  4. Lay-Z-Spa Wifi Control
210 Beiträge 74 Kommentatoren 110.7k Aufrufe 72 Beobachtet
  • Agria4800A Agria4800
    @agria4800 : Anbei das Script für die Leute mit dem Layz Hawaii oder Maldives (mit den Hydrojet Düsen) ;-)
    // https://forum.iobroker.net/topic/51603/lay-z-spa-wifi-control?_=1655490942180&lang=de
    /*Notes for me
    Last filter change was 0.00 day(s) ago.  RESET Button gedrückt!
    {"CMD":10,"VALUE":0,"XTIME":1658859596,"INTERVAL":0}
    Last chlorine add was 0.00 day(s) ago.
    {"CMD":9,"VALUE":0,"XTIME":1658859652,"INTERVAL":0}
    const Messages =
     "CONTENT": "STATES",
     "LCK": 0,
     "PWR": 0,
     "UNT": 1,
     "AIR": 0,
     "GRN": 0,
     "RED": 0,
     "FLT": 0,
     "TGT": 22,
     "TMP": 13,
     "CH1": 32,
     "CH2": 49,
     "CH3": 51,
     "HJT": 0,
     "BRT": 7
    const ID = '0_userdata.0.Layz-Hydro';
    const MQTTINSTANCE = 0;
    const debug = true;
     "CONTENT": "TIMES",
     "TIME": 1650746370,
     "CLTIME": 1644734714,
     "FTIME": 1644734719,
     "UPTIME": 41660,
     "PUMPTIME": 50,
     "HEATINGTIME": 24,
     "AIRTIME": 512,
     "JETTIME": 4294966,
     "COST": 0,
     "FINT": 4294967295,
     "CLINT": 4294967295,
     "KWH": null,
     "TTTT": -74677
    const STATES=[
           _id: 'LCK',
           type: 'state',
           common: {
               type: 'boolean',
               role: 'switch',
               read: true,
               write: false,
               desc: 'Lazy spa lock'
           native: {}
           _id: 'PWR',
           type: 'state',
           common: {
               type: 'boolean',
               role: 'switch.power',
               read: true,
               write: true,
               desc: 'Lazy spa power'
           native: {}
       _id: 'UNT',
       type: 'state',
       common: {
           type: 'number',
           role: 'value',
           read: true,
           write: true,
           max: 1,
           desc: 'Lazy spa unit',
           states: {
       			0: 'Farenheit',
       			1: 'Celsius'
          native: {}
       _id: 'HJT',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'Lazy spa Hydrojets state'
          native: {}
       _id: 'AIR',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'Lazy spa bubbles state'
       native: {}
       _id: 'GRN',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: false,
           desc: 'reached target temp.'
       native: {}
       _id: 'RED',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: false,
           desc: 'not reached target temp.'
       native: {}
       _id: 'FLT',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'pump state'
       },    native: {}
       _id: 'HEATER',
       type: 'state',
       common: {
           type: 'boolean',
           role: 'switch',
           read: true,
           write: true,
           desc: 'heater state'
       native: {}
       _id: 'TGT',
       type: 'state',
       common: {
           type: 'number',
           role: 'level.temperature',
           min: 20,
           max: 40,
           steps: 1,
           read: true,
           write: true,
           desc: 'taget temp.'
       native: {}
       _id: 'TMP',
       type: 'state',
       common: {
           type: 'number',
           role: 'value.temperature',
           read: true,
           write: false,
           unit: '°C',
           desc: 'temp.'
       native: {}
    init();
    async function stateChange(obj){
       let id = obj.id
       let state = id.split('.').pop()
       let value = obj.state.val
       log('change Unit' + state)
       switch (state) {
           case 'UNT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":1,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('change Unit')
           break;
           case 'TGT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":0,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('change target temp. to '+ value);
           break;
           case 'AIR':
               value = value ? 1: 0 ;
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":2,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set bubbles to '+ value);
           break;
            case 'HJT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":11,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set Hydrojets to '+ value);
           break;
           case 'HEATER':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":3,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set Heater to '+ value);
           break;
           case 'FLT':
               setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":4,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}')
               log('set pump to '+ value);
           break;
     default:
       // Anweisungen werden ausgeführt,
       // falls keine der case-Klauseln mit expression übereinstimmt
       break;
    async function init(){
       await asyncForEach(STATES, async (obj, index) => {
           let id = ID +'.'+ obj._id
           if (!existsState(id)) {
               log('create state '+ id)
               await createStateAsync(id, obj.common)
           else {
               log('skip state '+ id)
           //set subscription
           if(obj.common.write){
               on({id: id, change:"any"} , function(obj) {
                   if(!obj.state.ack){
                       log('change state! '+ JSON.stringify(obj))
                       stateChange(obj)
       log('init done!')
    async function setLazyStates(obj){
       try{
               let states = JSON.parse(obj)
               for (const [key, value] of Object.entries(states)) {
                   let statevalue = value
                   const found = STATES.find(state => state._id === key);
                   if(found){
                       if (found.common.type === 'boolean'){
                           statevalue = value === 1
                       await setStateAsync(ID +'.'+ key,statevalue,true)
               //set heater state
               await setStateAsync(ID +'.HEATER',(states.GRN || states.RED) === 1,true)
       catch(e){
           console.log('Error in setting State '+ e)
    async function asyncForEach(array, callback) {
       for (let index = 0; index < array.length; index++) {
       	await callback(array[index], index, array);
    function log (msg){
       if(debug) console.log (msg)
    on({id:'mqtt.'+ MQTTINSTANCE+'.layzspa.message', change:"ne"} , function(obj) {
       log('Lazyspa reached message! '+ JSON.stringify(obj.state))
       setLazyStates(obj.state.val)
    M
    M
    MiPl
    #73
    @agria4800
    Hallo Agria4800,
    ich habe das Script erfolgreich in Betrieb nehmen können (vielen Dank an die Ersteller). Ich bekomme derzeit alle ca. 4 Sekunden einen Eintrag im Log und eine entsprechende Aktualisierung der Daten, da sich z. B. die (virtuelle) Temperatur minimal ändert. Könnte man hier nicht auf Zentel-Grad Genauigkeit reduzieren, um die Rechnerlast ein wenig runterzufahren? Ich habe von Java Null Check, daher kann ich es nicht machen. Habe mir übergangsweise so geholfen und den Logeintrag auskommentiert. Aber das ist ja nicht Sinn der Sache.
    Danke im Voraus.
    • MeistertrM Meistertr
      Hallo Leute ich arbeite gerade daran meinen Lay-Z-Spa Smarthome kompatibel zu machen. bin da auf ein tolles Projekt gestoßen mit einem Esp8266 Wollte hierfür die Platinen bestellen hat noch jemand zufällig Interesse? Eine Platine alleine ist ein bisschen zu teuer... würde zwischen 6 und 11 Euro liegen die platine je nachdem wieviele es werden...
      Platine : https://easyeda.com/editor#id=a1b94bf9fc01407591a9e0fec6a813b3
      Projekt: https://github.com/visualapproach/WiFi-remote-for-Bestway-Lay-Z-SPA
      Wollte am Wochenende mal ein Testaufbau machen... und werde berichten...
      PS: ich selbst habe einen Palm-Springspcb.jpg
      edit: so ein kleines script habe ich auch dafür:
      const Messages =
        "LCK": 0,
        "PWR": 0,
        "UNT": 1,
        "AIR": 0,
        "GRN": 0,
        "RED": 0,
        "FLT": 0,
        "TGT": 22,
        "TMP": 13,
        "CH1": 32,
        "CH2": 49,
        "CH3": 51,
        "HJT": 0,
        "BRT": 7
      const ID = '0_userdata.0.LazySpa';
      const debug = true;
        "CONTENT": "TIMES",
        "TIME": 1650746370,
        "UPTIME": 41660,
        "PUMPTIME": 50,
        "HEATINGTIME": 24,
        "AIRTIME": 512,
        "JETTIME": 4294966,
        "COST": 0,
        "FINT": 4294967295,
        "KWH": null,
        "TTTT": -74677
      const STATES=[
              _id: 'LCK',
              type: 'state',
              common: {
                  type: 'boolean',
                  role: 'switch',
                  read: true,
                  write: false,
              native: {}
              _id: 'PWR',
              type: 'state',
              common: {
                  type: 'boolean',
                  read: true,
                  write: true,
              native: {}
          _id: 'UNT',
          type: 'state',
          common: {
              type: 'number',
              role: 'value',
              read: true,
              write: true,
              max: 1,
              states: {
      				0: 'Farenheit',
      				1: 'Celsius'
          native: {}
          _id: 'AIR',
          type: 'state',
          common: {
              type: 'boolean',
              role: 'switch',
              read: true,
              write: true,
          native: {}
          _id: 'GRN',
          type: 'state',
          common: {
              type: 'boolean',
              role: 'switch',
              read: true,
              write: false,
          native: {}
          _id: 'RED',
          type: 'state',
          common: {
              type: 'boolean',
              role: 'switch',
              read: true,
              write: false,
          native: {}
          _id: 'FLT',
          type: 'state',
          common: {
              type: 'boolean',
              role: 'switch',
              read: true,
              write: true,
              desc: 'pump state'
          },    native: {}
          _id: 'HEATER',
          type: 'state',
          common: {
              type: 'boolean',
              role: 'switch',
              read: true,
              write: true,
          native: {}
          _id: 'TGT',
          type: 'state',
          common: {
              type: 'number',
              min: 20,
              max: 40,
              steps: 1,
              read: true,
              write: true,
              desc: 'taget temp.'
          native: {}
          _id: 'TMP',
          type: 'state',
          common: {
              type: 'number',
              read: true,
              write: false,
              unit: '°C',
              desc: 'temp.'
          native: {}
      init();
          let id = obj.id
          switch (state) {
              case 'UNT':
                  log('change Unit')
              break;
              case 'TGT':
              break;
              case 'AIR':
              break;
              case 'HEATER':
              break;
              case 'FLT':
              break;
        default:
          break;
              else {
              //set subscription
                      if(!obj.state.ack){
                          stateChange(obj)
          log('init done!')
          try{
                      if(found){
                  //set heater state
          catch(e){
      function log (msg){
      J
      J
      johobo
      #74
      Hi, Ich habe gerade Platinen bestellt. falls also jemand interesse hat gerne melden.
      M J 2 Antworten Letzte Antwort
      • R Rickman
        Also... Ich hätte dann noch 2 fertige Boards für das Model S100101, St. Lucia/Rio.
        Im Moment drucke ich noch die passenden Gehäuse dafür, die wunderbar in die zwei freien Bohrungen neben der Heizung passen.
        Bei eBay werden die für 83,- Euro vertickt, hier für 35,- plus Versand.
        Falls es nicht klappen sollte, weil doch wieder was anders in der Elektronik der Pumpe ist, nehme ich den selbstverständlich wieder zurück. Bei Interesse gerne eine PN an mich.
        EDIT:
        Keiner mehr da...
        Gruß,
        Richy
        J
        J
        johobo
        #75
        @rickman
        würdest du die Dateien für das Gehäuse zur Verfügung stellen? Oder kann ich sie irgendwie auf Thingiverse finden? Danke & Viele Grüße! JoHo
        • M
          M
          mistral0806
          #76
          @johobo Hi, ich habe Interesse. Ist noch eine Platine übrig?
          • J johobo
            M
            M
            Mogedin
            #77
            @johobo suche auch noch eins 😊
            • J johobo
              J
              J
              johobo
              #78
              So, Ich wollte mal von meiner Umsetzung berichten.
              Ich habe den Lay-Z-Spa Miami mit dem >2021er Pumpenmodul.
              Die Platinen waren nach ca. 1,5 Wochen aus China bei mir.
              Bei einem ersten Testaufbau auf Steckbrett hatte ich schon festgestellt, dass ich für meinen Pool die Kabelbelegung 1:1 aufbauen muss, damit es funktioniert. Bei dem Versuch war kein Low-Pass Filter vorhanden und es kam zu keinem Display-Flickern. Zur Sicherheit baute ich dann im ersten Versuch mit Platine den Filter mit ein. Dies führte aber dazu, dass das Display nicht mehr funktionierte. Also bestückte ich eine zweiter Platine ohne filter und es funktionierte einwandfrei.
              Die Einbindung in IO broker lief soweit auch.
              Für den finalen Einbau musste aber noch ein Gehäuse her.
              Ich orientierte mich am Design von @Rickman (Vielen Dank!) und einem Case ohne Halterung von thingiverse. Heraus kam dieses Thing: https://www.thingiverse.com/thing:6061047 mit dem ich auch ziemlich zufrieden bin. Evtl. muss ich hier nochmal eine neuere Version aus ABS erstellen. PLA scheint mir hier bei den Temperaturen etwas kritisch…
              Alles in allem bin ich aber super zufrieden mit dem Projekt und bedanke mich bei euch allen für die Berichte die zu meinem Erfolg beigetragen haben!
              K R E 3 Antworten Letzte Antwort
              • M Marc79
                @naofireblade
                @BruderBleistift
                Meine Platinen von JLCPCB sind gerade auf dem Weg zu mir. Könnte euch gegen eine kleine Beteiligung und die Versandkosten jeweils eine schicken. Interesse?
                Marc
                K
                K
                Klaus.F
                #79
                @marc79 Hallo Marc, hast du noch eine Platine von JLCPCB um einen Bestway Spa Wifi-fähig zu machen
                Viele Grüße
                Klaus
                • J johobo
                  K
                  K
                  Klaus.F
                  #80
                  @johobo
                  Sorry, die Frage geht an alle die evtl. noch eine Platine haben!
                  Würde gerne das Projekt nachbauen
                  Danke im voraus
                  Viele Grüße
                  Klaus
                  • K Klaus.F
                    @johobo
                    Danke im voraus
                    Viele Grüße
                    Klaus
                    J
                    J
                    johobo
                    #81
                    @klaus-f ich habe noch. im Raum Mainz oder Versand
                    E 1 Antwort Letzte Antwort
                    • J johobo
                      E
                      E
                      einarmigerbandit
                      #82
                      @johobo bin auch noch auf der Suche nach einer Platine. Ist noch eine zu haben?
                      • T
                        T
                        ts_482
                        #83
                        Ich würde auch noch eine Platine suchen? Hat jemand noch eine? Bitte PN
                        • T ts_482
                          A
                          A
                          alwo23
                          #84
                          @ts_482 Hi, ich hab gestern erst 5 Bestellt mit Gehäuse wenn Du magst.
                          T F Bernhard BruckmeierB 3 Antworten Letzte Antwort
                          • A alwo23
                            T
                            T
                            ts_482
                            #85
                            @alwo23 danke, aber ich habe schon eine andere bekommen.
                            • T
                              T
                              ts_482
                              #86
                              wo bestellt ihr die Restliche Hardware?
                              ESP8266 NodeMCU + TXS0108E
                              und habt ihr eine Liste was genau noch benötigt wird?
                              • A alwo23
                                F
                                F
                                Forst89
                                #87
                                @alwo23 Hi, ich hätte Interesse an einer Platine und würde mich dann auch mal an das Projekt wagen :-) Hast du von den anderen benötigen Komponenten zufällig auch noch übrig umd das Set zu kompletieren?
                                • M MezzoDO
                                  Guten Abend zusammen!
                                  Gibt's hier fachkundige Leute zu diesem Projekt, die mir bei meinem Problem helfen könnten?
                                  Ich hab die PCB V1 Platine und wollte einen BAHAMAS mit der Pumpe S100101 mit dem Modul ausstatten.
                                  Zusammengebaut mit dem blauen Level Converter, der laut Instructions bestätigt funktionieren soll. Zudem habe ich in meiner Verzweiflung auch versucht die 560 Ohm Widerstände an die Datenleitungen 3,4 & 5 zum Display zu löten.
                                  Laut GitProject soll das Modell MIAMI2021 gewählt werden, was ich auch eingestellt und hochgeladen habe (PlatformIO Upload, Build Filesystem und Upload Filesystem).
                                  Die WebUI lässt sich soweit auch aufrufen und konfigurieren, allerdings bleibt das Display der Pumpe dunkel und Bedienung ist weder Am Display noch per WebUI möglich.
                                  Alles was ich sehe ist die (vermeintlich korrekte) Temperatur per WebUI.
                                  Habe alles gemäß Anleitung mehr als fünf mal gecheckt. Vielleicht findet sich jemand, der mir helfen kann :(
                                  tvtotalT
                                  tvtotalT
                                  tvtotal
                                  #88
                                  @mezzodo
                                  habe das gleiche Problem wie @MezzoDO Model S100101 Display tot macht aber eigenartige Pieptöne.
                                  Webinterface aufrufbar, jedoch keine Schaltfunktion möglich.
                                  Nutze die PCB v1 Verdrahtung überprüft finde aber keinen Fehler, Bild von @Rickman überprüft.
                                  Hat noch jemand einen Tipp ?😞
                                  Synology iobroker / Arduino Mega / CCU2 / Loxone Miniserver / Pokeys57e
                                  R 1 Antwort Letzte Antwort
                                  • tvtotalT tvtotal
                                    @mezzodo
                                    R
                                    R
                                    Rickman
                                    #89
                                    @tvtotal
                                    Das Problem hatte ich Anfangs auch mit totem Display und Pieptönen.
                                    Meine Verdrahtung sieht aber ein wenig anders aus - habe allerdings auch das v2- Board...
                                    Schau mal hier:
                                    • Stefan M.S
                                      Stefan M.S
                                      Stefan M.
                                      #90
                                      Hallo allerseits! :-) Ich bin neu hier und möchte ebenfalls meinen bestway-Whirlpool mit Wifi aufrüsten.
                                      Sollte noch jemand eine V2-Platine, vielleicht sogar einen Kabelsatz übrig haben, würde ich mich über PN freuen.
                                      Stefan
                                      • Jan MJ
                                        Jan MJ
                                        Jan M
                                        schrieb am zuletzt editiert von Jan M
                                        #91
                                        Hallo Leute, möchte meinen Pool auch aufrüsten. Würde auch noch eine Platine brauchen. Kannst mir bitte eine schicken. @alwo23 oder jemand anders. Danke Lg
                                        • A alwo23
                                          Bernhard Bruckmeier
                                          #92
                                          @alwo23 Hey, ich hab Interesse an eine Platine, hast du noch eine?
                                          33.2k
                                          84.3k
