vacuum": 3.11.0   , installed 3.11.0
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "socketio"     : 6.4.0    , installed 6.4.0
    Adapter    "sonoff"       : 2.5.7    , installed 2.5.7
    Adapter    "telegram"     : 1.16.0   , installed 1.16.0
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.2.0    , installed 2.2.0
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "worx"         : 2.3.2    , installed 2.3.2
    Adapter    "ws"           : 2.4.0    , installed 2.4.0
    Objects and States
    Objects:        13450
    States:         10882
    Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://deb.nodesource.com/node_18.x jammy InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18881      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20227      742/sshd: /usr/sbin
    tcp        0      0 192.168.123.95:8082     0.0.0.0:*               LISTEN      1001       24742      1337/io.web.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20365      691/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       22003      691/iobroker.js-con
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        19941      672/systemd-resolve
    tcp        0      0 192.168.123.95:2010     0.0.0.0:*               LISTEN      1001       63257      3242/io.hm-rpc.1
    tcp        0      0 192.168.123.95:2001     0.0.0.0:*               LISTEN      1001       66456      3374/io.hm-rpc.0
    tcp        0      0 192.168.123.95:1883     0.0.0.0:*               LISTEN      1001       22975      1063/io.sonoff.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       24041      1185/io.harmony.0
    tcp6       0      0 :::111                  :::*                    LISTEN      0          18883      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          20247      742/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22663      921/io.admin.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        19940      672/systemd-resolve
    udp        0      0 192.168.123.95:68       0.0.0.0:*                           101        19921      670/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18882      1/init
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       23676      1046/io.mihome-vacu
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       24042      1185/io.harmony.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       26482      1951/io.nanoleaf-li
    udp6       0      0 :::111                  :::*                                0          18884      1/init
    udp6       0      0 fe80::11:32ff:fe2f::546 :::*                                101        19976      670/systemd-network
    2023-07-24 18:00:34.089  - info: hm-rega.0 (1108) renamed hm-rpc.0.BidCoS-RF.50.PRESS_SHORT to "BidCoS-RF:50.PRESS_SHORT"
    2023-07-24 18:00:36.121  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:01:36.945  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:02:37.770  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:02:50.611  - info: worx.0 (1200) Refresh token for MQTT-Connection
    2023-07-24 18:02:50.612  - info: worx.0 (1200) Disconnected
    2023-07-24 18:02:51.013  - info: worx.0 (1200) MQTT connected to: iot.eu-west-1.worxlandroid.com
    2023-07-24 18:03:38.598  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:04:39.424  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:05:00.034  - info: host.ubunto-iobroker instance system.adapter.dwd.0 started with pid 3392
    2023-07-24 18:05:01.878  - info: dwd.0 (3392) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.8
    2023-07-24 18:05:04.397  - info: dwd.0 (3392) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-24 18:05:04.929  - info: host.ubunto-iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-24 18:05:40.050  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:06:40.464  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:07:40.775  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:08:41.603  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:09:42.428  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:10:00.036  - info: host.ubunto-iobroker instance system.adapter.dwd.0 started with pid 3410
    2023-07-24 18:10:01.850  - info: dwd.0 (3410) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.17.0, js-controller: 5.0.8
    2023-07-24 18:10:06.336  - info: dwd.0 (3410) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-07-24 18:10:06.869  - info: host.ubunto-iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-07-24 18:10:43.257  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:11:44.095  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    2023-07-24 18:12:44.908  - warn: fullybrowser.0 (1393) updateDeviceERROR 192.168.123.74
    ~~~~strikethrough text~~~~
    iob diag has finished.
    Press any key for a summary
    @njdfg sagte in Iob neu auf Synology VM - Datenpunkte leer:
    root
    muss das sein?
    das ist eine Betaversion.
    sogar alles!
    warum?
    N 1 Antwort Letzte Antwort
    • F fastfoot
      @njdfg es gibt da gerade ein issue mit hm-rpc, mW aber mit Node20. Dennoch könntest du mal probieren Sentry in der GUI abzuschalten, in den Instanzen beim Adapter das grüne Dreieck klicken, wird dann grau und der Adapter startet neu. Ist ja nur ein Klick und einen Versuch wert
      Edit: dazu muss in den Expertenmodus gewechselt werden, sonst sieht man das Dreieck gar nicht
      N Offline
      N Offline
      Njdfg
      @fastfoot
      COOL, das war es .... :-) 👏
      Habe in beiden Instanzen Sentry abgeschaltet und nun sind alle Datenpunkte da.
      DANKE.
      F 1 Antwort Letzte Antwort
      • bahnuhrB bahnuhr
        @njdfg
        Warum bist du als beta unterwegs ?
        Und dann wundert man sich wenn irgendwas nicht klappt.
        N Offline
        N Offline
        Njdfg
        @bahnuhr
        Hinterher ist man immer schlauer.....
          root
          muss das sein?
          sogar alles!
          warum?
          N Offline
          N Offline
          Njdfg
          Kann ich wieder auf Stable wechseln - oder bringt das jetzt nicht?
          • N Njdfg
            @bahnuhr
            @bahnuhr
            was meinst du damit?
            Beta ist immer riskant
            So eine Info muss es zu Beginn geben.
            • N Njdfg
              erstens ja!
              du müsstest ja alles downgraden
              zweitens ja!
              Möglicherweise bleibt dieses Issue sogar nach einem downgrade.
              • N Njdfg
                @fastfoot
                DANKE.
                F Online
                F Online
                fastfoot
                @njdfg Das gefällt mir jetzt so gar nicht, auch wenn ich mich natürlich freue dass Dir das geholfen hat. Ich versuche gerade diesen Fehler zu finden den es auch in anderen Adaptern gibt und die Annahme war bisher dass das nur mit Node20 auftritt, du hast ja aber die 18. Wobei beim hm-rpc auch der Controller 5.0.8 genannt wurde.
                N HomoranH 2 Antworten Letzte Antwort
                  @bahnuhr
                  N Offline
                  N Offline
                  Njdfg
                  Ja, habe ich jetzt auch gelernt, hatte vorher noch nie Probleme, ich denke ich habe das "damals" aktiviert als es die Alexa - Probleme gab und wollt durch die Beta wieder ein laufendes System haben.
                  Werde nun auf Stable - Version umschalten.
                  • F fastfoot
                    N Offline
                    N Offline
                    Njdfg
                    @fastfoot
                    Ich habe das System ja vor 2 Tagen erst neu aufgesetzt und alles (beta) aus der iob - Oberfläche installiert.
                    • F fastfoot
                      @fastfoot sagte in Iob neu auf Synology VM - Datenpunkte leer:
                      leider nein.
                      zumindest das was im rpc Problemthread steht.
                      keine Daten war höchstens zwischen den Zeilen dabei.
                      den Thread kennst du?
                      sonst such ich ihn dir
                      edit: https://forum.iobroker.net/post/1017380
                      • N Njdfg
                        @fastfoot
                        dann ist aber stable aktiv.
                          N Offline
                          N Offline
                          Njdfg
                          ja, aber da ich gute Erfahrung mit den Beta Dateien hatte und die ja meisten schon neues implementiert haben habe ich umgestellt - was vielleicht nun im Nachgang ein Fehler war.
                          Aber läuft das denn mit Sentry in der Stable - Version? Also hätte ich den Fehler dann nicht bekommen?
                          HomoranH F 2 Antworten Letzte Antwort
                          • N Njdfg
                            das werden wir jetzt nie erfahren.
                              leider nein.
                              F Online
                              F Online
                              fastfoot
                              @homoran doch den habe ich gestern gelesen, aber bei allen anderen Adaptern (influx, nuki-extended, tr-064, netatmo)tritt es scheinbar nur mit Node20 auf, der hm-rpc scheint da eine Ausnahme zu sein. Macht die Fehlersuche nicht einfacher(oder vlt. doch, mal sehen)
                              • F fastfoot
                                leider.
                                hatte es nur nebenbei mit zigbee mitbekommen
                                  N Offline
                                  N Offline
                                  Njdfg
                                  @homoran 🤔
                                  • N Njdfg
                                    @homoran 🤔
                                    @homoran 🤔
                                    Siehe Diskussion/posts von @fastfoot
                                    • N Njdfg
                                      F Online
                                      F Online
                                      fastfoot
                                      ist doch ok, so habe ich eine Rückmeldung/Info mehr. Habe den issue auf Github nur überflogen, meine mich aber zu erinnern dass ein Zurück auf die Beta 5.0.6(mit der es scheinbar läuft) nicht geholfen hat.
                                      wenn du es probieren willst, auf der Konsole und auf eigene Gefahr
                                      • iobroker stop
                                      • cd /opt/iobroker
                                      • npm i iobroker.js-controller@4.0.24
                                      • iobroker start
                                      damit wäre der controller wieder im Stable.
                                      • F fastfoot
                                        • iobroker stop
                                        • cd /opt/iobroker
                                        • iobroker start
                                        jepp! Auch bei den Problemen mit rpc unter node v16 und v18
                                          F Online
                                          F Online
                                          fastfoot
                                          @homoran sagte in Iob neu auf Synology VM - Datenpunkte leer:
                                          unter node v16
                                          omg, das habe ich jetzt nicht wirklich so gelesen? :-)
