  4. [Aufruf] TP-Link HS100 HS110 Adapter Testen
215 Beiträge 41 Kommentatoren 72.2k Aufrufe 3 Beobachtet
    muckel
    @muckel:
    @arteck:
    @muckel:
    Hallo Arteck
    Kannst du mir dazu einen Tip geben.
    Danke im Voraus
    liebe Grüße
    host.iobroker	2017-09-12 17:59:22.814	info	Restart adapter system.adapter.hs100.0 because enabled
    host.iobroker	2017-09-12 17:59:22.813	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
    hs100.0	2017-09-12 17:59:22.313	error	TypeError: Cannot read property 'length' of undefined at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32) at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.
    hs100.0	2017-09-12 17:59:22.313	error	uncaught exception: Cannot read property 'length' of undefined
    hs100.0	2017-09-12 17:59:22.311	info	starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.hs100, node: v4.7.2
    host.iobroker	2017-09-12 17:59:20.913	info	instance system.adapter.hs100.0 started with pid 768
    host.iobroker	2017-09-12 17:58:50.869	info	Restart adapter system.adapter.hs100.0 because enabled
    host.iobroker	2017-09-12 17:58:50.869	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
    hs100.0	2017-09-12 17:58:50.369	error	TypeError: Cannot read property 'length' of undefined at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32) at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.
    hs100.0	2017-09-12 17:58:50.368	error	uncaught exception: Cannot read property 'length' of undefined
    hs100.0	2017-09-12 17:58:50.367	info	starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.hs100, node: v4.7.2
    host.iobroker	2017-09-12 17:58:49.035	info	instance system.adapter.hs100.0 started with pid 758
    host.iobroker	2017-09-12 17:58:18.982	info	Restart adapter system.adapter.hs100.0 because enabled
    host.iobroker	2017-09-12 17:58:18.982	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
    hs100.0	2017-09-12 17:58:18.959	info	terminating
    hs100.0	2017-09-12 17:58:18.448	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    hs100.0	2017-09-12 17:58:18.448	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    hs100.0	2017-09-12 17:58:18.448	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    hs100.0	2017-09-12 17:58:18.448	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
    hs100.0	2017-09-12 17:58:18.448	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:703:25)
    hs100.0	2017-09-12 17:58:18.448	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4527:18)
    hs100.0	2017-09-12 17:58:18.448	error	at Adapter.emit (events.js:166:7)
    hs100.0	2017-09-12 17:58:18.448	error	at emitNone (events.js:67:13)
    hs100.0	2017-09-12 17:58:18.448	error	at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:30:5)
    hs100.0	2017-09-12 17:58:18.448	error	at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32)
    hs100.0	2017-09-12 17:58:18.448	error	TypeError: Cannot read property 'length' of undefined
    hs100.0	2017-09-12 17:58:18.438	error	uncaught exception: Cannot read property 'length' of undefined
    hast du IP's eingetragen ?? von den Dosen `
    Gesendet von iPhone mit Tapatalk `
    Ja natürlich.
    Es funktioniert ja alles.
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      bedeutet
      {ZEILE 377}: if (!adapter.config.devices.length) {
      adapter.config.devices ist undefined.
      Da fehlt wohl die Eigenschaft im Adapter-Objekt (müsste per Expertenmodus unter hs100.0 zu finden sein, Abschnitt "native").
      Wurde die eventuell mit einem Update hinzugefügt?
        AlCalzoneA Offline
        AlCalzone
        @UweRLP:
        laut Changelog soll es eine 0.0.16 (2017-08-19) geben, installiert wird aber eine 0.0.15 (Anzeige in Admin). `
        Da hat arteck wohl vergessen die io-package.json anzupassen.
        Adapter-testing fängt dieses Problem übrigens ab, könnte man mal aktivieren ;)
          muckel
          @AlCalzone:
          @UweRLP:
          Adapter-testing fängt dieses Problem übrigens ab, könnte man mal aktivieren ;) `
            muckel
            @muckel:
            @AlCalzone:
            @UweRLP:
            Das könnte ich mal probieren.
            Danke für den tip.
            Liebe Grüße
              AlCalzoneA Offline
              AlCalzone
              @muckel:
              Danke für den tip. `
              Das war an Arteck als Entwickler gerichtet. Dann sieht man wie https://github.com/AlCalzone/ioBroker.tradfri/blob/master/README.md auf den ersten Blick ob irgendwas grundlegendes nicht stimmt.
              • arteckA Offline
                arteckA Offline
                arteck
                ihr müsst mir verzeihen.. ich bau gerade mein Haus um.. soweit ich Zeit finde.. wirds korrigiert
                  DavidT
                  ich habe den ganzen Abend verzweifelt versucht den Adapter zu installieren (wie von Dir beschrieben), leider ohne Erfolg.
                  Bei dem Versuch mein node zu updaten habe ich mir meinen Container total zerschossen, hatte kein Backup usw. Ohne viele Linux und Docker-Kenntnisse echt eine Herausforderung :)
                  Ich habe wie von dir beschrieben das ganze in der Shell installiert (0.0.17) mit aktuellen node und bekomme bei "iobroker add hs100" folgenden Fehler:
                  root@T-NAS:/opt/iobroker# iobroker add hs100
                  host.T-NAS install adapter hs100
                  host.T-NAS error: reading io-package.json SyntaxError: Unexpected token , in JSON at position 1152
                  Mache ich irgendwas falsch!? Bin mit meinem Latein am ende :)
                  Gruß David
                    DavidT
                    Ok, wenn man die einfachen Probleme nicht sieht… In der io-package.json ist ein Syntaxfehler. Habe es gefixt und einen Pullrequest erstellt.
                    Danke für Deine Arbeit!
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      ich habs auch schon korrigiert.. version 0.0.18
                        mamoel
                        Hallo zusammen, die Installation des Adapters war recht einfach und wurde auch sofort in iobroker angezeigt. Mein HS100 wird erkannt und ich kann aus iobroker heraus (admin->Objects->HS100 …) die Steckdose über den 'state' ein- und ausschalten.
                        Was jedoch seltsamerweise nicht funktioniert:
                        Ich ändere den Status über die KASA-App am Smartphone und höre wie die Steckdose schaltet. In iobroker bleibt der Status jedoch unverändert. Haben das andere User hier auch?
                        Wenn ich den Adapter 'durchstarte' holt er sich den aktuellen Status korrekt.
                        Ich habe Node.js 6.11.4 und den neuesten HS100 Adapter 0.18 installiert. Das Intervall habe ich aktuell auf 3000ms.
                        <size size="85">ioBroker (docker) auf Synology DS418play
                        Alexa2, cloud, fritzdect, g-homa, harmony, hm-rega, hm-rpc, hs100, hue, javascript, nuki, ring, sayit, sonos, sql, viessmannapi</size>
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          @mamoel:
                          Ich habe Node.js 6.11.4 und den neuesten HS100 Adapter 0.18 installiert. Das Intervall habe ich aktuell auf 3000ms. `
                          das Problem ist das gleiche wie in Hue .. es wird nicht sofort aktuallisiert.. das kannst du im Adapter einstellen … unter Intervall..
                          das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten
                            mamoel
                            @arteck:
                            das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten `
                            Ich habe das Intervall jetzt auf 5000 ms gesetzt, das Ergebnis ist aber leider identisch: wenn ich den Schalter mit der Kasa-App betätige, aktualisiert sich der Status in iobroker auch nach einer Minute noch nicht.
                            • arteckA Offline
                              arteckA Offline
                              arteck
                              @mamoel:
                              @arteck:
                              das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten Ich habe das Intervall jetzt auf 5000 ms gesetzt, das Ergebnis ist aber leider identisch: wenn ich den Schalter mit der Kasa-App betätige, aktualisiert sich der Status in iobroker auch nach einer Minute noch nicht.
                              welches Betriebssystem ??
                                mamoel
                                Läuft bei mir auf einem Mac Mini (Late 2009) unter OSX.
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  @mamoel:
                                  Läuft bei mir auf einem Mac Mini (Late 2009) unter OSX. `
                                  ach du jemine.. :lol:
                                  ich werde probieren am WE bissel Zeit zu finden und paar Debuger informationen zu implementieren..
                                  schauen musst du dann selber.. habe so einen exoten nicht
                                    mamoel
                                    Hier wird alles recycled - von wegen CO2-Fußabdruck und so. :mrgreen:
                                      mamoel
                                      Hallo, ich wollte nochmal ein Update geben.
                                      Ich habe jetzt meine komplette ioBroker-Installation auf meinen ODROID C2 umgezogen. Der war sowieso übrig, da ich kürzlich als MediaCenter ein NVidia Shield ATV angeschafft habe.
                                      Aber wie auch immer…ich habe das aktuellste armbian für den C2 (5.31, jessie, 3.14.79) installiert und alle Adapter neu installiert. Lediglich die VIS-Konfiguration habe ich als einzelne Views ex- und wieder importiert.
                                      Soweit läuft jetzt endlich wieder alles.
                                      Allerdings hat sich das Verhalten des HS100 gegenüber der Mac-Konfig nicht verändert. Schaltvorgänge über den ioBroker sind in der KASA-App sichtbar, aber leider nicht umgekehrt. Was mir dabei aufgefallen ist:
                                      In der Objektansicht des ioBroker.admin wird der state Wert offenbar nicht ausgelesen. Das Feld bleibt immer rot.
                                        dj.tifosi
                                        Kleiner Tipp: Amazon haut diese Steckdosen heute für 9,99€ raus, wenn man zusätzlich ein Echo-Gerät kauft, siehe https://www.amazon.de/b/?ie=UTF8&node=1 … ods_echotp
                                        Die Echo-Geräte sind heute ebenfalls günstiger zu bekommen, habe beim Echo Dot 2. Generation für 34,99 € zugeschlagen.
                                        Also eine gute Gelegenheit, sich not beiden Geräten einzudecken.
                                        • O Offline
                                          O Offline
                                          onkelfrisko
                                          @mamoel:
                                          In der Objektansicht des ioBroker.admin wird der state Wert offenbar nicht ausgelesen. Das Feld bleibt immer rot. `
                                          auch bei mir wird der State nicht aktualisiert wenn ich per App oder manuell die Steckdose einschalte. Ich benutze einen Pi3 mit Raspbian Stretch Image
