  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
  • A ap2017
    @thomas-braun I guess I need to execute admin adapter right?
    @ap2017
    iob start admin
    • A ap2017
      @ap2017 sagte in Node.js update:
      yes, iob start admin
      but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
        ap2017
        @homoran said in Node.js update:
        iob start admin
        Thank you, I am back in business (till the next time)...
        • A ap2017
          iob start admin
          iob start admin
          please read my edit!
          • A ap2017
            iob start admin
            @ap2017
            Now check how to upgrade your operating system to the current release.
            'Tessa' is out of any support.
            19.1 'Tessa' (LTS)
            Security Support Ended 2 months and 2 weeks ago
            (01 Apr 2023)
            And run your iob on 'stable' not beta-stage.
              @ap2017
              19.1 'Tessa' (LTS)
              (01 Apr 2023)
              ap2017
              @thomas-braun Here is what I received from Mint support:
              Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
              The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
              CODE: SELECT ALL
              curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
              sudo apt-get install -y nodejs
              To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
              It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
              I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
              • A ap2017
                CODE: SELECT ALL
                Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                • A ap2017
                  CODE: SELECT ALL
                  diffi...what?
                  backup with backitup
                  install new OS
                  install iobroker and the latest recommended node with one line
                  install vis if you use it, because of an actual bug
                  restore the backup
                  drink a cup of coffee or what you prefer
                  ready
                    ap2017
                    @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
                    My system recovered but I see two issues:
                    1. Not able to start VIS, getting message
                    File edit.html not found: {}
                    1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
                    Here is additional info:
                    ap@AP-Tiny:/opt/iobroker$ iobroker list instances
                      system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
                    + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
                      system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
                      system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
                      system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
                    + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
                      system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
                      system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
                    + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
                    + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
                    + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
                      system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
                    + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
                      system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
                      system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
                      system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
                      system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
                    + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
                    + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                    + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
                    + instance is alive
                    • A ap2017
                      + instance is alive
                      @ap2017
                      i stall vis if you use it, because of an actual bug
                      You have to install vis prior to restoring your backup. Known issue.
                      1. Error 25 ist very generic, it can have a lot of causes for this error.
                      Try
                      iob stop
                      iob fix
                      iob start
                        @ap2017
                        Try
                        iob stop
                        iob fix
                        iob start
                        ap2017
                        1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
                        2. Tried this, did not help.
                        iob stop
                        iob fix
                        iob start
                        Here is detailed error message
                        $ ./iobroker upgrade echarts
                        Update echarts from @1.4.15 to @1.5.1
                        NPM version: 8.19.4
                        Installing iobroker.echarts@1.5.1... (System call)
                        ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
                        ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
                        • Thomas BraunT Online
                          @ap2017
                          Do it via command line interface and debug option:
                          iobroker upgrade echarts --debug
                            @ap2017
                            ap2017
                            ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
                            This upgrade of "echarts" will introduce the following changes:
                            -> 1.5.1:
                            Error handling in JSON data was improved
                            -> 1.5.0:
                            Implemented raw data export
                            Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
                            NPM version: 8.19.4
                            npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm ERR! code 6
                            npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
                            npm ERR! code 6
                            • A ap2017
                              -> 1.5.1:
                              -> 1.5.0:
                              NPM version: 8.19.4
                              npm ERR! code 6
                              npm ERR! code 6
                              npm ERR! code 6
                              The broken vis install blocks any other npm actions.
                              Try
                              iobroker upgrade vis@1.4.10
                              Restore your backup again.
                              And avoid the beta Repository!
                              A 2 Antworten Letzte Antwort
                                npm ERR! code 6
                                Try
                                ap2017
                                ap@AP-Tiny:~$ iobroker upgrade vis@1.4.10
                                This downgrade of "vis" will at least remove the following changes:
                                -> 1.4.16
                                Corrected connection with "only port" URLs
                                -> 1.4.15
                                Better check of the offline license
                                -> 1.4.14
                                Corrected GUI bug
                                -> 1.4.13
                                The group attributes will be replaced recursively
                                -> 1.4.12
                                Fixed bug with the export of specific widgets
                                -> 1.4.11
                                Removed ES6 commands to be supported by older browsers
                                Fixed problem with update of grouped widgets
                                Added web manifest to be able to handle vis as the web app
                                Would you like to downgrade vis from @1.4.16 to @1.4.10 now? [(y)es, (n)o]: y
                                Update vis from @1.4.16 to @1.4.10
                                NPM version: 8.19.4
                                Installing iobroker.vis@1.4.10... (System call)
                                npm ERR! code 6
                                npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T22_28_10_906Z-debug-0.log
                                host.AP-Tiny Cannot install iobroker.vis@1.4.10: 6
                                ap@AP-Tiny:~$
                                  npm ERR! code 6
                                  Try
                                  ap2017
                                  @thomas-braun said in Node.js update:
                                  What do you mean by "Restore your backup again."? I did not do nor restore backup
                                  • A ap2017
                                    @ap2017
                                    I thought you did change your operating system?
                                      @ap2017
                                      ap2017
                                      @thomas-braun Not yet, it will take me a while
                                      • A ap2017
                                        @ap2017
                                        Then take your time and come again when done.
                                        • A ap2017
                                          iob stop
                                          iob fix
                                          iob start
                                          NPM version: 8.19.4
                                          NO!!
                                          Don't delete the vis adapter!
                                          Just install a "blank" version before restoring.
