  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @ap2017
    https://github.com/nodesource/distributions#deb
    Linux Mint 19.1 "Tessa" (via Ubuntu 18.04 LTS) WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
    ap2017
    schrieb am zuletzt editiert von ap2017
    @thomas-braun Do I need to downgrade node.js to 16?
    • A ap2017
      @ap2017
      No, you really really need to upgrade your operating system.
        @ap2017
        ap2017
        @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
        In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
        • A ap2017
          @ap2017 sagte in Node.js update:
          Run
          iob diag
          again so I can see where you are at now.
          A 2 Antworten Letzte Antwort
            Run
            iob diag
            ap2017
            @thomas-braun said in Node.js update:
            iob diag
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            Press any key to continue
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Architecture    : x86_64
            Docker          : false
            Virtualization  : none
            Distributor ID: LinuxMint
            Description:    Linux Mint 19.1 Tessa
            Release:        19.1
            Codename:       tessa
            NAME="Linux Mint"
            VERSION="19.1 (Tessa)"
            ID=linuxmint
            ID_LIKE=ubuntu
            PRETTY_NAME="Linux Mint 19.1"
            VERSION_ID="19.1"
            HOME_URL="https://www.linuxmint.com/"
            SUPPORT_URL="https://forums.linuxmint.com/"
            BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
            PRIVACY_POLICY_URL="https://www.linuxmint.com/"
            VERSION_CODENAME=tessa
            UBUNTU_CODENAME=bionic
            Systemuptime and Load:
             14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
            CPU threads: 4
            *** Time and Time Zones ***
                                  Local time: Wed 2023-06-14 14:21:36 EDT
                              Universal time: Wed 2023-06-14 18:21:36 UTC
                                    RTC time: Wed 2023-06-14 18:21:36
                                   Time zone: America/New_York (EDT, -0400)
            systemd-timesyncd.service active: yes
                             RTC in local TZ: no
            *** User and Groups ***
            ap
            /home/ap
            ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
            *** X-Server-Setup ***
            X-Server:       true
            Desktop:
            Terminal:
            *** MEMORY ***
            Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
            Swap:          2.1G        262K        2.1G
            Total:         6.0G        1.3G        2.6G
                     3768 M total memory
                     1253 M used memory
                     2134 M active memory
                      810 M inactive memory
                      467 M free memory
                      136 M buffer memory
                     1910 M swap cache
                     2047 M total swap
                        0 M used swap
                     2047 M free swap
            *** FILESYSTEM ***
            udev           devtmpfs  1.9G     0  1.9G   0% /dev
            tmpfs          tmpfs     377M  1.3M  376M   1% /run
            /dev/sda1      ext4      220G  132G   77G  64% /
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
            [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            findmnt: unrecognized option '--real'
            Try 'findmnt --help' for more information.
            /var:
            4.2G    /var/
            1.9G    /var/lib
            1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
            1.7G    /var/log
            Archived and active journals take up 1.6G in the file system.
            /opt/iobroker/backups:
            24M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            56G     /opt/iobroker/iobroker-data/
            55G     /opt/iobroker/iobroker-data/history
            429M    /opt/iobroker/iobroker-data/files
            125M    /opt/iobroker/iobroker-data/history/20210321
            125M    /opt/iobroker/iobroker-data/history/20210320
            23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
            20M     /opt/iobroker/iobroker-data/objects.jsonl
            20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v16.20.0
            /usr/bin/node           v16.20.0
            /usr/bin/npm            8.19.4
            /usr/bin/npx            8.19.4
            nodejs:
              Installed: 16.20.0-deb-1nodesource1
              Candidate: 16.20.0-deb-1nodesource1
              Version table:
             *** 16.20.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                 8.10.0~dfsg-2ubuntu0.4 500
                    500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
                 8.10.0~dfsg-2ubuntu0.2 500
                    500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
                 8.10.0~dfsg-2 500
                    500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.2
            admin:          6.5.7
            javascript:     7.0.8
            Adapters from github:   0
            Adapter State
              system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
              system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
              system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
              system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
            + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
              system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
              system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
            + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
            + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
            + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
              system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
            + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
              system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
            + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
              system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
              system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
              system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
            + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
            + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
            + instance is alive
            ioBroker-Repositories
            Stable (default): http://download.iobroker.net/sources-dist.json
            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
            Active repo(s): Beta (latest)
            Installed ioBroker-Instances
            Used repository: Beta (latest)
            Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
            Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
            Adapter    "backitup"     : 2.6.23   , installed 2.6.23
            Adapter    "cloud"        : 4.4.1    , installed 4.4.1
            Adapter    "deconz"       : 1.3.21   , installed 1.3.21
            Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
            Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
            Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
            Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
            Adapter    "socketio"     : 6.3.5    , installed 6.3.5
            Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
            Adapter    "telegram"     : 1.15.6   , installed 1.15.6
            Adapter    "vis-material" : 0.1.3    , installed 0.1.3
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "web"          : 5.5.3    , installed 5.5.3
            Adapter    "ws"           : 2.3.6    , installed 2.3.6
            Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
            Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
            Objects and States
            Objects:        3955
            States:         3402
            Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
            Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
            Ign:4 http://packages.linuxmint.com tessa InRelease
            Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
            Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
            Hit:7 http://packages.linuxmint.com tessa Release
            Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
            Hit:9 http://phoscon.de/apt/deconz bionic InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
            udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
            udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
            udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
            2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
            2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
            2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
            2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
            2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
            2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
            2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
            2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
            2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
            2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
            2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
            2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
            2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
            iob diag has finished.
              Run
              iob diag
              ap2017
              @thomas-braun I guess I need to execute admin adapter right?
              • A ap2017
                @ap2017
                iob start admin
                • A ap2017
                  yes, iob start admin
                  but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                    ap2017
                    @homoran said in Node.js update:
                    iob start admin
                    Thank you, I am back in business (till the next time)...
                    • A ap2017
                      iob start admin
                      iob start admin
                      please read my edit!
                      • A ap2017
                        iob start admin
                        @ap2017
                        Now check how to upgrade your operating system to the current release.
                        'Tessa' is out of any support.
                        19.1 'Tessa' (LTS)
                        Security Support Ended 2 months and 2 weeks ago
                        (01 Apr 2023)
                        And run your iob on 'stable' not beta-stage.
                          @ap2017
                          19.1 'Tessa' (LTS)
                          (01 Apr 2023)
                          ap2017
                          @thomas-braun Here is what I received from Mint support:
                          Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                          The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                          CODE: SELECT ALL
                          curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                          sudo apt-get install -y nodejs
                          To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                          It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                          I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                          • A ap2017
                            CODE: SELECT ALL
                            Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                            • A ap2017
                              CODE: SELECT ALL
                              diffi...what?
                              backup with backitup
                              install new OS
                              install iobroker and the latest recommended node with one line
                              install vis if you use it, because of an actual bug
                              restore the backup
                              drink a cup of coffee or what you prefer
                              ready
                                ap2017
                                @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
                                My system recovered but I see two issues:
                                1. Not able to start VIS, getting message
                                File edit.html not found: {}
                                1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
                                Here is additional info:
                                ap@AP-Tiny:/opt/iobroker$ iobroker list instances
                                + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
                                + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
                                + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
                                + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
                                + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                                + instance is alive
                                • A ap2017
                                  + instance is alive
                                  @ap2017
                                  i stall vis if you use it, because of an actual bug
                                  You have to install vis prior to restoring your backup. Known issue.
                                  1. Error 25 ist very generic, it can have a lot of causes for this error.
                                  Try
                                  iob stop
                                  iob fix
                                  iob start
                                    @ap2017
                                    Try
                                    iob stop
                                    iob fix
                                    iob start
                                    ap2017
                                    1. Assuming that I have to delete VIS adapter and add it back. Will all my screens stay in the system?
                                    2. Tried this, did not help.
                                    iob stop
                                    iob fix
                                    iob start
                                    Here is detailed error message
                                    $ ./iobroker upgrade echarts
                                    Update echarts from @1.4.15 to @1.5.1
                                    NPM version: 8.19.4
                                    Installing iobroker.echarts@1.5.1... (System call)
                                    ERROR: npm ERR! code 6npm ERR! path /opt/iobroker/node_modules/iobroker.visnpm ERR! command failednpm ERR! command sh -c -- node main.js --installnpm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T20_57_44_562Z-debug-0.log
                                    ERROR: host.AP-Tiny Cannot install iobroker.echarts@1.5.1: 6
                                    • Thomas BraunT Online
                                      @ap2017
                                      Do it via command line interface and debug option:
                                      iobroker upgrade echarts --debug
                                        @ap2017
                                        ap2017
                                        ap@AP-Tiny:/opt/iobroker$ iobroker upgrade echarts --debug
                                        This upgrade of "echarts" will introduce the following changes:
                                        -> 1.5.1:
                                        Error handling in JSON data was improved
                                        -> 1.5.0:
                                        Implemented raw data export
                                        Would you like to upgrade echarts from @1.4.15 to @1.5.1 now? [(y)es, (n)o]: y
                                        NPM version: 8.19.4
                                        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        npm ERR! code 6
                                        npm ERR!     /home/iobroker/.npm/_logs/2023-06-14T21_31_07_618Z-debug-0.log
                                        npm ERR! code 6
                                        • A ap2017
                                          -> 1.5.1:
                                          -> 1.5.0:
                                          NPM version: 8.19.4
                                          npm ERR! code 6
                                          npm ERR! code 6
                                          npm ERR! code 6
                                          The broken vis install blocks any other npm actions.
                                          Try
                                          iobroker upgrade vis@1.4.10
                                          Restore your backup again.
                                          And avoid the beta Repository!
