  4. Test Adapter Awtrix-Light (Awtrix 3)
2.2k Beiträge 167 Kommentatoren 1.5m Aufrufe 141 Beobachtet
    @atomicix sagte in Test Adapter Awtrix-Light:
    und dann wir immer immer nur "undefined °C" angezeigt. Also wird nur die Zahl nicht übertragen.
    Bitte ein Debug-Log teilen.
    M Online
    M Online
    mrjeschke
    #437
    @haus-automatisierung
    Bei mir ist es die app temperature. Die anderen beiden laufen über alias.
    2023-06-08 19:52:14.235 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/stats" without data
    2023-06-08 19:52:14.290 - debug: awtrix-light.0 (7415) received 200 response from "/api/stats" with content: {"bat":97,"bat_raw":660,"lux":"8","ldr_raw":547,"ram":152948,"bri":120,"temp":"25","hum":"29","uptime":"76","wifi_signal":-41,"up_available":false,"messages":1,"version":"0.68","indicator1":true,"indicator2":false,"indicator3":true}
    2023-06-08 19:52:14.342 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/settings" without data
    2023-06-08 19:52:14.389 - debug: awtrix-light.0 (7415) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":31,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":65535,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
    2023-06-08 19:53:00.624 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "temperatur" with icon "6157" and text "%s"
    2023-06-08 19:53:00.625 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=temperatur" with data: {"text":"undefined","icon":"6157","duration":5}
    2023-06-08 19:53:00.753 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=temperatur" with content: "OK"
    2023-06-08 19:53:08.038 - warn: javascript.0 (479) script.js.common.Awtrix-Test: Neuer Wert: 18.95
    2023-06-08 19:53:08.038 - warn: javascript.0 (479) script.js.common.Awtrix-Test: Zeitstempel: 19:53:08.036
    2023-06-08 19:53:08.038 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "test" with icon "6157" and text "%s"
    2023-06-08 19:53:08.038 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=test" with data: {"text":"18.95","icon":"6157","duration":5}
    2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) [refreshCustomApp] Refreshing custom app "nocheintest" with icon "null" and text "%s %u"
    2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) [refreshCustomApp] formatted value of "alias.0.Wetter.Wetter2" from 18.95 to 18,95 (2 decimals)
    2023-06-08 19:53:08.039 - debug: awtrix-light.0 (7415) sending "POST" request to "/api/custom?name=nocheintest" with data: {"text":"18,95 °C","icon":null,"duration":5}
    2023-06-08 19:53:08.040 - debug: awtrix-light.0 (7415) [onStateChange] ignoring customApps state change of "openweathermap.0.forecast.current.temperature" to 18.95 - refreshes too fast (within 0 seconds)
    2023-06-08 19:53:08.124 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=test" with content: "OK"
    2023-06-08 19:53:08.179 - debug: awtrix-light.0 (7415) received 200 response from "/api/custom?name=nocheintest" with content: "OK"
    2023-06-08 19:53:14.235 - debug: awtrix-light.0 (7415) refreshing device state
    2023-06-08 19:53:14.236 - debug: awtrix-light.0 (7415) re-creating refresh state timeout
    2023-06-08 19:53:14.236 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/stats" without data
    2023-06-08 19:53:14.363 - debug: awtrix-light.0 (7415) received 200 response from "/api/stats" with content: {"bat":97,"bat_raw":660,"lux":"8","ldr_raw":539,"ram":151340,"bri":120,"temp":"25","hum":"29","uptime":"137","wifi_signal":-38,"up_available":false,"messages":3,"version":"0.68","indicator1":true,"indicator2":false,"indicator3":true}
    2023-06-08 19:53:14.412 - debug: awtrix-light.0 (7415) sending "GET" request to "/api/settings" without data
    2023-06-08 19:53:14.432 - debug: awtrix-light.0 (7415) received 200 response from "/api/settings" with content: {"FPS":23,"ABRI":true,"BRI":120,"ATRANS":true,"TCOL":31,"TSPEED":400,"ATIME":7000,"TFORMAT":"%H:%M:%S","DFORMAT":"%d.%m.%y","SOM":true,"CEL":true,"BLOCKN":false,"MAT":0,"SOUND":true,"GAMMA":0,"UPPERCASE":true,"CCORRECTION":"","CTEMP":"","WD":true,"WDCA":65535,"WDCI":27501,"TIME_COL":0,"DATE_COL":0,"HUM_COL":0,"TEMP_COL":0,"BAT_COL":0}
    • R reini
      heute auch das Teil geliefert bekommen und direkt geflasht - find ich klasse das Gerät in Kombination mit dem Adapter hier, danke Matthias 👍
      stellt gerne mal eure Design rein als Inspiration was man so alles anzeigen lassen kann, außer die Klassiker PV etc 😁
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      #438
      @reini
      • ebenfalls Anrufer per Fritzbox
      • wenn mein Zwerghamster "aktiv" wird :)
      • aktueller Filmtitel über PLEX
      • Begrüßungen wenn eine bekannte Person dem Netzwerk beitritt
      • wenns an der Tür klingelt
      • usw... ;)
      Lehrling seit 1975 !!!
        AtomicIXA Offline
        AtomicIXA Offline
        AtomicIX
        schrieb am zuletzt editiert von AtomicIX
        #439
        awtrix-light.0
        2023-06-09 14:32:50.974	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:32:50.909	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"49°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:32:50.909	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.6 to 49 (0 decimals)
        awtrix-light.0
        2023-06-09 14:32:50.909	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:32:31.633	debug	received 200 response from "/api/stats" with content: {"bat":65,"bat_raw":600,"lux":"1289","ldr_raw":1019,"ram":150840,"bri":120,"temp":"36","hum":"14","uptime":"2474","wifi_signal":-85,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:32:31.559	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:32:31.558	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:32:31.558	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:31:50.966	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:31:50.852	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:31:50.851	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.4 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:31:50.851	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:31:35.915	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:31:35.882	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"49°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:31:35.882	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.5 to 49 (0 decimals)
        awtrix-light.0
        2023-06-09 14:31:35.881	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:31:31.614	debug	received 200 response from "/api/stats" with content: {"bat":67,"bat_raw":603,"lux":"2814","ldr_raw":1021,"ram":151068,"bri":120,"temp":"36","hum":"14","uptime":"2414","wifi_signal":-82,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:31:31.558	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:31:31.558	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:31:31.557	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:31:03.249	debug	received 200 response from "/api/custom?name=aussen" with content: "OK"
        awtrix-light.0
        2023-06-09 14:31:03.136	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 29.2 - refreshes too fast (within 1 seconds)
        awtrix-light.0
        2023-06-09 14:31:03.132	debug	sending "POST" request to "/api/custom?name=aussen" with data: {"text":"undefined °C","icon":"4285","duration":5}
        awtrix-light.0
        2023-06-09 14:31:03.132	debug	[refreshCustomApp] Refreshing custom app "aussen" with icon "4285" and text "%s %u"
        admin.0
        2023-06-09 14:30:45.262	info	<== Disconnect system.user.admin from ::ffff:192.168.222.155 admin
        awtrix-light.0
        2023-06-09 14:30:31.606	debug	received 200 response from "/api/stats" with content: {"bat":66,"bat_raw":601,"lux":"7572","ldr_raw":1022,"ram":150844,"bri":120,"temp":"36","hum":"14","uptime":"2354","wifi_signal":-82,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:30:31.557	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:30:31.556	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:30:31.556	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:30:20.960	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:30:20.858	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:30:20.858	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.4 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:30:20.857	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:29:31.604	debug	received 200 response from "/api/stats" with content: {"bat":64,"bat_raw":598,"lux":"7033","ldr_raw":1022,"ram":151112,"bri":120,"temp":"36","hum":"14","uptime":"2294","wifi_signal":-83,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:29:31.556	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:29:31.555	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:29:31.555	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:28:50.947	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:28:50.854	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:28:50.853	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.3 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:28:50.853	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:28:35.999	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:28:35.878	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:28:35.878	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.2 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:28:35.878	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:28:32.028	debug	re-creating history apps timeout (300 seconds)
        awtrix-light.0
        2023-06-09 14:28:31.600	debug	received 200 response from "/api/stats" with content: {"bat":64,"bat_raw":598,"lux":"7572","ldr_raw":1022,"ram":151116,"bri":120,"temp":"36","hum":"14","uptime":"2234","wifi_signal":-83,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:28:31.554	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:28:31.553	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:28:31.553	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:27:31.589	debug	received 200 response from "/api/stats" with content: {"bat":65,"bat_raw":600,"lux":"7572","ldr_raw":1022,"ram":151112,"bri":120,"temp":"36","hum":"14","uptime":"2174","wifi_signal":-81,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:27:31.552	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:27:31.551	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:27:31.551	debug	refreshing device state
        awtrix-light.0
        2023-06-09 14:27:20.937	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:27:20.872	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:27:20.872	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.3 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:27:20.872	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:27:05.999	debug	received 200 response from "/api/custom?name=dusche" with content: "OK"
        awtrix-light.0
        2023-06-09 14:27:05.866	debug	sending "POST" request to "/api/custom?name=dusche" with data: {"text":"48°C","icon":"9840","duration":5}
        awtrix-light.0
        2023-06-09 14:27:05.866	debug	[refreshCustomApp] formatted value of "sonoff.0.Dusche.DS18B20_Temperature" from 48.2 to 48 (0 decimals)
        awtrix-light.0
        2023-06-09 14:27:05.866	debug	[refreshCustomApp] Refreshing custom app "dusche" with icon "9840" and text "%s%u"
        awtrix-light.0
        2023-06-09 14:26:31.695	debug	received 200 response from "/api/stats" with content: {"bat":66,"bat_raw":601,"lux":"7033","ldr_raw":1022,"ram":151564,"bri":120,"temp":"36","hum":"13","uptime":"2114","wifi_signal":-85,"up_available":false,"messages":0,"version":"0.67","indicator1":false,"indicator2":false,"indicator3":false}
        awtrix-light.0
        2023-06-09 14:26:31.550	debug	re-creating refresh state timeout
        awtrix-light.0
        2023-06-09 14:26:31.549	debug	sending "GET" request to "/api/stats" without data
        awtrix-light.0
        2023-06-09 14:26:31.549	debug	refreshing device state```
        • M Online
          M Online
          MCU
          #440
          @nordlicht67 Es gibt trotzdem weiterhin die Möglichkeit die Standard-Apps per javascript auszuschalten, wenn man sie nicht im Menu dauerhaft ausstellen möchte.
          Ein Bespiel:
          let ipaddress = '192.168.178.xxx';
          // show: false -> aus; true -> an
          // name anpassen : time, date, temp, hum, bat, eyes
          exec((['curl -X POST ','-d  "[{ name: \'time\', show: false }]" ','-H \'Content-Type: application/json\' ','\'http://'+ipaddress+'/api/apps\''].join('')));
          • R Offline
            reini
            schrieb am zuletzt editiert von reini
            #441
            würde es noch Sinn machen jeder benutzerdefinierten App einen eigenen Farbcode mitgeben zu können? Kann das der Adapter aussteuern?
            • R reini
              haus-automatisierungH Offline
              #442
              @reini sagte in Test Adapter Awtrix-Light:
              Ich brauche es nicht, daher habe ich die Fleißarbeit erstmal nicht gemacht :) Aber ja, kann ich noch einbauen
              📚 Meine Dokumentation
              • AtomicIXA AtomicIX
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                admin.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                awtrix-light.0
                #443
                @atomicix Mh, das sieht aber erstmal so aus als ob alles klappt? Kam in dem Durchlauf wieder ein "undefined"?
                AtomicIXA 2 Antworten Letzte Antwort
                • R Offline
                  reini
                  #444
                  noch ne blöde Frage, was macht Ihr am Abend mit den Ding? Ein setzen von Display/Power auf false hat bei mir keinerlei Auswirkung?! Möchte das Gerät ja nicht die ganze Nacht on haben sondern per Skript steuern..
                  DJMarc75D haus-automatisierungH 2 Antworten Letzte Antwort
                    AtomicIXA Offline
                    AtomicIXA Offline
                    AtomicIX
                    #445
                    Ja, wenn es erst mal da ist, bleibt es, bis zum Neustart. Dann ist wieder kurz alles gut, und dann bleibt es. Aber nur bei aussen (netatmo), die Dusche (sonoff) ist alles super.
                    • R reini
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #446
                      Dann machst Du halt was falsch. Wie setzt Du den DP genau ?
                      • R reini
                        #447
                        Auch hier: Debug-Log bitte :) Dass Du States unbestätigt (ack: false) schreiben musst ist hoffentlich klar?
                          Anrufer auf der FritzBox laufen hier bei mir durch.
                          erfggi
                          #448
                          @thomas-braun sagte in Test Adapter Awtrix-Light:
                          hast du einen Tipp wie das als App geht? ich bekomme das nicht hin.
                          • E erfggi
                            #449
                            @erfggi
                            Nicht als App, sondern als Blockly. Gibt einen passenden Baustein zu awtrix.
                            • E Offline
                              erfggi
                              #450
                              Danke! gefunden und funktioniert.
                              tobasiumT 1 Antwort Letzte Antwort
                                AtomicIXA Offline
                                AtomicIXA Offline
                                AtomicIX
                                #451
                                Hier noch mal ein auszug aus dem Log, Also Netatmo aktualisiert alle 10 min
                                Gefiltert nur auf Netatmo
                                awtrix-light.0
                                2023-06-09 21:41:03.042	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.2 - refreshes too fast (within 1 seconds)
                                awtrix-light.0
                                2023-06-09 21:31:03.010	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.5 - refreshes too fast (within 1 seconds)
                                awtrix-light.0
                                2023-06-09 21:21:03.005	debug	[onStateChange] ignoring customApps state change of "netatmo.0.5f451b174be7c35c0a5ef69f.70-ee-50-5e-d1-d4.02-00-00-8d-d2-46.Temperature.Temperature" to 21.8 - refreshes too fast (within 1 seconds)
                                EDIT:
                                Also das mit dem zusätzlichen Datenpunkt als Merker, wo die Temperaturen übertragen werden, läuft ohne Probleme. Was mir da nur aufgefallen ist, ich habe die Dezimal Stellen für die Cutom App auf 0 stehen.
                                Wenn ich den original Netatmo Datenpunkt nehme, wird das auch so angezeigt, wenn ich den Merker Datenpunkt nehme, habe ich eine Dezimal Stelle, ohne die Einstellungen zu ändern. Es wird ein "Punkt" angezeigt. Der Netatmo Datenpunkt ein ein Komma
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #452
                                  ich kann die standard apps nicht mehr auschalten..
                                  batt, date, eyes brauch ich nicht..
                                  • arteckA arteck
                                    Ben1983B Offline
                                    Ben1983B Offline
                                    Ben1983
                                    #453
                                    @arteck Mach es am besten direkt über die Uhr an den Tasten, funktioniert top.
                                    • Ben1983B Ben1983
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #454
                                      @ben1983 das hab ich gerade auch gemacht.... danke
                                        awtrix-light.0
                                        awtrix-light.0
                                        awtrix-light.0
                                        EDIT:
                                        #455
                                        Ich verstehe nicht ganz? Dann ist das eine wohl vom Objekttyp string und das andere eine number? Generell werden numerische Werte immer mit einem Punkt als Trennzeichen gespeichert, aber der Admin zeigt das entsprechend deiner Konfiguration an (also macht aus dem Punkt dann ein Komma falls so in den Einstellungen festgelegt). Zeig mal bitte wie die beiden Objekte definierte sind.
                                        AtomicIXA 1 Antwort Letzte Antwort
                                        • M mrjeschke
                                          @atomicix
                                          Ich habe momentan das gleiche Problem. Nach einem Neustart des Adapters funktioniert es.
                                          Sobald der DP das erste mal aktualisiert wird, steht im Display undefined.
                                          Im log sehe ich dann ein refreshes too fast.
                                          Der DP wird bei mir aber nur alle 15 Minuten aktualisiert.
                                          Wenn ich ein alias auf diesen DP erstelle und mir diesen anzeigen lasse funktioniert es komischerweise.
                                          cacherwolf
                                          schrieb am zuletzt editiert von cacherwolf
                                          #456
                                          @mrjeschke
                                          @mrjeschke said in Test Adapter Awtrix-Light:
                                          @atomicix
                                          Ich habe auch zwei DP der nicht aktualisiert wird, auch der Umweg über den Alias funktioniert bei mir nicht.
                                          Das sind beides Werte die aus einem JS-Script kommen, die Werte die direkt aus dem Sonoff Adapter kommen werden aktualisiert.
