  4. Javascript.0 Instanz ist deaktiviert
    5.3k
50 Beiträge 6 Kommentatoren 5.0k Aufrufe 4 Beobachtet
  • M mjohn
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    [sudo] Passwort für pi:
    OK:1 http://deb.debian.org/debian bullseye InRelease
    OK:2 http://security.debian.org/debian-security bullseye-security InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:5 https://deb.nodesource.com/node_18.x bullseye InRelease
    Holen:4 http://armbian.systemonachip.net/apt bullseye InRelease [53,3 kB]
    Es wurden 53,3 kB in 2 s geholt (27,3 kB/s).
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    @mjohn
    Dann jetzt mal
    iob diag
      @mjohn
      Dann jetzt mal
      iob diag
      mjohn
      @thomas-braun sagte in Javascript.0 Instanz ist deaktiviert:
      iob diag
                           v.2023-04-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Kernel:                 4.4.192-rockchip64
      Installation:           Native
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     0
      Pending iob updates:    1
      Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                              /usr/bin/node           v18.16.0
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            4.0G        1.2G        2.0G         33M        862M        2.7G
      Swap:           1.0G          0B        1.0G
      Total:          5.0G        1.2G        3.0G
      Active iob-Instances:   23
      Active repo(s): stable
      ioBroker Core:          js-controller           4.0.23
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : ioBroker-Rock                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.web.0                    : web                   : ioBroker-Rock                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                1311
      States:                 1012
      Size of iob-Database:
      5.3M    /opt/iobroker/iobroker-data/objects.jsonl
      872K    /opt/iobroker/iobroker-data/states.jsonl
      und js-controller müsste noch auf 4.0.24 updated werden. Einfach bei laufendem System auf den Button, oder?
      • M mjohn
        iob diag
                             v.2023-04-02
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
        MEMORY:
        Swap:           1.0G          0B        1.0G
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects:                1311
        States:                 1012
        @mjohn sagte in Javascript.0 Instanz ist deaktiviert:
        Nein, den js-controller bekommst du nur bei gestopptem iobroker aktualisiert.
        iob stop
        iob update
        iob upgrade self
        iob start
          iob stop
          iob update
          iob upgrade self
          iob start
          mjohn
          was bedeutet der Update Button unter Host im iobroker?
          • M mjohn
            @mjohn
            Keine Ahnung. Ich kenne die GUI nicht so genau, weil ich die für sowas nicht nutze.
            • M mjohn
              HomoranH Offline
              HomoranH Offline
              klick drauf, und du siehst es ;-)
                @mjohn
                mjohn
                Über deine Befehle gemacht, und alles aktuell, und iob läuft.
                OMG, was für eine Geburt.
                Ich weiß nicht, was ich sagen soll.
                DANKE ist das Mindeste.
                • M mjohn
                  mjohn
                  schrieb am zuletzt editiert von mjohn
                  @mjohn
                  Hi an alle,
                  ich musste leider Mitte Mai und heute iob restarten, da wieder die javascript.0 Instanz deaktiviert war. Fällt immer dann auf, wenn meine Garagentor Statusmeldung über Telegram nicht mehr eintrudeln.
                  Gibt es einen bekannten Bug?
                  Den Adapter stoppen und wieder starten genügt nicht bei mir. Ich muss leider iob restarten.
                  Fehlermeldungen/Protokolle fand ich keine, lediglich die Javascript.0 Instanz war rot und ließ sich nicht wieder anwählen, alle Scripte waren aktiv. Im rechten Scripte Feld, in der Menüzeile oben, wo ich das Script anhalten könnte stand hinter den grünen Doppelbalken in gelb 'Instanz ist deaktiviert'.
                  Außer dass ich dafür ein Script anlege, das natürlich auch nur dann funktioniert, wenn das Javascript nicht abgestürzt ist, fällt mir nichts ein.
                  Gibt es eine evtl. alternative Methode zum Script?
                  Vielen Dank.
                  • ? Offline
                    Moin,
                    Du schreibst leider nicht welche Versionen Du einsetzt, führe doch einmal auf der Kommandozeile den Befehl aus und poste die Lange Version hier in Code Tags </>
                    iob diag
                    Vielleicht ist es aber auch eines Deiner Skripte, das Amok läuft, siehe hier https://forum.iobroker.net/topic/59620/javascript-6-1-0-neue-funktionen-beta
                    Der JavaScript Adapter überwacht ab sofort die Anzahl der setState pro Skript und wenn dies pro Minute mehr als 1000 sind (der Wert ist global im Adapter konfigurierbar) - 1000/Min sind 16 pro Sekunde - wird das Skript beendet! Ein Fehler wird geloggt.
                    Und nicht sagen, dass Du nichts im Log gefunden hast, besser Du zeigst die Log Files, dann können die Wissenden, ich nicht :) besser beurteilen, was da evtl. schiefläuft.
                    Bernd
                      Moin,
                      iob diag
                      Bernd
                      mjohn
                      @dp20eic
                      Danke für die Antwort und entschuldige die Verzögerung. Urlaub und keinen brauchbaren Systemzugriff.
                      In der Zwischenzeit wieder javascript 2x als 'Instanz ist deaktiviert' angezeigt.
                      Einmal nach ca. 4 Wochen ohne Mucken, es genügte auch ein einfacher Adapter RESTART.
                      Danach Javascript Absturz innerhalb von ca. 2 Tagen. Nur über iob RESTART wieder grün.
                      Hier einmal
                      iob diag
                      von gerade eben. Hatte allerdings sowohl OS, als auch 6 Adapter heute Aktualisiert. Insofern nicht die genaue Situation vom Script Absturz.
                                           v.2023-04-16
                      User-ID:                0
                      X-Server:               false
                      Pending iob updates:    0
                      Nodejs-Installation:    /usr/bin/nodejs         v18.16.1
                                              /usr/bin/node           v18.16.1
                                              /usr/bin/npm            9.5.1
                                              /usr/bin/npx            9.5.1
                      MEMORY:
                      Mem:            4.0G        1.2G        1.1G         43M        1.7G        2.7G
                      Swap:           1.0G         18M        1.0G
                      Total:          5.0G        1.2G        2.1G
                      ioBroker Core:          js-controller           4.0.24
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                1460
                      States:                 1151
                      5.7M    /opt/iobroker/iobroker-data/objects.jsonl
                      604K    /opt/iobroker/iobroker-data/states.jsonl
                      Ich hoffe, das hilft etwas weiter. Meine Hoffung ist, dass der neue Javascript Adapter alles fixt.
                      Danke schon jetzt.
                      Thomas BraunT HomoranH ? 3 Antworten Letzte Antwort
                      • M mjohn
                        @dp20eic
                        Hier einmal
                        iob diag
                                             v.2023-04-16
                        User-ID:                0
                        X-Server:               false
                                                /usr/bin/npm            9.5.1
                                                /usr/bin/npx            9.5.1
                        MEMORY:
                        Swap:           1.0G         18M        1.0G
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                1460
                        States:                 1151
                        Danke schon jetzt.
                        @mjohn
                        Hinweis am Rande: NICHT als root herumkaspern. Macht das System nur über kurz oder lang kaputt, wenn man nicht ganz genau weiß was man da warum und wie macht.
                        • M mjohn
                          @dp20eic
                          Hier einmal
                          iob diag
                                               v.2023-04-16
                          User-ID:                0
                          X-Server:               false
                                                  /usr/bin/npm            9.5.1
                                                  /usr/bin/npx            9.5.1
                          MEMORY:
                          Swap:           1.0G         18M        1.0G
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                1460
                          States:                 1151
                          Danke schon jetzt.
                          HomoranH Offline
                          HomoranH Offline
                          nicht, wenn ein Script von dir Amok läuft
                          • M mjohn
                            @dp20eic
                            Hier einmal
                            iob diag
                                                 v.2023-04-16
                            User-ID:                0
                            X-Server:               false
                                                    /usr/bin/npm            9.5.1
                                                    /usr/bin/npx            9.5.1
                            MEMORY:
                            Swap:           1.0G         18M        1.0G
                                                    admin                   6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                1460
                            States:                 1151
                            Danke schon jetzt.
                            Hier einmal
                            iob diag
                            von gerade eben.
                            Moin,
                            danke für die Rückmeldung, es ist aber leider nur die Kurzfassung. In der Langen steht noch vielmehr, was vielleicht von Interesse sein könnte.
                            Das Skript iob diag legt ein Log File an, falls Du nicht alles, was da abgetestet wird, mehr in der Fensterhistorie siehst.
                            Vielleicht steht auch noch etwas im journal
                            journalctl -g java
                            Bernd
                              @mjohn
                              mjohn
                              Danke erneut für den Hinweis nicht als 'root' mit meinen Linux Kenntnissen rumzumachen. Vollständig deiner Meinung.
                              Ich melde mich immer als 'pi' an,
                              login as: pi
                              pi@192.168.178.45's password:
                               ____   ___   ____ _  ____   _  _
                              |  _ \ / _ \ / ___| |/ / /_ | || |
                              | |_) | | | | |   | ' / '_ \| || |_
                              |  _ <| |_| | |___| . \ (_) |__   _|
                              |_| \_\\___/ \____|_|\_\___/   |_|
                              Welcome to Debian Bullseye with Armbian Linux 4.4.192-rockchip64
                              System load:   1.75 0.85 0.67   Up time:       3 days
                              Memory usage:  43 % of 3988MB   IP:            192.168.178.45
                              CPU temp:      55°C
                              Usage of /:    11% of 56G
                              pi@ioBroker-Rock:~$
                              wurde aber bei einigen Befehlen (ich glaube update und/oder full-upgrade) aufgefordert, das root PWD einzugeben.
                              Habe ehrlich nicht darauf geachtet, ob dies eine root-Anmeldung zur Folge hat, oder nur eine einmalige Autorisierung.
                              @Homoran
                              Kann ich eigentlich ausschließen, dass Skript Amok läuft. Wenn meine Skripte üblicherweise wochenlang durchhalten wäre für mich kein grundsätzlicher Fehler vorhanden.
                              Es gibt 10 permanent laufende Skripte. 5 davon sind Abfragen 1x am Tag (u.a. Müll, PV Produktion bis heute), 2 geben eine Messenger Warnung bei Überschreiten ab (max 2x am Tag) und 3 lesen den Modbus der PV aus. Leserate ca. 1x pro Sekunde.
                              @dp20eic
                              hier die Langversion.
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Architecture    : aarch64
                              Docker          : false
                              Virtualization  : none
                              Distributor ID: Debian
                              Description:    Debian GNU/Linux 11 (bullseye)
                              Release:        11
                              Codename:       bullseye
                              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                              NAME="Debian GNU/Linux"
                              VERSION_ID="11"
                              VERSION="11 (bullseye)"
                              VERSION_CODENAME=bullseye
                              ID=debian
                              HOME_URL="https://www.debian.org/"
                              SUPPORT_URL="https://www.debian.org/support"
                              BUG_REPORT_URL="https://bugs.debian.org/"
                              Systemuptime and Load:
                               18:08:55 up 3 days,  3:38,  1 user,  load average: 0.72, 0.91, 0.89
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Sun 2023-07-09 18:08:56 CEST
                                         Universal time: Sun 2023-07-09 16:08:56 UTC
                                               RTC time: Sun 2023-07-09 16:08:56
                                            NTP service: n/a
                                        RTC in local TZ: no
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi dialout sudo audio video plugdev systemd-journal input netdev ssh iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            4.0G        1.8G        126M         43M        2.1G        2.1G
                              Swap:           1.0G          0B        1.0G
                              Total:          5.0G        1.8G        1.1G
                                       3988 M total memory
                                       1760 M used memory
                                       3180 M active memory
                                        530 M inactive memory
                                        125 M free memory
                                        161 M buffer memory
                                       1940 M swap cache
                                       1023 M total swap
                                          0 M used swap
                                       1023 M free swap
                              *** FILESYSTEM ***
                              udev           devtmpfs  2.0G     0  2.0G   0% /dev
                              tmpfs          tmpfs     399M   41M  359M  11% /run
                              /dev/mmcblk0p1 ext4       56G  5.8G   48G  11% /
                              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                              tmpfs          tmpfs     2.0G     0  2.0G   0% /tmp
                              /dev/zram0     ext4       49M   48M     0 100% /var/log
                              tmpfs          tmpfs     399M     0  399M   0% /run/user/1000
                              [Sun Jul  9 18:00:11 2023] EXT4-fs warning (device zram0): ext4_dirent_csum_verify:353: inode #11: comm find: No space for directory leaf checksum. Please run e2fsck -D.
                              [Sun Jul  9 18:00:11 2023] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm find: path /var/log/lost+found: directory fails checksum at offset 4096
                              [Sun Jul  9 18:00:11 2023] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm find: path /var/log/lost+found: directory fails checksum at offset 8192
                              [Sun Jul  9 18:00:11 2023] EXT4-fs error (device zram0): ext4_readdir:189: inode #11: comm find: path /var/log/lost+found: directory fails checksum at offset 12288
                              TARGET         SOURCE                   FSTYPE OPTIONS
                              /              /dev/mmcblk0p1           ext4   rw,noatime,nodiratime,errors=remount-ro,commit=600,data=ordered
                              |-/var/log.hdd /dev/mmcblk0p1[/var/log] ext4   rw,noatime,nodiratime,errors=remount-ro,commit=600,data=ordered
                              `-/var/log     /dev/zram0               ext4   rw,relatime,discard
                              /var:
                              1.5G    /var/
                              1014M   /var/cache
                              1009M   /var/cache/apt
                              910M    /var/cache/apt/archives
                              358M    /var/lib
                              Journal file /var/log/journal/f2f10dbdc16b4a0c88d6af121e6d1d50/user-1000@0005ffd0e8091710-60be34e07cd5bee9.journal~ is truncated, ignoring file.
                              Archived and active journals take up 55.2M in the file system.
                              /opt/iobroker/backups:
                              26M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              237M    /opt/iobroker/iobroker-data/
                              195M    /opt/iobroker/iobroker-data/files
                              72M     /opt/iobroker/iobroker-data/files/telegram.admin
                              52M     /opt/iobroker/iobroker-data/files/javascript.admin
                              48M     /opt/iobroker/iobroker-data/files/telegram.admin/custom/static/js
                              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                              15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                              12M     /opt/iobroker/iobroker-data/objects.jsonl
                              8.0M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js
                              7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js
                              *** NodeJS-Installation ***
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Installed: 18.16.1-deb-1nodesource1
                                Candidate: 18.16.1-deb-1nodesource1
                                Version table:
                               *** 18.16.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                   12.22.12~dfsg-1~deb11u4 500
                                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                   12.22.12~dfsg-1~deb11u3 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              No problems detected
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.5
                              javascript:     7.0.3
                              Adapters from github:   0
                              Adapter State
                              + system.adapter.backitup.0               : backitup              : ioBroker-Rock                            -  enabled
                              + system.adapter.cloud.0                  : cloud                 : ioBroker-Rock                            -  enabled
                              + system.adapter.discovery.0              : discovery             : ioBroker-Rock                            -  enabled
                              + system.adapter.history.0                : history               : ioBroker-Rock                            -  enabled
                                system.adapter.ical.0                   : ical                  : ioBroker-Rock                            -  enabled
                              + system.adapter.javascript.0             : javascript            : ioBroker-Rock                            -  enabled
                              + system.adapter.modbus.0                 : modbus                : ioBroker-Rock                            -  enabled
                              + system.adapter.ping.0                   : ping                  : ioBroker-Rock                            -  enabled
                              + system.adapter.pvforecast.0             : pvforecast            : ioBroker-Rock                            -  enabled
                              + system.adapter.pvforecast.1             : pvforecast            : ioBroker-Rock                            -  enabled
                              + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker-Rock                            -  enabled
                              + system.adapter.signal-cmb.1             : signal-cmb            : ioBroker-Rock                            -  enabled
                                system.adapter.smartmeter.0             : smartmeter            : ioBroker-Rock                            - disabled
                              + system.adapter.socketio.0               : socketio              : ioBroker-Rock                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.telegram.0               : telegram              : ioBroker-Rock                            -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : ioBroker-Rock                            -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : ioBroker-Rock                            -  enabled
                              + system.adapter.tuya.0                   : tuya                  : ioBroker-Rock                            -  enabled
                              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker-Rock                            -  enabled
                              + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : ioBroker-Rock                            -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018ECE257-if00
                              + system.adapter.zigbee.1                 : zigbee                : ioBroker-Rock                            -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220708080640-if00
                              + instance is alive
                              ioBroker-Repositories
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                              Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "ical"         : 1.13.3   , installed 1.13.3
                              Adapter    "javascript"   : 7.0.3    , installed 7.0.3
                              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                              Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                              Adapter    "pvforecast"   : 2.7.1    , installed 2.7.1
                              Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
                              Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
                              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                              Adapter    "text2command" : 3.0.2    , installed 3.0.2
                              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                              Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                              Adapter    "zigbee"       : 1.8.12   , installed 1.8.12
                              Objects and States
                              Objects:        1449
                              States:         1134
                              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:2 http://deb.debian.org/debian bullseye InRelease
                              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Hit:5 http://fi.mirror.armbian.de/apt bullseye InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20271      806/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       21510      806/iobroker.js-con
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2466       1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18330      867/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      110        18343      869/mosquitto
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          2468       1/init
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22752      1368/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22355      1873/io.web.0
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       23194      1895/io.socketio.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          18332      867/sshd: /usr/sbin
                              tcp6       0      0 ::1:1883                :::*                    LISTEN      110        18344      869/mosquitto
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2467       1/init
                              udp        0      0 192.168.178.45:123      0.0.0.0:*                           0          21733      1260/ntpd
                              udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21731      1260/ntpd
                              udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21727      1260/ntpd
                              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       22248      1758/io.tuya.0
                              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       22249      1758/io.tuya.0
                              udp6       0      0 :::111                  :::*                                0          2469       1/init
                              udp6       0      0 fe80::8d9b:2c4a:d7d:123 :::*                                0          21737      1260/ntpd
                              udp6       0      0 ::1:123                 :::*                                0          21735      1260/ntpd
                              udp6       0      0 :::123                  :::*                                0          21724      1260/ntpd
                              2023-07-09 17:24:37.233  - warn: zigbee.1 (116999) DeviceAvailability:Failed to ping 0xf0d1b800001297ae PAR16 RGBW Z3
                              2023-07-09 17:24:37.263  - warn: zigbee.1 (116999) DeviceAvailability:Failed to ping 0xf0d1b80000129a07 PAR16 RGBW Z3
                              2023-07-09 17:24:37.450  - warn: zigbee.1 (116999) DeviceAvailability:Failed to ping 0xf0d1b800001286c0 PAR16 RGBW Z3
                              2023-07-09 17:24:37.645  - warn: zigbee.1 (116999) DeviceAvailability:Failed to ping 0xf0d1b80000128703 PAR16 RGBW Z3
                              2023-07-09 17:34:55.013  - info: admin.0 (1368) ==> Connected system.user.admin from ::ffff:192.168.178.111
                              2023-07-09 17:34:57.994  - info: admin.0 (1368) <== Disconnect system.user.admin from ::ffff:192.168.178.111
                              2023-07-09 17:36:34.832  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:41:19.799  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:41:46.326  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:42:10.472  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:44:03.943  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:47:13.310  - info: history.0 (1553) enabled logging of modbus.0.holdingRegisters.1.40087_W, Alias=false, WriteNulls=false
                              2023-07-09 17:48:48.707  - info: admin.0 (1368) ==> Connected system.user.admin from ::ffff:192.168.178.111
                              2023-07-09 17:54:06.637  - warn: zigbee.0 (116993) DeviceAvailability:Stopping to ping 0x000d6ffffe9cc4fb TRADFRI signal repeater after 4 ping attempts
                              2023-07-09 17:54:07.774  - warn: zigbee.0 (116993) DeviceAvailability:Stopping to ping 0x000d6ffffea6a7e8 TRADFRI signal repeater after 4 ping attempts
                              2023-07-09 17:54:47.222  - warn: zigbee.1 (116999) DeviceAvailability:Stopping to ping 0x000d6ffffe9a7f8f TRADFRI signal repeater after 4 ping attempts
                              2023-07-09 17:55:15.766  - info: javascript.0 (1546) Stop script script.js.common.allg__Skripte.Strom.PV_Haus.Ertrag.SMA5000_2500
                              2023-07-09 17:55:15.942  - info: javascript.0 (1546) Start javascript script.js.common.allg__Skripte.Strom.PV_Haus.Ertrag.SMA5000_2500
                              2023-07-09 17:55:16.001  - info: javascript.0 (1546) script.js.common.allg__Skripte.Strom.PV_Haus.Ertrag.SMA5000_2500: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                              2023-07-09 17:55:28.611  - warn: zigbee.0 (116993) DeviceAvailability:Stopping to ping 0x7cb03eaa00ae74a8 Plug 01 after 4 ping attempts
                              2023-07-09 17:56:02.578  - info: admin.0 (1368) <== Disconnect system.user.admin from ::ffff:192.168.178.111 javascript
                              2023-07-09 17:56:07.637  - warn: zigbee.1 (116999) DeviceAvailability:Stopping to ping 0xf0d1b800001297ae PAR16 RGBW Z3 after 4 ping attempts
                              2023-07-09 17:56:07.661  - warn: zigbee.1 (116999) DeviceAvailability:Stopping to ping 0xf0d1b80000129a07 PAR16 RGBW Z3 after 4 ping attempts
                              2023-07-09 17:56:07.747  - warn: zigbee.1 (116999) DeviceAvailability:Stopping to ping 0xf0d1b800001286c0 PAR16 RGBW Z3 after 4 ping attempts
                              2023-07-09 17:56:07.953  - warn: zigbee.1 (116999) DeviceAvailability:Stopping to ping 0xf0d1b80000128703 PAR16 RGBW Z3 after 4 ping attempts
                              Nach Javascript Update auf 7.0.3. läuft er noch. 🙏
                              Thomas BraunT ? 2 Antworten Letzte Antwort
                              • M mjohn
                                login as: pi
                                CPU temp:      55°C
                                pi@ioBroker-Rock:~$
                                @Homoran
                                @dp20eic
                                Skript v.2023-04-16
                                *** BASE SYSTEM ***
                                Docker          : false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=debian
                                CPU threads: 4
                                              NTP service: n/a
                                          RTC in local TZ: no
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           1.0G          0B        1.0G
                                         3988 M total memory
                                         1760 M used memory
                                          125 M free memory
                                          161 M buffer memory
                                         1940 M swap cache
                                         1023 M total swap
                                            0 M used swap
                                         1023 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.5G    /var/
                                1014M   /var/cache
                                358M    /var/lib
                                /usr/bin/npm            9.5.1
                                /usr/bin/npx            9.5.1
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     7.0.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        1449
                                States:         1134
                                Pending Updates: 0
                                Deswegen macht man das dann per 'sudo BEFEHL_DER_ROOT_RECHTE_BRAUCHT'.
                                Dann fällst du sofort wieder in die user-Rolle zurück.
                                Dein zram ist kaputt:
                                • M mjohn
                                  login as: pi
                                  CPU temp:      55°C
                                  pi@ioBroker-Rock:~$
                                  @Homoran
                                  @dp20eic
                                  Skript v.2023-04-16
                                  *** BASE SYSTEM ***
                                  Docker          : false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=debian
                                  CPU threads: 4
                                                NTP service: n/a
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           1.0G          0B        1.0G
                                           3988 M total memory
                                           1760 M used memory
                                            125 M free memory
                                            161 M buffer memory
                                           1940 M swap cache
                                           1023 M total swap
                                              0 M used swap
                                           1023 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.5G    /var/
                                  1014M   /var/cache
                                  358M    /var/lib
                                  /usr/bin/npm            9.5.1
                                  /usr/bin/npx            9.5.1
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  javascript:     7.0.3
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        1449
                                  States:         1134
                                  Pending Updates: 0
                                  Moin,
                                  ich würde mal einen sauberen Reboot durchführen, und dann bevor ich wieder etwas starte, schauen, was mir das Log voll schreibt, denn irgendetwas geht da in deinem System schief.
                                  Ich bin kein Experte der SBC (Einplatinen Computer), aber ich glaube das zram nicht wirklich etwas bringt, außer, dass du 50 MB vom Hauptspeicher weg nimmst und somit die Kiste noch früher anfängt zu swappen, wenn dann auch noch Swap auf der Ram-Disk liegt wird es noch schlechter.
                                  Besser eine kleine SSD an die Kiste hängen, die sind ja gerade recht günstig, zudem ist ja am Di./Mi. PrimeDay :) und Log/Swap usw. darauf schaufeln.
                                  Bernd
                                    mjohn
                                    Danke erneut für die Hilfe.
                                    Bzgl. zram. Gibt es da etwas, was ich tun kann. Kann ich etwas testen?
                                    Ist hier Hardware das Übel, oder von mir falsche Befehle oder Systemeinstellungen?
                                    Wie oben leicht nachvollziehbar ist meine Kenntnis eher rudimentär. Folglich habe ich den zram nicht
                                    bewusst eingerichtet.
                                    Habe noch ein Argon ONE M.2 Case mit Raspberry Pi 4 incl. SATA SSD, das ich dafür aktivieren könnte. Ich hoffe, ich kann das einfach migrieren, ohne von NULL anzufangen.
                                    Gibt ja eine YT Anleitung.
                                    zram wird sich hoffentlich nicht einschleichen, was immer das auch ist...
                                    • M mjohn
                                      @mjohn
                                      Zu zram kann ich dir nix sagen, hab ich nicht im Einsatz.
