  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @ap2017
    Now check how to upgrade your operating system to the current release.
    'Tessa' is out of any support.
    19.1 'Tessa' (LTS)
    Security Support Ended 2 months and 2 weeks ago
    (01 Apr 2023)
    And run your iob on 'stable' not beta-stage.
    ap2017
    @thomas-braun Here is what I received from Mint support:
    Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
    The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
    CODE: SELECT ALL
    curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
    sudo apt-get install -y nodejs
    To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
    It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
    I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
    • A ap2017
      CODE: SELECT ALL
      @ap2017 sagte in Node.js update:
      Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
      • A ap2017
        CODE: SELECT ALL
        diffi...what?
        backup with backitup
        install new OS
        install iobroker and the latest recommended node with one line
        install vis if you use it, because of an actual bug
        restore the backup
        drink a cup of coffee or what you prefer
        ready
          ap2017
          @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
          My system recovered but I see two issues:
          1. Not able to start VIS, getting message
          File edit.html not found: {}
          1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
          Here is additional info:
          ap@AP-Tiny:/opt/iobroker$ iobroker list instances
            system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
          + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
            system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
            system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
            system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
          + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
            system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
            system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
          + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
          + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
          + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
            system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
          + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
            system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
            system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
            system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
            system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
          + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
          + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
          + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
          + instance is alive
          • A ap2017
            + instance is alive
            @ap2017
            i stall vis if you use it, because of an actual bug
            You have to install vis prior to restoring your backup. Known issue.
            1. Error 25 ist very generic, it can have a lot of causes for this error.
            Try
            iob stop
            iob fix
            iob start
              @ap2017
              Try
              iob stop
              iob fix
              iob start
              ap2017
              1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
              2. Tried this, did not help.
              iob stop
              iob fix
              iob start
              Here is detailed error message
              $ ./iobroker upgrade echarts
              Update echarts from @1.4.15 to @1.5.1
              NPM version: 8.19.4
              Installing iobroker.echarts@1.5.1... (System call)
              ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
              ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
              • Thomas BraunT Online
                @ap2017
                Do it via command line interface and debug option:
                iobroker upgrade echarts --debug
                  @ap2017
                  ap2017
                  ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
                  This upgrade of "echarts" will introduce the following changes:
                  -> 1.5.1:
                  Error handling in JSON data was improved
                  -> 1.5.0:
                  Implemented raw data export
                  Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
                  NPM version: 8.19.4
                  npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                  npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm ERR! code 6
                  npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
                  npm ERR! code 6
                  • A ap2017
                    -> 1.5.1:
                    -> 1.5.0:
                    NPM version: 8.19.4
                    npm ERR! code 6
                    npm ERR! code 6
                    npm ERR! code 6
                    The broken vis install blocks any other npm actions.
                    Try
                    iobroker upgrade vis@1.4.10
                    Restore your backup again.
                    And avoid the beta Repository!
                    A 2 Antworten Letzte Antwort
                      npm ERR! code 6
                      Try
                      ap2017
                      ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
                      This downgrade of "vis" will at least remove the following changes:
                      -> 1.4.16
                      Corrected connection with "only port" URLs
                      -> 1.4.15
                      Better check of the offline license
                      -> 1.4.14
                      Corrected GUI bug
                      -> 1.4.13
                      The group attributes will be replaced recursively
                      -> 1.4.12
                      Fixed bug with the export of specific widgets
                      -> 1.4.11
                      Removed ES6 commands to be supported by older browsers
                      Fixed problem with update of grouped widgets
                      Added web manifest to be able to handle vis as the web app
                      Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
                      Update vis from @1.4.16 to @1.4.10
                      NPM version: 8.19.4
                      Installing iobroker.vis@1.4.10... (System call)
                      npm ERR! code 6
                      npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
                      host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
                      ap@AP-Tiny:~$
                        npm ERR! code 6
                        Try
                        ap2017
                        @thomas-braun said in Node.js update:
                        What do you mean by "Restore your backup again."? I did not do nor restore backup
                        • A ap2017
                          @ap2017
                          I thought you did change your operating system?
                            @ap2017
                            ap2017
                            @thomas-braun Not yet, it will take me a while
                            • A ap2017
                              @ap2017
                              Then take your time and come again when done.
                              • A ap2017
                                iob stop
                                iob fix
                                iob start
                                NPM version: 8.19.4
                                NO!!
                                Don't delete the vis adapter!
                                Just install a "blank" version before restoring.
                                  @ap2017
                                  ap2017
                                  schrieb am zuletzt editiert von ap2017
                                  @thomas-braun Installed latest Ubuntu, restored ioBroker from backup (had to use latest beta controller to match with backup), but new installation of ioBroker is set for stable repositories. Everything seems to be working, including VIS. Having a bit of an issue with info adapter. It works for few seconds then turns red with error messages
                                  2023-06-16 16:09:19.354 - info: info.0 (3352) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                  2023-06-16 16:09:20.660 - info: info.0 (3352) starting. Version 1.9.26 in /opt/iobroker/node_modules/iobroker.info, node: v18.16.0, js-controller: 5.0.4
                                  2023-06-16 16:09:21.033 - info: info.0 (3352) Reading/updating systemdata.
                                  2023-06-16 16:09:22.167 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                                  2023-06-16 16:09:22.323 - info: info.0 (3352) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                                  2023-06-16 16:09:22.583 - info: info.0 (3352) cpu Temp res = {"main":62,"cores":[62,61],"max":62,"socket":[],"chipset":null}
                                  2023-06-16 16:09:25.284 - info: admin.0 (1913) ==> Connected system.user.admin from ::ffff:192.168.1.244
                                  2023-06-16 16:09:27.785 - info: host.ap-EB1033 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                                  2023-06-16 16:09:31.423 - info: info.0 (3352) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                                  Should I change Info objects types to match received vs. set?
                                  • A ap2017
                                    @ap2017
                                    Usually this would be reported as 'Issue' at the GitHub:
                                    https://github.com/iobroker-community-adapters/ioBroker.info/issues
                                    This may be due to the beta-version of the js-controller. Have seen similar errors with different adapters.
                                      @ap2017
                                      ap2017
                                      @thomas-braun Would it make sense to downgrade controller?
                                      • A ap2017
                                        @ap2017 To avoid the errors that come with a beta-js-contoller I 'd recommend to downgrade. But it's not that trivial
                                        Instructions on how to do a downgrade are only available in German, afaics.
                                        https://forum.iobroker.net/topic/66108/js-controller-5-0-x-jetzt-in-der-beta
                                          ap2017
                                          @thomas-braun Here is what I have in my records to downgrade. This from https://forum.iobroker.net/topic/19885/probleme-nach-js-controller-1-5-6-1-4-2-downgrade?_=1686947115238
                                          cd /opt/iobroker
                                          iobroker stop
                                          npm i iobroker.js-controller@x.x.x --production
                                          iobroker start
