  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @ap2017
    i stall vis if you use it, because of an actual bug
    You have to install vis prior to restoring your backup. Known issue.
    1. Error 25 ist very generic, it can have a lot of causes for this error.
    Try
    iob stop
    iob fix
    iob start
    ap2017
    1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
    2. Tried this, did not help.
    iob stop
    iob fix
    iob start
    Here is detailed error message
    $ ./iobroker upgrade echarts
    Update echarts from @1.4.15 to @1.5.1
    NPM version: 8.19.4
    Installing iobroker.echarts@1.5.1... (System call)
    ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
    ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
    • Thomas BraunT Online
      @ap2017
      Do it via command line interface and debug option:
      iobroker upgrade echarts --debug
        @ap2017
        ap2017
        ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
        This upgrade of "echarts" will introduce the following changes:
        -> 1.5.1:
        Error handling in JSON data was improved
        -> 1.5.0:
        Implemented raw data export
        Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
        NPM version: 8.19.4
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm ERR! code 6
        npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
        npm ERR! code 6
        • A ap2017
          -> 1.5.1:
          -> 1.5.0:
          NPM version: 8.19.4
          npm ERR! code 6
          npm ERR! code 6
          @ap2017 sagte in Node.js update:
          npm ERR! code 6
          The broken vis install blocks any other npm actions.
          Try
          iobroker upgrade vis@1.4.10
          Restore your backup again.
          And avoid the beta Repository!
          A 2 Antworten Letzte Antwort
            npm ERR! code 6
            Try
            ap2017
            ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
            This downgrade of "vis" will at least remove the following changes:
            -> 1.4.16
            Corrected connection with "only port" URLs
            -> 1.4.15
            Better check of the offline license
            -> 1.4.14
            Corrected GUI bug
            -> 1.4.13
            The group attributes will be replaced recursively
            -> 1.4.12
            Fixed bug with the export of specific widgets
            -> 1.4.11
            Removed ES6 commands to be supported by older browsers
            Fixed problem with update of grouped widgets
            Added web manifest to be able to handle vis as the web app
            Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
            Update vis from @1.4.16 to @1.4.10
            NPM version: 8.19.4
            Installing iobroker.vis@1.4.10... (System call)
            npm ERR! code 6
            npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
            host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
            ap@AP-Tiny:~$
              npm ERR! code 6
              Try
              ap2017
              @thomas-braun said in Node.js update:
              What do you mean by "Restore your backup again."? I did not do nor restore backup
              • A ap2017
                @ap2017
                I thought you did change your operating system?
                  @ap2017
                  ap2017
                  @thomas-braun Not yet, it will take me a while
                  • A ap2017
                    @ap2017
                    Then take your time and come again when done.
                    • A ap2017
                      iob stop
                      iob fix
                      iob start
                      NPM version: 8.19.4
                      NO!!
                      Don't delete the vis adapter!
                      Just install a "blank" version before restoring.
                        @ap2017
                        ap2017
                        schrieb am zuletzt editiert von ap2017
                        @thomas-braun Installed latest Ubuntu, restored ioBroker from backup (had to use latest beta controller to match with backup), but new installation of ioBroker is set for stable repositories. Everything seems to be working, including VIS. Having a bit of an issue with info adapter. It works for few seconds then turns red with error messages
                        2023-06-16 16:09:19.354 - info: info.0 (3352) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-06-16 16:09:20.660 - info: info.0 (3352) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 5.0.4
                        2023-06-16 16:09:21.033 - info: info.0 (3352) Reading/updating systemdata.
                        2023-06-16 16:09:22.167 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                        2023-06-16 16:09:22.323 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                        2023-06-16 16:09:22.583 - info: info.0 (3352) cpu Temp res = {"main":62,"cores":[62,61],"max":62,"socket":[],"chipset":null}
                        2023-06-16 16:09:25.284 - info: admin.0 (1913) ==> Connected system.user.admin from ::ffff:192.168.1.244
                        2023-06-16 16:09:27.785 - info: host.ap-EB1033 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                        2023-06-16 16:09:31.423 - info: info.0 (3352) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                        Should I change Info objects types to match received vs. set?
                        • A ap2017
                          @ap2017
                          Usually this would be reported as 'Issue' at the GitHub:
                          https://github.com/iobroker-community-adapters/ioBroker.info/issues
                          This may be due to the beta-version of the js-controller. Have seen similar errors with different adapters.
                            @ap2017
                            ap2017
                            @thomas-braun Would it make sense to downgrade controller?
                            • A ap2017
                              @ap2017 To avoid the errors that come with a beta-js-contoller I 'd recommend to downgrade. But it's not that trivial
                              Instructions on how to do a downgrade are only available in German, afaics.
                              https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                                ap2017
                                @thomas-braun Here is what I have in my records to downgrade. This from https://forum.iobroker.net/topic/19885/probleme-nach-js-controller-1-5-6-1-4-2-downgrade?_=1686947115238
                                cd /opt/iobroker
                                iobroker stop
                                npm i iobroker.js-controller@x.x.x --production
                                iobroker start
