  3. Off Topic
  4. Upgrade von Debian 11/Bullseye auf 12/Bookworm
upgrade bullseye bookworm
351 Beiträge 51 Kommentatoren 116.4k Aufrufe 52 Beobachtet
  • T tritor
    @spacerx
    Bei LXC grafana lief bei mir das upgrade auf bookworm noch durch.
    Bei Influx (in eigenem LXC) gabs dann Probleme mit dem repository.
    Wie hast du den Influx Container auf bookworm upgegraded?
    #81
    @tritor sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
    Ohne Meldungen? Kann ich mir nicht vorstellen.
      tritor
      #82
      nachdem der Versuch nicht funktioniert hat wegen Fehlermeldungen, habe ich backup zurückgespielt bevor noch was passiert.
      l# sudo apt update
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Err:4 https://repos.influxdata.com/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Reading package lists... Done
      357 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Gernot
      Host: i9 server Proxmox , Debian 13.4 for ioBroker
      ioBroker: 7.9.2, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.2.1
      Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
      Grafana 13.0.1 / InfluxDB 2.8.0
      • T tritor
        l# sudo apt update
        #83
        @tritor
        Ist das gleiche Thema wie hier:
        https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
        Konkret zu influx steht im weiteren Verlauf sogar was dabei.
          @tritor
          tritor
          schrieb am zuletzt editiert von tritor
          #84
          Danke, Grafana hatte ich schon in Arbeit, wußte bis jetzt nicht, daß dies auch bei Influx benötigt wird.
          Mach ich mich gleich mal ran das zu erledigen.
          Denke mal jetzt ist alles so wie sein soll:
          # sudo apt update
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          All packages are up to date.
          Gernot
          • T tritor
            # sudo apt update
            #85
            Deswegen sprechen die Programme mittels Meldungen mit dir.
            • T tritor
              # sudo apt update
              #86
              @tritor
              Scheint jetzt zu passen. Auch wenn es mal wieder unnötiger Einsatz von sudo ist. Du bist ja schon root...
              • T tritor
                @spacerx
                SpacerX
                #87
                @tritor so wie es @Thomas-Braun schon schrub. Ich hatte die Quellen bei Grafana und InfluxDB schon weit vorher aktualisiert und für beide vor dem Bookworm Upgrade noch die letzte Aktualisierung gemacht.
                DS720|Nuc8i3BEH|Proxmox|RaspberryMatic|ioBroker|influxDB2|Grafana
                  @tritor
                  smarthome2020
                  #88
                  Vielen Dank für das nützliche Tutorial . Habe 5 LXCs ohne Probleme auf bookworm anheben können :)
                    Vorab:
                    Debian 12 'Bookworm' ist am 10.06.2023 als stabil veröffentlicht worden.
                    Raspberry OS 'Bullseye' ist seit dem 10. Oktober 2023 auch verfügbar. Hier ist allerdings ein in-line-Upgrade von der Vorversion nicht so einfach wie in der Vergangenheit möglich. Es sollte hier eine komplette Neuinstallation vorgenommen werden.
                    Desweiteren würde ich empfehlen die Gelegenheit zu nutzen und 32bit-Systeme auf Raspberry Pi-Kisten auf 64bit umzustellen. Das funktioniert allerdings nicht wie hier vorgestellt, bei einem Wechsel der CPU-Architektur ist eine Neuinstallation erforderlich. Desweiteren gilt für Raspberry OS die dringende Empfehlung einer Neuinstallation:
                    Edit:
                    Diesmal rät Raspberry OS allerdings noch dringender als sonst dazu, die Systeme nicht von einem zum anderen Release rüberzuheben, sondern eine komplette Neuinstallation zu machen:
                    Wichtig zu wissen: Früher empfahl man eine frische Installation, aber es war möglich, vom Vorgänger zu aktualisieren. Die jetzige Installation sollte aber auf jeden Fall neu sein.
                    Da die Änderungen an der zugrundeliegenden Architektur so signifikant sind, schlägt man dieses Mal keine Prozedur vor, um ein Bullseye-Image auf Bookworm zu aktualisieren; jeder Versuch, dies zu tun, wird mit ziemlicher Sicherheit mit einem nicht bootenden Desktop und Datenverlust enden.
                    Die einzige Möglichkeit, Bookworm zu bekommen, ist entweder eine SD-Karte mit dem Raspberry Pi Imager zu erstellen oder ein Bookworm-Image von hier herunterzuladen und mit dem Tool der Wahl zu flashen.
                    Gilt aber auch für ein System ohne Desktop, bei meinen Versuchen hab ich schwer mit dem Bootvorgang zu kämpfen, den aktuellen Kernel habe ich nicht vollständig gestartet bekommen.
                    Wer es entgegen aller Warnungen versuchen möchte:
                    https://www.heise.de/hintergrund/Raspberry-Pi-OS-InPlace-Upgrade-von-Bullseye-auf-Bookworm-wagen-9999516.html
                    #Upgrade von Debian 11 'Bullseye' auf Debain 12 'Bookworm'
                    Gegeben ist ein System, auf dem 'Debian 11 - Bullseye' läuft:
                    pi@mysterium2:~ $ lsb_release -a
                    No LSB modules are available.
                    Distributor ID: Raspbian
                    Description:    Raspbian GNU/Linux 11 (bullseye)
                    Release:        11
                    Codename:       bullseye
                    Der Stand soll auf Debian 12 'Bookworm' gehoben werden. Ich mache das wie folgt:
                    Zunächst alles auf den letzten Stand bringen
                    pi@mysterium2:~ $ sudo apt update
                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                    Get:4 https://pkgs.tailscale.com/stable/raspbian bullseye InRelease
                    Fetched 6,522 B in 6s (1,042 B/s)
                    113 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    Wenn in der Liste irgendwas mit bullseye-backports oder bullseye-propsed-updates oder ähnliches auftauchen sollte, dann ist diese Quelle zuvor zu deaktivieren. Ebenso andere manuelle Eingriffe in die Paket-Datenbank. Z.B. ein apt-hold auf das Paket 'udev' ist ja von einigen getätigt worden, diese Sperren müssen aufgehoben werden. Kann man per
                    apt-mark showhold
                    prüfen. Die aufgelisteten Pakete dann mit
                    sudo apt-mark unhold `apt-mark showhold`
                    wieder frei laufen lassen.
                    Also
                    sudo apt full-upgrade
                    sudo reboot
                    Nach dem reboot dürfen keine Pakete mehr in der Pipeline hängen.
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Fetched 6,522 B in 2s (3,644 B/s)
                    Prima, jetzt ist die Basis stabil und wir können auf bookworm/Debian12 umschwenken.
                    In die Datei /etc/apt/sources.list kopieren wir diese neuen Zeilen rein, die alten Einträge fliegen dafür raus:
                    Via
                    sudo nano /etc/apt/sources.list
                    das einkopieren:
                    deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
                    deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
                    deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
                    # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                    deb-src http://deb.debian.org/debian bookworm main contrib non-free
                    deb-src http://security.debian.org/debian-security bookworm-security main contrib non-free
                    deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free
                    Zusätzlich stellen wir auch noch weitere Dateien auf bookworm um:
                    sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list
                    sudo sed -i 's/bullseye/bookworm/g' /etc/apt/sources.list.d/*
                    Wenn ein erneutes
                    sudo apt update
                    Meldungen wie die folgende ergibt:
                    Err:2 http://deb.debian.org/debian bookworm InRelease
                      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                    muss der Schlüssel jeweils herangezogen werden.
                    Macht man so:
                    sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 648ACFD622F3D138
                    Die ID des keys übernimmt man natürlich aus der vorherigen Meldung.
                    Das macht man mit allen fehlenden Schlüsseln, bis es so oder so ähnlich aussieht, die Meldungen bzgl. der Schlüssel also nicht mehr vorhanden sind:
                    Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
                    Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:5 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                    Hit:6 https://deb.nodesource.com/node_18.x bookworm InRelease
                    Get:7 https://pkgs.tailscale.com/stable/debian bookworm InRelease
                    Fetched 6,522 B in 3s (2,404 B/s)
                    445 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    Auch dürfen da keine Einträge mit bullseye mehr vorkommen.
                    Vor dem eigentlichen Upgrade schaut man per
                    sudo apt -o APT::Get::Trivial-Only=true full-upgrade
                    nach ob auch genug Platz auf dem Datenträger ist. Wenn E: You don't have enough free space in /var/cache/apt/archives/. gemeldet wird sollte man vorher aufräumen, z. B. per
                    sudo apt clean
                    Jetzt aber los...
                    sudo apt update
                    Wenn während des Upgrades Rückfragen kommen, ob eine neue Version einer Konfig-Datei eingespielt werden soll bitte immer mit yes bestätigen. Es wird von der ursprünglichen Datei eine Kopie mit der Endung .dpkg-old gespeichert, welche bei Bedarf dann zurückgespielt werden kann.
                    Gleiches gilt für die Frage, ob Services automatisch neugestartet werden sollen.
                    Aus der Anzeige des ChangeLogs kommt man durch Eingabe von q heraus.
                    Jetzt holt man sich einen Kaffee (alternativ Club Mate) und schaut wie ein Superhacker mit schwarzem Kaputzenpulli und koffeinhaltigem Getränk in der Hand angestrengt auf die vorbeilaufenden Meldungen im Terminal und haut gelegentlich bei den obengenannten Rückfragen auf die Y-Taste.
                    Wenn alles durchgelaufen ist und nach einem beherzten
                    sudo reboot
                    befinden wir uns in Debian 12 'Bookworm'
                           _,met$$$$$gg.          pi@mysterium2
                        ,g$$$$$$$$$$$$$$$P.       -------------
                      ,g$$P"     """Y$$.".        OS: Debian GNU/Linux 12 (bookworm) armv7l
                     ,$$P'              `$$$.     Host: Raspberry Pi 3 Model B Plus Rev 1.3
                    ',$$P       ,ggs.     `$$b:   Kernel: 6.1.21-v7+
                    `d$$'     ,$P"'   .    $$$    Uptime: 1 hour, 31 mins
                     $$P      d$'     ,    $$P    Packages: 711 (dpkg)
                     $$:      $$.   -    ,d$$'    Shell: bash 5.2.15
                     $$;      Y$b._   _,d$P'      Terminal: /dev/pts/0
                     Y$$.    `.`"Y$$$$P"'         CPU: BCM2835 (4) @ 1.400GHz
                     `$$b      "-.__              Memory: 70MiB / 965MiB
                      `Y$$
                       `Y$$.
                         `$$b.
                           `Y$$b.
                              `"Y$b._
                    Falls Meldungen bei einem
                    sudo apt update
                    bezüglich apt-key auftauchen:
                    W: http://security.debian.org/debian-security/dists/bookworm-security/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: http://deb.debian.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: http://archive.raspberrypi.org/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: http://deb.debian.org/debian/dists/bookworm-updates/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: http://archive.raspberrypi.org/debian/dists/bullseye/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: https://pkgs.tailscale.com/stable/debian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    kann man die noch an eine andere Stelle schieben:
                    sudo mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
                    Das ist zwar nicht der Königsweg, sorgt aber dafür das die Meldungen für das erste verschwinden.
                    Fertig, viel Spaß mit dem Bücherwurm / Debian 12.
                    amg_666A Offline
                    amg_666A Offline
                    amg_666
                    #89
                    @thomas-braun sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                    pi@iostrom:~ $ sudo apt update
                    OK:1 http://security.debian.org/debian-security bookworm-security InRelease
                    OK:2 http://deb.debian.org/debian bookworm InRelease
                    OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                    OK:4 http://archive.raspberrypi.org/debian buster InRelease
                    OK:5 https://deb.nodesource.com/node_18.x bookworm InRelease
                    da steht bei OK4 noch buster ??? Ich hab aber bullseye auf dem Raspi. Wo muss ich da nach alten Einträgen suchen um das zu korrigieren? Die Umstellungen auf bookworm hatte ich wie oben beschrieben gemacht.
                    • amg_666A amg_666
                      #90
                      @amg_666 sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                      Dann ist das ein Überbleibsel aus einem Upgrade von Buster auf Bullseye.
                      Steht in der /etc/apt/sources list.d/raspi.list drin
                      Raspberry OS gibt es aber noch nicht als bookworm. Da musst du also zweigleisig fahren und sowohl 'bullseye' wie auch 'bookworm' anlegen.
                      amg_666A L 2 Antworten Letzte Antwort
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        #91
                        Danke, das war es, jetzt ist es "clean" :-)
                        • amg_666A amg_666
                          #92
                          @amg_666
                          Siehe mein Edit oben.
                          Es muss hier temporär sowohl bullseye wie bookworm referenziert werden.
                            legro
                            schrieb am zuletzt editiert von legro
                            #93
                            Oh je, jetzt machst du mir regelrecht Angst. Ich habe nach deiner Anleitung mein auf RaspberryOS basierendes System doch auf Bookworm umgestellt. Muss ich nun Schlimmes befürchten?
                            Mein ioBroker scheint jedenfalls davon unbeeindruckt fehlerfrei zu laufen.
                            Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
                            • L legro
                              #94
                              @legro
                              Damit hast du dich für die Raspberry OS spezifischen Pakete (raspi-config, raspberrypi-kernel, usw.) von eine Quelle für Updates abgeschnitten.
                              Leg dir einfach eine zweite Zeile in der raspi.list an und ersetze in dieser Zeile bookworm durch bullseye.
                              Wenn bookworm für Raspberry OS offiziell ist und das bookworm-Rwpo gefüllt ist kannste das bullseye ausknipsen.
                              • L legro
                                #95
                                @legro sagte in Upgrade von Debian 11/Bullseye auf 12/Bookworm:
                                Hatte ich nicht geschrieben, dass es für Raspberry OS noch zu früh ist?
                                amg_666A Marko1974M 2 Antworten Letzte Antwort
                                  amg_666A Offline
                                  amg_666A Offline
                                  amg_666
                                  #96
                                  Ja hast du, aber: Ich hab in deinem 1. Post oben aber nur den Anfang überflogen und bin dann direkt ab der 1. fett geschriebenen Überschrift (#Upgrade von Debian 11 'Bullseye' auf Debain 12 'Bookworm') eingestiegen.
                                  Und da kommt dann als 1. Zeile direkt "Gegeben ist ein Raspi 3...", und damit hab ich weitergemacht.
                                  OK, mein Fehler, ich könnte mir aber gut vorstellen, dass ich da nicht der einzige bin...
                                  Ich hab jetzt wie beschrieben die raspi.list ergänzt und gut ist. Mein Raspberry ist auch "nur" ein Slave, der den Stromzähler einliest, Hauptsystem ist intel nuc mit proxmox Container und im Container lief die Umstellung auf bookworm ohne Probleme.
                                    Marko1974M Offline
                                    Marko1974M Offline
                                    Marko1974
                                    schrieb am zuletzt editiert von Marko1974
                                    #97
                                    @thomas-braun Dankesehr....hat soweit geklappt. Das kann ich auch ignorieren oder verschieben? Gerade weil es um deconz geht :-)
                                    Bestätigen kann ich aber, dass der udev Fehler hier wirklich nicht vorkommt.
                                    OK:1 http://phoscon.de/apt/deconz bookworm InRelease
                                    OK:3 http://security.debian.org/debian-security bookworm-security InRelease
                                    OK:4 http://deb.debian.org/debian bookworm-updates InRelease
                                    Alle Pakete sind aktuell.
                                    W: http://phoscon.de/apt/deconz/dists/bookworm/InRelease: Schlüssel ist im veralteten Schlüsselbund trusted.gpg gespeichert (/etc/apt/trusted.gpg), siehe den Abschnitt MISSBILLIGUNG in apt-key(8) für Details.
                                    openhabian@ioBroker:~$
                                    • Marko1974M Marko1974
                                      #98
                                      @marko1974
                                      Schlüssel entfernen und Repo mit dem aktuellen Verfahren neu anlegen.
                                      https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                      Marko1974M 1 Antwort Letzte Antwort
                                        @marko1974
                                        Marko1974M Offline
                                        Marko1974M Offline
                                        Marko1974
                                        #99
                                        @thomas-braun einfach löschen?
                                          #100
                                          @marko1974
                                          Prinzip wie hier:
