  4. M-TEC Energy Butler
M-TEC Energy Butler
201 Beiträge 21 Kommentatoren 69.6k Aufrufe 18 Beobachtet
  • metaxaM metaxa
    @homoran sagte in M-TEC Energy Butler:
    modbus RTU braucht ein twisted pair davon.
    Der Elektriker hat wie bei der Busverkabelung zwischen den beiden Geräten jeweils ein Pärchen zusammen für A und ein anderes für B sowie für GND genommen.
    gen3 anscheinend Inputregister (30000er)
    Habe Gen3 und so eingetragen
    Ahhhh! Jetzt wird der Adapter schon gesprächiger :-)
    modbus.0
    2023-06-23 21:30:59.005	error	unknown function code: 0x1d, 0x0
    modbus.0
    2023-06-23 21:30:58.993	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:58.978	error	Wrong CRC for frame: 247,3,42,254,0,60,56,165,247,3,120,16,25,16,19,16,24,9,73,0,9,9,72,0,37,9,74,0,10,19,134,0,0,3,103,0,0,1,34,0,0,1,127,0,0,0,30
    modbus.0
    2023-06-23 21:30:58.868	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:58.849	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:58.827	error	Wrong CRC for frame: 247,3,128,232,0,18,120,165,247,3,36,21,198,39,15,0,2,0,249,255,255,255,255,255,255,255,255,0,0,1,7,0,0,0,236,0,0,12,196,0,0,12,185,0,0,0,0,116,195,247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,4,0,0,0,7,0,0,0,15,216,192,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0
    modbus.0
    2023-06-23 21:30:57.506	debug	[DevID_0/inputRegs] Poll address 2999 - 1 registers
    modbus.0
    2023-06-23 21:30:57.506	debug	[DevID_0] Poll start ---------------------
    modbus.0
    2023-06-23 21:30:56.451	warn	Poll error count: 2 code: "ReadInputRegisters: Invalid FC 3"
    modbus.0
    2023-06-23 21:30:56.449	debug	received answer for wrong ID 247, expected 0
    modbus.0
    2023-06-23 21:30:56.305	error	Error response: 9b
    modbus.0
    2023-06-23 21:30:56.240	error	unknown function code: 0x8, 0x29
    modbus.0
    2023-06-23 21:30:56.225	error	unknown function code: 0x0, 0xf
    modbus.0
    2023-06-23 21:30:56.209	error	unknown function code: 0x4e, 0x20
    modbus.0
    2023-06-23 21:30:56.193	error	Error response: 1e
    modbus.0
    2023-06-23 21:30:56.177	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:56.161	error	Wrong CRC for frame: 247,3,42,254,0,60,56,165,247,3,120,16,25,16,20,16,24,9,73,0,9,9,73,0,38,9,74,0,10,19,134,0,0,3,117,0,0,1,34,0,0,1,127,0,0,0,30
    modbus.0
    2023-06-23 21:30:56.049	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:56.033	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-06-23 21:30:56.017	error	Wrong CRC for frame: 247,3,128,232,0,18,120,165,247,3,36,21,198,39,15,0,2,0,249,255,255,255,255,255,255,255,255,0,0,1,7,0,0,0,235,0,0,12,196,0,0,12,185,0,0,0,0,127,132,247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,255,255,255,252,0,0,0,9,0,0,0,0,195,48,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0
    modbus.0
    2023-06-23 21:30:54.215	debug	[DevID_0/inputRegs] Poll address 2999 - 1 registers
    modbus.0
    2023-06-23 21:30:54.213	debug	[DevID_0] Poll start ---------------------
    modbus.0
    2023-06-23 21:30:53.654	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,67,0,5,19,134,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,59,0,41,19,134,0,0,0,0,3,69,0,0,0,0,0,0,0,0,9,69,0,3,19,129,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,3,137,0,0,0,0,0,0,0,0,0,0,0,81,0,0,0,0,0,0,0,0,0,0,3,119,0,0,0,0,0,0,0,0,0,0,0,87,0,0,0,0,0,0,0,0,9,32,0
    modbus.0
    2023-06-23 21:30:53.446	debug	received answer for wrong ID 247, expected 0
    modbus.0
    2023-06-23 21:30:53.303	error	Error response: Value is not accepted by slave
    modbus.0
    2023-06-23 21:30:53.302	error	Error response for FCx119: Illegal Data Value
    modbus.0
    2023-06-23 21:30:53.240	error	Wrong CRC for frame: 247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    modbus.0
    2023-06-23 21:30:53.147	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
    modbus.0
    2023-06-23 21:30:53.144	debug	received answer for wrong ID 247, expected 0
    modbus.0
    2023-06-23 21:30:53.105	error	unknown function code: 0x3b, 0xf7
    modbus.0
    2023-06-23 21:30:51.779	debug	[DevID_0/inputRegs] Poll address 2999 - 1 registers
    modbus.0
    2023-06-23 21:30:51.742	debug	Initialization of scale factors done!
    modbus.0
    2023-06-23 21:30:51.739	debug	[DevID_0] Poll start ---------------------
    modbus.0
    2023-06-23 21:30:51.737	info	Connected to slave
    modbus.0
    2023-06-23 21:30:51.705	debug	connect to serial /dev/ttyUSB1 with 9600
    modbus.0
    2023-06-23 21:30:50.406	debug	Initialize Objects for holdingRegs: []
    modbus.0
    2023-06-23 21:30:50.404	debug	Add inputRegisters.33000_State_of_Charge_(SOC): {"_id":"inputRegisters.33000_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":0,"type":"uint16be","len":1,"offset":0,"factor":1}}
    modbus.0
    2023-06-23 21:30:50.403	debug	Initialize Objects for inputRegs: [{"_address":"33000","name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":2999,"deviceId":0,"id":"inputRegisters.33000_State_of_Charge_(SOC)"}]
    modbus.0
    2023-06-23 21:30:50.401	debug	Initialize Objects for coils: []
    modbus.0
    2023-06-23 21:30:50.398	debug	Initialize Objects for disInputs: []
    modbus.0
    2023-06-23 21:30:49.502	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
    wo stelle ich den falschen Port im Adapter richtig?
    @metaxa sagte in M-TEC Energy Butler:
    Port?
    ist das nicht die Geräte ID? die hast du nicht ausgefüllt
    metaxaM 1 Antwort Letzte Antwort
    • M manrum1
      @metaxa Hallo, ich bin noch am Abwarten, dass meine Anlage vom EVU abgenommen wird. Bis dahin möchte ich nichts an der Anlage verändern. Aber sicher werde ich danach die Anlage anbinden.
      Warne ausdrücklich von der genannten Installationsfirma aus München!!!! (FX-RIDER weiß wovon ich spreche)...
      metaxaM Offline
      metaxaM Offline
      metaxa
      @manrum1 sagte in M-TEC Energy Butler:
      das tue ich auch nicht, mein Solateur hat mir das BUS Kabel angeschlossen
      In diese Versuchung kam ich in Wien nicht :-) aber herzlichen Dank für die Info!
        Port?
        metaxaM Offline
        metaxaM Offline
        metaxa
        Mahhhh, richtig
        Der Fehler ist jetzt einmal weg, bleiben aber noch genügend andere 😰
        modbus.0
        2023-06-23 21:45:17.734	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
        modbus.0
        2023-06-23 21:45:17.701	error	unknown function code: 0x0, 0xef
        modbus.0
        2023-06-23 21:45:17.636	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.620	error	Wrong CRC for frame: 0,3,20,144,90,247,3,128,232,0,18,120,165,247,3,36,21,8,39,15,0,2,0,248,255
        modbus.0
        2023-06-23 21:45:17.527	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,74,0,5,19,136,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,64,0,37,19,134,0,0,0,0,2,225,0,0,0,0,0,0,0,0,9,82,0,3,19,139,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,3,37,0,0,0,0,0,0,0,0,0,0,0,82,0,0,0,0,0,0,0,0,0,0,3,7,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,29,0
        modbus.0
        2023-06-23 21:45:17.341	error	Wrong CRC for frame: 1,1,0,0,0
        modbus.0
        2023-06-23 21:45:17.320	error	unknown function code: 0x0, 0x40
        modbus.0
        2023-06-23 21:45:17.317	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.285	error	unknown function code: 0x26, 0x0
        modbus.0
        2023-06-23 21:45:17.269	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.253	error	Wrong CRC for frame: 247,3,42,254,0,60,56,165,247,3,120,16,41,16,34,16,35,9,78,0,9,9,83,0,34,9,83,0,10,19,134,0,0,3,25,0,0,1,36,0,0,1,129,0,0,0,31
        modbus.0
        2023-06-23 21:45:17.148	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.125	error	unknown function code: 0x0, 0x0
        modbus.0
        2023-06-23 21:45:17.116	error	unknown function code: 0x22, 0x0
        modbus.0
        2023-06-23 21:45:17.095	error	Wrong CRC for frame: 247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247
        modbus.0
        2023-06-23 21:45:16.064	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
        modbus.0
        2023-06-23 21:45:16.055	debug	Initialization of scale factors done!
        modbus.0
        2023-06-23 21:45:16.042	debug	[DevID_247] Poll start ---------------------
        modbus.0
        2023-06-23 21:45:16.041	info	Connected to slave
        • metaxaM metaxa
          Mahhhh, richtig
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          modbus.0
          @metaxa wrong crc hab ich noch nie gehabt
          A/B richtig rum?
            A/B richtig rum?
            metaxaM Offline
            metaxaM Offline
            metaxa
            schrieb am zuletzt editiert von metaxa
            A/B richtig rum?
            Wie gesagt, mein Elektriker hat das gemacht. Aber ich springe mal in den Keller und tausche A/B um.
            hast du den Waveshare?
            Ja, den von dir empfohlenen (habe ihn auf 5V geschalten seitlich).
            • metaxaM metaxa
              A/B richtig rum?
              da hatcder Elektriker auch angeklemmt?
                metaxaM Offline
                metaxaM Offline
                metaxa
                Ja, aber nur am Stecker
                Könnte diese Einstellung auch falsch sein?
                Ich gehe jetzt einmal umklemmen :-)
                HomoranH metaxaM 2 Antworten Letzte Antwort
                • metaxaM metaxa
                  ja, aber die hätte ich auch genommen.
                  Ab jetzt fische ich auch im trüben und würde in den allgemeinen Parametern spielen.
                  Alias mal aus -> was dann?
                  und auch die anderen Checkboxen mal testen
                  • metaxaM metaxa
                    metaxaM Offline
                    metaxaM Offline
                    metaxa
                    Uiiiiiii ..... das sind mehr Fehler als vorher
                    modbus.0
                    2023-06-23 21:59:39.687	info	Disconnected from slave
                    modbus.0
                    2023-06-23 21:59:39.583	error	Wrong CRC for frame: 255,1,2,2,52,252,255
                    modbus.0
                    2023-06-23 21:59:39.567	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.552	error	unknown function code: 0x7e, 0xb5
                    modbus.0
                    2023-06-23 21:59:39.500	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.491	error	Error response: fd
                    modbus.0
                    2023-06-23 21:59:39.470	error	unknown function code: 0x7e, 0xdb
                    modbus.0
                    2023-06-23 21:59:39.441	error	unknown function code: 0x7e, 0x5e
                    modbus.0
                    2023-06-23 21:59:39.393	error	Error response: e2
                    modbus.0
                    2023-06-23 21:59:39.381	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.366	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.348	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.336	error	Error response: f9
                    modbus.0
                    2023-06-23 21:59:39.318	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.302	error	unknown function code: 0x65, 0xff
                    modbus.0
                    2023-06-23 21:59:39.297	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.282	error	Error response: af
                    modbus.0
                    2023-06-23 21:59:39.277	error	Error response: fe
                    modbus.0
                    2023-06-23 21:59:39.259	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.242	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:39.182	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.174	error	Error response: a9
                    modbus.0
                    2023-06-23 21:59:39.158	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.144	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.129	error	Error response: fd
                    modbus.0
                    2023-06-23 21:59:39.110	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:39.093	error	Error response: eb
                    modbus.0
                    2023-06-23 21:59:39.075	error	Wrong CRC for frame: 0,4,126,181,131,239,13,58,0,4,126,247,255,255,255,1,2,2,140,252,255,255,241,255,255,255,255,3,93,0,4,126,108,247,233,201,43,0,4,126,186,169,103,103,179,102,246,182,246,246,44,150,246,182,54,214,54,110,255,255,255,255,131,154,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4,126,181,128,135,143,181,0,4,126,232,183,251,151,247,151,107,97,255
                    modbus.0
                    2023-06-23 21:59:38.686	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    2023-06-23 21:59:38.685	error	Request timed out.
                    modbus.0
                    2023-06-23 21:59:38.684	warn	Error: undefined
                    modbus.0
                    2023-06-23 21:59:36.679	error	Error response: e7
                    modbus.0
                    2023-06-23 21:59:36.664	error	Error response: fb
                    modbus.0
                    2023-06-23 21:59:36.657	error	Error response: fb
                    modbus.0
                    2023-06-23 21:59:36.641	error	unknown function code: 0x7e, 0xdb
                    modbus.0
                    2023-06-23 21:59:36.626	error	unknown function code: 0x7e, 0x5e
                    modbus.0
                    2023-06-23 21:59:36.570	error	Error response: 52
                    modbus.0
                    2023-06-23 21:59:36.564	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.548	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.532	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.523	error	Error response: f9
                    modbus.0
                    2023-06-23 21:59:36.504	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.489	error	unknown function code: 0x65, 0xff
                    modbus.0
                    2023-06-23 21:59:36.483	error	Error response: ff
                    modbus.0
                    2023-06-23 21:59:36.467	error	unknown function code: 0x79, 0xff
                    modbus.0
                    2023-06-23 21:59:36.462	error	Error response: f3
                    modbus.0
                    2023-06-23 21:59:36.444	error	unknown function code: 0x0, 0x4
                    modbus.0
                    2023-06-23 21:59:36.428	error	Wrong CRC for frame: 0,4,126,232,247,251,183,247,151,107,103,255,237,237,103,255,183,237,91,255,235,217,243,254,255,249,241,254,255,253,179,255,255,253,249,254,255,255,193,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,253,157,250,129,250,187,250,129,134,115,225,185,255,255,255,253,255,255,255,253,99,191,101,49,198,129,255,255,173,137,254,255,255,251,91,117,225,1,254,225,253,253,255,127,195,169,134,169,174,111,159,143,235,239,173,247,253,253,255,255,255,255,255,255,255,255,255,255,37,154,0,4,126,69,224,135
                    modbus.0
                    2023-06-23 21:59:36.230	error	Wrong CRC for frame: 0,4,126,108,247,233,201,43,0,4,126,186,169,103,103,179,102,246,182,246,246,44,150,246,182,54,214,54,110,255,255,255,255,131,154,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4,126,108,67,221,107,133,0,4,126,183,251,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,81,94,0,4
                    modbus.0
                    2023-06-23 21:59:33.671	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
                    modbus.0
                    2023-06-23 21:59:33.670	debug	Initialization of scale factors done!
                    modbus.0
                    2023-06-23 21:59:33.667	debug	[DevID_247] Poll start ---------------------
                    modbus.0
                    2023-06-23 21:59:33.665	info	Connected to slave
                    modbus.0
                    2023-06-23 21:59:33.636	debug	connect to serial /dev/ttyUSB1 with 9600
                    modbus.0
                    2023-06-23 21:59:32.476	debug	Initialize Objects for holdingRegs: []
                    modbus.0
                    2023-06-23 21:59:32.473	debug	Add inputRegisters.33000_State_of_Charge_(SOC): {"_id":"inputRegisters.33000_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":247,"type":"uint16be","len":1,"offset":0,"factor":1}}
                    modbus.0
                    2023-06-23 21:59:32.469	debug	Initialize Objects for inputRegs: [{"_address":"33000","name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":2999,"deviceId":247,"id":"inputRegisters.33000_State_of_Charge_(SOC)"}]
                    modbus.0
                    2023-06-23 21:59:32.461	debug	Initialize Objects for coils: []
                    modbus.0
                    2023-06-23 21:59:32.458	debug	Initialize Objects for disInputs: []
                    modbus.0
                    2023-06-23 21:59:31.818	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
                    Klemme wieder zurück!
                    • metaxaM metaxa
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      modbus.0
                      ja! wie blinkt es denn?
                        metaxaM Offline
                        metaxaM Offline
                        metaxa
                        wie blinkt es denn?
                        Kurz nur die rechte LED flackert nach dem Bestromen blau hört aber nach 2 Sekunden wieder auf und bleibt finster, links Power bleibt brav rot.
                        • metaxaM metaxa
                          wie blinkt es denn?
                          @metaxa der müsste jede Sekunde Blinken.
                          Brauchst du so viele Daten? sonst setz das Intervall runter 5000msec müssten vollkommen reichen.
                            metaxaM Offline
                            metaxaM Offline
                            metaxa
                            Habe jetzt wieder zurückgeklemmt, paar von diesen 16Bit Einträgen ausprobiert, es kommt immer dieser "Wrong SRC for frame"
                            modbus.0
                            2023-06-23 22:16:39.630	debug	[DevID_247] Poll start ---------------------
                            modbus.0
                            2023-06-23 22:16:37.896	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,71,0,3,19,134,0,0,0,0,0,41,0,0,0,0,0,0,0,0,9,64,0,38,19,136,0,0,0,0,2,161,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,28,0,0,0,0,0,0,0,0,0,0,2,230,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,173,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,9,27,0
                            modbus.0
                            2023-06-23 22:16:37.561	error	Error response: 28
                            modbus.0
                            2023-06-23 22:16:37.497	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:37.486	error	Wrong CRC for frame: 247,3,128,232,0,18,120,165,247,3,36,19,92,39,15,0,2,0,244,255,255,255,255,255,255,255,255,0,0,1,1,0,0,0,230,0,0,12,195,0,0,12,183,0,0,0,0,226,200,247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,255,255,255,243,0,0,0,7,0,0,0,0,235,1,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0
                            modbus.0
                            2023-06-23 22:16:35.088	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,67,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,67,0,36,19,134,0,0,0,0,2,166,0,0,0,0,0,0,0,0,9,74,0,3,19,138,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,235,0,0,0,0,0,0,0,0,0,0,0,83,0,0,0,0,0,0,0,0,0,0,2,184,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
                            modbus.0
                            2023-06-23 22:16:34.750	error	unknown function code: 0x28, 0xf7
                            modbus.0
                            2023-06-23 22:16:34.687	error	Wrong CRC for frame: 247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
                            modbus.0
                            2023-06-23 22:16:34.589	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:34.574	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,13,0,0,0,7,0,0,0,26,115,95,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
                            modbus.0
                            2023-06-23 22:16:32.338	error	Error response: Value is not accepted by slave
                            modbus.0
                            2023-06-23 22:16:32.337	error	Error response for FCx119: Illegal Data Value
                            modbus.0
                            2023-06-23 22:16:32.275	error	Wrong CRC for frame: 247,3,117,248,0,60,202,176,247,3,120,9,69,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,62,0,35,19,134,0,0,0,0,2,162,0,0,0,0,0,0,0,0,9,76,0,2,19,134,0,0,0,0,0,27,0,0,0,0,0,0,0,0,0,0,2,231,0,0,0,0,0,0,0,0,0,0,0,84,0,0,0,0,0,0,0,0,0,0,2,237,0,0,0,0,0,0,0,0,0,0,0,85,0,0,0,0,0,0,0,0,9,28,0
                            modbus.0
                            2023-06-23 22:16:31.940	error	Error response: 28
                            modbus.0
                            2023-06-23 22:16:31.879	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:31.861	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:31.843	error	unknown function code: 0x3d, 0xf7
                            modbus.0
                            2023-06-23 22:16:31.835	error	unknown function code: 0x0, 0xbe
                            modbus.0
                            2023-06-23 22:16:31.766	error	Wrong CRC for frame: 247,3,42,242,0,8,249,113,247,3,16,0,0,0,0,0,0,0,20,0,0,0,7,0,0,0,33,149,28,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48
                            modbus.0
                            2023-06-23 22:16:29.577	warn	Poll error count: 1 code: "ReadInputRegisters: Invalid FC 3"
                            modbus.0
                            2023-06-23 22:16:29.527	error	Error response: f7
                            modbus.0
                            2023-06-23 22:16:29.468	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.447	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.432	error	unknown function code: 0x53, 0x0
                            modbus.0
                            2023-06-23 22:16:29.416	error	unknown function code: 0x0, 0x0
                            modbus.0
                            2023-06-23 22:16:29.400	error	unknown function code: 0x13, 0x86
                            modbus.0
                            2023-06-23 22:16:29.384	error	unknown function code: 0x0, 0x2
                            modbus.0
                            2023-06-23 22:16:29.371	error	Wrong CRC for frame: 0,3,247,3,39,16,0,11,27,234,247,3,22,90,49,49,50,51,48,48,50,48,56,51,51,48,50,54,49,30,6,0,0,0,0,190,217,247,3,39,121,0,17,74,61,247,3,34,0,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,215,40,247,3,42,254,0,60,56,165,247,3,120,16,25,16,24,16,29,9,73,0,9,9,76,0,32,9,77,0,10,19,135,0,0,3,1,0,0,1,41,0,0,1,134,0,0,0,31,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,176,1,190,1,161,1,190,30,63,15,30,0,0,0,1,0,0,0,1,78,32,78,6,78,45,0,0,41,187,0,0,0,2,81,199,15,255,0,15,1,1,0,64,30,163,30,163,19,93,48,56,10,8,41,4,1,1,0,0,0,0,0,0,0,0,0,0,245,199,247,3,117,248,0,60,202,176,247,3,120,9,68,0,5,19,134,0,0,0,0,0,42,0,0,0,0,0,0,0,0,9,66,0,37
                            modbus.0
                            2023-06-23 22:16:28.445	debug	[DevID_247/inputRegs] Poll address 2999 - 1 registers
                            modbus.0
                            2023-06-23 22:16:28.444	debug	Initialization of scale factors done!
                            modbus.0
                            2023-06-23 22:16:28.440	debug	[DevID_247] Poll start ---------------------
                            modbus.0
                            2023-06-23 22:16:28.438	info	Connected to slave
                            modbus.0
                            2023-06-23 22:16:28.415	debug	connect to serial /dev/ttyUSB1 with 9600
                            modbus.0
                            2023-06-23 22:16:27.710	debug	Initialize Objects for holdingRegs: []
                            modbus.0
                            2023-06-23 22:16:27.709	debug	Add inputRegisters.2999_State_of_Charge_(SOC): {"_id":"inputRegisters.2999_State_of_Charge_(SOC)","type":"state","common":{"name":"Ladezustand der Batterie","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"%"},"native":{"regType":"inputRegs","address":2999,"deviceId":247,"type":"int16le","len":1,"offset":0,"factor":1}}
                            modbus.0
                            2023-06-23 22:16:27.708	debug	Initialize Objects for inputRegs: [{"_address":2999,"name":"State of Charge (SOC)","description":"Ladezustand der Batterie","unit":"%","type":"int16le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":false,"isScale":"","address":2999,"deviceId":247,"id":"inputRegisters.2999_State_of_Charge_(SOC)"}]
                            modbus.0
                            2023-06-23 22:16:27.707	debug	Initialize Objects for coils: []
                            modbus.0
                            2023-06-23 22:16:27.706	debug	Initialize Objects for disInputs: []
                            modbus.0
                            2023-06-23 22:16:27.222	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.1, js-controller: 4.0.24
                            alais Checkbox hat nix verändert.
                            • metaxaM metaxa
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              modbus.0
                              metaxaM Offline
                              metaxaM Offline
                              metaxa
                              Kann ich aus dem LOG erkennen ob da am anderen Ende überhaupt Daten sind, die Busschnittstelle die richtige ist?
                              • metaxaM metaxa
                                @metaxa das versuche ich die ganze Zeit zu erkennen.
                                was sagt denn lsusb?
                                  metaxaM Offline
                                  metaxaM Offline
                                  metaxa
                                  lsusb
                                  andreas@iOProduktiv:~$ lsusb -t
                                  /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                  /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                  /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
                                  /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                      |__ Port 1: Dev 2, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
                                      |__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
                                  /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
                                      |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbfs, 12M
                                  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
                                      |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                                  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
                                  andreas@iOProduktiv:~$ ls -l /dev/serial/by-id
                                  insgesamt 0
                                  lrwxrwxrwx 1 root root 13 23. Jun 19:53 usb-1a86_USB_Serial-if00-port0 -> ../../ttyUSB0
                                  lrwxrwxrwx 1 root root 13 23. Jun 22:09 usb-FTDI_FT232R_USB_UART_A10N5R2A-if00-port0 -> ../../ttyUSB1
                                  • metaxaM metaxa
                                    lsusb
                                    insgesamt 0
                                    @metaxa was hängt denn noch dran?
                                    pi@tinkerboard:~$ ls -l /dev/serial/by-id
                                    insgesamt 0
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:54 usb-FTDI_FT232R_USB_UART_A10NBMVW-if00-port0 -> ../../ttyUSB1
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-FTDI_FT232R_USB_UART_AB0OH9QR-if00-port0 -> ../../ttyUSB2
                                    lrwxrwxrwx 1 root root 13 14. Mai 22:53 usb-Silicon_Labs_CP2104_USB_to_UART_Bridge_Controller_01066523-if00-port0 -> ../../ttyUSB0
                                    ich hab 2 dran
                                      insgesamt 0
                                      ich hab 2 dran
                                      metaxaM Offline
                                      metaxaM Offline
                                      metaxa
                                      NUC -->
                                      1x USB für NUT (APC)
                                      1x USB Hub (Hama)
                                      --> ZigbeeStick
                                      --> Waveshare
                                      • metaxaM metaxa
                                        NUC -->
                                        1x USB Hub (Hama)
                                        --> ZigbeeStick
                                        --> Waveshare
                                        @metaxa dann bist du mit usb1 wohl richtig
                                          metaxaM Offline
                                          metaxaM Offline
                                          metaxa
                                          Ich stehe momentan an, habe keine Idee zur Zeit.
                                          Aber großen Dank zum 100sten Mal für deine Zeit und deine Geduld.
                                          mxa
