  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @ap2017 sagte in Node.js update:
    npm ERR! code 6
    npm ERR! path /opt/iobroker/node_modules/iobroker.vis
    npm ERR! command failed
    npm ERR! command sh -c -- node main.js --install
    The broken vis install blocks any other npm actions.
    Try
    iobroker upgrade vis@1.4.10
    Restore your backup again.
    And avoid the beta Repository!
    ap2017
    ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
    This downgrade of "vis" will at least remove the following changes:
    -> 1.4.16
    Corrected connection with "only port" URLs
    -> 1.4.15
    Better check of the offline license
    -> 1.4.14
    Corrected GUI bug
    -> 1.4.13
    The group attributes will be replaced recursively
    -> 1.4.12
    Fixed bug with the export of specific widgets
    -> 1.4.11
    Removed ES6 commands to be supported by older browsers
    Fixed problem with update of grouped widgets
    Added web manifest to be able to handle vis as the web app
    Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
    Update vis from @1.4.16 to @1.4.10
    NPM version: 8.19.4
    Installing iobroker.vis@1.4.10... (System call)
    npm ERR! code 6
    npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
    host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
    ap@AP-Tiny:~$
      npm ERR! code 6
      Try
      ap2017
      @thomas-braun said in Node.js update:
      What do you mean by "Restore your backup again."? I did not do nor restore backup
      • A ap2017
        @ap2017
        I thought you did change your operating system?
          @ap2017
          ap2017
          @thomas-braun Not yet, it will take me a while
          • A ap2017
            @ap2017
            Then take your time and come again when done.
            • A ap2017
              1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
              2. Tried this, did not help.
              iob stop
              iob fix
              iob start
              Here is detailed error message
              $ ./iobroker upgrade echarts
              Update echarts from @1.4.15 to @1.5.1
              NPM version: 8.19.4
              Installing iobroker.echarts@1.5.1... (System call)
              ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
              ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
              NO!!
              Don't delete the vis adapter!
              Just install a "blank" version before restoring.
                @ap2017
                ap2017
                schrieb am zuletzt editiert von ap2017
                @thomas-braun Installed latest Ubuntu, restored ioBroker from backup (had to use latest beta controller to match with backup), but new installation of ioBroker is set for stable repositories. Everything seems to be working, including VIS. Having a bit of an issue with info adapter. It works for few seconds then turns red with error messages
                2023-06-16 16:09:19.354 - info: info.0 (3352) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2023-06-16 16:09:20.660 - info: info.0 (3352) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 5.0.4
                2023-06-16 16:09:21.033 - info: info.0 (3352) Reading/updating systemdata.
                2023-06-16 16:09:22.167 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                2023-06-16 16:09:22.323 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                2023-06-16 16:09:22.583 - info: info.0 (3352) cpu Temp res = {"main":62,"cores":[62,61],"max":62,"socket":[],"chipset":null}
                2023-06-16 16:09:25.284 - info: admin.0 (1913) ==> Connected system.user.admin from ::ffff:192.168.1.244
                2023-06-16 16:09:27.785 - info: host.ap-EB1033 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                2023-06-16 16:09:31.423 - info: info.0 (3352) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                Should I change Info objects types to match received vs. set?
                • A ap2017
                  @ap2017
                  Usually this would be reported as 'Issue' at the GitHub:
                  https://github.com/iobroker-community-adapters/ioBroker.info/issues
                  This may be due to the beta-version of the js-controller. Have seen similar errors with different adapters.
                    @ap2017
                    ap2017
                    @thomas-braun Would it make sense to downgrade controller?
                    • A ap2017
                      @ap2017 To avoid the errors that come with a beta-js-contoller I 'd recommend to downgrade. But it's not that trivial
                      Instructions on how to do a downgrade are only available in German, afaics.
                      https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                        ap2017
                        @thomas-braun Here is what I have in my records to downgrade. This from https://forum.iobroker.net/topic/19885/probleme-nach-js-controller-1-5-6-1-4-2-downgrade?_=1686947115238
                        cd /opt/iobroker
                        iobroker stop
                        npm i iobroker.js-controller@x.x.x --production
                        iobroker start
