  2. English
  3. ioBroker general
  4. Node.js update
    6.6k
Node.js update
Geplant Angeheftet Gesperrt Verschoben ioBroker general
node.js
39 Beiträge 3 Kommentatoren 9.3k Aufrufe 3 Beobachtet
    @ap2017
    Check the situation:
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    For even more details on your system use
    iob diag
    If you can understand German, please also check the instructions regarding nodejs in my signature.
    ap2017
    schrieb am zuletzt editiert von ap2017
    @thomas-braun said in Node.js update:
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Not sure what you mean by checking situation. I am not getting any response from the system after running line 1 and 2
    • A ap2017
      iob diag
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Architecture    : x86_64
      Docker          : false
      Virtualization  : none
      Distributor ID: LinuxMint
      Description:    Linux Mint 19.1 Tessa
      Release:        19.1
      Codename:       tessa
      NAME="Linux Mint"
      VERSION="19.1 (Tessa)"
      ID=linuxmint
      ID_LIKE=ubuntu
      PRETTY_NAME="Linux Mint 19.1"
      VERSION_ID="19.1"
      HOME_URL="https://www.linuxmint.com/"
      SUPPORT_URL="https://forums.linuxmint.com/"
      BUG_REPORT_URL="http://linuxmint-troubleshooting-guide.readthedocs.io/en/latest/"
      PRIVACY_POLICY_URL="https://www.linuxmint.com/"
      VERSION_CODENAME=tessa
      UBUNTU_CODENAME=bionic
      Systemuptime and Load:
       16:21:23 up 20:38,  2 users,  load average: 0.10, 0.05, 0.02
      CPU threads: 4
      *** Time and Time Zones ***
                            Local time: Tue 2023-06-13 16:21:23 EDT
                        Universal time: Tue 2023-06-13 20:21:23 UTC
                              RTC time: Tue 2023-06-13 20:21:23
                             Time zone: America/New_York (EDT, -0400)
      systemd-timesyncd.service active: yes
                       RTC in local TZ: no
      *** User and Groups ***
      ap
      /home/ap
      ap adm dialout cdrom sudo dip plugdev lpadmin sambashare iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:           3.9G        494M        1.2G         45M        2.2G        3.0G
      Swap:          2.1G          0B        2.1G
      Total:         6.0G        494M        3.3G
               3768 M total memory
                483 M used memory
               1418 M active memory
                567 M inactive memory
               1155 M free memory
                666 M buffer memory
               1462 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     377M  1.2M  376M   1% /run
      /dev/sda1      ext4      220G  131G   78G  63% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      tmpfs          tmpfs     377M   20K  377M   1% /run/user/1000
      [Mon Jun 12 19:42:48 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Jun 12 19:42:49 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      findmnt: unrecognized option '--real'
      Try 'findmnt --help' for more information.
      /var:
      3.8G    /var/
      1.9G    /var/lib
      1.7G    /var/log/journal/82929df7ee394b73b81252fe3b4e5020
      1.7G    /var/log
      Archived and active journals take up 1.6G in the file system.
      /opt/iobroker/backups:
      24M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      56G     /opt/iobroker/iobroker-data/
      55G     /opt/iobroker/iobroker-data/history
      429M    /opt/iobroker/iobroker-data/files
      125M    /opt/iobroker/iobroker-data/history/20210321
      125M    /opt/iobroker/iobroker-data/history/20210320
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.de9334af.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.e7d9968b.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.de9334af.js.map
      20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.52d0ccae.js.map
      *** NodeJS-Installation ***
      /home/iobroker/.diag.sh: line 166: nodejs: command not found
      /home/iobroker/.diag.sh: line 167: node: command not found
      /home/iobroker/.diag.sh: line 168: npm: command not found
      /home/iobroker/.diag.sh: line 169: npx: command not found
      /home/iobroker/.diag.sh: line 175: nodejs: command not found
      /home/iobroker/.diag.sh: line 176: node: command not found
      /home/iobroker/.diag.sh: line 177: npm: command not found
      /home/iobroker/.diag.sh: line 178: npx: command not found
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: (none)
        Candidate: 18.16.0-deb-1nodesource1
        Version table:
           18.16.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bionic/main amd64 Packages
           8.10.0~dfsg-2ubuntu0.4 500
              500 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
           8.10.0~dfsg-2ubuntu0.2 500
              500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
           8.10.0~dfsg-2 500
              500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      sudo: node: command not found
      Core adapters versions
      js-controller:
      admin:
      javascript:
      /home/iobroker/.diag.sh: line 248: npm: command not found
      Adapters from github:   0
      Adapter State
      ioBroker-Repositories
      Installed ioBroker-Instances
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://security.ubuntu.com/ubuntu bionic-security InRelease
      Hit:2 http://archive.canonical.com/ubuntu bionic InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu bionic InRelease
      Ign:4 http://packages.linuxmint.com tessa InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
      Hit:6 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
      Hit:7 https://deb.nodesource.com/node_18.x bionic InRelease
      Hit:8 http://packages.linuxmint.com tessa Release
      Hit:9 http://phoscon.de/apt/deconz bionic InRelease
      Reading package lists...
      Pending Updates: 133
      *** Listening Ports ***
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        17852      677/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30232      818/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          494799     13412/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          30234      818/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          494798     13412/cupsd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          494804     13414/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        24257      690/avahi-daemon: r
      udp        0      0 0.0.0.0:57102           0.0.0.0:*                           115        24259      690/avahi-daemon: r
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        17851      677/systemd-resolve
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          28412      1091/dhclient
      udp6       0      0 :::48359                :::*                                115        24260      690/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                115        24258      690/avahi-daemon: r
      2023-06-12 19:29:38.392  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c138375c1e064d = false
      2023-06-12 19:29:38.394  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c138375c1e064d = 0
      2023-06-12 19:29:38.397  - debug: zigbee.0 (13952) DeviceAvailability:Publish available for 0xa4c13855ba4e66b6 = false
      2023-06-12 19:29:38.399  - debug: zigbee.0 (13952) DeviceAvailability:Publish LQ for 0xa4c13855ba4e66b6 = 0
      2023-06-12 19:29:38.403  - info: zigbee.0 (13952) Zigbee: disabling joining new devices.
      2023-06-12 19:29:38.799  - info: zigbee.0 (13952) Got terminate signal TERMINATE_YOURSELF
      2023-06-12 19:29:38.884  - info: zwave2.0 (14596) terminating
      2023-06-12 19:29:38.885  - info: host.AP-Tiny instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:38.896  - info: zigbee.0 (13952) terminating
      2023-06-12 19:29:38.897  - debug: zigbee.0 (13952) Plugin sentry destroyed
      2023-06-12 19:29:38.898  - info: zigbee.0 (13952) Terminated (NO_ERROR): Without reason
      2023-06-12 19:29:38.950  - info: host.AP-Tiny instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:38.998  - info: host.AP-Tiny instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:39.031  - info: host.AP-Tiny instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:39.077  - info: host.AP-Tiny instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:39.157  - info: host.AP-Tiny instance system.adapter.zwave2.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:39.247  - info: host.AP-Tiny instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:39.324  - info: host.AP-Tiny stopInstance system.adapter.zigbee.0 killing pid 13952
      2023-06-12 19:29:39.370  - warn: host.AP-Tiny instance system.adapter.zigbee.0 terminated due to SIGTERM
      2023-06-12 19:29:39.370  - info: host.AP-Tiny instance system.adapter.zigbee.0 terminated with code null ()
      2023-06-12 19:29:39.789  - info: history.0 (13935) terminating
      2023-06-12 19:29:39.793  - info: history.0 (13935) Terminated (NO_ERROR): Without reason
      2023-06-12 19:29:40.348  - info: host.AP-Tiny instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2023-06-12 19:29:40.349  - info: host.AP-Tiny All instances are stopped.
      2023-06-12 19:29:40.422  - info: host.AP-Tiny terminated
      iob diag has finished.
      Press any key for a summary
      Copy text starting here:
                           v.2023-04-16
      Operatingsystem:        Linux Mint 19.1 Tessa
      Kernel:                 4.15.0-65-generic
      Installation:           Native
      Timezone:                zone: America/New_York (EDT, -0400)
      User-ID:                1000
      X-Server:               true
      Pending OS-Updates:     133
      Pending iob updates:    0
      /home/iobroker/.diag.sh: line 340: nodejs: command not found
      Nodejs-Installation:
      /home/iobroker/.diag.sh: line 341: node: command not found
      /home/iobroker/.diag.sh: line 342: npm: command not found
      /home/iobroker/.diag.sh: line 343: npx: command not found
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:           3.9G        496M        1.2G         45M        2.2G        3.0G
      Swap:          2.1G          0B        2.1G
      Total:         6.0G        496M        3.3G
      Active iob-Instances:   0
      ioBroker Core:          js-controller
                              admin
      ioBroker Status:
      Objects:                0
      States:                 0
      Size of iob-Database:
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      6.9M    /opt/iobroker/iobroker-data/objects.json.migrated
      6.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      9.0M    /opt/iobroker/iobroker-data/states.jsonl
      424K    /opt/iobroker/iobroker-data/states.json.migrated
      424K    /opt/iobroker/iobroker-data/states.json.bak.migrated
      0       /opt/iobroker/iobroker-data/states.json.broken
      @ap2017
      Too old.
      Keep your OS Up-to-date.
      Node@18 won't build on Bionic based Distributions.
      • A ap2017
        @ap2017
        Try
        sudo apt install nodejs
        A DuffyD 2 Antworten Letzte Antwort
        • A ap2017
          @ap2017
          https://github.com/nodesource/distributions#deb
          Linux Mint 19.1 "Tessa" (via Ubuntu 18.04 LTS) WARNING: BUILD SYSTEM CURRENTLY BROKEN FOR NODEJS 18+
            @ap2017
            Try
            ap2017
            ap@AP-Tiny:~$ sudo apt install nodejs
            Reading package lists... Done
            Building dependency tree
            Some packages could not be installed. This may mean that you have
            requested an impossible situation or if you are using the unstable
            distribution that some required packages have not yet been created
            or been moved out of Incoming.
            The following information may help to resolve the situation:
            The following packages have unmet dependencies:
             nodejs : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6 is to be installed
            N: Ignoring file 'deconz.list.save.2' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
            N: Ignoring file 'deconz.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
            N: Ignoring file 'deconz.list.save.3' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
            E: Unable to correct problems, you have held broken packages.
            ap@AP-Tiny:~$
              @ap2017
              ap2017
              @thomas-braun Do I need to downgrade node.js to 16?
              • A ap2017
                @ap2017
                No, you really really need to upgrade your operating system.
                  @ap2017
                  ap2017
                  @thomas-braun I updated OS within current release 19.1 - did not help, waiting for instructions from Mint on how to update to newer release.
                  In the mean time, I installed node.js 16 and everything started to work, I was able to log in to system from web interface. I started updating ADMIN adapter and lost ability to log in via web browser again. Interestingly, the control script is working - I see responses to sensors, but I am not able to get into system via browser, Any ideas?
                  • A ap2017
                    @ap2017 sagte in Node.js update:
                    Run
                    iob diag
                    again so I can see where you are at now.
                    A 2 Antworten Letzte Antwort
                      Run
                      iob diag
                      ap2017
                      iob diag
                      Skript v.2023-04-16
                      *** BASE SYSTEM ***
                      Docker          : false
                      Release:        19.1
                      Codename:       tessa
                      NAME="Linux Mint"
                      ID=linuxmint
                      ID_LIKE=ubuntu
                      VERSION_ID="19.1"
                       14:21:35 up 47 min,  2 users,  load average: 0.07, 0.04, 0.05
                      CPU threads: 4
                                            Local time: Wed 2023-06-14 14:21:36 EDT
                                        Universal time: Wed 2023-06-14 18:21:36 UTC
                                              RTC time: Wed 2023-06-14 18:21:36
                                       RTC in local TZ: no
                      ap
                      /home/ap
                      X-Server:       true
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:           3.9G        1.3G        478M        118M        2.1G        2.2G
                      Swap:          2.1G        262K        2.1G
                      Total:         6.0G        1.3G        2.6G
                               3768 M total memory
                               1253 M used memory
                               2134 M active memory
                                810 M inactive memory
                                467 M free memory
                                136 M buffer memory
                               1910 M swap cache
                               2047 M total swap
                                  0 M used swap
                               2047 M free swap
                      *** FILESYSTEM ***
                      tmpfs          tmpfs     377M  1.3M  376M   1% /run
                      /dev/sda1      ext4      220G  132G   77G  64% /
                      tmpfs          tmpfs     377M   28K  377M   1% /run/user/1000
                      [Wed Jun 14 13:34:25 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                      [Wed Jun 14 13:34:27 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                      /var:
                      4.2G    /var/
                      1.9G    /var/lib
                      1.7G    /var/log
                      20M     /opt/iobroker/iobroker-data/objects.jsonl
                      /usr/bin/nodejs         v16.20.0
                      /usr/bin/node           v16.20.0
                      /usr/bin/npm            8.19.4
                      /usr/bin/npx            8.19.4
                      nodejs:
                        Installed: 16.20.0-deb-1nodesource1
                        Candidate: 16.20.0-deb-1nodesource1
                        Version table:
                       *** 16.20.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bionic/main amd64 Packages
                           8.10.0~dfsg-2 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      js-controller:  5.0.2
                      admin:          6.5.7
                      javascript:     7.0.8
                      Adapter State
                        system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  - disabled
                        system.adapter.admin.0                  : admin                 : AP-Tiny                                  - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0               : backitup              : AP-Tiny                                  - disabled
                        system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
                        system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
                      + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
                        system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
                        system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
                      + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
                      + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
                      + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
                        system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        system.adapter.socketio.0               : socketio              : AP-Tiny                                  - disabled, port: 8084, bind: 192.168.1.74, run as: admin
                        system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
                        system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
                        system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
                        system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
                      + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                      + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
                      + instance is alive
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                      Active repo(s): Beta (latest)
                      Used repository: Beta (latest)
                      Adapter    "accuweather"  : 1.2.4    , installed 1.2.4
                      Adapter    "admin"        : 6.5.8    , installed 6.5.7  [Updatable]
                      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
                      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
                      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
                      Adapter    "echarts"      : 1.5.1    , installed 1.4.15 [Updatable]
                      Adapter    "history"      : 2.2.4    , installed 2.2.4
                      Adapter    "javascript"   : 7.1.0    , installed 7.0.8  [Updatable]
                      Controller "js-controller": 5.0.3    , installed 5.0.2  [Updatable]
                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                      Adapter    "mysensors"    : 3.0.0    , installed 3.0.0
                      Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                      Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                      Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                      Adapter    "web"          : 5.5.3    , installed 5.5.3
                      Adapter    "ws"           : 2.3.6    , installed 2.3.6
                      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                      Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
                      Objects and States
                      Objects:        3955
                      States:         3402
                      Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
                      Hit:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
                      Hit:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
                      Hit:5 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
                      Hit:6 https://deb.nodesource.com/node_16.x bionic InRelease
                      Hit:7 http://packages.linuxmint.com tessa Release
                      Hit:8 http://archive.canonical.com/ubuntu bionic InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27152      807/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27102      807/iobroker.js-con
                      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22290      630/systemd-resolve
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          27647      816/sshd
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          23220      712/cupsd
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33556      1983/io.web.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          32769      816/sshd
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33684      2397/io.simple-api.
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          23219      712/cupsd
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25966      695/avahi-daemon: r
                      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22289      630/systemd-resolve
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          29500      1120/dhclient
                      udp        0      0 0.0.0.0:32983           0.0.0.0:*                           115        25968      695/avahi-daemon: r
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          23232      747/cups-browsed
                      udp6       0      0 :::5353                 :::*                                115        25967      695/avahi-daemon: r
                      udp6       0      0 :::58743                :::*                                115        25969      695/avahi-daemon: r
                      2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                      2023-06-14 14:20:54.236  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                      2023-06-14 14:20:54.237  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854235,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:20:54.262  - debug: zigbee.0 (1725) Publish {"state":"OFF"} to "00124b0022419f47"
                      2023-06-14 14:20:54.266  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854266,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:20:54.267  - debug: zigbee.0 (1725) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Received Zigbee message from '0x00124b0022419f47', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
                      2023-06-14 14:20:54.268  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:20:54.269  - debug: zigbee.0 (1725) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"mapped":{"exposes":[{"type":"switch","features":[{"type":"binary","name":"state","property":"state","access":7,"value_on":"ON","value_off":"OFF","description":"On/off state of the switch","value_toggle":"TOGGLE"}]},{"type":"enum","name":"power_on_behavior","property":"power_on_behavior","access":7,"values":["off","on","toggle","previous"],"description":"Controls the behavior when the device is powered on after power loss"},{"type":"numeric","name":"linkquality","property":"linkquality","access":1,"unit":"lqi","description":"Link quality (signal strength)","value_min":0,"value_max":255}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]}],"zigbeeModel":["SA-003-Zigbee"],"model":"SA-003-Zigbee","vendor":"eWeLink","description":"Zigbee smart plug","options":[]},"name":"0x00124b0022419f47"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":17,"_type":"Router","_ieeeAddr":"0x00124b0022419f47","_networkAddress":1904,"_manufacturerID":0,"_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":1,"profileID":260,"deviceID":9,"inputClusters":[0,3,4,5,6],"outputClusters":[0],"deviceNetworkAddress":1904,"deviceIeeeAddress":"0x00124b0022419f47","clusters":{"genBasic":{"attributes":{"modelId":"SA-003-Zigbee","manufacturerName":"eWeLink","powerSource":1,"zclVersion":1,"appVersion":3,"hwVersion":1,"dateCode":"20200702","swBuildId":"1.0.3"}},"genOnOff":{"attributes":{"onOff":0}}},"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00124b0014da43bb","endpointID":1}],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_manufacturerName":"eWeLink","_powerSource":"Mains (single phase)","_modelID":"SA-003-Zigbee","_applicationVersion":3,"_zclVersion":1,"_hardwareVersion":1,"_dateCode":"20200702","_softwareBuildID":"1.0.3","_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":true,"_skipTimeResponse":false,"meta":{"configured":1},"_lastSeen":1686766854267,"_defaultSendRequestWhen":"immediate","_linkquality":43},"endpoint":"[Circular]","data":{"onOff":0},"linkquality":43,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":56,"manufacturerCode":null,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
                      2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13895a0a783f8 TS0207 was last seen '5077.171' seconds ago.
                      2023-06-14 14:21:22.550  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00044678ff lumi.sensor_switch.aq3 was last seen '3689232.264' seconds ago.
                      2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00124b0022658a2b WB01 was last seen '304.075' seconds ago.
                      2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d00045a362e lumi.sensor_wleak.aq1 was last seen '703.242' seconds ago.
                      2023-06-14 14:21:22.552  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x04cf8cdf3c79009e lumi.sen_ill.mgl01 was last seen '177.775' seconds ago.
                      2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006ea578f lumi.sensor_wleak.aq1 was last seen '1047.042' seconds ago.
                      2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e9796b lumi.sensor_wleak.aq1 was last seen '1620.726' seconds ago.
                      2023-06-14 14:21:22.554  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006e97800 lumi.sensor_wleak.aq1 was last seen '917.723' seconds ago.
                      2023-06-14 14:21:22.555  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0x00158d0006f93fb0 lumi.sensor_wleak.aq1 was last seen '561.83' seconds ago.
                      2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138206a165e63 TS0207 was last seen '1379.288' seconds ago.
                      2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13808caa1c4e6 TS0207 was last seen '4434.999' seconds ago.
                      2023-06-14 14:21:22.556  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c138375c1e064d TS0207 was last seen '2260.278' seconds ago.
                      2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c13855ba4e66b6 TS0207 was last seen '8996.791' seconds ago.
                      2023-06-14 14:21:22.557  - debug: zigbee.0 (1725) DeviceAvailability:Non-pingable device 0xa4c1388acbf249aa TS0011 was last seen '14447731.067' seconds ago.
                        Run
                        iob diag
                        ap2017
                        @thomas-braun I guess I need to execute admin adapter right?
                        • A ap2017
                          @ap2017
                          iob start admin
                          • A ap2017
                            yes, iob start admin
                            but you will encounter a lot of more or less severe problens, because you have installed beta versions of several adapters and the brand new bleeding edge js-controller
                              ap2017
                              @homoran said in Node.js update:
                              iob start admin
                              Thank you, I am back in business (till the next time)...
                              • A ap2017
                                iob start admin
                                iob start admin
                                please read my edit!
                                • A ap2017
                                  iob start admin
                                  @ap2017
                                  Now check how to upgrade your operating system to the current release.
                                  'Tessa' is out of any support.
                                  19.1 'Tessa' (LTS)
                                  Security Support Ended 2 months and 2 weeks ago
                                  (01 Apr 2023)
                                  And run your iob on 'stable' not beta-stage.
                                    @ap2017
                                    19.1 'Tessa' (LTS)
                                    (01 Apr 2023)
                                    ap2017
                                    @thomas-braun Here is what I received from Mint support:
                                    Linux Mint 19.1 has reached end of life 2 months ago, so it's good to upgrade it. SO you'll keep getting security updates again for your software.
                                    The newest version of node.js on Linux Mint is 12 but you can add the NodeSource PPA on Linux Mint 20.x or 21.x to get node.js 18 (or newer). The instructions are here: https://github.com/nodesource/distribut ... /README.md. Use the Ubuntu instructions. So on Linux Mint 20.x or 21.x you would run this to add node.js 18.x:
                                    CODE: SELECT ALL
                                    curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash - &&\
                                    sudo apt-get install -y nodejs
                                    To upgrade from Linux Mint 19.1 to 20.x or 21.x you can follow the instructions here: viewtopic.php?t=235992. First upgrade to 19.3, then to 20 and if you want upgrade further to 20.3 and then 21. You can see till when each release is supported here: https://linuxmint.com/download_all.php.
                                    It will be some work to upgrade, and especially going from 19.3 to 20 is a hassle. Upgrading between major releases is easier and more reliable from 20 to 21. Still, because you're 2 major releases behind it may be recommended to instead do a fresh install of Linux Mint 21.x.
                                    I am wondering if it will be better to switch to different Linux version like Ubuntu. How difficult is to port ioBroker to new Linux installation?
                                    • A ap2017
                                      CODE: SELECT ALL
                                      Easy. Backup your current installation, change your OS to a current distribution (I recommend Debian 12 'Bookworm' for running a server), install a plain ioBroker and install your backup. Very easy with the Backitup-Adapter.
                                      • A ap2017
                                        CODE: SELECT ALL
                                        diffi...what?
                                        backup with backitup
                                        install new OS
                                        install iobroker and the latest recommended node with one line
                                        install vis if you use it, because of an actual bug
                                        restore the backup
                                        drink a cup of coffee or what you prefer
                                        ready
                                          ap2017
                                          @thomas-braun Sounds doable. Just to be safe I will do it on differed solid state drive in my controller.
                                          My system recovered but I see two issues:
                                          1. Not able to start VIS, getting message
                                          File edit.html not found: {}
                                          1. When updating adapters getting error 25. Tried to follow https://forum.iobroker.net/topic/57337/fehler-25-217-oder-enotempty-bei-adapter-install-update/2 still having error 25
                                          Here is additional info:
                                          ap@AP-Tiny:/opt/iobroker$ iobroker list instances
                                          + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admi                            n
                                          + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admi                            n
                                          + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as:                             admin
                                          + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admi                            n
                                          + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonof                            f_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
                                          + instance is alive
